    New test firmware 1.19+5
    Firmware installation
    2.8k
    • andreduplessisundefined
      andreduplessis
      Hi David
      Thanks for all your hard work. I love all that baked in magical goodness 🙂
      Something that I have picked up is that the layer duration graph on DWC gets confused when the Z-babystepping is increased during the first layer of the print. This is not something new and specific to 1.19.
      • DjDemonDundefined
        DjDemonD
        Installed this yesterday on one machine, printed a calibration object, looked great, but then I was not having any of the known issues with 1.19+4.
        www.precisionpiezo.co.uk
        • frafaundefined
          frafa
          Hi
          1.19+5 is unusable for me on Scara
          Very slow movements x / y / z
          And completely jerky
          impossible download 1.19+4 link download 1.19+5 …
          Please link to download downgrade 1.19+4 🙂
          Scara with DuetWifi => Scarlette3D
          https://youtu.be/mBF5cO8vGhI
            Strange, it's working well on my SCARA printer. What segments/second setting are you using, and what are your E steps/mm?
            • frafaundefined
              frafa
              My config.g
              ; Configuration file for Duet WiFi (firmware version 1.17)
              ; generated by RepRapFirmware Configuration Tool on Tue Jul 04 2017 23:08:34 GMT+0200
              M111 S0 ; S0 Debugging off S1 ; Debugging on
              G21 ; Work in millimetres
              ;M83  ; Set extruder to relative mode
              M82 ; Set extruder to absolute mode (Default: Simplify3d - Cura - Slic3r)
              M555 P2 ; Set firmware compatibility to look like Marlin
              M208 X300 Y300 Z385				; set axis maxima (adjust to suit your machine)
              M208 X0 Y0 Z0 S1				; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
              M574 X1 S0 ; Define (P) active low microswitches
              M574 y2 S0 ; Define (D) active high microswitches
              M574 Z0 S0 ; Define (Z) active low and unused microswitches
              ; Z probe
              M558 P1 I0 X0 Y0 Z1
              G31 Z1.2 P500 ;
              ; probe points for bed levelling (M557 Utilisé par G29) (ou utiliser G32 qui execute le fichier bed.g)
              ; https://duet3d.com/wiki/Using_mesh_bed_compensation
              M557 X20:260 Y20:260 S30   ; probe from X=20 to 290, Y=20 to 290mm with a mesh spacing of 20mm (Utilisé par G29)
              ;M558: Set Z probe type
              ;    Pnnn Z probe type
              ;    Xnnn If nonzero, use probe for homing X axis
              ;    Ynnn If nonzero, use probe for homing Y axis
              ;    Znnn If nonzero, use probe for homing Z axis
              ;    Fnnn Feed rate (i.e. probing speed, mm/min)
              ;    Hnnn Dive height (mm)
              ;    Innn Invert (I1) or do not invert (I0) the Z probe reading (RepRapFirmware 1.16 and later)
              ;    Rnnn Z probe recovery time after triggering, default zero (seconds) (RepRapFirmware 1.17 and later)1
              ;    Tnnn Travel speed to and between probe points (mm/min)
              ;    Snnn Extra parameter for experimentation
              ; Drives - Axis and motor configuration
              M569 P0 S0                    ; Drive 0 (X) goes forwards
              M569 P1 S1                    ; Drive 1 (Y) goes forwards
              M569 P2 S1                    ; Drive 2 (Z) goes forwards
              M569 P3 S0                    ; Drive 3 (E0) goes forwards
              M350 X256 Y256 Z16 E16 I1 ; Configure 256 microstepping with interpolation
              ;Calcul Step/mm X/Y (Réduction 80/16) ==> 400*256*(160/16)/360=2844,4444444444444444444444444444
              ;Calcul Step/mm Z   (Réduction 51/1)  ==> 200*256*51/2.0/20=6528
              M92 X2844.4444444444444444444444444444 Y2844.4444444444444444444444444444 Z4080 E475 ; Set steps per mm (extruder -debit = plus petite valeur)
              M566 X300 Y300 Z15 E120 ; Set maximum instantaneous speed changes (mm/min)
              M203 X6000 Y6000 Z300 E1200 ; Set maximum speeds (mm/min)
              M201 X600 Y600 Z250 E250 ; Set accelerations (mm/s^2)
              M906 X1400 Y1400 Z1400 E1000 I60 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              ;M669: Set kinematics type and kinematics parameters
              ;https://duet3d.com/wiki/G-code#M669:_Set_kinematics_type_and_kinematics_parameters
              M669 K4 P200 D200 A-116:175 B-175:140 1:0:0 S120 T0.2 X64.2 Y-150.0; set SCARA kinematics parameters ok S200
              ;old 116/140
              ;Snnn Segments per second if smooth XY motion is approximated by means of segmentation
              ;Tnnn Minimum segment length (mm) if smooth XY motion is approximated by means of segmentation
              ; Heaters Buse & Bed
              M143 S260 ; Set maximum heater temperature to 260C
              M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
              M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
              M563 P0 D0 H1 ; Define tool 0
              M550 PScara ; Set machine name
              M552 S1 ; Enable network
              ; Access point is configured manually via M587 by the user
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 S0.3 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P2 S0.3 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
              • frafaundefined
                frafa
                I found a 1.19 + 4 all is ok with him without changing anything
                  @frafa:
                  I'd like to get this sorted before the 1.19.2 release if possible, but there isn't much time. Please can you test 1.19+5 with a long straight non-extruding move, and a long straight move with extrusion. I am interested in whether both types of move are jerky, or just one of them. Also please test whether both fast and slow moves have the problem.
                  • frafaundefined
                    frafa
                    reinstall 1.19+5 move without extrude ok is linear
                    extrude very vibrate unusable …
                    It's really horrible kind of (parkinson's disease)
                    the gcode file tested
                    ; G-Code generated by Simplify3D(R) Version 4.0.0
                    ; Aug 26, 2017 at 1:19:37 AM
                    ; Settings Summary
                    ;   processName,Process1
                    ;   applyToModels,clips-e3d,clips-e3d(2)
                    ;   profileName,Scara Bracelets
                    ;   profileVersion,2017-08-22 21:23:10
                    ;   baseProfile,Default
                    ;   printMaterial,PLA
                    ;   printQuality,Medium
                    ;   printExtruders,
                    ;   extruderName,Extruder 1
                    ;   extruderToolheadNumber,0
                    ;   extruderDiameter,0.4
                    ;   extruderAutoWidth,0
                    ;   extruderWidth,0.4
                    ;   extrusionMultiplier,1
                    ;   extruderUseRetract,1
                    ;   extruderRetractionDistance,6.5
                    ;   extruderExtraRestartDistance,0
                    ;   extruderRetractionZLift,0
                    ;   extruderRetractionSpeed,1500
                    ;   extruderUseCoasting,1
                    ;   extruderCoastingDistance,1
                    ;   extruderUseWipe,0
                    ;   extruderWipeDistance,5
                    ;   primaryExtruder,0
                    ;   layerHeight,0.2
                    ;   topSolidLayers,3
                    ;   bottomSolidLayers,3
                    ;   perimeterOutlines,3
                    ;   printPerimetersInsideOut,1
                    ;   startPointOption,2
                    ;   startPointOriginX,0
                    ;   startPointOriginY,0
                    ;   sequentialIslands,0
                    ;   spiralVaseMode,0
                    ;   firstLayerHeightPercentage,150
                    ;   firstLayerWidthPercentage,100
                    ;   firstLayerUnderspeed,0.5
                    ;   useRaft,0
                    ;   raftExtruder,0
                    ;   raftTopLayers,3
                    ;   raftBaseLayers,2
                    ;   raftOffset,3
                    ;   raftSeparationDistance,0.14
                    ;   raftTopInfill,100
                    ;   aboveRaftSpeedMultiplier,0.3
                    ;   useSkirt,1
                    ;   skirtExtruder,0
                    ;   skirtLayers,1
                    ;   skirtOutlines,3
                    ;   skirtOffset,6
                    ;   usePrimePillar,0
                    ;   primePillarExtruder,999
                    ;   primePillarWidth,12
                    ;   primePillarLocation,7
                    ;   primePillarSpeedMultiplier,1
                    ;   useOozeShield,0
                    ;   oozeShieldExtruder,999
                    ;   oozeShieldOffset,2
                    ;   oozeShieldOutlines,1
                    ;   oozeShieldSidewallShape,1
                    ;   oozeShieldSidewallAngle,30
                    ;   oozeShieldSpeedMultiplier,1
                    ;   infillExtruder,0
                    ;   internalInfillPattern,Rectilinear
                    ;   externalInfillPattern,Rectilinear
                    ;   infillPercentage,32
                    ;   outlineOverlapPercentage,15
                    ;   infillExtrusionWidthPercentage,100
                    ;   minInfillLength,5
                    ;   infillLayerInterval,1
                    ;   internalInfillAngles,45,-45
                    ;   overlapInternalInfillAngles,0
                    ;   externalInfillAngles,45,-45
                    ;   generateSupport,0
                    ;   supportExtruder,0
                    ;   supportInfillPercentage,30
                    ;   supportExtraInflation,0
                    ;   supportBaseLayers,0
                    ;   denseSupportExtruder,0
                    ;   denseSupportLayers,0
                    ;   denseSupportInfillPercentage,70
                    ;   supportLayerInterval,1
                    ;   supportHorizontalPartOffset,0.3
                    ;   supportUpperSeparationLayers,1
                    ;   supportLowerSeparationLayers,1
                    ;   supportType,1
                    ;   supportGridSpacing,4
                    ;   maxOverhangAngle,45
                    ;   supportAngles,0
                    ;   temperatureName,Extruder 1,Heated Bed
                    ;   temperatureNumber,0,1
                    ;   temperatureSetpointCount,1,1
                    ;   temperatureSetpointLayers,1,1
                    ;   temperatureSetpointTemperatures,210,60
                    ;   temperatureStabilizeAtStartup,1,1
                    ;   temperatureHeatedBed,0,1
                    ;   temperatureRelayBetweenLayers,0,0
                    ;   temperatureRelayBetweenLoops,0,0
                    ;   fanLayers,1,2
                    ;   fanSpeeds,0,100
                    ;   blipFanToFullPower,0
                    ;   adjustSpeedForCooling,1
                    ;   minSpeedLayerTime,15
                    ;   minCoolingSpeedSlowdown,20
                    ;   increaseFanForCooling,0
                    ;   minFanLayerTime,45
                    ;   maxCoolingFanSpeed,100
                    ;   increaseFanForBridging,0
                    ;   bridgingFanSpeed,100
                    ;   use5D,1
                    ;   relativeEdistances,0
                    ;   allowEaxisZeroing,1
                    ;   independentExtruderAxes,0
                    ;   includeM10123,0
                    ;   stickySupport,1
                    ;   applyToolheadOffsets,0
                    ;   gcodeXoffset,0
                    ;   gcodeYoffset,0
                    ;   gcodeZoffset,0
                    ;   overrideMachineDefinition,1
                    ;   machineTypeOverride,0
                    ;   strokeXoverride,300
                    ;   strokeYoverride,300
                    ;   strokeZoverride,400
                    ;   originOffsetXoverride,0
                    ;   originOffsetYoverride,0
                    ;   originOffsetZoverride,0
                    ;   homeXdirOverride,-1
                    ;   homeYdirOverride,-1
                    ;   homeZdirOverride,-1
                    ;   flipXoverride,1
                    ;   flipYoverride,-1
                    ;   flipZoverride,1
                    ;   toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0
                    ;   overrideFirmwareConfiguration,1
                    ;   firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter)
                    ;   GPXconfigOverride,r2
                    ;   baudRateOverride,115200
                    ;   overridePrinterModels,0
                    ;   printerModelsOverride
                    ;   startingGcode,M106 P0 S0 ;Fan Off,M106 P1 S0 ;Fan Off,M106 P2 S0 ;Fan Off,G28 ; home all axes,G92 E0 ; zero the extruded length,G1 Z10 ; lower,G1 E10 F200 ; purge nozzle quickly,G1 E15 F60 ; purge nozzle slowly,G92 E0 ; zero the extruded length again,G1 E-5.5 F400 ; retract,G1 Y100 Z0 F9000 ; pull away filament,G1 Y100 F9000 ; wipe,G1 X20 F9000 ; wipe,G1 E0 ; feed filament back
                    ;   layerChangeGcode,
                    ;   retractionGcode,
                    ;   toolChangeGcode,
                    ;   endingGcode,M104 S0 ; turn off extruder,M140 S0 ; turn off bed,G91 ; use relative coordinates,G1 Z0.6 F5000 ; lift nozzle by 0.6mm,G90 ; use absolute coordinates,G1 X150  Y0 ; move Y axis to end position,M84 ; disable extruder,;M18 ; Disable all stepper motors,M107 ; turn off fan
                    ;   exportFileFormat,gcode
                    ;   celebration,0
                    ;   celebrationSong,Random Song
                    ;   postProcessing,
                    ;   defaultSpeed,3600
                    ;   outlineUnderspeed,0.5
                    ;   solidInfillUnderspeed,0.8
                    ;   supportUnderspeed,0.8
                    ;   rapidXYspeed,4800
                    ;   rapidZspeed,300
                    ;   minBridgingArea,50
                    ;   bridgingExtraInflation,0
                    ;   bridgingExtrusionMultiplier,1
                    ;   bridgingSpeedMultiplier,1
                    ;   useFixedBridgingAngle,0
                    ;   fixedBridgingAngle,0
                    ;   applyBridgingToPerimeters,0
                    ;   filamentDiameters,2.85|2.85|2.85|2.85|2.85|2.85
                    ;   filamentPricesPerKg,46|46|46|46|46|46
                    ;   filamentDensities,1.25|1.25|1.25|1.25|1.25|1.25
                    ;   useMinPrintHeight,0
                    ;   minPrintHeight,0
                    ;   useMaxPrintHeight,0
                    ;   maxPrintHeight,0
                    ;   useDiaphragm,0
                    ;   diaphragmLayerInterval,20
                    ;   robustSlicing,1
                    ;   mergeAllIntoSolid,0
                    ;   onlyRetractWhenCrossingOutline,1
                    ;   retractBetweenLayers,1
                    ;   useRetractionMinTravel,0
                    ;   retractionMinTravel,3
                    ;   retractWhileWiping,0
                    ;   onlyWipeOutlines,1
                    ;   avoidCrossingOutline,0
                    ;   maxMovementDetourFactor,3
                    ;   toolChangeRetractionDistance,12
                    ;   toolChangeExtraRestartDistance,-0.5
                    ;   toolChangeRetractionSpeed,600
                    ;   externalThinWallType,0
                    ;   internalThinWallType,2
                    ;   thinWallAllowedOverlapPercentage,10
                    ;   singleExtrusionMinLength,1
                    ;   singleExtrusionMinPrintingWidthPercentage,50
                    ;   singleExtrusionMaxPrintingWidthPercentage,200
                    ;   singleExtrusionEndpointExtension,0.2
                    ;   horizontalSizeCompensation,0
                    G90
                    M82
                    M106 S0
                    M140 S60
                    M190 S60
                    M104 S210 T0
                    M109 S210 T0
                    M106 P0 S0 ;Fan Off
                    M106 P1 S0 ;Fan Off
                    M106 P2 S0 ;Fan Off
                    G28 ; home all axes
                    G1 Z10 ; lower
                    G1 X20 F9000 ; wipe
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 Z0.300 F300
                    ; process Process1
                    ; layer 1, Z = 0.300
                    T0
                    ; tool H0.300 W0.400
                    ; skirt
                    G1 X140.635 Y130.482 F4800
                    G1 E0.0000 F450
                    G92 E0
                    G1 X140.657 Y130.458 E0.0006 F1800
                    G1 X140.958 Y130.157 E0.0086
                    G1 X140.982 Y130.135 E0.0092
                    G1 X141.892 Y129.337 E0.0320
                    G1 X141.917 Y129.316 E0.0326
                    G1 X142.255 Y129.057 E0.0406
                    G1 X142.281 Y129.038 E0.0412
                    G1 X143.288 Y128.365 E0.0640
                    G1 X143.316 Y128.348 E0.0646
                    G1 X143.684 Y128.135 E0.0726
                    G1 X143.713 Y128.120 E0.0732
                    G1 X144.799 Y127.584 E0.0960
                    G1 X144.829 Y127.571 E0.0966
                    G1 X145.222 Y127.408 E0.1046
                    G1 X145.252 Y127.397 E0.1053
                    G1 X146.399 Y127.007 E0.1280
                    G1 X146.430 Y126.998 E0.1286
                    G1 X146.841 Y126.888 E0.1366
                    G1 X146.873 Y126.880 E0.1373
                    G1 X148.060 Y126.644 E0.1600
                    G1 X148.092 Y126.639 E0.1606
                    G1 X148.514 Y126.583 E0.1686
                    G1 X148.547 Y126.580 E0.1693
                    G1 X149.755 Y126.501 E0.1920
                    G1 X149.787 Y126.500 E0.1926
                    G1 X150.213 Y126.500 E0.2007
                    G1 X150.245 Y126.501 E0.2013
                    G1 X151.453 Y126.580 E0.2240
                    G1 X151.486 Y126.583 E0.2247
                    G1 X151.908 Y126.639 E0.2327
                    G1 X151.940 Y126.644 E0.2333
                    G1 X153.127 Y126.880 E0.2560
                    G1 X153.159 Y126.888 E0.2567
                    G1 X153.570 Y126.998 E0.2647
                    G1 X153.601 Y127.007 E0.2653
                    G1 X154.748 Y127.397 E0.2880
                    G1 X154.778 Y127.408 E0.2887
                    G1 X155.172 Y127.571 E0.2967
                    G1 X155.201 Y127.585 E0.2973
                    G1 X156.287 Y128.120 E0.3201
                    G1 X156.316 Y128.135 E0.3207
                    G1 X156.684 Y128.348 E0.3287
                    G1 X156.712 Y128.365 E0.3293
                    G1 X157.718 Y129.038 E0.3521
                    G1 X157.745 Y129.057 E0.3527
                    G1 X158.083 Y129.316 E0.3607
                    G1 X158.108 Y129.337 E0.3613
                    G1 X159.018 Y130.135 E0.3841
                    G1 X159.042 Y130.157 E0.3847
                    G1 X159.343 Y130.458 E0.3927
                    G1 X159.365 Y130.482 E0.3933
                    G1 X160.163 Y131.392 E0.4161
                    G1 X160.184 Y131.417 E0.4167
                    G1 X160.443 Y131.755 E0.4247
                    G1 X160.462 Y131.782 E0.4253
                    G1 X161.135 Y132.788 E0.4481
                    G1 X161.152 Y132.816 E0.4487
                    G1 X161.365 Y133.184 E0.4567
                    G1 X161.380 Y133.213 E0.4573
                    G1 X161.915 Y134.299 E0.4801
                    G1 X161.929 Y134.329 E0.4807
                    G1 X162.092 Y134.722 E0.4887
                    G1 X162.103 Y134.752 E0.4893
                    G1 X162.492 Y135.898 E0.5121
                    G1 X162.502 Y135.930 E0.5127
                    G1 X162.612 Y136.341 E0.5207
                    G1 X162.620 Y136.373 E0.5213
                    G1 X162.856 Y137.560 E0.5441
                    G1 X162.861 Y137.592 E0.5447
                    G1 X162.917 Y138.014 E0.5527
                    G1 X162.920 Y138.047 E0.5533
                    G1 X162.992 Y139.148 E0.5741
                    G1 X162.993 Y139.164 E0.5744
                    G1 X163.000 Y139.377 E0.5784
                    G1 X163.000 Y139.394 E0.5787
                    G1 X163.000 Y144.606 E0.6768
                    G1 X163.000 Y144.623 E0.6771
                    G1 X162.993 Y144.835 E0.6811
                    G1 X162.992 Y144.851 E0.6814
                    G1 X162.946 Y145.561 E0.6947
                    G1 X162.942 Y145.593 E0.6954
                    G1 X162.887 Y146.016 E0.7034
                    G1 X162.881 Y146.048 E0.7040
                    G1 X162.722 Y146.850 E0.7194
                    G1 X162.714 Y146.882 E0.7200
                    G1 X162.604 Y147.293 E0.7280
                    G1 X162.595 Y147.324 E0.7286
                    G1 X162.332 Y148.097 E0.7440
                    G1 X162.321 Y148.128 E0.7446
                    G1 X162.158 Y148.521 E0.7526
                    G1 X162.144 Y148.551 E0.7532
                    G1 X161.783 Y149.284 E0.7686
                    G1 X161.768 Y149.313 E0.7692
                    G1 X161.555 Y149.682 E0.7772
                    G1 X161.537 Y149.709 E0.7778
                    G1 X161.083 Y150.389 E0.7932
                    G1 X161.064 Y150.416 E0.7938
                    G1 X160.805 Y150.753 E0.8018
                    G1 X160.784 Y150.779 E0.8024
                    G1 X160.600 Y150.988 E0.8077
                    G1 X161.135 Y151.788 E0.8258
                    G1 X161.152 Y151.816 E0.8264
                    G1 X161.365 Y152.184 E0.8344
                    G1 X161.380 Y152.213 E0.8350
                    G1 X161.915 Y153.299 E0.8578
                    G1 X161.929 Y153.329 E0.8584
                    G1 X162.092 Y153.722 E0.8664
                    G1 X162.103 Y153.752 E0.8670
                    G1 X162.492 Y154.898 E0.8898
                    G1 X162.502 Y154.930 E0.8904
                    G1 X162.612 Y155.341 E0.8984
                    G1 X162.620 Y155.373 E0.8990
                    G1 X162.856 Y156.560 E0.9218
                    G1 X162.861 Y156.592 E0.9224
                    G1 X162.917 Y157.014 E0.9304
                    G1 X162.920 Y157.047 E0.9310
                    G1 X162.992 Y158.148 E0.9518
                    G1 X162.993 Y158.164 E0.9521
                    G1 X163.000 Y158.377 E0.9561
                    G1 X163.000 Y158.394 E0.9564
                    G1 X163.000 Y163.606 E1.0544
                    G1 X163.000 Y163.623 E1.0548
                    G1 X162.993 Y163.835 E1.0588
                    G1 X162.992 Y163.851 E1.0591
                    G1 X162.946 Y164.561 E1.0724
                    G1 X162.942 Y164.593 E1.0731
                    G1 X162.887 Y165.016 E1.0811
                    G1 X162.881 Y165.048 E1.0817
                    G1 X162.722 Y165.850 E1.0971
                    G1 X162.714 Y165.882 E1.0977
                    G1 X162.604 Y166.293 E1.1057
                    G1 X162.595 Y166.324 E1.1063
                    G1 X162.332 Y167.097 E1.1217
                    G1 X162.321 Y167.128 E1.1223
                    G1 X162.158 Y167.521 E1.1303
                    G1 X162.144 Y167.551 E1.1309
                    G1 X161.783 Y168.284 E1.1463
                    G1 X161.768 Y168.313 E1.1469
                    G1 X161.555 Y168.682 E1.1549
                    G1 X161.537 Y168.709 E1.1555
                    G1 X161.083 Y169.389 E1.1709
                    G1 X161.064 Y169.416 E1.1715
                    G1 X160.805 Y169.753 E1.1795
                    G1 X160.784 Y169.779 E1.1801
                    G1 X160.245 Y170.393 E1.1955
                    G1 X160.223 Y170.417 E1.1961
                    G1 X159.922 Y170.718 E1.2041
                    G1 X159.898 Y170.740 E1.2047
                    G1 X159.284 Y171.279 E1.2201
                    G1 X159.259 Y171.300 E1.2207
                    G1 X158.921 Y171.559 E1.2287
                    G1 X158.894 Y171.578 E1.2293
                    G1 X158.215 Y172.032 E1.2447
                    G1 X158.187 Y172.049 E1.2453
                    G1 X157.818 Y172.262 E1.2533
                    G1 X157.790 Y172.277 E1.2539
                    G1 X157.057 Y172.639 E1.2693
                    G1 X157.027 Y172.652 E1.2699
                    G1 X156.634 Y172.815 E1.2779
                    G1 X156.603 Y172.827 E1.2786
                    G1 X155.829 Y173.090 E1.2939
                    G1 X155.798 Y173.099 E1.2946
                    G1 X155.386 Y173.209 E1.3026
                    G1 X155.354 Y173.217 E1.3032
                    G1 X154.574 Y173.372 E1.3181
                    G1 X154.545 Y173.377 E1.3187
                    G1 X154.166 Y173.429 E1.3259
                    G1 X154.137 Y173.432 E1.3264
                    G1 X150.730 Y173.701 E1.3907
                    G1 X150.335 Y173.564 E1.3986
                    G1 X150.000 Y173.254 E1.4072
                    G1 X149.665 Y173.564 E1.4158
                    G1 X149.270 Y173.701 E1.4236
                    G1 X145.863 Y173.432 E1.4879
                    G1 X145.834 Y173.429 E1.4885
                    G1 X145.455 Y173.377 E1.4957
