New test firmware 1.19+5
Installed this yesterday on one machine, printed a calibration object, looked great, but then I was not having any of the known issues with 1.19+4.
Hi
1.19+5 is unusable for me on Scara
Very slow movements x / y / z
And completely jerky
impossible download 1.19+4 link download 1.19+5 …
Please link to download downgrade 1.19+4 -
Strange, it's working well on my SCARA printer. What segments/second setting are you using, and what are your E steps/mm?
My config.g
; Configuration file for Duet WiFi (firmware version 1.17) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Tue Jul 04 2017 23:08:34 GMT+0200 ; General preferences M111 S0 ; S0 Debugging off S1 ; Debugging on G21 ; Work in millimetres G90 ; Send absolute coordinates... ;M83 ; Set extruder to relative mode M82 ; Set extruder to absolute mode (Default: Simplify3d - Cura - Slic3r) M555 P2 ; Set firmware compatibility to look like Marlin M208 X300 Y300 Z385 ; set axis maxima (adjust to suit your machine) M208 X0 Y0 Z0 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed) ; Endstops M574 X1 S0 ; Define (P) active low microswitches M574 y2 S0 ; Define (D) active high microswitches M574 Z0 S0 ; Define (Z) active low and unused microswitches ; Z probe M558 P1 I0 X0 Y0 Z1 G31 Z1.2 P500 ; ; probe points for bed levelling (M557 Utilisé par G29) (ou utiliser G32 qui execute le fichier bed.g) ; https://duet3d.com/wiki/Using_mesh_bed_compensation M557 X20:260 Y20:260 S30 ; probe from X=20 to 290, Y=20 to 290mm with a mesh spacing of 20mm (Utilisé par G29) ;M558: Set Z probe type ; Pnnn Z probe type ; Xnnn If nonzero, use probe for homing X axis ; Ynnn If nonzero, use probe for homing Y axis ; Znnn If nonzero, use probe for homing Z axis ; Fnnn Feed rate (i.e. probing speed, mm/min) ; Hnnn Dive height (mm) ; Innn Invert (I1) or do not invert (I0) the Z probe reading (RepRapFirmware 1.16 and later) ; Rnnn Z probe recovery time after triggering, default zero (seconds) (RepRapFirmware 1.17 and later)1 ; Tnnn Travel speed to and between probe points (mm/min) ; Snnn Extra parameter for experimentation ; Drives - Axis and motor configuration M569 P0 S0 ; Drive 0 (X) goes forwards M569 P1 S1 ; Drive 1 (Y) goes forwards M569 P2 S1 ; Drive 2 (Z) goes forwards M569 P3 S0 ; Drive 3 (E0) goes forwards M350 X256 Y256 Z16 E16 I1 ; Configure 256 microstepping with interpolation ;Calcul Step/mm X/Y (Réduction 80/16) ==> 400*256*(160/16)/360=2844,4444444444444444444444444444 ;Calcul Step/mm Z (Réduction 51/1) ==> 200*256*51/2.0/20=6528 M92 X2844.4444444444444444444444444444 Y2844.4444444444444444444444444444 Z4080 E475 ; Set steps per mm (extruder -debit = plus petite valeur) M566 X300 Y300 Z15 E120 ; Set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z300 E1200 ; Set maximum speeds (mm/min) M201 X600 Y600 Z250 E250 ; Set accelerations (mm/s^2) M906 X1400 Y1400 Z1400 E1000 I60 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ;M669: Set kinematics type and kinematics parameters ;https://duet3d.com/wiki/G-code#M669:_Set_kinematics_type_and_kinematics_parameters M669 K4 P200 D200 A-116:175 B-175:140 1:0:0 S120 T0.2 X64.2 Y-150.0; set SCARA kinematics parameters ok S200 ;old 116/140 ;Snnn Segments per second if smooth XY motion is approximated by means of segmentation ;Tnnn Minimum segment length (mm) if smooth XY motion is approximated by means of segmentation ; Heaters Buse & Bed M143 S260 ; Set maximum heater temperature to 260C M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0 M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1 ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Network M550 PScara ; Set machine name M552 S1 ; Enable network ; Access point is configured manually via M587 by the user M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Fans M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S0.3 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P2 S0.3 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Custom settings are not configured
I found a 1.19 + 4 all is ok with him without changing anything
I'd like to get this sorted before the 1.19.2 release if possible, but there isn't much time. Please can you test 1.19+5 with a long straight non-extruding move, and a long straight move with extrusion. I am interested in whether both types of move are jerky, or just one of them. Also please test whether both fast and slow moves have the problem.
reinstall 1.19+5 move without extrude ok is linear
extrude very vibrate unusable …
It's really horrible kind of (parkinson's disease)the gcode file tested
; G-Code generated by Simplify3D(R) Version 4.0.0 ; Aug 26, 2017 at 1:19:37 AM ; Settings Summary ; processName,Process1 ; applyToModels,clips-e3d,clips-e3d(2) ; profileName,Scara Bracelets ; profileVersion,2017-08-22 21:23:10 ; baseProfile,Default ; printMaterial,PLA ; printQuality,Medium ; printExtruders, ; extruderName,Extruder 1 ; extruderToolheadNumber,0 ; extruderDiameter,0.4 ; extruderAutoWidth,0 ; extruderWidth,0.4 ; extrusionMultiplier,1 ; extruderUseRetract,1 ; extruderRetractionDistance,6.5 ; extruderExtraRestartDistance,0 ; extruderRetractionZLift,0 ; extruderRetractionSpeed,1500 ; extruderUseCoasting,1 ; extruderCoastingDistance,1 ; extruderUseWipe,0 ; extruderWipeDistance,5 ; primaryExtruder,0 ; layerHeight,0.2 ; topSolidLayers,3 ; bottomSolidLayers,3 ; perimeterOutlines,3 ; printPerimetersInsideOut,1 ; startPointOption,2 ; startPointOriginX,0 ; startPointOriginY,0 ; sequentialIslands,0 ; spiralVaseMode,0 ; firstLayerHeightPercentage,150 ; firstLayerWidthPercentage,100 ; firstLayerUnderspeed,0.5 ; useRaft,0 ; raftExtruder,0 ; raftTopLayers,3 ; raftBaseLayers,2 ; raftOffset,3 ; raftSeparationDistance,0.14 ; raftTopInfill,100 ; aboveRaftSpeedMultiplier,0.3 ; useSkirt,1 ; skirtExtruder,0 ; skirtLayers,1 ; skirtOutlines,3 ; skirtOffset,6 ; usePrimePillar,0 ; primePillarExtruder,999 ; primePillarWidth,12 ; primePillarLocation,7 ; primePillarSpeedMultiplier,1 ; useOozeShield,0 ; oozeShieldExtruder,999 ; oozeShieldOffset,2 ; oozeShieldOutlines,1 ; oozeShieldSidewallShape,1 ; oozeShieldSidewallAngle,30 ; oozeShieldSpeedMultiplier,1 ; infillExtruder,0 ; internalInfillPattern,Rectilinear ; externalInfillPattern,Rectilinear ; infillPercentage,32 ; outlineOverlapPercentage,15 ; infillExtrusionWidthPercentage,100 ; minInfillLength,5 ; infillLayerInterval,1 ; internalInfillAngles,45,-45 ; overlapInternalInfillAngles,0 ; externalInfillAngles,45,-45 ; generateSupport,0 ; supportExtruder,0 ; supportInfillPercentage,30 ; supportExtraInflation,0 ; supportBaseLayers,0 ; denseSupportExtruder,0 ; denseSupportLayers,0 ; denseSupportInfillPercentage,70 ; supportLayerInterval,1 ; supportHorizontalPartOffset,0.3 ; supportUpperSeparationLayers,1 ; supportLowerSeparationLayers,1 ; supportType,1 ; supportGridSpacing,4 ; maxOverhangAngle,45 ; supportAngles,0 ; temperatureName,Extruder 1,Heated Bed ; temperatureNumber,0,1 ; temperatureSetpointCount,1,1 ; temperatureSetpointLayers,1,1 ; temperatureSetpointTemperatures,210,60 ; temperatureStabilizeAtStartup,1,1 ; temperatureHeatedBed,0,1 ; temperatureRelayBetweenLayers,0,0 ; temperatureRelayBetweenLoops,0,0 ; fanLayers,1,2 ; fanSpeeds,0,100 ; blipFanToFullPower,0 ; adjustSpeedForCooling,1 ; minSpeedLayerTime,15 ; minCoolingSpeedSlowdown,20 ; increaseFanForCooling,0 ; minFanLayerTime,45 ; maxCoolingFanSpeed,100 ; increaseFanForBridging,0 ; bridgingFanSpeed,100 ; use5D,1 ; relativeEdistances,0 ; allowEaxisZeroing,1 ; independentExtruderAxes,0 ; includeM10123,0 ; stickySupport,1 ; applyToolheadOffsets,0 ; gcodeXoffset,0 ; gcodeYoffset,0 ; gcodeZoffset,0 ; overrideMachineDefinition,1 ; machineTypeOverride,0 ; strokeXoverride,300 ; strokeYoverride,300 ; strokeZoverride,400 ; originOffsetXoverride,0 ; originOffsetYoverride,0 ; originOffsetZoverride,0 ; homeXdirOverride,-1 ; homeYdirOverride,-1 ; homeZdirOverride,-1 ; flipXoverride,1 ; flipYoverride,-1 ; flipZoverride,1 ; toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0 ; overrideFirmwareConfiguration,1 ; firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter) ; GPXconfigOverride,r2 ; baudRateOverride,115200 ; overridePrinterModels,0 ; printerModelsOverride ; startingGcode,M106 P0 S0 ;Fan Off,M106 P1 S0 ;Fan Off,M106 P2 S0 ;Fan Off,G28 ; home all axes,G92 E0 ; zero the extruded length,G1 Z10 ; lower,G1 E10 F200 ; purge nozzle quickly,G1 E15 F60 ; purge nozzle slowly,G92 E0 ; zero the extruded length again,G1 E-5.5 F400 ; retract,G1 Y100 Z0 F9000 ; pull away filament,G1 Y100 F9000 ; wipe,G1 X20 F9000 ; wipe,G1 E0 ; feed filament back ; layerChangeGcode, ; retractionGcode, ; toolChangeGcode, ; endingGcode,M104 S0 ; turn off extruder,M140 S0 ; turn off bed,G91 ; use relative coordinates,G1 Z0.6 F5000 ; lift nozzle by 0.6mm,G90 ; use absolute coordinates,G1 X150 Y0 ; move Y axis to end position,M84 ; disable extruder,;M18 ; Disable all stepper motors,M107 ; turn off fan ; exportFileFormat,gcode ; celebration,0 ; celebrationSong,Random Song ; postProcessing, ; defaultSpeed,3600 ; outlineUnderspeed,0.5 ; solidInfillUnderspeed,0.8 ; supportUnderspeed,0.8 ; rapidXYspeed,4800 ; rapidZspeed,300 ; minBridgingArea,50 ; bridgingExtraInflation,0 ; bridgingExtrusionMultiplier,1 ; bridgingSpeedMultiplier,1 ; useFixedBridgingAngle,0 ; fixedBridgingAngle,0 ; applyBridgingToPerimeters,0 ; filamentDiameters,2.85|2.85|2.85|2.85|2.85|2.85 ; filamentPricesPerKg,46|46|46|46|46|46 ; filamentDensities,1.25|1.25|1.25|1.25|1.25|1.25 ; useMinPrintHeight,0 ; minPrintHeight,0 ; useMaxPrintHeight,0 ; maxPrintHeight,0 ; useDiaphragm,0 ; diaphragmLayerInterval,20 ; robustSlicing,1 ; mergeAllIntoSolid,0 ; onlyRetractWhenCrossingOutline,1 ; retractBetweenLayers,1 ; useRetractionMinTravel,0 ; retractionMinTravel,3 ; retractWhileWiping,0 ; onlyWipeOutlines,1 ; avoidCrossingOutline,0 ; maxMovementDetourFactor,3 ; toolChangeRetractionDistance,12 ; toolChangeExtraRestartDistance,-0.5 ; toolChangeRetractionSpeed,600 ; externalThinWallType,0 ; internalThinWallType,2 ; thinWallAllowedOverlapPercentage,10 ; singleExtrusionMinLength,1 ; singleExtrusionMinPrintingWidthPercentage,50 ; singleExtrusionMaxPrintingWidthPercentage,200 ; singleExtrusionEndpointExtension,0.2 ; horizontalSizeCompensation,0 G90 M82 M106 S0 M140 S60 M190 S60 M104 S210 T0 M109 S210 T0 M106 P0 S0 ;Fan Off M106 P1 S0 ;Fan Off M106 P2 S0 ;Fan Off G28 ; home all axes G92 E0 ; zero the extruded length G1 Z10 ; lower G1 E10 F200 ; purge nozzle quickly G1 E15 F60 ; purge nozzle slowly G92 E0 ; zero the extruded length again G1 E-5.5 F400 ; retract G1 Y100 Z0 F9000 ; pull away filament G1 Y100 F9000 ; wipe G1 X20 F9000 ; wipe G1 E0 ; feed filament back G92 E0 G1 E-6.5000 F1500 G1 Z0.300 F300 ; process Process1 ; layer 1, Z = 0.300 T0 ; tool H0.300 W0.400 ; skirt G1 X140.635 Y130.482 F4800 G1 E0.0000 F450 G92 E0 G1 X140.657 Y130.458 E0.0006 F1800 G1 X140.958 Y130.157 E0.0086 G1 X140.982 Y130.135 E0.0092 G1 X141.892 Y129.337 E0.0320 G1 X141.917 Y129.316 E0.0326 G1 X142.255 Y129.057 E0.0406 G1 X142.281 Y129.038 E0.0412 G1 X143.288 Y128.365 E0.0640 G1 X143.316 Y128.348 E0.0646 G1 X143.684 Y128.135 E0.0726 G1 X143.713 Y128.120 E0.0732 G1 X144.799 Y127.584 E0.0960 G1 X144.829 Y127.571 E0.0966 G1 X145.222 Y127.408 E0.1046 G1 X145.252 Y127.397 E0.1053 G1 X146.399 Y127.007 E0.1280 G1 X146.430 Y126.998 E0.1286 G1 X146.841 Y126.888 E0.1366 G1 X146.873 Y126.880 E0.1373 G1 X148.060 Y126.644 E0.1600 G1 X148.092 Y126.639 E0.1606 G1 X148.514 Y126.583 E0.1686 G1 X148.547 Y126.580 E0.1693 G1 X149.755 Y126.501 E0.1920 G1 X149.787 Y126.500 E0.1926 G1 X150.213 Y126.500 E0.2007 G1 X150.245 Y126.501 E0.2013 G1 X151.453 Y126.580 E0.2240 G1 X151.486 Y126.583 E0.2247 G1 X151.908 Y126.639 E0.2327 G1 X151.940 Y126.644 E0.2333 G1 X153.127 Y126.880 E0.2560 G1 X153.159 Y126.888 E0.2567 G1 X153.570 Y126.998 E0.2647 G1 X153.601 Y127.007 E0.2653 G1 X154.748 Y127.397 E0.2880 G1 X154.778 Y127.408 E0.2887 G1 X155.172 Y127.571 E0.2967 G1 X155.201 Y127.585 E0.2973 G1 X156.287 Y128.120 E0.3201 G1 X156.316 Y128.135 E0.3207 G1 X156.684 Y128.348 E0.3287 G1 X156.712 Y128.365 E0.3293 G1 X157.718 Y129.038 E0.3521 G1 X157.745 Y129.057 E0.3527 G1 X158.083 Y129.316 E0.3607 G1 X158.108 Y129.337 E0.3613 G1 X159.018 Y130.135 E0.3841 G1 X159.042 Y130.157 E0.3847 G1 X159.343 Y130.458 E0.3927 G1 X159.365 Y130.482 E0.3933 G1 X160.163 Y131.392 E0.4161 G1 X160.184 Y131.417 E0.4167 G1 X160.443 Y131.755 E0.4247 G1 X160.462 Y131.782 E0.4253 G1 X161.135 Y132.788 E0.4481 G1 X161.152 Y132.816 E0.4487 G1 X161.365 Y133.184 E0.4567 G1 X161.380 Y133.213 E0.4573 G1 X161.915 Y134.299 E0.4801 G1 X161.929 Y134.329 E0.4807 G1 X162.092 Y134.722 E0.4887 G1 X162.103 Y134.752 E0.4893 G1 X162.492 Y135.898 E0.5121 G1 X162.502 Y135.930 E0.5127 G1 X162.612 Y136.341 E0.5207 G1 X162.620 Y136.373 E0.5213 G1 X162.856 Y137.560 E0.5441 G1 X162.861 Y137.592 E0.5447 G1 X162.917 Y138.014 E0.5527 G1 X162.920 Y138.047 E0.5533 G1 X162.992 Y139.148 E0.5741 G1 X162.993 Y139.164 E0.5744 G1 X163.000 Y139.377 E0.5784 G1 X163.000 Y139.394 E0.5787 G1 X163.000 Y144.606 E0.6768 G1 X163.000 Y144.623 E0.6771 G1 X162.993 Y144.835 E0.6811 G1 X162.992 Y144.851 E0.6814 G1 X162.946 Y145.561 E0.6947 G1 X162.942 Y145.593 E0.6954 G1 X162.887 Y146.016 E0.7034 G1 X162.881 Y146.048 E0.7040 G1 X162.722 Y146.850 E0.7194 G1 X162.714 Y146.882 E0.7200 G1 X162.604 Y147.293 E0.7280 G1 X162.595 Y147.324 E0.7286 G1 X162.332 Y148.097 E0.7440 G1 X162.321 Y148.128 E0.7446 G1 X162.158 Y148.521 E0.7526 G1 X162.144 Y148.551 E0.7532 G1 X161.783 Y149.284 E0.7686 G1 X161.768 Y149.313 E0.7692 G1 X161.555 Y149.682 E0.7772 G1 X161.537 Y149.709 E0.7778 G1 X161.083 Y150.389 E0.7932 G1 X161.064 Y150.416 E0.7938 G1 X160.805 Y150.753 E0.8018 G1 X160.784 Y150.779 E0.8024 G1 X160.600 Y150.988 E0.8077 G1 X161.135 Y151.788 E0.8258 G1 X161.152 Y151.816 E0.8264 G1 X161.365 Y152.184 E0.8344 G1 X161.380 Y152.213 E0.8350 G1 X161.915 Y153.299 E0.8578 G1 X161.929 Y153.329 E0.8584 G1 X162.092 Y153.722 E0.8664 G1 X162.103 Y153.752 E0.8670 G1 X162.492 Y154.898 E0.8898 G1 X162.502 Y154.930 E0.8904 G1 X162.612 Y155.341 E0.8984 G1 X162.620 Y155.373 E0.8990 G1 X162.856 Y156.560 E0.9218 G1 X162.861 Y156.592 E0.9224 G1 X162.917 Y157.014 E0.9304 G1 X162.920 Y157.047 E0.9310 G1 X162.992 Y158.148 E0.9518 G1 X162.993 Y158.164 E0.9521 G1 X163.000 Y158.377 E0.9561 G1 X163.000 Y158.394 E0.9564 G1 X163.000 Y163.606 E1.0544 G1 X163.000 Y163.623 E1.0548 G1 X162.993 Y163.835 E1.0588 G1 X162.992 Y163.851 E1.0591 G1 X162.946 Y164.561 E1.0724 G1 X162.942 Y164.593 E1.0731 G1 X162.887 Y165.016 E1.0811 G1 X162.881 Y165.048 E1.0817 G1 X162.722 Y165.850 E1.0971 G1 X162.714 Y165.882 E1.0977 G1 X162.604 Y166.293 E1.1057 G1 X162.595 Y166.324 E1.1063 G1 X162.332 Y167.097 E1.1217 G1 X162.321 Y167.128 E1.1223 G1 X162.158 Y167.521 E1.1303 G1 X162.144 Y167.551 E1.1309 G1 X161.783 Y168.284 E1.1463 G1 X161.768 Y168.313 E1.1469 G1 X161.555 Y168.682 E1.1549 G1 X161.537 Y168.709 E1.1555 G1 X161.083 Y169.389 E1.1709 G1 X161.064 Y169.416 E1.1715 G1 X160.805 Y169.753 E1.1795 G1 X160.784 Y169.779 E1.1801 G1 X160.245 Y170.393 E1.1955 G1 X160.223 Y170.417 E1.1961 G1 X159.922 Y170.718 E1.2041 G1 X159.898 Y170.740 E1.2047 G1 X159.284 Y171.279 E1.2201 G1 X159.259 Y171.300 E1.2207 G1 X158.921 Y171.559 E1.2287 G1 X158.894 Y171.578 E1.2293 G1 X158.215 Y172.032 E1.2447 G1 X158.187 Y172.049 E1.2453 G1 X157.818 Y172.262 E1.2533 G1 X157.790 Y172.277 E1.2539 G1 X157.057 Y172.639 E1.2693 G1 X157.027 Y172.652 E1.2699 G1 X156.634 Y172.815 E1.2779 G1 X156.603 Y172.827 E1.2786 G1 X155.829 Y173.090 E1.2939 G1 X155.798 Y173.099 E1.2946 G1 X155.386 Y173.209 E1.3026 G1 X155.354 Y173.217 E1.3032 G1 X154.574 Y173.372 E1.3181 G1 X154.545 Y173.377 E1.3187 G1 X154.166 Y173.429 E1.3259 G1 X154.137 Y173.432 E1.3264 G1 X150.730 Y173.701 E1.3907 G1 X150.335 Y173.564 E1.3986 G1 X150.000 Y173.254 E1.4072 G1 X149.665 Y173.564 E1.4158 G1 X149.270 Y173.701 E1.4236 G1 X145.863 Y173.432 E1.4879 G1 X145.834 Y173.429 E1.4885 G1 X145.455 Y173.377 E1.4957 G1 X145.426 Y173.372 E1.4962 G1 X144.646 Y173.217 E1.5112 G1 X144.614 Y173.209 E1.5118 G1 X144.202 Y173.099 E1.5198 G1 X144.171 Y173.090 E1.5204 G1 X143.397 Y172.827 E1.5358 G1 X143.366 Y172.815 E1.5364 G1 X142.973 Y172.652 E1.5444 G1 X142.943 Y172.639 E1.5450 G1 X142.210 Y172.277 E1.5604 G1 X142.182 Y172.262 E1.5610 G1 X141.813 Y172.049 E1.5690 G1 X141.786 Y172.032 E1.5696 G1 X141.106 Y171.578 E1.5850 G1 X141.079 Y171.559 E1.5856 G1 X140.741 Y171.300 E1.5936 G1 X140.716 Y171.279 E1.5942 G1 X140.102 Y170.740 E1.6096 G1 X140.078 Y170.718 E1.6102 G1 X139.777 Y170.417 E1.6182 G1 X139.755 Y170.393 E1.6189 G1 X139.216 Y169.779 E1.6342 G1 X139.195 Y169.753 E1.6348 G1 X138.936 Y169.416 E1.6428 G1 X138.917 Y169.389 E1.6435 G1 X138.463 Y168.710 E1.6588 G1 X138.446 Y168.682 E1.6595 G1 X138.233 Y168.313 E1.6675 G1 X138.217 Y168.284 E1.6681 G1 X137.856 Y167.551 E1.6835 G1 X137.842 Y167.522 E1.6841 G1 X137.679 Y167.128 E1.6921 G1 X137.668 Y167.098 E1.6927 G1 X137.405 Y166.324 E1.7081 G1 X137.396 Y166.292 E1.7087 G1 X137.285 Y165.881 E1.7167 G1 X137.278 Y165.849 E1.7173 G1 X137.119 Y165.048 E1.7327 G1 X137.113 Y165.016 E1.7333 G1 X137.058 Y164.594 E1.7413 G1 X137.055 Y164.561 E1.7419 G1 X137.008 Y163.852 E1.7553 G1 X137.007 Y163.835 E1.7556 G1 X137.000 Y163.623 E1.7596 G1 X137.000 Y163.606 E1.7599 G1 X137.000 Y158.394 E1.8580 G1 X137.000 Y158.377 E1.8583 G1 X137.007 Y158.165 E1.8623 G1 X137.008 Y158.148 E1.8626 G1 X137.080 Y157.047 E1.8833 G1 X137.083 Y157.014 E1.8840 G1 X137.139 Y156.592 E1.8920 G1 X137.144 Y156.560 E1.8926 G1 X137.380 Y155.373 E1.9153 G1 X137.388 Y155.341 E1.9160 G1 X137.498 Y154.930 E1.9240 G1 X137.507 Y154.899 E1.9246 G1 X137.897 Y153.752 E1.9473 G1 X137.908 Y153.722 E1.9480 G1 X138.071 Y153.328 E1.9560 G1 X138.085 Y153.298 E1.9566 G1 X138.620 Y152.213 E1.9794 G1 X138.636 Y152.184 E1.9800 G1 X138.848 Y151.816 E1.9880 G1 X138.865 Y151.788 E1.9886 G1 X139.400 Y150.988 E2.0067 G1 X139.216 Y150.779 E2.0119 G1 X139.195 Y150.753 E2.0125 G1 X138.936 Y150.416 E2.0205 G1 X138.917 Y150.389 E2.0212 G1 X138.463 Y149.710 E2.0365 G1 X138.446 Y149.682 E2.0371 G1 X138.233 Y149.313 E2.0452 G1 X138.217 Y149.284 E2.0458 G1 X137.856 Y148.551 E2.0611 G1 X137.842 Y148.522 E2.0618 G1 X137.679 Y148.128 E2.0698 G1 X137.668 Y148.098 E2.0704 G1 X137.405 Y147.324 E2.0858 G1 X137.396 Y147.292 E2.0864 G1 X137.285 Y146.881 E2.0944 G1 X137.278 Y146.849 E2.0950 G1 X137.119 Y146.048 E2.1104 G1 X137.113 Y146.016 E2.1110 G1 X137.058 Y145.594 E2.1190 G1 X137.055 Y145.561 E2.1196 G1 X137.008 Y144.852 E2.1330 G1 X137.007 Y144.835 E2.1333 G1 X137.000 Y144.623 E2.1373 G1 X137.000 Y144.606 E2.1376 G1 X137.000 Y139.394 E2.2356 G1 X137.000 Y139.377 E2.2360 G1 X137.007 Y139.165 E2.2400 G1 X137.008 Y139.148 E2.2403 G1 X137.080 Y138.047 E2.2610 G1 X137.083 Y138.014 E2.2616 G1 X137.139 Y137.592 E2.2697 G1 X137.144 Y137.560 E2.2703 G1 X137.380 Y136.373 E2.2930 G1 X137.388 Y136.341 E2.2937 G1 X137.498 Y135.930 E2.3017 G1 X137.507 Y135.899 E2.3023 G1 X137.897 Y134.752 E2.3250 G1 X137.908 Y134.722 E2.3257 G1 X138.071 Y134.328 E2.3337 G1 X138.085 Y134.298 E2.3343 G1 X138.620 Y133.213 E2.3571 G1 X138.636 Y133.184 E2.3577 G1 X138.848 