Heater config not working, why?
Hi *,
I have a problem with my new setup. (The config is still a bit "wild", do not be shocked, you have been warned. (Mini 5+ FW 3.3)
Thing is: The bed heater does not work:
; Bed M308 S0 P"0.temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out5" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C
I tried "out5" and "out6", with and without "1." in front. The outputs should drive a SSR. I do not measure any voltage change when I turn on the heater via the DWC. I had a close look the the MosFets next to the output, they look good. I do not measure anythings at the pins, not VIN against GND and not GND when I measure against the power supply.
What else to test? (Jumper is still in factory default)Full Config:
; Default config.g template for DuetPi ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org) ; Display initial welcome message ;M291 P"Please go to <a href=""https://www.duet3d.com/StartHere"" target=""_blank"">this</a> page for further instructions on how to set it up." R"Welcome to your new Duet 3!" S1 T0 ; Hardware: Duet Mini 5+ ; Stepper XY = LDO 0,9° 2Amax LDO-42STH40-2004MAC ; Stepper Z = LDO 1,8° 2Amax LDO-42STH48-2004AC ; Stepper E = LDO 1,8 1Amax LDO-42STH20-1004ASH ; Enable network if {network.interfaces[0].type = "ethernet"} M552 P0.0.0.0 S1 else M552 S1 ; Network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"v2" ; set printer name M669 K1 ; 1=select CoreXY mode 0=Cadasian ;; Toolboards ; M115 B121 ; Show board 121 ; M997 B121 ; Update tool 121 ; M122 B121 ; Detailed status of toolboard G4 S1 ; wait for expansion boards to start ;;; Drives ;X M569 P0.2 S1 M584 X0.2 ;Y M569 P0.1 S0 M584 Y0.1 ;; Z ; - front left M569 P0.5 S1 ; physical drive 0.6 goes forward/backward - ; - front right M569 P0.6 S0 ; physical drive 0.5 goes forward/backward - ; - back left M569 P0.0 S1 ; physical drive 0.0 goes forward/backward - ; - back right M569 P0.4 S0 ; physical drive 0.4 goes forward/backward - M584 Z0.4:0.0:0.5:0.6 ;; E M569 P121.0 S0 M584 E121.0 ;M584 X0.2 Y0.0 Z0.3:0.4:0.5 E121.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160 Y160 Z400 E560 ; set steps per mm M92 X80.00 Y80.00 Z400.00 E420.00 M566 X200.00 Y200.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z480.00 E1200.00 ; set maximum speeds (mm/min) Z180 M201 X400.00 Y400.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1400 Y1400 Z1400 E700 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M84 S120 ; Idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X230 Y250 Z275 S0 ; set axis maxima ;; Endstops -- Display status with: M119 M574 Y2 S1 P"0.io5.in" ; Y M574 X2 S1 P"!0.io6.in" ; X M574 Z0 P"nil" ; No Z endstop, we have a probe ; Z probe ; Vinda: Black = Signal - Brown = +5v - Blue = GND M574 Z1 S2 ; Configure Z-probe endstop for low end on Z M558 P8 C"^121.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0.1 Y-0.1 ; set Z probe offset G31 Z0.05 ; set Z probe and trigger height M557 X0:270 Y0:290 S15 ; define mesh grid ; Z-level settings M671 X-65:-65:365:365 Y-20:380:380:-20 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) M557 X25:275 Y25:275 S25 ; Define bed mesh grid (inductive probe, positions include the Z offset!) ;; Heaters :: Tune with: M303 H0 S115 ; Bed M308 S0 P"0.temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out5" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ; Hotend ; Tune in with: M303 H1 S270 (270=Temp) (M500 to save) ; Show current settings M307 H1 M308 S1 P"121.temp0" Y"thermistor" T500000 B4702 C1.171057e-7 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"121.out0" T1 ; create nozzle heater output on 0.out3 and map it to sensor 1 M143 H1 S400 ; set temperature limit for heater 1 to 320C ;; Fans ; Fan for the printed part: M950 F0 C"121.out1" Q500 ; create fan 0 on pin 0.out9 and set its frequency M106 P0 S0 H-1 C"Part" ; set fan 0 