RRF configuration using object model notation
Firmware wishlist
    zapta
    TL;DR, allow RRF configuration using a human friendly object model notation.
    RRF has now a nice object model and format that allows humans to easily read its state
    https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
    However, writing to the object model (e.g. in config.g) is still done with cryptic gcode based setters.
    Being able to also configure with object model notation would make RRF configuration more intuitive and less error prone. Here is one example how this can be done, using the indented block construct currently used for conditions and loops:
    M???
    move.axes [
    "letter": "X",
    "max": 200,
    "min": 0,
    "visible": true
    "letter": "Y",
    "max": 200,
    "min": 0,
    "visible": true
    EDIT: Some ideas may be borrowed from GCL. It's a similar language to construct structured configurations but with more bells and whistles https://gcl.readthedocs.io/en/latest/introduction.html#vision
    undefined 1 Reply Last reply 27 Aug 2021, 18:01 Reply Quote 0
      fcwilt @zapta
      @zapta
      Way too much typing.
      If that was an alternate way fine but don't force everyone to generate that much code.
      Just my 2 cents - well given inflation maybe that should be 4 cents.
      undefined 1 Reply Last reply 27 Aug 2021, 18:55 Reply Quote 0
        zapta @fcwilt
        @fcwilt, think of all the comments it will save.
        undefined undefined 2 Replies Last reply 27 Aug 2021, 18:56 Reply Quote 1
          fcwilt @zapta
          @zapta said in RRF configuration using object model notation:
          True enough.
            engikeneer @zapta
            Wait, you guys are commenting your gcode? 😛
            i3 clone with a bunch of mods
            undefined 1 Reply Last reply 28 Aug 2021, 01:18 Reply Quote 5
              fcwilt @engikeneer
              @engikeneer
              I was a programmer for 30+ years.
              Lots and lots of comments, more comments than code.
              • undefined zapta referenced this topic 9 Apr 2022, 13:42
              6 out of 6