Y132.816 E2.3657 G1 X138.865 Y132.788 E2.3663 G1 X139.538 Y131.782 E2.3891 G1 X139.557 Y131.755 E2.3897 G1 X139.816 Y131.417 E2.3977 G1 X139.837 Y131.392 E2.3983 G1 X139.975 Y131.234 E2.4022 G1 X140.635 Y130.482 F1800 G1 X140.931 Y130.751 F4800 G92 E0 G1 X140.945 Y130.736 E0.0004 F1800 G1 X141.236 Y130.445 E0.0081 G1 X141.251 Y130.431 E0.0085 G1 X142.151 Y129.642 E0.0310 G1 X142.166 Y129.629 E0.0314 G1 X142.493 Y129.378 E0.0391 G1 X142.509 Y129.367 E0.0395 G1 X143.505 Y128.702 E0.0620 G1 X143.521 Y128.691 E0.0624 G1 X143.879 Y128.485 E0.0702 G1 X143.896 Y128.476 E0.0705 G1 X144.970 Y127.946 E0.0931 G1 X144.988 Y127.938 E0.0934 G1 X145.369 Y127.780 E0.1012 G1 X145.387 Y127.773 E0.1016 G1 X146.521 Y127.388 E0.1241 G1 X146.540 Y127.383 E0.1245 G1 X146.938 Y127.276 E0.1322 G1 X146.957 Y127.271 E0.1326 G1 X148.132 Y127.038 E0.1551 G1 X148.151 Y127.035 E0.1555 G1 X148.560 Y126.981 E0.1632 G1 X148.579 Y126.979 E0.1636 G1 X149.774 Y126.901 E0.1861 G1 X149.794 Y126.900 E0.1865 G1 X150.206 Y126.900 E0.1942 G1 X150.226 Y126.901 E0.1946 G1 X151.421 Y126.979 E0.2171 G1 X151.440 Y126.981 E0.2175 G1 X151.849 Y127.035 E0.2253 G1 X151.869 Y127.038 E0.2256 G1 X153.043 Y127.272 E0.2482 G1 X153.062 Y127.276 E0.2485 G1 X153.460 Y127.383 E0.2563 G1 X153.479 Y127.388 E0.2567 G1 X154.613 Y127.773 E0.2792 G1 X154.631 Y127.780 E0.2795 G1 X155.012 Y127.938 E0.2873 G1 X155.030 Y127.946 E0.2877 G1 X156.104 Y128.476 E0.3102 G1 X156.122 Y128.485 E0.3106 G1 X156.479 Y128.691 E0.3183 G1 X156.495 Y128.702 E0.3187 G1 X157.491 Y129.367 E0.3412 G1 X157.507 Y129.378 E0.3416 G1 X157.834 Y129.629 E0.3493 G1 X157.849 Y129.642 E0.3497 G1 X158.749 Y130.431 E0.3722 G1 X158.764 Y130.445 E0.3726 G1 X159.055 Y130.736 E0.3804 G1 X159.069 Y130.751 E0.3807 G1 X159.858 Y131.651 E0.4033 G1 X159.871 Y131.666 E0.4036 G1 X160.122 Y131.993 E0.4114 G1 X160.133 Y132.009 E0.4118 G1 X160.798 Y133.005 E0.4343 G1 X160.809 Y133.021 E0.4346 G1 X161.015 Y133.379 E0.4424 G1 X161.024 Y133.396 E0.4428 G1 X161.554 Y134.470 E0.4653 G1 X161.562 Y134.488 E0.4657 G1 X161.720 Y134.869 E0.4734 G1 X161.727 Y134.887 E0.4738 G1 X162.112 Y136.021 E0.4963 G1 X162.117 Y136.040 E0.4967 G1 X162.224 Y136.438 E0.5045 G1 X162.229 Y136.458 E0.5048 G1 X162.462 Y137.632 E0.5273 G1 X162.465 Y137.651 E0.5277 G1 X162.519 Y138.060 E0.5355 G1 X162.521 Y138.079 E0.5358 G1 X162.593 Y139.171 E0.5564 G1 X162.593 Y139.181 E0.5566 G1 X162.600 Y139.387 E0.5605 G1 X162.600 Y139.397 E0.5607 G1 X162.600 Y144.603 E0.6586 G1 X162.600 Y144.613 E0.6588 G1 X162.593 Y144.818 E0.6627 G1 X162.593 Y144.828 E0.6628 G1 X162.547 Y145.528 E0.6760 G1 X162.545 Y145.548 E0.6764 G1 X162.491 Y145.957 E0.6842 G1 X162.488 Y145.977 E0.6845 G1 X162.331 Y146.766 E0.6997 G1 X162.326 Y146.785 E0.7000 G1 X162.220 Y147.183 E0.7078 G1 X162.214 Y147.201 E0.7082 G1 X161.956 Y147.963 E0.7233 G1 X161.949 Y147.981 E0.7236 G1 X161.791 Y148.362 E0.7314 G1 X161.783 Y148.380 E0.7318 G1 X161.427 Y149.101 E0.7469 G1 X161.418 Y149.118 E0.7473 G1 X161.211 Y149.476 E0.7550 G1 X161.201 Y149.493 E0.7554 G1 X160.754 Y150.161 E0.7705 G1 X160.743 Y150.177 E0.7709 G1 X160.492 Y150.505 E0.7787 G1 X160.479 Y150.520 E0.7790 G1 X160.095 Y150.958 E0.7900 G1 X160.122 Y150.993 E0.7908 G1 X160.133 Y151.009 E0.7912 G1 X160.798 Y152.005 E0.8137 G1 X160.809 Y152.021 E0.8141 G1 X161.015 Y152.379 E0.8219 G1 X161.024 Y152.396 E0.8222 G1 X161.554 Y153.470 E0.8447 G1 X161.562 Y153.488 E0.8451 G1 X161.720 Y153.869 E0.8529 G1 X161.727 Y153.887 E0.8532 G1 X162.112 Y155.021 E0.8758 G1 X162.117 Y155.040 E0.8761 G1 X162.224 Y155.438 E0.8839 G1 X162.229 Y155.458 E0.8843 G1 X162.462 Y156.632 E0.9068 G1 X162.465 Y156.651 E0.9072 G1 X162.519 Y157.060 E0.9149 G1 X162.521 Y157.079 E0.9153 G1 X162.593 Y158.171 E0.9359 G1 X162.593 Y158.181 E0.9360 G1 X162.600 Y158.387 E0.9399 G1 X162.600 Y158.397 E0.9401 G1 X162.600 Y163.603 E1.0380 G1 X162.600 Y163.613 E1.0382 G1 X162.593 Y163.818 E1.0421 G1 X162.593 Y163.828 E1.0423 G1 X162.547 Y164.528 E1.0555 G1 X162.545 Y164.548 E1.0558 G1 X162.491 Y164.957 E1.0636 G1 X162.488 Y164.977 E1.0640 G1 X162.331 Y165.766 E1.0791 G1 X162.326 Y165.785 E1.0795 G1 X162.220 Y166.183 E1.0872 G1 X162.214 Y166.201 E1.0876 G1 X161.956 Y166.963 E1.1027 G1 X161.949 Y166.981 E1.1031 G1 X161.791 Y167.362 E1.1108 G1 X161.783 Y167.380 E1.1112 G1 X161.427 Y168.101 E1.1263 G1 X161.418 Y168.118 E1.1267 G1 X161.211 Y168.476 E1.1345 G1 X161.201 Y168.493 E1.1349 G1 X160.754 Y169.161 E1.1500 G1 X160.743 Y169.177 E1.1503 G1 X160.492 Y169.505 E1.1581 G1 X160.479 Y169.520 E1.1585 G1 X159.949 Y170.124 E1.1736 G1 X159.936 Y170.139 E1.1740 G1 X159.644 Y170.430 E1.1817 G1 X159.630 Y170.444 E1.1821 G1 X159.025 Y170.974 E1.1972 G1 X159.010 Y170.986 E1.1976 G1 X158.682 Y171.238 E1.2054 G1 X158.666 Y171.249 E1.2057 G1 X157.998 Y171.696 E1.2209 G1 X157.981 Y171.706 E1.2212 G1 X157.624 Y171.912 E1.2290 G1 X157.607 Y171.922 E1.2293 G1 X156.886 Y172.277 E1.2445 G1 X156.868 Y172.285 E1.2448 G1 X156.487 Y172.443 E1.2526 G1 X156.468 Y172.450 E1.2530 G1 X155.707 Y172.709 E1.2681 G1 X155.688 Y172.715 E1.2685 G1 X155.289 Y172.821 E1.2762 G1 X155.270 Y172.826 E1.2766 G1 X154.502 Y172.979 E1.2913 G1 X154.484 Y172.981 E1.2917 G1 X154.117 Y173.032 E1.2986 G1 X154.100 Y173.034 E1.2990 G1 X150.782 Y173.296 E1.3616 G1 X150.545 Y173.214 E1.3663 G1 X150.000 Y172.710 E1.3803 G1 X149.455 Y173.214 E1.3942 G1 X149.218 Y173.296 E1.3989 G1 X145.900 Y173.034 E1.4615 G1 X145.883 Y173.032 E1.4619 G1 X145.516 Y172.981 E1.4688 G1 X145.498 Y172.979 E1.4692 G1 X144.730 Y172.826 E1.4839 G1 X144.711 Y172.821 E1.4843 G1 X144.312 Y172.715 E1.4920 G1 X144.294 Y172.709 E1.4924 G1 X143.532 Y172.450 E1.5075 G1 X143.513 Y172.443 E1.5079 G1 X143.132 Y172.285 E1.5157 G1 X143.114 Y172.277 E1.5160 G1 X142.393 Y171.922 E1.5312 G1 X142.376 Y171.912 E1.5315 G1 X142.019 Y171.706 E1.5393 G1 X142.002 Y171.696 E1.5397 G1 X141.334 Y171.249 E1.5548 G1 X141.318 Y171.238 E1.5552 G1 X140.990 Y170.986 E1.5629 G1 X140.975 Y170.974 E1.5633 G1 X140.370 Y170.444 E1.5784 G1 X140.356 Y170.430 E1.5788 G1 X140.064 Y170.139 E1.5865 G1 X140.051 Y170.124 E1.5869 G1 X139.521 Y169.520 E1.6020 G1 X139.508 Y169.505 E1.6024 G1 X139.257 Y169.177 E1.6102 G1 X139.246 Y169.162 E1.6105 G1 X138.799 Y168.493 E1.6257 G1 X138.789 Y168.476 E1.6260 G1 X138.582 Y168.119 E1.6338 G1 X138.573 Y168.102 E1.6342 G1 X138.217 Y167.380 E1.6493 G1 X138.209 Y167.362 E1.6497 G1 X138.051 Y166.981 E1.6574 G1 X138.044 Y166.963 E1.6578 G1 X137.786 Y166.201 E1.6729 G1 X137.780 Y166.182 E1.6733 G1 X137.674 Y165.784 E1.6810 G1 X137.669 Y165.765 E1.6814 G1 X137.512 Y164.976 E1.6965 G1 X137.509 Y164.957 E1.6969 G1 X137.455 Y164.548 E1.7047 G1 X137.453 Y164.528 E1.7050 G1 X137.407 Y163.829 E1.7182 G1 X137.407 Y163.819 E1.7184 G1 X137.400 Y163.613 E1.7223 G1 X137.400 Y163.603 E1.7225 G1 X137.400 Y158.397 E1.8204 G1 X137.400 Y158.387 E1.8206 G1 X137.407 Y158.181 E1.8245 G1 X137.407 Y158.171 E1.8247 G1 X137.479 Y157.079 E1.8452 G1 X137.481 Y157.060 E1.8456 G1 X137.535 Y156.651 E1.8534 G1 X137.538 Y156.631 E1.8537 G1 X137.772 Y155.457 E1.8763 G1 X137.776 Y155.438 E1.8766 G1 X137.883 Y155.040 E1.8844 G1 X137.888 Y155.021 E1.8847 G1 X138.273 Y153.887 E1.9073 G1 X138.280 Y153.869 E1.9076 G1 X138.438 Y153.487 E1.9154 G1 X138.446 Y153.469 E1.9158 G1 X138.976 Y152.396 E1.9383 G1 X138.985 Y152.378 E1.9387 G1 X139.191 Y152.021 E1.9464 G1 X139.202 Y152.005 E1.9468 G1 X139.867 Y151.009 E1.9693 G1 X139.878 Y150.993 E1.9697 G1 X139.905 Y150.958 E1.9705 G1 X139.521 Y150.520 E1.9815 G1 X139.508 Y150.505 E1.9819 G1 X139.257 Y150.177 E1.9896 G1 X139.246 Y150.161 E1.9900 G1 X138.799 Y149.493 E2.0051 G1 X138.789 Y149.476 E2.0055 G1 X138.582 Y149.119 E2.0132 G1 X138.573 Y149.102 E2.0136 G1 X138.217 Y148.380 E2.0287 G1 X138.209 Y148.362 E2.0291 G1 X138.051 Y147.981 E2.0369 G1 X138.044 Y147.963 E2.0372 G1 X137.786 Y147.201 E2.0524 G1 X137.780 Y147.182 E2.0527 G1 X137.674 Y146.784 E2.0605 G1 X137.669 Y146.765 E2.0609 G1 X137.512 Y145.976 E2.0760 G1 X137.509 Y145.957 E2.0764 G1 X137.455 Y145.548 E2.0841 G1 X137.453 Y145.528 E2.0845 G1 X137.407 Y144.829 E2.0977 G1 X137.407 Y144.819 E2.0979 G1 X137.400 Y144.613 E2.1017 G1 X137.400 Y144.603 E2.1019 G1 X137.400 Y139.397 E2.1999 G1 X137.400 Y139.387 E2.2000 G1 X137.407 Y139.181 E2.2039 G1 X137.407 Y139.171 E2.2041 G1 X137.479 Y138.079 E2.2247 G1 X137.481 Y138.060 E2.2251 G1 X137.535 Y137.651 E2.2328 G1 X137.538 Y137.631 E2.2332 G1 X137.772 Y136.457 E2.2557 G1 X137.776 Y136.438 E2.2561 G1 X137.883 Y136.040 E2.2638 G1 X137.888 Y136.021 E2.2642 G1 X138.273 Y134.887 E2.2867 G1 X138.280 Y134.869 E2.2871 G1 X138.438 Y134.487 E2.2949 G1 X138.446 Y134.469 E2.2952 G1 X138.976 Y133.396 E2.3177 G1 X138.985 Y133.378 E2.3181 G1 X139.191 Y133.021 E2.3259 G1 X139.202 Y133.005 E2.3262 G1 X139.867 Y132.009 E2.3488 G1 X139.878 Y131.993 E2.3491 G1 X140.129 Y131.666 E2.3569 G1 X140.142 Y131.651 E2.3573 G1 X140.272 Y131.503 E2.3610 G1 X140.931 Y130.751 F1800 G1 X141.228 Y131.019 F4800 G92 E0 G1 X141.232 Y131.015 E0.0001 F1800 G1 X141.515 Y130.732 E0.0076 G1 X141.519 Y130.728 E0.0078 G1 X142.410 Y129.947 E0.0300 G1 X142.415 Y129.943 E0.0302 G1 X142.731 Y129.700 E0.0377 G1 X142.737 Y129.696 E0.0378 G1 X143.721 Y129.038 E0.0601 G1 X143.727 Y129.034 E0.0602 G1 X144.073 Y128.835 E0.0677 G1 X144.079 Y128.832 E0.0678 G1 X145.141 Y128.308 E0.0901 G1 X145.147 Y128.305 E0.0902 G1 X145.516 Y128.152 E0.0977 G1 X145.522 Y128.150 E0.0979 G1 X146.643 Y127.769 E0.1201 G1 X146.650 Y127.767 E0.1203 G1 X147.035 Y127.664 E0.1278 G1 X147.042 Y127.663 E0.1279 G1 X148.203 Y127.431 E0.1502 G1 X148.210 Y127.430 E0.1503 G1 X148.606 Y127.378 E0.1578 G1 X148.612 Y127.378 E0.1579 G1 X149.794 Y127.300 E0.1802 G1 X149.800 Y127.300 E0.1803 G1 X150.200 Y127.300 E0.1878 G1 X150.206 Y127.300 E0.1880 G1 X151.388 Y127.378 E0.2102 G1 X151.394 Y127.378 E0.2104 G1 X151.791 Y127.430 E0.2179 G1 X151.797 Y127.432 E0.2180 G1 X152.958 Y127.663 E0.2403 G1 X152.965 Y127.664 E0.2404 G1 X153.350 Y127.767 E0.2479 G1 X153.357 Y127.769 E0.2480 G1 X154.478 Y128.150 E0.2703 G1 X154.484 Y128.152 E0.2704 G1 X154.853 Y128.305 E0.2780 G1 X154.859 Y128.308 E0.2781 G1 X155.921 Y128.832 E0.3004 G1 X155.927 Y128.835 E0.3005 G1 X156.273 Y129.034 E0.3080 G1 X156.279 Y129.038 E0.3081 G1 X157.263 Y129.696 E0.3304 G1 X157.268 Y129.700 E0.3305 G1 X157.585 Y129.943 E0.3380 G1 X157.590 Y129.947 E0.3381 G1 X158.481 Y130.728 E0.3604 G1 X158.485 Y130.732 E0.3605 G1 X158.768 Y131.015 E0.3681 G1 X158.772 Y131.019 E0.3682 G1 X159.553 Y131.910 E0.3905 G1 X159.557 Y131.915 E0.3906 G1 X159.800 Y132.232 E0.3981 G1 X159.804 Y132.237 E0.3982 G1 X160.462 Y133.222 E0.4205 G1 X160.466 Y133.227 E0.4206 G1 X160.665 Y133.573 E0.4281 G1 X160.668 Y133.579 E0.4282 G1 X161.192 Y134.641 E0.4505 G1 X161.195 Y134.647 E0.4506 G1 X161.348 Y135.016 E0.4582 G1 X161.350 Y135.022 E0.4583 G1 X161.731 Y136.143 E0.4806 G1 X161.733 Y136.149 E0.4807 G1 X161.836 Y136.536 E0.4882 G1 X161.838 Y136.542 E0.4883 G1 X162.069 Y137.703 E0.5106 G1 X162.070 Y137.710 E0.5107 G1 X162.122 Y138.105 E0.5182 G1 X162.122 Y138.112 E0.5184 G1 X162.193 Y139.194 E0.5387 G1 X162.193 Y139.197 E0.5388 G1 X162.200 Y139.397 E0.5426 G1 X162.200 Y139.400 E0.5426 G1 X162.200 Y144.600 E0.6404 G1 X162.200 Y144.603 E0.6405 G1 X162.193 Y144.802 E0.6442 G1 X162.193 Y144.805 E0.6443 G1 X162.148 Y145.495 E0.6573 G1 X162.147 Y145.502 E0.6574 G1 X162.095 Y145.899 E0.6650 G1 X162.094 Y145.905 E0.6651 G1 X161.940 Y146.681 E0.6800 G1 X161.938 Y146.687 E0.6801 G1 X161.835 Y147.073 E0.6876 G1 X161.833 Y147.079 E0.6877 G1 X161.579 Y147.828 E0.7026 G1 X161.577 Y147.834 E0.7027 G1 X161.424 Y148.203 E0.7102 G1 X161.421 Y148.209 E0.7103 G1 X161.071 Y148.918 E0.7252 G1 X161.068 Y148.924 E0.7254 G1 X160.868 Y149.270 E0.7329 G1 X160.865 Y149.276 E0.7330 G1 X160.425 Y149.934 E0.7479 G1 X160.421 Y149.939 E0.7480 G1 X160.178 Y150.256 E0.7555 G1 X160.174 Y150.261 E0.7556 G1 X159.653 Y150.856 E0.7705 G1 X159.648 Y150.860 E0.7706 G1 X159.573 Y150.935 E0.7726 G1 X159.800 Y151.232 E0.7797 G1 X159.804 Y151.237 E0.7798 G1 X160.462 Y152.222 E0.8021 G1 X160.466 Y152.227 E0.8022 G1 X160.665 Y152.573 E0.8097 G1 X160.668 Y152.579 E0.8098 G1 X161.192 Y153.641 E0.8321 G1 X161.195 Y153.647 E0.8322 G1 X161.348 Y154.016 E0.8397 G1 X161.350 Y154.022 E0.8398 G1 X161.731 Y155.143 E0.8621 G1 X161.733 Y155.149 E0.8622 G1 X161.836 Y155.536 E0.8698 G1 X161.838 Y155.542 E0.8699 G1 X162.069 Y156.703 E0.8922 G1 X162.070 Y156.710 E0.8923 G1 X162.122 Y157.105 E0.8998 G1 X162.122 Y157.112 E0.8999 G1 X162.193 Y158.194 E0.9203 G1 X162.193 Y158.197 E0.9204 G1 X162.200 Y158.397 E0.9241 G1 X162.200 Y158.400 E0.9242 G1 X162.200 Y163.600 E1.0220 G1 X162.200 Y163.603 E1.0221 G1 X162.193 Y163.802 E1.0258 G1 X162.193 Y163.805 E1.0259 G1 X162.148 Y164.495 E1.0389 G1 X162.147 Y164.502 E1.0390 G1 X162.095 Y164.899 E1.0465 G1 X162.094 Y164.905 E1.0467 G1 X161.940 Y165.681 E1.0615 G1 X161.938 Y165.687 E1.0617 G1 X161.835 Y166.073 E1.0692 G1 X161.833 Y166.079 E1.0693 G1 X161.579 Y166.828 E1.0842 G1 X161.577 Y166.834 E1.0843 G1 X161.424 Y167.203 E1.0918 G1 X161.421 Y167.209 E1.0919 G1 X161.071 Y167.918 E1.1068 G1 X161.068 Y167.924 E1.1069 G1 X160.868 Y168.270 E1.1144 G1 X160.865 Y168.276 E1.1146 G1 X160.425 Y168.934 E1.1294 G1 X160.421 Y168.939 E1.1296 G1 X160.178 Y169.256 E1.1371 G1 X160.174 Y169.261 E1.1372 G1 X159.653 Y169.856 E1.1521 G1 X159.648 Y169.860 E1.1522 G1 X159.366 Y170.143 E1.1597 G1 X159.361 Y170.147 E1.1598 G1 X158.766 Y170.669 E1.1747 G1 X158.761 Y170.673 E1.1748 G1 X158.444 Y170.916 E1.1824 G1 X158.439 Y170.920 E1.1825 G1 X157.781 Y171.360 E1.1974 G1 X157.775 Y171.363 E1.1975 G1 X157.430 Y171.563 E1.2050 G1 X157.424 Y171.566 E1.2051 G1 X156.715 Y171.916 E1.2200 G1 X156.709 Y171.918 E1.2201 G1 X156.340 Y172.071 E1.2276 G1 X156.333 Y172.074 E1.2278 G1 X155.584 Y172.328 E1.2426 G1 X155.578 Y172.330 E1.2428 G1 X155.192 Y172.433 E1.2503 G1 X155.186 Y172.435 E1.2504 G1 X154.429 Y172.585 E1.2649 G1 X154.424 Y172.586 E1.2650 G1 X154.068 Y172.635 E1.2718 G1 X154.062 Y172.636 E1.2719 G1 X150.834 Y172.890 E1.3328 G1 X150.755 Y172.863 E1.3344 G1 X150.000 Y172.165 E1.3537 G1 X149.245 Y172.863 E1.3731 G1 X149.166 Y172.890 E1.3746 G1 X145.938 Y172.636 E1.4355 G1 X145.932 Y172.635 E1.4357 G1 X145.576 Y172.586 E1.4424 G1 X145.571 Y172.585 E1.4425 G1 X144.814 Y172.435 E1.4570 G1 X144.808 Y172.433 E1.4571 G1 X144.422 Y172.330 E1.4647 G1 X144.416 Y172.328 E1.4648 G1 X143.667 Y172.074 E1.4797 G1 X143.660 Y172.071 E1.4798 G1 X143.291 Y171.918 E1.4873 G1 X143.285 Y171.916 E1.4874 G1 X142.576 Y171.566 E1.5023 G1 X142.570 Y171.563 E1.5024 G1 X142.225 Y171.363 E1.5099 G1 X142.219 Y171.360 E1.5101 G1 X141.561 Y170.920 E1.5249 G1 X141.556 Y170.916 E1.5251 G1 X141.239 Y170.673 E1.5326 G1 X141.234 Y170.669 E1.5327 G1 X140.639 Y170.147 E1.5476 G1 X140.634 Y170.143 E1.5477 G1 X140.352 Y169.860 E1.5552 G1 X140.347 Y169.856 E1.5553 G1 X139.826 Y169.261 E1.5702 G1 X139.822 Y169.256 E1.5703 G1 X139.579 Y168.939 E1.5779 G1 X139.575 Y168.934 E1.5780 G1 X139.135 Y168.276 E1.5929 G1 X139.132 Y168.271 E1.5930 G1 X138.932 Y167.925 E1.6005 G1 X138.929 Y167.919 E1.6006 G1 X138.579 Y167.209 E1.6155 G1 X138.576 Y167.203 E1.6156 G1 X138.423 Y166.834 E1.6231 G1 X138.421 Y166.828 E1.6233 G1 X138.167 Y166.079 E1.6381 G1 X138.165 Y166.073 E1.6383 G1 X138.062 Y165.687 E1.6458 G1 X138.060 Y165.680 E1.6459 G1 X137.906 Y164.905 E1.6608 G1 X137.905 Y164.898 E1.6609 G1 X137.853 Y164.502 E1.6684 G1 X137.852 Y164.496 E1.6685 G1 X137.807 Y163.806 E1.6815 G1 X137.807 Y163.803 E1.6816 G1 X137.800 Y163.603 E1.6854 G1 X137.800 Y163.600 E1.6854 G1 X137.800 Y158.400 E1.7832 G1 X137.800 Y158.397 E1.7833 G1 X137.807 Y158.197 E1.7870 G1 X137.807 Y158.194 E1.7871 G1 X137.878 Y157.112 E1.8075 G1 X137.878 Y157.106 E1.8076 G1 X137.930 Y156.709 E1.8151 G1 X137.932 Y156.703 E1.8153 G1 X138.163 Y155.542 E1.8375 G1 X138.164 Y155.535 E1.8377 G1 X138.267 Y155.150 E1.8452 G1 X138.269 Y155.143 E1.8453 G1 X138.650 Y154.022 E1.8676 G1 X138.652 Y154.016 E1.8677 G1 X138.805 Y153.647 E1.8752 G1 X138.808 Y153.641 E1.8753 G1 X139.332 Y152.578 E1.8976 G1 X139.335 Y152.573 E1.8977 G1 X139.534 Y152.227 E1.9052 G1 X139.538 Y152.221 E1.9054 G1 X140.196 Y151.237 E1.9276 G1 X140.200 Y151.232 E1.9278 G1 X140.427 Y150.935 E1.9348 G1 X140.352 Y150.860 E1.9368 G1 X140.347 Y150.856 E1.9369 G1 X139.826 Y150.261 E1.9518 G1 X139.822 Y150.256 E1.9519 G1 X139.579 Y149.939 E1.9594 G1 X139.575 Y149.934 E1.9595 G1 X139.135 Y149.276 E1.9744 G1 X139.132 Y149.271 E1.9745 G1 X138.932 Y148.925 E1.9821 G1 X138.929 Y148.919 E1.9822 G1 X138.579 Y148.209 E1.9971 G1 X138.576 Y148.203 E1.9972 G1 X138.423 Y147.834 E2.0047 G1 X138.421 Y147.828 E2.0048 G1 X138.167 Y147.079 E2.0197 G1 X138.165 Y147.073 E2.0198 G1 X138.062 Y146.687 E2.0273 G1 X138.060 Y146.680 E2.0275 G1 X137.906 Y145.905 E2.0423 G1 X137.905 Y145.898 E2.0425 G1 X137.853 Y145.502 E2.0500 G1 X137.852 Y145.496 E2.0501 G1 X137.807 Y144.806 E2.0631 G1 X137.807 Y144.803 E2.0632 G1 X137.800 Y144.603 E2.0669 G1 X137.800 Y144.600 E2.0670 G1 X137.800 Y139.400 E2.1648 G1 X137.800 Y139.397 E2.1649 G1 X137.807 Y139.197 E2.1686 G1 X137.807 Y139.194 E2.1687 G1 X137.878 Y138.112 E2.1891 G1 X137.878 Y138.106 E2.1892 G1 X137.930 Y137.709 E2.1967 G1 X137.932 Y137.703 E2.1968 G1 X138.163 Y136.542 E2.2191 G1 X138.164 Y136.535 E2.2192 G1 X138.267 Y136.150 E2.2267 G1 X138.269 Y136.143 E2.2269 G1 X138.650 Y135.022 E2.2491 G1 X138.652 Y135.016 E2.2493 G1 X138.805 Y134.647 E2.2568 G1 X138.808 Y134.641 E2.2569 G1 X139.332 Y133.578 E2.2792 G1 X139.335 Y133.573 E2.2793 G1 X139.534 Y133.227 E2.2868 G1 X139.538 Y133.221 E2.2869 G1 X140.196 Y132.237 E2.3092 G1 X140.200 Y132.232 E2.3093 G1 X140.443 Y131.915 E2.3168 G1 X140.447 Y131.910 E2.3170 G1 X140.568 Y131.771 E2.3204 G1 X141.228 Y131.019 F1800 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X146.466 Y135.966 F4800 G1 E0.0000 F1500 G92 E0 G1 X146.957 Y135.535 E0.0123 F1350 G1 X147.501 Y135.172 E0.0246 G1 X148.087 Y134.883 E0.0369 G1 X148.706 Y134.672 E0.0492 G1 X149.348 Y134.545 E0.0615 G1 X150.000 Y134.502 E0.0738 G1 X150.652 Y134.545 E0.0861 G1 X151.294 Y134.672 E0.0984 G1 X151.913 Y134.883 E0.1107 G1 X152.499 Y135.172 E0.1230 G1 X153.042 Y135.535 E0.1353 G1 X153.534 Y135.966 E0.1476 G1 X153.965 Y136.458 E0.1599 G1 X154.328 Y137.001 E0.1722 G1 X154.617 Y137.587 E0.1845 G1 X154.828 Y138.206 E0.1968 G1 X154.955 Y138.848 E0.2091 G1 X155.000 Y139.533 E0.2220 G1 X155.000 Y140.190 E0.2343 G1 X154.710 Y140.248 E0.2399 G1 X154.554 Y139.871 E0.2476 G1 X153.718 Y138.782 E0.2734 G1 X152.629 Y137.946 E0.2992 G1 X151.361 Y137.421 E0.3250 G1 X150.000 Y137.241 E0.3509 G1 X148.639 Y137.421 E0.3767 G1 X147.371 Y137.946 E0.4025 G1 X146.282 Y138.782 E0.4283 G1 X145.446 Y139.871 E0.4541 G1 X145.290 Y140.248 E0.4618 G1 X145.000 Y140.190 E0.4674 G1 X145.000 Y139.533 E0.4797 G1 X145.045 Y138.848 E0.4927 G1 X145.172 Y138.206 E0.5050 G1 X145.383 Y137.587 E0.5172 G1 X145.672 Y137.001 E0.5295 G1 X145.843 Y136.745 E0.5353 G1 X146.035 Y136.458 F1350 G1 X146.466 Y135.966 F1350 G1 X145.458 Y145.145 F4800 G92 E0 G1 X145.974 Y145.818 E0.0159 F1350 G1 X145.736 Y146.041 E0.0221 G1 X145.586 Y145.909 E0.0258 G1 X145.555 Y145.873 E0.0267 G1 X145.414 Y145.713 F1350 G1 X145.269 Y145.496 F1350 G1 X145.181 Y145.317 F1350 G1 X145.458 Y145.145 F1350 G92 E0 G1 E-6.5000 F1500 G1 X154.026 Y145.