    SD card not detected by Paneldue, until I detect via DWC
    PanelDue
    • jbergeneundefined
      jbergene
      hey
      running latest versions of beta 3.4
      latest version paneldue and latest DWC
      When I plug in the SD into the Paneldue, I have to detect it first via the DWC by pressing SD card #1
      If i dont do that it never shows up on the SD card list on panel due.
      • mfs12undefined
        mfs12
        Hey @jbergene to access a second sd card you need to open the files dialog and press on top left the 'Files on card X' button.
        Did you do that?
        • mfs12undefined
          mfs12
          This post is deleted!
          • mfs12undefined
            mfs12
            @jbergene thanks for reporting this issue.
            I created an issue at github. Any further progress will be done there.
            https://github.com/Duet3D/PanelDueFirmware/issues/207
            mfs12 created this issue in Duet3D/PanelDueFirmware
            closed Wrong number for available sd card slots is use #207
            • mfs12undefined
              mfs12
              Will be part of next release.
              jbergeneundefined 1 Reply Last reply Reply Quote 1
              • RomanVinundefined
                RomanVin
                I registered the M21 P1 config.g in the initial lines and the card slot started working. A little crooked solution but working. Condition - the card must be in the slot. Or, after installing the card, reset the controller.
                • jbergeneundefined
                  jbergene @mfs12
                  @mfs12 thank you
