    Anybody wants a stepper motor analyzer?
    281
    31.6k
    • 1riundefined
      1ri @zapta
      @zapta
      hi, i sent my address and tโ€™he amazon code via chat, i think.
      I don't know if you received it or not, I don't get along with chats
      Via GoogleTranslator ๐Ÿ˜…
      • zaptaundefined
        zapta @1ri
        @1ri, got your message. Replied via chat. Sorry for my late response.
        • zaptaundefined
          zapta @agmeadows
          @agmeadows, please send me your shipping name and address via chat.
          @tenaja, I am sorry but all the planed units are claimed. I hope that somebody will pick the idea and will make them available in larger quantities (the design is in public domain with no strings attached whatsoever).
          • Th0mpyundefined
            Th0mpy
            I am planning to make a few but I've been delayed by a few weeks. I may decide to just place a big order once I'm done with the first, I'll post here when I do. If you're interested send me a message and I'll direct my communication to those people interested.
            Usually the team that scores the most points wins the game.
            zaptaundefined wouldstainundefined 2 Replies Last reply Reply Quote 1
            • zaptaundefined
              zapta @Th0mpy
              @th0mpy said in Anybody wants a stepper motor analyzer?:
              Hi @Th0mpy, that's a great initiative. Thanks. Please remember that the license is public domain (CC0) and allows commercial use, which make the availability of analyzers more sustainable. Can also be a great kickstarter.
              I suggest to use files from released versions (firmware, electronic, and mechanical) rather than latest, it's safe this way. https://github.com/zapta/simple_stepper_motor_analyzer/releases
              Also, I used JLCP to provide and solder all the SMD components in their inventory, which includes the heavy lifting of soldering the two FPC 0.5mm pitch connectors. Just had to solder myself the current sensors, stepper connector (remember to cut the pins using the 3D printed jig) and the Pico.
              The mechanical design and TFT are based on Dustin's Watts ESP32 Touchdown (but is ~2mm longer). https://www.youtube.com/channel/UCYPmdetwhvFeRkgXhIWq_eg . He uses PCBWay to assembled his board (potentially they can solder all of the components) and had a few vidoes about it. He is also very approachable on his Discord forum so you can ask him for manufacturing advise. https://youtu.be/YHzU_GXCIkQ
              https://www.tindie.com/products/dustinwattsnl/esp32-touchdown/
              Please let me know if you have any question, here or on github, and if you want I can add to my github repository a link to your store.
              BTW, the last unit from my 30 units batch went out today and I don't plan to make another batch.
              Th0mpyundefined 1 Reply Last reply Reply Quote 2
              • Th0mpyundefined
                Th0mpy @zapta
                @zapta Cool thank you! I appreciate the feedback and the offer. Once I get mine done I'll give you a holler.
                • CCS86undefined
                  CCS86
                  Hey @Zapta, after using it for a while now, I would love to change at least one configuration aspect: A lower scale screen for the steps chart.
                  When I have it hooked up to my extruder motor, even at the higher end of my print speeds, I only use about 600 of the 1k step scale, with the current time scaling.
                  For really looking at how linear advance is (or is not) working, a much tighter scale would be awesome. Maybe a [300 step / 10 sec] screen, or even [150 step / 5 sec]
                  It looks like steps_chart_screen.cpp handles this:
                  But while Y scale might be set here (and labeling), it looks like the X time scale is defined elsewhere.
                  Questions:
                  • Is there a memory limit that would prevent adding say 2 more chart axis configs to this screen?
                  • Would you be interested in kicking out a new firmware revision that added these?
                  • If not, could you offer any guidance on which files need to be changed, and any thing else about compiling and uploading that is important?
                  Thanks!
                  zaptaundefined 1 Reply Last reply Reply Quote 1
                  • zaptaundefined
                    zapta @CCS86
                    Hi @ccs86, thanks for the feedback.
                    I created a release candidate with that include a third scale 0-200 steps. Please try to flash to your device and see if it works.
                    To flash, disconnect the usb connector, press and hold the button at the back (through the hole) and connect to your computer. This should add a new disk drive to your computer. Download and copy APPLICATION.uf2 from the link below to that disk, wait a second or two until it completes and you are doen.
                    https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/temp/APPLICATION.uf2
                    If it will work, I will make it an official release.
                    As for the time scale, how important is it to have it faster (e.g. 5 secs)? This change is slightly more involved if different Y scales need different time scale but doable.
                    EDIT: this is how the scale definitions looks now. If you have change suggestion for the other two scales please let me know.
                    https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/platformio/src/ui/steps_chart_screen.cpp#L24
                    CCS86undefined 1 Reply Last reply Reply Quote 3
                    • CCS86undefined
                      CCS86 @zapta
                      @zapta said in Anybody wants a stepper motor analyzer?:
                      @zapta Thanks my man!
