    RRF 3.4b3 - bed heater fault
    Beta Firmware
    905
    • SIamundefined
      SIam @CadetC
      @cadetc Welcome in the club 😉 https://forum.duet3d.com/topic/24809/3-4-0-beta-3-heater-0-fault/2
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
        Can you give us some details about the bed and heater?
        CadetCundefined 1 Reply Last reply Reply Quote 0
        • CadetCundefined
          CadetC @Phaedrux
          @phaedrux said in RRF 3.4b3 - bed heater fault:
          Bed is made out of 8 mm aluminum plate with dimensions 340X340
          Heating element - 300X300 - 220V, 750W Kenovo connected via SSR
          Starting with RRF 3.2 I had all versions installed, including betas - it was only with RRF3.4b3 that this problem occurred
          my bed config from config.g
          M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"Bed"      ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                                   ; create bed heater output on out0 and map it to sensor 0
          M307 H0 B0 S1.00                                     ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                              ; map heated bed to heater 0
          M143 H0 S130                                         ; set temperature limit for heater 0 to 130C
            dc42 administrators @CadetC
            @cadetc @SIam in order to help ne work on a solution, please can each of you do the following:
            1. Heat the bed to the same temperature that you tuned it at (resetting heater faults as necessary);
            2. When the temperature is stable, use command M573 P0 (assuming it is heater 0) to monitor the heater PWM;
            3. When the value reported by M573 is stable, report in this thread:
            • The M573 result
            • The ambient temperature at the time
            • The bed temperature that you tuned at and set
            • The heater tuning results, or the resulting M307 command.
            SIamundefined 1 Reply Last reply Reply Quote 0
            • SIamundefined
              SIam @dc42
              @dc42 Here we go, The first thing is M573 is never stable, the heat bed is on Temp since 3 hours
              28.8.2021, 13:27:28	M573 P0
              Average heater 0 PWM: 0.238
              28.8.2021, 13:27:27	M573 P0
              Average heater 0 PWM: 0.247
              28.8.2021, 13:27:26	M573 P0
              Average heater 0 PWM: 0.177
              28.8.2021, 13:27:24	M573 P0
              Average heater 0 PWM: 0.215
              28.8.2021, 13:27:23	M573 P0
              Average heater 0 PWM: 0.267
              28.8.2021, 13:27:22	M573 P0
              Average heater 0 PWM: 0.262
              28.8.2021, 13:27:20	M573 P0
              Average heater 0 PWM: 0.216
              28.8.2021, 13:27:19	M573 P0
              Average heater 0 PWM: 0.228
              28.8.2021, 13:27:18	M573 P0
              Average heater 0 PWM: 0.214
              28.8.2021, 13:27:16	M573 P0
              Average heater 0 PWM: 0.184
              28.8.2021, 13:27:14	M573 P0
              28.8.2021, 13:27:11	M573 P0
              Average heater 0 PWM: 0.199
              28.8.2021, 13:27:09	M573 P0
              28.8.2021, 13:27:07	M573 P0
              Average heater 0 PWM: 0.289
              28.8.2021, 13:27:06	M573 P0
              Average heater 0 PWM: 0.185
              28.8.2021, 13:27:03	M573 P0
              Average heater 0 PWM: 0.278
              28.8.2021, 13:27:02	M573 P0
              Average heater 0 PWM: 0.236
              28.8.2021, 13:27:00	M573 P0
              Average heater 0 PWM: 0.209
              28.8.2021, 13:26:58	M573 P0
              Average heater 0 PWM: 0.244
              28.8.2021, 13:26:56	M573 P0
              Average heater 0 PWM: 0.147
              The ambient temperature is 17 C°
              The Bed temperature that i have Tuned was 100C° and set to 75C°
              and at last the tuning result is
              M307 H0 R0.466 C285.252:285.252 D0.89 S1.00 V24.3 B0 I0
              if you need more tests, let me know
                dc42 administrators @SIam
                @siam thanks. If the M573 reading is not stable, is the temperature oscillating a little? If so, increase the M307 D parameter until it is stable. You can do this while the heater is hot.
