    Has anyone used the placeholders with Ideamaker in RRF?
    654
      A Former User @fcwilt
      @fcwilt said in Has anyone used the placeholders with Ideamaker in RRF?:
      @the_dragonlord
      Here it is.
      The global variables are actually created in config.g and then used in this code.
      I included the lines that create the global variables (commented out) as a reference.
      ; layer_change.g
      *** THIS IS THE CODE THAT IS IN CONFIG.G TO CREATE THE VARIABLES - INITIAL/DEFAULT VALUES ARE SHOWN ***
      *** THE CODE IN CONFIG.G WOULD, OF COURSE, NOT BE COMMENTED OUT AS IT IS HERE ***
      ; global g_pa_setting        = 0          ; the current pressure advance setting
      ; global g_pa_increment      = 0.05       ; the amount to increment the pressure advance setting
      ; global g_pa_layer_count    = 25         ; the number of layers to count to cause the incrementing of the pressure advance setting
      ; global g_pa_layer_counter  = 0          ; the current layer count
      *** THIS IS THE CODE THAT USES THE GLOBAL VARIABLES TO COUNT LAYER CHANGES AND INCREASE THE PA SETTING ***
      if global.g_pa_layer_count > 0
        ; if the layer counter is 0 reset it to the layer count value
        ; otherwise decrement the layer counter by 1
        if global.g_pa_layer_counter = 0
          set global.g_pa_layer_counter = {global.g_pa_layer_count}
        else
          set global.g_pa_layer_counter = {global.g_pa_layer_counter} - 1
          ; if the layer counter is now 0 increment the pressure advance setting by the pressure advance increment
          ; echo the current pressure advance setting just to keep track - doesn't need to be done
          ; apply the new pressure advance setting with M572
            set global.g_pa_setting = {global.g_pa_setting} + {global.g_pa_increment}
            echo global.g_pa_setting
            M572 D0 S{global.g_pa_setting}
      Thanks!
        @the_dragonlord
        Here it is.
        ; layer_change.g
          else
        Same error message even with your commands...I'm starting to think that maybe I have some setting wich avoid me to dinamically adjust the PA via GCODE....is it possible?
        fcwiltundefined 2 Replies Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @A Former User
          @the_dragonlord
          What firmware version are you using?
          • fcwiltundefined
            @the_dragonlord
            Do you have an extruder 0?
              @the_dragonlord
              the latest
                @the_dragonlord
                yes, I have two extruders but for this calibration I'm using only one
                • fcwiltundefined
                  @the_dragonlord
                  And you can issue a M572 in the DWC Console without an error appearing?
                    @the_dragonlord
                    yes, but maybe i've figured it out....in my original layer change gcode in my slicer there were another comand before M98, I've deleted it and now it seems to work (for now)
                    Thanks!!!
                    • fcwiltundefined
                      @the_dragonlord said in Has anyone used the placeholders with Ideamaker in RRF?:
                      @the_dragonlord
                      Thanks!!!
                      Get back to me if you have any problem with my code - it worked well for me with firmware 3.3
                      A Former User? 2 Replies Last reply Reply Quote 0
                        @the_dragonlord
                        Thanks!!!
                        I will! Thanks a lot again Frederick!
                          @the_dragonlord
                          Thanks!!!
                          just for asking....what kind of object do you print to set the PA? A cube or some other model?
                          • fcwiltundefined
                            Well the documentation said to print a cube with the seam in the center of one face but I could not get that to work.
                            PA Documentation
                            So I printed a simple cylinder which clearly showed the effect of the changing PA setting but some folks here said that shape was a waste time and suggested different things to try.
                            My take is that I am printing actual printer parts, like the cylinder, and if PA doesn't benefit things I actually need to print then what good is it to me.
                            Still I found a setting that made a slight improvement (the seam was smoother) and I use that.
                            BUT I use Zesty Nimble remote drive extruders and they don't benefit as much from PA as do Bowden tube setups.
                              PA Documentation
                              I've printed the object you see in the pic (with some "spikes" to see the sharp corners), I've started from 0 and gone to 1,9.....I see no differences between different settings...should I go further with the settings (more than 2) or maybe I've some other setting wich are not ok in your opinion (jerk, acceleration etc)...I have a configuration with a 37cm bowden
                              • fcwiltundefined
                                @the_dragonlord
                                Well the docs say for Bowden tube setups the starting point would be 0.5 and up.
                                It certainly cannot hurt to test a wider range.
                                Here is my first run and you can clearly see PA affecting the print - I think I tested in 0.05 steps - but it's been awhile.
                                First PA Run
                                I then went back and tested in 0.01 steps and 0.05 produced the smoothest seam.
                                In any case using 0.05 produces objects that meet all my needs even if my testing is seriously flawed.
                                  @the_dragonlord
                                  First PA Run
                                  0.05??? I'm testing until 1.9 with no result 😁
                                    @the_dragonlord
                                    First PA Run
                                    what slicer are you using?
                                    • fcwiltundefined
                                      @the_dragonlord
                                      Simplify3D
                                      • fcwiltundefined
                                        @the_dragonlord
                                        Did you leave that echo command in and verify that the setting seemed to be changing as expected?
                                          @the_dragonlord
                                          Yes, I've runned the M572 command to verify
