homing dual z with independant motors
1.5k
    Monkey68
    duet 2wifi 1.03 ,3.3 fw
    cartesian printer
    dual z motors connected to z +e1
    dual z endstops connected to z +e1
    probe connected to probe
    can home x, can home y.
    z tries to home, it moves to the upper switches and triggers the switches as indicated by the leds on the board but the motors keep trying to go and it just sits there and bounces on the stops, the e1 light flashes.
      Monkey68
      M569 P0.0 S1 ; physical drive 0 goes forwards
      M569 P0.1 S1 ; physical drive 1 goes forwards
      M569 P0.2 S0 ; physical drive 2 goes backwards
      M569 P0.3 S1 ; physical drive 3 goes forwards
      M569 P0.4 S0 ; physical drive 4 goes backwards
      ;M584 X0 Y1 Z2 E3 ; set drive mapping
      M584 X0.0 Y0.1 Z0.2:0.4 E0.3 ;two Z motors connected to driver outputs Z and E1
      M671 X-18:224 Y112.5:112.5 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00:400.00 E143.2 ; set steps per mm
      M566 X800.00 Y800.00 Z1000.00:1000.00 E3600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9600.00 Y9600.00 Z1000.00:1000.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z600.00:600.00 E2000.00 ; set accelerations (mm/s^2)
      M906 X1250 Y1300 Z1250:1250 E1250 I30 ; set motor currents (mA) and motor idle factor in per cent
      M572 D0 S0.002 ;set pressure advance
      M84 S30 ; Set idle timeout
      M208 X-27 Y-35 Z0 S1 ; set axis minima
      M208 X250 Y225 Z300 S0 ; set axis maxima
      ;M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
      ; Endstops ```; Snnn 1 = switch-type (eg microswitch) endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z2 S1 P"!zstop" ; configure active-high endstops for low end on Z via pins zstop and e1stop
      M574 E12 S1 P"!e1stop"
      ;M574 Z2 S1 P"!zstop+!e1stop" ; configure active-high endstops for high end on Z via pins zstop and e1stop
      ; Filament Sensing
      M591 D0 P1 C"!e0stop" S1 ; filament monitor connected to E0 endstop
      M558 P1 C"zprobe.in" H3 F600 T6000 A3 S0.03 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P1000 X25 Y14 Z1.50 ; set Z probe trigger value, offset and trigger height
      ;M557 X45:265 Y45:265 S110 ; define mesh grid glass bed plate
      M557 X45:245 Y45:220 S87.5 ; define mesh grid prusa bed plate
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C0 R4700 ; configure sensor 0 as thermistor on pin bedtemp
      ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
      M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.196220e-7 ; configure sensor 1 as thermistor on pin e0temp
      ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      ;M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H1 A388.5 C88.1 D2.4 S1.00 V24.2 B0
      M143 H1 S500 ; set temperature limit for heater 1 to 500C
      M950 F0 C"^fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
      M950 F2 C"duex.fan3" Q500 ; create fan 2 on pin duex.fan3 and set its frequency
      M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
      M950 F3 C"duex.fan4" Q500 ; create fan 3 on pin duex.fan4 and set its frequency
      M106 P3 S1 H1 T45 ; set fan 3 value. Thermostatic control is turned on
      M563 P0 S"Copper Head" D0 H1 F0 ; define tool 0
      G10 P0 X0 Y0 Z0:0 ; set tool 0 axis offsets
      T0 ; select first tool
      M501
      undefined undefined 2 Replies Last reply 13 Sept 2021, 06:59 Reply Quote 0
        Monkey68
        ; homez.g
        ; called to home the Z axis
        ; generated by RepRapFirmware Configuration Tool v3.3.2 on Wed Sep 08 2021 20:07:17 GMT+1200 (New Zealand Standard Time)
        G90 ; absolute positioning
        G1 X125 Y105 F6000 ; go to probe point
        G91 ; relative positioning
        G1 H2 Z305 E1305 F1800 ; lift Z relative to current position
        G1 H1 Z-5 E1-5 F6000
        G1 H2 Z305 E1305 F360
        G90
          Monkey68
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.3.1 on Thu Aug 26 2021 19:02:13 GMT+1200 (New Zealand Standard Time)
          ;G91 ; relative positioning
          ;G1 H2 Z5 F6000 ; lift Z relative to current position
          ;G1 H1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          ;G1 X5 Y5 F6000 ; go back a few mm
          ;G1 H1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