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.542 Y145.145 E0.0160 F1350 G1 X154.819 Y145.317 E0.0221 G1 X154.731 Y145.496 E0.0258 G1 X154.705 Y145.536 E0.0267 G1 X154.586 Y145.713 F1350 G1 X154.414 Y145.909 F1350 G1 X154.264 Y146.041 F1350 G1 X154.026 Y145.818 F1350 G1 X153.605 Y145.709 F4800 G92 E0 G1 X154.205 Y144.928 E0.0185 F1350 G1 X154.690 Y143.757 E0.0424 G1 X154.855 Y142.500 E0.0662 G1 X154.690 Y141.243 E0.0900 G1 X154.205 Y140.072 E0.1139 G1 X153.433 Y139.067 E0.1377 G1 X152.428 Y138.295 E0.1616 G1 X151.257 Y137.810 E0.1854 G1 X150.000 Y137.645 E0.2093 G1 X148.743 Y137.810 E0.2331 G1 X147.572 Y138.295 E0.2569 G1 X146.567 Y139.067 E0.2808 G1 X145.795 Y140.072 E0.3046 G1 X145.310 Y141.243 E0.3285 G1 X145.145 Y142.500 E0.3523 G1 X145.310 Y143.757 E0.3761 G1 X145.795 Y144.928 E0.4000 G1 X146.395 Y145.709 E0.4185 G1 X146.395 Y146.819 E0.4394 G1 X146.079 Y146.711 E0.4457 G1 X145.798 Y146.573 E0.4516 G1 X145.538 Y146.399 E0.4574 G1 X145.302 Y146.192 E0.4633 G1 X145.096 Y145.957 E0.4692 G1 X144.922 Y145.697 E0.4751 G1 X144.783 Y145.416 E0.4810 G1 X144.683 Y145.119 E0.4869 G1 X144.622 Y144.812 E0.4928 G1 X144.600 Y144.480 E0.4990 G1 X144.600 Y139.520 E0.5924 G1 X144.647 Y138.795 E0.6060 G1 X144.785 Y138.103 E0.6193 G1 X145.012 Y137.434 E0.6326 G1 X145.325 Y136.801 E0.6459 G1 X145.717 Y136.213 E0.6591 G1 X146.183 Y135.683 E0.6724 G1 X146.714 Y135.217 E0.6857 G1 X147.301 Y134.825 E0.6990 G1 X147.934 Y134.512 E0.7123 G1 X148.603 Y134.285 E0.7256 G1 X149.295 Y134.147 E0.7388 G1 X150.000 Y134.101 E0.7521 G1 X150.705 Y134.147 E0.7654 G1 X151.397 Y134.285 E0.7787 G1 X152.066 Y134.512 E0.7920 G1 X152.699 Y134.825 E0.8053 G1 X153.287 Y135.217 E0.8185 G1 X153.818 Y135.683 E0.8318 G1 X154.283 Y136.213 E0.8451 G1 X154.675 Y136.801 E0.8584 G1 X154.988 Y137.434 E0.8717 G1 X155.215 Y138.103 E0.8850 G1 X155.352 Y138.795 E0.8982 G1 X155.400 Y139.520 E0.9119 G1 X155.400 Y144.480 E1.0052 G1 X155.378 Y144.812 E1.0115 G1 X155.317 Y145.119 E1.0174 G1 X155.217 Y145.416 E1.0233 G1 X155.078 Y145.697 E1.0291 G1 X154.904 Y145.957 E1.0350 G1 X154.698 Y146.192 E1.0409 G1 X154.462 Y146.399 E1.0468 G1 X154.202 Y146.573 E1.0527 G1 X153.921 Y146.711 E1.0586 G1 X153.605 Y146.819 E1.0649 G1 X153.605 Y146.709 E1.0669 G1 X153.605 Y145.709 F1350 ; outer perimeter G1 X153.205 Y145.573 F4800 G92 E0 G1 X153.855 Y144.726 E0.0201 F900 G1 X154.300 Y143.652 E0.0419 G1 X154.452 Y142.500 E0.0638 G1 X154.300 Y141.348 E0.0857 G1 X153.855 Y140.274 E0.1075 G1 X153.148 Y139.352 E0.1294 G1 X152.226 Y138.645 E0.1513 G1 X151.152 Y138.200 E0.1731 G1 X150.000 Y138.048 E0.1950 G1 X148.848 Y138.200 E0.2168 G1 X147.774 Y138.645 E0.2387 G1 X146.852 Y139.352 E0.2606 G1 X146.145 Y140.274 E0.2824 G1 X145.700 Y141.348 E0.3043 G1 X145.548 Y142.500 E0.3261 G1 X145.700 Y143.652 E0.3480 G1 X146.145 Y144.726 E0.3699 G1 X146.795 Y145.573 E0.3899 G1 X146.795 Y147.284 E0.4221 G1 X146.631 Y147.271 E0.4252 G1 X146.272 Y147.199 E0.4321 G1 X145.925 Y147.082 E0.4390 G1 X145.598 Y146.920 E0.4459 G1 X145.294 Y146.717 E0.4527 G1 X145.019 Y146.476 E0.4596 G1 X144.778 Y146.201 E0.4665 G1 X144.575 Y145.897 E0.4734 G1 X144.413 Y145.569 E0.4802 G1 X144.296 Y145.223 E0.4871 G1 X144.224 Y144.865 E0.4940 G1 X144.200 Y144.493 E0.5010 G1 X144.200 Y139.507 E0.5948 G1 X144.250 Y138.743 E0.6092 G1 X144.398 Y137.999 E0.6235 G1 X144.642 Y137.281 E0.6377 G1 X144.977 Y136.600 E0.6520 G1 X145.399 Y135.969 E0.6663 G1 X145.899 Y135.399 E0.6805 G1 X146.469 Y134.899 E0.6948 G1 X147.100 Y134.477 E0.7091 G1 X147.781 Y134.142 E0.7233 G1 X148.499 Y133.898 E0.7376 G1 X149.243 Y133.750 E0.7519 G1 X150.000 Y133.700 E0.7662 G1 X150.757 Y133.750 E0.7804 G1 X151.501 Y133.898 E0.7947 G1 X152.219 Y134.142 E0.8090 G1 X152.900 Y134.477 E0.8232 G1 X153.531 Y134.899 E0.8375 G1 X154.101 Y135.399 E0.8518 G1 X154.601 Y135.969 E0.8660 G1 X155.023 Y136.600 E0.8803 G1 X155.358 Y137.281 E0.8946 G1 X155.602 Y137.999 E0.9089 G1 X155.750 Y138.743 E0.9231 G1 X155.800 Y139.507 E0.9375 G1 X155.800 Y144.494 E1.0313 G1 X155.776 Y144.865 E1.0383 G1 X155.704 Y145.223 E1.0452 G1 X155.587 Y145.569 E1.0521 G1 X155.425 Y145.897 E1.0589 G1 X155.222 Y146.201 E1.0658 G1 X154.981 Y146.476 E1.0727 G1 X154.706 Y146.717 E1.0796 G1 X154.402 Y146.920 E1.0865 G1 X154.075 Y147.082 E1.0933 G1 X153.728 Y147.199 E1.1002 G1 X153.369 Y147.271 E1.1071 G1 X153.205 Y147.284 E1.1102 G1 X153.205 Y146.573 E1.1236 G1 X153.205 Y145.573 F900 ; gap fill G1 X155.022 Y144.840 F4800 G92 E0 G1 X154.733 Y144.551 E0.0077 F1440 G1 X154.826 Y144.327 E0.0122 G1 X154.899 Y144.151 F1440 G1 X155.056 Y144.308 F1440 G1 X155.056 Y143.742 F1440 G1 X155.041 Y143.727 F1440 G92 E0 G1 E-6.5000 F1500 G1 X144.944 Y143.813 F4800 G1 E0.0000 F1500 G92 E0 G1 X144.975 Y143.843 E0.0008 F1440 G1 X144.975 Y143.846 E0.0009 G1 X145.368 Y144.796 E0.0202 G1 X145.364 Y144.798 E0.0203 G1 X145.196 Y144.630 E0.0248 G1 X144.944 Y144.378 F1440 G1 X144.944 Y144.469 F1440 G1 X144.964 Y144.767 F1440 G1 X145.012 Y145.012 F1440 G1 X145.015 Y145.015 F1440 ; solid layer G1 X145.366 Y139.144 F4800 G92 E0 G1 X145.484 Y139.262 E0.0031 F1440 G1 X145.730 Y138.942 E0.0107 G1 X145.432 Y138.644 E0.0187 G1 X145.502 Y138.295 E0.0254 G1 X145.539 Y138.185 E0.0275 G1 X145.976 Y138.622 E0.0392 G1 X146.039 Y138.539 E0.0411 G1 X146.277 Y138.357 E0.0467 G1 X145.682 Y137.763 E0.0626 G1 X145.697 Y137.718 E0.0634 G1 X145.864 Y137.379 E0.0706 G1 X146.597 Y138.111 E0.0900 G1 X146.917 Y137.866 E0.0976 G1 X146.069 Y137.018 E0.1202 G1 X146.296 Y136.679 E0.1278 G1 X147.246 Y137.629 E0.1531 G1 X147.646 Y137.464 E0.1613 G1 X146.559 Y136.376 E0.1902 G1 X146.707 Y136.207 E0.1944 G1 X146.839 Y136.091 E0.1977 G1 X148.046 Y137.298 E0.2298 G1 X148.446 Y137.132 E0.2380 G1 X147.140 Y135.827 E0.2727 G1 X147.165 Y135.805 E0.2733 G1 X147.476 Y135.597 E0.2804 G1 X148.920 Y137.041 E0.3188 G1 X149.420 Y136.975 E0.3283 G1 X147.832 Y135.387 E0.3705 G1 X148.211 Y135.201 E0.3784 G1 X149.920 Y136.909 E0.4239 G1 X150.000 Y136.898 E0.4254 G1 X150.547 Y136.970 E0.4358 G1 X148.633 Y135.056 E0.4867 G1 X148.795 Y135.002 E0.4899 G1 X149.086 Y134.944 E0.4955 G1 X151.198 Y137.056 E0.5517 G1 X151.450 Y137.089 E0.5565 G1 X152.043 Y137.335 E0.5685 G1 X149.578 Y134.871 E0.6341 G1 X150.000 Y134.843 E0.6421 G1 X150.125 Y134.851 E0.6444 G1 X153.324 Y138.050 E0.7295 G1 X153.961 Y138.539 E0.7446 G1 X154.450 Y139.176 E0.7597 G1 X154.649 Y139.375 E0.7650 G1 X154.617 Y138.892 E0.7741 G1 X154.589 Y138.750 E0.7769 G1 X150.750 Y134.911 E0.8790 G1 X151.205 Y135.002 E0.8877 G1 X151.510 Y135.105 E0.8938 G1 X154.395 Y137.990 E0.9705 G1 X154.303 Y137.718 E0.9759 G1 X154.033 Y137.171 E0.9874 G1 X153.814 Y136.843 E0.9948 G1 X153.364 Y136.393 E1.0068 G1 X152.657 Y135.686 F1440 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X150.652 Y153.545 F4800 G1 E0.0000 F1500 G92 E0 G1 X151.294 Y153.672 E0.0123 F1350 G1 X151.913 Y153.883 E0.0246 G1 X152.499 Y154.172 E0.0369 G1 X153.042 Y154.535 E0.0492 G1 X153.534 Y154.966 E0.0615 G1 X153.965 Y155.458 E0.0738 G1 X154.328 Y156.001 E0.0861 G1 X154.617 Y156.587 E0.0984 G1 X154.828 Y157.206 E0.1107 G1 X154.955 Y157.848 E0.1230 G1 X155.000 Y158.533 E0.1359 G1 X155.000 Y159.190 E0.1483 G1 X154.710 Y159.248 E0.1538 G1 X154.554 Y158.871 E0.1615 G1 X153.718 Y157.782 E0.1873 G1 X152.629 Y156.946 E0.2131 G1 X151.361 Y156.421 E0.2390 G1 X150.000 Y156.241 E0.2648 G1 X148.639 Y156.421 E0.2906 G1 X147.371 Y156.946 E0.3164 G1 X146.282 Y157.782 E0.3422 G1 X145.446 Y158.871 E0.3681 G1 X145.290 Y159.248 E0.3757 G1 X145.000 Y159.190 E0.3813 G1 X145.000 Y158.533 E0.3937 G1 X145.045 Y157.848 E0.4066 G1 X145.172 Y157.206 E0.4189 G1 X145.383 Y156.587 E0.4312 G1 X145.672 Y156.001 E0.4435 G1 X146.035 Y155.458 E0.4558 G1 X146.466 Y154.966 E0.4681 G1 X146.957 Y154.535 E0.4804 G1 X147.501 Y154.172 E0.4927 G1 X148.087 Y153.883 E0.5050 G1 X148.706 Y153.672 E0.5173 G1 X149.348 Y153.545 E0.5295 G1 X149.655 Y153.525 E0.5353 G1 X150.000 Y153.502 F1350 G1 X150.652 Y153.545 F1350 G92 E0 G1 E-6.5000 F1500 G1 X154.542 Y164.145 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.819 Y164.317 E0.0061 F1350 G1 X154.731 Y164.496 E0.0099 G1 X154.586 Y164.713 E0.0148 G1 X154.414 Y164.909 E0.0197 G1 X154.264 Y165.041 E0.0235 G1 X154.137 Y164.922 E0.0267 G1 X154.026 Y164.818 F1350 G1 X154.542 Y164.145 F1350 G92 E0 G1 E-6.5000 F1500 G1 X145.974 Y164.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.736 Y165.041 E0.0061 F1350 G1 X145.586 Y164.909 E0.0099 G1 X145.414 Y164.713 E0.0148 G1 X145.269 Y164.496 E0.0197 G1 X145.181 Y164.317 E0.0235 G1 X145.329 Y164.225 E0.0267 G1 X145.458 Y164.145 F1350 G1 X145.974 Y164.818 F1350 G1 X146.395 Y164.709 F4800 G92 E0 G1 X146.395 Y165.819 E0.0209 F1350 G1 X146.079 Y165.711 E0.0271 G1 X145.798 Y165.573 E0.0330 G1 X145.538 Y165.399 E0.0389 G1 X145.302 Y165.192 E0.0448 G1 X145.096 Y164.957 E0.0507 G1 X144.922 Y164.697 E0.0566 G1 X144.783 Y164.416 E0.0625 G1 X144.683 Y164.119 E0.0684 G1 X144.622 Y163.812 E0.0743 G1 X144.600 Y163.480 E0.0805 G1 X144.600 Y158.520 E0.1738 G1 X144.647 Y157.795 E0.1875 G1 X144.785 Y157.103 E0.2008 G1 X145.012 Y156.434 E0.2141 G1 X145.325 Y155.801 E0.2273 G1 X145.717 Y155.213 E0.2406 G1 X146.183 Y154.683 E0.2539 G1 X146.714 Y154.217 E0.2672 G1 X147.301 Y153.825 E0.2805 G1 X147.934 Y153.512 E0.2938 G1 X148.603 Y153.285 E0.3070 G1 X149.295 Y153.147 E0.3203 G1 X150.000 Y153.101 E0.3336 G1 X150.705 Y153.147 E0.3469 G1 X151.397 Y153.285 E0.3602 G1 X152.066 Y153.512 E0.3735 G1 X152.699 Y153.825 E0.3867 G1 X153.287 Y154.217 E0.4000 G1 X153.818 Y154.683 E0.4133 G1 X154.283 Y155.213 E0.4266 G1 X154.675 Y155.801 E0.4399 G1 X154.988 Y156.434 E0.4532 G1 X155.215 Y157.103 E0.4665 G1 X155.352 Y157.795 E0.4797 G1 X155.400 Y158.520 E0.4934 G1 X155.400 Y163.480 E0.5867 G1 X155.378 Y163.812 E0.5930 G1 X155.317 Y164.119 E0.5989 G1 X155.217 Y164.416 E0.6047 G1 X155.078 Y164.697 E0.6106 G1 X154.904 Y164.957 E0.6165 G1 X154.698 Y165.192 E0.6224 G1 X154.462 Y165.399 E0.6283 G1 X154.202 Y165.573 E0.6342 G1 X153.921 Y165.711 E0.6401 G1 X153.605 Y165.819 E0.6464 G1 X153.605 Y164.709 E0.6672 G1 X154.205 Y163.928 E0.6857 G1 X154.690 Y162.757 E0.7096 G1 X154.855 Y161.500 E0.7334 G1 X154.690 Y160.243 E0.7573 G1 X154.205 Y159.072 E0.7811 G1 X153.433 Y158.067 E0.8050 G1 X152.428 Y157.295 E0.8288 G1 X151.257 Y156.810 E0.8526 G1 X150.000 Y156.645 E0.8765 G1 X148.743 Y156.810 E0.9003 G1 X147.572 Y157.295 E0.9242 G1 X146.567 Y158.067 E0.9480 G1 X145.795 Y159.072 E0.9718 G1 X145.310 Y160.243 E0.9957 G1 X145.145 Y161.500 E1.0195 G1 X145.310 Y162.757 E1.0434 G1 X145.789 Y163.914 E1.0669 G1 X145.795 Y163.928 F1350 G1 X146.395 Y164.709 F1350 ; outer perimeter G1 X146.795 Y164.573 F4800 G92 E0 G1 X146.795 Y166.284 E0.0322 F900 G1 X146.631 Y166.271 E0.0353 G1 X146.272 Y166.199 E0.0422 G1 X145.925 Y166.082 E0.0490 G1 X145.598 Y165.920 E0.0559 G1 X145.294 Y165.717 E0.0628 G1 X145.019 Y165.476 E0.0697 G1 X144.778 Y165.201 E0.0765 G1 X144.575 Y164.897 E0.0834 G1 X144.413 Y164.569 E0.0903 G1 X144.296 Y164.223 E0.0972 G1 X144.224 Y163.865 E0.1040 G1 X144.200 Y163.493 E0.1110 G1 X144.200 Y158.507 E0.2048 G1 X144.250 Y157.743 E0.2192 G1 X144.398 Y156.999 E0.2335 G1 X144.642 Y156.281 E0.2478 G1 X144.977 Y155.600 E0.2621 G1 X145.399 Y154.969 E0.2763 G1 X145.899 Y154.399 E0.2906 G1 X146.469 Y153.899 E0.3049 G1 X147.100 Y153.477 E0.3191 G1 X147.781 Y153.142 E0.3334 G1 X148.499 Y152.898 E0.3477 G1 X149.243 Y152.750 E0.3619 G1 X150.000 Y152.700 E0.3762 G1 X150.757 Y152.750 E0.3905 G1 X151.501 Y152.898 E0.4048 G1 X152.219 Y153.142 E0.4190 G1 X152.900 Y153.477 E0.4333 G1 X153.531 Y153.899 E0.4476 G1 X154.101 Y154.399 E0.4618 G1 X154.601 Y154.969 E0.4761 G1 X155.023 Y155.600 E0.4904 G1 X155.358 Y156.281 E0.5046 G1 X155.602 Y156.999 E0.5189 G1 X155.750 Y157.743 E0.5332 G1 X155.800 Y158.507 E0.5476 G1 X155.800 Y163.494 E0.6414 G1 X155.776 Y163.865 E0.6484 G1 X155.704 Y164.223 E0.6553 G1 X155.587 Y164.569 E0.6621 G1 X155.425 Y164.897 E0.6690 G1 X155.222 Y165.201 E0.6759 G1 X154.981 Y165.476 E0.6828 G1 X154.706 Y165.717 E0.6896 G1 X154.402 Y165.920 E0.6965 G1 X154.075 Y166.082 E0.7034 G1 X153.728 Y166.199 E0.7103 G1 X153.369 Y166.271 E0.7172 G1 X153.205 Y166.284 E0.7202 G1 X153.205 Y164.573 E0.7524 G1 X153.855 Y163.726 E0.7725 G1 X154.300 Y162.652 E0.7944 G1 X154.452 Y161.500 E0.8162 G1 X154.300 Y160.348 E0.8381 G1 X153.855 Y159.274 E0.8600 G1 X153.148 Y158.352 E0.8818 G1 X152.226 Y157.645 E0.9037 G1 X151.152 Y157.200 E0.9255 G1 X150.000 Y157.048 E0.9474 G1 X148.848 Y157.200 E0.9693 G1 X147.774 Y157.645 E0.9911 G1 X146.852 Y158.352 E1.0130 G1 X146.145 Y159.274 E1.0348 G1 X145.700 Y160.348 E1.0567 G1 X145.548 Y161.500 E1.0786 G1 X145.700 Y162.652 E1.1004 G1 X146.145 Y163.726 E1.1223 G1 X146.186 Y163.780 E1.1236 G1 X146.795 Y164.573 F900 ; gap fill G1 X144.954 Y163.622 F4800 G92 E0 G1 X145.220 Y163.888 E0.0071 F1440 G1 X145.263 Y163.861 E0.0080 G1 X145.368 Y163.796 F1440 G1 X145.138 Y163.240 F1440 G1 X144.944 Y163.046 F1440 G92 E0 G1 E-6.5000 F1500 G1 X154.930 Y163.981 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.665 Y163.716 E0.0070 F1440 G1 X154.815 Y163.354 E0.0144 G1 X154.831 Y163.316 F1440 G1 X155.052 Y163.537 F1440 G1 X155.056 Y163.469 F1440 G1 X155.056 Y162.976 F1440 G1 X154.996 Y162.916 F1440 ; solid layer G1 X152.083 Y154.346 F4800 G92 E0 G1 X154.154 Y156.417 E0.0551 F1440 G1 X154.303 Y156.718 E0.0614 G1 X154.498 Y157.295 E0.0729 G1 X154.506 Y157.335 E0.0736 G1 X151.165 Y153.994 E0.1625 G1 X150.608 Y153.883 E0.1732 G1 X150.480 Y153.874 E0.1756 G1 X154.626 Y158.020 E0.2859 G1 X154.653 Y158.441 E0.2938 G1 X153.961 Y157.539 E0.3152 G1 X152.801 Y156.649 E0.3427 G1 X152.610 Y156.570 E0.3466 G1 X149.890 Y153.850 E0.4190 G1 X149.392 Y153.883 E0.4284 G1 X149.363 Y153.889 E0.4289 G1 X151.645 Y156.170 E0.4896 G1 X151.450 Y156.089 E0.4936 G1 X150.930 Y156.021 E0.5035 G1 X148.891 Y153.982 E0.5577 G1 X148.795 Y154.002 E0.5595 G1 X148.459 Y154.116 E0.5662 G1 X150.278 Y155.935 E0.6146 G1 X150.000 Y155.898 E0.6199 G1 X149.714 Y155.936 E0.6253 G1 X148.055 Y154.278 E0.6694 G1 X147.676 Y154.464 E0.6774 G1 X149.214 Y156.002 E0.7183 G1 X148.714 Y156.068 E0.7278 G1 X147.337 Y154.691 E0.7644 G1 X147.165 Y154.805 E0.7683 G1 X147.016 Y154.936 E0.7720 G1 X148.281 Y156.201 E0.8057 G1 X147.881 Y156.366 E0.8138 G1 X146.715 Y155.200 E0.8448 G1 X146.707 Y155.207 E0.8450 G1 X146.450 Y155.500 E0.8524 G1 X147.481 Y156.532 E0.8798 G1 X147.199 Y156.649 E0.8856 G1 X147.105 Y156.721 E0.8878 G1 X146.202 Y155.819 E0.9118 G1 X145.976 Y156.158 E0.9195 G1 X146.785 Y156.967 E0.9410 G1 X146.465 Y157.213 E0.9486 G1 X145.787 Y156.535 E0.9666 G1 X145.697 Y156.718 E0.9704 G1 X145.623 Y156.937 E0.9748 G1 X146.145 Y157.458 E0.9887 G1 X146.039 Y157.539 E0.9912 G1 X145.874 Y157.754 E0.9962 G1 X145.487 Y157.367 E1.0065 G1 X145.436 Y157.623 E1.0115 G1 X145.393 Y157.838 F1440 G1 X145.629 Y158.074 F1440 G1 X145.383 Y158.394 F1440 G1 X145.352 Y158.363 F1440 G92 E0 G1 E-6.5000 F1500 ; layer 2, Z = 0.500 M106 S255 ; tool H0.200 W0.400 ; inner perimeter G1 X145.000 Y158.533 F4800 G1 Z0.500 F300 G1 E0.0000 F1500 G92 E0 G1 X145.045 Y157.848 E0.0086 F1898 G1 X145.172 Y157.206 E0.0168 G1 X145.383 Y156.587 E0.0250 G1 X145.672 Y156.001 E0.0332 G1 X146.035 Y155.458 E0.0414 G1 X146.466 Y154.966 E0.0496 G1 X146.957 Y154.535 E0.0578 G1 X147.501 Y154.172 E0.0660 G1 X148.087 Y153.883 E0.0742 G1 X148.706 Y153.672 E0.0824 G1 X149.348 Y153.545 E0.0906 G1 X150.000 Y153.502 E0.0988 G1 X150.652 Y153.545 E0.1070 G1 X151.294 Y153.672 E0.1152 G1 X151.913 Y153.883 E0.1234 G1 X152.499 Y154.172 E0.1316 G1 X153.042 Y154.535 E0.1398 G1 X153.534 Y154.966 E0.1480 G1 X153.965 Y155.458 E0.1562 G1 X154.328 Y156.001 E0.1644 G1 X154.617 Y156.587 E0.1726 G1 X154.828 Y157.206 E0.1808 G1 X154.955 Y157.848 E0.1890 G1 X155.000 Y158.533 E0.1976 G1 X155.000 Y159.190 E0.2058 G1 X154.710 Y159.248 E0.2095 G1 X154.554 Y158.871 E0.2146 G1 X153.718 Y157.782 E0.2319 G1 X152.629 Y156.946 E0.2491 G1 X151.361 Y156.421 E0.2663 G1 X150.000 Y156.241 E0.2835 G1 X148.639 Y156.421 E0.3007 G1 X147.371 Y156.946 E0.3179 G1 X146.282 Y157.782 E0.3351 G1 X145.446 Y158.871 E0.3524 G1 X145.308 Y159.204 E0.3569 G1 X145.290 Y159.248 F1898 G1 X145.000 Y159.190 F1898 G1 X145.000 Y158.533 F1898 G1 X145.458 Y164.145 F4800 G92 E0 G1 X145.974 Y164.818 E0.0106 F1898 G1 X145.736 Y165.041 E0.0147 G1 X145.586 Y164.909 E0.0172 G1 X145.555 Y164.873 E0.0178 G1 X145.414 Y164.713 F1898 G1 X145.269 Y164.496 F1898 G1 X145.181 Y164.317 F1898 G1 X145.458 Y164.145 F1898 G92 E0 G1 E-6.5000 F1500 G1 X154.026 Y164.