    [Solved][Duet2Wifi] WiFi SPI Timeout after removing SBC Mod
    781
    • keyz182undefined
      keyz182 @T3P3Tony
      @t3p3tony
      Connecting...
      Printer is now online.
      >>>M997 S1
      SENDING:M997 S1
      Trying to connect at 230400 baud:
       success
      Erasing 4096 bytes...
      Erasing 196608 bytes...
      Uploading file...
      5% complete
      10% complete
      15% complete
      20% complete
      25% complete
      30% complete
      35% complete
      40% complete
      45% complete
      50% complete
      55% complete
      60% complete
      65% complete
      70% complete
      75% complete
      80% complete
      85% complete
      90% complete
      95% complete
      Upload successful
      And for good measure I did an M997 S0 too which correctly reports 3.3 after a restart and M122.
        T3P3Tony administrators @keyz182
        @keyz182 ok to the UART comms to the module is working. Have a look at the schematic here
        https://github.com/Duet3D/Duet-2-Hardware/blob/master/Duet2/Old versions/DuetWifiv1.02/DuetWifi_Schematic_v1.02.pdf
        you can test the continuity for the SPI pins
        keyz182undefined 2 Replies Last reply Reply Quote 0
        • keyz182undefined
          keyz182 @T3P3Tony
          @t3p3tony Continuity to the MCU for MOSI, MISO and SPCK, any other pins I should check?
          • keyz182undefined
            keyz182 @T3P3Tony
            @t3p3tony There's continuity on all three.
              @keyz182 also the ESP_DATA_RDY and NPCS0
              keyz182undefined albertshaoundefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @keyz182
                @keyz182 is the SPI timeout message consistent? That message is sometimes produced spuriously, especially when sending a M587 command for the first time after re-flashing the WiFi firmware.
                • keyz182undefined
                  keyz182 @T3P3Tony
                  @t3p3tony Continuity (through 2.2KOhm) on both which seems to tally up with the schematic.
                  @dc42 It's consistent. Right after a flash, leaving it a while, rebooting, etc, all the same as soon as I try M587 or M122.
                  Connecting...
                  >>>M552 S1
                  SENDING:M552 S1
                  WiFi module started
                  WiFi reported error: no known networks found
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  >>>M587 S"IoT_2G" P"********"
                  SENDING:M587 S"IoT_2G" P"********"
                  Error: M587: Failed to add SSID to remembered list: SPI timeout
                  [ERROR] Error: M587: Failed to add SSID to remembered list: SPI timeout
                  Error retrieving WiFi status message: SPI timeout
                  [ERROR] Error retrieving WiFi status message: SPI timeout
                  WiFi module is idle
                  Failed to change WiFi mode: SPI timeout
                  >>>M552 S-1
                  SENDING:M552 S-1
                  >>>M552 S0
                  SENDING:M552 S0
                  WiFi module started
                  >>>M552 S1
                  SENDING:M552 S1
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                    jay_s_uk @keyz182
                    @keyz182 can you try sending M552 S0 before trying M587?
                    I find its sometimes not happy sending the wifi details when in S1
                    keyz182undefined 1 Reply Last reply Reply Quote 1
                    • keyz182undefined
                      keyz182 @jay_s_uk
                      @jay_s_uk OK, that worked. Is that documented behavior that I've just misread? I swear I've always done M552 S1 before any M587 commands.
                        jay_s_uk @keyz182
                        @keyz182 the step by step guide does say to put it in S0 mode first.
                        Its also they way I've documented it on all the STM32/LPC port support pages.
                        • albertshaoundefined
                          albertshao @T3P3Tony
                          @t3p3tony what do ESP_DATA_RDY and NPCS0 for? can this to pin connect to GND or 3.3V pull up, thanks for reply