                CadetCundefined SIamundefined 2 Replies Last reply Reply Quote 0
                • CadetCundefined
                  CadetC @dc42
                  @dc42 said in RRF 3.4b3 - bed heater fault:
                  the temperature after reaching the desired 110 degrees is a little unstable, it fluctuates within +0.3, -0.3 degrees
                  I tried to change parameter D, but I don't know by what values I can change it - I changed it by 0.1 to the value 4.80 with no visible improvement.
                  Here are the readings taken about an hour after setting the bed temperature
                  M573 results
                  .08.2021, 16:03:22	m573 P0
                  Average heater 0 PWM: 0.196
                  28.08.2021, 16:03:16	m573 P0
                  Average heater 0 PWM: 0.165
                  28.08.2021, 16:03:15	m573 P0
                  Average heater 0 PWM: 0.163
                  28.08.2021, 16:03:14	m573 P0
                  Average heater 0 PWM: 0.178
                  28.08.2021, 16:03:12	m573 P0
                  Average heater 0 PWM: 0.213
                  28.08.2021, 16:02:57	m573 P0
                  Average heater 0 PWM: 0.256
                  Ambient temperature 20C
                  Bed temperature 110C
                  M307 H0
                  8.08.2021, 16:00:46	M307 H0
                  Heater 0 model: heating rate 0.858, cooling time constant 275.9, dead time 4.18, max PWM 1.00, calibration voltage 24.0, mode PID
                  Computed PID parameters:
                   setpoint change: P49.8, I1.466, D145.6, load change: P49.8, I3.664, D145.6
                  • SIamundefined
                    SIam @dc42
                    @dc42 The temperature is a bit unstable 69.8 C° - 70.2C° I have increased the d Value by 0.1 up to 6 without any improvement
                      @siam @CadetC you can double or treble the D parameter if necessary, although that will only help if you are getting regular temperature oscillations.
                      SIamundefined CadetCundefined 2 Replies Last reply Reply Quote 0
                      • SIamundefined
                        SIam @dc42
                        @dc42 I can do what I want, the PWM Value is always unstable, the only change I can see is that the temperature fluctuations get bigger when I increase the D value. I have now the D value increased by 0.5 until D=25
                        • SIamundefined
                          SIam @SIam
                          I have now written a quick and dirty macro to get the values and share the results
                          var D_Value = 1
                          var D_Value_max = 10
                          var D_value_incr = 0.5
                          var get_pwm_repeat = 10
                          var count_pwm = 0
                          echo >"PWM.log" " " ; write new file to sys:
                          while var.D_Value < var.D_Value_max
                          	echo >>"PWM.log" " "
                          	echo "D_Value " ^ var.D_Value
                          	echo >>"PWM.log" "D_Value " ^ var.D_Value
                          	M307 H0 R0.466 C285.252:285.252 D{ var.D_Value } S1.00 V24.3 B0 I0  ; change that line to fit to your heater settings
                          	echo "M307 H0 R0.466 C285.252:285.252 D" ^ var.D_Value ^ " S1.00 V24.3 B0 I0" ; change that line to fit to your heater settings
                          	echo >>"PWM.log" "M307 H0 R0.466 C285.252:285.252 D" ^ var.D_Value ^ " S1.00 V24.3 B0 I0" ; change that line to fit to your heater settings
                          	set var.D_Value = var.D_Value + var.D_value_incr
                          	G4 S2
                          	while var.count_pwm < var.get_pwm_repeat
                          		M573 P0
                          		echo "PWM: " ^ heat.heaters[0].avgPwm
                          		echo >>"PWM.log" "PWM: " ^ heat.heaters[0].avgPwm
                          		G4 S1
                          		set var.count_pwm = var.count_pwm +1
                          	set var.count_pwm = 0
                          The result
                          D_Value 1
                          M307 H0 R0.466 C285.252:285.252 D1 S1.00 V24.3 B0 I0
                          PWM: 0.196
                          PWM: 0.235
                          PWM: 0.239
                          PWM: 0.199
                          PWM: 0.179
                          PWM: 0.201
                          PWM: 0.220
                          PWM: 0.186
                          PWM: 0.156
                          PWM: 0.154
                          D_Value 1.5