                    G1 X145.426 Y173.372 E1.4962
                    G1 X144.646 Y173.217 E1.5112
                    G1 X144.614 Y173.209 E1.5118
                    G1 X144.202 Y173.099 E1.5198
                    G1 X144.171 Y173.090 E1.5204
                    G1 X143.397 Y172.827 E1.5358
                    G1 X143.366 Y172.815 E1.5364
                    G1 X142.973 Y172.652 E1.5444
                    G1 X142.943 Y172.639 E1.5450
                    G1 X142.210 Y172.277 E1.5604
                    G1 X142.182 Y172.262 E1.5610
                    G1 X141.813 Y172.049 E1.5690
                    G1 X141.786 Y172.032 E1.5696
                    G1 X141.106 Y171.578 E1.5850
                    G1 X141.079 Y171.559 E1.5856
                    G1 X140.741 Y171.300 E1.5936
                    G1 X140.716 Y171.279 E1.5942
                    G1 X140.102 Y170.740 E1.6096
                    G1 X140.078 Y170.718 E1.6102
                    G1 X139.777 Y170.417 E1.6182
                    G1 X139.755 Y170.393 E1.6189
                    G1 X139.216 Y169.779 E1.6342
                    G1 X139.195 Y169.753 E1.6348
                    G1 X138.936 Y169.416 E1.6428
                    G1 X138.917 Y169.389 E1.6435
                    G1 X138.463 Y168.710 E1.6588
                    G1 X138.446 Y168.682 E1.6595
                    G1 X138.233 Y168.313 E1.6675
                    G1 X138.217 Y168.284 E1.6681
                    G1 X137.856 Y167.551 E1.6835
                    G1 X137.842 Y167.522 E1.6841
                    G1 X137.679 Y167.128 E1.6921
                    G1 X137.668 Y167.098 E1.6927
                    G1 X137.405 Y166.324 E1.7081
                    G1 X137.396 Y166.292 E1.7087
                    G1 X137.285 Y165.881 E1.7167
                    G1 X137.278 Y165.849 E1.7173
                    G1 X137.119 Y165.048 E1.7327
                    G1 X137.113 Y165.016 E1.7333
                    G1 X137.058 Y164.594 E1.7413
                    G1 X137.055 Y164.561 E1.7419
                    G1 X137.008 Y163.852 E1.7553
                    G1 X137.007 Y163.835 E1.7556
                    G1 X137.000 Y163.623 E1.7596
                    G1 X137.000 Y163.606 E1.7599
                    G1 X137.000 Y158.394 E1.8580
                    G1 X137.000 Y158.377 E1.8583
                    G1 X137.007 Y158.165 E1.8623
                    G1 X137.008 Y158.148 E1.8626
                    G1 X137.080 Y157.047 E1.8833
                    G1 X137.083 Y157.014 E1.8840
                    G1 X137.139 Y156.592 E1.8920
                    G1 X137.144 Y156.560 E1.8926
                    G1 X137.380 Y155.373 E1.9153
                    G1 X137.388 Y155.341 E1.9160
                    G1 X137.498 Y154.930 E1.9240
                    G1 X137.507 Y154.899 E1.9246
                    G1 X137.897 Y153.752 E1.9473
                    G1 X137.908 Y153.722 E1.9480
                    G1 X138.071 Y153.328 E1.9560
                    G1 X138.085 Y153.298 E1.9566
                    G1 X138.620 Y152.213 E1.9794
                    G1 X138.636 Y152.184 E1.9800
                    G1 X138.848 Y151.816 E1.9880
                    G1 X138.865 Y151.788 E1.9886
                    G1 X139.400 Y150.988 E2.0067
                    G1 X139.216 Y150.779 E2.0119
                    G1 X139.195 Y150.753 E2.0125
                    G1 X138.936 Y150.416 E2.0205
                    G1 X138.917 Y150.389 E2.0212
                    G1 X138.463 Y149.710 E2.0365
                    G1 X138.446 Y149.682 E2.0371
                    G1 X138.233 Y149.313 E2.0452
                    G1 X138.217 Y149.284 E2.0458
                    G1 X137.856 Y148.551 E2.0611
                    G1 X137.842 Y148.522 E2.0618
                    G1 X137.679 Y148.128 E2.0698
                    G1 X137.668 Y148.098 E2.0704
                    G1 X137.405 Y147.324 E2.0858
                    G1 X137.396 Y147.292 E2.0864
                    G1 X137.285 Y146.881 E2.0944
                    G1 X137.278 Y146.849 E2.0950
                    G1 X137.119 Y146.048 E2.1104
                    G1 X137.113 Y146.016 E2.1110
                    G1 X137.058 Y145.594 E2.1190
                    G1 X137.055 Y145.561 E2.1196
                    G1 X137.008 Y144.852 E2.1330
                    G1 X137.007 Y144.835 E2.1333
                    G1 X137.000 Y144.623 E2.1373
                    G1 X137.000 Y144.606 E2.1376
                    G1 X137.000 Y139.394 E2.2356
                    G1 X137.000 Y139.377 E2.2360
                    G1 X137.007 Y139.165 E2.2400
                    G1 X137.008 Y139.148 E2.2403
                    G1 X137.080 Y138.047 E2.2610
                    G1 X137.083 Y138.014 E2.2616
                    G1 X137.139 Y137.592 E2.2697
                    G1 X137.144 Y137.560 E2.2703
                    G1 X137.380 Y136.373 E2.2930
                    G1 X137.388 Y136.341 E2.2937
                    G1 X137.498 Y135.930 E2.3017
                    G1 X137.507 Y135.899 E2.3023
                    G1 X137.897 Y134.752 E2.3250
                    G1 X137.908 Y134.722 E2.3257
                    G1 X138.071 Y134.328 E2.3337
                    G1 X138.085 Y134.298 E2.3343
                    G1 X138.620 Y133.213 E2.3571
                    G1 X138.636 Y133.184 E2.3577
                    G1 X138.848 Y132.816 E2.3657
                    G1 X138.865 Y132.788 E2.3663
                    G1 X139.538 Y131.782 E2.3891
                    G1 X139.557 Y131.755 E2.3897
                    G1 X139.816 Y131.417 E2.3977
                    G1 X139.837 Y131.392 E2.3983
                    G1 X139.975 Y131.234 E2.4022
                    G1 X140.635 Y130.482 F1800
                    G1 X140.931 Y130.751 F4800
                    G92 E0
                    G1 X140.945 Y130.736 E0.0004 F1800
                    G1 X141.236 Y130.445 E0.0081
                    G1 X141.251 Y130.431 E0.0085
                    G1 X142.151 Y129.642 E0.0310
                    G1 X142.166 Y129.629 E0.0314
                    G1 X142.493 Y129.378 E0.0391
                    G1 X142.509 Y129.367 E0.0395
                    G1 X143.505 Y128.702 E0.0620
                    G1 X143.521 Y128.691 E0.0624
                    G1 X143.879 Y128.485 E0.0702
                    G1 X143.896 Y128.476 E0.0705
                    G1 X144.970 Y127.946 E0.0931
                    G1 X144.988 Y127.938 E0.0934
                    G1 X145.369 Y127.780 E0.1012
                    G1 X145.387 Y127.773 E0.1016
                    G1 X146.521 Y127.388 E0.1241
                    G1 X146.540 Y127.383 E0.1245
                    G1 X146.938 Y127.276 E0.1322
                    G1 X146.957 Y127.271 E0.1326
                    G1 X148.132 Y127.038 E0.1551
                    G1 X148.151 Y127.035 E0.1555
                    G1 X148.560 Y126.981 E0.1632
                    G1 X148.579 Y126.979 E0.1636
                    G1 X149.774 Y126.901 E0.1861
                    G1 X149.794 Y126.900 E0.1865
                    G1 X150.206 Y126.900 E0.1942
                    G1 X150.226 Y126.901 E0.1946
                    G1 X151.421 Y126.979 E0.2171
                    G1 X151.440 Y126.981 E0.2175
                    G1 X151.849 Y127.035 E0.2253
                    G1 X151.869 Y127.038 E0.2256
                    G1 X153.043 Y127.272 E0.2482
                    G1 X153.062 Y127.276 E0.2485
                    G1 X153.460 Y127.383 E0.2563
                    G1 X153.479 Y127.388 E0.2567
                    G1 X154.613 Y127.773 E0.2792
                    G1 X154.631 Y127.780 E0.2795
                    G1 X155.012 Y127.938 E0.2873
                    G1 X155.030 Y127.946 E0.2877
                    G1 X156.104 Y128.476 E0.3102
                    G1 X156.122 Y128.485 E0.3106
                    G1 X156.479 Y128.691 E0.3183
                    G1 X156.495 Y128.702 E0.3187
                    G1 X157.491 Y129.367 E0.3412
                    G1 X157.507 Y129.378 E0.3416
                    G1 X157.834 Y129.629 E0.3493
                    G1 X157.849 Y129.642 E0.3497
                    G1 X158.749 Y130.431 E0.3722
                    G1 X158.764 Y130.445 E0.3726
                    G1 X159.055 Y130.736 E0.3804
                    G1 X159.069 Y130.751 E0.3807
                    G1 X159.858 Y131.651 E0.4033
                    G1 X159.871 Y131.666 E0.4036
                    G1 X160.122 Y131.993 E0.4114
                    G1 X160.133 Y132.009 E0.4118
                    G1 X160.798 Y133.005 E0.4343
                    G1 X160.809 Y133.021 E0.4346
                    G1 X161.015 Y133.379 E0.4424
                    G1 X161.024 Y133.396 E0.4428
                    G1 X161.554 Y134.470 E0.4653
                    G1 X161.562 Y134.488 E0.4657
                    G1 X161.720 Y134.869 E0.4734
                    G1 X161.727 Y134.887 E0.4738
                    G1 X162.112 Y136.021 E0.4963
                    G1 X162.117 Y136.040 E0.4967
                    G1 X162.224 Y136.438 E0.5045
                    G1 X162.229 Y136.458 E0.5048
                    G1 X162.462 Y137.632 E0.5273
                    G1 X162.465 Y137.651 E0.5277
                    G1 X162.519 Y138.060 E0.5355
                    G1 X162.521 Y138.079 E0.5358
                    G1 X162.593 Y139.171 E0.5564
                    G1 X162.593 Y139.181 E0.5566
                    G1 X162.600 Y139.387 E0.5605
                    G1 X162.600 Y139.397 E0.5607
                    G1 X162.600 Y144.603 E0.6586
                    G1 X162.600 Y144.613 E0.6588
                    G1 X162.593 Y144.818 E0.6627
                    G1 X162.593 Y144.828 E0.6628
                    G1 X162.547 Y145.528 E0.6760
                    G1 X162.545 Y145.548 E0.6764
                    G1 X162.491 Y145.957 E0.6842
                    G1 X162.488 Y145.977 E0.6845
                    G1 X162.331 Y146.766 E0.6997
                    G1 X162.326 Y146.785 E0.7000
                    G1 X162.220 Y147.183 E0.7078
                    G1 X162.214 Y147.201 E0.7082
                    G1 X161.956 Y147.963 E0.7233
                    G1 X161.949 Y147.981 E0.7236
                    G1 X161.791 Y148.362 E0.7314
                    G1 X161.783 Y148.380 E0.7318
                    G1 X161.427 Y149.101 E0.7469
                    G1 X161.418 Y149.118 E0.7473
                    G1 X161.211 Y149.476 E0.7550
                    G1 X161.201 Y149.493 E0.7554
                    G1 X160.754 Y150.161 E0.7705
                    G1 X160.743 Y150.177 E0.7709
                    G1 X160.492 Y150.505 E0.7787
                    G1 X160.479 Y150.520 E0.7790
                    G1 X160.095 Y150.958 E0.7900
                    G1 X160.122 Y150.993 E0.7908
                    G1 X160.133 Y151.009 E0.7912
                    G1 X160.798 Y152.005 E0.8137
                    G1 X160.809 Y152.021 E0.8141
                    G1 X161.015 Y152.379 E0.8219
                    G1 X161.024 Y152.396 E0.8222
                    G1 X161.554 Y153.470 E0.8447
                    G1 X161.562 Y153.488 E0.8451
                    G1 X161.720 Y153.869 E0.8529
                    G1 X161.727 Y153.887 E0.8532
                    G1 X162.112 Y155.021 E0.8758
                    G1 X162.117 Y155.040 E0.8761
                    G1 X162.224 Y155.438 E0.8839
                    G1 X162.229 Y155.458 E0.8843
                    G1 X162.462 Y156.632 E0.9068
                    G1 X162.465 Y156.651 E0.9072
                    G1 X162.519 Y157.060 E0.9149
                    G1 X162.521 Y157.079 E0.9153
                    G1 X162.593 Y158.171 E0.9359
                    G1 X162.593 Y158.181 E0.9360
                    G1 X162.600 Y158.387 E0.9399
                    G1 X162.600 Y158.397 E0.9401
                    G1 X162.600 Y163.603 E1.0380
                    G1 X162.600 Y163.613 E1.0382
                    G1 X162.593 Y163.818 E1.0421
                    G1 X162.593 Y163.828 E1.0423
                    G1 X162.547 Y164.528 E1.0555
                    G1 X162.545 Y164.548 E1.0558
                    G1 X162.491 Y164.957 E1.0636
                    G1 X162.488 Y164.977 E1.0640
                    G1 X162.331 Y165.766 E1.0791
                    G1 X162.326 Y165.785 E1.0795
                    G1 X162.220 Y166.183 E1.0872
                    G1 X162.214 Y166.201 E1.0876
                    G1 X161.956 Y166.963 E1.1027
                    G1 X161.949 Y166.981 E1.1031
                    G1 X161.791 Y167.362 E1.1108
                    G1 X161.783 Y167.380 E1.1112
                    G1 X161.427 Y168.101 E1.1263
                    G1 X161.418 Y168.118 E1.1267
                    G1 X161.211 Y168.476 E1.1345
                    G1 X161.201 Y168.493 E1.1349
                    G1 X160.754 Y169.161 E1.1500
                    G1 X160.743 Y169.177 E1.1503
                    G1 X160.492 Y169.505 E1.1581
                    G1 X160.479 Y169.520 E1.1585
                    G1 X159.949 Y170.124 E1.1736
                    G1 X159.936 Y170.139 E1.1740
                    G1 X159.644 Y170.430 E1.1817
                    G1 X159.630 Y170.444 E1.1821
                    G1 X159.025 Y170.974 E1.1972
                    G1 X159.010 Y170.986 E1.1976
                    G1 X158.682 Y171.238 E1.2054
                    G1 X158.666 Y171.249 E1.2057
                    G1 X157.998 Y171.696 E1.2209
                    G1 X157.981 Y171.706 E1.2212
                    G1 X157.624 Y171.912 E1.2290
                    G1 X157.607 Y171.922 E1.2293
                    G1 X156.886 Y172.277 E1.2445
                    G1 X156.868 Y172.285 E1.2448
                    G1 X156.487 Y172.443 E1.2526
                    G1 X156.468 Y172.450 E1.2530
                    G1 X155.707 Y172.709 E1.2681
                    G1 X155.688 Y172.715 E1.2685
                    G1 X155.289 Y172.821 E1.2762
                    G1 X155.270 Y172.826 E1.2766
                    G1 X154.502 Y172.979 E1.2913
                    G1 X154.484 Y172.981 E1.2917
                    G1 X154.117 Y173.032 E1.2986
                    G1 X154.100 Y173.034 E1.2990
                    G1 X150.782 Y173.296 E1.3616
                    G1 X150.545 Y173.214 E1.3663
                    G1 X150.000 Y172.710 E1.3803
                    G1 X149.455 Y173.214 E1.3942
                    G1 X149.218 Y173.296 E1.3989
                    G1 X145.900 Y173.034 E1.4615
                    G1 X145.883 Y173.032 E1.4619
                    G1 X145.516 Y172.981 E1.4688
                    G1 X145.498 Y172.979 E1.4692
                    G1 X144.730 Y172.826 E1.4839
                    G1 X144.711 Y172.821 E1.4843
                    G1 X144.312 Y172.715 E1.4920
                    G1 X144.294 Y172.709 E1.4924
                    G1 X143.532 Y172.450 E1.5075
                    G1 X143.513 Y172.443 E1.5079
                    G1 X143.132 Y172.285 E1.5157
                    G1 X143.114 Y172.277 E1.5160
                    G1 X142.393 Y171.922 E1.5312
                    G1 X142.376 Y171.912 E1.5315
                    G1 X142.019 Y171.706 E1.5393
                    G1 X142.002 Y171.696 E1.5397
                    G1 X141.334 Y171.249 E1.5548
                    G1 X141.318 Y171.238 E1.5552
                    G1 X140.990 Y170.986 E1.5629
                    G1 X140.975 Y170.974 E1.5633
                    G1 X140.370 Y170.444 E1.5784
                    G1 X140.356 Y170.430 E1.5788
                    G1 X140.064 Y170.139 E1.5865
                    G1 X140.051 Y170.124 E1.5869
                    G1 X139.521 Y169.520 E1.6020
                    G1 X139.508 Y169.505 E1.6024
                    G1 X139.257 Y169.177 E1.6102
                    G1 X139.246 Y169.162 E1.6105
                    G1 X138.799 Y168.493 E1.6257
                    G1 X138.789 Y168.476 E1.6260
                    G1 X138.582 Y168.119 E1.6338
                    G1 X138.573 Y168.102 E1.6342
                    G1 X138.217 Y167.380 E1.6493
                    G1 X138.209 Y167.362 E1.6497
                    G1 X138.051 Y166.981 E1.6574
                    G1 X138.044 Y166.963 E1.6578
                    G1 X137.786 Y166.201 E1.6729
                    G1 X137.780 Y166.182 E1.6733
                    G1 X137.674 Y165.784 E1.6810
                    G1 X137.669 Y165.765 E1.6814
                    G1 X137.512 Y164.976 E1.6965
                    G1 X137.509 Y164.957 E1.6969
                    G1 X137.455 Y164.548 E1.7047
                    G1 X137.453 Y164.528 E1.7050
                    G1 X137.407 Y163.829 E1.7182
                    G1 X137.407 Y163.819 E1.7184
                    G1 X137.400 Y163.613 E1.7223
                    G1 X137.400 Y163.603 E1.7225
                    G1 X137.400 Y158.397 E1.8204
                    G1 X137.400 Y158.387 E1.8206
                    G1 X137.407 Y158.181 E1.8245
                    G1 X137.407 Y158.171 E1.8247
                    G1 X137.479 Y157.079 E1.8452
                    G1 X137.481 Y157.060 E1.8456
                    G1 X137.535 Y156.651 E1.8534
                    G1 X137.538 Y156.631 E1.8537
                    G1 X137.772 Y155.457 E1.8763
                    G1 X137.776 Y155.438 E1.8766
                    G1 X137.883 Y155.040 E1.8844
                    G1 X137.888 Y155.021 E1.8847
                    G1 X138.273 Y153.887 E1.9073
                    G1 X138.280 Y153.869 E1.9076
                    G1 X138.438 Y153.487 E1.9154
                    G1 X138.446 Y153.469 E1.9158
                    G1 X138.976 Y152.396 E1.9383
                    G1 X138.985 Y152.378 E1.9387
                    G1 X139.191 Y152.021 E1.9464
                    G1 X139.202 Y152.005 E1.9468
                    G1 X139.867 Y151.009 E1.9693
                    G1 X139.878 Y150.993 E1.9697
                    G1 X139.905 Y150.958 E1.9705
                    G1 X139.521 Y150.520 E1.9815
                    G1 X139.508 Y150.505 E1.9819
                    G1 X139.257 Y150.177 E1.9896
                    G1 X139.246 Y150.161 E1.9900
                    G1 X138.799 Y149.493 E2.0051
                    G1 X138.789 Y149.476 E2.0055
                    G1 X138.582 Y149.119 E2.0132
                    G1 X138.573 Y149.102 E2.0136
                    G1 X138.217 Y148.380 E2.0287
                    G1 X138.209 Y148.362 E2.0291
                    G1 X138.051 Y147.981 E2.0369
                    G1 X138.044 Y147.963 E2.0372
                    G1 X137.786 Y147.201 E2.0524
                    G1 X137.780 Y147.182 E2.0527
                    G1 X137.674 Y146.784 E2.0605
                    G1 X137.669 Y146.765 E2.0609
                    G1 X137.512 Y145.976 E2.0760
                    G1 X137.509 Y145.957 E2.0764
                    G1 X137.455 Y145.548 E2.0841
                    G1 X137.453 Y145.528 E2.0845
                    G1 X137.407 Y144.829 E2.0977
                    G1 X137.407 Y144.819 E2.0979
                    G1 X137.400 Y144.613 E2.1017
                    G1 X137.400 Y144.603 E2.1019
                    G1 X137.400 Y139.397 E2.1999
                    G1 X137.400 Y139.387 E2.2000
                    G1 X137.407 Y139.181 E2.2039
                    G1 X137.407 Y139.171 E2.2041
                    G1 X137.479 Y138.079 E2.2247
                    G1 X137.481 Y138.060 E2.2251
                    G1 X137.535 Y137.651 E2.2328
                    G1 X137.538 Y137.631 E2.2332
                    G1 X137.772 Y136.457 E2.2557
                    G1 X137.776 Y136.438 E2.2561
                    G1 X137.883 Y136.040 E2.2638
                    G1 X137.888 Y136.021 E2.2642
                    G1 X138.273 Y134.887 E2.2867
                    G1 X138.280 Y134.869 E2.2871
                    G1 X138.438 Y134.487 E2.2949
                    G1 X138.446 Y134.469 E2.2952
                    G1 X138.976 Y133.396 E2.3177
                    G1 X138.985 Y133.378 E2.3181
                    G1 X139.191 Y133.021 E2.3259
                    G1 X139.202 Y133.005 E2.3262
                    G1 X139.867 Y132.009 E2.3488
                    G1 X139.878 Y131.993 E2.3491
                    G1 X140.129 Y131.666 E2.3569
                    G1 X140.142 Y131.651 E2.3573
                    G1 X140.272 Y131.503 E2.3610
                    G1 X140.931 Y130.751 F1800
                    G1 X141.228 Y131.019 F4800
                    G92 E0
                    G1 X141.232 Y131.015 E0.0001 F1800
                    G1 X141.515 Y130.732 E0.0076
                    G1 X141.519 Y130.728 E0.0078
                    G1 X142.410 Y129.947 E0.0300
                    G1 X142.415 Y129.943 E0.0302
                    G1 X142.731 Y129.700 E0.0377
                    G1 X142.737 Y129.696 E0.0378
                    G1 X143.721 Y129.038 E0.0601
                    G1 X143.727 Y129.034 E0.0602
                    G1 X144.073 Y128.835 E0.0677
                    G1 X144.079 Y128.832 E0.0678
                    G1 X145.141 Y128.308 E0.0901
                    G1 X145.147 Y128.305 E0.0902
                    G1 X145.516 Y128.152 E0.0977
                    G1 X145.522 Y128.150 E0.0979
                    G1 X146.643 Y127.769 E0.1201
                    G1 X146.650 Y127.767 E0.1203
                    G1 X147.035 Y127.664 E0.1278
                    G1 X147.042 Y127.663 E0.1279
                    G1 X148.203 Y127.431 E0.1502
                    G1 X148.210 Y127.430 E0.1503
                    G1 X148.606 Y127.378 E0.1578
                    G1 X148.612 Y127.378 E0.1579
                    G1 X149.794 Y127.300 E0.1802
                    G1 X149.800 Y127.300 E0.1803
                    G1 X150.200 Y127.300 E0.1878
                    G1 X150.206 Y127.300 E0.1880
                    G1 X151.388 Y127.378 E0.2102
                    G1 X151.394 Y127.378 E0.2104
                    G1 X151.791 Y127.430 E0.2179
                    G1 X151.797 Y127.432 E0.2180
                    G1 X152.958 Y127.663 E0.2403
                    G1 X152.965 Y127.664 E0.2404
                    G1 X153.350 Y127.767 E0.2479
                    G1 X153.357 Y127.769 E0.2480
                    G1 X154.478 Y128.150 E0.2703
                    G1 X154.484 Y128.152 E0.2704
                    G1 X154.853 Y128.305 E0.2780
                    G1 X154.859 Y128.308 E0.2781
                    G1 X155.921 Y128.832 E0.3004
                    G1 X155.927 Y128.835 E0.3005
                    G1 X156.273 Y129.034 E0.3080
                    G1 X156.279 Y129.038 E0.3081
                    G1 X157.263 Y129.696 E0.3304
                    G1 X157.268 Y129.700 E0.3305
                    G1 X157.585 Y129.943 E0.3380
                    G1 X157.590 Y129.947 E0.3381
                    G1 X158.481 Y130.728 E0.3604
                    G1 X158.485 Y130.732 E0.3605
                    G1 X158.768 Y131.015 E0.3681
                    G1 X158.772 Y131.019 E0.3682
                    G1 X159.553 Y131.910 E0.3905
                    G1 X159.557 Y131.915 E0.3906
                    G1 X159.800 Y132.232 E0.3981
                    G1 X159.804 Y132.237 E0.3982
                    G1 X160.462 Y133.222 E0.4205
                    G1 X160.466 Y133.227 E0.4206
                    G1 X160.665 Y133.573 E0.4281
                    G1 X160.668 Y133.579 E0.4282
                    G1 X161.192 Y134.641 E0.4505
                    G1 X161.195 Y134.647 E0.4506
                    G1 X161.348 Y135.016 E0.4582
                    G1 X161.350 Y135.022 E0.4583
                    G1 X161.731 Y136.143 E0.4806
                    G1 X161.733 Y136.149 E0.4807
                    G1 X161.836 Y136.536 E0.4882
                    G1 X161.838 Y136.542 E0.4883
                    G1 X162.069 Y137.703 E0.5106
                    G1 X162.070 Y137.710 E0.5107
                    G1 X162.122 Y138.105 E0.5182
                    G1 X162.122 Y138.112 E0.5184
                    G1 X162.193 Y139.194 E0.5387
                    G1 X162.193 Y139.197 E0.5388
                    G1 X162.200 Y139.397 E0.5426
                    G1 X162.200 Y139.400 E0.5426
                    G1 X162.200 Y144.600 E0.6404
                    G1 X162.200 Y144.603 E0.6405
                    G1 X162.193 Y144.802 E0.6442
                    G1 X162.193 Y144.805 E0.6443
                    G1 X162.148 Y145.495 E0.6573
                    G1 X162.147 Y145.502 E0.6574
                    G1 X162.095 Y145.899 E0.6650
                    G1 X162.094 Y145.905 E0.6651
                    G1 X161.940 Y146.681 E0.6800
                    G1 X161.938 Y146.687 E0.6801
                    G1 X161.835 Y147.073 E0.6876
                    G1 X161.833 Y147.079 E0.6877
                    G1 X161.579 Y147.828 E0.7026
                    G1 X161.577 Y147.834 E0.7027
                    G1 X161.424 Y148.203 E0.7102
                    G1 X161.421 Y148.209 E0.7103
                    G1 X161.071 Y148.918 E0.7252
                    G1 X161.068 Y148.924 E0.7254
                    G1 X160.868 Y149.270 E0.7329
                    G1 X160.865 Y149.276 E0.7330
                    G1 X160.425 Y149.934 E0.7479
                    G1 X160.421 Y149.939 E0.7480
                    G1 X160.178 Y150.256 E0.7555
                    G1 X160.174 Y150.261 E0.7556
                    G1 X159.653 Y150.856 E0.7705
                    G1 X159.648 Y150.860 E0.7706
                    G1 X159.573 Y150.935 E0.7726
                    G1 X159.800 Y151.232 E0.7797
                    G1 X159.804 Y151.237 E0.7798
                    G1 X160.462 Y152.222 E0.8021
                    G1 X160.466 Y152.227 E0.8022
                    G1 X160.665 Y152.573 E0.8097
                    G1 X160.668 Y152.579 E0.8098