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.542 Y164.145 E0.0106 F1898 G1 X154.819 Y164.317 E0.0147 G1 X154.731 Y164.496 E0.0172 G1 X154.705 Y164.536 E0.0178 G1 X154.586 Y164.713 F1898 G1 X154.414 Y164.909 F1898 G1 X154.264 Y165.041 F1898 G1 X154.026 Y164.818 F1898 G1 X153.605 Y164.709 F4800 G92 E0 G1 X154.205 Y163.928 E0.0123 F1898 G1 X154.690 Y162.757 E0.0282 G1 X154.855 Y161.500 E0.0441 G1 X154.690 Y160.243 E0.0600 G1 X154.205 Y159.072 E0.0759 G1 X153.433 Y158.067 E0.0918 G1 X152.428 Y157.295 E0.1077 G1 X151.257 Y156.810 E0.1236 G1 X150.000 Y156.645 E0.1395 G1 X148.743 Y156.810 E0.1554 G1 X147.572 Y157.295 E0.1713 G1 X146.567 Y158.067 E0.1872 G1 X145.795 Y159.072 E0.2031 G1 X145.310 Y160.243 E0.2190 G1 X145.145 Y161.500 E0.2349 G1 X145.310 Y162.757 E0.2508 G1 X145.795 Y163.928 E0.2667 G1 X146.395 Y164.709 E0.2790 G1 X146.395 Y165.819 E0.2929 G1 X146.079 Y165.711 E0.2971 G1 X145.798 Y165.573 E0.3010 G1 X145.538 Y165.399 E0.3050 G1 X145.302 Y165.192 E0.3089 G1 X145.096 Y164.957 E0.3128 G1 X144.922 Y164.697 E0.3167 G1 X144.783 Y164.416 E0.3207 G1 X144.683 Y164.119 E0.3246 G1 X144.622 Y163.812 E0.3285 G1 X144.600 Y163.480 E0.3327 G1 X144.600 Y158.520 E0.3949 G1 X144.647 Y157.795 E0.4040 G1 X144.785 Y157.103 E0.4129 G1 X145.012 Y156.434 E0.4217 G1 X145.325 Y155.801 E0.4306 G1 X145.717 Y155.213 E0.4394 G1 X146.183 Y154.683 E0.4483 G1 X146.714 Y154.217 E0.4571 G1 X147.301 Y153.825 E0.4660 G1 X147.934 Y153.512 E0.4749 G1 X148.603 Y153.285 E0.4837 G1 X149.295 Y153.147 E0.4926 G1 X150.000 Y153.101 E0.5014 G1 X150.705 Y153.147 E0.5103 G1 X151.397 Y153.285 E0.5191 G1 X152.066 Y153.512 E0.5280 G1 X152.699 Y153.825 E0.5368 G1 X153.287 Y154.217 E0.5457 G1 X153.818 Y154.683 E0.5546 G1 X154.283 Y155.213 E0.5634 G1 X154.675 Y155.801 E0.5723 G1 X154.988 Y156.434 E0.5811 G1 X155.215 Y157.103 E0.5900 G1 X155.352 Y157.795 E0.5988 G1 X155.400 Y158.520 E0.6079 G1 X155.400 Y163.480 E0.6701 G1 X155.378 Y163.812 E0.6743 G1 X155.317 Y164.119 E0.6782 G1 X155.217 Y164.416 E0.6822 G1 X155.078 Y164.697 E0.6861 G1 X154.904 Y164.957 E0.6900 G1 X154.698 Y165.192 E0.6939 G1 X154.462 Y165.399 E0.6979 G1 X154.202 Y165.573 E0.7018 G1 X153.921 Y165.711 E0.7057 G1 X153.605 Y165.819 E0.7099 G1 X153.605 Y165.709 E0.7113 G1 X153.605 Y164.709 F1898 ; outer perimeter G1 X153.205 Y164.573 F4800 G92 E0 G1 X153.855 Y163.726 E0.0134 F1265 G1 X154.300 Y162.652 E0.0280 G1 X154.452 Y161.500 E0.0425 G1 X154.300 Y160.348 E0.0571 G1 X153.855 Y159.274 E0.0717 G1 X153.148 Y158.352 E0.0863 G1 X152.226 Y157.645 E0.1008 G1 X151.152 Y157.200 E0.1154 G1 X150.000 Y157.048 E0.1300 G1 X148.848 Y157.200 E0.1446 G1 X147.774 Y157.645 E0.1591 G1 X146.852 Y158.352 E0.1737 G1 X146.145 Y159.274 E0.1883 G1 X145.700 Y160.348 E0.2028 G1 X145.548 Y161.500 E0.2174 G1 X145.700 Y162.652 E0.2320 G1 X146.145 Y163.726 E0.2466 G1 X146.795 Y164.573 E0.2600 G1 X146.795 Y166.284 E0.2814 G1 X146.631 Y166.271 E0.2835 G1 X146.272 Y166.199 E0.2881 G1 X145.925 Y166.082 E0.2927 G1 X145.598 Y165.920 E0.2972 G1 X145.294 Y165.717 E0.3018 G1 X145.019 Y165.476 E0.3064 G1 X144.778 Y165.201 E0.3110 G1 X144.575 Y164.897 E0.3156 G1 X144.413 Y164.569 E0.3202 G1 X144.296 Y164.223 E0.3247 G1 X144.224 Y163.865 E0.3293 G1 X144.200 Y163.493 E0.3340 G1 X144.200 Y158.507 E0.3965 G1 X144.250 Y157.743 E0.4061 G1 X144.398 Y156.999 E0.4156 G1 X144.642 Y156.281 E0.4251 G1 X144.977 Y155.600 E0.4347 G1 X145.399 Y154.969 E0.4442 G1 X145.899 Y154.399 E0.4537 G1 X146.469 Y153.899 E0.4632 G1 X147.100 Y153.477 E0.4727 G1 X147.781 Y153.142 E0.4822 G1 X148.499 Y152.898 E0.4917 G1 X149.243 Y152.750 E0.5013 G1 X150.000 Y152.700 E0.5108 G1 X150.757 Y152.750 E0.5203 G1 X151.501 Y152.898 E0.5298 G1 X152.219 Y153.142 E0.5393 G1 X152.900 Y153.477 E0.5488 G1 X153.531 Y153.899 E0.5583 G1 X154.101 Y154.399 E0.5678 G1 X154.601 Y154.969 E0.5774 G1 X155.023 Y155.600 E0.5869 G1 X155.358 Y156.281 E0.5964 G1 X155.602 Y156.999 E0.6059 G1 X155.750 Y157.743 E0.6154 G1 X155.800 Y158.507 E0.6250 G1 X155.800 Y163.494 E0.6875 G1 X155.776 Y163.865 E0.6922 G1 X155.704 Y164.223 E0.6968 G1 X155.587 Y164.569 E0.7014 G1 X155.425 Y164.897 E0.7060 G1 X155.222 Y165.201 E0.7105 G1 X154.981 Y165.476 E0.7151 G1 X154.706 Y165.717 E0.7197 G1 X154.402 Y165.920 E0.7243 G1 X154.075 Y166.082 E0.7289 G1 X153.728 Y166.199 E0.7335 G1 X153.369 Y166.271 E0.7381 G1 X153.205 Y166.284 E0.7401 G1 X153.205 Y165.573 E0.7490 G1 X153.205 Y164.573 F1265 ; gap fill G1 X154.780 Y163.888 F4800 G92 E0 G1 X154.940 Y163.727 E0.0028 F2025 G1 X155.046 Y163.622 F2025 G1 X155.056 Y163.469 F2025 G1 X155.056 Y163.046 F2025 G1 X154.862 Y163.240 F2025 G92 E0 G1 E-6.5000 F1500 G1 X145.335 Y163.716 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.070 Y163.981 E0.0047 F2025 G1 X145.013 Y164.016 E0.0055 G1 X144.964 Y163.767 E0.0087 G1 X144.960 Y163.706 E0.0095 G1 X144.948 Y163.537 F2025 G1 X145.170 Y163.316 F2025 G1 X145.004 Y162.916 F2025 G1 X144.944 Y162.976 F2025 ; solid layer G1 X145.846 Y156.417 F4800 G92 E0 G1 X147.917 Y154.346 E0.0367 F2025 G1 X148.218 Y154.197 E0.0409 G1 X148.795 Y154.002 E0.0486 G1 X148.835 Y153.994 E0.0491 G1 X145.494 Y157.335 E0.1084 G1 X145.383 Y157.892 E0.1155 G1 X145.374 Y158.020 E0.1171 G1 X149.520 Y153.874 E0.1906 G1 X150.000 Y153.843 E0.1966 G1 X150.110 Y153.850 E0.1980 G1 X147.390 Y156.570 E0.2462 G1 X148.356 Y156.170 E0.2594 G1 X150.637 Y153.889 E0.2998 G1 X151.109 Y153.982 E0.3058 G1 X149.070 Y156.021 E0.3420 G1 X149.722 Y155.935 E0.3502 G1 X151.541 Y154.116 E0.3825 G1 X151.782 Y154.197 E0.3857 G1 X151.945 Y154.278 E0.3880 G1 X150.286 Y155.936 E0.4174 G1 X150.786 Y156.002 E0.4237 G1 X152.324 Y154.464 E0.4510 G1 X152.329 Y154.467 E0.4510 G1 X152.663 Y154.691 E0.4561 G1 X151.286 Y156.068 E0.4805 G1 X151.450 Y156.089 E0.4826 G1 X151.719 Y156.201 E0.4862 G1 X152.984 Y154.936 E0.5087 G1 X153.285 Y155.200 E0.5137 G1 X152.119 Y156.366 E0.5344 G1 X152.519 Y156.532 E0.5398 G1 X153.551 Y155.500 E0.5581 G1 X153.695 Y155.665 E0.5609 G1 X153.798 Y155.819 E0.5632 G1 X152.895 Y156.721 E0.5792 G1 X153.215 Y156.967 E0.5842 G1 X154.024 Y156.158 E0.5986 G1 X154.033 Y156.171 E0.5988 G1 X154.213 Y156.535 E0.6039 G1 X153.535 Y157.213 E0.6159 G1 X153.856 Y157.458 E0.6210 G1 X154.377 Y156.937 E0.6302 G1 X154.498 Y157.295 E0.6349 G1 X154.513 Y157.367 E0.6359 G1 X154.126 Y157.754 E0.6427 G1 X154.312 Y157.997 E0.6466 G1 X154.371 Y158.074 F2025 G1 X154.607 Y157.838 F2025 G1 X154.617 Y157.892 F2025 G1 X154.648 Y158.363 F2025 G1 X154.617 Y158.394 F2025 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X154.264 Y146.041 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.026 Y145.818 E0.0041 F1898 G1 X154.542 Y145.145 E0.0147 G1 X154.752 Y145.275 E0.0178 G1 X154.819 Y145.317 F1898 G1 X154.731 Y145.496 F1898 G1 X154.586 Y145.713 F1898 G1 X154.414 Y145.909 F1898 G1 X154.264 Y146.041 F1898 G1 X154.710 Y140.248 F4800 G92 E0 G1 X154.554 Y139.871 E0.0051 F1898 G1 X153.718 Y138.782 E0.0223 G1 X152.629 Y137.946 E0.0395 G1 X151.361 Y137.421 E0.0568 G1 X150.000 Y137.241 E0.0740 G1 X148.639 Y137.421 E0.0912 G1 X147.371 Y137.946 E0.1084 G1 X146.282 Y138.782 E0.1256 G1 X145.446 Y139.871 E0.1428 G1 X145.290 Y140.248 E0.1480 G1 X145.000 Y140.190 E0.1517 G1 X145.000 Y139.533 E0.1599 G1 X145.045 Y138.848 E0.1685 G1 X145.172 Y138.206 E0.1767 G1 X145.383 Y137.587 E0.1849 G1 X145.672 Y137.001 E0.1931 G1 X146.035 Y136.458 E0.2013 G1 X146.466 Y135.966 E0.2095 G1 X146.957 Y135.535 E0.2177 G1 X147.501 Y135.172 E0.2259 G1 X148.087 Y134.883 E0.2341 G1 X148.706 Y134.672 E0.2423 G1 X149.348 Y134.545 E0.2505 G1 X150.000 Y134.502 E0.2587 G1 X150.652 Y134.545 E0.2669 G1 X151.294 Y134.672 E0.2751 G1 X151.913 Y134.883 E0.2833 G1 X152.499 Y135.172 E0.2915 G1 X153.042 Y135.535 E0.2997 G1 X153.534 Y135.966 E0.3079 G1 X153.965 Y136.458 E0.3161 G1 X154.328 Y137.001 E0.3243 G1 X154.617 Y137.587 E0.3325 G1 X154.828 Y138.206 E0.3407 G1 X154.955 Y138.848 E0.3489 G1 X154.997 Y139.486 E0.3569 G1 X155.000 Y139.533 F1898 G1 X155.000 Y140.190 F1898 G1 X154.710 Y140.248 F1898 G92 E0 G1 E-6.5000 F1500 G1 X145.974 Y145.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.736 Y146.041 E0.0041 F1898 G1 X145.586 Y145.909 E0.0066 G1 X145.414 Y145.713 E0.0099 G1 X145.269 Y145.496 E0.0131 G1 X145.181 Y145.317 E0.0156 G1 X145.329 Y145.225 E0.0178 G1 X145.458 Y145.145 F1898 G1 X145.974 Y145.818 F1898 G1 X146.395 Y145.709 F4800 G92 E0 G1 X146.395 Y146.819 E0.0139 F1898 G1 X146.079 Y146.711 E0.0181 G1 X145.798 Y146.573 E0.0220 G1 X145.538 Y146.399 E0.0260 G1 X145.302 Y146.192 E0.0299 G1 X145.096 Y145.957 E0.0338 G1 X144.922 Y145.697 E0.0377 G1 X144.783 Y145.416 E0.0417 G1 X144.683 Y145.119 E0.0456 G1 X144.622 Y144.812 E0.0495 G1 X144.600 Y144.480 E0.0537 G1 X144.600 Y139.520 E0.1159 G1 X144.647 Y138.795 E0.1250 G1 X144.785 Y138.103 E0.1339 G1 X145.012 Y137.434 E0.1427 G1 X145.325 Y136.801 E0.1516 G1 X145.717 Y136.213 E0.1604 G1 X146.183 Y135.683 E0.1693 G1 X146.714 Y135.217 E0.1781 G1 X147.301 Y134.825 E0.1870 G1 X147.934 Y134.512 E0.1958 G1 X148.603 Y134.285 E0.2047 G1 X149.295 Y134.147 E0.2136 G1 X150.000 Y134.101 E0.2224 G1 X150.705 Y134.147 E0.2313 G1 X151.397 Y134.285 E0.2401 G1 X152.066 Y134.512 E0.2490 G1 X152.699 Y134.825 E0.2578 G1 X153.287 Y135.217 E0.2667 G1 X153.818 Y135.683 E0.2755 G1 X154.283 Y136.213 E0.2844 G1 X154.675 Y136.801 E0.2933 G1 X154.988 Y137.434 E0.3021 G1 X155.215 Y138.103 E0.3110 G1 X155.352 Y138.795 E0.3198 G1 X155.400 Y139.520 E0.3289 G1 X155.400 Y144.480 E0.3911 G1 X155.378 Y144.812 E0.3953 G1 X155.317 Y145.119 E0.3992 G1 X155.217 Y145.416 E0.4032 G1 X155.078 Y145.697 E0.4071 G1 X154.904 Y145.957 E0.4110 G1 X154.698 Y146.192 E0.4149 G1 X154.462 Y146.399 E0.4189 G1 X154.202 Y146.573 E0.4228 G1 X153.921 Y146.711 E0.4267 G1 X153.605 Y146.819 E0.4309 G1 X153.605 Y145.709 E0.4448 G1 X154.205 Y144.928 E0.4572 G1 X154.690 Y143.757 E0.4731 G1 X154.855 Y142.500 E0.4890 G1 X154.690 Y141.243 E0.5048 G1 X154.205 Y140.072 E0.5207 G1 X153.433 Y139.067 E0.5366 G1 X152.428 Y138.295 E0.5525 G1 X151.257 Y137.810 E0.5684 G1 X150.000 Y137.645 E0.5843 G1 X148.743 Y137.810 E0.6002 G1 X147.572 Y138.295 E0.6161 G1 X146.567 Y139.067 E0.6320 G1 X145.795 Y140.072 E0.6479 G1 X145.310 Y141.243 E0.6638 G1 X145.145 Y142.500 E0.6797 G1 X145.310 Y143.757 E0.6956 G1 X145.789 Y144.914 E0.7113 G1 X145.795 Y144.928 F1898 G1 X146.395 Y145.709 F1898 ; outer perimeter G1 X146.795 Y145.573 F4800 G92 E0 G1 X146.795 Y147.284 E0.0215 F1265 G1 X146.631 Y147.271 E0.0235 G1 X146.272 Y147.199 E0.0281 G1 X145.925 Y147.082 E0.0327 G1 X145.598 Y146.920 E0.0373 G1 X145.294 Y146.717 E0.0419 G1 X145.019 Y146.476 E0.0464 G1 X144.778 Y146.201 E0.0510 G1 X144.575 Y145.897 E0.0556 G1 X144.413 Y145.569 E0.0602 G1 X144.296 Y145.223 E0.0648 G1 X144.224 Y144.865 E0.0694 G1 X144.200 Y144.493 E0.0740 G1 X144.200 Y139.507 E0.1366 G1 X144.250 Y138.743 E0.1462 G1 X144.398 Y137.999 E0.1557 G1 X144.642 Y137.281 E0.1652 G1 X144.977 Y136.600 E0.1747 G1 X145.399 Y135.969 E0.1842 G1 X145.899 Y135.399 E0.1937 G1 X146.469 Y134.899 E0.2032 G1 X147.100 Y134.477 E0.2128 G1 X147.781 Y134.142 E0.2223 G1 X148.499 Y133.898 E0.2318 G1 X149.243 Y133.750 E0.2413 G1 X150.000 Y133.700 E0.2508 G1 X150.757 Y133.750 E0.2603 G1 X151.501 Y133.898 E0.2698 G1 X152.219 Y134.142 E0.2793 G1 X152.900 Y134.477 E0.2889 G1 X153.531 Y134.899 E0.2984 G1 X154.101 Y135.399 E0.3079 G1 X154.601 Y135.969 E0.3174 G1 X155.023 Y136.600 E0.3269 G1 X155.358 Y137.281 E0.3364 G1 X155.602 Y137.999 E0.3459 G1 X155.750 Y138.743 E0.3555 G1 X155.800 Y139.507 E0.3650 G1 X155.800 Y144.494 E0.4276 G1 X155.776 Y144.865 E0.4323 G1 X155.704 Y145.223 E0.4368 G1 X155.587 Y145.569 E0.4414 G1 X155.425 Y145.897 E0.4460 G1 X155.222 Y146.201 E0.4506 G1 X154.981 Y146.476 E0.4552 G1 X154.706 Y146.717 E0.4598 G1 X154.402 Y146.920 E0.4643 G1 X154.075 Y147.082 E0.4689 G1 X153.728 Y147.199 E0.4735 G1 X153.369 Y147.271 E0.4781 G1 X153.205 Y147.284 E0.4802 G1 X153.205 Y145.573 E0.5016 G1 X153.855 Y144.726 E0.5150 G1 X154.300 Y143.652 E0.5296 G1 X154.452 Y142.500 E0.5442 G1 X154.300 Y141.348 E0.5587 G1 X153.855 Y140.274 E0.5733 G1 X153.148 Y139.352 E0.5879 G1 X152.226 Y138.645 E0.6024 G1 X151.152 Y138.200 E0.6170 G1 X150.000 Y138.048 E0.6316 G1 X148.848 Y138.200 E0.6462 G1 X147.774 Y138.645 E0.6607 G1 X146.852 Y139.352 E0.6753 G1 X146.145 Y140.274 E0.6899 G1 X145.700 Y141.348 E0.7045 G1 X145.548 Y142.500 E0.7190 G1 X145.700 Y143.652 E0.7336 G1 X146.145 Y144.726 E0.7482 G1 X146.186 Y144.780 E0.7490 G1 X146.795 Y145.573 F1265 ; gap fill G1 X145.267 Y144.551 F4800 G92 E0 G1 X144.978 Y144.840 E0.0051 F2025 G1 X144.964 Y144.767 E0.0060 G1 X144.953 Y144.614 E0.0080 G1 X144.944 Y144.469 F2025 G1 X144.944 Y144.308 F2025 G1 X145.101 Y144.151 F2025 G1 X144.975 Y143.846 F2025 G1 X144.959 Y143.727 F2025 G1 X144.944 Y143.742 F2025 G92 E0 G1 E-6.5000 F1500 G1 X155.025 Y143.843 F4800 G1 E0.0000 F1500 G92 E0 G1 X155.056 Y143.813 E0.0005 F2025 G1 X155.056 Y144.378 E0.0076 G1 X155.050 Y144.384 E0.0077 G1 X154.636 Y144.798 F2025 G1 X154.985 Y145.015 F2025 G1 X154.988 Y145.012 F2025 ; solid layer G1 X154.516 Y139.262 F4800 G92 E0 G1 X154.634 Y139.144 E0.0021 F2025 G1 X154.617 Y138.892 E0.0053 G1 X154.568 Y138.644 E0.0084 G1 X154.270 Y138.942 E0.0137 G1 X154.024 Y138.622 E0.0188 G1 X154.461 Y138.185 E0.0265 G1 X154.318 Y137.763 E0.0321 G1 X153.724 Y138.357 E0.0427 G1 X153.403 Y138.111 E0.0477 G1 X154.136 Y137.379 E0.0607 G1 X154.033 Y137.171 E0.0636 G1 X153.931 Y137.018 E0.0659 G1 X153.083 Y137.866 E0.0809 G1 X152.801 Y137.649 E0.0854 G1 X152.754 Y137.629 E0.0860 G1 X153.704 Y136.679 E0.1029 G1 X153.695 Y136.665 E0.1031 G1 X153.442 Y136.376 E0.1079 G1 X152.354 Y137.464 E0.1272 G1 X151.954 Y137.298 E0.1327 G1 X153.161 Y136.091 E0.1541 G1 X152.860 Y135.827 E0.1591 G1 X151.554 Y137.132 E0.1822 G1 X151.450 Y137.089 E0.1837 G1 X151.080 Y137.041 E0.1883 G1 X152.524 Y135.597 E0.2139 G1 X152.329 Y135.467 E0.2169 G1 X152.168 Y135.387 E0.2191 G1 X150.580 Y136.975 E0.2473 G1 X150.080 Y136.909 E0.2536 G1 X151.789 Y135.201 E0.2839 G1 X151.782 Y135.197 E0.2840 G1 X151.367 Y135.056 E0.2895 G1 X149.453 Y136.970 E0.3234 G1 X148.802 Y137.056 E0.3317 G1 X150.914 Y134.944 E0.3691 G1 X150.608 Y134.883 E0.3731 G1 X150.422 Y134.871 E0.3754 G1 X148.664 Y136.628 E0.4066 G1 X147.957 Y137.335 F2025 G1 X146.186 Y136.843 F4800 G92 E0 G1 X147.344 Y135.686 E0.0205 F2025 G1 X147.672 Y135.467 E0.0255 G1 X148.218 Y135.197 E0.0331 G1 X148.490 Y135.105 E0.0367 G1 X145.605 Y137.990 E0.0879 G1 X145.502 Y138.295 E0.0919 G1 X145.411 Y138.750 E0.0977 G1 X149.250 Y134.911 E0.1658 G1 X149.392 Y134.883 E0.1676 G1 X149.875 Y134.851 E0.1737 G1 X146.677 Y138.050 E0.2304 G1 X146.039 Y138.539 E0.2405 G1 X145.987 Y138.606 E0.2416 G1 X145.550 Y139.177 F2025 G1 X145.351 Y139.375 F2025 G92 E0 G1 E-6.5000 F1500 ; layer 3, Z = 0.700 ; inner perimeter G1 X145.000 Y139.533 F4800 G1 Z0.700 F300 G1 E0.0000 F1500 G92 E0 G1 X145.045 Y138.848 E0.0086 F1911 G1 X145.172 Y138.206 E0.0168 G1 X145.383 Y137.587 E0.0250 G1 X145.672 Y137.001 E0.0332 G1 X146.035 Y136.458 E0.0414 G1 X146.466 Y135.966 E0.0496 G1 X146.957 Y135.535 E0.0578 G1 X147.501 Y135.172 E0.0660 G1 X148.087 Y134.883 E0.0742 G1 X148.706 Y134.672 E0.0824 G1 X149.348 Y134.545 E0.0906 G1 X150.000 Y134.502 E0.0988 G1 X150.652 Y134.545 E0.1070 G1 X151.294 Y134.672 E0.1152 G1 X151.913 Y134.883 E0.1234 G1 X152.499 Y135.172 E0.1316 G1 X153.042 Y135.535 E0.1398 G1 X153.534 Y135.966 E0.1480 G1 X153.965 Y136.458 E0.1562 G1 X154.328 Y137.001 E0.1644 G1 X154.617 Y137.587 E0.1726 G1 X154.828 Y138.206 E0.1808 G1 X154.955 Y138.848 E0.1890 G1 X155.000 Y139.533 E0.1976 G1 X155.000 Y140.190 E0.2058 G1 X154.710 Y140.248 E0.2095 G1 X154.554 Y139.871 E0.2146 G1 X153.718 Y138.782 E0.2319 G1 X152.629 Y137.946 E0.2491 G1 X151.361 Y137.421 E0.2663 G1 X150.000 Y137.241 E0.2835 G1 X148.639 Y137.421 E0.3007 G1 X147.371 Y137.946 E0.3179 G1 X146.282 Y138.782 E0.3351 G1 X145.446 Y139.871 E0.3524 G1 X145.308 Y140.204 E0.3569 G1 X145.290 Y140.248 F1911 G1 X145.000 Y140.190 F1911 G1 X145.000 Y139.533 F1911 G1 X145.458 Y145.145 F4800 G92 E0 G1 X145.974 Y145.818 E0.0106 F1911 G1 X145.736 Y146.041 E0.0147 G1 X145.586 Y145.909 E0.0172 G1 X145.555 Y145.873 E0.0178 G1 X145.414 Y145.713 F1911 G1 X145.269 Y145.496 F1911 G1 X145.181 Y145.317 F1911 G1 X145.458 Y145.145 F1911 G92 E0 G1 E-6.5000 F1500 G1 X154.026 Y145.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.542 Y145.145 E0.0106 F1911 G1 X154.819 Y145.317 E0.0147 G1 X154.731 Y145.496 E0.0172 G1 X154.705 Y145.536 E0.0178 G1 X154.586 Y145.713 F1911 G1 X154.414 Y145.909 F1911 G1 X154.264 Y146.041 F1911 G1 X154.026 Y145.818 F1911 G1 X153.605 Y145.709 F4800 G92 E0 G1 X154.205 Y144.928 E0.0123 F1911 G1 X154.690 Y143.757 E0.0282 G1 X154.855 Y142.500 E0.0441 G1 X154.690 Y141.243 E0.0600 G1 X154.205 Y140.072 E0.0759 G1 X153.433 Y139.067 E0.0918 G1 X152.428 Y138.295 E0.1077 G1 X151.257 Y137.810 E0.1236 G1 X150.000 Y137.645 E0.1395 G1 X148.743 Y137.810 E0.1554 G1 X147.572 Y138.295 E0.1713 G1 X146.567 Y139.067 E0.1872 G1 X145.795 Y140.072 E0.2031 G1 X145.310 Y141.243 E0.2190 G1 X145.145 Y142.500 E0.2349 G1 X145.310 Y143.757 E0.2508 G1 X145.795 Y144.928 E0.2667 G1 X146.395 Y145.709 E0.2790 G1 X146.395 Y146.819 E0.2929 G1 X146.079 Y146.711 E0.2971 G1 X145.798 Y146.573 E0.3010 G1 X145.538 Y146.399 E0.3050 G1 X145.302 Y146.192 E0.3089 G1 X145.096 Y145.957 E0.3128 G1 X144.922 Y145.697 E0.3167 G1 X144.783 Y145.416 E0.3207 G1 X144.683 Y145.119 E0.3246 G1 X144.622 Y144.812 E0.3285 G1 X144.600 Y144.480 E0.3327 G1 X144.600 Y139.520 E0.3949 G1 X144.647 Y138.795 E0.4040 G1 X144.785 Y138.103 E0.4129 G1 X145.012 Y137.434 E0.4217 G1 X145.325 Y136.801 E0.4306 G1 X145.717 Y136.213 E0.4394 G1 X146.183 Y135.683 E0.4483 G1 X146.714 Y135.217 E0.4571 G1 X147.301 Y134.825 E0.4660 G1 X147.934 Y134.512 E0.4749 G1 X148.603 Y134.285 E0.4837 G1 X149.295 Y134.147 E0.4926 G1 X150.000 Y134.101 E0.5014 G1 X150.705 Y134.147 E0.5103 G1 X151.397 Y134.285 E0.5191 G1 X152.066 Y134.512 E0.5280 G1 X152.699 Y134.825 E0.5368 G1 X153.287 Y135.217 E0.5457 G1 X153.818 Y135.683 E0.5546 G1 X154.283 Y136.213 E0.5634 G1 X154.675 Y136.801 E0.5723 G1 X154.988 Y137.434 E0.5811 G1 X155.215 Y138.103 E0.5900 G1 X155.352 Y138.795 E0.5988 G1 X155.400 Y139.520 E0.6079 G1 X155.400 Y144.480 E0.6701 G1 X155.378 Y144.812 E0.6743 G1 X155.317 Y145.119 E0.6782 G1 X155.217 Y145.416 E0.6822 G1 X155.078 Y145.697 E0.6861 G1 X154.904 Y145.957 E0.6900 G1 X154.698 Y146.192 E0.6939 G1 X154.462 Y146.399 E0.6979 G1 X154.202 Y146.573 E0.7018 G1 X153.921 Y146.711 E0.7057 G1 X153.605 Y146.819 E0.7099 G1 X153.605 Y146.709 E0.7113 G1 X153.605 Y145.709 F1911 ; outer perimeter G1 X153.205 Y145.573 F4800 G92 E0 G1 X153.855 Y144.726 E0.0134 F1274 G1 X154.300 Y143.652 E0.0280 G1 X154.452 Y142.500 E0.0425 G1 X154.300 Y141.348 E0.0571 G1 X153.855 Y140.274 E0.0717 G1 X153.148 Y139.352 E0.0863 G1 X152.226 Y138.645 E0.1008 G1 X151.152 Y138.200 E0.1154 G1 X150.000 Y138.048 E0.1300 G1 X148.848 Y138.200 E0.1446 G1 X147.774 Y138.645 E0.1591 G1 X146.852 Y139.352 E0.1737 G1 X146.145 Y140.274 E0.1883 G1 X145.700 Y141.348 E0.2028 G1 X145.548 Y142.500 E0.2174 G1 X145.700 Y143.652 E0.2320 G1 X146.145 Y144.726 E0.2466 G1 X146.795 Y145.573 E0.2600 G1 X146.795 Y147.284 E0.2814 G1 X146.631 Y147.271 E0.2835 G1 X146.272 Y147.199 E0.2881 G1 X145.925 Y147.082 E0.2927 G1 X145.598 Y146.920 E0.2972 G1 X145.294 Y146.717 E0.3018 G1 X145.019 Y146.476 E0.3064 G1 X144.778 Y146.201 E0.3110 G1 X144.575 Y145.897 E0.3156 G1 X144.413 Y145.569 E0.3202 G1 X144.296 Y145.223 E0.3247 G1 X144.224 Y144.865 E0.3293 G1 X144.200 Y144.493 E0.3340 G1 X144.200 Y139.507 E0.3965 G1 X144.250 Y138.743 E0.4061 G1 X144.398 Y137.999 E0.4156 G1 X144.642 Y137.281 E0.4251 G1 X144.977 Y136.600 E0.4347 G1 X145.399 Y135.969 E0.4442 G1 X145.899 Y135.399 E0.4537 G1 X146.469 Y134.899 E0.4632 G1 X147.100 Y134.477 E0.4727 G1 X147.781 Y134.142 E0.4822 G1 X148.499 Y133.898 E0.4917 G1 X149.243 Y133.750 E0.5013 G1 X150.000 Y133.700 E0.5108 G1 X150.757 Y133.750 E0.5203 G1 X151.501 Y133.898 E0.5298 G1 X152.219 Y134.142 E0.5393 G1 X152.900 Y134.477 E0.5488 G1 X153.531 Y134.899 E0.5583 G1 X154.101 Y135.399 E0.5678 G1 X154.601 Y135.969 E0.5774 G1 X155.023 Y136.600 E0.5869 G1 X155.358 Y137.281 E0.5964 G1 X155.602 Y137.999 E0.6059 G1 X155.750 Y138.743 E0.6154 G1 X155.800 Y139.507 E0.6250 G1 X155.800 Y144.494 E0.6875 G1 X155.776 Y144.865 E0.6922 G1 X155.704 Y145.223 E0.6968 G1 X155.587 Y145.569 E0.7014 G1 X155.425 Y145.897 E0.7060 G1 X155.222 Y146.201 E0.7105 G1 X154.981 Y146.476 E0.7151 G1 X154.706 Y146.717 E0.7197 G1 X154.402 Y146.920 E0.7243 G1 X154.075 Y147.082 E0.7289 G1 X153.728 Y147.199 E0.7335 G1 X153.369 Y147.271 E0.7381 G1 X153.205 Y147.284 E0.7401 G1 X153.205 Y146.573 E0.7490 G1 X153.205 Y145.573 F1274 ; gap fill G1 X155.022 Y144.840 F4800 G92 E0 G1 X154.733 Y144.551 E0.0051 F2038 G1 X154.826 Y144.327 E0.0082 G1 X154.899 Y144.151 F2038 G1 X155.056 Y144.308 F2038 G1 X155.056 Y143.742 F2038 G1 X155.041 Y143.727 F2038 G92 E0 G1 E-6.5000 F1500 G1 X144.944 Y143.813 F4800 G1 E0.0000 F1500 G92 E0 G1 X144.975 Y143.843 E0.0005 F2038 G1 X144.975 Y143.846 E0.0006 G1 X145.368 Y144.796 E0.0135 G1 X145.364 Y144.798 E0.0135 G1 X145.196 Y144.630 E0.0165 G1 X144.944 Y144.378 F2038 G1 X144.944 Y144.469 F2038 G1 X144.964 Y144.767 F2038 G1 X145.012 Y145.012 F2038 G1 X145.015 Y145.015 F2038 ; solid layer G1 X145.366 Y139.144 F4800 G92 E0 G1 X145.484 Y139.262 E0.0021 F2038 G1 X145.730 Y138.942 E0.0072 G1 X145.432 Y138.644 E0.0124 G1 X145.502 Y138.295 E0.0169 G1 X145.539 Y138.185 E0.0184 G1 X145.976 Y138.622 E0.0261 G1 X146.039 Y138.539 E0.0274 G1 X146.277 Y138.357 E0.0312 G1 X145.682 Y137.763 E0.0417 G1 X145.697 Y137.718 E0.0423 G1 X145.864 Y137.379 E0.0470 G1 X146.597 Y138.111 E0.0600 G1 X146.917 Y137.866 E0.0651 G1 X146.069 Y137.018 E0.0801 G1 X146.296 Y136.679 E0.0852 G1 X147.246 Y137.629 E0.1021 G1 X147.646 Y137.464 E0.1075 G1 X146.559 Y136.376 E0.1268 G1 X146.707 Y136.207 E0.1296 G1 X146.839 Y136.091 E0.1318 G1 X148.046 Y137.298 E0.1532 G1 X148.446 Y137.132 E0.1587 G1 X147.140 Y135.827 E0.1818 G1 X147.165 Y135.805 E0.1822 G1 X147.476 Y135.597 E0.1869 G1 X148.920 Y137.041 E0.2125 G1 X149.420 Y136.975 E0.2188 G1 X147.832 Y135.387 E0.2470 G1 X148.211 Y135.201 E0.2523 G1 X149.920 Y136.909 E0.2826 G1 X150.000 Y136.898 E0.2836 G1 X150.547 Y136.970 E0.2905 G1 X148.633 Y135.056 E0.3245 G1 X148.795 Y135.002 E0.3266 G1 X149.086 Y134.944 E0.3303 G1 X151.198 Y137.056 E0.3678 G1 X151.450 Y137.089 E0.3710 G1 X152.043 Y137.335 E0.3790 G1 X149.578 Y134.871 E0.4227 G1 X150.000 Y134.843 E0.4280 G1 X150.125 Y134.851 E0.4296 G1 X153.324 Y138.050 E0.4863 G1 X153.961 Y138.539 E0.4964 G1 X154.450 Y139.176 E0.5065 G1 X154.649 Y139.375 E0.5100 G1 X154.617 Y138.892 E0.5161 G1 X154.589 Y138.750 E0.5179 G1 X150.750 Y134.911 E0.5860 G1 X151.205 Y135.002 E0.5918 G1 X151.510 Y135.105 E0.5958 G1 X154.395 Y137.990 E0.6470 G1 X154.303 Y137.718 E0.6506 G1 X154.033 Y137.171 E0.6583 G1 X153.814 Y136.843 E0.6632 G1 X153.364 Y136.393 E0.6712 G1 X152.657 Y135.686 F2038 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X150.652 Y153.545 F4800 G1 E0.0000 F1500 G92 E0 G1 X151.294 Y153.672 E0.0082 F1911 G1 X151.913 Y153.883 E0.0164 G1 X152.499 Y154.172 E0.0246 G1 X153.042 Y154.535 E0.0328 G1 X153.534 Y154.966 E0.0410 G1 X153.965 Y155.458 E0.0492 G1 X154.328 Y156.001 E0.0574 G1 X154.617 Y156.587 E0.0656 G1 X154.828 Y157.206 E0.0738 G1 X154.955 Y157.848 E0.0820 G1 X155.000 Y158.533 E0.0906 G1 X155.000 Y159.190 E0.0988 G1 X154.710 Y159.248 E0.1025 G1 X154.554 Y158.871 E0.1077 G1 X153.718 Y157.782 E0.1249 G1 X152.629 Y156.946 E0.1421 G1 X151.361 Y156.421 E0.1593 G1 X150.000 Y156.241 E0.1765 G1 X148.639 Y156.421 E0.1937 G1 X147.371 Y156.946 E0.2109 G1 X146.282 Y157.782 E0.2282 G1 X145.446 Y158.871 E0.2454 G1 X145.290 Y159.248 E0.2505 G1 X145.000 Y159.190 E0.2542 G1 X145.000 Y158.533 E0.2624 G1 X145.045 Y157.848 E0.2710 G1 X145.172 Y157.206 E0.2792 G1 X145.383 Y156.587 E0.2874 G1 X145.672 Y156.001 E0.2956 G1 X146.035 Y155.458 E0.3038 G1 X146.466 Y154.966 E0.3120 G1 X146.957 Y154.535 E0.3202 G1 X147.501 Y154.172 E0.3284 G1 X148.087 Y153.883 E0.3366 G1 X148.706 Y153.672 E0.3448 G1 X149.348 Y153.545 E0.3530 G1 X149.655 Y153.525 E0.3569 G1 X150.000 Y153.502 F1911 G1 X150.652 Y153.545 F1911 G92 E0 G1 E-6.5000 F1500 G1 X154.542 Y164.145 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.819 Y164.317 E0.0041 F1911 G1 X154.731 Y164.496 E0.0066 G1 X154.586 Y164.713 E0.0099 G1 X154.414 Y164.909 E0.0131 G1 X154.264 Y165.041 E0.0156 G1 X154.137 Y164.922 E0.0178 G1 X154.026 Y164.818 F1911 G1 X154.542 Y164.145 F1911 G92 E0 G1 E-6.5000 F1500 G1 X145.974 Y164.