toolboard print fan issue
Firmware installation
    dutti
    hey cummunity
    I have the problem that the print cooling fan isn´t working (at the moment I just have one tool in use).
    maybe anybody has a solution for it. would be very great! 😄
    -I´m using cura.
    -extruder fan is working fine
    -using original e3d 12v fans.
    thanks to all who takes time for support.
    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 16:15:35 GMT+0200 (Mitteleuropäische Sommerzeit)
    M550 P"Duet 3" ; set printer name
    M552 S1 P192.168.2.108 ; Wifi
    G4 S4
    M574 C1 S3
    M574 C0 Z0 ; No C Z endstop
    M915 P1.2 C S0 F0 R1
    M569 P0.2 S0 ; physical drive 0.2 goes forwards
    M569 P0.3 S0 ; physical drive 0.2 goes forwards
    M569 P0.4 S0 ; physical drive 0.2 goes forwards
    M569 P0.5 S0 ; physical drive 0.2 goes forwards
    M569 P1.0 S0 ; physical drive 0.2 goes forwards
    M569 P1.2 S0 ; physical drive 0.2 goes forwards
    M569 P121.0 S0 ; physical drive 121.0 goes forwards
    M569 P122.0 S1 ; physical drive 122.0 goes forwards
    M569 P123.0 S1 ; physical drive 123.0 goes forwards
    M584 X1.0 Y0.0:0.1 Z0.2:0.3:0.4:0.5 C1.2 E121.0:122.0:123.0 ; set drive mapping
    M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
    M92 X160.00 Y160.00 Z640.00 C91.022 E409.00:409.00:409.00 ; set steps per mm
    M566 X300.00 Y300.00 Z60.00 C3000 E3.00:3.00:3.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X15000.00 Y15000.00 Z800.00 C5000 E6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z800.00 C400 E2500.00:2500.00:2500.00 ; set accelerations (mm/s^2)
    M906 X1300 Y1300 Z2500 C400 E1000:1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M671 X-80:-80:930:930 Y-80:930:930:-80 S20 ; leadscrews at front left1 and n´back2. back rigth3 and front4
    M208 X-10 Y-81.4 Z0 S1 ; set axis minima
    M208 X860 Y890 Z850 S0 ; set axis maxima
    M574 X2 S1 P"^io3.in" ; configure active-high endstop for high end on X via pin ^io3.in
    M574 Y2 S1 P"^io1.in" ; configure active-high endstop for high end on Y via pin ^io1.in
    ; Z probe
    M558 P5 C"io2.in" H50 F360 I0 T1100 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
    G31 P200 X5 Y30 Z0 ; Set Z probe trigger value, offset and trigger height; Z probe
    M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
    M557 X200:650 Y200:650 S45 ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    M307 H0 B0 R0.243 C586.2 D33.87 S1.00 V0 ; disable bang-bang mode for the bed heater and set PWM limit
    M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as PT1000 on pin 121.temp0
    M143 H1 S250 ; set temperature limit for heater 1 to 250C
    M308 S2 P"122.temp0" Y"pt1000" R2200 ; configure sensor 2 as PT1000 on pin 122.temp0
    M950 H2 C"122.out0" T2 ; create nozzle heater output on 122.out0 and map it to sensor 2
    M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H2 S250 ; set temperature limit for heater 2 to 250C
    M308 S3 P"123.temp0" Y"pt1000" R2200 ; configure sensor 3 as PT1000 on pin 123.temp0
    M950 H3 C"123.out0" T3 ; create nozzle heater output on 123.out0 and map it to sensor 3
    M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H3 S250 ; set temperature limit for heater 3 to 250C
    M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
    M563 P0 D0 H1 ; tool uses extruder 0, heater 1
    M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
    M563 P0 D0 H1 F1 ; tool uses extruder 0, heater 1
    M950 F2 C"122.out1" Q500 ; create fan 2 on pin 122.out1 and set its frequency
    M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
    M950 F3 C"122.out2" Q500 ; create fan 3 on pin 122.out2 and set its frequency
    M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on
    M950 F4 C"123.out1" Q500 ; create fan 4 on pin 123.out1 and set its frequency
    M106 P4 S1 H-1 ; set fan 4 value. Thermostatic control is turned off
    M950 F5 C"123.out2" Q500 ; create fan 5 on pin 123.out2 and set its frequency
    M106 P5 S1 H3 T45 ; set fan 5 value. Thermostatic control is turned on
    M950 F6 C"out4" Q500 ; create fan 6 on pin out4 and set its frequency
    M106 P6 S1 H-1 ; set fan 6 value. Thermostatic control is turned off
    M950 F7 C"out5" Q500 ; create fan 7 on pin out5 and set its frequency
    M106 P7 S1 H T45 ; set fan 7 value. Thermostatic control is turned on
    M563 P0 D0 H1 ; define tool 0
    G10 P0 X30 Y28.25 Z-39.75 ; set tool 0 axis offsets
    M563 P1 D1 H2 F2 ; define tool 1
    M563 P2 D2 H3 F4 ; define tool 2
    G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
    G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
    undefined 1 Reply Last reply 29 Aug 2021, 12:52 Reply Quote 0
      dutti @dutti
      @dutti
      additional
      1.dwc shows the right amount for print cooling...
      2.he dwc shows fan 6 and 7.. is this normal?
        dutti
        Is there any describtion about the wiring for 2 pin fans for toolboard on out1?
        thanks
          Your tool definition is missing an F# to tell it which fan is assigned to that tool.
          If it's fan0, add F0.
          undefined 2 Replies Last reply 30 Aug 2021, 07:54 Reply Quote 0
            dutti @Phaedrux
            @phaedrux
            sadly... it´s still not working 😕
              dutti @Phaedrux
              @Phaedrux
              Problem solved by using different fan.
              2 out of 6