                    G1 X161.192 Y153.641 E0.8321
                    G1 X161.195 Y153.647 E0.8322
                    G1 X161.348 Y154.016 E0.8397
                    G1 X161.350 Y154.022 E0.8398
                    G1 X161.731 Y155.143 E0.8621
                    G1 X161.733 Y155.149 E0.8622
                    G1 X161.836 Y155.536 E0.8698
                    G1 X161.838 Y155.542 E0.8699
                    G1 X162.069 Y156.703 E0.8922
                    G1 X162.070 Y156.710 E0.8923
                    G1 X162.122 Y157.105 E0.8998
                    G1 X162.122 Y157.112 E0.8999
                    G1 X162.193 Y158.194 E0.9203
                    G1 X162.193 Y158.197 E0.9204
                    G1 X162.200 Y158.397 E0.9241
                    G1 X162.200 Y158.400 E0.9242
                    G1 X162.200 Y163.600 E1.0220
                    G1 X162.200 Y163.603 E1.0221
                    G1 X162.193 Y163.802 E1.0258
                    G1 X162.193 Y163.805 E1.0259
                    G1 X162.148 Y164.495 E1.0389
                    G1 X162.147 Y164.502 E1.0390
                    G1 X162.095 Y164.899 E1.0465
                    G1 X162.094 Y164.905 E1.0467
                    G1 X161.940 Y165.681 E1.0615
                    G1 X161.938 Y165.687 E1.0617
                    G1 X161.835 Y166.073 E1.0692
                    G1 X161.833 Y166.079 E1.0693
                    G1 X161.579 Y166.828 E1.0842
                    G1 X161.577 Y166.834 E1.0843
                    G1 X161.424 Y167.203 E1.0918
                    G1 X161.421 Y167.209 E1.0919
                    G1 X161.071 Y167.918 E1.1068
                    G1 X161.068 Y167.924 E1.1069
                    G1 X160.868 Y168.270 E1.1144
                    G1 X160.865 Y168.276 E1.1146
                    G1 X160.425 Y168.934 E1.1294
                    G1 X160.421 Y168.939 E1.1296
                    G1 X160.178 Y169.256 E1.1371
                    G1 X160.174 Y169.261 E1.1372
                    G1 X159.653 Y169.856 E1.1521
                    G1 X159.648 Y169.860 E1.1522
                    G1 X159.366 Y170.143 E1.1597
                    G1 X159.361 Y170.147 E1.1598
                    G1 X158.766 Y170.669 E1.1747
                    G1 X158.761 Y170.673 E1.1748
                    G1 X158.444 Y170.916 E1.1824
                    G1 X158.439 Y170.920 E1.1825
                    G1 X157.781 Y171.360 E1.1974
                    G1 X157.775 Y171.363 E1.1975
                    G1 X157.430 Y171.563 E1.2050
                    G1 X157.424 Y171.566 E1.2051
                    G1 X156.715 Y171.916 E1.2200
                    G1 X156.709 Y171.918 E1.2201
                    G1 X156.340 Y172.071 E1.2276
                    G1 X156.333 Y172.074 E1.2278
                    G1 X155.584 Y172.328 E1.2426
                    G1 X155.578 Y172.330 E1.2428
                    G1 X155.192 Y172.433 E1.2503
                    G1 X155.186 Y172.435 E1.2504
                    G1 X154.429 Y172.585 E1.2649
                    G1 X154.424 Y172.586 E1.2650
                    G1 X154.068 Y172.635 E1.2718
                    G1 X154.062 Y172.636 E1.2719
                    G1 X150.834 Y172.890 E1.3328
                    G1 X150.755 Y172.863 E1.3344
                    G1 X150.000 Y172.165 E1.3537
                    G1 X149.245 Y172.863 E1.3731
                    G1 X149.166 Y172.890 E1.3746
                    G1 X145.938 Y172.636 E1.4355
                    G1 X145.932 Y172.635 E1.4357
                    G1 X145.576 Y172.586 E1.4424
                    G1 X145.571 Y172.585 E1.4425
                    G1 X144.814 Y172.435 E1.4570
                    G1 X144.808 Y172.433 E1.4571
                    G1 X144.422 Y172.330 E1.4647
                    G1 X144.416 Y172.328 E1.4648
                    G1 X143.667 Y172.074 E1.4797
                    G1 X143.660 Y172.071 E1.4798
                    G1 X143.291 Y171.918 E1.4873
                    G1 X143.285 Y171.916 E1.4874
                    G1 X142.576 Y171.566 E1.5023
                    G1 X142.570 Y171.563 E1.5024
                    G1 X142.225 Y171.363 E1.5099
                    G1 X142.219 Y171.360 E1.5101
                    G1 X141.561 Y170.920 E1.5249
                    G1 X141.556 Y170.916 E1.5251
                    G1 X141.239 Y170.673 E1.5326
                    G1 X141.234 Y170.669 E1.5327
                    G1 X140.639 Y170.147 E1.5476
                    G1 X140.634 Y170.143 E1.5477
                    G1 X140.352 Y169.860 E1.5552
                    G1 X140.347 Y169.856 E1.5553
                    G1 X139.826 Y169.261 E1.5702
                    G1 X139.822 Y169.256 E1.5703
                    G1 X139.579 Y168.939 E1.5779
                    G1 X139.575 Y168.934 E1.5780
                    G1 X139.135 Y168.276 E1.5929
                    G1 X139.132 Y168.271 E1.5930
                    G1 X138.932 Y167.925 E1.6005
                    G1 X138.929 Y167.919 E1.6006
                    G1 X138.579 Y167.209 E1.6155
                    G1 X138.576 Y167.203 E1.6156
                    G1 X138.423 Y166.834 E1.6231
                    G1 X138.421 Y166.828 E1.6233
                    G1 X138.167 Y166.079 E1.6381
                    G1 X138.165 Y166.073 E1.6383
                    G1 X138.062 Y165.687 E1.6458
                    G1 X138.060 Y165.680 E1.6459
                    G1 X137.906 Y164.905 E1.6608
                    G1 X137.905 Y164.898 E1.6609
                    G1 X137.853 Y164.502 E1.6684
                    G1 X137.852 Y164.496 E1.6685
                    G1 X137.807 Y163.806 E1.6815
                    G1 X137.807 Y163.803 E1.6816
                    G1 X137.800 Y163.603 E1.6854
                    G1 X137.800 Y163.600 E1.6854
                    G1 X137.800 Y158.400 E1.7832
                    G1 X137.800 Y158.397 E1.7833
                    G1 X137.807 Y158.197 E1.7870
                    G1 X137.807 Y158.194 E1.7871
                    G1 X137.878 Y157.112 E1.8075
                    G1 X137.878 Y157.106 E1.8076
                    G1 X137.930 Y156.709 E1.8151
                    G1 X137.932 Y156.703 E1.8153
                    G1 X138.163 Y155.542 E1.8375
                    G1 X138.164 Y155.535 E1.8377
                    G1 X138.267 Y155.150 E1.8452
                    G1 X138.269 Y155.143 E1.8453
                    G1 X138.650 Y154.022 E1.8676
                    G1 X138.652 Y154.016 E1.8677
                    G1 X138.805 Y153.647 E1.8752
                    G1 X138.808 Y153.641 E1.8753
                    G1 X139.332 Y152.578 E1.8976
                    G1 X139.335 Y152.573 E1.8977
                    G1 X139.534 Y152.227 E1.9052
                    G1 X139.538 Y152.221 E1.9054
                    G1 X140.196 Y151.237 E1.9276
                    G1 X140.200 Y151.232 E1.9278
                    G1 X140.427 Y150.935 E1.9348
                    G1 X140.352 Y150.860 E1.9368
                    G1 X140.347 Y150.856 E1.9369
                    G1 X139.826 Y150.261 E1.9518
                    G1 X139.822 Y150.256 E1.9519
                    G1 X139.579 Y149.939 E1.9594
                    G1 X139.575 Y149.934 E1.9595
                    G1 X139.135 Y149.276 E1.9744
                    G1 X139.132 Y149.271 E1.9745
                    G1 X138.932 Y148.925 E1.9821
                    G1 X138.929 Y148.919 E1.9822
                    G1 X138.579 Y148.209 E1.9971
                    G1 X138.576 Y148.203 E1.9972
                    G1 X138.423 Y147.834 E2.0047
                    G1 X138.421 Y147.828 E2.0048
                    G1 X138.167 Y147.079 E2.0197
                    G1 X138.165 Y147.073 E2.0198
                    G1 X138.062 Y146.687 E2.0273
                    G1 X138.060 Y146.680 E2.0275
                    G1 X137.906 Y145.905 E2.0423
                    G1 X137.905 Y145.898 E2.0425
                    G1 X137.853 Y145.502 E2.0500
                    G1 X137.852 Y145.496 E2.0501
                    G1 X137.807 Y144.806 E2.0631
                    G1 X137.807 Y144.803 E2.0632
                    G1 X137.800 Y144.603 E2.0669
                    G1 X137.800 Y144.600 E2.0670
                    G1 X137.800 Y139.400 E2.1648
                    G1 X137.800 Y139.397 E2.1649
                    G1 X137.807 Y139.197 E2.1686
                    G1 X137.807 Y139.194 E2.1687
                    G1 X137.878 Y138.112 E2.1891
                    G1 X137.878 Y138.106 E2.1892
                    G1 X137.930 Y137.709 E2.1967
                    G1 X137.932 Y137.703 E2.1968
                    G1 X138.163 Y136.542 E2.2191
                    G1 X138.164 Y136.535 E2.2192
                    G1 X138.267 Y136.150 E2.2267
                    G1 X138.269 Y136.143 E2.2269
                    G1 X138.650 Y135.022 E2.2491
                    G1 X138.652 Y135.016 E2.2493
                    G1 X138.805 Y134.647 E2.2568
                    G1 X138.808 Y134.641 E2.2569
                    G1 X139.332 Y133.578 E2.2792
                    G1 X139.335 Y133.573 E2.2793
                    G1 X139.534 Y133.227 E2.2868
                    G1 X139.538 Y133.221 E2.2869
                    G1 X140.196 Y132.237 E2.3092
                    G1 X140.200 Y132.232 E2.3093
                    G1 X140.443 Y131.915 E2.3168
                    G1 X140.447 Y131.910 E2.3170
                    G1 X140.568 Y131.771 E2.3204
                    G1 X141.228 Y131.019 F1800
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 X146.466 Y135.966 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X146.957 Y135.535 E0.0123 F1350
                    G1 X147.501 Y135.172 E0.0246
                    G1 X148.087 Y134.883 E0.0369
                    G1 X148.706 Y134.672 E0.0492
                    G1 X149.348 Y134.545 E0.0615
                    G1 X150.000 Y134.502 E0.0738
                    G1 X150.652 Y134.545 E0.0861
                    G1 X151.294 Y134.672 E0.0984
                    G1 X151.913 Y134.883 E0.1107
                    G1 X152.499 Y135.172 E0.1230
                    G1 X153.042 Y135.535 E0.1353
                    G1 X153.534 Y135.966 E0.1476
                    G1 X153.965 Y136.458 E0.1599
                    G1 X154.328 Y137.001 E0.1722
                    G1 X154.617 Y137.587 E0.1845
                    G1 X154.828 Y138.206 E0.1968
                    G1 X154.955 Y138.848 E0.2091
                    G1 X155.000 Y139.533 E0.2220
                    G1 X155.000 Y140.190 E0.2343
                    G1 X154.710 Y140.248 E0.2399
                    G1 X154.554 Y139.871 E0.2476
                    G1 X153.718 Y138.782 E0.2734
                    G1 X152.629 Y137.946 E0.2992
                    G1 X151.361 Y137.421 E0.3250
                    G1 X150.000 Y137.241 E0.3509
                    G1 X148.639 Y137.421 E0.3767
                    G1 X147.371 Y137.946 E0.4025
                    G1 X146.282 Y138.782 E0.4283
                    G1 X145.446 Y139.871 E0.4541
                    G1 X145.290 Y140.248 E0.4618
                    G1 X145.000 Y140.190 E0.4674
                    G1 X145.000 Y139.533 E0.4797
                    G1 X145.045 Y138.848 E0.4927
                    G1 X145.172 Y138.206 E0.5050
                    G1 X145.383 Y137.587 E0.5172
                    G1 X145.672 Y137.001 E0.5295
                    G1 X145.843 Y136.745 E0.5353
                    G1 X146.035 Y136.458 F1350
                    G1 X146.466 Y135.966 F1350
                    G1 X145.458 Y145.145 F4800
                    G92 E0
                    G1 X145.974 Y145.818 E0.0159 F1350
                    G1 X145.736 Y146.041 E0.0221
                    G1 X145.586 Y145.909 E0.0258
                    G1 X145.555 Y145.873 E0.0267
                    G1 X145.414 Y145.713 F1350
                    G1 X145.269 Y145.496 F1350
                    G1 X145.181 Y145.317 F1350
                    G1 X145.458 Y145.145 F1350
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X154.026 Y145.818 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.542 Y145.145 E0.0160 F1350
                    G1 X154.819 Y145.317 E0.0221
                    G1 X154.731 Y145.496 E0.0258
                    G1 X154.705 Y145.536 E0.0267
                    G1 X154.586 Y145.713 F1350
                    G1 X154.414 Y145.909 F1350
                    G1 X154.264 Y146.041 F1350
                    G1 X154.026 Y145.818 F1350
                    G1 X153.605 Y145.709 F4800
                    G92 E0
                    G1 X154.205 Y144.928 E0.0185 F1350
                    G1 X154.690 Y143.757 E0.0424
                    G1 X154.855 Y142.500 E0.0662
                    G1 X154.690 Y141.243 E0.0900
                    G1 X154.205 Y140.072 E0.1139
                    G1 X153.433 Y139.067 E0.1377
                    G1 X152.428 Y138.295 E0.1616
                    G1 X151.257 Y137.810 E0.1854
                    G1 X150.000 Y137.645 E0.2093
                    G1 X148.743 Y137.810 E0.2331
                    G1 X147.572 Y138.295 E0.2569
                    G1 X146.567 Y139.067 E0.2808
                    G1 X145.795 Y140.072 E0.3046
                    G1 X145.310 Y141.243 E0.3285
                    G1 X145.145 Y142.500 E0.3523
                    G1 X145.310 Y143.757 E0.3761
                    G1 X145.795 Y144.928 E0.4000
                    G1 X146.395 Y145.709 E0.4185
                    G1 X146.395 Y146.819 E0.4394
                    G1 X146.079 Y146.711 E0.4457
                    G1 X145.798 Y146.573 E0.4516
                    G1 X145.538 Y146.399 E0.4574
                    G1 X145.302 Y146.192 E0.4633
                    G1 X145.096 Y145.957 E0.4692
                    G1 X144.922 Y145.697 E0.4751
                    G1 X144.783 Y145.416 E0.4810
                    G1 X144.683 Y145.119 E0.4869
                    G1 X144.622 Y144.812 E0.4928
                    G1 X144.600 Y144.480 E0.4990
                    G1 X144.600 Y139.520 E0.5924
                    G1 X144.647 Y138.795 E0.6060
                    G1 X144.785 Y138.103 E0.6193
                    G1 X145.012 Y137.434 E0.6326
                    G1 X145.325 Y136.801 E0.6459
                    G1 X145.717 Y136.213 E0.6591
                    G1 X146.183 Y135.683 E0.6724
                    G1 X146.714 Y135.217 E0.6857
                    G1 X147.301 Y134.825 E0.6990
                    G1 X147.934 Y134.512 E0.7123
                    G1 X148.603 Y134.285 E0.7256
                    G1 X149.295 Y134.147 E0.7388
                    G1 X150.000 Y134.101 E0.7521
                    G1 X150.705 Y134.147 E0.7654
                    G1 X151.397 Y134.285 E0.7787
                    G1 X152.066 Y134.512 E0.7920
                    G1 X152.699 Y134.825 E0.8053
                    G1 X153.287 Y135.217 E0.8185
                    G1 X153.818 Y135.683 E0.8318
                    G1 X154.283 Y136.213 E0.8451
                    G1 X154.675 Y136.801 E0.8584
                    G1 X154.988 Y137.434 E0.8717
                    G1 X155.215 Y138.103 E0.8850
                    G1 X155.352 Y138.795 E0.8982
                    G1 X155.400 Y139.520 E0.9119
                    G1 X155.400 Y144.480 E1.0052
                    G1 X155.378 Y144.812 E1.0115
                    G1 X155.317 Y145.119 E1.0174
                    G1 X155.217 Y145.416 E1.0233
                    G1 X155.078 Y145.697 E1.0291
                    G1 X154.904 Y145.957 E1.0350
                    G1 X154.698 Y146.192 E1.0409
                    G1 X154.462 Y146.399 E1.0468
                    G1 X154.202 Y146.573 E1.0527
                    G1 X153.921 Y146.711 E1.0586
                    G1 X153.605 Y146.819 E1.0649
                    G1 X153.605 Y146.709 E1.0669
                    G1 X153.605 Y145.709 F1350
                    ; outer perimeter
                    G1 X153.205 Y145.573 F4800
                    G92 E0
                    G1 X153.855 Y144.726 E0.0201 F900
                    G1 X154.300 Y143.652 E0.0419
                    G1 X154.452 Y142.500 E0.0638
                    G1 X154.300 Y141.348 E0.0857
                    G1 X153.855 Y140.274 E0.1075
                    G1 X153.148 Y139.352 E0.1294
                    G1 X152.226 Y138.645 E0.1513
                    G1 X151.152 Y138.200 E0.1731
                    G1 X150.000 Y138.048 E0.1950
                    G1 X148.848 Y138.200 E0.2168
                    G1 X147.774 Y138.645 E0.2387
                    G1 X146.852 Y139.352 E0.2606
                    G1 X146.145 Y140.274 E0.2824
                    G1 X145.700 Y141.348 E0.3043
                    G1 X145.548 Y142.500 E0.3261
                    G1 X145.700 Y143.652 E0.3480
                    G1 X146.145 Y144.726 E0.3699
                    G1 X146.795 Y145.573 E0.3899
                    G1 X146.795 Y147.284 E0.4221
                    G1 X146.631 Y147.271 E0.4252
                    G1 X146.272 Y147.199 E0.4321
                    G1 X145.925 Y147.082 E0.4390
                    G1 X145.598 Y146.920 E0.4459
                    G1 X145.294 Y146.717 E0.4527
                    G1 X145.019 Y146.476 E0.4596
                    G1 X144.778 Y146.201 E0.4665
                    G1 X144.575 Y145.897 E0.4734
                    G1 X144.413 Y145.569 E0.4802
                    G1 X144.296 Y145.223 E0.4871
                    G1 X144.224 Y144.865 E0.4940
                    G1 X144.200 Y144.493 E0.5010
                    G1 X144.200 Y139.507 E0.5948
                    G1 X144.250 Y138.743 E0.6092
                    G1 X144.398 Y137.999 E0.6235
                    G1 X144.642 Y137.281 E0.6377
                    G1 X144.977 Y136.600 E0.6520
                    G1 X145.399 Y135.969 E0.6663
                    G1 X145.899 Y135.399 E0.6805
                    G1 X146.469 Y134.899 E0.6948
                    G1 X147.100 Y134.477 E0.7091
                    G1 X147.781 Y134.142 E0.7233
                    G1 X148.499 Y133.898 E0.7376
                    G1 X149.243 Y133.750 E0.7519
                    G1 X150.000 Y133.700 E0.7662
                    G1 X150.757 Y133.750 E0.7804
                    G1 X151.501 Y133.898 E0.7947
                    G1 X152.219 Y134.142 E0.8090
                    G1 X152.900 Y134.477 E0.8232
                    G1 X153.531 Y134.899 E0.8375
                    G1 X154.101 Y135.399 E0.8518
                    G1 X154.601 Y135.969 E0.8660
                    G1 X155.023 Y136.600 E0.8803
                    G1 X155.358 Y137.281 E0.8946
                    G1 X155.602 Y137.999 E0.9089
                    G1 X155.750 Y138.743 E0.9231
                    G1 X155.800 Y139.507 E0.9375
                    G1 X155.800 Y144.494 E1.0313
                    G1 X155.776 Y144.865 E1.0383
                    G1 X155.704 Y145.223 E1.0452
                    G1 X155.587 Y145.569 E1.0521
                    G1 X155.425 Y145.897 E1.0589
                    G1 X155.222 Y146.201 E1.0658
                    G1 X154.981 Y146.476 E1.0727
                    G1 X154.706 Y146.717 E1.0796
                    G1 X154.402 Y146.920 E1.0865
                    G1 X154.075 Y147.082 E1.0933
                    G1 X153.728 Y147.199 E1.1002
                    G1 X153.369 Y147.271 E1.1071
                    G1 X153.205 Y147.284 E1.1102
                    G1 X153.205 Y146.573 E1.1236
                    G1 X153.205 Y145.573 F900
                    ; gap fill
                    G1 X155.022 Y144.840 F4800
                    G92 E0
                    G1 X154.733 Y144.551 E0.0077 F1440
                    G1 X154.826 Y144.327 E0.0122
                    G1 X154.899 Y144.151 F1440
                    G1 X155.056 Y144.308 F1440
                    G1 X155.056 Y143.742 F1440
                    G1 X155.041 Y143.727 F1440
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X144.944 Y143.813 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X144.975 Y143.843 E0.0008 F1440
                    G1 X144.975 Y143.846 E0.0009
                    G1 X145.368 Y144.796 E0.0202
                    G1 X145.364 Y144.798 E0.0203
                    G1 X145.196 Y144.630 E0.0248
                    G1 X144.944 Y144.378 F1440
                    G1 X144.944 Y144.469 F1440
                    G1 X144.964 Y144.767 F1440
                    G1 X145.012 Y145.012 F1440
                    G1 X145.015 Y145.015 F1440
                    ; solid layer
                    G1 X145.366 Y139.144 F4800
                    G92 E0
                    G1 X145.484 Y139.262 E0.0031 F1440
                    G1 X145.730 Y138.942 E0.0107
                    G1 X145.432 Y138.644 E0.0187
                    G1 X145.502 Y138.295 E0.0254
                    G1 X145.539 Y138.185 E0.0275
                    G1 X145.976 Y138.622 E0.0392
                    G1 X146.039 Y138.539 E0.0411
                    G1 X146.277 Y138.357 E0.0467
                    G1 X145.682 Y137.763 E0.0626
                    G1 X145.697 Y137.718 E0.0634
                    G1 X145.864 Y137.379 E0.0706
                    G1 X146.597 Y138.111 E0.0900
                    G1 X146.917 Y137.866 E0.0976
                    G1 X146.069 Y137.018 E0.1202
                    G1 X146.296 Y136.679 E0.1278
                    G1 X147.246 Y137.629 E0.1531
                    G1 X147.646 Y137.464 E0.1613
                    G1 X146.559 Y136.376 E0.1902
                    G1 X146.707 Y136.207 E0.1944
                    G1 X146.839 Y136.091 E0.1977
                    G1 X148.046 Y137.298 E0.2298
                    G1 X148.446 Y137.132 E0.2380
                    G1 X147.140 Y135.827 E0.2727
                    G1 X147.165 Y135.805 E0.2733
                    G1 X147.476 Y135.597 E0.2804
                    G1 X148.920 Y137.041 E0.3188
                    G1 X149.420 Y136.975 E0.3283
                    G1 X147.832 Y135.387 E0.3705
                    G1 X148.211 Y135.201 E0.3784
                    G1 X149.920 Y136.909 E0.4239
                    G1 X150.000 Y136.898 E0.4254
                    G1 X150.547 Y136.970 E0.4358
                    G1 X148.633 Y135.056 E0.4867
                    G1 X148.795 Y135.002 E0.4899
                    G1 X149.086 Y134.944 E0.4955
                    G1 X151.198 Y137.056 E0.5517
                    G1 X151.450 Y137.089 E0.5565
                    G1 X152.043 Y137.335 E0.5685
                    G1 X149.578 Y134.871 E0.6341
                    G1 X150.000 Y134.843 E0.6421
                    G1 X150.125 Y134.851 E0.6444
                    G1 X153.324 Y138.050 E0.7295
                    G1 X153.961 Y138.539 E0.7446
                    G1 X154.450 Y139.176 E0.7597
                    G1 X154.649 Y139.375 E0.7650
                    G1 X154.617 Y138.892 E0.7741
                    G1 X154.589 Y138.750 E0.7769
                    G1 X150.750 Y134.911 E0.8790
                    G1 X151.205 Y135.002 E0.8877
                    G1 X151.510 Y135.105 E0.8938
                    G1 X154.395 Y137.990 E0.9705
                    G1 X154.303 Y137.718 E0.9759
                    G1 X154.033 Y137.171 E0.9874
                    G1 X153.814 Y136.843 E0.9948
                    G1 X153.364 Y136.393 E1.0068
                    G1 X152.657 Y135.686 F1440
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 X150.652 Y153.545 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X151.294 Y153.672 E0.0123 F1350
                    G1 X151.913 Y153.883 E0.0246
                    G1 X152.499 Y154.172 E0.0369
                    G1 X153.042 Y154.535 E0.0492
                    G1 X153.534 Y154.966 E0.0615
                    G1 X153.965 Y155.458 E0.0738
                    G1 X154.328 Y156.001 E0.0861
                    G1 X154.617 Y156.587 E0.0984
                    G1 X154.828 Y157.206 E0.1107
                    G1 X154.955 Y157.848 E0.1230
                    G1 X155.000 Y158.533 E0.1359
                    G1 X155.000 Y159.190 E0.1483
                    G1 X154.710 Y159.248 E0.1538
                    G1 X154.554 Y158.871 E0.1615
                    G1 X153.718 Y157.782 E0.1873
                    G1 X152.629 Y156.946 E0.2131
                    G1 X151.361 Y156.421 E0.2390
                    G1 X150.000 Y156.241 E0.2648
                    G1 X148.639 Y156.421 E0.2906
                    G1 X147.371 Y156.946 E0.3164
                    G1 X146.282 Y157.782 E0.3422
                    G1 X145.446 Y158.871 E0.3681
                    G1 X145.290 Y159.248 E0.3757
                    G1 X145.000 Y159.190 E0.3813
                    G1 X145.000 Y158.533 E0.3937
                    G1 X145.045 Y157.848 E0.4066
                    G1 X145.172 Y157.206 E0.4189
                    G1 X145.383 Y156.587 E0.4312
                    G1 X145.672 Y156.001 E0.4435
                    G1 X146.035 Y155.458 E0.4558
                    G1 X146.466 Y154.966 E0.4681
                    G1 X146.957 Y154.535 E0.4804
                    G1 X147.501 Y154.172 E0.4927
                    G1 X148.087 Y153.883 E0.5050
                    G1 X148.706 Y153.672 E0.5173
                    G1 X149.348 Y153.545 E0.5295
                    G1 X149.655 Y153.525 E0.5353
                    G1 X150.000 Y153.502 F1350
                    G1 X150.652 Y153.545 F1350
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X154.542 Y164.145 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.819 Y164.317 E0.0061 F1350
                    G1 X154.731 Y164.496 E0.0099
                    G1 X154.586 Y164.713 E0.0148
                    G1 X154.414 Y164.909 E0.0197
                    G1 X154.264 Y165.041 E0.0235
                    G1 X154.137 Y164.922 E0.0267
                    G1 X154.026 Y164.818 F1350
