    Triggers firing by themselves on restart
    555
    • o_lampeundefined
      o_lampe @RodrigoRMaraujo
      @rodrigormaraujo
      4.7k -10k ohms are common. (that is 4700 -10000 ohms for the uneducated readers)
      RodrigoRMaraujoundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @RodrigoRMaraujo
        @rodrigormaraujo said in Triggers firing by themselves on restart:
        please how can i do this? I have no idea.
        Something like this. You have to addapt this code to your inputs:
        This code has to be in the beginning of the Trigger macro!
        if fans[0].rpm < 100
                    G4 P10
                        M25
                        M118 S"No Water flow!"
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        • RodrigoRMaraujoundefined
          RodrigoRMaraujo @o_lampe
          @o_lampe said in Triggers firing by themselves on restart:
          Ok, thank you!
            RodrigoRMaraujo @cosmowave
            @cosmowave thanks for the answer.
            Got it, but I'm not sure it would work well, because I check the status (state.status == "idle" || state.status == "busy"). This state will be the same before and after the G4. The problem, as I understand it, is the reading of a false signal through the endstop port, which is apparently extremely sensitive to noise.
            fcwiltundefined cosmowaveundefined 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @RodrigoRMaraujo
              @rodrigormaraujo
              Are the switches of the normally closed type?
              Are the triggers running when you press the switch or release the switch.
              I've got plain normally closed switches on both Duet 2 and Duet 3 hardware using the built-in pull-up resistors and have never seen your kind of problem.
              RodrigoRMaraujoundefined 1 Reply Last reply Reply Quote 1
                Eventually you can improve the cabeling (shielded cable)? try to not routing them near to stepper/ stepper cables...
                  RodrigoRMaraujo @fcwilt
                  @fcwilt said in Triggers firing by themselves on restart:
                  No, I used normally open mechanical keyboard (cherry mx green) buttons.
                  [https://pt.aliexpress.com/item/1005001681627152.html?spm=a2g0s.9042311.0.0.2742b90a6Tptvm]
                  A friend commented to me about using NC buttons. I ordered magnetic filters on aliexpress. If the problem persists I will look for these buttons, but I will have to review how to install them on the skirts of the voron.
                    @cosmowave said in Triggers firing by themselves on restart:
                    I ordered magnetic filters on the advice of a friend who works in electronics and builds cnc machines. According to him, this will help eliminate noise.
                    [https://pt.aliexpress.com/item/4000803662446.html?spm=a2g0s.9042311.0.0.3366b90aNy53pX]
                    • fcwiltundefined
                      Normally closed setups are less sensitive to noise. Your normally open switches might, perhaps, be the cause of your problem.
                        @fcwilt yes, thank you!