          ;G90 ; absolute positioning
          ;G1 X125 Y105 F6000
          ;G30
          ;G1 Z5.5 F360 ; lift Z relative to current position
          G1 H1 X-282 Y265 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y-5 F6000 ; go back a few mm
          G1 H1 X-282 Y265 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G1 H1 Z305 F360 ; move Z up stopping at the endstop
          G92 Z300 ; set Z position to axis maximum (you may want to adjust this)
            o_lampe @Monkey68
            Once you've defined the dual Z axis like that: (modified quotation)
            @monkey68 said in homing dual z with independant motors:
            M92 X80.00 Y80.00 Z400.00 E143.2 ; set steps per mm
            M566 X... Y... Z1000.00 ...; set maximum instantaneous speed changes (mm/min)
            M203 X... Y... Z1000.00 E... ; set maximum speeds (mm/min)
            M201 X... Y... Z600.00 E... ; set accelerations (mm/s^2)
            M906 X... Y... Z1250 E... I30 ; set motor currents (mA) and motor idle factor in per cent
            ; endstops
            you must not refer to E1 in the homing files
            ; homez.g
            G1 H2 Z305 F1800 ; lift Z relative to current position
            G1 H1 Z-5 F6000
            G1 H2 Z10 F360
            G90
            undefined 1 Reply Last reply 13 Sept 2021, 07:54 Reply Quote 0
              Monkey68 @o_lampe
              @o_lampe ok thank you, I have tried that and it makes no difference
                Phaedrux Moderator @Monkey68
                The first line is incorrect. The second line is correct.
                Z1000.00:1000.00
                Remove all the duplicated values for Z from config.g
                Please share the results of sending M122 and M98 P"config.g"
                undefined 1 Reply Last reply 13 Sept 2021, 23:24 Reply Quote 0
                  Monkey68 @Phaedrux
                  @phaedrux said in homing dual z with independant motors:
                  M98 P"config.g"
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Endstop configuration:
                  X: low end switch connected to pin !xstop
                  Y: low end switch connected to pin !ystop
                  Z: high end switch connected to pin !zstopWarning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 442C
                  undefined undefined 2 Replies Last reply 13 Sept 2021, 23:25 Reply Quote 0
                    Monkey68 @Monkey68
                    @monkey68 ; Network
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    ;M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
                    M350 X16 Y16 Z16 E16 E116 I1
                    ;M92 X80.00 Y80.00 Z400.00:400.00 E143.2 ; set steps per mm
                    M92 X80.00 Y80.00 Z400.00 E143.2 E1400
                    ;M566 X800.00 Y800.00 Z1000.00:1000.00 E3600.00 ; set maximum instantaneous speed changes (mm/min)
                    M566 X800.00 Y800.00 Z1000.00 E3600.00 E11000
                    ;M203 X9600.00 Y9600.00 Z1000.00:1000.00 E6000.00 ; set maximum speeds (mm/min)
                    M203 X9600.00 Y9600.00 Z1000.00 E6000.00 E11000
                    ;M201 X1000.00 Y1000.00 Z600.00:600.00 E2000.00 ; set accelerations (mm/s^2)
                    M201 X1000.00 Y1000.00 Z600.00 E2000.00 E1600
                    ;M906 X1250 Y1300 Z1250:1250 E1250 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M906 X1250 Y1300 Z1250 E1250 E11250 I30
                    ; Filament Sensing
                    M501
                    undefined undefined 3 Replies Last reply 13 Sept 2021, 23:29 Reply Quote 0
                      Monkey68 @Monkey68
                      @monkey68 the heater 0 is room temperature as in its not hot 😉
                        Is this being reported from when you send M98 P"config.g"?
                        If you're referring to the heater 0 temp warning it's just telling you what the predicted max temp could be in a runaway situation.
                        Can we get this please?
                        What are you trying to do with this command?
                        You've got E values listed twice in some of your commands. Why?
                        Do you have multiple extruders? If so the correct format is E###:### just like you had before for the Z axis. That format is only correct for extruders.