value. Thermostatic control is turned off ; Fan for the Hotend: M950 F1 C"121.out2" Q500 ; create fan 1 on pin 0.out9 and set its frequency M106 P1 S1 H1 T45 C"Hotend" ; P="set fan 1" S="value" H="Thermostatic control Heater No." T=" is turned on at 45°C" ;; Tool M563 P0 S"Tool" D0 H1 F0 ; define tool G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ;;;;;;;;;;;; Setup Only ;M564 S0 H0 ; Allow movement over the endstops M302 P1 ; allow cold extrusion ;M302 S1 ; deny cold extrusion ;;;;;;;;;;;; Setup Only END M501 ; Load config-override.g ; Serial interface M575 P1 B115200 S1 ; Mini 12864 M918 P2 ;M918 P2 E4 R3 C100 ;M150 X2 R255 U255 B255 S3 ; set all 3 LEDs to white M150 X2 R0 U255 B0 S3 ; set all 3 LEDs to red T0 ; Select the tool 0 as default
Cheers, Chriss
@chriss At a guess, I'd say that it might be because the PWM frequency might be too high for your SSR. I believe that if you don't specify a value, then frequency will default to 250 for heaters. But SSRs usually need much lower values - typically 10 Hz. So try adding Q10 to you M950 command for the bed heater.
i.e. try this: M950 H0 C"out5" T0 Q10.
Note also that the Mosfet switches the negative side, so you won't see any change on the voltage input side of the heater connector.
@deckingman said in Heater config not working, why?:
I tried it, without success.Note also that the Mosfet switches the negative side, so you won't see any change on the voltage input side of the heater connector.
Well, what I measure is 24V between "V_OUTLC2+" out out 5 and GND. Clear because we switch GND here. What I do not see is a change on the GND pin.
The SSR works when I trigger it with a wire from GND of the power supply to the SSR.
Cheers, Chriss
@chriss Update: I pushed two pins in the connector (the same typo of connectors as on the boad) and powered the pins. That triggered the SSR. So I do not expect any problems with the crimping or the wires.
Cheers, Chriss
@chriss I tested now with out0, same result. I do not get the SSR working, I see no GND on the ground pin.
I thing that I should see the LED next to the connector blinking (out0), shouldn't I? (The LED remains off)
Cheers, Chriss
This here works funnily:
M950 F3 C"0.out0" Q10 ; LED on out6 ground on top pin, plus on 3rd pin from top (V_OUTLC1) M106 P3 C"LED" S0
So something is wrong with my heater here....
The config.g looks now like that:
; Default config.g template for DuetPi ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org) ; Display initial welcome message ;M291 P"Please go to <a href=""https://www.duet3d.com/StartHere"" target=""_blank"">this</a> page for further instructions on how to set it up." R"Welcome to your new Duet 3!" S1 T0 ; Hardware: Duet Mini 5+ ; Stepper XY = LDO 0,9° 2Amax LDO-42STH40-2004MAC ; Stepper Z = LDO 1,8° 2Amax LDO-42STH48-2004AC ; Stepper E = LDO 1,8 1Amax LDO-42STH20-1004ASH ; Enable network if {network.interfaces[0].type = "ethernet"} M552 P0.0.0.0 S1 else M552 S1 ; Network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet ;; Heaters :: Tune with: M303 H0 S115 ; Bed ;M308 S0 P"0.temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 ;M950 H0 C"out6" T0 Q10 ; create bed heater output on out0 and map it to sensor 0 ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit ;M140 H0 ; map heated bed to heater 0 ;M143 H0 S120 ; set temperature limit for heater 0 to 120C ; Bed M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120
All other .g files where removed. And I still do not see the LED next to out0 blinking.
I have two more of the Mini 5+ and use exactly the same code on them and it works there. :?Cheers, Chriss
I upgraded to "3.4.0beta3 (2021-08-24)" now and you guys know what? The heater works now. Why? I have no idea..... :? Maybe a bit more "reset" than with a normal reboot? I have no idea at all.
Anyway, it works now...
Cheers, Chriss
Very strange. Please keep us posted.
