Has anyone used the placeholders with Ideamaker in RRF?
@fcwilt said in Has anyone used the placeholders with Ideamaker in RRF?:
@the_dragonlord
What firmware version are you using?
the latest
@the_dragonlord
Do you have an extruder 0?
yes, I have two extruders but for this calibration I'm using only one
@the_dragonlord
And you can issue a M572 in the DWC Console without an error appearing?
@the_dragonlord
yes, but maybe i've figured it out....in my original layer change gcode in my slicer there were another comand before M98, I've deleted it and now it seems to work (for now)
Thanks!!!
@the_dragonlord said in Has anyone used the placeholders with Ideamaker in RRF?:
@the_dragonlord
Thanks!!!
Get back to me if you have any problem with my code - it worked well for me with firmware 3.3
@the_dragonlord
Thanks!!!
I will! Thanks a lot again Frederick!
@the_dragonlord
Thanks!!!
just for asking....what kind of object do you print to set the PA? A cube or some other model?
Well the documentation said to print a cube with the seam in the center of one face but I could not get that to work.
So I printed a simple cylinder which clearly showed the effect of the changing PA setting but some folks here said that shape was a waste time and suggested different things to try.
My take is that I am printing actual printer parts, like the cylinder, and if PA doesn't benefit things I actually need to print then what good is it to me.
Still I found a setting that made a slight improvement (the seam was smoother) and I use that.
BUT I use Zesty Nimble remote drive extruders and they don't benefit as much from PA as do Bowden tube setups.
I've printed the object you see in the pic (with some "spikes" to see the sharp corners), I've started from 0 and gone to 1,9.....I see no differences between different settings...should I go further with the settings (more than 2) or maybe I've some other setting wich are not ok in your opinion (jerk, acceleration etc)...I have a configuration with a 37cm bowden
@the_dragonlord
Well the docs say for Bowden tube setups the starting point would be 0.5 and up.
It certainly cannot hurt to test a wider range.
Here is my first run and you can clearly see PA affecting the print - I think I tested in 0.05 steps - but it's been awhile.
I then went back and tested in 0.01 steps and 0.05 produced the smoothest seam.
In any case using 0.05 produces objects that meet all my needs even if my testing is seriously flawed.
@the_dragonlord
0.05??? I'm testing until 1.9 with no result
@the_dragonlord
what slicer are you using?
@the_dragonlord
Simplify3D
@the_dragonlord
Did you leave that echo command in and verify that the setting seemed to be changing as expected?
@the_dragonlord
Yes, I've runned the M572 command to verify