                    G1 X154.542 Y164.145 F1350
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X145.974 Y164.818 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.736 Y165.041 E0.0061 F1350
                    G1 X145.586 Y164.909 E0.0099
                    G1 X145.414 Y164.713 E0.0148
                    G1 X145.269 Y164.496 E0.0197
                    G1 X145.181 Y164.317 E0.0235
                    G1 X145.329 Y164.225 E0.0267
                    G1 X145.458 Y164.145 F1350
                    G1 X145.974 Y164.818 F1350
                    G1 X146.395 Y164.709 F4800
                    G92 E0
                    G1 X146.395 Y165.819 E0.0209 F1350
                    G1 X146.079 Y165.711 E0.0271
                    G1 X145.798 Y165.573 E0.0330
                    G1 X145.538 Y165.399 E0.0389
                    G1 X145.302 Y165.192 E0.0448
                    G1 X145.096 Y164.957 E0.0507
                    G1 X144.922 Y164.697 E0.0566
                    G1 X144.783 Y164.416 E0.0625
                    G1 X144.683 Y164.119 E0.0684
                    G1 X144.622 Y163.812 E0.0743
                    G1 X144.600 Y163.480 E0.0805
                    G1 X144.600 Y158.520 E0.1738
                    G1 X144.647 Y157.795 E0.1875
                    G1 X144.785 Y157.103 E0.2008
                    G1 X145.012 Y156.434 E0.2141
                    G1 X145.325 Y155.801 E0.2273
                    G1 X145.717 Y155.213 E0.2406
                    G1 X146.183 Y154.683 E0.2539
                    G1 X146.714 Y154.217 E0.2672
                    G1 X147.301 Y153.825 E0.2805
                    G1 X147.934 Y153.512 E0.2938
                    G1 X148.603 Y153.285 E0.3070
                    G1 X149.295 Y153.147 E0.3203
                    G1 X150.000 Y153.101 E0.3336
                    G1 X150.705 Y153.147 E0.3469
                    G1 X151.397 Y153.285 E0.3602
                    G1 X152.066 Y153.512 E0.3735
                    G1 X152.699 Y153.825 E0.3867
                    G1 X153.287 Y154.217 E0.4000
                    G1 X153.818 Y154.683 E0.4133
                    G1 X154.283 Y155.213 E0.4266
                    G1 X154.675 Y155.801 E0.4399
                    G1 X154.988 Y156.434 E0.4532
                    G1 X155.215 Y157.103 E0.4665
                    G1 X155.352 Y157.795 E0.4797
                    G1 X155.400 Y158.520 E0.4934
                    G1 X155.400 Y163.480 E0.5867
                    G1 X155.378 Y163.812 E0.5930
                    G1 X155.317 Y164.119 E0.5989
                    G1 X155.217 Y164.416 E0.6047
                    G1 X155.078 Y164.697 E0.6106
                    G1 X154.904 Y164.957 E0.6165
                    G1 X154.698 Y165.192 E0.6224
                    G1 X154.462 Y165.399 E0.6283
                    G1 X154.202 Y165.573 E0.6342
                    G1 X153.921 Y165.711 E0.6401
                    G1 X153.605 Y165.819 E0.6464
                    G1 X153.605 Y164.709 E0.6672
                    G1 X154.205 Y163.928 E0.6857
                    G1 X154.690 Y162.757 E0.7096
                    G1 X154.855 Y161.500 E0.7334
                    G1 X154.690 Y160.243 E0.7573
                    G1 X154.205 Y159.072 E0.7811
                    G1 X153.433 Y158.067 E0.8050
                    G1 X152.428 Y157.295 E0.8288
                    G1 X151.257 Y156.810 E0.8526
                    G1 X150.000 Y156.645 E0.8765
                    G1 X148.743 Y156.810 E0.9003
                    G1 X147.572 Y157.295 E0.9242
                    G1 X146.567 Y158.067 E0.9480
                    G1 X145.795 Y159.072 E0.9718
                    G1 X145.310 Y160.243 E0.9957
                    G1 X145.145 Y161.500 E1.0195
                    G1 X145.310 Y162.757 E1.0434
                    G1 X145.789 Y163.914 E1.0669
                    G1 X145.795 Y163.928 F1350
                    G1 X146.395 Y164.709 F1350
                    ; outer perimeter
                    G1 X146.795 Y164.573 F4800
                    G92 E0
                    G1 X146.795 Y166.284 E0.0322 F900
                    G1 X146.631 Y166.271 E0.0353
                    G1 X146.272 Y166.199 E0.0422
                    G1 X145.925 Y166.082 E0.0490
                    G1 X145.598 Y165.920 E0.0559
                    G1 X145.294 Y165.717 E0.0628
                    G1 X145.019 Y165.476 E0.0697
                    G1 X144.778 Y165.201 E0.0765
                    G1 X144.575 Y164.897 E0.0834
                    G1 X144.413 Y164.569 E0.0903
                    G1 X144.296 Y164.223 E0.0972
                    G1 X144.224 Y163.865 E0.1040
                    G1 X144.200 Y163.493 E0.1110
                    G1 X144.200 Y158.507 E0.2048
                    G1 X144.250 Y157.743 E0.2192
                    G1 X144.398 Y156.999 E0.2335
                    G1 X144.642 Y156.281 E0.2478
                    G1 X144.977 Y155.600 E0.2621
                    G1 X145.399 Y154.969 E0.2763
                    G1 X145.899 Y154.399 E0.2906
                    G1 X146.469 Y153.899 E0.3049
                    G1 X147.100 Y153.477 E0.3191
                    G1 X147.781 Y153.142 E0.3334
                    G1 X148.499 Y152.898 E0.3477
                    G1 X149.243 Y152.750 E0.3619
                    G1 X150.000 Y152.700 E0.3762
                    G1 X150.757 Y152.750 E0.3905
                    G1 X151.501 Y152.898 E0.4048
                    G1 X152.219 Y153.142 E0.4190
                    G1 X152.900 Y153.477 E0.4333
                    G1 X153.531 Y153.899 E0.4476
                    G1 X154.101 Y154.399 E0.4618
                    G1 X154.601 Y154.969 E0.4761
                    G1 X155.023 Y155.600 E0.4904
                    G1 X155.358 Y156.281 E0.5046
                    G1 X155.602 Y156.999 E0.5189
                    G1 X155.750 Y157.743 E0.5332
                    G1 X155.800 Y158.507 E0.5476
                    G1 X155.800 Y163.494 E0.6414
                    G1 X155.776 Y163.865 E0.6484
                    G1 X155.704 Y164.223 E0.6553
                    G1 X155.587 Y164.569 E0.6621
                    G1 X155.425 Y164.897 E0.6690
                    G1 X155.222 Y165.201 E0.6759
                    G1 X154.981 Y165.476 E0.6828
                    G1 X154.706 Y165.717 E0.6896
                    G1 X154.402 Y165.920 E0.6965
                    G1 X154.075 Y166.082 E0.7034
                    G1 X153.728 Y166.199 E0.7103
                    G1 X153.369 Y166.271 E0.7172
                    G1 X153.205 Y166.284 E0.7202
                    G1 X153.205 Y164.573 E0.7524
                    G1 X153.855 Y163.726 E0.7725
                    G1 X154.300 Y162.652 E0.7944
                    G1 X154.452 Y161.500 E0.8162
                    G1 X154.300 Y160.348 E0.8381
                    G1 X153.855 Y159.274 E0.8600
                    G1 X153.148 Y158.352 E0.8818
                    G1 X152.226 Y157.645 E0.9037
                    G1 X151.152 Y157.200 E0.9255
                    G1 X150.000 Y157.048 E0.9474
                    G1 X148.848 Y157.200 E0.9693
                    G1 X147.774 Y157.645 E0.9911
                    G1 X146.852 Y158.352 E1.0130
                    G1 X146.145 Y159.274 E1.0348
                    G1 X145.700 Y160.348 E1.0567
                    G1 X145.548 Y161.500 E1.0786
                    G1 X145.700 Y162.652 E1.1004
                    G1 X146.145 Y163.726 E1.1223
                    G1 X146.186 Y163.780 E1.1236
                    G1 X146.795 Y164.573 F900
                    ; gap fill
                    G1 X144.954 Y163.622 F4800
                    G92 E0
                    G1 X145.220 Y163.888 E0.0071 F1440
                    G1 X145.263 Y163.861 E0.0080
                    G1 X145.368 Y163.796 F1440
                    G1 X145.138 Y163.240 F1440
                    G1 X144.944 Y163.046 F1440
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X154.930 Y163.981 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.665 Y163.716 E0.0070 F1440
                    G1 X154.815 Y163.354 E0.0144
                    G1 X154.831 Y163.316 F1440
                    G1 X155.052 Y163.537 F1440
                    G1 X155.056 Y163.469 F1440
                    G1 X155.056 Y162.976 F1440
                    G1 X154.996 Y162.916 F1440
                    ; solid layer
                    G1 X152.083 Y154.346 F4800
                    G92 E0
                    G1 X154.154 Y156.417 E0.0551 F1440
                    G1 X154.303 Y156.718 E0.0614
                    G1 X154.498 Y157.295 E0.0729
                    G1 X154.506 Y157.335 E0.0736
                    G1 X151.165 Y153.994 E0.1625
                    G1 X150.608 Y153.883 E0.1732
                    G1 X150.480 Y153.874 E0.1756
                    G1 X154.626 Y158.020 E0.2859
                    G1 X154.653 Y158.441 E0.2938
                    G1 X153.961 Y157.539 E0.3152
                    G1 X152.801 Y156.649 E0.3427
                    G1 X152.610 Y156.570 E0.3466
                    G1 X149.890 Y153.850 E0.4190
                    G1 X149.392 Y153.883 E0.4284
                    G1 X149.363 Y153.889 E0.4289
                    G1 X151.645 Y156.170 E0.4896
                    G1 X151.450 Y156.089 E0.4936
                    G1 X150.930 Y156.021 E0.5035
                    G1 X148.891 Y153.982 E0.5577
                    G1 X148.795 Y154.002 E0.5595
                    G1 X148.459 Y154.116 E0.5662
                    G1 X150.278 Y155.935 E0.6146
                    G1 X150.000 Y155.898 E0.6199
                    G1 X149.714 Y155.936 E0.6253
                    G1 X148.055 Y154.278 E0.6694
                    G1 X147.676 Y154.464 E0.6774
                    G1 X149.214 Y156.002 E0.7183
                    G1 X148.714 Y156.068 E0.7278
                    G1 X147.337 Y154.691 E0.7644
                    G1 X147.165 Y154.805 E0.7683
                    G1 X147.016 Y154.936 E0.7720
                    G1 X148.281 Y156.201 E0.8057
                    G1 X147.881 Y156.366 E0.8138
                    G1 X146.715 Y155.200 E0.8448
                    G1 X146.707 Y155.207 E0.8450
                    G1 X146.450 Y155.500 E0.8524
                    G1 X147.481 Y156.532 E0.8798
                    G1 X147.199 Y156.649 E0.8856
                    G1 X147.105 Y156.721 E0.8878
                    G1 X146.202 Y155.819 E0.9118
                    G1 X145.976 Y156.158 E0.9195
                    G1 X146.785 Y156.967 E0.9410
                    G1 X146.465 Y157.213 E0.9486
                    G1 X145.787 Y156.535 E0.9666
                    G1 X145.697 Y156.718 E0.9704
                    G1 X145.623 Y156.937 E0.9748
                    G1 X146.145 Y157.458 E0.9887
                    G1 X146.039 Y157.539 E0.9912
                    G1 X145.874 Y157.754 E0.9962
                    G1 X145.487 Y157.367 E1.0065
                    G1 X145.436 Y157.623 E1.0115
                    G1 X145.393 Y157.838 F1440
                    G1 X145.629 Y158.074 F1440
                    G1 X145.383 Y158.394 F1440
                    G1 X145.352 Y158.363 F1440
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 2, Z = 0.500
                    M106 S255
                    ; tool H0.200 W0.400
                    ; inner perimeter
                    G1 X145.000 Y158.533 F4800
                    G1 Z0.500 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.045 Y157.848 E0.0086 F1898
                    G1 X145.172 Y157.206 E0.0168
                    G1 X145.383 Y156.587 E0.0250
                    G1 X145.672 Y156.001 E0.0332
                    G1 X146.035 Y155.458 E0.0414
                    G1 X146.466 Y154.966 E0.0496
                    G1 X146.957 Y154.535 E0.0578
                    G1 X147.501 Y154.172 E0.0660
                    G1 X148.087 Y153.883 E0.0742
                    G1 X148.706 Y153.672 E0.0824
                    G1 X149.348 Y153.545 E0.0906
                    G1 X150.000 Y153.502 E0.0988
                    G1 X150.652 Y153.545 E0.1070
                    G1 X151.294 Y153.672 E0.1152
                    G1 X151.913 Y153.883 E0.1234
                    G1 X152.499 Y154.172 E0.1316
                    G1 X153.042 Y154.535 E0.1398
                    G1 X153.534 Y154.966 E0.1480
                    G1 X153.965 Y155.458 E0.1562
                    G1 X154.328 Y156.001 E0.1644
                    G1 X154.617 Y156.587 E0.1726
                    G1 X154.828 Y157.206 E0.1808
                    G1 X154.955 Y157.848 E0.1890
                    G1 X155.000 Y158.533 E0.1976
                    G1 X155.000 Y159.190 E0.2058
                    G1 X154.710 Y159.248 E0.2095
                    G1 X154.554 Y158.871 E0.2146
                    G1 X153.718 Y157.782 E0.2319
                    G1 X152.629 Y156.946 E0.2491
                    G1 X151.361 Y156.421 E0.2663
                    G1 X150.000 Y156.241 E0.2835
                    G1 X148.639 Y156.421 E0.3007
                    G1 X147.371 Y156.946 E0.3179
                    G1 X146.282 Y157.782 E0.3351
                    G1 X145.446 Y158.871 E0.3524
                    G1 X145.308 Y159.204 E0.3569
                    G1 X145.290 Y159.248 F1898
                    G1 X145.000 Y159.190 F1898
                    G1 X145.000 Y158.533 F1898
                    G1 X145.458 Y164.145 F4800
                    G92 E0
                    G1 X145.974 Y164.818 E0.0106 F1898
                    G1 X145.736 Y165.041 E0.0147
                    G1 X145.586 Y164.909 E0.0172
                    G1 X145.555 Y164.873 E0.0178
                    G1 X145.414 Y164.713 F1898
                    G1 X145.269 Y164.496 F1898
                    G1 X145.181 Y164.317 F1898
                    G1 X145.458 Y164.145 F1898
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X154.026 Y164.818 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.542 Y164.145 E0.0106 F1898
                    G1 X154.819 Y164.317 E0.0147
                    G1 X154.731 Y164.496 E0.0172
                    G1 X154.705 Y164.536 E0.0178
                    G1 X154.586 Y164.713 F1898
                    G1 X154.414 Y164.909 F1898
                    G1 X154.264 Y165.041 F1898
                    G1 X154.026 Y164.818 F1898
                    G1 X153.605 Y164.709 F4800
                    G92 E0
                    G1 X154.205 Y163.928 E0.0123 F1898
                    G1 X154.690 Y162.757 E0.0282
                    G1 X154.855 Y161.500 E0.0441
                    G1 X154.690 Y160.243 E0.0600
                    G1 X154.205 Y159.072 E0.0759
                    G1 X153.433 Y158.067 E0.0918
                    G1 X152.428 Y157.295 E0.1077
                    G1 X151.257 Y156.810 E0.1236
                    G1 X150.000 Y156.645 E0.1395
                    G1 X148.743 Y156.810 E0.1554
                    G1 X147.572 Y157.295 E0.1713
                    G1 X146.567 Y158.067 E0.1872
                    G1 X145.795 Y159.072 E0.2031
                    G1 X145.310 Y160.243 E0.2190
                    G1 X145.145 Y161.500 E0.2349
                    G1 X145.310 Y162.757 E0.2508
                    G1 X145.795 Y163.928 E0.2667
                    G1 X146.395 Y164.709 E0.2790
                    G1 X146.395 Y165.819 E0.2929
                    G1 X146.079 Y165.711 E0.2971
                    G1 X145.798 Y165.573 E0.3010
                    G1 X145.538 Y165.399 E0.3050
                    G1 X145.302 Y165.192 E0.3089
                    G1 X145.096 Y164.957 E0.3128
                    G1 X144.922 Y164.697 E0.3167
                    G1 X144.783 Y164.416 E0.3207
                    G1 X144.683 Y164.119 E0.3246
                    G1 X144.622 Y163.812 E0.3285
                    G1 X144.600 Y163.480 E0.3327
                    G1 X144.600 Y158.520 E0.3949
                    G1 X144.647 Y157.795 E0.4040
                    G1 X144.785 Y157.103 E0.4129
                    G1 X145.012 Y156.434 E0.4217
                    G1 X145.325 Y155.801 E0.4306
                    G1 X145.717 Y155.213 E0.4394
                    G1 X146.183 Y154.683 E0.4483
                    G1 X146.714 Y154.217 E0.4571
                    G1 X147.301 Y153.825 E0.4660
                    G1 X147.934 Y153.512 E0.4749
                    G1 X148.603 Y153.285 E0.4837
                    G1 X149.295 Y153.147 E0.4926
                    G1 X150.000 Y153.101 E0.5014
                    G1 X150.705 Y153.147 E0.5103
                    G1 X151.397 Y153.285 E0.5191
                    G1 X152.066 Y153.512 E0.5280
                    G1 X152.699 Y153.825 E0.5368
                    G1 X153.287 Y154.217 E0.5457
                    G1 X153.818 Y154.683 E0.5546
                    G1 X154.283 Y155.213 E0.5634
                    G1 X154.675 Y155.801 E0.5723
                    G1 X154.988 Y156.434 E0.5811
                    G1 X155.215 Y157.103 E0.5900
                    G1 X155.352 Y157.795 E0.5988
                    G1 X155.400 Y158.520 E0.6079
                    G1 X155.400 Y163.480 E0.6701
                    G1 X155.378 Y163.812 E0.6743
                    G1 X155.317 Y164.119 E0.6782
                    G1 X155.217 Y164.416 E0.6822
                    G1 X155.078 Y164.697 E0.6861
                    G1 X154.904 Y164.957 E0.6900
                    G1 X154.698 Y165.192 E0.6939
                    G1 X154.462 Y165.399 E0.6979
                    G1 X154.202 Y165.573 E0.7018
                    G1 X153.921 Y165.711 E0.7057
                    G1 X153.605 Y165.819 E0.7099
                    G1 X153.605 Y165.709 E0.7113
                    G1 X153.605 Y164.709 F1898
                    ; outer perimeter
                    G1 X153.205 Y164.573 F4800
                    G92 E0
                    G1 X153.855 Y163.726 E0.0134 F1265
                    G1 X154.300 Y162.652 E0.0280
                    G1 X154.452 Y161.500 E0.0425
                    G1 X154.300 Y160.348 E0.0571
                    G1 X153.855 Y159.274 E0.0717
                    G1 X153.148 Y158.352 E0.0863
                    G1 X152.226 Y157.645 E0.1008
                    G1 X151.152 Y157.200 E0.1154
                    G1 X150.000 Y157.048 E0.1300
                    G1 X148.848 Y157.200 E0.1446
                    G1 X147.774 Y157.645 E0.1591
                    G1 X146.852 Y158.352 E0.1737
                    G1 X146.145 Y159.274 E0.1883
                    G1 X145.700 Y160.348 E0.2028
                    G1 X145.548 Y161.500 E0.2174
                    G1 X145.700 Y162.652 E0.2320
                    G1 X146.145 Y163.726 E0.2466
                    G1 X146.795 Y164.573 E0.2600
                    G1 X146.795 Y166.284 E0.2814
                    G1 X146.631 Y166.271 E0.2835
                    G1 X146.272 Y166.199 E0.2881
                    G1 X145.925 Y166.082 E0.2927
                    G1 X145.598 Y165.920 E0.2972
                    G1 X145.294 Y165.717 E0.3018
                    G1 X145.019 Y165.476 E0.3064
                    G1 X144.778 Y165.201 E0.3110
                    G1 X144.575 Y164.897 E0.3156
                    G1 X144.413 Y164.569 E0.3202
                    G1 X144.296 Y164.223 E0.3247
                    G1 X144.224 Y163.865 E0.3293
                    G1 X144.200 Y163.493 E0.3340
                    G1 X144.200 Y158.507 E0.3965
                    G1 X144.250 Y157.743 E0.4061
                    G1 X144.398 Y156.999 E0.4156
                    G1 X144.642 Y156.281 E0.4251
                    G1 X144.977 Y155.600 E0.4347
                    G1 X145.399 Y154.969 E0.4442
                    G1 X145.899 Y154.399 E0.4537
                    G1 X146.469 Y153.899 E0.4632
                    G1 X147.100 Y153.477 E0.4727
                    G1 X147.781 Y153.142 E0.4822
                    G1 X148.499 Y152.898 E0.4917
                    G1 X149.243 Y152.750 E0.5013
                    G1 X150.000 Y152.700 E0.5108
                    G1 X150.757 Y152.750 E0.5203
                    G1 X151.501 Y152.898 E0.5298
                    G1 X152.219 Y153.142 E0.5393
                    G1 X152.900 Y153.477 E0.5488
                    G1 X153.531 Y153.899 E0.5583
                    G1 X154.101 Y154.399 E0.5678
                    G1 X154.601 Y154.969 E0.5774
                    G1 X155.023 Y155.600 E0.5869
                    G1 X155.358 Y156.281 E0.5964
                    G1 X155.602 Y156.999 E0.6059
                    G1 X155.750 Y157.743 E0.6154
                    G1 X155.800 Y158.507 E0.6250
                    G1 X155.800 Y163.494 E0.6875
                    G1 X155.776 Y163.865 E0.6922
                    G1 X155.704 Y164.223 E0.6968
                    G1 X155.587 Y164.569 E0.7014
                    G1 X155.425 Y164.897 E0.7060
                    G1 X155.222 Y165.201 E0.7105
                    G1 X154.981 Y165.476 E0.7151
                    G1 X154.706 Y165.717 E0.7197
                    G1 X154.402 Y165.920 E0.7243
                    G1 X154.075 Y166.082 E0.7289
                    G1 X153.728 Y166.199 E0.7335
                    G1 X153.369 Y166.271 E0.7381
                    G1 X153.205 Y166.284 E0.7401
                    G1 X153.205 Y165.573 E0.7490
                    G1 X153.205 Y164.573 F1265
                    ; gap fill
                    G1 X154.780 Y163.888 F4800
                    G92 E0
                    G1 X154.940 Y163.727 E0.0028 F2025
                    G1 X155.046 Y163.622 F2025
                    G1 X155.056 Y163.469 F2025
                    G1 X155.056 Y163.046 F2025
                    G1 X154.862 Y163.240 F2025
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X145.335 Y163.716 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.070 Y163.981 E0.0047 F2025
                    G1 X145.013 Y164.016 E0.0055
                    G1 X144.964 Y163.767 E0.0087
                    G1 X144.960 Y163.706 E0.0095
                    G1 X144.948 Y163.537 F2025
                    G1 X145.170 Y163.316 F2025
                    G1 X145.004 Y162.916 F2025
                    G1 X144.944 Y162.976 F2025
                    ; solid layer
                    G1 X145.846 Y156.417 F4800
                    G92 E0
                    G1 X147.917 Y154.346 E0.0367 F2025
                    G1 X148.218 Y154.197 E0.0409
                    G1 X148.795 Y154.002 E0.0486
                    G1 X148.835 Y153.994 E0.0491
                    G1 X145.494 Y157.335 E0.1084
                    G1 X145.383 Y157.892 E0.1155
                    G1 X145.374 Y158.020 E0.1171
                    G1 X149.520 Y153.874 E0.1906
                    G1 X150.000 Y153.843 E0.1966
                    G1 X150.110 Y153.850 E0.1980
                    G1 X147.390 Y156.570 E0.2462
                    G1 X148.356 Y156.170 E0.2594
                    G1 X150.637 Y153.889 E0.2998
                    G1 X151.109 Y153.982 E0.3058
                    G1 X149.070 Y156.021 E0.3420
                    G1 X149.722 Y155.935 E0.3502
                    G1 X151.541 Y154.116 E0.3825
                    G1 X151.782 Y154.197 E0.3857
                    G1 X151.945 Y154.278 E0.3880
                    G1 X150.286 Y155.936 E0.4174
                    G1 X150.786 Y156.002 E0.4237
                    G1 X152.324 Y154.464 E0.4510
                    G1 X152.329 Y154.467 E0.4510
                    G1 X152.663 Y154.691 E0.4561
                    G1 X151.286 Y156.068 E0.4805
                    G1 X151.450 Y156.089 E0.4826
                    G1 X151.719 Y156.201 E0.4862
                    G1 X152.984 Y154.936 E0.5087
                    G1 X153.285 Y155.200 E0.5137
                    G1 X152.119 Y156.366 E0.5344
                    G1 X152.519 Y156.532 E0.5398
                    G1 X153.551 Y155.500 E0.5581
                    G1 X153.695 Y155.665 E0.5609
                    G1 X153.798 Y155.819 E0.5632
                    G1 X152.895 Y156.721 E0.5792
                    G1 X153.215 Y156.967 E0.5842
                    G1 X154.024 Y156.158 E0.5986
                    G1 X154.033 Y156.171 E0.5988
                    G1 X154.213 Y156.535 E0.6039
                    G1 X153.535 Y157.213 E0.6159
                    G1 X153.856 Y157.458 E0.6210
                    G1 X154.377 Y156.937 E0.6302
                    G1 X154.498 Y157.295 E0.6349
                    G1 X154.513 Y157.367 E0.6359
                    G1 X154.126 Y157.754 E0.6427
                    G1 X154.312 Y157.997 E0.6466
                    G1 X154.371 Y158.074 F2025
                    G1 X154.607 Y157.838 F2025
                    G1 X154.617 Y157.892 F2025
                    G1 X154.648 Y158.363 F2025
                    G1 X154.617 Y158.394 F2025
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 X154.264 Y146.041 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.026 Y145.818 E0.0041 F1898
                    G1 X154.542 Y145.145 E0.0147
                    G1 X154.752 Y145.275 E0.0178
                    G1 X154.819 Y145.317 F1898
                    G1 X154.731 Y145.496 F1898
                    G1 X154.586 Y145.713 F1898
                    G1 X154.414 Y145.909 F1898
                    G1 X154.264 Y146.041 F1898
                    G1 X154.710 Y140.248 F4800
                    G92 E0
                    G1 X154.554 Y139.871 E0.0051 F1898
                    G1 X153.718 Y138.782 E0.0223
                    G1 X152.629 Y137.946 E0.0395
                    G1 X151.361 Y137.421 E0.0568
                    G1 X150.000 Y137.241 E0.0740
                    G1 X148.639 Y137.421 E0.0912
                    G1 X147.371 Y137.946 E0.1084
                    G1 X146.282 Y138.782 E0.1256
                    G1 X145.446 Y139.871 E0.1428