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.736 Y165.041 E0.0041 F1911 G1 X145.586 Y164.909 E0.0066 G1 X145.414 Y164.713 E0.0099 G1 X145.269 Y164.496 E0.0131 G1 X145.181 Y164.317 E0.0156 G1 X145.329 Y164.225 E0.0178 G1 X145.458 Y164.145 F1911 G1 X145.974 Y164.818 F1911 G1 X146.395 Y164.709 F4800 G92 E0 G1 X146.395 Y165.819 E0.0139 F1911 G1 X146.079 Y165.711 E0.0181 G1 X145.798 Y165.573 E0.0220 G1 X145.538 Y165.399 E0.0260 G1 X145.302 Y165.192 E0.0299 G1 X145.096 Y164.957 E0.0338 G1 X144.922 Y164.697 E0.0377 G1 X144.783 Y164.416 E0.0417 G1 X144.683 Y164.119 E0.0456 G1 X144.622 Y163.812 E0.0495 G1 X144.600 Y163.480 E0.0537 G1 X144.600 Y158.520 E0.1159 G1 X144.647 Y157.795 E0.1250 G1 X144.785 Y157.103 E0.1339 G1 X145.012 Y156.434 E0.1427 G1 X145.325 Y155.801 E0.1516 G1 X145.717 Y155.213 E0.1604 G1 X146.183 Y154.683 E0.1693 G1 X146.714 Y154.217 E0.1781 G1 X147.301 Y153.825 E0.1870 G1 X147.934 Y153.512 E0.1958 G1 X148.603 Y153.285 E0.2047 G1 X149.295 Y153.147 E0.2136 G1 X150.000 Y153.101 E0.2224 G1 X150.705 Y153.147 E0.2313 G1 X151.397 Y153.285 E0.2401 G1 X152.066 Y153.512 E0.2490 G1 X152.699 Y153.825 E0.2578 G1 X153.287 Y154.217 E0.2667 G1 X153.818 Y154.683 E0.2755 G1 X154.283 Y155.213 E0.2844 G1 X154.675 Y155.801 E0.2933 G1 X154.988 Y156.434 E0.3021 G1 X155.215 Y157.103 E0.3110 G1 X155.352 Y157.795 E0.3198 G1 X155.400 Y158.520 E0.3289 G1 X155.400 Y163.480 E0.3911 G1 X155.378 Y163.812 E0.3953 G1 X155.317 Y164.119 E0.3992 G1 X155.217 Y164.416 E0.4032 G1 X155.078 Y164.697 E0.4071 G1 X154.904 Y164.957 E0.4110 G1 X154.698 Y165.192 E0.4149 G1 X154.462 Y165.399 E0.4189 G1 X154.202 Y165.573 E0.4228 G1 X153.921 Y165.711 E0.4267 G1 X153.605 Y165.819 E0.4309 G1 X153.605 Y164.709 E0.4448 G1 X154.205 Y163.928 E0.4572 G1 X154.690 Y162.757 E0.4731 G1 X154.855 Y161.500 E0.4890 G1 X154.690 Y160.243 E0.5048 G1 X154.205 Y159.072 E0.5207 G1 X153.433 Y158.067 E0.5366 G1 X152.428 Y157.295 E0.5525 G1 X151.257 Y156.810 E0.5684 G1 X150.000 Y156.645 E0.5843 G1 X148.743 Y156.810 E0.6002 G1 X147.572 Y157.295 E0.6161 G1 X146.567 Y158.067 E0.6320 G1 X145.795 Y159.072 E0.6479 G1 X145.310 Y160.243 E0.6638 G1 X145.145 Y161.500 E0.6797 G1 X145.310 Y162.757 E0.6956 G1 X145.789 Y163.914 E0.7113 G1 X145.795 Y163.928 F1911 G1 X146.395 Y164.709 F1911 ; outer perimeter G1 X146.795 Y164.573 F4800 G92 E0 G1 X146.795 Y166.284 E0.0215 F1274 G1 X146.631 Y166.271 E0.0235 G1 X146.272 Y166.199 E0.0281 G1 X145.925 Y166.082 E0.0327 G1 X145.598 Y165.920 E0.0373 G1 X145.294 Y165.717 E0.0419 G1 X145.019 Y165.476 E0.0464 G1 X144.778 Y165.201 E0.0510 G1 X144.575 Y164.897 E0.0556 G1 X144.413 Y164.569 E0.0602 G1 X144.296 Y164.223 E0.0648 G1 X144.224 Y163.865 E0.0694 G1 X144.200 Y163.493 E0.0740 G1 X144.200 Y158.507 E0.1366 G1 X144.250 Y157.743 E0.1462 G1 X144.398 Y156.999 E0.1557 G1 X144.642 Y156.281 E0.1652 G1 X144.977 Y155.600 E0.1747 G1 X145.399 Y154.969 E0.1842 G1 X145.899 Y154.399 E0.1937 G1 X146.469 Y153.899 E0.2032 G1 X147.100 Y153.477 E0.2128 G1 X147.781 Y153.142 E0.2223 G1 X148.499 Y152.898 E0.2318 G1 X149.243 Y152.750 E0.2413 G1 X150.000 Y152.700 E0.2508 G1 X150.757 Y152.750 E0.2603 G1 X151.501 Y152.898 E0.2698 G1 X152.219 Y153.142 E0.2793 G1 X152.900 Y153.477 E0.2889 G1 X153.531 Y153.899 E0.2984 G1 X154.101 Y154.399 E0.3079 G1 X154.601 Y154.969 E0.3174 G1 X155.023 Y155.600 E0.3269 G1 X155.358 Y156.281 E0.3364 G1 X155.602 Y156.999 E0.3459 G1 X155.750 Y157.743 E0.3555 G1 X155.800 Y158.507 E0.3650 G1 X155.800 Y163.494 E0.4276 G1 X155.776 Y163.865 E0.4323 G1 X155.704 Y164.223 E0.4368 G1 X155.587 Y164.569 E0.4414 G1 X155.425 Y164.897 E0.4460 G1 X155.222 Y165.201 E0.4506 G1 X154.981 Y165.476 E0.4552 G1 X154.706 Y165.717 E0.4598 G1 X154.402 Y165.920 E0.4643 G1 X154.075 Y166.082 E0.4689 G1 X153.728 Y166.199 E0.4735 G1 X153.369 Y166.271 E0.4781 G1 X153.205 Y166.284 E0.4802 G1 X153.205 Y164.573 E0.5016 G1 X153.855 Y163.726 E0.5150 G1 X154.300 Y162.652 E0.5296 G1 X154.452 Y161.500 E0.5442 G1 X154.300 Y160.348 E0.5587 G1 X153.855 Y159.274 E0.5733 G1 X153.148 Y158.352 E0.5879 G1 X152.226 Y157.645 E0.6024 G1 X151.152 Y157.200 E0.6170 G1 X150.000 Y157.048 E0.6316 G1 X148.848 Y157.200 E0.6462 G1 X147.774 Y157.645 E0.6607 G1 X146.852 Y158.352 E0.6753 G1 X146.145 Y159.274 E0.6899 G1 X145.700 Y160.348 E0.7045 G1 X145.548 Y161.500 E0.7190 G1 X145.700 Y162.652 E0.7336 G1 X146.145 Y163.726 E0.7482 G1 X146.186 Y163.780 E0.7490 G1 X146.795 Y164.573 F1274 ; gap fill G1 X144.954 Y163.622 F4800 G92 E0 G1 X145.220 Y163.888 E0.0047 F2038 G1 X145.263 Y163.861 E0.0054 G1 X145.368 Y163.796 F2038 G1 X145.138 Y163.240 F2038 G1 X144.944 Y163.046 F2038 G92 E0 G1 E-6.5000 F1500 G1 X154.930 Y163.981 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.665 Y163.716 E0.0047 F2038 G1 X154.815 Y163.354 E0.0096 G1 X154.831 Y163.316 F2038 G1 X155.052 Y163.537 F2038 G1 X155.056 Y163.469 F2038 G1 X155.056 Y162.976 F2038 G1 X154.996 Y162.916 F2038 ; solid layer G1 X152.083 Y154.346 F4800 G92 E0 G1 X154.154 Y156.417 E0.0367 F2038 G1 X154.303 Y156.718 E0.0409 G1 X154.498 Y157.295 E0.0486 G1 X154.506 Y157.335 E0.0491 G1 X151.165 Y153.994 E0.1084 G1 X150.608 Y153.883 E0.1155 G1 X150.480 Y153.874 E0.1171 G1 X154.626 Y158.020 E0.1906 G1 X154.653 Y158.441 E0.1959 G1 X153.961 Y157.539 E0.2102 G1 X152.801 Y156.649 E0.2285 G1 X152.610 Y156.570 E0.2311 G1 X149.890 Y153.850 E0.2793 G1 X149.392 Y153.883 E0.2856 G1 X149.363 Y153.889 E0.2860 G1 X151.645 Y156.170 E0.3264 G1 X151.450 Y156.089 E0.3291 G1 X150.930 Y156.021 E0.3356 G1 X148.891 Y153.982 E0.3718 G1 X148.795 Y154.002 E0.3730 G1 X148.459 Y154.116 E0.3775 G1 X150.278 Y155.935 E0.4097 G1 X150.000 Y155.898 E0.4133 G1 X149.714 Y155.936 E0.4169 G1 X148.055 Y154.278 E0.4463 G1 X147.676 Y154.464 E0.4516 G1 X149.214 Y156.002 E0.4789 G1 X148.714 Y156.068 E0.4852 G1 X147.337 Y154.691 E0.5096 G1 X147.165 Y154.805 E0.5122 G1 X147.016 Y154.936 E0.5147 G1 X148.281 Y156.201 E0.5371 G1 X147.881 Y156.366 E0.5425 G1 X146.715 Y155.200 E0.5632 G1 X146.707 Y155.207 E0.5634 G1 X146.450 Y155.500 E0.5683 G1 X147.481 Y156.532 E0.5866 G1 X147.199 Y156.649 E0.5904 G1 X147.105 Y156.721 E0.5919 G1 X146.202 Y155.819 E0.6079 G1 X145.976 Y156.158 E0.6130 G1 X146.785 Y156.967 E0.6273 G1 X146.465 Y157.213 E0.6324 G1 X145.787 Y156.535 E0.6444 G1 X145.697 Y156.718 E0.6470 G1 X145.623 Y156.937 E0.6499 G1 X146.145 Y157.458 E0.6591 G1 X146.039 Y157.539 E0.6608 G1 X145.874 Y157.754 E0.6642 G1 X145.487 Y157.367 E0.6710 G1 X145.436 Y157.623 E0.6743 G1 X145.393 Y157.838 F2038 G1 X145.629 Y158.074 F2038 G1 X145.383 Y158.394 F2038 G1 X145.352 Y158.363 F2038 G92 E0 G1 E-6.5000 F1500 ; layer 4, Z = 0.900 ; inner perimeter G1 X145.000 Y158.533 F4800 G1 Z0.900 F300 G1 E0.0000 F1500 G92 E0 G1 X145.045 Y157.848 E0.0086 F1896 G1 X145.172 Y157.206 E0.0168 G1 X145.383 Y156.587 E0.0250 G1 X145.672 Y156.001 E0.0332 G1 X146.035 Y155.458 E0.0414 G1 X146.466 Y154.966 E0.0496 G1 X146.957 Y154.535 E0.0578 G1 X147.501 Y154.172 E0.0660 G1 X148.087 Y153.883 E0.0742 G1 X148.706 Y153.672 E0.0824 G1 X149.348 Y153.545 E0.0906 G1 X150.000 Y153.502 E0.0988 G1 X150.652 Y153.545 E0.1070 G1 X151.294 Y153.672 E0.1152 G1 X151.913 Y153.883 E0.1234 G1 X152.499 Y154.172 E0.1316 G1 X153.042 Y154.535 E0.1398 G1 X153.534 Y154.966 E0.1480 G1 X153.965 Y155.458 E0.1562 G1 X154.328 Y156.001 E0.1644 G1 X154.617 Y156.587 E0.1726 G1 X154.828 Y157.206 E0.1808 G1 X154.955 Y157.848 E0.1890 G1 X155.000 Y158.533 E0.1976 G1 X155.000 Y159.190 E0.2058 G1 X154.710 Y159.248 E0.2095 G1 X154.554 Y158.871 E0.2146 G1 X153.718 Y157.782 E0.2319 G1 X152.629 Y156.946 E0.2491 G1 X151.361 Y156.421 E0.2663 G1 X150.000 Y156.241 E0.2835 G1 X148.639 Y156.421 E0.3007 G1 X147.371 Y156.946 E0.3179 G1 X146.282 Y157.782 E0.3351 G1 X145.446 Y158.871 E0.3524 G1 X145.308 Y159.204 E0.3569 G1 X145.290 Y159.248 F1896 G1 X145.000 Y159.190 F1896 G1 X145.000 Y158.533 F1896 G1 X145.458 Y164.145 F4800 G92 E0 G1 X145.974 Y164.818 E0.0106 F1896 G1 X145.736 Y165.041 E0.0147 G1 X145.586 Y164.909 E0.0172 G1 X145.555 Y164.873 E0.0178 G1 X145.414 Y164.713 F1896 G1 X145.269 Y164.496 F1896 G1 X145.181 Y164.317 F1896 G1 X145.458 Y164.145 F1896 G92 E0 G1 E-6.5000 F1500 G1 X154.026 Y164.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.542 Y164.145 E0.0106 F1896 G1 X154.819 Y164.317 E0.0147 G1 X154.731 Y164.496 E0.0172 G1 X154.705 Y164.536 E0.0178 G1 X154.586 Y164.713 F1896 G1 X154.414 Y164.909 F1896 G1 X154.264 Y165.041 F1896 G1 X154.026 Y164.818 F1896 G1 X153.605 Y164.709 F4800 G92 E0 G1 X154.205 Y163.928 E0.0123 F1896 G1 X154.690 Y162.757 E0.0282 G1 X154.855 Y161.500 E0.0441 G1 X154.690 Y160.243 E0.0600 G1 X154.205 Y159.072 E0.0759 G1 X153.433 Y158.067 E0.0918 G1 X152.428 Y157.295 E0.1077 G1 X151.257 Y156.810 E0.1236 G1 X150.000 Y156.645 E0.1395 G1 X148.743 Y156.810 E0.1554 G1 X147.572 Y157.295 E0.1713 G1 X146.567 Y158.067 E0.1872 G1 X145.795 Y159.072 E0.2031 G1 X145.310 Y160.243 E0.2190 G1 X145.145 Y161.500 E0.2349 G1 X145.310 Y162.757 E0.2508 G1 X145.795 Y163.928 E0.2667 G1 X146.395 Y164.709 E0.2790 G1 X146.395 Y165.819 E0.2929 G1 X146.079 Y165.711 E0.2971 G1 X145.798 Y165.573 E0.3010 G1 X145.538 Y165.399 E0.3050 G1 X145.302 Y165.192 E0.3089 G1 X145.096 Y164.957 E0.3128 G1 X144.922 Y164.697 E0.3167 G1 X144.783 Y164.416 E0.3207 G1 X144.683 Y164.119 E0.3246 G1 X144.622 Y163.812 E0.3285 G1 X144.600 Y163.480 E0.3327 G1 X144.600 Y158.520 E0.3949 G1 X144.647 Y157.795 E0.4040 G1 X144.785 Y157.103 E0.4129 G1 X145.012 Y156.434 E0.4217 G1 X145.325 Y155.801 E0.4306 G1 X145.717 Y155.213 E0.4394 G1 X146.183 Y154.683 E0.4483 G1 X146.714 Y154.217 E0.4571 G1 X147.301 Y153.825 E0.4660 G1 X147.934 Y153.512 E0.4749 G1 X148.603 Y153.285 E0.4837 G1 X149.295 Y153.147 E0.4926 G1 X150.000 Y153.101 E0.5014 G1 X150.705 Y153.147 E0.5103 G1 X151.397 Y153.285 E0.5191 G1 X152.066 Y153.512 E0.5280 G1 X152.699 Y153.825 E0.5368 G1 X153.287 Y154.217 E0.5457 G1 X153.818 Y154.683 E0.5546 G1 X154.283 Y155.213 E0.5634 G1 X154.675 Y155.801 E0.5723 G1 X154.988 Y156.434 E0.5811 G1 X155.215 Y157.103 E0.5900 G1 X155.352 Y157.795 E0.5988 G1 X155.400 Y158.520 E0.6079 G1 X155.400 Y163.480 E0.6701 G1 X155.378 Y163.812 E0.6743 G1 X155.317 Y164.119 E0.6782 G1 X155.217 Y164.416 E0.6822 G1 X155.078 Y164.697 E0.6861 G1 X154.904 Y164.957 E0.6900 G1 X154.698 Y165.192 E0.6939 G1 X154.462 Y165.399 E0.6979 G1 X154.202 Y165.573 E0.7018 G1 X153.921 Y165.711 E0.7057 G1 X153.605 Y165.819 E0.7099 G1 X153.605 Y165.709 E0.7113 G1 X153.605 Y164.709 F1896 ; outer perimeter G1 X153.205 Y164.573 F4800 G92 E0 G1 X153.855 Y163.726 E0.0134 F1264 G1 X154.300 Y162.652 E0.0280 G1 X154.452 Y161.500 E0.0425 G1 X154.300 Y160.348 E0.0571 G1 X153.855 Y159.274 E0.0717 G1 X153.148 Y158.352 E0.0863 G1 X152.226 Y157.645 E0.1008 G1 X151.152 Y157.200 E0.1154 G1 X150.000 Y157.048 E0.1300 G1 X148.848 Y157.200 E0.1446 G1 X147.774 Y157.645 E0.1591 G1 X146.852 Y158.352 E0.1737 G1 X146.145 Y159.274 E0.1883 G1 X145.700 Y160.348 E0.2028 G1 X145.548 Y161.500 E0.2174 G1 X145.700 Y162.652 E0.2320 G1 X146.145 Y163.726 E0.2466 G1 X146.795 Y164.573 E0.2600 G1 X146.795 Y166.284 E0.2814 G1 X146.631 Y166.271 E0.2835 G1 X146.272 Y166.199 E0.2881 G1 X145.925 Y166.082 E0.2927 G1 X145.598 Y165.920 E0.2972 G1 X145.294 Y165.717 E0.3018 G1 X145.019 Y165.476 E0.3064 G1 X144.778 Y165.201 E0.3110 G1 X144.575 Y164.897 E0.3156 G1 X144.413 Y164.569 E0.3202 G1 X144.296 Y164.223 E0.3247 G1 X144.224 Y163.865 E0.3293 G1 X144.200 Y163.493 E0.3340 G1 X144.200 Y158.507 E0.3965 G1 X144.250 Y157.743 E0.4061 G1 X144.398 Y156.999 E0.4156 G1 X144.642 Y156.281 E0.4251 G1 X144.977 Y155.600 E0.4347 G1 X145.399 Y154.969 E0.4442 G1 X145.899 Y154.399 E0.4537 G1 X146.469 Y153.899 E0.4632 G1 X147.100 Y153.477 E0.4727 G1 X147.781 Y153.142 E0.4822 G1 X148.499 Y152.898 E0.4917 G1 X149.243 Y152.750 E0.5013 G1 X150.000 Y152.700 E0.5108 G1 X150.757 Y152.750 E0.5203 G1 X151.501 Y152.898 E0.5298 G1 X152.219 Y153.142 E0.5393 G1 X152.900 Y153.477 E0.5488 G1 X153.531 Y153.899 E0.5583 G1 X154.101 Y154.399 E0.5678 G1 X154.601 Y154.969 E0.5774 G1 X155.023 Y155.600 E0.5869 G1 X155.358 Y156.281 E0.5964 G1 X155.602 Y156.999 E0.6059 G1 X155.750 Y157.743 E0.6154 G1 X155.800 Y158.507 E0.6250 G1 X155.800 Y163.494 E0.6875 G1 X155.776 Y163.865 E0.6922 G1 X155.704 Y164.223 E0.6968 G1 X155.587 Y164.569 E0.7014 G1 X155.425 Y164.897 E0.7060 G1 X155.222 Y165.201 E0.7105 G1 X154.981 Y165.476 E0.7151 G1 X154.706 Y165.717 E0.7197 G1 X154.402 Y165.920 E0.7243 G1 X154.075 Y166.082 E0.7289 G1 X153.728 Y166.199 E0.7335 G1 X153.369 Y166.271 E0.7381 G1 X153.205 Y166.284 E0.7401 G1 X153.205 Y165.573 E0.7490 G1 X153.205 Y164.573 F1264 ; gap fill G1 X154.780 Y163.888 F4800 G92 E0 G1 X154.940 Y163.727 E0.0028 F2022 G1 X155.046 Y163.622 F2022 G1 X155.056 Y163.469 F2022 G1 X155.056 Y163.046 F2022 G1 X154.862 Y163.240 F2022 G92 E0 G1 E-6.5000 F1500 G1 X145.335 Y163.716 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.070 Y163.981 E0.0047 F2022 G1 X145.013 Y164.016 E0.0055 G1 X144.964 Y163.767 E0.0087 G1 X144.960 Y163.706 E0.0095 G1 X144.948 Y163.537 F2022 G1 X145.170 Y163.316 F2022 G1 X145.004 Y162.916 F2022 G1 X144.944 Y162.976 F2022 ; solid layer G1 X145.846 Y156.417 F4800 G92 E0 G1 X147.917 Y154.346 E0.0367 F2022 G1 X148.218 Y154.197 E0.0409 G1 X148.638 Y154.055 E0.0465 G1 X148.807 Y154.021 E0.0487 G1 X145.494 Y157.335 E0.1074 G1 X145.383 Y157.892 E0.1146 G1 X145.374 Y158.020 E0.1162 G1 X149.460 Y153.934 E0.1886 G1 X150.000 Y153.899 E0.1954 G1 X150.057 Y153.902 E0.1961 G1 X147.390 Y156.570 E0.2434 G1 X148.356 Y156.170 E0.2566 G1 X150.588 Y153.937 E0.2961 G1 X150.862 Y153.955 E0.2996 G1 X151.090 Y154.001 E0.3025 G1 X149.070 Y156.021 E0.3383 G1 X149.722 Y155.935 E0.3466 G1 X151.541 Y154.116 E0.3788 G1 X151.782 Y154.197 E0.3820 G1 X151.945 Y154.278 E0.3843 G1 X150.286 Y155.936 E0.4137 G1 X150.786 Y156.002 E0.4200 G1 X152.324 Y154.464 E0.4473 G1 X152.328 Y154.467 E0.4474 G1 X152.663 Y154.691 E0.4524 G1 X151.286 Y156.068 E0.4769 G1 X151.450 Y156.089 E0.4789 G1 X151.719 Y156.201 E0.4826 G1 X152.984 Y154.936 E0.5050 G1 X153.285 Y155.200 E0.5100 G1 X152.119 Y156.366 E0.5307 G1 X152.519 Y156.532 E0.5362 G1 X153.551 Y155.500 E0.5544 G1 X153.695 Y155.665 E0.5572 G1 X153.798 Y155.819 E0.5595 G1 X152.895 Y156.721 E0.5755 G1 X153.215 Y156.967 E0.5806 G1 X154.024 Y156.158 E0.5949 G1 X154.033 Y156.171 E0.5951 G1 X154.213 Y156.535 E0.6002 G1 X153.535 Y157.213 E0.6122 G1 X153.856 Y157.458 E0.6173 G1 X154.377 Y156.937 E0.6265 G1 X154.498 Y157.295 E0.6313 G1 X154.513 Y157.367 E0.6322 G1 X154.126 Y157.754 E0.6391 G1 X154.312 Y157.997 E0.6429 G1 X154.371 Y158.074 F2022 G1 X154.607 Y157.838 F2022 G1 X154.617 Y157.892 F2022 G1 X154.648 Y158.363 F2022 G1 X154.617 Y158.394 F2022 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X154.264 Y146.041 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.026 Y145.818 E0.0041 F1896 G1 X154.542 Y145.145 E0.0147 G1 X154.752 Y145.275 E0.0178 G1 X154.819 Y145.317 F1896 G1 X154.731 Y145.496 F1896 G1 X154.586 Y145.713 F1896 G1 X154.414 Y145.909 F1896 G1 X154.264 Y146.041 F1896 G1 X154.710 Y140.248 F4800 G92 E0 G1 X154.554 Y139.871 E0.0051 F1896 G1 X153.718 Y138.782 E0.0223 G1 X152.629 Y137.946 E0.0395 G1 X151.361 Y137.421 E0.0568 G1 X150.000 Y137.241 E0.0740 G1 X148.639 Y137.421 E0.0912 G1 X147.371 Y137.946 E0.1084 G1 X146.282 Y138.782 E0.1256 G1 X145.446 Y139.871 E0.1428 G1 X145.290 Y140.248 E0.1480 G1 X145.000 Y140.190 E0.1517 G1 X145.000 Y139.533 E0.1599 G1 X145.045 Y138.848 E0.1685 G1 X145.172 Y138.206 E0.1767 G1 X145.383 Y137.587 E0.1849 G1 X145.672 Y137.001 E0.1931 G1 X146.035 Y136.458 E0.2013 G1 X146.466 Y135.966 E0.2095 G1 X146.957 Y135.535 E0.2177 G1 X147.501 Y135.172 E0.2259 G1 X148.087 Y134.883 E0.2341 G1 X148.706 Y134.672 E0.2423 G1 X149.348 Y134.545 E0.2505 G1 X150.000 Y134.502 E0.2587 G1 X150.652 Y134.545 E0.2669 G1 X151.294 Y134.672 E0.2751 G1 X151.913 Y134.883 E0.2833 G1 X152.499 Y135.172 E0.2915 G1 X153.042 Y135.535 E0.2997 G1 X153.534 Y135.966 E0.3079 G1 X153.965 Y136.458 E0.3161 G1 X154.328 Y137.001 E0.3243 G1 X154.617 Y137.587 E0.3325 G1 X154.828 Y138.206 E0.3407 G1 X154.955 Y138.848 E0.3489 G1 X154.997 Y139.486 E0.3569 G1 X155.000 Y139.533 F1896 G1 X155.000 Y140.190 F1896 G1 X154.710 Y140.248 F1896 G92 E0 G1 E-6.5000 F1500 G1 X145.974 Y145.