    #- (hash) printer with super simple gantry
    Example setups and prints
    anti-racking dual roller constraint hash printer
    11
    65
    6.4k
    • mrehorstdmdundefined
      mrehorstdmd @o_lampe
      @o_lampe oh yeah, I remember now. Never mind...
      • o_lampeundefined
        o_lampe
        First Toolholder for an E3D heatsink. I can add a sherpa mini or bowden extruder.
        • o_lampeundefined
          o_lampe
          I've installed two beam braker endstops and wrote homing files.
          They work fine, when called independently, but using homeall throws an error. "Failed to enable endstops"
          Here's a homing file (check out, how I define/invert and delete the endstop)
          ; homeU.g
          M574 U2 S1 P"Xmax"   ; change endstop
          M400
          G91              ; relative positioning
          ;G1 H2 Z5 F6000   ; lift Z relative to current position
          G1 H1 U295 F6000 ; move quickly to X axis endstop and stop there (first pass)
          M574 U2 S1 P"!Xmax"   ; change endstop
          M400
          G1 H1 U29 F360  ; move slowly to x axis endstop once more (second pass)
          G92 U0
          ;G1 H2 Z-5 F6000  ; lower Z again
          G90              ; absolute positioning
          M574 U2 S1 P"Nil"   ; delete endstop
          M400
          G1 U-130 F24000
          Homeall just calles all macros one by one, so where's my mistake?
          ; homeall.g
          ; called to home all axes
          m98 p"homeX.g"
          m98 p"homeY.g"
          m98 p"homeU.g"
          m98 p"homeV.g"
          ;G1 Z5 F100           ; lift Z relative to current position
          RRF3.3.0_6 on a F407ZG controller
          Here's a pic of the endstop with the extra cutout
          cosmowaveundefined 1 Reply Last reply Reply Quote 0
          • cosmowaveundefined
            cosmowave @o_lampe
            @o_lampe what's in your other home macros? Can you please post them?
            Mankati FSXT+, DeltaTowerV2, E3D MS/TC
            • o_lampeundefined
              o_lampe @cosmowave
              @cosmowave they're almost the same, except the specific parking positions and neg/pos signs of the homing moves.
              ; homeV.g
              M574 V2 S1 P"ymax"   ; define endstop
              M400
              G1 H1 V-295 F6000 ; move quickly to Y axis endstop and stop there (first pass)
              M574 V2 S1 P"!ymax"   ; invert endstop
              M400
              G1 H1 V-29 F360  ; move slowly to Y axis endstop once more (second pass)
              G92 V0
              M574 V2 S1 P"nil"   ; delete endstop
              M400
              G1 V170 F24000
              ; homeX.g
              M574 X2 S1 P"Xmax"   ; change endstop
              M400
              G1 H1 X295 F6000 ; move quickly to x axis endstop and stop there (first pass)
              M574 X2 S1 P"!Xmax"   ; change endstop
              M400
              G1 H1 X29 F360  ; move slowly to x axis endstop once more (second pass)
              G92 X0
              M574 X2 S1 P"Nil"   ; delete endstop
              M400
              G1 X-185 F24000
              ; homey.g
              M574 Y2 S1 P"ymax"   ; change endstop
              M400
              G1 H1 Y295 F6000 ; move quickly to Y axis endstop and stop there (first pass)
              M574 Y2 S1 P"!ymax"   ; change endstop
              M400
              G1 H1 Y29 F360  ; move slowly to Y axis endstop once more (second pass)
              G92 Y0
              M574 Y2 S1 P"Nil"   ; delete endstop
              M400
              G1 Y-174 F24000
                cosmowave @o_lampe
                @o_lampe I'm not sure if the command M400 after setting/deleting the endstop will work correctly!? Perhaps it helps to change it to a short delay with G4?
                • o_lampeundefined
                  o_lampe @cosmowave
                  that's funny: I send m98 P"homeall.g" and no error pops up, I reset the printer and send "G28" and the error is back.
                  @cosmowave m400 or g4 p100 made no difference, G4 only slows things down
                  • fcwiltundefined
                    fcwilt @o_lampe
                    @o_lampe
                    Just out of curiosity why do you need to change the way the endstop works between the first and second pass?
                    • o_lampeundefined
                      o_lampe @fcwilt
                      @fcwilt
                      there's a cutout at the center of the tongue that triggers the endstop during the slow pass.
                      The first pass detects the left or right edge of the tongue, then I invert the logic of the endstop and do the second pass. That way both tools set their homing point to the center of their tongue.
                      It's not mandatory to do it that way. Later, I have to fine tune the 0,0 position of every tool anyway.
                      • fcwiltundefined
                        fcwilt @o_lampe
                        @o_lampe said in #- (hash) printer with super simple gantry:
                        @fcwilt
                        Could you arrange homing so that the sensor was not triggered after homing was complete?
                        If so it would seem you could connect the sensor to two different inputs and not have to deal with changing the endstop settings.
                        • o_lampeundefined
                          o_lampe @fcwilt
                          @fcwilt said in #- (hash) printer with super simple gantry:
                          Sounds, like it would provoke false triggers to the not_homed axis or raising a endstop hit flag ?