                    G1 X145.290 Y140.248 E0.1480
                    G1 X145.000 Y140.190 E0.1517
                    G1 X145.000 Y139.533 E0.1599
                    G1 X145.045 Y138.848 E0.1685
                    G1 X145.172 Y138.206 E0.1767
                    G1 X145.383 Y137.587 E0.1849
                    G1 X145.672 Y137.001 E0.1931
                    G1 X146.035 Y136.458 E0.2013
                    G1 X146.466 Y135.966 E0.2095
                    G1 X146.957 Y135.535 E0.2177
                    G1 X147.501 Y135.172 E0.2259
                    G1 X148.087 Y134.883 E0.2341
                    G1 X148.706 Y134.672 E0.2423
                    G1 X149.348 Y134.545 E0.2505
                    G1 X150.000 Y134.502 E0.2587
                    G1 X150.652 Y134.545 E0.2669
                    G1 X151.294 Y134.672 E0.2751
                    G1 X151.913 Y134.883 E0.2833
                    G1 X152.499 Y135.172 E0.2915
                    G1 X153.042 Y135.535 E0.2997
                    G1 X153.534 Y135.966 E0.3079
                    G1 X153.965 Y136.458 E0.3161
                    G1 X154.328 Y137.001 E0.3243
                    G1 X154.617 Y137.587 E0.3325
                    G1 X154.828 Y138.206 E0.3407
                    G1 X154.955 Y138.848 E0.3489
                    G1 X154.997 Y139.486 E0.3569
                    G1 X155.000 Y139.533 F1898
                    G1 X155.000 Y140.190 F1898
                    G1 X154.710 Y140.248 F1898
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X145.974 Y145.818 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.736 Y146.041 E0.0041 F1898
                    G1 X145.586 Y145.909 E0.0066
                    G1 X145.414 Y145.713 E0.0099
                    G1 X145.269 Y145.496 E0.0131
                    G1 X145.181 Y145.317 E0.0156
                    G1 X145.329 Y145.225 E0.0178
                    G1 X145.458 Y145.145 F1898
                    G1 X145.974 Y145.818 F1898
                    G1 X146.395 Y145.709 F4800
                    G92 E0
                    G1 X146.395 Y146.819 E0.0139 F1898
                    G1 X146.079 Y146.711 E0.0181
                    G1 X145.798 Y146.573 E0.0220
                    G1 X145.538 Y146.399 E0.0260
                    G1 X145.302 Y146.192 E0.0299
                    G1 X145.096 Y145.957 E0.0338
                    G1 X144.922 Y145.697 E0.0377
                    G1 X144.783 Y145.416 E0.0417
                    G1 X144.683 Y145.119 E0.0456
                    G1 X144.622 Y144.812 E0.0495
                    G1 X144.600 Y144.480 E0.0537
                    G1 X144.600 Y139.520 E0.1159
                    G1 X144.647 Y138.795 E0.1250
                    G1 X144.785 Y138.103 E0.1339
                    G1 X145.012 Y137.434 E0.1427
                    G1 X145.325 Y136.801 E0.1516
                    G1 X145.717 Y136.213 E0.1604
                    G1 X146.183 Y135.683 E0.1693
                    G1 X146.714 Y135.217 E0.1781
                    G1 X147.301 Y134.825 E0.1870
                    G1 X147.934 Y134.512 E0.1958
                    G1 X148.603 Y134.285 E0.2047
                    G1 X149.295 Y134.147 E0.2136
                    G1 X150.000 Y134.101 E0.2224
                    G1 X150.705 Y134.147 E0.2313
                    G1 X151.397 Y134.285 E0.2401
                    G1 X152.066 Y134.512 E0.2490
                    G1 X152.699 Y134.825 E0.2578
                    G1 X153.287 Y135.217 E0.2667
                    G1 X153.818 Y135.683 E0.2755
                    G1 X154.283 Y136.213 E0.2844
                    G1 X154.675 Y136.801 E0.2933
                    G1 X154.988 Y137.434 E0.3021
                    G1 X155.215 Y138.103 E0.3110
                    G1 X155.352 Y138.795 E0.3198
                    G1 X155.400 Y139.520 E0.3289
                    G1 X155.400 Y144.480 E0.3911
                    G1 X155.378 Y144.812 E0.3953
                    G1 X155.317 Y145.119 E0.3992
                    G1 X155.217 Y145.416 E0.4032
                    G1 X155.078 Y145.697 E0.4071
                    G1 X154.904 Y145.957 E0.4110
                    G1 X154.698 Y146.192 E0.4149
                    G1 X154.462 Y146.399 E0.4189
                    G1 X154.202 Y146.573 E0.4228
                    G1 X153.921 Y146.711 E0.4267
                    G1 X153.605 Y146.819 E0.4309
                    G1 X153.605 Y145.709 E0.4448
                    G1 X154.205 Y144.928 E0.4572
                    G1 X154.690 Y143.757 E0.4731
                    G1 X154.855 Y142.500 E0.4890
                    G1 X154.690 Y141.243 E0.5048
                    G1 X154.205 Y140.072 E0.5207
                    G1 X153.433 Y139.067 E0.5366
                    G1 X152.428 Y138.295 E0.5525
                    G1 X151.257 Y137.810 E0.5684
                    G1 X150.000 Y137.645 E0.5843
                    G1 X148.743 Y137.810 E0.6002
                    G1 X147.572 Y138.295 E0.6161
                    G1 X146.567 Y139.067 E0.6320
                    G1 X145.795 Y140.072 E0.6479
                    G1 X145.310 Y141.243 E0.6638
                    G1 X145.145 Y142.500 E0.6797
                    G1 X145.310 Y143.757 E0.6956
                    G1 X145.789 Y144.914 E0.7113
                    G1 X145.795 Y144.928 F1898
                    G1 X146.395 Y145.709 F1898
                    ; outer perimeter
                    G1 X146.795 Y145.573 F4800
                    G92 E0
                    G1 X146.795 Y147.284 E0.0215 F1265
                    G1 X146.631 Y147.271 E0.0235
                    G1 X146.272 Y147.199 E0.0281
                    G1 X145.925 Y147.082 E0.0327
                    G1 X145.598 Y146.920 E0.0373
                    G1 X145.294 Y146.717 E0.0419
                    G1 X145.019 Y146.476 E0.0464
                    G1 X144.778 Y146.201 E0.0510
                    G1 X144.575 Y145.897 E0.0556
                    G1 X144.413 Y145.569 E0.0602
                    G1 X144.296 Y145.223 E0.0648
                    G1 X144.224 Y144.865 E0.0694
                    G1 X144.200 Y144.493 E0.0740
                    G1 X144.200 Y139.507 E0.1366
                    G1 X144.250 Y138.743 E0.1462
                    G1 X144.398 Y137.999 E0.1557
                    G1 X144.642 Y137.281 E0.1652
                    G1 X144.977 Y136.600 E0.1747
                    G1 X145.399 Y135.969 E0.1842
                    G1 X145.899 Y135.399 E0.1937
                    G1 X146.469 Y134.899 E0.2032
                    G1 X147.100 Y134.477 E0.2128
                    G1 X147.781 Y134.142 E0.2223
                    G1 X148.499 Y133.898 E0.2318
                    G1 X149.243 Y133.750 E0.2413
                    G1 X150.000 Y133.700 E0.2508
                    G1 X150.757 Y133.750 E0.2603
                    G1 X151.501 Y133.898 E0.2698
                    G1 X152.219 Y134.142 E0.2793
                    G1 X152.900 Y134.477 E0.2889
                    G1 X153.531 Y134.899 E0.2984
                    G1 X154.101 Y135.399 E0.3079
                    G1 X154.601 Y135.969 E0.3174
                    G1 X155.023 Y136.600 E0.3269
                    G1 X155.358 Y137.281 E0.3364
                    G1 X155.602 Y137.999 E0.3459
                    G1 X155.750 Y138.743 E0.3555
                    G1 X155.800 Y139.507 E0.3650
                    G1 X155.800 Y144.494 E0.4276
                    G1 X155.776 Y144.865 E0.4323
                    G1 X155.704 Y145.223 E0.4368
                    G1 X155.587 Y145.569 E0.4414
                    G1 X155.425 Y145.897 E0.4460
                    G1 X155.222 Y146.201 E0.4506
                    G1 X154.981 Y146.476 E0.4552
                    G1 X154.706 Y146.717 E0.4598
                    G1 X154.402 Y146.920 E0.4643
                    G1 X154.075 Y147.082 E0.4689
                    G1 X153.728 Y147.199 E0.4735
                    G1 X153.369 Y147.271 E0.4781
                    G1 X153.205 Y147.284 E0.4802
                    G1 X153.205 Y145.573 E0.5016
                    G1 X153.855 Y144.726 E0.5150
                    G1 X154.300 Y143.652 E0.5296
                    G1 X154.452 Y142.500 E0.5442
                    G1 X154.300 Y141.348 E0.5587
                    G1 X153.855 Y140.274 E0.5733
                    G1 X153.148 Y139.352 E0.5879
                    G1 X152.226 Y138.645 E0.6024
                    G1 X151.152 Y138.200 E0.6170
                    G1 X150.000 Y138.048 E0.6316
                    G1 X148.848 Y138.200 E0.6462
                    G1 X147.774 Y138.645 E0.6607
                    G1 X146.852 Y139.352 E0.6753
                    G1 X146.145 Y140.274 E0.6899
                    G1 X145.700 Y141.348 E0.7045
                    G1 X145.548 Y142.500 E0.7190
                    G1 X145.700 Y143.652 E0.7336
                    G1 X146.145 Y144.726 E0.7482
                    G1 X146.186 Y144.780 E0.7490
                    G1 X146.795 Y145.573 F1265
                    ; gap fill
                    G1 X145.267 Y144.551 F4800
                    G92 E0
                    G1 X144.978 Y144.840 E0.0051 F2025
                    G1 X144.964 Y144.767 E0.0060
                    G1 X144.953 Y144.614 E0.0080
                    G1 X144.944 Y144.469 F2025
                    G1 X144.944 Y144.308 F2025
                    G1 X145.101 Y144.151 F2025
                    G1 X144.975 Y143.846 F2025
                    G1 X144.959 Y143.727 F2025
                    G1 X144.944 Y143.742 F2025
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X155.025 Y143.843 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X155.056 Y143.813 E0.0005 F2025
                    G1 X155.056 Y144.378 E0.0076
                    G1 X155.050 Y144.384 E0.0077
                    G1 X154.636 Y144.798 F2025
                    G1 X154.985 Y145.015 F2025
                    G1 X154.988 Y145.012 F2025
                    ; solid layer
                    G1 X154.516 Y139.262 F4800
                    G92 E0
                    G1 X154.634 Y139.144 E0.0021 F2025
                    G1 X154.617 Y138.892 E0.0053
                    G1 X154.568 Y138.644 E0.0084
                    G1 X154.270 Y138.942 E0.0137
                    G1 X154.024 Y138.622 E0.0188
                    G1 X154.461 Y138.185 E0.0265
                    G1 X154.318 Y137.763 E0.0321
                    G1 X153.724 Y138.357 E0.0427
                    G1 X153.403 Y138.111 E0.0477
                    G1 X154.136 Y137.379 E0.0607
                    G1 X154.033 Y137.171 E0.0636
                    G1 X153.931 Y137.018 E0.0659
                    G1 X153.083 Y137.866 E0.0809
                    G1 X152.801 Y137.649 E0.0854
                    G1 X152.754 Y137.629 E0.0860
                    G1 X153.704 Y136.679 E0.1029
                    G1 X153.695 Y136.665 E0.1031
                    G1 X153.442 Y136.376 E0.1079
                    G1 X152.354 Y137.464 E0.1272
                    G1 X151.954 Y137.298 E0.1327
                    G1 X153.161 Y136.091 E0.1541
                    G1 X152.860 Y135.827 E0.1591
                    G1 X151.554 Y137.132 E0.1822
                    G1 X151.450 Y137.089 E0.1837
                    G1 X151.080 Y137.041 E0.1883
                    G1 X152.524 Y135.597 E0.2139
                    G1 X152.329 Y135.467 E0.2169
                    G1 X152.168 Y135.387 E0.2191
                    G1 X150.580 Y136.975 E0.2473
                    G1 X150.080 Y136.909 E0.2536
                    G1 X151.789 Y135.201 E0.2839
                    G1 X151.782 Y135.197 E0.2840
                    G1 X151.367 Y135.056 E0.2895
                    G1 X149.453 Y136.970 E0.3234
                    G1 X148.802 Y137.056 E0.3317
                    G1 X150.914 Y134.944 E0.3691
                    G1 X150.608 Y134.883 E0.3731
                    G1 X150.422 Y134.871 E0.3754
                    G1 X148.664 Y136.628 E0.4066
                    G1 X147.957 Y137.335 F2025
                    G1 X146.186 Y136.843 F4800
                    G92 E0
                    G1 X147.344 Y135.686 E0.0205 F2025
                    G1 X147.672 Y135.467 E0.0255
                    G1 X148.218 Y135.197 E0.0331
                    G1 X148.490 Y135.105 E0.0367
                    G1 X145.605 Y137.990 E0.0879
                    G1 X145.502 Y138.295 E0.0919
                    G1 X145.411 Y138.750 E0.0977
                    G1 X149.250 Y134.911 E0.1658
                    G1 X149.392 Y134.883 E0.1676
                    G1 X149.875 Y134.851 E0.1737
                    G1 X146.677 Y138.050 E0.2304
                    G1 X146.039 Y138.539 E0.2405
                    G1 X145.987 Y138.606 E0.2416
                    G1 X145.550 Y139.177 F2025
                    G1 X145.351 Y139.375 F2025
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 3, Z = 0.700
                    ; inner perimeter
                    G1 X145.000 Y139.533 F4800
                    G1 Z0.700 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.045 Y138.848 E0.0086 F1911
                    G1 X145.172 Y138.206 E0.0168
                    G1 X145.383 Y137.587 E0.0250
                    G1 X145.672 Y137.001 E0.0332
                    G1 X146.035 Y136.458 E0.0414
                    G1 X146.466 Y135.966 E0.0496
                    G1 X146.957 Y135.535 E0.0578
                    G1 X147.501 Y135.172 E0.0660
                    G1 X148.087 Y134.883 E0.0742
                    G1 X148.706 Y134.672 E0.0824
                    G1 X149.348 Y134.545 E0.0906
                    G1 X150.000 Y134.502 E0.0988
                    G1 X150.652 Y134.545 E0.1070
                    G1 X151.294 Y134.672 E0.1152
                    G1 X151.913 Y134.883 E0.1234
                    G1 X152.499 Y135.172 E0.1316
                    G1 X153.042 Y135.535 E0.1398
                    G1 X153.534 Y135.966 E0.1480
                    G1 X153.965 Y136.458 E0.1562
                    G1 X154.328 Y137.001 E0.1644
                    G1 X154.617 Y137.587 E0.1726
                    G1 X154.828 Y138.206 E0.1808
                    G1 X154.955 Y138.848 E0.1890
                    G1 X155.000 Y139.533 E0.1976
                    G1 X155.000 Y140.190 E0.2058
                    G1 X154.710 Y140.248 E0.2095
                    G1 X154.554 Y139.871 E0.2146
                    G1 X153.718 Y138.782 E0.2319
                    G1 X152.629 Y137.946 E0.2491
                    G1 X151.361 Y137.421 E0.2663
                    G1 X150.000 Y137.241 E0.2835
                    G1 X148.639 Y137.421 E0.3007
                    G1 X147.371 Y137.946 E0.3179
                    G1 X146.282 Y138.782 E0.3351
                    G1 X145.446 Y139.871 E0.3524
                    G1 X145.308 Y140.204 E0.3569
                    G1 X145.290 Y140.248 F1911
                    G1 X145.000 Y140.190 F1911
                    G1 X145.000 Y139.533 F1911
                    G92 E0
                    G1 X145.974 Y145.818 E0.0106 F1911
                    G1 X145.736 Y146.041 E0.0147
                    G1 X145.586 Y145.909 E0.0172
                    G1 X145.555 Y145.873 E0.0178
                    G1 X145.414 Y145.713 F1911
                    G1 X145.269 Y145.496 F1911
                    G1 X145.181 Y145.317 F1911
                    G1 X145.458 Y145.145 F1911
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.542 Y145.145 E0.0106 F1911
                    G1 X154.819 Y145.317 E0.0147
                    G1 X154.731 Y145.496 E0.0172
                    G1 X154.705 Y145.536 E0.0178
                    G1 X154.586 Y145.713 F1911
                    G1 X154.414 Y145.909 F1911
                    G1 X154.264 Y146.041 F1911
                    G1 X154.026 Y145.818 F1911
                    G92 E0
                    G1 X154.205 Y144.928 E0.0123 F1911
                    G1 X154.690 Y143.757 E0.0282
                    G1 X154.855 Y142.500 E0.0441
                    G1 X154.690 Y141.243 E0.0600
                    G1 X154.205 Y140.072 E0.0759
                    G1 X153.433 Y139.067 E0.0918
                    G1 X152.428 Y138.295 E0.1077
                    G1 X151.257 Y137.810 E0.1236
                    G1 X150.000 Y137.645 E0.1395
                    G1 X148.743 Y137.810 E0.1554
                    G1 X147.572 Y138.295 E0.1713
                    G1 X146.567 Y139.067 E0.1872
                    G1 X145.795 Y140.072 E0.2031
                    G1 X145.310 Y141.243 E0.2190
                    G1 X145.145 Y142.500 E0.2349
                    G1 X145.310 Y143.757 E0.2508
                    G1 X145.795 Y144.928 E0.2667
                    G1 X146.395 Y145.709 E0.2790
                    G1 X146.395 Y146.819 E0.2929
                    G1 X146.079 Y146.711 E0.2971
                    G1 X145.798 Y146.573 E0.3010
                    G1 X145.538 Y146.399 E0.3050
                    G1 X145.302 Y146.192 E0.3089
                    G1 X145.096 Y145.957 E0.3128
                    G1 X144.922 Y145.697 E0.3167
                    G1 X144.783 Y145.416 E0.3207
                    G1 X144.683 Y145.119 E0.3246
                    G1 X144.622 Y144.812 E0.3285
                    G1 X144.600 Y144.480 E0.3327
                    G1 X144.600 Y139.520 E0.3949
                    G1 X144.647 Y138.795 E0.4040
                    G1 X144.785 Y138.103 E0.4129
                    G1 X145.012 Y137.434 E0.4217
                    G1 X145.325 Y136.801 E0.4306
                    G1 X145.717 Y136.213 E0.4394
                    G1 X146.183 Y135.683 E0.4483
                    G1 X146.714 Y135.217 E0.4571
                    G1 X147.301 Y134.825 E0.4660
                    G1 X147.934 Y134.512 E0.4749
                    G1 X148.603 Y134.285 E0.4837
                    G1 X149.295 Y134.147 E0.4926
                    G1 X150.000 Y134.101 E0.5014
                    G1 X150.705 Y134.147 E0.5103
                    G1 X151.397 Y134.285 E0.5191
                    G1 X152.066 Y134.512 E0.5280
                    G1 X152.699 Y134.825 E0.5368
                    G1 X153.287 Y135.217 E0.5457
                    G1 X153.818 Y135.683 E0.5546
                    G1 X154.283 Y136.213 E0.5634
                    G1 X154.675 Y136.801 E0.5723
                    G1 X154.988 Y137.434 E0.5811
                    G1 X155.215 Y138.103 E0.5900
                    G1 X155.352 Y138.795 E0.5988
                    G1 X155.400 Y139.520 E0.6079
                    G1 X155.400 Y144.480 E0.6701
                    G1 X155.378 Y144.812 E0.6743
                    G1 X155.317 Y145.119 E0.6782
                    G1 X155.217 Y145.416 E0.6822
                    G1 X155.078 Y145.697 E0.6861
                    G1 X154.904 Y145.957 E0.6900
                    G1 X154.698 Y146.192 E0.6939
                    G1 X154.462 Y146.399 E0.6979
                    G1 X154.202 Y146.573 E0.7018
                    G1 X153.921 Y146.711 E0.7057
                    G1 X153.605 Y146.819 E0.7099
                    G1 X153.605 Y146.709 E0.7113
                    G1 X153.605 Y145.709 F1911
                    ; outer perimeter
                    G92 E0
                    G1 X153.855 Y144.726 E0.0134 F1274
                    G1 X154.300 Y143.652 E0.0280
                    G1 X154.452 Y142.500 E0.0425
                    G1 X154.300 Y141.348 E0.0571
                    G1 X153.855 Y140.274 E0.0717
                    G1 X153.148 Y139.352 E0.0863
                    G1 X152.226 Y138.645 E0.1008
                    G1 X151.152 Y138.200 E0.1154
                    G1 X150.000 Y138.048 E0.1300
                    G1 X148.848 Y138.200 E0.1446
                    G1 X147.774 Y138.645 E0.1591
                    G1 X146.852 Y139.352 E0.1737
                    G1 X146.145 Y140.274 E0.1883
                    G1 X145.700 Y141.348 E0.2028
                    G1 X145.548 Y142.500 E0.2174
                    G1 X145.700 Y143.652 E0.2320
                    G1 X146.145 Y144.726 E0.2466
                    G1 X146.795 Y145.573 E0.2600
                    G1 X146.795 Y147.284 E0.2814
                    G1 X146.631 Y147.271 E0.2835
                    G1 X146.272 Y147.199 E0.2881
                    G1 X145.925 Y147.082 E0.2927
                    G1 X145.598 Y146.920 E0.2972
                    G1 X145.294 Y146.717 E0.3018
                    G1 X145.019 Y146.476 E0.3064
                    G1 X144.778 Y146.201 E0.3110
                    G1 X144.575 Y145.897 E0.3156
                    G1 X144.413 Y145.569 E0.3202
                    G1 X144.296 Y145.223 E0.3247
                    G1 X144.224 Y144.865 E0.3293
                    G1 X144.200 Y144.493 E0.3340
                    G1 X144.200 Y139.507 E0.3965
                    G1 X144.250 Y138.743 E0.4061
                    G1 X144.398 Y137.999 E0.4156
                    G1 X144.642 Y137.281 E0.4251
                    G1 X144.977 Y136.600 E0.4347
                    G1 X145.399 Y135.969 E0.4442
                    G1 X145.899 Y135.399 E0.4537
                    G1 X146.469 Y134.899 E0.4632
                    G1 X147.100 Y134.477 E0.4727
                    G1 X147.781 Y134.142 E0.4822
                    G1 X148.499 Y133.898 E0.4917
                    G1 X149.243 Y133.750 E0.5013
                    G1 X150.000 Y133.700 E0.5108
                    G1 X150.757 Y133.750 E0.5203
                    G1 X151.501 Y133.898 E0.5298
                    G1 X152.219 Y134.142 E0.5393
                    G1 X152.900 Y134.477 E0.5488
                    G1 X153.531 Y134.899 E0.5583
                    G1 X154.101 Y135.399 E0.5678
                    G1 X154.601 Y135.969 E0.5774
                    G1 X155.023 Y136.600 E0.5869
                    G1 X155.358 Y137.281 E0.5964
                    G1 X155.602 Y137.999 E0.6059
                    G1 X155.750 Y138.743 E0.6154
                    G1 X155.800 Y139.507 E0.6250
                    G1 X155.800 Y144.494 E0.6875
                    G1 X155.776 Y144.865 E0.6922
                    G1 X155.704 Y145.223 E0.6968
                    G1 X155.587 Y145.569 E0.7014
                    G1 X155.425 Y145.897 E0.7060
                    G1 X155.222 Y146.201 E0.7105
                    G1 X154.981 Y146.476 E0.7151
                    G1 X154.706 Y146.717 E0.7197
                    G1 X154.402 Y146.920 E0.7243
                    G1 X154.075 Y147.082 E0.7289
                    G1 X153.728 Y147.199 E0.7335
                    G1 X153.369 Y147.271 E0.7381
                    G1 X153.205 Y147.284 E0.7401
                    G1 X153.205 Y146.573 E0.7490
                    G1 X153.205 Y145.573 F1274
                    ; gap fill
                    G92 E0
                    G1 X154.733 Y144.551 E0.0051 F2038
                    G1 X154.826 Y144.327 E0.0082
                    G1 X154.899 Y144.151 F2038
                    G1 X155.056 Y144.308 F2038
                    G1 X155.056 Y143.742 F2038
                    G1 X155.041 Y143.727 F2038
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X144.975 Y143.843 E0.0005 F2038
                    G1 X144.975 Y143.846 E0.0006
                    G1 X145.368 Y144.796 E0.0135
                    G1 X145.364 Y144.798 E0.0135
                    G1 X145.196 Y144.630 E0.0165
                    G1 X144.944 Y144.378 F2038
                    G1 X144.944 Y144.469 F2038
                    G1 X144.964 Y144.767 F2038
                    G1 X145.012 Y145.012 F2038
                    G1 X145.015 Y145.015 F2038
                    ; solid layer
                    G92 E0
                    G1 X145.484 Y139.262 E0.0021 F2038
                    G1 X145.730 Y138.942 E0.0072
                    G1 X145.432 Y138.644 E0.0124
                    G1 X145.502 Y138.295 E0.0169
                    G1 X145.539 Y138.185 E0.0184
                    G1 X145.976 Y138.622 E0.0261
                    G1 X146.039 Y138.539 E0.0274
                    G1 X146.277 Y138.357 E0.0312
                    G1 X145.682 Y137.763 E0.0417
                    G1 X145.697 Y137.718 E0.0423
                    G1 X145.864 Y137.379 E0.0470
                    G1 X146.597 Y138.111 E0.0600
                    G1 X146.917 Y137.866 E0.0651
                    G1 X146.069 Y137.018 E0.0801
                    G1 X146.296 Y136.679 E0.0852
                    G1 X147.246 Y137.629 E0.1021
                    G1 X147.646 Y137.464 E0.1075
                    G1 X146.559 Y136.376 E0.1268
                    G1 X146.707 Y136.207 E0.1296
                    G1 X146.839 Y136.091 E0.1318
                    G1 X148.046 Y137.298 E0.1532
                    G1 X148.446 Y137.132 E0.1587
                    G1 X147.140 Y135.827 E0.1818
                    G1 X147.165 Y135.805 E0.1822
                    G1 X147.476 Y135.597 E0.1869
                    G1 X148.920 Y137.041 E0.2125
                    G1 X149.420 Y136.975 E0.2188
                    G1 X147.832 Y135.387 E0.2470
                    G1 X148.211 Y135.201 E0.2523
                    G1 X149.920 Y136.909 E0.2826
                    G1 X150.000 Y136.898 E0.2836
                    G1 X150.547 Y136.970 E0.2905
                    G1 X148.633 Y135.056 E0.3245
                    G1 X148.795 Y135.002 E0.3266
                    G1 X149.086 Y134.944 E0.3303
                    G1 X151.198 Y137.056 E0.3678
                    G1 X151.450 Y137.089 E0.3710
                    G1 X152.043 Y137.335 E0.3790
                    G1 X149.578 Y134.871 E0.4227
                    G1 X150.000 Y134.843 E0.4280
                    G1 X150.125 Y134.851 E0.4296
                    G1 X153.324 Y138.050 E0.4863
                    G1 X153.961 Y138.539 E0.4964
                    G1 X154.450 Y139.176 E0.5065