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.736 Y146.041 E0.0041 F1896 G1 X145.586 Y145.909 E0.0066 G1 X145.414 Y145.713 E0.0099 G1 X145.269 Y145.496 E0.0131 G1 X145.181 Y145.317 E0.0156 G1 X145.329 Y145.225 E0.0178 G1 X145.458 Y145.145 F1896 G1 X145.974 Y145.818 F1896 G1 X146.395 Y145.709 F4800 G92 E0 G1 X146.395 Y146.819 E0.0139 F1896 G1 X146.079 Y146.711 E0.0181 G1 X145.798 Y146.573 E0.0220 G1 X145.538 Y146.399 E0.0260 G1 X145.302 Y146.192 E0.0299 G1 X145.096 Y145.957 E0.0338 G1 X144.922 Y145.697 E0.0377 G1 X144.783 Y145.416 E0.0417 G1 X144.683 Y145.119 E0.0456 G1 X144.622 Y144.812 E0.0495 G1 X144.600 Y144.480 E0.0537 G1 X144.600 Y139.520 E0.1159 G1 X144.647 Y138.795 E0.1250 G1 X144.785 Y138.103 E0.1339 G1 X145.012 Y137.434 E0.1427 G1 X145.325 Y136.801 E0.1516 G1 X145.717 Y136.213 E0.1604 G1 X146.183 Y135.683 E0.1693 G1 X146.714 Y135.217 E0.1781 G1 X147.301 Y134.825 E0.1870 G1 X147.934 Y134.512 E0.1958 G1 X148.603 Y134.285 E0.2047 G1 X149.295 Y134.147 E0.2136 G1 X150.000 Y134.101 E0.2224 G1 X150.705 Y134.147 E0.2313 G1 X151.397 Y134.285 E0.2401 G1 X152.066 Y134.512 E0.2490 G1 X152.699 Y134.825 E0.2578 G1 X153.287 Y135.217 E0.2667 G1 X153.818 Y135.683 E0.2755 G1 X154.283 Y136.213 E0.2844 G1 X154.675 Y136.801 E0.2933 G1 X154.988 Y137.434 E0.3021 G1 X155.215 Y138.103 E0.3110 G1 X155.352 Y138.795 E0.3198 G1 X155.400 Y139.520 E0.3289 G1 X155.400 Y144.480 E0.3911 G1 X155.378 Y144.812 E0.3953 G1 X155.317 Y145.119 E0.3992 G1 X155.217 Y145.416 E0.4032 G1 X155.078 Y145.697 E0.4071 G1 X154.904 Y145.957 E0.4110 G1 X154.698 Y146.192 E0.4149 G1 X154.462 Y146.399 E0.4189 G1 X154.202 Y146.573 E0.4228 G1 X153.921 Y146.711 E0.4267 G1 X153.605 Y146.819 E0.4309 G1 X153.605 Y145.709 E0.4448 G1 X154.205 Y144.928 E0.4572 G1 X154.690 Y143.757 E0.4731 G1 X154.855 Y142.500 E0.4890 G1 X154.690 Y141.243 E0.5048 G1 X154.205 Y140.072 E0.5207 G1 X153.433 Y139.067 E0.5366 G1 X152.428 Y138.295 E0.5525 G1 X151.257 Y137.810 E0.5684 G1 X150.000 Y137.645 E0.5843 G1 X148.743 Y137.810 E0.6002 G1 X147.572 Y138.295 E0.6161 G1 X146.567 Y139.067 E0.6320 G1 X145.795 Y140.072 E0.6479 G1 X145.310 Y141.243 E0.6638 G1 X145.145 Y142.500 E0.6797 G1 X145.310 Y143.757 E0.6956 G1 X145.789 Y144.914 E0.7113 G1 X145.795 Y144.928 F1896 G1 X146.395 Y145.709 F1896 ; outer perimeter G1 X146.795 Y145.573 F4800 G92 E0 G1 X146.795 Y147.284 E0.0215 F1264 G1 X146.631 Y147.271 E0.0235 G1 X146.272 Y147.199 E0.0281 G1 X145.925 Y147.082 E0.0327 G1 X145.598 Y146.920 E0.0373 G1 X145.294 Y146.717 E0.0419 G1 X145.019 Y146.476 E0.0464 G1 X144.778 Y146.201 E0.0510 G1 X144.575 Y145.897 E0.0556 G1 X144.413 Y145.569 E0.0602 G1 X144.296 Y145.223 E0.0648 G1 X144.224 Y144.865 E0.0694 G1 X144.200 Y144.493 E0.0740 G1 X144.200 Y139.507 E0.1366 G1 X144.250 Y138.743 E0.1462 G1 X144.398 Y137.999 E0.1557 G1 X144.642 Y137.281 E0.1652 G1 X144.977 Y136.600 E0.1747 G1 X145.399 Y135.969 E0.1842 G1 X145.899 Y135.399 E0.1937 G1 X146.469 Y134.899 E0.2032 G1 X147.100 Y134.477 E0.2128 G1 X147.781 Y134.142 E0.2223 G1 X148.499 Y133.898 E0.2318 G1 X149.243 Y133.750 E0.2413 G1 X150.000 Y133.700 E0.2508 G1 X150.757 Y133.750 E0.2603 G1 X151.501 Y133.898 E0.2698 G1 X152.219 Y134.142 E0.2793 G1 X152.900 Y134.477 E0.2889 G1 X153.531 Y134.899 E0.2984 G1 X154.101 Y135.399 E0.3079 G1 X154.601 Y135.969 E0.3174 G1 X155.023 Y136.600 E0.3269 G1 X155.358 Y137.281 E0.3364 G1 X155.602 Y137.999 E0.3459 G1 X155.750 Y138.743 E0.3555 G1 X155.800 Y139.507 E0.3650 G1 X155.800 Y144.494 E0.4276 G1 X155.776 Y144.865 E0.4323 G1 X155.704 Y145.223 E0.4368 G1 X155.587 Y145.569 E0.4414 G1 X155.425 Y145.897 E0.4460 G1 X155.222 Y146.201 E0.4506 G1 X154.981 Y146.476 E0.4552 G1 X154.706 Y146.717 E0.4598 G1 X154.402 Y146.920 E0.4643 G1 X154.075 Y147.082 E0.4689 G1 X153.728 Y147.199 E0.4735 G1 X153.369 Y147.271 E0.4781 G1 X153.205 Y147.284 E0.4802 G1 X153.205 Y145.573 E0.5016 G1 X153.855 Y144.726 E0.5150 G1 X154.300 Y143.652 E0.5296 G1 X154.452 Y142.500 E0.5442 G1 X154.300 Y141.348 E0.5587 G1 X153.855 Y140.274 E0.5733 G1 X153.148 Y139.352 E0.5879 G1 X152.226 Y138.645 E0.6024 G1 X151.152 Y138.200 E0.6170 G1 X150.000 Y138.048 E0.6316 G1 X148.848 Y138.200 E0.6462 G1 X147.774 Y138.645 E0.6607 G1 X146.852 Y139.352 E0.6753 G1 X146.145 Y140.274 E0.6899 G1 X145.700 Y141.348 E0.7045 G1 X145.548 Y142.500 E0.7190 G1 X145.700 Y143.652 E0.7336 G1 X146.145 Y144.726 E0.7482 G1 X146.186 Y144.780 E0.7490 G1 X146.795 Y145.573 F1264 ; gap fill G1 X145.267 Y144.551 F4800 G92 E0 G1 X144.978 Y144.840 E0.0051 F2022 G1 X144.964 Y144.767 E0.0060 G1 X144.953 Y144.614 E0.0080 G1 X144.944 Y144.469 F2022 G1 X144.944 Y144.308 F2022 G1 X145.101 Y144.151 F2022 G1 X144.975 Y143.846 F2022 G1 X144.959 Y143.727 F2022 G1 X144.944 Y143.742 F2022 G92 E0 G1 E-6.5000 F1500 G1 X155.025 Y143.843 F4800 G1 E0.0000 F1500 G92 E0 G1 X155.056 Y143.813 E0.0005 F2022 G1 X155.056 Y144.378 E0.0076 G1 X155.050 Y144.384 E0.0077 G1 X154.636 Y144.798 F2022 G1 X154.985 Y145.015 F2022 G1 X154.988 Y145.012 F2022 ; solid layer G1 X154.516 Y139.262 F4800 G92 E0 G1 X154.634 Y139.144 E0.0021 F2022 G1 X154.617 Y138.892 E0.0053 G1 X154.568 Y138.644 E0.0084 G1 X154.270 Y138.942 E0.0137 G1 X154.024 Y138.622 E0.0188 G1 X154.461 Y138.185 E0.0265 G1 X154.318 Y137.763 E0.0321 G1 X153.724 Y138.357 E0.0427 G1 X153.403 Y138.111 E0.0477 G1 X154.136 Y137.379 E0.0607 G1 X154.033 Y137.171 E0.0636 G1 X153.931 Y137.018 E0.0659 G1 X153.083 Y137.866 E0.0809 G1 X152.801 Y137.649 E0.0854 G1 X152.754 Y137.629 E0.0860 G1 X153.704 Y136.679 E0.1029 G1 X153.695 Y136.665 E0.1031 G1 X153.442 Y136.376 E0.1079 G1 X152.354 Y137.464 E0.1272 G1 X151.954 Y137.298 E0.1327 G1 X153.161 Y136.091 E0.1541 G1 X152.860 Y135.827 E0.1591 G1 X151.554 Y137.132 E0.1822 G1 X151.450 Y137.089 E0.1837 G1 X151.080 Y137.041 E0.1883 G1 X152.524 Y135.597 E0.2139 G1 X152.328 Y135.467 E0.2169 G1 X152.168 Y135.387 E0.2191 G1 X150.580 Y136.975 E0.2473 G1 X150.080 Y136.909 E0.2536 G1 X151.789 Y135.201 E0.2839 G1 X151.782 Y135.197 E0.2840 G1 X151.367 Y135.056 E0.2895 G1 X149.453 Y136.970 E0.3234 G1 X148.802 Y137.056 E0.3317 G1 X150.896 Y134.962 E0.3688 G1 X150.862 Y134.955 E0.3693 G1 X150.369 Y134.923 E0.3754 G1 X148.664 Y136.628 E0.4057 G1 X147.957 Y137.335 F2022 G1 X146.186 Y136.843 F4800 G92 E0 G1 X147.344 Y135.686 E0.0205 F2022 G1 X147.672 Y135.467 E0.0255 G1 X148.218 Y135.197 E0.0331 G1 X148.490 Y135.105 E0.0367 G1 X145.605 Y137.990 E0.0879 G1 X145.502 Y138.295 E0.0919 G1 X145.411 Y138.750 E0.0977 G1 X149.210 Y134.950 E0.1651 G1 X149.816 Y134.911 E0.1727 G1 X146.677 Y138.050 E0.2284 G1 X146.039 Y138.539 E0.2385 G1 X145.987 Y138.606 E0.2395 G1 X145.550 Y139.177 F2022 G1 X145.351 Y139.375 F2022 G92 E0 G1 E-6.5000 F1500 ; layer 5, Z = 1.100 ; inner perimeter G1 X145.000 Y139.533 F4800 G1 Z1.100 F300 G1 E0.0000 F1500 G92 E0 G1 X145.045 Y138.848 E0.0086 F1909 G1 X145.172 Y138.206 E0.0168 G1 X145.383 Y137.587 E0.0250 G1 X145.672 Y137.001 E0.0332 G1 X146.035 Y136.458 E0.0414 G1 X146.466 Y135.966 E0.0496 G1 X146.957 Y135.535 E0.0578 G1 X147.501 Y135.172 E0.0660 G1 X148.087 Y134.883 E0.0742 G1 X148.706 Y134.672 E0.0824 G1 X149.348 Y134.545 E0.0906 G1 X150.000 Y134.502 E0.0988 G1 X150.652 Y134.545 E0.1070 G1 X151.294 Y134.672 E0.1152 G1 X151.913 Y134.883 E0.1234 G1 X152.499 Y135.172 E0.1316 G1 X153.042 Y135.535 E0.1398 G1 X153.534 Y135.966 E0.1480 G1 X153.965 Y136.458 E0.1562 G1 X154.328 Y137.001 E0.1644 G1 X154.617 Y137.587 E0.1726 G1 X154.828 Y138.206 E0.1808 G1 X154.955 Y138.848 E0.1890 G1 X155.000 Y139.533 E0.1976 G1 X155.000 Y140.190 E0.2058 G1 X154.710 Y140.248 E0.2095 G1 X154.554 Y139.871 E0.2146 G1 X153.718 Y138.782 E0.2319 G1 X152.629 Y137.946 E0.2491 G1 X151.361 Y137.421 E0.2663 G1 X150.000 Y137.241 E0.2835 G1 X148.639 Y137.421 E0.3007 G1 X147.371 Y137.946 E0.3179 G1 X146.282 Y138.782 E0.3351 G1 X145.446 Y139.871 E0.3524 G1 X145.308 Y140.204 E0.3569 G1 X145.290 Y140.248 F1909 G1 X145.000 Y140.190 F1909 G1 X145.000 Y139.533 F1909 G1 X145.458 Y145.145 F4800 G92 E0 G1 X145.974 Y145.818 E0.0106 F1909 G1 X145.736 Y146.041 E0.0147 G1 X145.586 Y145.909 E0.0172 G1 X145.555 Y145.873 E0.0178 G1 X145.414 Y145.713 F1909 G1 X145.269 Y145.496 F1909 G1 X145.181 Y145.317 F1909 G1 X145.458 Y145.145 F1909 G92 E0 G1 E-6.5000 F1500 G1 X154.026 Y145.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.542 Y145.145 E0.0106 F1909 G1 X154.819 Y145.317 E0.0147 G1 X154.731 Y145.496 E0.0172 G1 X154.705 Y145.536 E0.0178 G1 X154.586 Y145.713 F1909 G1 X154.414 Y145.909 F1909 G1 X154.264 Y146.041 F1909 G1 X154.026 Y145.818 F1909 G1 X153.605 Y145.709 F4800 G92 E0 G1 X154.205 Y144.928 E0.0123 F1909 G1 X154.690 Y143.757 E0.0282 G1 X154.855 Y142.500 E0.0441 G1 X154.690 Y141.243 E0.0600 G1 X154.205 Y140.072 E0.0759 G1 X153.433 Y139.067 E0.0918 G1 X152.428 Y138.295 E0.1077 G1 X151.257 Y137.810 E0.1236 G1 X150.000 Y137.645 E0.1395 G1 X148.743 Y137.810 E0.1554 G1 X147.572 Y138.295 E0.1713 G1 X146.567 Y139.067 E0.1872 G1 X145.795 Y140.072 E0.2031 G1 X145.310 Y141.243 E0.2190 G1 X145.145 Y142.500 E0.2349 G1 X145.310 Y143.757 E0.2508 G1 X145.795 Y144.928 E0.2667 G1 X146.395 Y145.709 E0.2790 G1 X146.395 Y146.819 E0.2929 G1 X146.079 Y146.711 E0.2971 G1 X145.798 Y146.573 E0.3010 G1 X145.538 Y146.399 E0.3050 G1 X145.302 Y146.192 E0.3089 G1 X145.096 Y145.957 E0.3128 G1 X144.922 Y145.697 E0.3167 G1 X144.783 Y145.416 E0.3207 G1 X144.683 Y145.119 E0.3246 G1 X144.622 Y144.812 E0.3285 G1 X144.600 Y144.480 E0.3327 G1 X144.600 Y139.520 E0.3949 G1 X144.647 Y138.795 E0.4040 G1 X144.785 Y138.103 E0.4129 G1 X145.012 Y137.434 E0.4217 G1 X145.325 Y136.801 E0.4306 G1 X145.717 Y136.213 E0.4394 G1 X146.183 Y135.683 E0.4483 G1 X146.714 Y135.217 E0.4571 G1 X147.301 Y134.825 E0.4660 G1 X147.934 Y134.512 E0.4749 G1 X148.603 Y134.285 E0.4837 G1 X149.295 Y134.147 E0.4926 G1 X150.000 Y134.101 E0.5014 G1 X150.705 Y134.147 E0.5103 G1 X151.397 Y134.285 E0.5191 G1 X152.066 Y134.512 E0.5280 G1 X152.699 Y134.825 E0.5368 G1 X153.287 Y135.217 E0.5457 G1 X153.818 Y135.683 E0.5546 G1 X154.283 Y136.213 E0.5634 G1 X154.675 Y136.801 E0.5723 G1 X154.988 Y137.434 E0.5811 G1 X155.215 Y138.103 E0.5900 G1 X155.352 Y138.795 E0.5988 G1 X155.400 Y139.520 E0.6079 G1 X155.400 Y144.480 E0.6701 G1 X155.378 Y144.812 E0.6743 G1 X155.317 Y145.119 E0.6782 G1 X155.217 Y145.416 E0.6822 G1 X155.078 Y145.697 E0.6861 G1 X154.904 Y145.957 E0.6900 G1 X154.698 Y146.192 E0.6939 G1 X154.462 Y146.399 E0.6979 G1 X154.202 Y146.573 E0.7018 G1 X153.921 Y146.711 E0.7057 G1 X153.605 Y146.819 E0.7099 G1 X153.605 Y146.709 E0.7113 G1 X153.605 Y145.709 F1909 ; outer perimeter G1 X153.205 Y145.573 F4800 G92 E0 G1 X153.855 Y144.726 E0.0134 F1273 G1 X154.300 Y143.652 E0.0280 G1 X154.452 Y142.500 E0.0425 G1 X154.300 Y141.348 E0.0571 G1 X153.855 Y140.274 E0.0717 G1 X153.148 Y139.352 E0.0863 G1 X152.226 Y138.645 E0.1008 G1 X151.152 Y138.200 E0.1154 G1 X150.000 Y138.048 E0.1300 G1 X148.848 Y138.200 E0.1446 G1 X147.774 Y138.645 E0.1591 G1 X146.852 Y139.352 E0.1737 G1 X146.145 Y140.274 E0.1883 G1 X145.700 Y141.348 E0.2028 G1 X145.548 Y142.500 E0.2174 G1 X145.700 Y143.652 E0.2320 G1 X146.145 Y144.726 E0.2466 G1 X146.795 Y145.573 E0.2600 G1 X146.795 Y147.284 E0.2814 G1 X146.631 Y147.271 E0.2835 G1 X146.272 Y147.199 E0.2881 G1 X145.925 Y147.082 E0.2927 G1 X145.598 Y146.920 E0.2972 G1 X145.294 Y146.717 E0.3018 G1 X145.019 Y146.476 E0.3064 G1 X144.778 Y146.201 E0.3110 G1 X144.575 Y145.897 E0.3156 G1 X144.413 Y145.569 E0.3202 G1 X144.296 Y145.223 E0.3247 G1 X144.224 Y144.865 E0.3293 G1 X144.200 Y144.493 E0.3340 G1 X144.200 Y139.507 E0.3965 G1 X144.250 Y138.743 E0.4061 G1 X144.398 Y137.999 E0.4156 G1 X144.642 Y137.281 E0.4251 G1 X144.977 Y136.600 E0.4347 G1 X145.399 Y135.969 E0.4442 G1 X145.899 Y135.399 E0.4537 G1 X146.469 Y134.899 E0.4632 G1 X147.100 Y134.477 E0.4727 G1 X147.781 Y134.142 E0.4822 G1 X148.499 Y133.898 E0.4917 G1 X149.243 Y133.750 E0.5013 G1 X150.000 Y133.700 E0.5108 G1 X150.757 Y133.750 E0.5203 G1 X151.501 Y133.898 E0.5298 G1 X152.219 Y134.142 E0.5393 G1 X152.900 Y134.477 E0.5488 G1 X153.531 Y134.899 E0.5583 G1 X154.101 Y135.399 E0.5678 G1 X154.601 Y135.969 E0.5774 G1 X155.023 Y136.600 E0.5869 G1 X155.358 Y137.281 E0.5964 G1 X155.602 Y137.999 E0.6059 G1 X155.750 Y138.743 E0.6154 G1 X155.800 Y139.507 E0.6250 G1 X155.800 Y144.494 E0.6875 G1 X155.776 Y144.865 E0.6922 G1 X155.704 Y145.223 E0.6968 G1 X155.587 Y145.569 E0.7014 G1 X155.425 Y145.897 E0.7060 G1 X155.222 Y146.201 E0.7105 G1 X154.981 Y146.476 E0.7151 G1 X154.706 Y146.717 E0.7197 G1 X154.402 Y146.920 E0.7243 G1 X154.075 Y147.082 E0.7289 G1 X153.728 Y147.199 E0.7335 G1 X153.369 Y147.271 E0.7381 G1 X153.205 Y147.284 E0.7401 G1 X153.205 Y146.573 E0.7490 G1 X153.205 Y145.573 F1273 ; gap fill G1 X155.022 Y144.840 F4800 G92 E0 G1 X154.733 Y144.551 E0.0051 F2036 G1 X154.826 Y144.327 E0.0082 G1 X154.899 Y144.151 F2036 G1 X155.056 Y144.308 F2036 G1 X155.056 Y143.742 F2036 G1 X155.041 Y143.727 F2036 G92 E0 G1 E-6.5000 F1500 G1 X144.944 Y143.813 F4800 G1 E0.0000 F1500 G92 E0 G1 X144.975 Y143.843 E0.0005 F2036 G1 X144.975 Y143.846 E0.0006 G1 X145.368 Y144.796 E0.0135 G1 X145.364 Y144.798 E0.0135 G1 X145.196 Y144.630 E0.0165 G1 X144.944 Y144.378 F2036 G1 X144.944 Y144.469 F2036 G1 X144.964 Y144.767 F2036 G1 X145.012 Y145.012 F2036 G1 X145.015 Y145.015 F2036 ; solid layer G1 X145.366 Y139.144 F4800 G92 E0 G1 X145.484 Y139.262 E0.0021 F2036 G1 X145.730 Y138.942 E0.0072 G1 X145.432 Y138.644 E0.0124 G1 X145.502 Y138.295 E0.0169 G1 X145.539 Y138.185 E0.0184 G1 X145.976 Y138.622 E0.0261 G1 X146.039 Y138.539 E0.0274 G1 X146.277 Y138.357 E0.0312 G1 X145.682 Y137.763 E0.0417 G1 X145.697 Y137.718 E0.0423 G1 X145.864 Y137.379 E0.0470 G1 X146.597 Y138.111 E0.0600 G1 X146.917 Y137.866 E0.0651 G1 X146.069 Y137.018 E0.0801 G1 X146.296 Y136.679 E0.0852 G1 X147.246 Y137.629 E0.1021 G1 X147.646 Y137.464 E0.1075 G1 X146.559 Y136.376 E0.1268 G1 X146.707 Y136.207 E0.1296 G1 X146.839 Y136.091 E0.1318 G1 X148.046 Y137.298 E0.1532 G1 X148.446 Y137.132 E0.1587 G1 X147.140 Y135.827 E0.1818 G1 X147.165 Y135.805 E0.1822 G1 X147.476 Y135.597 E0.1869 G1 X148.920 Y137.041 E0.2125 G1 X149.420 Y136.975 E0.2188 G1 X147.832 Y135.387 E0.2470 G1 X148.211 Y135.201 E0.2523 G1 X149.920 Y136.909 E0.2826 G1 X150.000 Y136.898 E0.2836 G1 X150.547 Y136.970 E0.2905 G1 X148.633 Y135.056 E0.3245 G1 X148.638 Y135.055 E0.3245 G1 X149.104 Y134.962 E0.3305 G1 X151.198 Y137.056 E0.3676 G1 X151.450 Y137.089 E0.3708 G1 X152.043 Y137.335 E0.3789 G1 X149.631 Y134.923 E0.4216 G1 X150.000 Y134.899 E0.4263 G1 X150.184 Y134.911 E0.4286 G1 X153.324 Y138.050 E0.4843 G1 X153.961 Y138.539 E0.4944 G1 X154.450 Y139.176 E0.5044 G1 X154.649 Y139.375 E0.5080 G1 X154.617 Y138.892 E0.5140 G1 X154.589 Y138.750 E0.5158 G1 X150.790 Y134.950 E0.5832 G1 X150.862 Y134.955 E0.5841 G1 X151.362 Y135.055 E0.5905 G1 X151.510 Y135.105 E0.5925 G1 X154.395 Y137.990 E0.6437 G1 X154.303 Y137.718 E0.6473 G1 X154.033 Y137.171 E0.6549 G1 X153.814 Y136.843 E0.6599 G1 X153.364 Y136.393 E0.6678 G1 X152.657 Y135.686 F2036 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X150.652 Y153.545 F4800 G1 E0.0000 F1500 G92 E0 G1 X151.294 Y153.672 E0.0082 F1909 G1 X151.913 Y153.883 E0.0164 G1 X152.499 Y154.172 E0.0246 G1 X153.042 Y154.535 E0.0328 G1 X153.534 Y154.966 E0.0410 G1 X153.965 Y155.458 E0.0492 G1 X154.328 Y156.001 E0.0574 G1 X154.617 Y156.587 E0.0656 G1 X154.828 Y157.206 E0.0738 G1 X154.955 Y157.848 E0.0820 G1 X155.000 Y158.533 E0.0906 G1 X155.000 Y159.190 E0.0988 G1 X154.710 Y159.248 E0.1025 G1 X154.554 Y158.871 E0.1077 G1 X153.718 Y157.782 E0.1249 G1 X152.629 Y156.946 E0.1421 G1 X151.361 Y156.421 E0.1593 G1 X150.000 Y156.241 E0.1765 G1 X148.639 Y156.421 E0.1937 G1 X147.371 Y156.946 E0.2109 G1 X146.282 Y157.782 E0.2282 G1 X145.446 Y158.871 E0.2454 G1 X145.290 Y159.248 E0.2505 G1 X145.000 Y159.190 E0.2542 G1 X145.000 Y158.533 E0.2624 G1 X145.045 Y157.848 E0.2710 G1 X145.172 Y157.206 E0.2792 G1 X145.383 Y156.587 E0.2874 G1 X145.672 Y156.001 E0.2956 G1 X146.035 Y155.458 E0.3038 G1 X146.466 Y154.966 E0.3120 G1 X146.957 Y154.535 E0.3202 G1 X147.501 Y154.172 E0.3284 G1 X148.087 Y153.883 E0.3366 G1 X148.706 Y153.672 E0.3448 G1 X149.348 Y153.545 E0.3530 G1 X149.655 Y153.525 E0.3569 G1 X150.000 Y153.502 F1909 G1 X150.652 Y153.545 F1909 G92 E0 G1 E-6.5000 F1500 G1 X154.542 Y164.145 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.819 Y164.317 E0.0041 F1909 G1 X154.731 Y164.496 E0.0066 G1 X154.586 Y164.713 E0.0099 G1 X154.414 Y164.909 E0.0131 G1 X154.264 Y165.041 E0.0156 G1 X154.137 Y164.922 E0.0178 G1 X154.026 Y164.818 F1909 G1 X154.542 Y164.145 F1909 G92 E0 G1 E-6.5000 F1500 G1 X145.974 Y164.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.736 Y165.041 E0.0041 F1909 G1 X145.586 Y164.909 E0.0066 G1 X145.414 Y164.713 E0.0099 G1 X145.269 Y164.496 E0.0131 G1 X145.181 Y164.317 E0.0156 G1 X145.329 Y164.225 E0.0178 G1 X145.458 Y164.145 F1909 G1 X145.974 Y164.818 F1909 G1 X146.395 Y164.709 F4800 G92 E0 G1 X146.395 Y165.819 E0.0139 F1909 G1 X146.079 Y165.711 E0.0181 G1 X145.798 Y165.573 E0.0220 G1 X145.538 Y165.399 E0.0260 G1 X145.302 Y165.192 E0.0299 G1 X145.096 Y164.957 E0.0338 G1 X144.922 Y164.697 E0.0377 G1 X144.783 Y164.416 E0.0417 G1 X144.683 Y164.119 E0.0456 G1 X144.622 Y163.812 E0.0495 G1 X144.600 Y163.480 E0.0537 G1 X144.600 Y158.520 E0.1159 G1 X144.647 Y157.795 E0.1250 G1 X144.785 Y157.103 E0.1339 G1 X145.012 Y156.434 E0.1427 G1 X145.325 Y155.801 E0.1516 G1 X145.717 Y155.213 E0.1604 G1 X146.183 Y154.683 E0.1693 G1 X146.714 Y154.217 E0.1781 G1 X147.301 Y153.825 E0.1870 G1 X147.934 Y153.512 E0.1958 G1 X148.603 Y153.285 E0.2047 G1 X149.295 Y153.147 E0.2136 G1 X150.000 Y153.101 E0.2224 G1 X150.705 Y153.147 E0.2313 G1 X151.397 Y153.285 E0.2401 G1 X152.066 Y153.512 E0.2490 G1 X152.699 Y153.825 E0.2578 G1 X153.287 Y154.217 E0.2667 G1 X153.818 Y154.683 E0.2755 G1 X154.283 Y155.213 E0.2844 G1 X154.675 Y155.801 E0.2933 G1 X154.988 Y156.434 E0.3021 G1 X155.215 Y157.103 E0.3110 G1 X155.352 Y157.795 E0.3198 G1 X155.400 Y158.520 E0.3289 G1 X155.400 Y163.480 E0.3911 G1 X155.378 Y163.812 E0.3953 G1 X155.317 Y164.119 E0.3992 G1 X155.217 Y164.416 E0.4032 G1 X155.078 Y164.697 E0.4071 G1 X154.904 Y164.957 E0.4110 G1 X154.698 Y165.192 E0.4149 G1 X154.462 Y165.399 E0.4189 G1 X154.202 Y165.573 E0.4228 G1 X153.921 Y165.711 E0.4267 G1 X153.605 Y165.819 E0.4309 G1 X153.605 Y164.709 E0.4448 G1 X154.205 Y163.928 E0.4572 G1 X154.690 Y162.757 E0.4731 G1 X154.855 Y161.500 E0.4890 G1 X154.690 Y160.243 E0.5048 G1 X154.205 Y159.072 E0.5207 G1 X153.433 Y158.067 E0.5366 G1 X152.428 Y157.295 E0.5525 G1 X151.257 Y156.810 E0.5684 G1 X150.000 Y156.645 E0.5843 G1 X148.743 Y156.810 E0.6002 G1 X147.572 Y157.295 E0.6161 G1 X146.567 Y158.067 E0.6320 G1 X145.795 Y159.072 E0.6479 G1 X145.310 Y160.243 E0.6638 G1 X145.145 Y161.500 E0.6797 G1 X145.310 Y162.757 E0.6956 G1 X145.789 Y163.914 E0.7113 G1 X145.795 Y163.928 F1909 G1 X146.395 Y164.709 F1909 ; outer perimeter G1 X146.795 Y164.573 F4800 G92 E0 G1 X146.795 Y166.284 E0.0215 F1273 G1 X146.631 Y166.271 E0.0235 G1 X146.272 Y166.199 E0.0281 G1 X145.925 Y166.082 E0.0327 G1 X145.598 Y165.920 E0.0373 G1 X145.294 Y165.717 E0.0419 G1 X145.019 Y165.476 E0.0464 G1 X144.778 Y165.201 E0.0510 G1 X144.575 Y164.897 E0.0556 G1 X144.413 Y164.569 E0.0602 G1 X144.296 Y164.223 E0.0648 G1 X144.224 Y163.865 E0.0694 G1 X144.200 Y163.493 E0.0740 G1 X144.200 Y158.507 E0.1366 G1 X144.250 Y157.743 E0.1462 G1 X144.398 Y156.999 E0.1557 G1 X144.642 Y156.281 E0.1652 G1 X144.977 Y155.600 E0.1747 G1 X145.399 Y154.969 E0.1842 G1 X145.899 Y154.399 E0.1937 G1 X146.469 Y153.899 E0.2032 G1 X147.100 Y153.477 E0.2128 G1 X147.781 Y153.142 E0.2223 G1 X148.499 Y152.898 E0.2318 G1 X149.243 Y152.750 E0.2413 G1 X150.000 Y152.700 E0.2508 G1 X150.757 Y152.750 E0.2603 G1 