    please help z axis confusion
    405
    • kevinlallshouseundefined
      kevinlallshouse
      hey guys I'm having some issues and don't know what to do. i can home my printer fine and run mesh bed leveling and every thing but every time i go to print it runs straight in to my bed and when I compensate for that with babysteps on layer 2 it jumps up like 5mm for second layer on print and i don't know what could be wrong. i will add my config and a example print to see if maybe someone may be able to help I'm running a longer lk1 its a 300x300x400 Cartesian. thanks in advance.```
      undefined; Configuration file for Duet WiFi (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.3.0 on Wed Aug 25 2021 16:58:52 GMT-0700 (Pacific Daylight Time)
      M550 P"My Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S0 ; physical drive 2 goes backwards
      M92 X80.00 Y80.00 Z4000.00 E67.91 ; set steps per mm
      M566 X4500.00 Y4500.00 Z60.00 E6000.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z20.00 E2500.00 ; set accelerations (mm/s^2)
      M906 X1300 Y1300 Z1300 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S10 ; Set idle timeout
      M208 X300 Y300 Z400 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
      M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin !ystop
      M574 Z2 S2 ; configure Z-probe endstop for high end on Z
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-30 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4500 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4000 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      undefined[NEW BLTOUCH GODE DUET.gcode](/assets/uploads/files/1629986504957-new-bltouch-gode-duet.gcode)
        A Former User
        This post is deleted!
        kevinlallshouseundefined 1 Reply Last reply Reply Quote 1
          kevinlallshouse @A Former User
          @arnold_r_clark my bl touch all works perfect but here is home all```
          undefined; homeall.g
          ; called to home all axes
          G91 ; relative positioning
          G1 H2 Z10 F6000 ; lift Z relative to current position
          G1 H1 X-305 Y305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y-5 F6000 ; go back a few mm
          G1 H1 X-305 Y305 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X45 Y15 F6000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G1 Z10 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          and here is home z```; homez.g
          ; called to home the Z axis
          G1 X45 Y15 F6000 ; go to first probe point
          undefined
          here is even my cura start gcode i got from longer for bl touch
          undefined-- BL-TOUCH START GCODE --
          G21 ; metric values
          M82 ; set extruder to absolute mode
          M107 ; start with the fan off
          ; confirm BL-touch safety
          M280 P0 S160 ; BL-Touch Alarm release
          G4 P100 ; Delay for BL-Touch homing
          G28 X0 Y0 ; move X/Y to min endstops
          G28 Z0 ; move Z to min endstops
          ; reconfirm BL-touch safety
          M280 P0 S160 ; BL-Touch Alarm realease
          ; bed leveling
          G29; Auto leveling
          M420 Z5 ; set LEVELING_FADE_HEIGHT
          M500 ; save data of G29 and M420
          M420 S1 ; enable bed leveling
          ; prepare hot-end
          G92 E0 ; zero the extruded length
          G1 F200 E3 ; extrude 3mm of feed stock
          G92 E0 ; zero the extruded length again
          M117 Printing
          ; -- end of BL-TOUCH START GCODE --
          anything else you can think of?
            kevinlallshouse
            and im runnind duet 2 wifi and rrf 2.2 and web 1.26
            • fcwiltundefined
              fcwilt @kevinlallshouse
              @kevinlallshouse said in please help z axis confusion:
              When using the </> tag you should see:
              • a row of three ` characters
              • a row with just the word undefined
              Paste the code over the word undefined being sure to not disturb the rows of ` characters.
                kevinlallshouse
                i think i figured out the issue i disabled axis limits and adjusted trigger hight and re zero z axis and it seems to be working but my cura code is causeing a auto level before each print can anyone see mistakes in it that i posted?
                • fcwiltundefined
                  Could you go back and edit your post with the files? You didn't get the use of the </> tag correct.
                    Phaedrux Moderator @kevinlallshouse
                    Is 4000 for sure correct for your Z axis steps per mm?
                    M420 isn't a valid gcode in reprapfirmware. And M500 isn't doing what you think there and should be removed. This looks like marlin specific gcodes not applicable on a Duet.
                    kevinlallshouseundefined 1 Reply Last reply Reply Quote 0
                      kevinlallshouse @Phaedrux
                      @phaedrux ok great thank you i have the Cura fixed but I'm having issues with my z steps like u said. my problem is I have a longer lk1 lead screw that's 8mm and I cant find any info on it so I'm quite sure its wrong. an ideas were I could start to calculate them correctly or how to identify my lead screw?
                        Well if you have absolutely no idea what your lead screw is you can just tell it to move a small amount that you can measure and see how much it differs. Then do the math to see how much you're off. Similar to how with extruder is calibrated. You tell it to move 100mm and then measure how much it actually moved and then adjust the steps as needed.
                          kevinlallshouse
                          Ok that was my thought as well. I'm in the process of going dual z leads so I'm just waiting on new leads then I will know for sure. I don't need to change any settings for dual z correct? just wire in place of z jumpers and good to go from my understanding? or am I'm I mistaken? and thanks for taking time to answer all my questions
                            Yes you can use the dual output Z driver to run the two z motors together without any other configuration.
                            If you have a spare driver free you could use a separate driver for the second motor and then use it for auto leveling.
                            https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