                    G1 X154.649 Y139.375 E0.5100
                    G1 X154.617 Y138.892 E0.5161
                    G1 X154.589 Y138.750 E0.5179
                    G1 X150.750 Y134.911 E0.5860
                    G1 X151.205 Y135.002 E0.5918
                    G1 X151.510 Y135.105 E0.5958
                    G1 X154.395 Y137.990 E0.6470
                    G1 X154.303 Y137.718 E0.6506
                    G1 X154.033 Y137.171 E0.6583
                    G1 X153.814 Y136.843 E0.6632
                    G1 X153.364 Y136.393 E0.6712
                    G1 X152.657 Y135.686 F2038
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X151.294 Y153.672 E0.0082 F1911
                    G1 X151.913 Y153.883 E0.0164
                    G1 X152.499 Y154.172 E0.0246
                    G1 X153.042 Y154.535 E0.0328
                    G1 X153.534 Y154.966 E0.0410
                    G1 X153.965 Y155.458 E0.0492
                    G1 X154.328 Y156.001 E0.0574
                    G1 X154.617 Y156.587 E0.0656
                    G1 X154.828 Y157.206 E0.0738
                    G1 X154.955 Y157.848 E0.0820
                    G1 X155.000 Y158.533 E0.0906
                    G1 X155.000 Y159.190 E0.0988
                    G1 X154.710 Y159.248 E0.1025
                    G1 X154.554 Y158.871 E0.1077
                    G1 X153.718 Y157.782 E0.1249
                    G1 X152.629 Y156.946 E0.1421
                    G1 X151.361 Y156.421 E0.1593
                    G1 X150.000 Y156.241 E0.1765
                    G1 X148.639 Y156.421 E0.1937
                    G1 X147.371 Y156.946 E0.2109
                    G1 X146.282 Y157.782 E0.2282
                    G1 X145.446 Y158.871 E0.2454
                    G1 X145.290 Y159.248 E0.2505
                    G1 X145.000 Y159.190 E0.2542
                    G1 X145.000 Y158.533 E0.2624
                    G1 X145.045 Y157.848 E0.2710
                    G1 X145.172 Y157.206 E0.2792
                    G1 X145.383 Y156.587 E0.2874
                    G1 X145.672 Y156.001 E0.2956
                    G1 X146.035 Y155.458 E0.3038
                    G1 X146.466 Y154.966 E0.3120
                    G1 X146.957 Y154.535 E0.3202
                    G1 X147.501 Y154.172 E0.3284
                    G1 X148.087 Y153.883 E0.3366
                    G1 X148.706 Y153.672 E0.3448
                    G1 X149.348 Y153.545 E0.3530
                    G1 X149.655 Y153.525 E0.3569
                    G1 X150.000 Y153.502 F1911
                    G1 X150.652 Y153.545 F1911
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.819 Y164.317 E0.0041 F1911
                    G1 X154.731 Y164.496 E0.0066
                    G1 X154.586 Y164.713 E0.0099
                    G1 X154.414 Y164.909 E0.0131
                    G1 X154.264 Y165.041 E0.0156
                    G1 X154.137 Y164.922 E0.0178
                    G1 X154.026 Y164.818 F1911
                    G1 X154.542 Y164.145 F1911
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.736 Y165.041 E0.0041 F1911
                    G1 X145.586 Y164.909 E0.0066
                    G1 X145.414 Y164.713 E0.0099
                    G1 X145.269 Y164.496 E0.0131
                    G1 X145.181 Y164.317 E0.0156
                    G1 X145.329 Y164.225 E0.0178
                    G1 X145.458 Y164.145 F1911
                    G1 X145.974 Y164.818 F1911
                    G92 E0
                    G1 X146.395 Y165.819 E0.0139 F1911
                    G1 X146.079 Y165.711 E0.0181
                    G1 X145.798 Y165.573 E0.0220
                    G1 X145.538 Y165.399 E0.0260
                    G1 X145.302 Y165.192 E0.0299
                    G1 X145.096 Y164.957 E0.0338
                    G1 X144.922 Y164.697 E0.0377
                    G1 X144.783 Y164.416 E0.0417
                    G1 X144.683 Y164.119 E0.0456
                    G1 X144.622 Y163.812 E0.0495
                    G1 X144.600 Y163.480 E0.0537
                    G1 X144.600 Y158.520 E0.1159
                    G1 X144.647 Y157.795 E0.1250
                    G1 X144.785 Y157.103 E0.1339
                    G1 X145.012 Y156.434 E0.1427
                    G1 X145.325 Y155.801 E0.1516
                    G1 X145.717 Y155.213 E0.1604
                    G1 X146.183 Y154.683 E0.1693
                    G1 X146.714 Y154.217 E0.1781
                    G1 X147.301 Y153.825 E0.1870
                    G1 X147.934 Y153.512 E0.1958
                    G1 X148.603 Y153.285 E0.2047
                    G1 X149.295 Y153.147 E0.2136
                    G1 X150.000 Y153.101 E0.2224
                    G1 X150.705 Y153.147 E0.2313
                    G1 X151.397 Y153.285 E0.2401
                    G1 X152.066 Y153.512 E0.2490
                    G1 X152.699 Y153.825 E0.2578
                    G1 X153.287 Y154.217 E0.2667
                    G1 X153.818 Y154.683 E0.2755
                    G1 X154.283 Y155.213 E0.2844
                    G1 X154.675 Y155.801 E0.2933
                    G1 X154.988 Y156.434 E0.3021
                    G1 X155.215 Y157.103 E0.3110
                    G1 X155.352 Y157.795 E0.3198
                    G1 X155.400 Y158.520 E0.3289
                    G1 X155.400 Y163.480 E0.3911
                    G1 X155.378 Y163.812 E0.3953
                    G1 X155.317 Y164.119 E0.3992
                    G1 X155.217 Y164.416 E0.4032
                    G1 X155.078 Y164.697 E0.4071
                    G1 X154.904 Y164.957 E0.4110
                    G1 X154.698 Y165.192 E0.4149
                    G1 X154.462 Y165.399 E0.4189
                    G1 X154.202 Y165.573 E0.4228
                    G1 X153.921 Y165.711 E0.4267
                    G1 X153.605 Y165.819 E0.4309
                    G1 X153.605 Y164.709 E0.4448
                    G1 X154.205 Y163.928 E0.4572
                    G1 X154.690 Y162.757 E0.4731
                    G1 X154.855 Y161.500 E0.4890
                    G1 X154.690 Y160.243 E0.5048
                    G1 X154.205 Y159.072 E0.5207
                    G1 X153.433 Y158.067 E0.5366
                    G1 X152.428 Y157.295 E0.5525
                    G1 X151.257 Y156.810 E0.5684
                    G1 X150.000 Y156.645 E0.5843
                    G1 X148.743 Y156.810 E0.6002
                    G1 X147.572 Y157.295 E0.6161
                    G1 X146.567 Y158.067 E0.6320
                    G1 X145.795 Y159.072 E0.6479
                    G1 X145.310 Y160.243 E0.6638
                    G1 X145.145 Y161.500 E0.6797
                    G1 X145.310 Y162.757 E0.6956
                    G1 X145.789 Y163.914 E0.7113
                    G1 X145.795 Y163.928 F1911
                    G1 X146.395 Y164.709 F1911
                    ; outer perimeter
                    G92 E0
                    G1 X146.795 Y166.284 E0.0215 F1274
                    G1 X146.631 Y166.271 E0.0235
                    G1 X146.272 Y166.199 E0.0281
                    G1 X145.925 Y166.082 E0.0327
                    G1 X145.598 Y165.920 E0.0373
                    G1 X145.294 Y165.717 E0.0419
                    G1 X145.019 Y165.476 E0.0464
                    G1 X144.778 Y165.201 E0.0510
                    G1 X144.575 Y164.897 E0.0556
                    G1 X144.413 Y164.569 E0.0602
                    G1 X144.296 Y164.223 E0.0648
                    G1 X144.224 Y163.865 E0.0694
                    G1 X144.200 Y163.493 E0.0740
                    G1 X144.200 Y158.507 E0.1366
                    G1 X144.250 Y157.743 E0.1462
                    G1 X144.398 Y156.999 E0.1557
                    G1 X144.642 Y156.281 E0.1652
                    G1 X144.977 Y155.600 E0.1747
                    G1 X145.399 Y154.969 E0.1842
                    G1 X145.899 Y154.399 E0.1937
                    G1 X146.469 Y153.899 E0.2032
                    G1 X147.100 Y153.477 E0.2128
                    G1 X147.781 Y153.142 E0.2223
                    G1 X148.499 Y152.898 E0.2318
                    G1 X149.243 Y152.750 E0.2413
                    G1 X150.000 Y152.700 E0.2508
                    G1 X150.757 Y152.750 E0.2603
                    G1 X151.501 Y152.898 E0.2698
                    G1 X152.219 Y153.142 E0.2793
                    G1 X152.900 Y153.477 E0.2889
                    G1 X153.531 Y153.899 E0.2984
                    G1 X154.101 Y154.399 E0.3079
                    G1 X154.601 Y154.969 E0.3174
                    G1 X155.023 Y155.600 E0.3269
                    G1 X155.358 Y156.281 E0.3364
                    G1 X155.602 Y156.999 E0.3459
                    G1 X155.750 Y157.743 E0.3555
                    G1 X155.800 Y158.507 E0.3650
                    G1 X155.800 Y163.494 E0.4276
                    G1 X155.776 Y163.865 E0.4323
                    G1 X155.704 Y164.223 E0.4368
                    G1 X155.587 Y164.569 E0.4414
                    G1 X155.425 Y164.897 E0.4460
                    G1 X155.222 Y165.201 E0.4506
                    G1 X154.981 Y165.476 E0.4552
                    G1 X154.706 Y165.717 E0.4598
                    G1 X154.402 Y165.920 E0.4643
                    G1 X154.075 Y166.082 E0.4689
                    G1 X153.728 Y166.199 E0.4735
                    G1 X153.369 Y166.271 E0.4781
                    G1 X153.205 Y166.284 E0.4802
                    G1 X153.205 Y164.573 E0.5016
                    G1 X153.855 Y163.726 E0.5150
                    G1 X154.300 Y162.652 E0.5296
                    G1 X154.452 Y161.500 E0.5442
                    G1 X154.300 Y160.348 E0.5587
                    G1 X153.855 Y159.274 E0.5733
                    G1 X153.148 Y158.352 E0.5879
                    G1 X152.226 Y157.645 E0.6024
                    G1 X151.152 Y157.200 E0.6170
                    G1 X150.000 Y157.048 E0.6316
                    G1 X148.848 Y157.200 E0.6462
                    G1 X147.774 Y157.645 E0.6607
                    G1 X146.852 Y158.352 E0.6753
                    G1 X146.145 Y159.274 E0.6899
                    G1 X145.700 Y160.348 E0.7045
                    G1 X145.548 Y161.500 E0.7190
                    G1 X145.700 Y162.652 E0.7336
                    G1 X146.145 Y163.726 E0.7482
                    G1 X146.186 Y163.780 E0.7490
                    G1 X146.795 Y164.573 F1274
                    ; gap fill
                    G92 E0
                    G1 X145.220 Y163.888 E0.0047 F2038
                    G1 X145.263 Y163.861 E0.0054
                    G1 X145.368 Y163.796 F2038
                    G1 X145.138 Y163.240 F2038
                    G1 X144.944 Y163.046 F2038
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.665 Y163.716 E0.0047 F2038
                    G1 X154.815 Y163.354 E0.0096
                    G1 X154.831 Y163.316 F2038
                    G1 X155.052 Y163.537 F2038
                    G1 X155.056 Y163.469 F2038
                    G1 X155.056 Y162.976 F2038
                    G1 X154.996 Y162.916 F2038
                    ; solid layer
                    G92 E0
                    G1 X154.154 Y156.417 E0.0367 F2038
                    G1 X154.303 Y156.718 E0.0409
                    G1 X154.498 Y157.295 E0.0486
                    G1 X154.506 Y157.335 E0.0491
                    G1 X151.165 Y153.994 E0.1084
                    G1 X150.608 Y153.883 E0.1155
                    G1 X150.480 Y153.874 E0.1171
                    G1 X154.626 Y158.020 E0.1906
                    G1 X154.653 Y158.441 E0.1959
                    G1 X153.961 Y157.539 E0.2102
                    G1 X152.801 Y156.649 E0.2285
                    G1 X152.610 Y156.570 E0.2311
                    G1 X149.890 Y153.850 E0.2793
                    G1 X149.392 Y153.883 E0.2856
                    G1 X149.363 Y153.889 E0.2860
                    G1 X151.645 Y156.170 E0.3264
                    G1 X151.450 Y156.089 E0.3291
                    G1 X150.930 Y156.021 E0.3356
                    G1 X148.891 Y153.982 E0.3718
                    G1 X148.795 Y154.002 E0.3730
                    G1 X148.459 Y154.116 E0.3775
                    G1 X150.278 Y155.935 E0.4097
                    G1 X150.000 Y155.898 E0.4133
                    G1 X149.714 Y155.936 E0.4169
                    G1 X148.055 Y154.278 E0.4463
                    G1 X147.676 Y154.464 E0.4516
                    G1 X149.214 Y156.002 E0.4789
                    G1 X148.714 Y156.068 E0.4852
                    G1 X147.337 Y154.691 E0.5096
                    G1 X147.165 Y154.805 E0.5122
                    G1 X147.016 Y154.936 E0.5147
                    G1 X148.281 Y156.201 E0.5371
                    G1 X147.881 Y156.366 E0.5425
                    G1 X146.715 Y155.200 E0.5632
                    G1 X146.707 Y155.207 E0.5634
                    G1 X146.450 Y155.500 E0.5683
                    G1 X147.481 Y156.532 E0.5866
                    G1 X147.199 Y156.649 E0.5904
                    G1 X147.105 Y156.721 E0.5919
                    G1 X146.202 Y155.819 E0.6079
                    G1 X145.976 Y156.158 E0.6130
                    G1 X146.785 Y156.967 E0.6273
                    G1 X146.465 Y157.213 E0.6324
                    G1 X145.787 Y156.535 E0.6444
                    G1 X145.697 Y156.718 E0.6470
                    G1 X145.623 Y156.937 E0.6499
                    G1 X146.145 Y157.458 E0.6591
                    G1 X146.039 Y157.539 E0.6608
                    G1 X145.874 Y157.754 E0.6642
                    G1 X145.487 Y157.367 E0.6710
                    G1 X145.436 Y157.623 E0.6743
                    G1 X145.393 Y157.838 F2038
                    G1 X145.629 Y158.074 F2038
                    G1 X145.383 Y158.394 F2038
                    G1 X145.352 Y158.363 F2038
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 4, Z = 0.900
                    ; inner perimeter
                    G1 Z0.900 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.045 Y157.848 E0.0086 F1896
                    G1 X145.290 Y159.248 F1896
                    G1 X145.000 Y159.190 F1896
                    G1 X145.000 Y158.533 F1896
                    G92 E0
                    G1 X145.974 Y164.818 E0.0106 F1896
                    G1 X145.414 Y164.713 F1896
                    G1 X145.269 Y164.496 F1896
                    G1 X145.181 Y164.317 F1896
                    G1 X145.458 Y164.145 F1896
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.542 Y164.145 E0.0106 F1896
                    G1 X154.586 Y164.713 F1896
                    G1 X154.414 Y164.909 F1896
                    G1 X154.264 Y165.041 F1896
                    G1 X154.026 Y164.818 F1896
                    G92 E0
                    G1 X154.205 Y163.928 E0.0123 F1896
                    G1 X153.605 Y164.709 F1896
                    ; outer perimeter
                    G92 E0
                    G1 X153.855 Y163.726 E0.0134 F1264
                    G1 X153.205 Y164.573 F1264
                    ; gap fill
                    G92 E0
                    G1 X154.940 Y163.727 E0.0028 F2022
                    G1 X155.046 Y163.622 F2022
                    G1 X155.056 Y163.469 F2022
                    G1 X155.056 Y163.046 F2022
                    G1 X154.862 Y163.240 F2022
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.070 Y163.981 E0.0047 F2022
                    G1 X144.948 Y163.537 F2022
                    G1 X145.170 Y163.316 F2022
                    G1 X145.004 Y162.916 F2022
                    G1 X144.944 Y162.976 F2022
                    ; solid layer
                    G92 E0
                    G1 X147.917 Y154.346 E0.0367 F2022
                    G1 X148.638 Y154.055 E0.0465
                    G1 X148.807 Y154.021 E0.0487
                    G1 X145.494 Y157.335 E0.1074
                    G1 X145.383 Y157.892 E0.1146
                    G1 X145.374 Y158.020 E0.1162
                    G1 X149.460 Y153.934 E0.1886
                    G1 X150.000 Y153.899 E0.1954
                    G1 X150.057 Y153.902 E0.1961
                    G1 X147.390 Y156.570 E0.2434
                    G1 X148.356 Y156.170 E0.2566
                    G1 X150.588 Y153.937 E0.2961
                    G1 X150.862 Y153.955 E0.2996
                    G1 X151.090 Y154.001 E0.3025
                    G1 X149.070 Y156.021 E0.3383
                    G1 X149.722 Y155.935 E0.3466
                    G1 X151.541 Y154.116 E0.3788
                    G1 X151.782 Y154.197 E0.3820
                    G1 X151.945 Y154.278 E0.3843
                    G1 X150.286 Y155.936 E0.4137
                    G1 X150.786 Y156.002 E0.4200
                    G1 X152.324 Y154.464 E0.4473
                    G1 X152.328 Y154.467 E0.4474
                    G1 X152.663 Y154.691 E0.4524
                    G1 X151.286 Y156.068 E0.4769
                    G1 X151.450 Y156.089 E0.4789
                    G1 X151.719 Y156.201 E0.4826
                    G1 X152.984 Y154.936 E0.5050
                    G1 X153.285 Y155.200 E0.5100
                    G1 X152.119 Y156.366 E0.5307
                    G1 X152.519 Y156.532 E0.5362
                    G1 X153.551 Y155.500 E0.5544
                    G1 X153.695 Y155.665 E0.5572
                    G1 X153.798 Y155.819 E0.5595
                    G1 X152.895 Y156.721 E0.5755
                    G1 X153.215 Y156.967 E0.5806
                    G1 X154.024 Y156.158 E0.5949
                    G1 X154.033 Y156.171 E0.5951
                    G1 X154.213 Y156.535 E0.6002
                    G1 X153.535 Y157.213 E0.6122
                    G1 X153.856 Y157.458 E0.6173
                    G1 X154.377 Y156.937 E0.6265
                    G1 X154.498 Y157.295 E0.6313
                    G1 X154.513 Y157.367 E0.6322
                    G1 X154.126 Y157.754 E0.6391
                    G1 X154.312 Y157.997 E0.6429
                    G1 X154.371 Y158.074 F2022
                    G1 X154.607 Y157.838 F2022
                    G1 X154.617 Y157.892 F2022
                    G1 X154.648 Y158.363 F2022
                    G1 X154.617 Y158.394 F2022
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.026 Y145.818 E0.0041 F1896
                    G1 X154.819 Y145.317 F1896
                    G1 X154.731 Y145.496 F1896
                    G1 X154.586 Y145.713 F1896
                    G1 X154.414 Y145.909 F1896
                    G1 X154.264 Y146.041 F1896
                    G92 E0
                    G1 X154.554 Y139.871 E0.0051 F1896
                    G1 X155.000 Y139.533 F1896
                    G1 X155.000 Y140.190 F1896
                    G1 X154.710 Y140.248 F1896
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.736 Y146.041 E0.0041 F1896
                    G1 X145.458 Y145.145 F1896
                    G1 X145.974 Y145.818 F1896
                    G92 E0
                    G1 X146.395 Y146.819 E0.0139 F1896
                    G1 X145.795 Y144.928 F1896
                    G1 X146.395 Y145.709 F1896
                    ; outer perimeter
                    G92 E0
                    G1 X146.795 Y147.284 E0.0215 F1264
                    G1 X146.795 Y145.573 F1264
                    ; gap fill
                    G92 E0
                    G1 X144.978 Y144.840 E0.0051 F2022
                    G1 X144.944 Y144.469 F2022
                    G1 X144.944 Y144.308 F2022
                    G1 X145.101 Y144.151 F2022
                    G1 X144.975 Y143.846 F2022
                    G1 X144.959 Y143.727 F2022
                    G1 X144.944 Y143.742 F2022
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X155.056 Y143.813 E0.0005 F2022
                    G1 X154.636 Y144.798 F2022
                    G1 X154.985 Y145.015 F2022
                    G1 X154.988 Y145.012 F2022
                    ; solid layer
                    G92 E0
                    G1 X154.634 Y139.144 E0.0021 F2022
                    G1 X152.328 Y135.467 E0.2169
                    G1 X150.896 Y134.962 E0.3688
                    G1 X150.862 Y134.955 E0.3693
                    G1 X150.369 Y134.923 E0.3754
                    G1 X148.664 Y136.628 E0.4057
                    G1 X147.957 Y137.335 F2022
                    G92 E0
                    G1 X147.344 Y135.686 E0.0205 F2022
                    G1 X149.210 Y134.950 E0.1651
                    G1 X149.816 Y134.911 E0.1727
                    G1 X146.677 Y138.050 E0.2284
                    G1 X146.039 Y138.539 E0.2385
                    G1 X145.987 Y138.606 E0.2395
                    G1 X145.550 Y139.177 F2022
                    G1 X145.351 Y139.375 F2022
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 5, Z = 1.100
                    ; inner perimeter
                    G1 Z1.100 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.045 Y138.848 E0.0086 F1909
                    G1 X145.290 Y140.248 F1909
                    G1 X145.000 Y140.190 F1909
                    G1 X145.000 Y139.533 F1909
                    G92 E0
                    G1 X145.974 Y145.818 E0.0106 F1909
                    G1 X145.414 Y145.713 F1909
                    G1 X145.269 Y145.496 F1909
                    G1 X145.181 Y145.317 F1909
                    G1 X145.458 Y145.145 F1909
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.542 Y145.145 E0.0106 F1909
                    G1 X154.586 Y145.713 F1909
                    G1 X154.414 Y145.909 F1909
                    G1 X154.264 Y146.041 F1909
                    G1 X154.026 Y145.818 F1909
                    G92 E0
                    G1 X154.205 Y144.928 E0.0123 F1909
                    G1 X153.605 Y145.709 F1909
                    ; outer perimeter
                    G92 E0
                    G1 X153.855 Y144.726 E0.0134 F1273
                    G1 X153.205 Y145.573 F1273
                    ; gap fill
                    G92 E0
                    G1 X154.733 Y144.551 E0.0051 F2036
                    G1 X154.899 Y144.151 F2036
                    G1 X155.056 Y144.308 F2036
                    G1 X155.056 Y143.742 F2036
                    G1 X155.041 Y143.727 F2036
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X144.975 Y143.843 E0.0005 F2036
                    G1 X144.944 Y144.378 F2036
                    G1 X144.944 Y144.469 F2036
                    G1 X144.964 Y144.767 F2036
                    G1 X145.012 Y145.012 F2036
                    G1 X145.015 Y145.015 F2036
                    ; solid layer
                    G92 E0
                    G1 X145.484 Y139.262 E0.0021 F2036
                    G1 X148.638 Y135.055 E0.3245
                    G1 X149.104 Y134.962 E0.3305
                    G1 X151.198 Y137.056 E0.3676
                    G1 X151.450 Y137.089 E0.3708
                    G1 X152.043 Y137.335 E0.3789
                    G1 X149.631 Y134.923 E0.4216
                    G1 X150.000 Y134.899 E0.4263
                    G1 X150.184 Y134.911 E0.4286
                    G1 X153.324 Y138.050 E0.4843
                    G1 X153.961 Y138.539 E0.4944
                    G1 X154.450 Y139.176 E0.5044
                    G1 X154.649 Y139.375 E0.5080
                    G1 X154.617 Y138.892 E0.5140
                    G1 X154.589 Y138.750 E0.5158
                    G1 X150.790 Y134.950 E0.5832
                    G1 X150.862 Y134.955 E0.5841
                    G1 X151.362 Y135.055 E0.5905
                    G1 X151.510 Y135.105 E0.5925
                    G1 X154.395 Y137.990 E0.6437
                    G1 X154.303 Y137.718 E0.6473
                    G1 X154.033 Y137.171 E0.6549
                    G1 X153.814 Y136.843 E0.6599
                    G1 X153.364 Y136.393 E0.6678
                    G1 X152.657 Y135.686 F2036
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X151.294 Y153.672 E0.0082 F1909
                    G1 X150.000 Y153.502 F1909
                    G1 X150.652 Y153.545 F1909
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.819 Y164.317 E0.0041 F1909
                    G1 X154.026 Y164.818 F1909
                    G1 X154.542 Y164.145 F1909
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X145.736 Y165.041 E0.0041 F1909
                    G1 X145.458 Y164.145 F1909
                    G1 X145.974 Y164.818 F1909
                    G92 E0
                    G1 X146.395 Y165.819 E0.0139 F1909
                    G1 X145.795 Y163.928 F1909
                    G1 X146.395 Y164.709 F1909
                    ; outer perimeter
                    G92 E0
                    G1 X146.795 Y166.284 E0.0215 F1273
                    G1 X146.795 Y164.573 F1273
                    ; gap fill
                    G92 E0
                    G1 X145.220 Y163.888 E0.0047 F2036
                    G1 X145.368 Y163.796 F2036
                    G1 X145.138 Y163.240 F2036
                    G1 X144.944 Y163.046 F2036
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.665 Y163.716 E0.0047 F2036
                    G1 X154.831 Y163.316 F2036
                    G1 X155.052 Y163.537 F2036
                    G1 X155.056 Y163.469 F2036
                    G1 X155.056 Y162.976 F2036
                    G1 X154.996 Y162.916 F2036
                    ; solid layer
                    G92 E0
                    G1 X154.154 Y156.417 E0.0367 F2036
                    G1 X151.193 Y154.021 E0.1079
                    G1 X150.862 Y153.955 E0.1121
                    G1 X150.540 Y153.934 E0.1161
                    G1 X154.626 Y158.020 E0.1886
                    G1 X154.653 Y158.441 E0.1939
                    G1 X153.961 Y157.539 E0.2082
                    G1 X152.801 Y156.649 E0.2265
                    G1 X152.610 Y156.570 E0.2291
                    G1 X149.943 Y153.902 E0.2764
                    G1 X149.412 Y153.937 E0.2831
