    Print stopped for no apparent reason
    • Oct_opusundefined
      Oct_opus
      Hello everyone,
      Last night I tried a 12h print on my duet 2 Wifi and for not apparent reason it just stoped.
      I’v reformatted the SD card and ran the SD card test provided and the wiki but no errors was found.
      If someone has an idea and could help that would be greatly appreciated, I'v tried looking online but haven't found any meaningful help.
      Printer info:
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
      Here's the M122 output after the crash (I was sleeping during it):
      Static ram: 27980
      Dynamic ram: 93952 of which 24 recycled
      Exception stack ram used: 304
      Never used ram: 8812
      Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
      Owned mutexes: WiFi(NETWORK)
      Last reset 06:44:46 ago, cause: software
      Last software reset at 2021-09-05 03:22, reason: Stuck in spin loop, spinning module GCodes, available RAM 8452 bytes (slot 3)
      Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200051f4 Task MAIN
      Stack: 00457b03 0045b488 61030200 3f000000 3e49ba00 3edb6db7 b7b4d800 49742400 44fa0000 447a0000 447a0000
      Error status: 0
      MCU temperature: min 50.5, current 51.0, max 57.6
      Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2021-09-05 10:07:31
      Slowest loop: 356.64ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 52.5ms, write time 0.0ms, max retries 4
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.69ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address b4:e6:2d:60:31:f9
      WiFi Vcc 3.38, reset reason Unknown
      WiFi flash size 4194304, free heap 20224
      WiFi IP address 192.168.1.65
      WiFi signal strength -56dBm, reconnections 0, sleep mode modem
      Socket states: 0 4 0 0 0 0 0 0"
      console.csv
      Thank you
        jay_s_uk @Oct_opus
        @oct_opus please update to the latest version 3.3.0
        Oct_opusundefined 1 Reply Last reply Reply Quote 0
        • Oct_opusundefined
          Oct_opus @jay_s_uk
          @jay_s_uk I'm going to do that thanks. Do you know if a specific problem before that version that would have caused such problem ?
          jay_s_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @Oct_opus
            @oct_opus there have been many bugs fixed so it would be difficult to pinpoint
              deckingman @Oct_opus
              @oct_opus It's good that you had the insight to run M122. Whilst I am no expert, this ought to be significant to someone like @dc42.
              Hopefully updating the firmware as suggested by @jay_s_uk should fix it, but if not raise the issue again and post the M122 report again (Run M122 as soon as you can after the fault happens and certainly without cycling power).
              Oct_opusundefined 1 Reply Last reply Reply Quote 1
              • Oct_opusundefined
                Oct_opus @deckingman
                @deckingman Yes, I wonder what would cause this error to appear. I will update the firmware and if it happens again ill post the G-code along with it
                  Post your config.g as well as the M122 if it happens again on 3.3 please.
