Unresponsive board, DIAG lit, next steps?
Hello all,
I have a Duet 2 WiFi V1.04 (no erase button), unknown firmware on an Ender 3 [V1] Pro.
It ran great until I moved and tried to connect to a new wireless network.I tried to connect via YAT under USB power only. No luck.
I checked Device Manager on two Windows laptops and the board did not appear anywhere
I found/followed the above link
The lights on board were: 5v, 3.3v, & red light b/t rest button and USB. The DIAG light lit up ~0.5sec then remained off
I jumpered the erase pins (no erase button), applied USB power (few sec, per the link) then removed USB power & jumper
I applied USB power lights are same, plus DIAG light now remains on
USB inserted I checked Device Manager and got "device descriptor request failed" (code 43)
Board still unresponsive, I even tried with/out SD card inserted. I bought through Filastruder two years ago so I am likely outside my warranty.How can I save her?
Thanks! *smiles in noob -
@unstabletable try a few different USB cables. Also try a powered USB hub if you have one
@jay_s_uk Hey Hey! The USB hub solved it! A new BOSSA COM port open in YAT.
Continue in YAT as per usual set up for a new wireless network? -
@unstabletable yep. that should get you going
@unstabletable said in Unresponsive board, DIAG lit, next steps?:
Continue in YAT as per usual set up for a new wireless network?You will need to flash the firmware using Bossa. After that, you can use YAT to set up the network.
@dc42 got it thank you