                    G1 X151.645 Y156.170 E0.3227
                    G1 X151.450 Y156.089 E0.3253
                    G1 X150.930 Y156.021 E0.3319
                    G1 X148.910 Y154.001 E0.3677
                    G1 X148.638 Y154.055 E0.3712
                    G1 X148.459 Y154.116 E0.3736
                    G1 X150.278 Y155.935 E0.4058
                    G1 X150.000 Y155.898 E0.4093
                    G1 X149.714 Y155.936 E0.4130
                    G1 X148.055 Y154.278 E0.4424
                    G1 X147.676 Y154.464 E0.4477
                    G1 X149.214 Y156.002 E0.4749
                    G1 X148.714 Y156.068 E0.4813
                    G1 X147.337 Y154.691 E0.5057
                    G1 X147.165 Y154.805 E0.5083
                    G1 X147.016 Y154.936 E0.5108
                    G1 X148.281 Y156.201 E0.5332
                    G1 X147.881 Y156.366 E0.5386
                    G1 X146.715 Y155.200 E0.5593
                    G1 X146.707 Y155.207 E0.5594
                    G1 X146.450 Y155.500 E0.5643
                    G1 X147.481 Y156.532 E0.5826
                    G1 X147.199 Y156.649 E0.5865
                    G1 X147.105 Y156.721 E0.5880
                    G1 X146.202 Y155.819 E0.6040
                    G1 X145.976 Y156.158 E0.6091
                    G1 X146.785 Y156.967 E0.6234
                    G1 X146.465 Y157.213 E0.6285
                    G1 X145.787 Y156.535 E0.6405
                    G1 X145.697 Y156.718 E0.6430
                    G1 X145.623 Y156.937 E0.6459
                    G1 X146.145 Y157.458 E0.6552
                    G1 X146.039 Y157.539 E0.6569
                    G1 X145.874 Y157.754 E0.6602
                    G1 X145.487 Y157.367 E0.6671
                    G1 X145.436 Y157.623 E0.6704
                    G1 X145.393 Y157.838 F2036
                    G1 X145.629 Y158.074 F2036
                    G1 X145.383 Y158.394 F2036
                    G1 X145.352 Y158.363 F2036
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 6, Z = 1.300
                    ; inner perimeter
                    G1 Z1.300 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    ; solid layer
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    ; solid layer
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 7, Z = 1.500
                    ; inner perimeter
                    G1 X146.244 Y136.088 F4800
                    G1 Z1.500 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X146.035 Y135.850 E0.0040 F582
                    G1 X146.183 Y135.683 E0.0068
                    G1 X146.714 Y135.217 E0.0156
                    G1 X147.301 Y134.825 E0.0245
                    G1 X147.934 Y134.512 E0.0333
                    G1 X148.603 Y134.285 E0.0422
                    G1 X149.295 Y134.147 E0.0510
                    G1 X150.000 Y134.101 E0.0599
                    G1 X150.705 Y134.147 E0.0687
                    G1 X151.397 Y134.285 E0.0776
                    G1 X152.066 Y134.512 E0.0865
                    G1 X152.699 Y134.825 E0.0953
                    G1 X153.287 Y135.217 E0.1042
                    G1 X153.817 Y135.683 E0.1130
                    G1 X153.965 Y135.850 E0.1158
                    G1 X153.756 Y136.088 E0.1198
                    G1 X153.301 Y135.783 E0.1267
                    G1 X152.526 Y135.401 E0.1375
                    G1 X151.709 Y135.124 E0.1483
                    G1 X150.862 Y134.955 E0.1591
                    G1 X150.000 Y134.899 E0.1700
                    G1 X149.138 Y134.955 E0.1808
                    G1 X148.291 Y135.124 E0.1916
                    G1 X147.474 Y135.401 E0.2025
                    G1 X147.105 Y135.583 E0.2076
                    G1 X146.699 Y135.783 F582
                    G1 X146.244 Y136.088 F582
                    ; outer perimeter
                    G1 X146.225 Y136.581 F4800
                    G92 E0
                    G1 X145.616 Y137.116 E0.0102 F388
                    G1 X145.081 Y137.725 E0.0203
                    G1 X144.630 Y138.400 E0.0305
                    G1 X144.272 Y139.127 E0.0407
                    G1 X144.214 Y139.298 E0.0429
                    G1 X144.250 Y138.743 E0.0499
                    G1 X144.398 Y137.999 E0.0594
                    G1 X144.642 Y137.281 E0.0689
                    G1 X144.977 Y136.600 E0.0785
                    G1 X145.399 Y135.969 E0.0880
                    G1 X145.899 Y135.399 E0.0975
                    G1 X146.469 Y134.899 E0.1070
                    G1 X147.100 Y134.477 E0.1165
                    G1 X147.781 Y134.142 E0.1260
                    G1 X148.499 Y133.898 E0.1355
                    G1 X149.243 Y133.750 E0.1450
                    G1 X150.000 Y133.700 E0.1546
                    G1 X150.757 Y133.750 E0.1641
                    G1 X151.501 Y133.898 E0.1736
                    G1 X152.219 Y134.142 E0.1831
                    G1 X152.900 Y134.477 E0.1926
                    G1 X153.531 Y134.899 E0.2021
                    G1 X154.101 Y135.399 E0.2116
                    G1 X154.601 Y135.969 E0.2212
                    G1 X155.023 Y136.600 E0.2307
                    G1 X155.358 Y137.281 E0.2402
                    G1 X155.602 Y137.999 E0.2497
                    G1 X155.750 Y138.743 E0.2592
                    G1 X155.786 Y139.298 E0.2662
                    G1 X155.728 Y139.127 E0.2684
                    G1 X155.370 Y138.400 E0.2786
                    G1 X154.919 Y137.725 E0.2888
                    G1 X154.384 Y137.116 E0.2989
                    G1 X153.775 Y136.581 E0.3091
                    G1 X153.100 Y136.130 E0.3193
                    G1 X152.373 Y135.772 E0.3295
                    G1 X151.605 Y135.511 E0.3396
                    G1 X150.809 Y135.353 E0.3498
                    G1 X150.000 Y135.300 E0.3600
                    G1 X149.191 Y135.353 E0.3701
                    G1 X148.395 Y135.511 E0.3803
                    G1 X147.627 Y135.772 E0.3905
                    G1 X147.069 Y136.047 E0.3983
                    G1 X146.900 Y136.130 F388
                    G1 X146.225 Y136.581 F388
                    ; gap fill
                    G1 X145.730 Y136.113 F4800
                    G92 E0
                    G1 X145.967 Y136.350 E0.0042 F620
                    G1 X145.665 Y136.614 E0.0092
                    G1 X145.518 Y136.467 E0.0118
                    G1 X145.495 Y136.444 F620
                    G1 X145.276 Y136.773 F620
                    G1 X145.270 Y136.785 F620
                    G1 X145.365 Y136.880 F620
                    G1 X145.101 Y137.181 F620
                    G1 X145.083 Y137.164 F620
                    G1 X148.340 Y134.763 F4800
                    G92 E0
                    G1 X148.321 Y134.744 E0.0003 F620
                    G1 X148.692 Y134.618 E0.0053
                    G1 X148.749 Y134.607 E0.0060
                    G1 X148.812 Y134.669 E0.0071
                    G1 X149.093 Y134.613 E0.0107
                    G1 X149.307 Y134.599 E0.0134
                    G1 X149.221 Y134.513 E0.0149
                    G1 X149.340 Y134.489 E0.0164
                    G1 X149.737 Y134.463 E0.0214
                    G1 X149.838 Y134.565 E0.0232
                    G1 X150.000 Y134.554 E0.0253
                    G1 X150.421 Y134.582 E0.0305
                    G1 X150.305 Y134.466 E0.0326
                    G1 X150.660 Y134.489 E0.0370
                    G1 X150.834 Y134.524 E0.0393
                    G1 X150.952 Y134.547 F620
                    G1 X151.046 Y134.641 F620
                    G1 X151.752 Y134.782 F620
                    G1 X151.733 Y134.762 F620
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 X150.705 Y153.147 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X151.397 Y153.285 E0.0089 F582
                    G1 X152.066 Y153.512 E0.0177
                    G1 X152.699 Y153.825 E0.0266
                    G1 X153.287 Y154.217 E0.0354
                    G1 X153.817 Y154.683 E0.0443
                    G1 X153.965 Y154.850 E0.0471
                    G1 X153.756 Y155.088 E0.0510
                    G1 X153.301 Y154.783 E0.0579
                    G1 X152.526 Y154.401 E0.0687
                    G1 X151.709 Y154.124 E0.0796
                    G1 X150.862 Y153.955 E0.0904
                    G1 X150.000 Y153.899 E0.1012
                    G1 X149.138 Y153.955 E0.1121
                    G1 X148.291 Y154.124 E0.1229
                    G1 X147.474 Y154.401 E0.1337
                    G1 X146.699 Y154.783 E0.1445
                    G1 X146.244 Y155.088 E0.1514
                    G1 X146.035 Y154.850 E0.1554
                    G1 X146.183 Y154.683 E0.1582
                    G1 X146.714 Y154.217 E0.1670
                    G1 X147.301 Y153.825 E0.1759
                    G1 X147.934 Y153.512 E0.1847
                    G1 X148.603 Y153.285 E0.1936
                    G1 X149.295 Y153.147 E0.2025
                    G1 X149.707 Y153.120 E0.2076
                    G1 X150.000 Y153.101 F582
                    G1 X150.705 Y153.147 F582
                    ; outer perimeter
                    G1 X150.757 Y152.750 F4800
                    G92 E0
                    G1 X151.501 Y152.898 E0.0095 F388
                    G1 X152.219 Y153.142 E0.0190
                    G1 X152.900 Y153.477 E0.0285
                    G1 X153.531 Y153.899 E0.0381
                    G1 X154.101 Y154.399 E0.0476
                    G1 X154.601 Y154.969 E0.0571
                    G1 X155.023 Y155.600 E0.0666
                    G1 X155.358 Y156.281 E0.0761
                    G1 X155.602 Y156.999 E0.0856
                    G1 X155.750 Y157.743 E0.0951
                    G1 X155.786 Y158.298 E0.1021
                    G1 X155.728 Y158.127 E0.1044
                    G1 X155.370 Y157.400 E0.1145
                    G1 X154.919 Y156.725 E0.1247
                    G1 X154.384 Y156.116 E0.1349
                    G1 X153.775 Y155.581 E0.1450
                    G1 X153.100 Y155.130 E0.1552
                    G1 X152.373 Y154.772 E0.1654
                    G1 X151.605 Y154.511 E0.1756
                    G1 X150.809 Y154.353 E0.1857
                    G1 X150.000 Y154.300 E0.1959
                    G1 X149.191 Y154.353 E0.2061
                    G1 X148.395 Y154.511 E0.2162
                    G1 X147.627 Y154.772 E0.2264
                    G1 X146.900 Y155.130 E0.2366
                    G1 X146.225 Y155.581 E0.2468
                    G1 X145.616 Y156.116 E0.2569
                    G1 X145.081 Y156.725 E0.2671
                    G1 X144.630 Y157.400 E0.2773
                    G1 X144.272 Y158.127 E0.2874
                    G1 X144.214 Y158.298 E0.2897
                    G1 X144.250 Y157.743 E0.2967
                    G1 X144.398 Y156.999 E0.3062
                    G1 X144.642 Y156.281 E0.3157
                    G1 X144.977 Y155.600 E0.3252
                    G1 X145.399 Y154.969 E0.3347
                    G1 X145.899 Y154.399 E0.3442
                    G1 X146.469 Y153.899 E0.3537
                    G1 X147.100 Y153.477 E0.3633
                    G1 X147.781 Y153.142 E0.3728
                    G1 X148.499 Y152.898 E0.3823
                    G1 X149.243 Y152.750 E0.3918
                    G1 X149.759 Y152.716 E0.3983
                    G1 X150.000 Y152.700 F388
                    G1 X150.757 Y152.750 F388
                    ; gap fill
                    G1 X151.380 Y153.643 F4800
                    G92 E0
                    G1 X151.461 Y153.724 E0.0014 F620
                    G1 X150.907 Y153.613 E0.0085
                    G1 X150.776 Y153.605 E0.0102
                    G1 X150.661 Y153.490 E0.0122
                    G1 X150.056 Y153.450 E0.0198
                    G1 X150.171 Y153.565 E0.0218
                    G1 X150.000 Y153.554 E0.0240
                    G1 X149.619 Y153.579 E0.0288
                    G1 X149.518 Y153.478 E0.0306
                    G1 X149.340 Y153.489 E0.0328
                    G1 X149.026 Y153.552 E0.0368
                    G1 X149.089 Y153.614 E0.0379
                    G1 X149.086 Y153.615 E0.0380
                    G1 X148.617 Y153.708 F620
                    G1 X148.569 Y153.660 F620
                    G1 X148.147 Y153.803 F620
                    G1 X148.151 Y153.808 F620
                    G1 X145.628 Y155.245 F4800
                    G92 E0
                    G1 X145.843 Y155.459 E0.0038 F620
                    G1 X145.766 Y155.526 E0.0051
                    G1 X145.541 Y155.723 F620
                    G1 X145.402 Y155.584 F620
                    G1 X145.276 Y155.773 F620
                    G1 X145.193 Y155.941 F620
                    G1 X145.256 Y156.004 F620
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 X154.094 Y155.225 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X154.097 Y155.229 E0.0001 F620
                    G1 X154.805 Y155.936 F620
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 8, Z = 1.700
                    ; inner perimeter
                    G1 X153.757 Y155.088 F4800
                    G1 Z1.700 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X153.301 Y154.783 E0.0069 F582
                    G1 X152.526 Y154.401 E0.0177
                    G1 X151.709 Y154.124 E0.0285
                    G1 X150.862 Y153.955 E0.0394
                    G1 X150.000 Y153.899 E0.0502
                    G1 X149.138 Y153.955 E0.0610
                    G1 X148.291 Y154.124 E0.0718
                    G1 X147.474 Y154.401 E0.0827
                    G1 X146.699 Y154.783 E0.0935
                    G1 X146.244 Y155.088 E0.1004
                    G1 X146.035 Y154.850 E0.1043
                    G1 X146.183 Y154.683 E0.1071
                    G1 X146.714 Y154.217 E0.1160
                    G1 X147.301 Y153.825 E0.1248
                    G1 X147.934 Y153.512 E0.1337
                    G1 X148.603 Y153.285 E0.1426
                    G1 X149.295 Y153.147 E0.1514
                    G1 X150.000 Y153.101 E0.1603
                    G1 X150.705 Y153.147 E0.1691
                    G1 X151.397 Y153.285 E0.1780
                    G1 X152.066 Y153.512 E0.1868
                    G1 X152.699 Y153.825 E0.1957
                    G1 X153.287 Y154.217 E0.2045
                    G1 X153.471 Y154.379 E0.2076
                    G1 X153.817 Y154.683 F582
                    G1 X153.965 Y154.850 F582
                    G1 X153.756 Y155.088 F582
                    ; outer perimeter
                    G1 X153.775 Y155.581 F4800
                    G92 E0
                    G1 X153.100 Y155.130 E0.0102 F388
                    G1 X152.373 Y154.772 E0.0203
                    G1 X151.605 Y154.511 E0.0305
                    G1 X150.809 Y154.353 E0.0407
                    G1 X150.000 Y154.300 E0.0509
                    G1 X149.191 Y154.353 E0.0610
                    G1 X148.395 Y154.511 E0.0712
                    G1 X147.627 Y154.772 E0.0814
                    G1 X146.900 Y155.130 E0.0915
                    G1 X146.225 Y155.581 E0.1017
                    G1 X145.616 Y156.116 E0.1119
                    G1 X145.081 Y156.725 E0.1221
                    G1 X144.630 Y157.400 E0.1322
                    G1 X144.272 Y158.127 E0.1424
                    G1 X144.214 Y158.298 E0.1447
                    G1 X144.250 Y157.743 E0.1516
                    G1 X144.398 Y156.999 E0.1611
                    G1 X144.642 Y156.281 E0.1706
                    G1 X144.977 Y155.600 E0.1802
                    G1 X145.399 Y154.969 E0.1897
                    G1 X145.899 Y154.399 E0.1992
                    G1 X146.469 Y153.899 E0.2087
                    G1 X147.100 Y153.477 E0.2182
                    G1 X147.781 Y153.142 E0.2277
                    G1 X148.499 Y152.898 E0.2372
                    G1 X149.243 Y152.750 E0.2468
                    G1 X150.000 Y152.700 E0.2563
                    G1 X150.757 Y152.750 E0.2658
                    G1 X151.501 Y152.898 E0.2753
                    G1 X152.219 Y153.142 E0.2848
                    G1 X152.900 Y153.477 E0.2943
                    G1 X153.531 Y153.899 E0.3038
                    G1 X154.101 Y154.399 E0.3134
                    G1 X154.601 Y154.969 E0.3229
                    G1 X155.023 Y155.600 E0.3324
                    G1 X155.358 Y156.281 E0.3419
                    G1 X155.602 Y156.999 E0.3514
                    G1 X155.750 Y157.743 E0.3609
                    G1 X155.786 Y158.298 E0.3679
                    G1 X155.728 Y158.127 E0.3701
                    G1 X155.370 Y157.400 E0.3803
                    G1 X154.919 Y156.725 E0.3905
                    G1 X154.509 Y156.258 E0.3983
                    G1 X154.384 Y156.116 F388
                    G1 X153.775 Y155.581 F388
                    ; gap fill
                    G1 X154.158 Y155.459 F4800
                    G92 E0
                    G1 X154.372 Y155.245 E0.0038 F621
                    G1 X154.424 Y155.324 E0.0050
                    G1 X154.598 Y155.584 F621
                    G1 X154.459 Y155.723 F621
                    G1 X154.628 Y155.872 F621
                    G1 X154.744 Y156.004 F621
                    G1 X154.807 Y155.941 F621
                    G1 X151.854 Y153.803 F4800
                    G92 E0
                    G1 X151.849 Y153.808 E0.0001 F621
                    G1 X151.798 Y153.791 E0.0008
                    G1 X151.383 Y153.708 E0.0061
                    G1 X151.431 Y153.660 E0.0069
                    G1 X151.308 Y153.618 E0.0085
                    G1 X150.974 Y153.552 E0.0128
                    G1 X150.911 Y153.614 E0.0139
                    G1 X150.907 Y153.613 E0.0140
                    G1 X150.381 Y153.579 E0.0206
                    G1 X150.482 Y153.478 E0.0224
                    G1 X150.000 Y153.446 E0.0285
                    G1 X149.944 Y153.450 E0.0292
                    G1 X149.829 Y153.565 E0.0312
                    G1 X149.224 Y153.605 E0.0388
                    G1 X149.233 Y153.596 E0.0390
                    G1 X149.339 Y153.490 F621
                    G1 X148.692 Y153.618 F621
                    G1 X148.620 Y153.643 F621
                    G1 X148.539 Y153.724 F621
                    G1 X145.906 Y155.225 F4800
                    G92 E0
                    G1 X145.903 Y155.229 E0.0001 F621
                    G1 X145.195 Y155.936 F621
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G1 X148.248 Y134.782 F4800
                    G92 E0
                    G1 X148.267 Y134.762 E0.0003 F621
                    G1 X148.692 Y134.618 E0.0060
                    G1 X149.048 Y134.547 E0.0105
                    G1 X148.954 Y134.641 E0.0122
                    G1 X149.093 Y134.613 E0.0140
                    G1 X149.579 Y134.582 E0.0201
                    G1 X149.695 Y134.466 E0.0221
                    G1 X150.000 Y134.446 E0.0259
                    G1 X150.263 Y134.463 E0.0293
                    G1 X150.162 Y134.565 E0.0311
                    G1 X150.693 Y134.599 E0.0377
                    G1 X150.779 Y134.513 E0.0393
                    G1 X150.855 Y134.528 E0.0402
                    G1 X151.251 Y134.607 F621
                    G1 X151.188 Y134.669 F621
                    G1 X151.660 Y134.763 F621
                    G1 X151.679 Y134.744 F621
                    G1 X154.033 Y136.350 F4800
                    G92 E0
                    G1 X154.270 Y136.113 E0.0042 F621
                    G1 X154.328 Y136.179 E0.0053
                    G1 X154.505 Y136.444 E0.0093
                    G1 X154.347 Y136.602 E0.0121
                    G1 X154.335 Y136.614 F621
                    G1 X154.628 Y136.872 F621
                    G1 X154.635 Y136.880 F621
                    G1 X154.730 Y136.785 F621
                    G1 X154.917 Y137.164 F621
                    G1 X154.899 Y137.181 F621
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 9, Z = 1.900
                    ; inner perimeter
                    G1 X153.757 Y136.088 F4800
                    G1 Z1.900 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X153.301 Y135.783 E0.0069 F582
                    G1 X152.526 Y135.401 E0.0177
                    G1 X151.709 Y135.124 E0.0285
                    G1 X150.862 Y134.955 E0.0394
                    G1 X150.000 Y134.899 E0.0502
                    G1 X149.138 Y134.955 E0.0610
                    G1 X148.291 Y135.124 E0.0718
                    G1 X147.474 Y135.401 E0.0827
                    G1 X146.699 Y135.783 E0.0935
                    G1 X146.244 Y136.088 E0.1004
                    G1 X146.035 Y135.850 E0.1043
                    G1 X146.183 Y135.683 E0.1071
                    G1 X146.714 Y135.217 E0.1160
                    G1 X147.301 Y134.825 E0.1248
                    G1 X147.934 Y134.512 E0.1337
                    G1 X148.603 Y134.285 E0.1426
                    G1 X149.295 Y134.147 E0.1514
                    G1 X150.000 Y134.101 E0.1603
                    G1 X150.705 Y134.147 E0.1691
                    G1 X151.397 Y134.285 E0.1780
                    G1 X152.066 Y134.512 E0.1868
                    G1 X152.699 Y134.825 E0.1957
                    G1 X153.287 Y135.217 E0.2045
                    G1 X153.471 Y135.379 E0.2076
                    G1 X153.817 Y135.683 F582
                    G1 X153.965 Y135.850 F582
                    G1 X153.756 Y136.088 F582
                    ; outer perimeter
                    G1 X153.775 Y136.581 F4800
                    G92 E0
                    G1 X153.100 Y136.130 E0.0102 F388
                    G1 X152.373 Y135.772 E0.0203
                    G1 X151.605 Y135.511 E0.0305
                    G1 X150.809 Y135.353 E0.0407
                    G1 X150.000 Y135.300 E0.0509
                    G1 X149.191 Y135.353 E0.0610
                    G1 X148.395 Y135.511 E0.0712
                    G1 X147.627 Y135.772 E0.0814
                    G1 X146.900 Y136.130 E0.0915
                    G1 X146.225 Y136.581 E0.1017
                    G1 X145.616 Y137.116 E0.1119
                    G1 X145.081 Y137.725 E0.1221
                    G1 X144.630 Y138.400 E0.1322
                    G1 X144.272 Y139.127 E0.1424
                    G1 X144.214 Y139.298 E0.1447
                    G1 X144.250 Y138.743 E0.1516
                    G1 X144.398 Y137.999 E0.1611
                    G1 X144.642 Y137.281 E0.1706
                    G1 X144.977 Y136.600 E0.1802
                    G1 X145.399 Y135.969 E0.1897
                    G1 X145.899 Y135.399 E0.1992
                    G1 X146.469 Y134.899 E0.2087
                    G1 X147.100 Y134.477 E0.2182
                    G1 X147.781 Y134.142 E0.2277
                    G1 X148.499 Y133.898 E0.2372
                    G1 X149.243 Y133.750 E0.2468
                    G1 X150.000 Y133.700 E0.2563
                    G1 X150.757 Y133.750 E0.2658
                    G1 X151.501 Y133.898 E0.2753
                    G1 X152.219 Y134.142 E0.2848
                    G1 X152.900 Y134.477 E0.2943
                    G1 X153.531 Y134.899 E0.3038
                    G1 X154.101 Y135.399 E0.3134
                    G1 X154.601 Y135.969 E0.3229
                    G1 X155.023 Y136.600 E0.3324
                    G1 X155.358 Y137.281 E0.3419
                    G1 X155.602 Y137.999 E0.3514
                    G1 X155.750 Y138.743 E0.3609
                    G1 X155.786 Y139.298 E0.3679
                    G1 X155.728 Y139.127 E0.3701
                    G1 X155.370 Y138.400 E0.3803
                    G1 X154.919 Y137.725 E0.3905
                    G1 X154.509 Y137.258 E0.3983
                    G1 X154.384 Y137.116 F388
                    G1 X153.775 Y136.581 F388
                    ; gap fill
                    G1 X151.733 Y134.762 F4800
                    G92 E0
                    G1 X151.752 Y134.782 E0.0003 F620
                    G1 X151.046 Y134.641 E0.0094
                    G1 X150.952 Y134.547 E0.0110
                    G1 X150.660 Y134.489 E0.0148
                    G1 X150.305 Y134.466 E0.0192
                    G1 X150.421 Y134.582 E0.0213
                    G1 X150.000 Y134.554 E0.0266
                    G1 X149.838 Y134.565 E0.0286
                    G1 X149.737 Y134.463 E0.0304
                    G1 X149.340 Y134.489 E0.0354
                    G1 X149.221 Y134.513 E0.0369
                    G1 X149.307 Y134.599 E0.0384
                    G1 X149.240 Y134.604 E0.0393
                    G1 X149.093 Y134.613 F620
                    G1 X148.812 Y134.669 F620
                    G1 X148.749 Y134.607 F620
                    G1 X148.692 Y134.618 F620
                    G1 X148.321 Y134.744 F620
                    G1 X148.340 Y134.763 F620
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 X148.603 Y153.285 F4800
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X149.295 Y153.147 E0.0089 F582
                    G1 X150.000 Y153.101 E0.0177
                    G1 X150.705 Y153.147 E0.0266
                    G1 X151.397 Y153.285 E0.0354
                    G1 X152.066 Y153.512 E0.0443
                    G1 X152.699 Y153.825 E0.0531
                    G1 X153.287 Y154.217 E0.0620
                    G1 X153.817 Y154.683 E0.0708
                    G1 X153.965 Y154.850 E0.0736
                    G1 X153.756 Y155.088 E0.0776
                    G1 X153.301 Y154.783 E0.0845
                    G1 X152.526 Y154.401 E0.0953
                    G1 X151.709 Y154.124 E0.1061
                    G1 X150.862 Y153.955 E0.1170
                    G1 X150.000 Y153.899 E0.1278
                    G1 X149.138 Y153.955 E0.1386
                    G1 X148.291 Y154.124 E0.1495
