insufficient axis homed when start printing
@agileproductontwikkeling said in insufficient axis homed when start printing:
Anyway the main problem I had is gone:
So what made the problem go away?
@fcwilt Dont give the homing command when already homed. Not sure why that is a problem, but apparently it is in my case.
Homing when already homed should never be an issue as (one of) the first thing a G28 command does is mark the axis as un-homed.
You have something wrong in your code.
We just need to find the problem and correct it.
@fcwilt said in insufficient axis homed when start printing:
It most certainly CAN be a problem .... see my various postings on the Jubilee printer.
A Jubilee printer can only be homed when it has no tools loaded in the tool changer. The first thing Cura does, and this is BEFORE any Cura start code is executed, is to select a tool. Generally the homing is done after that in the Cura start code.
There is no known way of bypassing the fact that Cura selects a tool even before executing it's start codes. -
@jens55 said in insufficient axis homed when start printing:
You write the code that does the homing - you can code it as needed.
How is that possible - since the code in the sliced file is doing all the work.
The first command I see Cura 4.10.0 generate is M109 S0.
When RRF processes that command it selects the tool.
The next command I see is M82 which has no effect on tools.
The third command I see is the call to my own start code where I can, if needed, de-select the tool selected by the M109.
So perhaps I am missing the problem but I just don't see it.
I made one change to Cura 4.10.0 to use RepRap as the "gcode flavor" instead of Repetier.
I still am setting all temps in Cura to 0 as I don't let slicers control temps.
The only difference I see in the generated code, compared to Repetier, is a T0 as the very first command.
But the result is the same in that when my code gets executed I still can de-select the tool.
It is a bit of an esoteric issue and yes, you are missing something.
I should first mention that I use the latest Master Branch of Cura rather than plain old Cura.
What happens, even before the start code from Cura is run, is that Cura calls for a tool and then sets up temperatures for said tool and the bed. The temperature calls can be bypassed but no matter what you do, Cura calls for a tool.
Generally the Cura start code calls for homing.
The Jubilee printer can not home if a tool is mounted period. If you try to do that you get all kinds of errors. Yes, you can most certainly remove all the code that generates the errors but you can't bypass the crash that happens as a result of trying to home while a tool is physically mounted in the tool changer.I think we are getting way too fixated on a specific setup that the OP might not even have. There are apparently a few other printers that throw errors when you try to do a home with a tool mounted but this might still not be the issue with the OP. I only mentioned this issue because I had a bit of a struggle finding why things were happening and I wanted to make some mention in this thread about the issues I encountered in case somebody searches for the same problem.
I am more than happy to discuss more details via email to clarify things for you.
One quick question:
Cura has no connection to the printer so how can it do anything like calling for a tool.
@fcwilt, when I say "Cura is calling for a tool", please read that as "the gcode that Cura generated, when executed' calls for a tool"