                          M307 H0 R0.466 C285.252:285.252 D1.5 S1.00 V24.3 B0 I0
                          PWM: 0.224
                          PWM: 0.215
                          PWM: 0.257
                          PWM: 0.303
                          PWM: 0.278
                          PWM: 0.215
                          PWM: 0.181
                          PWM: 0.195
                          PWM: 0.243
                          PWM: 0.282
                          D_Value 2.0
                          M307 H0 R0.466 C285.252:285.252 D2.0 S1.00 V24.3 B0 I0
                          PWM: 0.206
                          PWM: 0.225
                          PWM: 0.268
                          PWM: 0.285
                          PWM: 0.264
                          PWM: 0.263
                          PWM: 0.302
                          PWM: 0.342
                          PWM: 0.336
                          PWM: 0.321
                          D_Value 2.5
                          M307 H0 R0.466 C285.252:285.252 D2.5 S1.00 V24.3 B0 I0
                          PWM: 0.246
                          PWM: 0.203
                          PWM: 0.198
                          PWM: 0.200
                          PWM: 0.167
                          PWM: 0.138
                          PWM: 0.141
                          PWM: 0.172
                          PWM: 0.185
                          PWM: 0.159
                          D_Value 3.0
                          M307 H0 R0.466 C285.252:285.252 D3.0 S1.00 V24.3 B0 I0
                          PWM: 0.206
                          PWM: 0.255
                          PWM: 0.264
                          PWM: 0.228
                          PWM: 0.191
                          PWM: 0.195
                          PWM: 0.234
                          PWM: 0.257
                          PWM: 0.255
                          PWM: 0.255
                          D_Value 3.5
                          M307 H0 R0.466 C285.252:285.252 D3.5 S1.00 V24.3 B0 I0
                          PWM: 0.199
                          PWM: 0.218
                          PWM: 0.219
                          PWM: 0.204
                          PWM: 0.206
                          PWM: 0.235
                          PWM: 0.259
                          PWM: 0.247
                          PWM: 0.233
                          PWM: 0.251
                          D_Value 4.0
                          M307 H0 R0.466 C285.252:285.252 D4.0 S1.00 V24.3 B0 I0
                          PWM: 0.296
                          PWM: 0.299
                          PWM: 0.336
                          PWM: 0.361
                          PWM: 0.329
                          PWM: 0.269
                          PWM: 0.233
                          PWM: 0.241
                          PWM: 0.239
                          PWM: 0.197
                          D_Value 4.5
                          M307 H0 R0.466 C285.252:285.252 D4.5 S1.00 V24.3 B0 I0
                          PWM: 0.191
                          PWM: 0.170
                          PWM: 0.140
                          PWM: 0.130
                          PWM: 0.151
                          PWM: 0.149
                          PWM: 0.123
                          PWM: 0.100
                          PWM: 0.095
                          PWM: 0.117
                          D_Value 5.0
                          M307 H0 R0.466 C285.252:285.252 D5.0 S1.00 V24.3 B0 I0
                          PWM: 0.218
                          PWM: 0.209
                          PWM: 0.194
                          PWM: 0.207
                          PWM: 0.223
                          PWM: 0.201
                          PWM: 0.165
                          PWM: 0.152
                          PWM: 0.169
                          PWM: 0.204
                          D_Value 5.5
                          M307 H0 R0.466 C285.252:285.252 D5.5 S1.00 V24.3 B0 I0
                          PWM: 0.175
                          PWM: 0.165
                          PWM: 0.155
                          PWM: 0.131
                          PWM: 0.107
                          PWM: 0.101
                          PWM: 0.126
                          PWM: 0.165
                          PWM: 0.205
                          PWM: 0.242
                          D_Value 6.0
                          M307 H0 R0.466 C285.252:285.252 D6.0 S1.00 V24.3 B0 I0
                          PWM: 0.299
                          PWM: 0.304
                          PWM: 0.327
                          PWM: 0.317
                          PWM: 0.284
                          PWM: 0.246
                          PWM: 0.218