                      It works great!
                      The shorter times scale (I think) would be cool, but if it's a big pain don't worry about it. Here is a simple pressure advance test, 20 - 80 mm/s, 3mm retracts.
                      Going to first off an actual print to see how that looks.
                      • zaptaundefined
                        zapta @CCS86
                        @ccs86, I published a new release with this change https://github.com/zapta/simple_stepper_motor_analyzer/releases/tag/F1.0.4
                        The graph looks interesting. If I understand it correctly the pressure advance doesn't start immediate after the retraction/traction, and it extrudes a little bit before it increases slope. is it so?
                        CCS86undefined 1 Reply Last reply Reply Quote 1
                        • CCS86undefined
                          CCS86 @zapta
                          I think you have it right.
                          Here is a video that will probably illustrate it much better than I can explain.
                          It starts with some alignment marks, then does a pass with no pressure advance, then PA turns on and increases for each line, and then off again for the last line.
                          https://photos.app.goo.gl/VvjoMEUo68r8pisLA
                          • zaptaundefined
                            zapta @CCS86
                            @ccs86, the link didn't work for me.
                            CCS86undefined 1 Reply Last reply Reply Quote 0
                            • CCS86undefined
                              CCS86 @zapta
                              Link updated. Try again.
                              • zaptaundefined
                                zapta @CCS86
                                @ccs86, very interesting. Those PA 'pulses' is not how I imagined PA.
                                It explains the extreme noises I got at the time when I tried high PA values with a 600mm bowden printer. The stepper was so erratic that I had to install it on RC rubber dumpers. Eventually I switched to a direct drive and the problem solved.
                                I wonder if PA has one 'natural' profile or if different firmware developers come with different profiles. There are many degrees of freedom in shaping the profile which we reduce to a single number.
                                • CCS86undefined
                                  CCS86 @zapta
                                  I have found that the current PA implementation is not useful at all on my bowden printer, and I think it's about as well-tuned as a bowden gets. I have a few thoughts on why it is missing the mark that I posted here:
                                  https://forum.duet3d.com/topic/17752/pressure-advance-discussion-for-future-development
                                  There are certainly different ways to implement PA, but the same basic principle is a the base: increasing volumetric extrusion rate, requires increased nozzle pressure (filament drive force). The filament drive system acts like a spring, so you can increase pressure/force with an increased spring preload (being a certain number of steps "ahead").
                                  Klipper has a PA "smoothing" algorithm that I think would be really helpful in calming down the extruder motion. But I think bowden machines need more,
                                  On the steps chart, you can think of the green line here as PA=0. The orange area is the steps boost for 20mm/s, and the red area the additional steps for 80 mm/s
                                  • Webhunterundefined
                                    Webhunter
                                    Hi Zapta - nice work with the Stepper analyzer.
                                    I would like to buy one - do you send to Denmark? And what will it cost?
                                    many greetings
                                    • zaptaundefined
                                      zapta @Webhunter
                                      Hi @webhunter, build 30 units and gave to people here at cost. Currently I don't plan to build additional ones but all the files are in public domain and anybody is invited to build, including commercially.
                                        Webhunter
                                        Hi @zapta
                                        Where can i buy PCB ?
                                        Greetings
                                        Luke'sLaboratoryundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                        • Luke'sLaboratoryundefined
                                          Luke'sLaboratory @Webhunter
                                          @webhunter You can certainly get your own pcb (note, not assembled with components) from a place like JLCPCB or OshPark and build it yourself, or source assembled units from JLCPCB using the source files.
                                          Luke
                                          http://lukeslab.online
                                          • zaptaundefined
                                            zapta @Webhunter
                                            @webhunter, I used the files here to order the boards from JLCPCB with SMD service.
                                            https://github.com/zapta/simple_stepper_motor_analyzer/tree/main/kicad/JLCPCB
                                            It includes only the components they support which means that some parts you will need to order and solder yourself (the two current sensors, the two connectors, the Raspberry Pico module, and then you will need to attach and connect the TFT module). Make sure to get the exact TFT module for compatibility with the hardware and firmware.
                                            Of course you can get bare boards and solder everything yourself but it depends on your SMD soldering skills. The TFT connectors have 0.5mm pitch and it's easy to bridge adjacent pins (and it's possible to fix if you or JLCPCB happened to bridge them).
                                            Let me know if you have further questions.
                                            Edit:
                                            • When ordering from JLCPCB with SMD service, they will fix the orientation of a few components. That's normal since they assume different footprints.
                                            • PCBWAY may provide a more complete service (with current sensors and Pico board soldered) but ordering SMD service from them is slightly more involved.
                                            PCRundefined 1 Reply Last reply Reply Quote 1