X151.501 Y152.898 E0.2698 G1 X152.219 Y153.142 E0.2793 G1 X152.900 Y153.477 E0.2889 G1 X153.531 Y153.899 E0.2984 G1 X154.101 Y154.399 E0.3079 G1 X154.601 Y154.969 E0.3174 G1 X155.023 Y155.600 E0.3269 G1 X155.358 Y156.281 E0.3364 G1 X155.602 Y156.999 E0.3459 G1 X155.750 Y157.743 E0.3555 G1 X155.800 Y158.507 E0.3650 G1 X155.800 Y163.494 E0.4276 G1 X155.776 Y163.865 E0.4323 G1 X155.704 Y164.223 E0.4368 G1 X155.587 Y164.569 E0.4414 G1 X155.425 Y164.897 E0.4460 G1 X155.222 Y165.201 E0.4506 G1 X154.981 Y165.476 E0.4552 G1 X154.706 Y165.717 E0.4598 G1 X154.402 Y165.920 E0.4643 G1 X154.075 Y166.082 E0.4689 G1 X153.728 Y166.199 E0.4735 G1 X153.369 Y166.271 E0.4781 G1 X153.205 Y166.284 E0.4802 G1 X153.205 Y164.573 E0.5016 G1 X153.855 Y163.726 E0.5150 G1 X154.300 Y162.652 E0.5296 G1 X154.452 Y161.500 E0.5442 G1 X154.300 Y160.348 E0.5587 G1 X153.855 Y159.274 E0.5733 G1 X153.148 Y158.352 E0.5879 G1 X152.226 Y157.645 E0.6024 G1 X151.152 Y157.200 E0.6170 G1 X150.000 Y157.048 E0.6316 G1 X148.848 Y157.200 E0.6462 G1 X147.774 Y157.645 E0.6607 G1 X146.852 Y158.352 E0.6753 G1 X146.145 Y159.274 E0.6899 G1 X145.700 Y160.348 E0.7045 G1 X145.548 Y161.500 E0.7190 G1 X145.700 Y162.652 E0.7336 G1 X146.145 Y163.726 E0.7482 G1 X146.186 Y163.780 E0.7490 G1 X146.795 Y164.573 F1273 ; gap fill G1 X144.954 Y163.622 F4800 G92 E0 G1 X145.220 Y163.888 E0.0047 F2036 G1 X145.263 Y163.861 E0.0054 G1 X145.368 Y163.796 F2036 G1 X145.138 Y163.240 F2036 G1 X144.944 Y163.046 F2036 G92 E0 G1 E-6.5000 F1500 G1 X154.930 Y163.981 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.665 Y163.716 E0.0047 F2036 G1 X154.815 Y163.354 E0.0096 G1 X154.831 Y163.316 F2036 G1 X155.052 Y163.537 F2036 G1 X155.056 Y163.469 F2036 G1 X155.056 Y162.976 F2036 G1 X154.996 Y162.916 F2036 ; solid layer G1 X152.083 Y154.346 F4800 G92 E0 G1 X154.154 Y156.417 E0.0367 F2036 G1 X154.303 Y156.718 E0.0409 G1 X154.498 Y157.295 E0.0486 G1 X154.506 Y157.335 E0.0491 G1 X151.193 Y154.021 E0.1079 G1 X150.862 Y153.955 E0.1121 G1 X150.540 Y153.934 E0.1161 G1 X154.626 Y158.020 E0.1886 G1 X154.653 Y158.441 E0.1939 G1 X153.961 Y157.539 E0.2082 G1 X152.801 Y156.649 E0.2265 G1 X152.610 Y156.570 E0.2291 G1 X149.943 Y153.902 E0.2764 G1 X149.412 Y153.937 E0.2831 G1 X151.645 Y156.170 E0.3227 G1 X151.450 Y156.089 E0.3253 G1 X150.930 Y156.021 E0.3319 G1 X148.910 Y154.001 E0.3677 G1 X148.638 Y154.055 E0.3712 G1 X148.459 Y154.116 E0.3736 G1 X150.278 Y155.935 E0.4058 G1 X150.000 Y155.898 E0.4093 G1 X149.714 Y155.936 E0.4130 G1 X148.055 Y154.278 E0.4424 G1 X147.676 Y154.464 E0.4477 G1 X149.214 Y156.002 E0.4749 G1 X148.714 Y156.068 E0.4813 G1 X147.337 Y154.691 E0.5057 G1 X147.165 Y154.805 E0.5083 G1 X147.016 Y154.936 E0.5108 G1 X148.281 Y156.201 E0.5332 G1 X147.881 Y156.366 E0.5386 G1 X146.715 Y155.200 E0.5593 G1 X146.707 Y155.207 E0.5594 G1 X146.450 Y155.500 E0.5643 G1 X147.481 Y156.532 E0.5826 G1 X147.199 Y156.649 E0.5865 G1 X147.105 Y156.721 E0.5880 G1 X146.202 Y155.819 E0.6040 G1 X145.976 Y156.158 E0.6091 G1 X146.785 Y156.967 E0.6234 G1 X146.465 Y157.213 E0.6285 G1 X145.787 Y156.535 E0.6405 G1 X145.697 Y156.718 E0.6430 G1 X145.623 Y156.937 E0.6459 G1 X146.145 Y157.458 E0.6552 G1 X146.039 Y157.539 E0.6569 G1 X145.874 Y157.754 E0.6602 G1 X145.487 Y157.367 E0.6671 G1 X145.436 Y157.623 E0.6704 G1 X145.393 Y157.838 F2036 G1 X145.629 Y158.074 F2036 G1 X145.383 Y158.394 F2036 G1 X145.352 Y158.363 F2036 G92 E0 G1 E-6.5000 F1500 ; layer 6, Z = 1.300 ; inner perimeter G1 X145.000 Y158.533 F4800 G1 Z1.300 F300 G1 E0.0000 F1500 G92 E0 G1 X145.045 Y157.848 E0.0086 F1896 G1 X145.172 Y157.206 E0.0168 G1 X145.383 Y156.587 E0.0250 G1 X145.672 Y156.001 E0.0332 G1 X146.035 Y155.458 E0.0414 G1 X146.466 Y154.966 E0.0496 G1 X146.957 Y154.535 E0.0578 G1 X147.501 Y154.172 E0.0660 G1 X148.087 Y153.883 E0.0742 G1 X148.706 Y153.672 E0.0824 G1 X149.348 Y153.545 E0.0906 G1 X150.000 Y153.502 E0.0988 G1 X150.652 Y153.545 E0.1070 G1 X151.294 Y153.672 E0.1152 G1 X151.913 Y153.883 E0.1234 G1 X152.499 Y154.172 E0.1316 G1 X153.042 Y154.535 E0.1398 G1 X153.534 Y154.966 E0.1480 G1 X153.965 Y155.458 E0.1562 G1 X154.328 Y156.001 E0.1644 G1 X154.617 Y156.587 E0.1726 G1 X154.828 Y157.206 E0.1808 G1 X154.955 Y157.848 E0.1890 G1 X155.000 Y158.533 E0.1976 G1 X155.000 Y159.190 E0.2058 G1 X154.710 Y159.248 E0.2095 G1 X154.554 Y158.871 E0.2146 G1 X153.718 Y157.782 E0.2319 G1 X152.629 Y156.946 E0.2491 G1 X151.361 Y156.421 E0.2663 G1 X150.000 Y156.241 E0.2835 G1 X148.639 Y156.421 E0.3007 G1 X147.371 Y156.946 E0.3179 G1 X146.282 Y157.782 E0.3351 G1 X145.446 Y158.871 E0.3524 G1 X145.308 Y159.204 E0.3569 G1 X145.290 Y159.248 F1896 G1 X145.000 Y159.190 F1896 G1 X145.000 Y158.533 F1896 G1 X145.458 Y164.145 F4800 G92 E0 G1 X145.974 Y164.818 E0.0106 F1896 G1 X145.736 Y165.041 E0.0147 G1 X145.586 Y164.909 E0.0172 G1 X145.555 Y164.873 E0.0178 G1 X145.414 Y164.713 F1896 G1 X145.269 Y164.496 F1896 G1 X145.181 Y164.317 F1896 G1 X145.458 Y164.145 F1896 G92 E0 G1 E-6.5000 F1500 G1 X154.026 Y164.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.542 Y164.145 E0.0106 F1896 G1 X154.819 Y164.317 E0.0147 G1 X154.731 Y164.496 E0.0172 G1 X154.705 Y164.536 E0.0178 G1 X154.586 Y164.713 F1896 G1 X154.414 Y164.909 F1896 G1 X154.264 Y165.041 F1896 G1 X154.026 Y164.818 F1896 G1 X153.605 Y164.709 F4800 G92 E0 G1 X154.205 Y163.928 E0.0123 F1896 G1 X154.690 Y162.757 E0.0282 G1 X154.855 Y161.500 E0.0441 G1 X154.690 Y160.243 E0.0600 G1 X154.205 Y159.072 E0.0759 G1 X153.433 Y158.067 E0.0918 G1 X152.428 Y157.295 E0.1077 G1 X151.257 Y156.810 E0.1236 G1 X150.000 Y156.645 E0.1395 G1 X148.743 Y156.810 E0.1554 G1 X147.572 Y157.295 E0.1713 G1 X146.567 Y158.067 E0.1872 G1 X145.795 Y159.072 E0.2031 G1 X145.310 Y160.243 E0.2190 G1 X145.145 Y161.500 E0.2349 G1 X145.310 Y162.757 E0.2508 G1 X145.795 Y163.928 E0.2667 G1 X146.395 Y164.709 E0.2790 G1 X146.395 Y165.819 E0.2929 G1 X146.079 Y165.711 E0.2971 G1 X145.798 Y165.573 E0.3010 G1 X145.538 Y165.399 E0.3050 G1 X145.302 Y165.192 E0.3089 G1 X145.096 Y164.957 E0.3128 G1 X144.922 Y164.697 E0.3167 G1 X144.783 Y164.416 E0.3207 G1 X144.683 Y164.119 E0.3246 G1 X144.622 Y163.812 E0.3285 G1 X144.600 Y163.480 E0.3327 G1 X144.600 Y158.520 E0.3949 G1 X144.647 Y157.795 E0.4040 G1 X144.785 Y157.103 E0.4129 G1 X145.012 Y156.434 E0.4217 G1 X145.325 Y155.801 E0.4306 G1 X145.717 Y155.213 E0.4394 G1 X146.183 Y154.683 E0.4483 G1 X146.714 Y154.217 E0.4571 G1 X147.301 Y153.825 E0.4660 G1 X147.934 Y153.512 E0.4749 G1 X148.603 Y153.285 E0.4837 G1 X149.295 Y153.147 E0.4926 G1 X150.000 Y153.101 E0.5014 G1 X150.705 Y153.147 E0.5103 G1 X151.397 Y153.285 E0.5191 G1 X152.066 Y153.512 E0.5280 G1 X152.699 Y153.825 E0.5368 G1 X153.287 Y154.217 E0.5457 G1 X153.818 Y154.683 E0.5546 G1 X154.283 Y155.213 E0.5634 G1 X154.675 Y155.801 E0.5723 G1 X154.988 Y156.434 E0.5811 G1 X155.215 Y157.103 E0.5900 G1 X155.352 Y157.795 E0.5988 G1 X155.400 Y158.520 E0.6079 G1 X155.400 Y163.480 E0.6701 G1 X155.378 Y163.812 E0.6743 G1 X155.317 Y164.119 E0.6782 G1 X155.217 Y164.416 E0.6822 G1 X155.078 Y164.697 E0.6861 G1 X154.904 Y164.957 E0.6900 G1 X154.698 Y165.192 E0.6939 G1 X154.462 Y165.399 E0.6979 G1 X154.202 Y165.573 E0.7018 G1 X153.921 Y165.711 E0.7057 G1 X153.605 Y165.819 E0.7099 G1 X153.605 Y165.709 E0.7113 G1 X153.605 Y164.709 F1896 ; outer perimeter G1 X153.205 Y164.573 F4800 G92 E0 G1 X153.855 Y163.726 E0.0134 F1264 G1 X154.300 Y162.652 E0.0280 G1 X154.452 Y161.500 E0.0425 G1 X154.300 Y160.348 E0.0571 G1 X153.855 Y159.274 E0.0717 G1 X153.148 Y158.352 E0.0863 G1 X152.226 Y157.645 E0.1008 G1 X151.152 Y157.200 E0.1154 G1 X150.000 Y157.048 E0.1300 G1 X148.848 Y157.200 E0.1446 G1 X147.774 Y157.645 E0.1591 G1 X146.852 Y158.352 E0.1737 G1 X146.145 Y159.274 E0.1883 G1 X145.700 Y160.348 E0.2028 G1 X145.548 Y161.500 E0.2174 G1 X145.700 Y162.652 E0.2320 G1 X146.145 Y163.726 E0.2466 G1 X146.795 Y164.573 E0.2600 G1 X146.795 Y166.284 E0.2814 G1 X146.631 Y166.271 E0.2835 G1 X146.272 Y166.199 E0.2881 G1 X145.925 Y166.082 E0.2927 G1 X145.598 Y165.920 E0.2972 G1 X145.294 Y165.717 E0.3018 G1 X145.019 Y165.476 E0.3064 G1 X144.778 Y165.201 E0.3110 G1 X144.575 Y164.897 E0.3156 G1 X144.413 Y164.569 E0.3202 G1 X144.296 Y164.223 E0.3247 G1 X144.224 Y163.865 E0.3293 G1 X144.200 Y163.493 E0.3340 G1 X144.200 Y158.507 E0.3965 G1 X144.250 Y157.743 E0.4061 G1 X144.398 Y156.999 E0.4156 G1 X144.642 Y156.281 E0.4251 G1 X144.977 Y155.600 E0.4347 G1 X145.399 Y154.969 E0.4442 G1 X145.899 Y154.399 E0.4537 G1 X146.469 Y153.899 E0.4632 G1 X147.100 Y153.477 E0.4727 G1 X147.781 Y153.142 E0.4822 G1 X148.499 Y152.898 E0.4917 G1 X149.243 Y152.750 E0.5013 G1 X150.000 Y152.700 E0.5108 G1 X150.757 Y152.750 E0.5203 G1 X151.501 Y152.898 E0.5298 G1 X152.219 Y153.142 E0.5393 G1 X152.900 Y153.477 E0.5488 G1 X153.531 Y153.899 E0.5583 G1 X154.101 Y154.399 E0.5678 G1 X154.601 Y154.969 E0.5774 G1 X155.023 Y155.600 E0.5869 G1 X155.358 Y156.281 E0.5964 G1 X155.602 Y156.999 E0.6059 G1 X155.750 Y157.743 E0.6154 G1 X155.800 Y158.507 E0.6250 G1 X155.800 Y163.494 E0.6875 G1 X155.776 Y163.865 E0.6922 G1 X155.704 Y164.223 E0.6968 G1 X155.587 Y164.569 E0.7014 G1 X155.425 Y164.897 E0.7060 G1 X155.222 Y165.201 E0.7105 G1 X154.981 Y165.476 E0.7151 G1 X154.706 Y165.717 E0.7197 G1 X154.402 Y165.920 E0.7243 G1 X154.075 Y166.082 E0.7289 G1 X153.728 Y166.199 E0.7335 G1 X153.369 Y166.271 E0.7381 G1 X153.205 Y166.284 E0.7401 G1 X153.205 Y165.573 E0.7490 G1 X153.205 Y164.573 F1264 ; gap fill G1 X154.780 Y163.888 F4800 G92 E0 G1 X154.940 Y163.727 E0.0028 F2022 G1 X155.046 Y163.622 F2022 G1 X155.056 Y163.469 F2022 G1 X155.056 Y163.046 F2022 G1 X154.862 Y163.240 F2022 G92 E0 G1 E-6.5000 F1500 G1 X145.335 Y163.716 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.070 Y163.981 E0.0047 F2022 G1 X145.013 Y164.016 E0.0055 G1 X144.964 Y163.767 E0.0087 G1 X144.960 Y163.706 E0.0095 G1 X144.948 Y163.537 F2022 G1 X145.170 Y163.316 F2022 G1 X145.004 Y162.916 F2022 G1 X144.944 Y162.976 F2022 ; solid layer G1 X145.846 Y156.417 F4800 G92 E0 G1 X147.917 Y154.346 E0.0367 F2022 G1 X148.218 Y154.197 E0.0409 G1 X148.638 Y154.055 E0.0465 G1 X148.807 Y154.021 E0.0487 G1 X145.494 Y157.335 E0.1074 G1 X145.383 Y157.892 E0.1146 G1 X145.374 Y158.020 E0.1162 G1 X149.460 Y153.934 E0.1886 G1 X150.000 Y153.899 E0.1954 G1 X150.057 Y153.902 E0.1961 G1 X147.390 Y156.570 E0.2434 G1 X148.356 Y156.170 E0.2566 G1 X150.588 Y153.937 E0.2961 G1 X150.862 Y153.955 E0.2996 G1 X151.090 Y154.001 E0.3025 G1 X149.070 Y156.021 E0.3383 G1 X149.722 Y155.935 E0.3466 G1 X151.541 Y154.116 E0.3788 G1 X151.782 Y154.197 E0.3820 G1 X151.945 Y154.278 E0.3843 G1 X150.286 Y155.936 E0.4137 G1 X150.786 Y156.002 E0.4200 G1 X152.324 Y154.464 E0.4473 G1 X152.328 Y154.467 E0.4474 G1 X152.663 Y154.691 E0.4524 G1 X151.286 Y156.068 E0.4769 G1 X151.450 Y156.089 E0.4789 G1 X151.719 Y156.201 E0.4826 G1 X152.984 Y154.936 E0.5050 G1 X153.285 Y155.200 E0.5100 G1 X152.119 Y156.366 E0.5307 G1 X152.519 Y156.532 E0.5362 G1 X153.551 Y155.500 E0.5544 G1 X153.695 Y155.665 E0.5572 G1 X153.798 Y155.819 E0.5595 G1 X152.895 Y156.721 E0.5755 G1 X153.215 Y156.967 E0.5806 G1 X154.024 Y156.158 E0.5949 G1 X154.033 Y156.171 E0.5951 G1 X154.213 Y156.535 E0.6002 G1 X153.535 Y157.213 E0.6122 G1 X153.856 Y157.458 E0.6173 G1 X154.377 Y156.937 E0.6265 G1 X154.498 Y157.295 E0.6313 G1 X154.513 Y157.367 E0.6322 G1 X154.126 Y157.754 E0.6391 G1 X154.312 Y157.997 E0.6429 G1 X154.371 Y158.074 F2022 G1 X154.607 Y157.838 F2022 G1 X154.617 Y157.892 F2022 G1 X154.648 Y158.363 F2022 G1 X154.617 Y158.394 F2022 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X154.264 Y146.041 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.026 Y145.818 E0.0041 F1896 G1 X154.542 Y145.145 E0.0147 G1 X154.752 Y145.275 E0.0178 G1 X154.819 Y145.317 F1896 G1 X154.731 Y145.496 F1896 G1 X154.586 Y145.713 F1896 G1 X154.414 Y145.909 F1896 G1 X154.264 Y146.041 F1896 G1 X154.710 Y140.248 F4800 G92 E0 G1 X154.554 Y139.871 E0.0051 F1896 G1 X153.718 Y138.782 E0.0223 G1 X152.629 Y137.946 E0.0395 G1 X151.361 Y137.421 E0.0568 G1 X150.000 Y137.241 E0.0740 G1 X148.639 Y137.421 E0.0912 G1 X147.371 Y137.946 E0.1084 G1 X146.282 Y138.782 E0.1256 G1 X145.446 Y139.871 E0.1428 G1 X145.290 Y140.248 E0.1480 G1 X145.000 Y140.190 E0.1517 G1 X145.000 Y139.533 E0.1599 G1 X145.045 Y138.848 E0.1685 G1 X145.172 Y138.206 E0.1767 G1 X145.383 Y137.587 E0.1849 G1 X145.672 Y137.001 E0.1931 G1 X146.035 Y136.458 E0.2013 G1 X146.466 Y135.966 E0.2095 G1 X146.957 Y135.535 E0.2177 G1 X147.501 Y135.172 E0.2259 G1 X148.087 Y134.883 E0.2341 G1 X148.706 Y134.672 E0.2423 G1 X149.348 Y134.545 E0.2505 G1 X150.000 Y134.502 E0.2587 G1 X150.652 Y134.545 E0.2669 G1 X151.294 Y134.672 E0.2751 G1 X151.913 Y134.883 E0.2833 G1 X152.499 Y135.172 E0.2915 G1 X153.042 Y135.535 E0.2997 G1 X153.534 Y135.966 E0.3079 G1 X153.965 Y136.458 E0.3161 G1 X154.328 Y137.001 E0.3243 G1 X154.617 Y137.587 E0.3325 G1 X154.828 Y138.206 E0.3407 G1 X154.955 Y138.848 E0.3489 G1 X154.997 Y139.486 E0.3569 G1 X155.000 Y139.533 F1896 G1 X155.000 Y140.190 F1896 G1 X154.710 Y140.248 F1896 G92 E0 G1 E-6.5000 F1500 G1 X145.974 Y145.818 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.736 Y146.041 E0.0041 F1896 G1 X145.586 Y145.909 E0.0066 G1 X145.414 Y145.713 E0.0099 G1 X145.269 Y145.496 E0.0131 G1 X145.181 Y145.317 E0.0156 G1 X145.329 Y145.225 E0.0178 G1 X145.458 Y145.145 F1896 G1 X145.974 Y145.818 F1896 G1 X146.395 Y145.709 F4800 G92 E0 G1 X146.395 Y146.819 E0.0139 F1896 G1 X146.079 Y146.711 E0.0181 G1 X145.798 Y146.573 E0.0220 G1 X145.538 Y146.399 E0.0260 G1 X145.302 Y146.192 E0.0299 G1 X145.096 Y145.957 E0.0338 G1 X144.922 Y145.697 E0.0377 G1 X144.783 Y145.416 E0.0417 G1 X144.683 Y145.119 E0.0456 G1 X144.622 Y144.812 E0.0495 G1 X144.600 Y144.480 E0.0537 G1 X144.600 Y139.520 E0.1159 G1 X144.647 Y138.795 E0.1250 G1 X144.785 Y138.103 E0.1339 G1 X145.012 Y137.434 E0.1427 G1 X145.325 Y136.801 E0.1516 G1 X145.717 Y136.213 E0.1604 G1 X146.183 Y135.683 E0.1693 G1 X146.714 Y135.217 E0.1781 G1 X147.301 Y134.825 E0.1870 G1 X147.934 Y134.512 E0.1958 G1 X148.603 Y134.285 E0.2047 G1 X149.295 Y134.147 E0.2136 G1 X150.000 Y134.101 E0.2224 G1 X150.705 Y134.147 E0.2313 G1 X151.397 Y134.285 E0.2401 G1 X152.066 Y134.512 E0.2490 G1 X152.699 Y134.825 E0.2578 G1 X153.287 Y135.217 E0.2667 G1 X153.818 Y135.683 E0.2755 G1 X154.283 Y136.213 E0.2844 G1 X154.675 Y136.801 E0.2933 G1 X154.988 Y137.434 E0.3021 G1 X155.215 Y138.103 E0.3110 G1 X155.352 Y138.795 E0.3198 G1 X155.400 Y139.520 E0.3289 G1 X155.400 Y144.480 E0.3911 G1 X155.378 Y144.812 E0.3953 G1 X155.317 Y145.119 E0.3992 G1 X155.217 Y145.416 E0.4032 G1 X155.078 Y145.697 E0.4071 G1 X154.904 Y145.957 E0.4110 G1 X154.698 Y146.192 E0.4149 G1 X154.462 Y146.399 E0.4189 G1 X154.202 Y146.573 E0.4228 G1 X153.921 Y146.711 E0.4267 G1 X153.605 Y146.819 E0.4309 G1 X153.605 Y145.709 E0.4448 G1 X154.205 Y144.928 E0.4572 G1 X154.690 Y143.757 E0.4731 G1 X154.855 Y142.500 E0.4890 G1 X154.690 Y141.243 E0.5048 G1 X154.205 Y140.072 E0.5207 G1 X153.433 Y139.067 E0.5366 G1 X152.428 Y138.295 E0.5525 G1 X151.257 Y137.810 E0.5684 G1 X150.000 Y137.645 E0.5843 G1 X148.743 Y137.810 E0.6002 G1 X147.572 Y138.295 E0.6161 G1 X146.567 Y139.067 E0.6320 G1 X145.795 Y140.072 E0.6479 G1 X145.310 Y141.243 E0.6638 G1 X145.145 Y142.500 E0.6797 G1 X145.310 Y143.757 E0.6956 G1 X145.789 Y144.914 E0.7113 G1 X145.795 Y144.928 F1896 G1 X146.395 Y145.709 F1896 ; outer perimeter G1 X146.795 Y145.573 F4800 G92 E0 G1 X146.795 Y147.284 E0.0215 F1264 G1 X146.631 Y147.271 E0.0235 G1 X146.272 Y147.199 E0.0281 G1 X145.925 Y147.082 E0.0327 G1 X145.598 Y146.920 E0.0373 G1 X145.294 Y146.717 E0.0419 G1 X145.019 Y146.476 E0.0464 G1 X144.778 Y146.201 E0.0510 G1 X144.575 Y145.897 E0.0556 G1 X144.413 Y145.569 E0.0602 G1 X144.296 Y145.223 E0.0648 G1 X144.224 Y144.865 E0.0694 G1 X144.200 Y144.493 E0.0740 G1 X144.200 Y139.507 E0.1366 G1 X144.250 Y138.743 E0.1462 G1 X144.398 Y137.999 E0.1557 G1 X144.642 Y137.281 E0.1652 G1 X144.977 Y136.600 E0.1747 G1 X145.399 Y135.969 E0.1842 G1 X145.899 Y135.399 E0.1937 G1 X146.469 Y134.899 E0.2032 G1 X147.100 Y134.477 E0.2128 G1 X147.781 Y134.142 E0.2223 G1 X148.499 Y133.898 E0.2318 G1 X149.243 Y133.750 E0.2413 G1 X150.000 Y133.700 E0.2508 G1 X150.757 Y133.750 E0.2603 G1 X151.501 Y133.898 E0.2698 G1 X152.219 Y134.142 E0.2793 G1 X152.900 Y134.477 E0.2889 G1 X153.531 Y134.899 E0.2984 G1 X154.101 Y135.399 E0.3079 G1 X154.601 Y135.969 E0.3174 G1 X155.023 Y136.600 E0.3269 G1 X155.358 Y137.281 E0.3364 G1 X155.602 Y137.999 E0.3459 G1 X155.750 Y138.743 E0.3555 G1 X155.800 Y139.507 E0.3650 G1 X155.800 Y144.494 E0.4276 G1 X155.776 Y144.865 E0.4323 G1 X155.704 Y145.223 E0.4368 G1 X155.587 Y145.569 E0.4414 G1 X155.425 Y145.897 E0.4460 G1 X155.222 Y146.201 E0.4506 G1 X154.981 Y146.476 E0.4552 G1 X154.706 Y146.717 E0.4598 G1 X154.402 Y146.920 E0.4643 G1 X154.075 Y147.082 E0.4689 G1 X153.728 Y147.199 E0.4735 G1 X153.369 Y147.271 E0.4781 G1 X153.205 Y147.284 E0.4802 G1 X153.205 Y145.573 E0.5016 G1 X153.855 Y144.726 E0.5150 G1 X154.300 Y143.652 E0.5296 G1 X154.452 Y142.500 E0.5442 G1 X154.300 Y141.348 E0.5587 G1 X153.855 Y140.274 E0.5733 G1 X153.148 Y139.352 E0.5879 G1 X152.226 Y138.645 E0.6024 G1 X151.152 Y138.200 E0.6170 G1 X150.000 Y138.048 E0.6316 G1 X148.848 Y138.200 E0.6462 G1 X147.774 Y138.645 E0.6607 G1 X146.852 Y139.352 E0.6753 G1 X146.145 Y140.274 E0.6899 G1 X145.700 Y141.348 E0.7045 G1 X145.548 Y142.500 E0.7190 G1 X145.700 Y143.652 E0.7336 G1 X146.145 Y144.726 E0.7482 G1 X146.186 Y144.780 E0.7490 G1 X146.795 Y145.573 F1264 ; gap fill G1 X145.267 Y144.551 F4800 G92 E0 G1 X144.978 Y144.840 E0.0051 F2022 G1 X144.964 Y144.767 E0.0060 G1 X144.953 Y144.614 E0.0080 G1 X144.944 Y144.469 F2022 G1 X144.944 Y144.308 F2022 G1 X145.101 Y144.151 F2022 G1 X144.975 Y143.846 F2022 G1 X144.959 Y143.727 F2022 G1 X144.944 Y143.742 F2022 G92 E0 G1 E-6.5000 F1500 G1 X155.025 Y143.843 F4800 G1 E0.0000 F1500 G92 E0 G1 X155.056 Y143.813 E0.0005 F2022 G1 X155.056 Y144.378 E0.0076 G1 X155.050 Y144.384 E0.0077 G1 X154.636 Y144.798 F2022 G1 X154.985 Y145.015 F2022 G1 X154.988 Y145.012 F2022 ; solid layer G1 X154.516 Y139.262 F4800 G92 E0 G1 X154.634 Y139.144 E0.0021 F2022 G1 X154.617 Y138.892 E0.0053 G1 X154.568 Y138.644 E0.0084 G1 X154.270 Y138.942 E0.0137 G1 X154.024 Y138.622 E0.0188 G1 X154.461 Y138.185 E0.0265 G1 X154.318 Y137.763 E0.0321 G1 X153.724 Y138.357 E0.0427 G1 X153.403 Y138.111 E0.0477 G1 X154.136 Y137.379 E0.0607 G1 X154.033 Y137.171 E0.0636 G1 X153.931 Y137.018 E0.0659 G1 X153.083 Y137.866 E0.0809 G1 X152.801 Y137.649 E0.0854 G1 X152.754 Y137.629 E0.0860 G1 X153.704 Y136.679 E0.1029 G1 X153.695 Y136.665 E0.1031 G1 X153.442 Y136.376 E0.1079 G1 X152.354 Y137.464 E0.1272 G1 X151.954 Y137.298 E0.1327 G1 X153.161 Y136.091 E0.1541 G1 X152.860 Y135.827 E0.1591 G1 X151.554 Y137.132 E0.1822 G1 X151.450 Y137.089 E0.1837 G1 X151.080 Y137.041 E0.1883 G1 X152.524 Y135.597 E0.2139 G1 X152.328 Y135.467 E0.2169 G1 X152.168 Y135.387 E0.2191 G1 X150.580 Y136.975 E0.2473 G1 X150.080 Y136.909 E0.2536 G1 X151.789 Y135.201 E0.2839 G1 X151.782 Y135.197 E0.2840 G1 X151.367 Y135.056 E0.2895 G1 X149.453 Y136.970 E0.3234 G1 X148.802 Y137.056 E0.3317 G1 X150.896 Y134.962 E0.3688 G1 X150.862 Y134.955 E0.3693 G1 X150.369 Y134.923 E0.3754 G1 X148.664 Y136.628 E0.4057 G1 X147.957 Y137.335 F2022 G1 X146.186 