                        undefined 3 Replies Last reply 14 Sept 2021, 04:07 Reply Quote 0
                          Monkey68 @Phaedrux
                          @phaedrux 14/09/2021, 16:06:14 m122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
                          Board ID: 08DGM-9568A-F23SD-6JTDG-3SN6P-1UR7H
                          Used output buffers: 3 of 24 (15 max)
                          Static ram: 23876
                          Dynamic ram: 76012 of which 0 recycled
                          Never used RAM 14528, free system stack 182 words
                          Tasks: NETWORK(ready,78.7%,244) HEAT(delaying,0.2%,314) Move(notifyWait,0.4%,340) DUEX(notifyWait,0.0%,24) MAIN(running,20.6%,441) IDLE(ready,0.1%,29), total 100.0%
                          Owned mutexes:
                          Last reset 04:38:52 ago, cause: software
                          Last software reset at 2021-09-14 11:27, reason: User, GCodes spinning, available RAM 11320, slot 1
                          Error status: 0x00
                          Step timer max interval 0
                          MCU temperature: min 36.4, current 41.9, max 42.4
                          Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                          Driver 0: position 0, standstill, SG min/max not available
                          Driver 1: position 0, standstill, SG min/max not available
                          Driver 2: position 0, standstill, SG min/max not available
                          Driver 3: position 0, standstill, SG min/max not available
                          Driver 4: position 0, standstill, SG min/max not available
                          Driver 5: position 0, standstill, SG min/max not available
                          Driver 6: position 0, standstill, SG min/max not available
                          Driver 7: position 0, standstill, SG min/max not available
                          Driver 8: position 0, standstill, SG min/max not available
                          Driver 9: position 0, standstill, SG min/max not available
                          Driver 10: position 0
                          Driver 11: position 0
                          Date/time: 2021-09-14 16:06:12
                          Slowest loop: 6.17ms; fastest: 0.17ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 1.3ms, write time 0.0ms, max retries 0
                          === MainDDARing ===
                          === AuxDDARing ===
                          Heater 1 is on, I-accum = 0.0
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Code queue is empty.
                          === Filament sensors ===
                          Extruder 0 sensor: ok
                          === DueX ===
                          Read count 1, 0.00 reads/min
                          === Network ===
                          Slowest loop: 15.58ms; fastest: 0.00ms
                          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                          HTTP sessions: 1 of 8
                          • WiFi -
                            Network state is active
                            WiFi firmware version 1.26
                            WiFi MAC address 2c:3a:e8:0b:1f:b7
                            WiFi Vcc 3.34, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 26920
                            WiFi IP address 192.168.50.251
                            WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
                            Clock register 00002002
                            Socket states: 4 0 0 0 0 0 0 0
                          undefined 1 Reply Last reply 14 Sept 2021, 04:09 Reply Quote 0
                            Monkey68 @Monkey68
                            @monkey68 14/09/2021, 16:08:44 M98 P"config.g"
                            FTP is disabled
                            TELNET is disabled
                              Can you remove that line from config.g and send M98 P"config.g" again and see if it still spits out the endstop configuration?
                                Monkey68 @Phaedrux
                                @phaedrux ok i will remove them, the motor connected to E1 did not move before just the z and reading throught all of the comments and checking out the how to's which i have come to figure out are out dated and dont apply to the 3 series firmware is really confusing and should be sorted out and then you guys wouldnt be so busy doing the supposed simple stuff that we that are less affluent in the firmware can not work out, it was much simpler when i first got my duet as i could read the guides and copy the needed txt and like magic it just worked, sadly thats not the case anymore. sorry for the rant
                                  The instructions are here for both RRF2 and RRF3.
                                  https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                                  What guides are you looking at that are out of date?
                                  undefined 1 Reply Last reply 14 Sept 2021, 04:22 Reply Quote 0
                                    Monkey68 @Phaedrux
                                    @phaedrux 14/09/2021, 16:21:37 M98 P"config.g"
                                    FTP is disabled
                                    TELNET is disabled
                                      Ok, so now you can uncomment that line, which should be correct.
                                      Now you can test the homing again, but this time click the switches by hand before it reaches them so that you have time to hit the estop if it doesn't stop movement.
                                      You can also check the status of the endstops by sending M119. Check it when the endstops are depressed and again when they are not and see if it reports the state you would expect.
                                        Monkey68 @Phaedrux
                                        @phaedrux M574 E12 S1 P"!e1stop"
                                        following the instructions given in the guides, specifying the stop for the motor and its place on the axis
                                        undefined 1 Reply Last reply 14 Sept 2021, 04:33 Reply Quote 0
                                          What guides?
                                          E12 isn't valid in any way.
                                          undefined 1 Reply Last reply 14 Sept 2021, 04:36 Reply Quote 0
                                          9 out of 36
