    Future Option for Linear Absolute Encoders
    1.2k
    • JoergS5undefined
      JoergS5 @NeueKlasse
      @neueklasse said in Future Option for Linear Absolute Encoders:
      Save the Actual Stepper Position with daemon.g and load it after eac
      This will not work, because steppers change their positions after restart of the controller, up to +- 2 full steps, which is more than your 0.05 mm accuracy (with 20 teeth pulley, 200 stepper and GT2 belts it would be +- 0.4 mm). So to be sure you recover the correct position, the position must be read and stored before the stepper is activated. After stepper activation, the position is probably changed by the stepper and must be recovered by stepper position correction. Then the firmware can be told the stepper's (and axis) position.
      NeueKlasseundefined 1 Reply Last reply Reply Quote 0
      • NeueKlasseundefined
        NeueKlasse @JoergS5
        @joergs5 the Steppers i use are Nema23, with a 11x2 Spindle, i trust them to be accurate enough to handle that (to be clear it’s a Z and U Axis.. height adjustment)
        due to the Spindle pitch it‘s self retaining…
        Prusa Mini, Chiron @ BMG X2
        Metal SLS Printer Development
        • JoergS5undefined
          JoergS5 @NeueKlasse
          Steppers +- 2 fullsteps are then +- 0.02 mm, which is inside your range, you're right. Detent Torque of a Nema 23 is also quite high, so the Z axis should not move down when powered off.
          About Renishaw, to use it you should check how to use the supported protocols, as they are all (or most of) protocols for specific commercial products. I thought of an alternative AMT21/23..., part of them are absolute encoders, they use standard protocols/interfaces/bus like RS485, but they need battery buffers to store the absolute position, I suspect. The accuracy is 0.2 degree, which means 1 micrometer for the spindle solution, when no gear is used.
          The 1HCL will not help you imho in this case, as it reads differential quadrature signals for closed loop stepper implementations, but doesn't read absolute positions.
          The hint above using Arduino, ESP32 or alike was imho a good one to install it between the encoder and the Duet. You should check whether there are libraries to support one of the Renishaw protocols (Biss C, DRIVE-CLiQ, FANUC, Mitsubishi, Panasonic, Yaskawa).
          • o_lampeundefined
            o_lampe
            I'd look for an ESP to buffer the position, because it wouldn't need level shifters and it has power saving features like wake up on interupt
              NeueKlasse @JoergS5
              @joergs5 How to tell the Duet, (Duet3 btw) the actual Position from the ESP Board?
              then it would be interesting,
              i checked the Information about the HCL Board.. it's simply just a "Standard" for the most common Encodertype that's in Use in the Printers, so for me sadly no way.
              now i test a little bit around with Variables and Assignments...
              i created these 2 in the config.g file:
              ; Variables
              global LastZAxisPosition = 0
              global LastUAxisPosition = 0
              in other Controllers (example ABB, KUKA) they will be updated in the config file if i set an Value,
              in the Duet Framework after a Restart it's 0 again (like i wrote the in the config file...)
              JoergS5undefined 2 Replies Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @NeueKlasse
                Duet has a very clever concept: it is controlled by G-Code commands completely. Everything from config.g to sliced 3D printing is based on it. So the ESP32 needs to send a G-Code command like a G92 to the Duet, that's it. You only need a connection between ESP and Duet which is supported by both. ESP and Duet support eg SPI, I2C, http, even TCP through WLAN if Duet supports Wifi. If Duet 3 is in the internal network, the ESP32 could send the data through WLAN and router to the Duet 3.
                NeueKlasseundefined 2 Replies Last reply Reply Quote 0
                  NeueKlasse @JoergS5
                  @joergs5, @PCR i think i like that way, i order an ESP to test it out!
                  • JoergS5undefined
                    JoergS5 @NeueKlasse
                    there was a thread recently how to store global variables:
                    https://forum.duet3d.com/topic/24880/does-rrf-have-maintenance-counters-timers
                      NeueKlasse @JoergS5
                      @joergs5 i tested that,
                      => config.g = global ZAxisPos = 0
                      => i created a "VariableBuffer.g" file in the sys Folder and Inside:
                      set global ZAxisPos = 0
                      then A Macrofile w.
                      M28 "0:/sys/VariableBuffer.g"
                      set global.ZAxisPos = -25
                      M29
                      After Calling the Macro the Variable inside the VariableBuffer.g file is Updated,
                      it's also persistent through a Restart.
                      if i set it under the M29 Command in the Macro: G92 Z{global.ZAxisPos}
                      the Z Value Remains 0
                      so i checked it in the Objekt Model Browser under "global" ... it remains 0.
                      • JoergS5undefined
                        JoergS5 @NeueKlasse
                        @neueklasse I did not use and test it myself, I only saw the thread. If you have negative results, you could post your try and question in this thread where storing the variable was discussed.
                          NeueKlasse @JoergS5
                          @joergs5
                          the easiest way i think would be over UART, but in my case a PanelDue is connected on IO0,
                          do i have to Activate the SPI Protocol (M576) to send the Commands via the GPIO Header and
                          the SPI Pins?
                          I think the Second UART Port on IO1 is not working right now?
                          • JoergS5undefined
                            JoergS5 @NeueKlasse
                            @neueklasse you don't need something fast or permanent for this task, so I would not waste a dedicated line, but use the Lan connection.*)
                            *) but there is https://github.com/technik-gegg/SMuFF-Ifc which could be used to be between Duet and Paneldue. But I2C is sensitive, I would prefer Lan.
                            If I remember correctly, you're using a Raspi with Octoprint also, so using Lan for all communication would be fine and usable for other ideas.
                            A different direction would be CAN-FD, with a board like Teensy 4 or Sammy-C21, or using the MCP2542FD chips. The Duet 3 is a groving environment with CAN-FD components, enlarging it with a component for encoder would be interesting. But this may require some development of the communication.
                              dc42 administrators @NeueKlasse
                              @neueklasse I've been looking at whether the forthcoming closed loop board could support this type of absolute encoder. It appears to me that it could, with a little extra hardware (possibly on a daughter board) to provide an RS422 interface. We would use BISS C protocol to communicate with the encoder.
                              NeueKlasseundefined roiki11undefined 2 Replies Last reply Reply Quote 0
                                NeueKlasse @dc42
                                @dc42 Thanks for the info, that would be great! i'm looking forward to the developments.
                                BISS C would be perfect (at least in my Case)
                                • roiki11undefined
                                  roiki11 @dc42
                                  You could make a completely separate board with hardware quadrature counters or biss-c master ic(ic-haus makes them) then just use SPI to talk to them. The master ic supports SSI too.
