Duet 3 beta 3.4.0 b3 | Unable to setup Endstop on toolboard.
I have a toolboard configured as board 2 with three endstops in series, X, Y & Z. I have the Z probe set to use the same endstop. The z-probe can be seen to trigger in DWC when a switch is pressed.
However, when issuing M574 X1 P"2.io0.in" S1 i get an error telling me the pin isn't free.
Error: M574: Pin 2.io0.in is not free
This happens even when the z-probe is not setup with M558 P8 C"2.io0.in" H3 F360 I0 T20000
I have been unable to find out why. I have a similar setup using X & Y endstops on a single toolboard, and that seems to run just fine on a different machine.
What am I doing wrong?
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Vogue" ; set printer name M667 S1 ; Set CoreXY ; Drives M569 P0.0 S0 ; X M569 P0.1 S0 ; Y M569 P0.2 S0 ; T1 M569 P0.3 S0 ; B M569 P0.4 S0 ; T0 M569 P0.5 S1 ; Z M569 P1.0 S1 ; T3 M569 P1.1 S0 ; T2 M569 P1.2 S0 ; M569 P2.0 S0 ; C M584 X0.0 Y0.1 Z0.5 E0.4:0.2:1.1:1.0 B0.3 C2.0 ; Drive mapping M350 E16:16:16 C16 I0 ; Configure microstepping without interpolation M350 X16 Y16 Z16 B16 I1 ; Configure microstepping with interpolation M92 X100 Y100 Z800 B1600 C91.022 E396:396:396:396 ; Set steps per mm M566 X100 Y100 Z50 C2 B200 E10:10:10:10 ; Set maximum instantaneous speed changes (mm/min) M203 X35000 Y35000 Z4000 B3500 C5000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min) M201 X2000 Y2000 Z125 B500 C500 E1000:1000:1000:1000 ; Set accelerations (mm/s^2) M906 X1800 Y1800 Z1330 B750 I30 ; Idle motion motors to 30% M906 E1330:1330:1330 C500 I10 ; Idle extruder motors to 10% ; Axis Limits M208 X0:350 Y0:300 Z0:300 B0:50 C0:360 S0 ; Set axis maxima & minima ; Endstops M574 B1 C1 S3 ; Set B C endstops to stall detection M574 X0 P"nil" M574 Y0 P"nil" M574 Z0 P"nil" ; Setup Z-Probe M558 P8 C"2.io0.in" H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height M557 X10:290 Y20:180 S40 ; Define mesh grid ; Heaters M308 S0 A"Bed" P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out3" T0 ; create bed heater output on out2 and map it to sensor 0 M143 H0 S250 ; set temperature limit for heater 0 to 250C M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 A"T0" ; define E0 temperature sensor M950 H1 C"out1" T1 ; Extruder 0 heater M143 H1 S305 ; Set temperature limit for heater 1 to 300C M308 S2 P"1.temp1" Y"thermistor" T100000 B4725 C7.06e-8 A"T1" ; define E1 temperature sensor M950 H2 C"1.out1" T2 ; Extruder 1 heater M143 H2 S305 ; Set temperature limit for heater 2 to 300C M308 S3 P"1.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"T2" ; define E2 temperature sensor M950 H3 C"1.out2" T3 ; Extruder 2 heater M143 H3 S305 ; Set temperature limit for heater 3 to 300C M308 S4 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8 A"T3" ; define E3 temperature sensor M950 H4 C"out2" T4 ; Extruder 4 heater M143 H4 S305 ; Set temperature limit for heater 4 to 300C ; Fans M950 F0 C"out7" ; T0 Hotend Fan M950 F1 C"1.out7" ; T1 Hotend Fan M950 F2 C"out8" ; T3 Hotend Fan M950 F3 C"1.out8" ; T4 Hotend Fan M950 F4 C"out4" ; T0 Part Cooling Fan M950 F5 C"1.out4" ; T1 Part Cooling Fan M950 F6 C"out5" ; T3 Part Cooling Fan M950 F7 C"1.out5" ; T4 Part Cooling Fan M106 P0 T65 S255 H1 ; T0 HotEnd Fan M106 P1 T65 S255 H2 ; T2 HotEnd Fan M106 P2 T65 S255 H3 ; T3 HotEnd Fan M106 P3 T65 S255 H4 ; T4 HotEnd Fan M106 P4 S0 ; T0 Part Cooling Fan M106 P5 S0 ; T1 Part Cooling Fan M106 P6 S0 ; T2 Part Cooling Fan M106 P7 S0 ; T3 Part Cooling Fan ; Tools M563 P0 S"T0" D0 H1 F0 F4 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C M563 P1 S"T1" D1 H2 F1 F5 ; Define tool 1 G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C M563 P2 S"T2" D2 H3 F2 F6 ; Define tool 2 G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0C M563 P3 S"T3" D3 H4 F3 F7 ; Define tool 3 G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C ;Set Hotends to Standby T0 P0 T1 P0 T2 P0 T3 P0 T-1 P0 ; Machine settings M501 ; Load config-overide.g M575 P1 S1 B57600 ; Enable LCD ; homex.g ; called to home the x axis ;Set Endstops M574 Y0 P"nil" M574 Z0 P"nil" M574 X1 P"2.io0.in" S1 T-1 ; deselect tool G91 ; Relative mode G1 H2 Z5 F5000 ; Lower the bed G4 P50 ; wait 50msec G1 H1 X-350 F5000 ; Move X until the switch triggers (first pass) G4 P250 ; wait 250msec G1 X5 F5000 ; go back a few mm G4 P250 ; wait 250msec G1 H1 X-10 F300 ; Move X until the switch triggers (second pass) G1 X1 F5000 ; go back a few mm G90 ; Back to absolute positioning ;Release Endstops M574 X0 P"nil" M574 Y0 P"nil" M574 Z0 P"nil" -
@greg_the_maker is this happening even if you have the M558 line commented out in config.g and restart the machine? What happens when you send M558 with no parameters?
yes, even with M558 commented out.
@greg_the_maker add a G4 S2 before any CAN-FD connected board is referenced in your config.
This error is probably connected to this https://forum.duet3d.com/topic/24984/trouble-assigning-filament-sensor-after-using-pin-for-gpio/5?_=1631544376470
I think something very odd is going on.
Even with no M558, and nothing being assigned to use the pin, I can't assign anything to that pin.
@greg_the_maker which version of RRF are you running?
@greg_the_maker you can't assign a pin to be both a Z probe and an endstop. If you are using the Z probe in lieu of a Z endstop, then you don't need to configure a Z endstop, and your Z homing file should use a G30 command.
