    Unresponsive board, DIAG lit, next steps?
    • unstableTableundefined
      unstableTable
      Hello all,
      I have a Duet 2 WiFi V1.04 (no erase button), unknown firmware on an Ender 3 [V1] Pro.
      It ran great until I moved and tried to connect to a new wireless network.
      I followed:
      https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond#Section_Check_the_voltage_indication_LEDs
      I tried to connect via YAT under USB power only. No luck.
      I checked Device Manager on two Windows laptops and the board did not appear anywhere
      I found/followed the above link
      The lights on board were: 5v, 3.3v, & red light b/t rest button and USB. The DIAG light lit up ~0.5sec then remained off
      I jumpered the erase pins (no erase button), applied USB power (few sec, per the link) then removed USB power & jumper
      I applied USB power lights are same, plus DIAG light now remains on
      USB inserted I checked Device Manager and got "device descriptor request failed" (code 43)
      Board still unresponsive, I even tried with/out SD card inserted. I bought through Filastruder two years ago so I am likely outside my warranty.
      How can I save her?
      Thanks! *smiles in noob
        jay_s_uk @unstableTable
        @unstabletable try a few different USB cables. Also try a powered USB hub if you have one
        unstableTableundefined 1 Reply Last reply Reply Quote 1
          unstableTable @jay_s_uk
          @jay_s_uk Hey Hey! The USB hub solved it! A new BOSSA COM port open in YAT.
          Continue in YAT as per usual set up for a new wireless network?
          jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
            @unstabletable yep. that should get you going
              dc42 administrators @unstableTable
              @unstabletable said in Unresponsive board, DIAG lit, next steps?:
              You will need to flash the firmware using Bossa. After that, you can use YAT to set up the network.
              unstableTableundefined 1 Reply Last reply Reply Quote 0
                https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_2
                  unstableTable @dc42
                  @dc42 got it thank you