                          The correct way seems to be to completely undefine the endstop to make it usable for the next tool.
                          • fcwiltundefined
                            fcwilt @o_lampe
                            Well unless there is a G1 H1 move underway for a given axis I've never seen endstop activation have any effect.
                            Though I think I will do some tests just for fun.
                            • o_lampeundefined
                              o_lampe
                              Another update.
                              I thought the triple Z-axis/bed frame would be a piece of cake to build, but it was tricky to find a place for steppers and belt-idlers.
                              It ended up in an ugly mess, but I'd have to redesign almost the whole printer to get it right. It's working, so I keep it as is until I find a real reason to rebuild it.
                              Pretty compact carrier
                              Top view. All tools are outside of the bed, which will be mounted above the frame. The 500x500 outside dimension shrinks to 300x300 working area, but that was expected.
                              The third Z-stepper needs an appendix to clear the tool path and still stabilize the far end of the cantilevered bed frame.
                              • o_lampeundefined
                                o_lampe
                                I want to design a tripod bed mount where the bed rests on three ballstuds sliding on dowel-pins to allow temp-expansion.
                                I"ve seen this on other printers, but I'm unsure about the angles of the dowel pins?
                                Q: Should they aim to the bed-center, or should I place them at equal angles?
                                Here's a sketch of the angles in question
                                • o_lampeundefined
                                  o_lampe
                                  I went for Maxwell temp-expansion layout, simply because I couldn't make up a way to fix one side without melting the bracket.
                                  Now I've used Haydn's ballstuds and 4mm PTFE tube as dowel pins. I guess that PTFE keeps the heat away from the brackets, better than (stainless) steel dowel pins.
                                  I also filled the PTFE tube with pieces of wooden toothpicks to avoid sinking balls (pun intended)
                                  PS: magnets will arrive monday, I hope they fit in their pocket.
                                  • fcwiltundefined
                                    fcwilt @o_lampe
                                    @o_lampe
                                    I did something like your setup but my rear support is a ball-stud sitting in a cup.
                                    • mikeabuilderundefined
                                      mikeabuilder
                                      We're using kinematic supports for the heated bed on a large printer we are designing at my local maker space. We started with the classic steel ball and parallel rod design, but questioned the steel rods. They provide a parallel point landings for the steel ball. This means that the round cross section is not important - the steel ball touches only at a point. After trying a few things we opted for two small rectangular steel plates (1.5mm thick) that we files a 45 degree slope on. We screw these to the bottom of the heated bed. Here's a sketch from our F360 design.
                                      Next point - We are using the steel balls because we already bought them, but in the future I'd replace these with acorn nuts. I think just as good, easier to find, and much cheaper.
                                      Next point - If one of your kinematic supports is a ball and cup, it locks in two directions of motion, but not rotation. The other two joints need to be different. One of the two should have one parallel sliding joint (with the sliding axis going through the center of the cup. This joint provides a lock to rotation. The last joint should be a ball sitting on a plane. It only provides a Z support. If you make either of these joints constrain more movement than this, you will not have a true kinematic connection. Sort of anal and pedantic, but if you go down the kinematic connection path...
                                      Last point - I think keeping the balls on 120degree lines from a common center point, with the direction of sliding at each joint going through the center point, you will have the best solution.
                                      o_lampeundefined 1 Reply Last reply Reply Quote 1
                                      • o_lampeundefined
                                        o_lampe @mikeabuilder
                                        @mikeabuilder @fcwilt
                                        you both describe a Kelvin mount. I opted against it, because I wanted to have three identical ball-guides.
                                        A filed 45° corner would have to be perfectly machined. The Acorn nuts will drive you crazy, because they are only casted with high tolerances. (They are produced for the looks, not for accuracy)
                                        The 120° approach would be easy to implement on a circular bed on a Delta frame, but a square bed frame ends in 90+2x150° angles. Not too bad, 'cause we don't need equal expansion.
                                        The whole build is experimental, I expect more trouble with the XY gantry. (and slicer/firmware issues)
                                        • o_lampeundefined
                                          o_lampe
                                          I made a short demo video as appetizer for things to come.
                                          It shows how two tools can draw different shapes at the same time. The other two tools can draw other shapes, but not at the same time.
                                          Four tools could draw/print the same pattern simultaneously, eg. the four feet of The Eiffel tower. That would even be easier to slice and postprocess...
                                          I'm using feltpens for now, but with extruders it would be ready to 3D print. (adjustment of individual Z-height per tool is important then)
                                          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                                          • fcwiltundefined
                                            fcwilt @o_lampe
                                            @fcwilt
                                            you both describe a *[Kelvin mount]
                                            After reading about the different kinds of mounts I decided to follow your lead.
                                            I modified my printer to use a mount similar to yours.
                                            My bed is supported by a frame made from 20x20 extrusions and the mounting points are on the frame well away from the heat of the bed.
                                            I now have three one piece printed parts with a V for the ball to ride in.
                                            They seem to be working fine.
                                            Here is one of them:
                                            Thanks for leading me to a better design.