                          PWM: 0.216
                          PWM: 0.226
                          PWM: 0.215
                          D_Value 6.5
                          M307 H0 R0.466 C285.252:285.252 D6.5 S1.00 V24.3 B0 I0
                          PWM: 0.233
                          PWM: 0.248
                          PWM: 0.233
                          PWM: 0.222
                          PWM: 0.242
                          PWM: 0.269
                          PWM: 0.266
                          PWM: 0.248
                          PWM: 0.251
                          PWM: 0.275
                          D_Value 7.0
                          M307 H0 R0.466 C285.252:285.252 D7.0 S1.00 V24.3 B0 I0
                          PWM: 0.240
                          PWM: 0.253
                          PWM: 0.258
                          PWM: 0.235
                          PWM: 0.207
                          PWM: 0.190
                          PWM: 0.169
                          PWM: 0.149
                          PWM: 0.161
                          PWM: 0.194
                          D_Value 7.5
                          M307 H0 R0.466 C285.252:285.252 D7.5 S1.00 V24.3 B0 I0
                          PWM: 0.174
                          PWM: 0.145
                          PWM: 0.144
                          PWM: 0.170
                          PWM: 0.191
                          PWM: 0.178
                          PWM: 0.154
                          PWM: 0.155
                          PWM: 0.177
                          PWM: 0.190
                          D_Value 8.0
                          M307 H0 R0.466 C285.252:285.252 D8.0 S1.00 V24.3 B0 I0
                          PWM: 0.194
                          PWM: 0.214
                          PWM: 0.201
                          PWM: 0.167
                          PWM: 0.141
                          PWM: 0.147
                          PWM: 0.177
                          PWM: 0.211
                          PWM: 0.223
                          PWM: 0.207
                          D_Value 8.5
                          M307 H0 R0.466 C285.252:285.252 D8.5 S1.00 V24.3 B0 I0
                          PWM: 0.217
                          PWM: 0.201
                          PWM: 0.168
                          PWM: 0.148
                          PWM: 0.152
                          PWM: 0.146
                          PWM: 0.121
                          PWM: 0.101
                          PWM: 0.112
                          PWM: 0.116
                          D_Value 9.0
                          M307 H0 R0.466 C285.252:285.252 D9.0 S1.00 V24.3 B0 I0
                          PWM: 0.112
                          PWM: 0.132
                          PWM: 0.125
                          PWM: 0.118
                          PWM: 0.135
                          PWM: 0.159
                          PWM: 0.162
                          PWM: 0.141
                          PWM: 0.134
                          PWM: 0.155
                          D_Value 9.5
                          M307 H0 R0.466 C285.252:285.252 D9.5 S1.00 V24.3 B0 I0
                          PWM: 0.150
                          PWM: 0.167
                          PWM: 0.193
                          PWM: 0.196
                          PWM: 0.180
                          PWM: 0.186
                          PWM: 0.215
                          PWM: 0.248
                          PWM: 0.276
                          PWM: 0.291
                          • CadetCundefined
                            CadetC @dc42
                            Today I checked again how this issue looks like - when heating up to 110C I had to delete fault once, then everything was OK.
                            After about 30 minutes temperature quite stable, small fluctuations +0.1, -0.1 degrees .
                            After the temperature of the table stabilized (with small deviations as above) the result of M573 varied from 0.226 to 0.242 - I checked it for about 15 minutes
                            30.08.2021, 17:18:38	M307 H0
                            Computed PID parameters: setpoint change: P49.8, I1.466, D145.6, load change: P49.8, I3.664, D145.6
                            30.08.2021, 17:17:49	M573 p0undefined
                            • hestiahuangundefined
                              hestiahuang
                              @cadetc said in RRF 3.4b3 - bed heater fault:
                              Refer to https://forum.duet3d.com/topic/24809/3-4-0-beta-3-heater-0-fault/12
                              • hestiahuangundefined hestiahuang referenced this topic