                    G1 X147.474 Y154.401 E0.1603
                    G1 X146.699 Y154.783 E0.1711
                    G1 X146.244 Y155.088 E0.1780
                    G1 X146.035 Y154.850 E0.1819
                    G1 X146.183 Y154.683 E0.1847
                    G1 X146.714 Y154.217 E0.1936
                    G1 X147.301 Y153.825 E0.2025
                    G1 X147.670 Y153.642 E0.2076
                    G1 X147.934 Y153.512 F582
                    G1 X148.603 Y153.285 F582
                    ; outer perimeter
                    G1 X148.499 Y152.898 F4800
                    G92 E0
                    G1 X149.243 Y152.750 E0.0095 F388
                    G1 X150.000 Y152.700 E0.0190
                    G1 X150.757 Y152.750 E0.0285
                    G1 X151.501 Y152.898 E0.0381
                    G1 X152.219 Y153.142 E0.0476
                    G1 X152.900 Y153.477 E0.0571
                    G1 X153.531 Y153.899 E0.0666
                    G1 X154.101 Y154.399 E0.0761
                    G1 X154.601 Y154.969 E0.0856
                    G1 X155.023 Y155.600 E0.0951
                    G1 X155.358 Y156.281 E0.1046
                    G1 X155.602 Y156.999 E0.1142
                    G1 X155.750 Y157.743 E0.1237
                    G1 X155.786 Y158.298 E0.1306
                    G1 X155.728 Y158.127 E0.1329
                    G1 X155.370 Y157.400 E0.1431
                    G1 X154.919 Y156.725 E0.1532
                    G1 X154.384 Y156.116 E0.1634
                    G1 X153.775 Y155.581 E0.1736
                    G1 X153.100 Y155.130 E0.1838
                    G1 X152.373 Y154.772 E0.1939
                    G1 X151.605 Y154.511 E0.2041
                    G1 X150.809 Y154.353 E0.2143
                    G1 X150.000 Y154.300 E0.2244
                    G1 X149.191 Y154.353 E0.2346
                    G1 X148.395 Y154.511 E0.2448
                    G1 X147.627 Y154.772 E0.2550
                    G1 X146.900 Y155.130 E0.2651
                    G1 X146.225 Y155.581 E0.2753
                    G1 X145.616 Y156.116 E0.2855
                    G1 X145.081 Y156.725 E0.2956
                    G1 X144.630 Y157.400 E0.3058
                    G1 X144.272 Y158.127 E0.3160
                    G1 X144.214 Y158.298 E0.3182
                    G1 X144.250 Y157.743 E0.3252
                    G1 X144.398 Y156.999 E0.3347
                    G1 X144.642 Y156.281 E0.3442
                    G1 X144.977 Y155.600 E0.3537
                    G1 X145.399 Y154.969 E0.3633
                    G1 X145.899 Y154.399 E0.3728
                    G1 X146.469 Y153.899 E0.3823
                    G1 X147.100 Y153.477 E0.3918
                    G1 X147.564 Y153.249 E0.3983
                    G1 X147.781 Y153.142 F388
                    G1 X148.499 Y152.898 F388
                    ; gap fill
                    G1 X148.151 Y153.808 F4800
                    G92 E0
                    G1 X148.147 Y153.803 E0.0001 F620
                    G1 X148.569 Y153.660 E0.0057
                    G1 X148.617 Y153.708 E0.0065
                    G1 X149.089 Y153.614 E0.0126
                    G1 X149.026 Y153.552 E0.0137
                    G1 X149.340 Y153.489 E0.0177
                    G1 X149.518 Y153.478 E0.0199
                    G1 X149.619 Y153.579 E0.0217
                    G1 X150.000 Y153.554 E0.0265
                    G1 X150.171 Y153.565 E0.0287
                    G1 X150.056 Y153.450 E0.0307
                    G1 X150.635 Y153.488 E0.0380
                    G1 X150.660 Y153.489 F620
                    G1 X150.776 Y153.605 F620
                    G1 X150.907 Y153.613 F620
                    G1 X151.461 Y153.724 F620
                    G1 X151.380 Y153.643 F620
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 10, Z = 2.100
                    ; inner perimeter
                    G1 X146.244 Y155.088 F4800
                    G1 Z2.100 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X146.035 Y154.850 E0.0040 F582
                    G1 X146.183 Y154.683 E0.0068
                    G1 X146.714 Y154.217 E0.0156
                    G1 X147.301 Y153.825 E0.0245
                    G1 X147.934 Y153.512 E0.0333
                    G1 X148.603 Y153.285 E0.0422
                    G1 X149.295 Y153.147 E0.0510
                    G1 X150.000 Y153.101 E0.0599
                    G1 X150.705 Y153.147 E0.0687
                    G1 X151.397 Y153.285 E0.0776
                    G1 X152.066 Y153.512 E0.0865
                    G1 X152.699 Y153.825 E0.0953
                    G1 X153.287 Y154.217 E0.1042
                    G1 X153.817 Y154.683 E0.1130
                    G1 X153.965 Y154.850 E0.1158
                    G1 X153.756 Y155.088 E0.1198
                    G1 X153.301 Y154.783 E0.1267
                    G1 X152.526 Y154.401 E0.1375
                    G1 X151.709 Y154.124 E0.1483
                    G1 X150.862 Y153.955 E0.1591
                    G1 X150.000 Y153.899 E0.1700
                    G1 X149.138 Y153.955 E0.1808
                    G1 X148.291 Y154.124 E0.1916
                    G1 X147.474 Y154.401 E0.2025
                    G1 X147.105 Y154.583 E0.2076
                    G1 X146.699 Y154.783 F582
                    G1 X146.244 Y155.088 F582
                    ; outer perimeter
                    G1 X146.225 Y155.581 F4800
                    G92 E0
                    G1 X145.616 Y156.116 E0.0102 F388
                    G1 X145.081 Y156.725 E0.0203
                    G1 X144.630 Y157.400 E0.0305
                    G1 X144.272 Y158.127 E0.0407
                    G1 X144.214 Y158.298 E0.0429
                    G1 X144.250 Y157.743 E0.0499
                    G1 X144.398 Y156.999 E0.0594
                    G1 X144.642 Y156.281 E0.0689
                    G1 X144.977 Y155.600 E0.0785
                    G1 X145.399 Y154.969 E0.0880
                    G1 X145.899 Y154.399 E0.0975
                    G1 X146.469 Y153.899 E0.1070
                    G1 X147.100 Y153.477 E0.1165
                    G1 X147.781 Y153.142 E0.1260
                    G1 X148.499 Y152.898 E0.1355
                    G1 X149.243 Y152.750 E0.1450
                    G1 X150.000 Y152.700 E0.1546
                    G1 X150.757 Y152.750 E0.1641
                    G1 X151.501 Y152.898 E0.1736
                    G1 X152.219 Y153.142 E0.1831
                    G1 X152.900 Y153.477 E0.1926
                    G1 X153.531 Y153.899 E0.2021
                    G1 X154.101 Y154.399 E0.2116
                    G1 X154.601 Y154.969 E0.2212
                    G1 X155.023 Y155.600 E0.2307
                    G1 X155.358 Y156.281 E0.2402
                    G1 X155.602 Y156.999 E0.2497
                    G1 X155.750 Y157.743 E0.2592
                    G1 X155.786 Y158.298 E0.2662
                    G1 X155.728 Y158.127 E0.2684
                    G1 X155.370 Y157.400 E0.2786
                    G1 X154.919 Y156.725 E0.2888
                    G1 X154.384 Y156.116 E0.2989
                    G1 X153.775 Y155.581 E0.3091
                    G1 X153.100 Y155.130 E0.3193
                    G1 X152.373 Y154.772 E0.3295
                    G1 X151.605 Y154.511 E0.3396
                    G1 X150.809 Y154.353 E0.3498
                    G1 X150.000 Y154.300 E0.3600
                    G1 X149.191 Y154.353 E0.3701
                    G1 X148.395 Y154.511 E0.3803
                    G1 X147.627 Y154.772 E0.3905
                    G1 X147.069 Y155.047 E0.3983
                    G1 X146.900 Y155.130 F388
                    G1 X146.225 Y155.581 F388
                    ; gap fill
                    G92 E0
                    G1 X148.539 Y153.724 F4800
                    G92 E0
                    G1 X148.620 Y153.643 E0.0014 F621
                    G1 X148.692 Y153.618 E0.0024
                    G1 X149.339 Y153.490 E0.0107
                    G1 X149.224 Y153.605 E0.0127
                    G1 X149.829 Y153.565 E0.0203
                    G1 X149.944 Y153.450 E0.0224
                    G1 X150.000 Y153.446 E0.0231
                    G1 X150.482 Y153.478 E0.0291
                    G1 X150.381 Y153.579 E0.0309
                    G1 X150.907 Y153.613 E0.0375
                    G1 X150.911 Y153.614 E0.0376
                    G1 X150.974 Y153.552 E0.0387
                    G1 X150.996 Y153.556 E0.0390
                    G1 X151.308 Y153.618 F621
                    G1 X151.431 Y153.660 F621
                    G1 X151.383 Y153.708 F621
                    G1 X151.798 Y153.791 F621
                    G1 X151.849 Y153.808 F621
                    G1 X151.854 Y153.803 F621
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G1 X151.679 Y134.744 F4800
                    G92 E0
                    G1 X151.660 Y134.763 E0.0003 F621
                    G1 X151.188 Y134.669 E0.0064
                    G1 X151.251 Y134.607 E0.0075
                    G1 X150.779 Y134.513 E0.0135
                    G1 X150.693 Y134.599 E0.0150
                    G1 X150.162 Y134.565 E0.0217
                    G1 X150.263 Y134.463 E0.0235
                    G1 X150.000 Y134.446 E0.0268
                    G1 X149.695 Y134.466 E0.0307
                    G1 X149.579 Y134.582 E0.0327
                    G1 X149.093 Y134.613 E0.0388
                    G1 X148.983 Y134.635 E0.0402
                    G1 X148.954 Y134.641 F621
                    G1 X149.048 Y134.547 F621
                    G1 X148.692 Y134.618 F621
                    G1 X148.267 Y134.762 F621
                    G1 X148.248 Y134.782 F621
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 11, Z = 2.300
                    ; inner perimeter
                    G1 X148.291 Y135.124 F4800
                    G1 Z2.300 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X147.474 Y135.401 E0.0108 F582
                    G1 X146.699 Y135.783 E0.0217
                    G1 X146.244 Y136.088 E0.0285
                    G1 X146.035 Y135.850 E0.0325
                    G1 X146.183 Y135.683 E0.0353
                    G1 X146.714 Y135.217 E0.0441
                    G1 X147.301 Y134.825 E0.0530
                    G1 X147.934 Y134.512 E0.0619
                    G1 X148.603 Y134.285 E0.0707
                    G1 X149.295 Y134.147 E0.0796
                    G1 X150.000 Y134.101 E0.0884
                    G1 X150.705 Y134.147 E0.0973
                    G1 X151.397 Y134.285 E0.1061
                    G1 X152.066 Y134.512 E0.1150
                    G1 X152.699 Y134.825 E0.1238
                    G1 X153.287 Y135.217 E0.1327
                    G1 X153.817 Y135.683 E0.1416
                    G1 X153.965 Y135.850 E0.1444
                    G1 X153.756 Y136.088 E0.1483
                    G1 X153.301 Y135.783 E0.1552
                    G1 X152.526 Y135.401 E0.1660
                    G1 X151.709 Y135.124 E0.1768
                    G1 X150.862 Y134.955 E0.1877
                    G1 X150.000 Y134.899 E0.1985
                    G1 X149.275 Y134.946 E0.2076
                    G1 X149.138 Y134.955 F582
                    G1 X148.291 Y135.124 F582
                    ; outer perimeter
                    G1 X148.395 Y135.511 F4800
                    G92 E0
                    G1 X147.627 Y135.772 E0.0102 F388
                    G1 X146.900 Y136.130 E0.0203
                    G1 X146.225 Y136.581 E0.0305
                    G1 X145.616 Y137.116 E0.0407
                    G1 X145.081 Y137.725 E0.0509
                    G1 X144.630 Y138.400 E0.0610
                    G1 X144.272 Y139.127 E0.0712
                    G1 X144.214 Y139.298 E0.0735
                    G1 X144.250 Y138.743 E0.0804
                    G1 X144.398 Y137.999 E0.0899
                    G1 X144.642 Y137.281 E0.0995
                    G1 X144.977 Y136.600 E0.1090
                    G1 X145.399 Y135.969 E0.1185
                    G1 X145.899 Y135.399 E0.1280
                    G1 X146.469 Y134.899 E0.1375
                    G1 X147.100 Y134.477 E0.1470
                    G1 X147.781 Y134.142 E0.1565
                    G1 X148.499 Y133.898 E0.1660
                    G1 X149.243 Y133.750 E0.1756
                    G1 X150.000 Y133.700 E0.1851
                    G1 X150.757 Y133.750 E0.1946
                    G1 X151.501 Y133.898 E0.2041
                    G1 X152.219 Y134.142 E0.2136
                    G1 X152.900 Y134.477 E0.2231
                    G1 X153.531 Y134.899 E0.2326
                    G1 X154.101 Y135.399 E0.2422
                    G1 X154.601 Y135.969 E0.2517
                    G1 X155.023 Y136.600 E0.2612
                    G1 X155.358 Y137.281 E0.2707
                    G1 X155.602 Y137.999 E0.2802
                    G1 X155.750 Y138.743 E0.2897
                    G1 X155.786 Y139.298 E0.2967
                    G1 X155.728 Y139.127 E0.2989
                    G1 X155.370 Y138.400 E0.3091
                    G1 X154.919 Y137.725 E0.3193
                    G1 X154.384 Y137.116 E0.3295
                    G1 X153.775 Y136.581 E0.3396
                    G1 X153.100 Y136.130 E0.3498
                    G1 X152.373 Y135.772 E0.3600
                    G1 X151.605 Y135.511 E0.3701
                    G1 X150.809 Y135.353 E0.3803
                    G1 X150.000 Y135.300 E0.3905
                    G1 X149.379 Y135.340 E0.3983
                    G1 X149.191 Y135.353 F388
                    G1 X148.395 Y135.511 F388
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 12, Z = 2.500
                    ; inner perimeter
                    G1 Z2.500 F300
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 13, Z = 2.700
                    ; inner perimeter
                    G1 Z2.700 F300
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 14, Z = 2.900
                    ; inner perimeter
                    G1 Z2.900 F300
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 15, Z = 3.100
                    ; inner perimeter
                    G1 Z3.100 F300
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 16, Z = 3.300
                    ; inner perimeter
                    G1 Z3.300 F300
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 17, Z = 3.500
                    ; inner perimeter
                    G1 Z3.500 F300
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 18, Z = 3.700
                    ; inner perimeter
                    G1 Z3.700 F300
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 19, Z = 3.900
                    ; inner perimeter
                    G1 Z3.900 F300
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    G1 E0.0000 F1500
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 20, Z = 4.100
                    ; inner perimeter
                    G1 Z4.100 F300
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    ; outer perimeter
                    G92 E0
                    ; gap fill
                    G92 E0
                    G92 E0
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer 21, Z = 4.300
                    ; inner perimeter
                    G1 Z4.300 F300
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X147.474 Y135.401 E0.0108 F540
                    G1 X152.118 Y134.530 E0.1157
                    G1 X152.118 Y135.263 E0.1249
                    G1 X151.709 Y135.124 E0.1303
                    G1 X150.862 Y134.955 E0.1411
                    G1 X150.000 Y134.899 E0.1520
                    G1 X149.275 Y134.946 E0.1611
                    G1 X149.138 Y134.955 F540
                    G1 X148.291 Y135.124 F540
                    ; outer perimeter
                    G92 E0
                    G1 X147.627 Y135.772 E0.0102 F360
                    G1 X144.588 Y138.486 E0.0622
                    G1 X144.509 Y137.673 E0.0725
                    G1 X144.642 Y137.281 E0.0777
                    G1 X144.977 Y136.600 E0.0872
                    G1 X145.399 Y135.969 E0.0967
                    G1 X145.899 Y135.399 E0.1062
                    G1 X146.469 Y134.899 E0.1157
                    G1 X147.100 Y134.477 E0.1252
                    G1 X147.781 Y134.142 E0.1347
                    G1 X148.499 Y133.898 E0.1443
                    G1 X149.243 Y133.750 E0.1538
                    G1 X150.000 Y133.700 E0.1633
                    G1 X150.757 Y133.750 E0.1728
                    G1 X151.501 Y133.898 E0.1823
                    G1 X152.219 Y134.142 E0.1918
                    G1 X152.518 Y134.289 E0.1960
                    G1 X152.518 Y135.843 E0.2155
                    G1 X152.373 Y135.772 E0.2175
                    G1 X151.605 Y135.511 E0.2277
                    G1 X150.809 Y135.353 E0.2379
                    G1 X150.000 Y135.300 E0.2480
                    G1 X149.379 Y135.340 E0.2558
                    G1 X149.191 Y135.353 F360
                    G1 X148.395 Y135.511 F360
                    ; gap fill
                    G92 E0
                    G1 X148.321 Y134.744 E0.0003 F576
                    G1 X150.952 Y134.547 F576
                    G1 X151.046 Y134.641 F576
                    G1 X151.752 Y134.782 F576
                    G1 X151.733 Y134.762 F576
                    G92 E0
                    G1 X145.967 Y136.350 E0.0042 F576
                    G1 X145.495 Y136.444 F576
                    G1 X145.276 Y136.773 F576
                    G1 X145.270 Y136.785 F576
                    G1 X145.365 Y136.880 F576
                    G1 X145.101 Y137.181 F576
                    G1 X145.083 Y137.164 F576
                    G92 E0
                    G1 E-6.5000 F1500
                    ; inner perimeter
                    G1 E0.0000 F1500
                    G92 E0
                    G1 X149.295 Y153.147 E0.0089 F540
                    G1 X152.118 Y153.530 E0.0450
                    G1 X152.118 Y154.263 E0.0542
                    G1 X151.709 Y154.124 E0.0596
                    G1 X150.862 Y153.955 E0.0704
                    G1 X150.000 Y153.899 E0.0812
                    G1 X149.138 Y153.955 E0.0921
                    G1 X148.291 Y154.124 E0.1029
                    G1 X147.474 Y154.401 E0.1137
                    G1 X146.699 Y154.783 E0.1246
                    G1 X146.244 Y155.088 E0.1314
                    G1 X146.035 Y154.850 E0.1354
                    G1 X146.183 Y154.683 E0.1382
                    G1 X146.714 Y154.217 E0.1470
                    G1 X147.301 Y153.825 E0.1559
                    G1 X147.670 Y153.642 E0.1611
                    G1 X147.934 Y153.512 F540
                    G1 X148.603 Y153.285 F540
                    ; outer perimeter
                    G92 E0
                    G1 X149.243 Y152.750 E0.0095 F360
                    G1 X152.518 Y153.289 E0.0517
                    G1 X152.518 Y154.843 E0.0712
                    G1 X152.373 Y154.772 E0.0733
                    G1 X151.605 Y154.511 E0.0834
                    G1 X150.809 Y154.353 E0.0936
                    G1 X150.000 Y154.300 E0.1038
                    G1 X149.191 Y154.353 E0.1140
                    G1 X148.395 Y154.511 E0.1241
                    G1 X147.627 Y154.772 E0.1343
                    G1 X146.900 Y155.130 E0.1445
                    G1 X146.225 Y155.581 E0.1546
                    G1 X145.616 Y156.116 E0.1648
                    G1 X145.081 Y156.725 E0.1750
                    G1 X144.630 Y157.400 E0.1852
                    G1 X144.588 Y157.486 E0.1864
                    G1 X144.509 Y156.673 E0.1966
                    G1 X144.642 Y156.281 E0.2018
                    G1 X144.977 Y155.600 E0.2113
                    G1 X145.399 Y154.969 E0.2208
                    G1 X145.899 Y154.399 E0.2303
                    G1 X146.469 Y153.899 E0.2398
                    G1 X147.100 Y153.477 E0.2494
                    G1 X147.564 Y153.249 E0.2558
                    G1 X147.781 Y153.142 F360
                    G1 X148.499 Y152.898 F360
                    ; gap fill
                    G92 E0
                    G1 X148.147 Y153.803 E0.0001 F576
                    G1 X150.660 Y153.489 F576
                    G1 X150.776 Y153.605 F576
                    G1 X150.907 Y153.613 F576
                    G1 X151.461 Y153.724 F576
                    G1 X151.380 Y153.643 F576
                    G92 E0
                    G1 X145.843 Y155.459 E0.0038 F576
                    G1 X145.541 Y155.723 F576
                    G1 X145.402 Y155.584 F576
                    G1 X145.276 Y155.773 F576
                    G1 X145.193 Y155.941 F576
                    G1 X145.256 Y156.004 F576
                    G92 E0
                    G1 E-6.5000 F1500
                    ; layer end
                    M104 S0 ; turn off extruder
                    M140 S0 ; turn off bed
                    G91 ; use relative coordinates
                    G1 Z0.6 F5000 ; lift nozzle by 0.6mm
                    G90 ; use absolute coordinates
                    G1 X150  Y0 ; move Y axis to end position
                    M84 ; disable extruder
                    ;M18 ; Disable all stepper motors
                    M107 ; turn off fan
                    ; Build Summary
                    ;   Build time: 0 hours 6 minutes
                    ;   Filament length: 59.2 mm (0.06 m)
                    ;   Plastic volume: 377.62 mm^3 (0.38 cc)
                    ;   Plastic weight: 0.47 g (0.00 lb)
                    ;   Material cost: 0.02
                    Scara with DuetWifi => Scarlette3D
                    https://youtu.be/mBF5cO8vGhI
                      Thanks, it's extrusion-related then. I'll prepare a change for you to test. Is your board a Duet WiFi?
                      • frafaundefined
                        frafa
                        Yes Duet WiFI
                          Please can you try 1.19+6 at https://www.dropbox.com/s/yybmbe4jyonn2g3/DuetWiFiFirmware.bin?dl=0 and see if it is better.
                          • synergy41undefined
                            synergy41
                            Hello everyone,
                            David I have exactly the same problem on my DELTA, I have a big vibration that I did not have in 1.19 + 4.
                            I have my printer back in this version, and I have no problem.
                            Maybe the size of the print has something to have, because yesterday I tried Version 1.19 + 5 on a 10mn print and no problem.
                            The I had to launch a print of 9H.
                            I LOVE MY DUET WIFI
                            Board: Duet 2 WiFi (2WiFi)
                            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
                            Duet WiFi Server Version: 1.26
                            Duet Web Control 3.4.1
                            Cura 4.10
                            • frafaundefined
                              frafa
                              Come home, not possible to test before tomorrow afternoon at the fablab …
                                @synergy41:
                                Hello everyone,
                                Please can you try the 1.16 version too. Versions for Duet Ethernet and Duet WiFi are at https://www.dropbox.com/sh/wzb6bm1www3ewn5/AACUbv-2xHJkzV2gdThu7a5Wa?dl=0. EDIT: and now a Duet 08/085 build too.
                                  synergy41
                                  Hello everyone
                                  David I made an impression of 2h in 1.19 + 6, and apparently more problem of vibration in me.
                                  On the other hand I still had a disconnection of the card on the web, I try on 2 computers, and impossible to reconnect.
                                  I do not know if this comes from my network or update.
                                  thank you for your work
                                  I LOVE MY DUET WIFI
                                  Cura 4.10
                                    Thank for your message. Please clarify:
                                    1. Is vibration still a problem for you, or not?
                                    2. If vibration is still a problem, does it occur at any particular place in the print? For example, when printing the skirt of a print that was sliced using Simplify3D.
                                    Regarding the network disconnection:
                                    1. Did you install version 1.19+1 of the wifi module firmware (DuetWiFiServer.bin)? The Settings/General page of Duet Web Control will tell you which version of the WiFi Server you are running.
                                    2. If yes, then any reconnection attempts made will be reported to PanelDue if you have one (check the Console page) and to USB.
                                      synergy41
                                      1> I no longer have any vibration.
                                        Network
                                      1> Yes I'm fine with WiFi Server Version: 1.19 + 1
                                      2> I would look next time that this product and I would tell you.
                                      I LOVE MY DUET WIFI
                                      Cura 4.10
                                      • frafaundefined
                                        frafa
                                        apparently 1.19+6 ok for me no vibrate on my Scara, Thanks 🙂
                                        I feel that the speed is faster ?
                                          Thanks, both of you. I'll relabel 1.19+6 as 1.19.2 and release it later this afternoon.