Y136.843 F4800 G92 E0 G1 X147.344 Y135.686 E0.0205 F2022 G1 X147.672 Y135.467 E0.0255 G1 X148.218 Y135.197 E0.0331 G1 X148.490 Y135.105 E0.0367 G1 X145.605 Y137.990 E0.0879 G1 X145.502 Y138.295 E0.0919 G1 X145.411 Y138.750 E0.0977 G1 X149.210 Y134.950 E0.1651 G1 X149.816 Y134.911 E0.1727 G1 X146.677 Y138.050 E0.2284 G1 X146.039 Y138.539 E0.2385 G1 X145.987 Y138.606 E0.2395 G1 X145.550 Y139.177 F2022 G1 X145.351 Y139.375 F2022 G92 E0 G1 E-6.5000 F1500 ; layer 7, Z = 1.500 ; inner perimeter G1 X146.244 Y136.088 F4800 G1 Z1.500 F300 G1 E0.0000 F1500 G92 E0 G1 X146.035 Y135.850 E0.0040 F582 G1 X146.183 Y135.683 E0.0068 G1 X146.714 Y135.217 E0.0156 G1 X147.301 Y134.825 E0.0245 G1 X147.934 Y134.512 E0.0333 G1 X148.603 Y134.285 E0.0422 G1 X149.295 Y134.147 E0.0510 G1 X150.000 Y134.101 E0.0599 G1 X150.705 Y134.147 E0.0687 G1 X151.397 Y134.285 E0.0776 G1 X152.066 Y134.512 E0.0865 G1 X152.699 Y134.825 E0.0953 G1 X153.287 Y135.217 E0.1042 G1 X153.817 Y135.683 E0.1130 G1 X153.965 Y135.850 E0.1158 G1 X153.756 Y136.088 E0.1198 G1 X153.301 Y135.783 E0.1267 G1 X152.526 Y135.401 E0.1375 G1 X151.709 Y135.124 E0.1483 G1 X150.862 Y134.955 E0.1591 G1 X150.000 Y134.899 E0.1700 G1 X149.138 Y134.955 E0.1808 G1 X148.291 Y135.124 E0.1916 G1 X147.474 Y135.401 E0.2025 G1 X147.105 Y135.583 E0.2076 G1 X146.699 Y135.783 F582 G1 X146.244 Y136.088 F582 ; outer perimeter G1 X146.225 Y136.581 F4800 G92 E0 G1 X145.616 Y137.116 E0.0102 F388 G1 X145.081 Y137.725 E0.0203 G1 X144.630 Y138.400 E0.0305 G1 X144.272 Y139.127 E0.0407 G1 X144.214 Y139.298 E0.0429 G1 X144.250 Y138.743 E0.0499 G1 X144.398 Y137.999 E0.0594 G1 X144.642 Y137.281 E0.0689 G1 X144.977 Y136.600 E0.0785 G1 X145.399 Y135.969 E0.0880 G1 X145.899 Y135.399 E0.0975 G1 X146.469 Y134.899 E0.1070 G1 X147.100 Y134.477 E0.1165 G1 X147.781 Y134.142 E0.1260 G1 X148.499 Y133.898 E0.1355 G1 X149.243 Y133.750 E0.1450 G1 X150.000 Y133.700 E0.1546 G1 X150.757 Y133.750 E0.1641 G1 X151.501 Y133.898 E0.1736 G1 X152.219 Y134.142 E0.1831 G1 X152.900 Y134.477 E0.1926 G1 X153.531 Y134.899 E0.2021 G1 X154.101 Y135.399 E0.2116 G1 X154.601 Y135.969 E0.2212 G1 X155.023 Y136.600 E0.2307 G1 X155.358 Y137.281 E0.2402 G1 X155.602 Y137.999 E0.2497 G1 X155.750 Y138.743 E0.2592 G1 X155.786 Y139.298 E0.2662 G1 X155.728 Y139.127 E0.2684 G1 X155.370 Y138.400 E0.2786 G1 X154.919 Y137.725 E0.2888 G1 X154.384 Y137.116 E0.2989 G1 X153.775 Y136.581 E0.3091 G1 X153.100 Y136.130 E0.3193 G1 X152.373 Y135.772 E0.3295 G1 X151.605 Y135.511 E0.3396 G1 X150.809 Y135.353 E0.3498 G1 X150.000 Y135.300 E0.3600 G1 X149.191 Y135.353 E0.3701 G1 X148.395 Y135.511 E0.3803 G1 X147.627 Y135.772 E0.3905 G1 X147.069 Y136.047 E0.3983 G1 X146.900 Y136.130 F388 G1 X146.225 Y136.581 F388 ; gap fill G1 X145.730 Y136.113 F4800 G92 E0 G1 X145.967 Y136.350 E0.0042 F620 G1 X145.665 Y136.614 E0.0092 G1 X145.518 Y136.467 E0.0118 G1 X145.495 Y136.444 F620 G1 X145.276 Y136.773 F620 G1 X145.270 Y136.785 F620 G1 X145.365 Y136.880 F620 G1 X145.101 Y137.181 F620 G1 X145.083 Y137.164 F620 G1 X148.340 Y134.763 F4800 G92 E0 G1 X148.321 Y134.744 E0.0003 F620 G1 X148.692 Y134.618 E0.0053 G1 X148.749 Y134.607 E0.0060 G1 X148.812 Y134.669 E0.0071 G1 X149.093 Y134.613 E0.0107 G1 X149.307 Y134.599 E0.0134 G1 X149.221 Y134.513 E0.0149 G1 X149.340 Y134.489 E0.0164 G1 X149.737 Y134.463 E0.0214 G1 X149.838 Y134.565 E0.0232 G1 X150.000 Y134.554 E0.0253 G1 X150.421 Y134.582 E0.0305 G1 X150.305 Y134.466 E0.0326 G1 X150.660 Y134.489 E0.0370 G1 X150.834 Y134.524 E0.0393 G1 X150.952 Y134.547 F620 G1 X151.046 Y134.641 F620 G1 X151.752 Y134.782 F620 G1 X151.733 Y134.762 F620 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X150.705 Y153.147 F4800 G1 E0.0000 F1500 G92 E0 G1 X151.397 Y153.285 E0.0089 F582 G1 X152.066 Y153.512 E0.0177 G1 X152.699 Y153.825 E0.0266 G1 X153.287 Y154.217 E0.0354 G1 X153.817 Y154.683 E0.0443 G1 X153.965 Y154.850 E0.0471 G1 X153.756 Y155.088 E0.0510 G1 X153.301 Y154.783 E0.0579 G1 X152.526 Y154.401 E0.0687 G1 X151.709 Y154.124 E0.0796 G1 X150.862 Y153.955 E0.0904 G1 X150.000 Y153.899 E0.1012 G1 X149.138 Y153.955 E0.1121 G1 X148.291 Y154.124 E0.1229 G1 X147.474 Y154.401 E0.1337 G1 X146.699 Y154.783 E0.1445 G1 X146.244 Y155.088 E0.1514 G1 X146.035 Y154.850 E0.1554 G1 X146.183 Y154.683 E0.1582 G1 X146.714 Y154.217 E0.1670 G1 X147.301 Y153.825 E0.1759 G1 X147.934 Y153.512 E0.1847 G1 X148.603 Y153.285 E0.1936 G1 X149.295 Y153.147 E0.2025 G1 X149.707 Y153.120 E0.2076 G1 X150.000 Y153.101 F582 G1 X150.705 Y153.147 F582 ; outer perimeter G1 X150.757 Y152.750 F4800 G92 E0 G1 X151.501 Y152.898 E0.0095 F388 G1 X152.219 Y153.142 E0.0190 G1 X152.900 Y153.477 E0.0285 G1 X153.531 Y153.899 E0.0381 G1 X154.101 Y154.399 E0.0476 G1 X154.601 Y154.969 E0.0571 G1 X155.023 Y155.600 E0.0666 G1 X155.358 Y156.281 E0.0761 G1 X155.602 Y156.999 E0.0856 G1 X155.750 Y157.743 E0.0951 G1 X155.786 Y158.298 E0.1021 G1 X155.728 Y158.127 E0.1044 G1 X155.370 Y157.400 E0.1145 G1 X154.919 Y156.725 E0.1247 G1 X154.384 Y156.116 E0.1349 G1 X153.775 Y155.581 E0.1450 G1 X153.100 Y155.130 E0.1552 G1 X152.373 Y154.772 E0.1654 G1 X151.605 Y154.511 E0.1756 G1 X150.809 Y154.353 E0.1857 G1 X150.000 Y154.300 E0.1959 G1 X149.191 Y154.353 E0.2061 G1 X148.395 Y154.511 E0.2162 G1 X147.627 Y154.772 E0.2264 G1 X146.900 Y155.130 E0.2366 G1 X146.225 Y155.581 E0.2468 G1 X145.616 Y156.116 E0.2569 G1 X145.081 Y156.725 E0.2671 G1 X144.630 Y157.400 E0.2773 G1 X144.272 Y158.127 E0.2874 G1 X144.214 Y158.298 E0.2897 G1 X144.250 Y157.743 E0.2967 G1 X144.398 Y156.999 E0.3062 G1 X144.642 Y156.281 E0.3157 G1 X144.977 Y155.600 E0.3252 G1 X145.399 Y154.969 E0.3347 G1 X145.899 Y154.399 E0.3442 G1 X146.469 Y153.899 E0.3537 G1 X147.100 Y153.477 E0.3633 G1 X147.781 Y153.142 E0.3728 G1 X148.499 Y152.898 E0.3823 G1 X149.243 Y152.750 E0.3918 G1 X149.759 Y152.716 E0.3983 G1 X150.000 Y152.700 F388 G1 X150.757 Y152.750 F388 ; gap fill G1 X151.380 Y153.643 F4800 G92 E0 G1 X151.461 Y153.724 E0.0014 F620 G1 X150.907 Y153.613 E0.0085 G1 X150.776 Y153.605 E0.0102 G1 X150.661 Y153.490 E0.0122 G1 X150.056 Y153.450 E0.0198 G1 X150.171 Y153.565 E0.0218 G1 X150.000 Y153.554 E0.0240 G1 X149.619 Y153.579 E0.0288 G1 X149.518 Y153.478 E0.0306 G1 X149.340 Y153.489 E0.0328 G1 X149.026 Y153.552 E0.0368 G1 X149.089 Y153.614 E0.0379 G1 X149.086 Y153.615 E0.0380 G1 X148.617 Y153.708 F620 G1 X148.569 Y153.660 F620 G1 X148.147 Y153.803 F620 G1 X148.151 Y153.808 F620 G1 X145.628 Y155.245 F4800 G92 E0 G1 X145.843 Y155.459 E0.0038 F620 G1 X145.766 Y155.526 E0.0051 G1 X145.541 Y155.723 F620 G1 X145.402 Y155.584 F620 G1 X145.276 Y155.773 F620 G1 X145.193 Y155.941 F620 G1 X145.256 Y156.004 F620 G92 E0 G1 E-6.5000 F1500 G1 X154.094 Y155.225 F4800 G1 E0.0000 F1500 G92 E0 G1 X154.097 Y155.229 E0.0001 F620 G1 X154.805 Y155.936 F620 G92 E0 G1 E-6.5000 F1500 ; layer 8, Z = 1.700 ; inner perimeter G1 X153.757 Y155.088 F4800 G1 Z1.700 F300 G1 E0.0000 F1500 G92 E0 G1 X153.301 Y154.783 E0.0069 F582 G1 X152.526 Y154.401 E0.0177 G1 X151.709 Y154.124 E0.0285 G1 X150.862 Y153.955 E0.0394 G1 X150.000 Y153.899 E0.0502 G1 X149.138 Y153.955 E0.0610 G1 X148.291 Y154.124 E0.0718 G1 X147.474 Y154.401 E0.0827 G1 X146.699 Y154.783 E0.0935 G1 X146.244 Y155.088 E0.1004 G1 X146.035 Y154.850 E0.1043 G1 X146.183 Y154.683 E0.1071 G1 X146.714 Y154.217 E0.1160 G1 X147.301 Y153.825 E0.1248 G1 X147.934 Y153.512 E0.1337 G1 X148.603 Y153.285 E0.1426 G1 X149.295 Y153.147 E0.1514 G1 X150.000 Y153.101 E0.1603 G1 X150.705 Y153.147 E0.1691 G1 X151.397 Y153.285 E0.1780 G1 X152.066 Y153.512 E0.1868 G1 X152.699 Y153.825 E0.1957 G1 X153.287 Y154.217 E0.2045 G1 X153.471 Y154.379 E0.2076 G1 X153.817 Y154.683 F582 G1 X153.965 Y154.850 F582 G1 X153.756 Y155.088 F582 ; outer perimeter G1 X153.775 Y155.581 F4800 G92 E0 G1 X153.100 Y155.130 E0.0102 F388 G1 X152.373 Y154.772 E0.0203 G1 X151.605 Y154.511 E0.0305 G1 X150.809 Y154.353 E0.0407 G1 X150.000 Y154.300 E0.0509 G1 X149.191 Y154.353 E0.0610 G1 X148.395 Y154.511 E0.0712 G1 X147.627 Y154.772 E0.0814 G1 X146.900 Y155.130 E0.0915 G1 X146.225 Y155.581 E0.1017 G1 X145.616 Y156.116 E0.1119 G1 X145.081 Y156.725 E0.1221 G1 X144.630 Y157.400 E0.1322 G1 X144.272 Y158.127 E0.1424 G1 X144.214 Y158.298 E0.1447 G1 X144.250 Y157.743 E0.1516 G1 X144.398 Y156.999 E0.1611 G1 X144.642 Y156.281 E0.1706 G1 X144.977 Y155.600 E0.1802 G1 X145.399 Y154.969 E0.1897 G1 X145.899 Y154.399 E0.1992 G1 X146.469 Y153.899 E0.2087 G1 X147.100 Y153.477 E0.2182 G1 X147.781 Y153.142 E0.2277 G1 X148.499 Y152.898 E0.2372 G1 X149.243 Y152.750 E0.2468 G1 X150.000 Y152.700 E0.2563 G1 X150.757 Y152.750 E0.2658 G1 X151.501 Y152.898 E0.2753 G1 X152.219 Y153.142 E0.2848 G1 X152.900 Y153.477 E0.2943 G1 X153.531 Y153.899 E0.3038 G1 X154.101 Y154.399 E0.3134 G1 X154.601 Y154.969 E0.3229 G1 X155.023 Y155.600 E0.3324 G1 X155.358 Y156.281 E0.3419 G1 X155.602 Y156.999 E0.3514 G1 X155.750 Y157.743 E0.3609 G1 X155.786 Y158.298 E0.3679 G1 X155.728 Y158.127 E0.3701 G1 X155.370 Y157.400 E0.3803 G1 X154.919 Y156.725 E0.3905 G1 X154.509 Y156.258 E0.3983 G1 X154.384 Y156.116 F388 G1 X153.775 Y155.581 F388 ; gap fill G1 X154.158 Y155.459 F4800 G92 E0 G1 X154.372 Y155.245 E0.0038 F621 G1 X154.424 Y155.324 E0.0050 G1 X154.598 Y155.584 F621 G1 X154.459 Y155.723 F621 G1 X154.628 Y155.872 F621 G1 X154.744 Y156.004 F621 G1 X154.807 Y155.941 F621 G1 X151.854 Y153.803 F4800 G92 E0 G1 X151.849 Y153.808 E0.0001 F621 G1 X151.798 Y153.791 E0.0008 G1 X151.383 Y153.708 E0.0061 G1 X151.431 Y153.660 E0.0069 G1 X151.308 Y153.618 E0.0085 G1 X150.974 Y153.552 E0.0128 G1 X150.911 Y153.614 E0.0139 G1 X150.907 Y153.613 E0.0140 G1 X150.381 Y153.579 E0.0206 G1 X150.482 Y153.478 E0.0224 G1 X150.000 Y153.446 E0.0285 G1 X149.944 Y153.450 E0.0292 G1 X149.829 Y153.565 E0.0312 G1 X149.224 Y153.605 E0.0388 G1 X149.233 Y153.596 E0.0390 G1 X149.339 Y153.490 F621 G1 X148.692 Y153.618 F621 G1 X148.620 Y153.643 F621 G1 X148.539 Y153.724 F621 G1 X145.906 Y155.225 F4800 G92 E0 G1 X145.903 Y155.229 E0.0001 F621 G1 X145.195 Y155.936 F621 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X146.244 Y136.088 F4800 G1 E0.0000 F1500 G92 E0 G1 X146.035 Y135.850 E0.0040 F582 G1 X146.183 Y135.683 E0.0068 G1 X146.714 Y135.217 E0.0156 G1 X147.301 Y134.825 E0.0245 G1 X147.934 Y134.512 E0.0333 G1 X148.603 Y134.285 E0.0422 G1 X149.295 Y134.147 E0.0510 G1 X150.000 Y134.101 E0.0599 G1 X150.705 Y134.147 E0.0687 G1 X151.397 Y134.285 E0.0776 G1 X152.066 Y134.512 E0.0865 G1 X152.699 Y134.825 E0.0953 G1 X153.287 Y135.217 E0.1042 G1 X153.817 Y135.683 E0.1130 G1 X153.965 Y135.850 E0.1158 G1 X153.756 Y136.088 E0.1198 G1 X153.301 Y135.783 E0.1267 G1 X152.526 Y135.401 E0.1375 G1 X151.709 Y135.124 E0.1483 G1 X150.862 Y134.955 E0.1591 G1 X150.000 Y134.899 E0.1700 G1 X149.138 Y134.955 E0.1808 G1 X148.291 Y135.124 E0.1916 G1 X147.474 Y135.401 E0.2025 G1 X147.105 Y135.583 E0.2076 G1 X146.699 Y135.783 F582 G1 X146.244 Y136.088 F582 ; outer perimeter G1 X146.225 Y136.581 F4800 G92 E0 G1 X145.616 Y137.116 E0.0102 F388 G1 X145.081 Y137.725 E0.0203 G1 X144.630 Y138.400 E0.0305 G1 X144.272 Y139.127 E0.0407 G1 X144.214 Y139.298 E0.0429 G1 X144.250 Y138.743 E0.0499 G1 X144.398 Y137.999 E0.0594 G1 X144.642 Y137.281 E0.0689 G1 X144.977 Y136.600 E0.0785 G1 X145.399 Y135.969 E0.0880 G1 X145.899 Y135.399 E0.0975 G1 X146.469 Y134.899 E0.1070 G1 X147.100 Y134.477 E0.1165 G1 X147.781 Y134.142 E0.1260 G1 X148.499 Y133.898 E0.1355 G1 X149.243 Y133.750 E0.1450 G1 X150.000 Y133.700 E0.1546 G1 X150.757 Y133.750 E0.1641 G1 X151.501 Y133.898 E0.1736 G1 X152.219 Y134.142 E0.1831 G1 X152.900 Y134.477 E0.1926 G1 X153.531 Y134.899 E0.2021 G1 X154.101 Y135.399 E0.2116 G1 X154.601 Y135.969 E0.2212 G1 X155.023 Y136.600 E0.2307 G1 X155.358 Y137.281 E0.2402 G1 X155.602 Y137.999 E0.2497 G1 X155.750 Y138.743 E0.2592 G1 X155.786 Y139.298 E0.2662 G1 X155.728 Y139.127 E0.2684 G1 X155.370 Y138.400 E0.2786 G1 X154.919 Y137.725 E0.2888 G1 X154.384 Y137.116 E0.2989 G1 X153.775 Y136.581 E0.3091 G1 X153.100 Y136.130 E0.3193 G1 X152.373 Y135.772 E0.3295 G1 X151.605 Y135.511 E0.3396 G1 X150.809 Y135.353 E0.3498 G1 X150.000 Y135.300 E0.3600 G1 X149.191 Y135.353 E0.3701 G1 X148.395 Y135.511 E0.3803 G1 X147.627 Y135.772 E0.3905 G1 X147.069 Y136.047 E0.3983 G1 X146.900 Y136.130 F388 G1 X146.225 Y136.581 F388 ; gap fill G1 X148.248 Y134.782 F4800 G92 E0 G1 X148.267 Y134.762 E0.0003 F621 G1 X148.692 Y134.618 E0.0060 G1 X149.048 Y134.547 E0.0105 G1 X148.954 Y134.641 E0.0122 G1 X149.093 Y134.613 E0.0140 G1 X149.579 Y134.582 E0.0201 G1 X149.695 Y134.466 E0.0221 G1 X150.000 Y134.446 E0.0259 G1 X150.263 Y134.463 E0.0293 G1 X150.162 Y134.565 E0.0311 G1 X150.693 Y134.599 E0.0377 G1 X150.779 Y134.513 E0.0393 G1 X150.855 Y134.528 E0.0402 G1 X151.251 Y134.607 F621 G1 X151.188 Y134.669 F621 G1 X151.660 Y134.763 F621 G1 X151.679 Y134.744 F621 G1 X154.033 Y136.350 F4800 G92 E0 G1 X154.270 Y136.113 E0.0042 F621 G1 X154.328 Y136.179 E0.0053 G1 X154.505 Y136.444 E0.0093 G1 X154.347 Y136.602 E0.0121 G1 X154.335 Y136.614 F621 G1 X154.628 Y136.872 F621 G1 X154.635 Y136.880 F621 G1 X154.730 Y136.785 F621 G1 X154.917 Y137.164 F621 G1 X154.899 Y137.181 F621 G92 E0 G1 E-6.5000 F1500 ; layer 9, Z = 1.900 ; inner perimeter G1 X153.757 Y136.088 F4800 G1 Z1.900 F300 G1 E0.0000 F1500 G92 E0 G1 X153.301 Y135.783 E0.0069 F582 G1 X152.526 Y135.401 E0.0177 G1 X151.709 Y135.124 E0.0285 G1 X150.862 Y134.955 E0.0394 G1 X150.000 Y134.899 E0.0502 G1 X149.138 Y134.955 E0.0610 G1 X148.291 Y135.124 E0.0718 G1 X147.474 Y135.401 E0.0827 G1 X146.699 Y135.783 E0.0935 G1 X146.244 Y136.088 E0.1004 G1 X146.035 Y135.850 E0.1043 G1 X146.183 Y135.683 E0.1071 G1 X146.714 Y135.217 E0.1160 G1 X147.301 Y134.825 E0.1248 G1 X147.934 Y134.512 E0.1337 G1 X148.603 Y134.285 E0.1426 G1 X149.295 Y134.147 E0.1514 G1 X150.000 Y134.101 E0.1603 G1 X150.705 Y134.147 E0.1691 G1 X151.397 Y134.285 E0.1780 G1 X152.066 Y134.512 E0.1868 G1 X152.699 Y134.825 E0.1957 G1 X153.287 Y135.217 E0.2045 G1 X153.471 Y135.379 E0.2076 G1 X153.817 Y135.683 F582 G1 X153.965 Y135.850 F582 G1 X153.756 Y136.088 F582 ; outer perimeter G1 X153.775 Y136.581 F4800 G92 E0 G1 X153.100 Y136.130 E0.0102 F388 G1 X152.373 Y135.772 E0.0203 G1 X151.605 Y135.511 E0.0305 G1 X150.809 Y135.353 E0.0407 G1 X150.000 Y135.300 E0.0509 G1 X149.191 Y135.353 E0.0610 G1 X148.395 Y135.511 E0.0712 G1 X147.627 Y135.772 E0.0814 G1 X146.900 Y136.130 E0.0915 G1 X146.225 Y136.581 E0.1017 G1 X145.616 Y137.116 E0.1119 G1 X145.081 Y137.725 E0.1221 G1 X144.630 Y138.400 E0.1322 G1 X144.272 Y139.127 E0.1424 G1 X144.214 Y139.298 E0.1447 G1 X144.250 Y138.743 E0.1516 G1 X144.398 Y137.999 E0.1611 G1 X144.642 Y137.281 E0.1706 G1 X144.977 Y136.600 E0.1802 G1 X145.399 Y135.969 E0.1897 G1 X145.899 Y135.399 E0.1992 G1 X146.469 Y134.899 E0.2087 G1 X147.100 Y134.477 E0.2182 G1 X147.781 Y134.142 E0.2277 G1 X148.499 Y133.898 E0.2372 G1 X149.243 Y133.750 E0.2468 G1 X150.000 Y133.700 E0.2563 G1 X150.757 Y133.750 E0.2658 G1 X151.501 Y133.898 E0.2753 G1 X152.219 Y134.142 E0.2848 G1 X152.900 Y134.477 E0.2943 G1 X153.531 Y134.899 E0.3038 G1 X154.101 Y135.399 E0.3134 G1 X154.601 Y135.969 E0.3229 G1 X155.023 Y136.600 E0.3324 G1 X155.358 Y137.281 E0.3419 G1 X155.602 Y137.999 E0.3514 G1 X155.750 Y138.743 E0.3609 G1 X155.786 Y139.298 E0.3679 G1 X155.728 Y139.127 E0.3701 G1 X155.370 Y138.400 E0.3803 G1 X154.919 Y137.725 E0.3905 G1 X154.509 Y137.258 E0.3983 G1 X154.384 Y137.116 F388 G1 X153.775 Y136.581 F388 ; gap fill G1 X151.733 Y134.762 F4800 G92 E0 G1 X151.752 Y134.782 E0.0003 F620 G1 X151.046 Y134.641 E0.0094 G1 X150.952 Y134.547 E0.0110 G1 X150.660 Y134.489 E0.0148 G1 X150.305 Y134.466 E0.0192 G1 X150.421 Y134.582 E0.0213 G1 X150.000 Y134.554 E0.0266 G1 X149.838 Y134.565 E0.0286 G1 X149.737 Y134.463 E0.0304 G1 X149.340 Y134.489 E0.0354 G1 X149.221 Y134.513 E0.0369 G1 X149.307 Y134.599 E0.0384 G1 X149.240 Y134.604 E0.0393 G1 X149.093 Y134.613 F620 G1 X148.812 Y134.669 F620 G1 X148.749 Y134.607 F620 G1 X148.692 Y134.618 F620 G1 X148.321 Y134.744 F620 G1 X148.340 Y134.763 F620 G1 X145.730 Y136.113 F4800 G92 E0 G1 X145.967 Y136.350 E0.0042 F620 G1 X145.665 Y136.614 E0.0092 G1 X145.518 Y136.467 E0.0118 G1 X145.495 Y136.444 F620 G1 X145.276 Y136.773 F620 G1 X145.270 Y136.785 F620 G1 X145.365 Y136.880 F620 G1 X145.101 Y137.181 F620 G1 X145.083 Y137.164 F620 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X148.603 Y153.285 F4800 G1 E0.0000 F1500 G92 E0 G1 X149.295 Y153.147 E0.0089 F582 G1 X150.000 Y153.101 E0.0177 G1 X150.705 Y153.147 E0.0266 G1 X151.397 Y153.285 E0.0354 G1 X152.066 Y153.512 E0.0443 G1 X152.699 Y153.825 E0.0531 G1 X153.287 Y154.217 E0.0620 G1 X153.817 Y154.683 E0.0708 G1 X153.965 Y154.850 E0.0736 G1 X153.756 Y155.088 E0.0776 G1 X153.301 Y154.783 E0.0845 G1 X152.526 Y154.401 E0.0953 G1 X151.709 Y154.124 E0.1061 G1 X150.862 Y153.955 E0.1170 G1 X150.000 Y153.899 E0.1278 G1 X149.138 Y153.955 E0.1386 G1 X148.291 Y154.124 E0.1495 G1 X147.474 Y154.401 E0.1603 G1 X146.699 Y154.783 E0.1711 G1 X146.244 Y155.088 E0.1780 G1 X146.035 Y154.850 E0.1819 G1 X146.183 Y154.683 E0.1847 G1 X146.714 Y154.217 E0.1936 G1 X147.301 Y153.825 E0.2025 G1 X147.670 Y153.642 E0.2076 G1 X147.934 Y153.512 F582 G1 X148.603 Y153.285 F582 ; outer perimeter G1 X148.499 Y152.898 F4800 G92 E0 G1 X149.243 Y152.750 E0.0095 F388 G1 X150.000 Y152.700 E0.0190 G1 X150.757 Y152.750 E0.0285 G1 X151.501 Y152.898 E0.0381 G1 X152.219 Y153.142 E0.0476 G1 X152.900 Y153.477 E0.0571 G1 X153.531 Y153.899 E0.0666 G1 X154.101 Y154.399 E0.0761 G1 X154.601 Y154.969 E0.0856 G1 X155.023 Y155.600 E0.0951 G1 X155.358 Y156.281 E0.1046 G1 X155.602 Y156.999 E0.1142 G1 X155.750 Y157.743 E0.1237 G1 X155.786 Y158.298 E0.1306 G1 X155.728 Y158.127 E0.1329 G1 X155.370 Y157.400 E0.1431 G1 X154.919 Y156.725 E0.1532 G1 X154.384 Y156.116 E0.1634 G1 X153.775 Y155.581 E0.1736 G1 X153.100 Y155.130 E0.1838 G1 X152.373 Y154.772 E0.1939 G1 X151.605 Y154.511 E0.2041 G1 X150.809 Y154.353 E0.2143 G1 X150.000 Y154.300 E0.2244 G1 X149.191 Y154.353 E0.2346 G1 X148.395 Y154.511 E0.2448 G1 X147.627 Y154.772 E0.2550 G1 X146.900 Y155.130 E0.2651 G1 X146.225 Y155.581 E0.2753 G1 X145.616 Y156.116 E0.2855 G1 X145.081 Y156.725 E0.2956 G1 X144.630 Y157.400 E0.3058 G1 X144.272 Y158.127 E0.3160 G1 X144.214 Y158.298 E0.3182 G1 X144.250 Y157.743 E0.3252 G1 X144.398 Y156.999 E0.3347 G1 X144.642 Y156.281 E0.3442 G1 X144.977 Y155.600 E0.3537 G1 X145.399 Y154.969 E0.3633 G1 X145.899 Y154.399 E0.3728 G1 X146.469 Y153.899 E0.3823 G1 X147.100 Y153.477 E0.3918 G1 X147.564 Y153.249 E0.3983 G1 X147.781 Y153.142 F388 G1 X148.499 Y152.898 F388 ; gap fill G1 X148.151 Y153.808 F4800 G92 E0 G1 X148.147 Y153.803 E0.0001 F620 G1 X148.569 Y153.660 E0.0057 G1 X148.617 Y153.708 E0.0065 G1 X149.089 Y153.614 E0.0126 G1 X149.026 Y153.552 E0.0137 G1 X149.340 Y153.489 E0.0177 G1 X149.518 Y153.478 E0.0199 G1 X149.619 Y153.579 E0.0217 G1 X150.000 Y153.554 E0.0265 G1 X150.171 Y153.565 E0.0287 G1 X150.056 Y153.450 E0.0307 G1 X150.635 Y153.488 E0.0380 G1 X150.660 Y153.489 F620 G1 X150.776 Y153.605 F620 G1 X150.907 Y153.613 F620 G1 X151.461 Y153.724 F620 G1 X151.380 Y153.643 F620 G1 X154.094 Y155.225 F4800 G92 E0 G1 X154.097 Y155.229 E0.0001 F620 G1 X154.805 Y155.936 F620 G92 E0 G1 E-6.5000 F1500 G1 X145.628 Y155.245 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.843 Y155.459 E0.0038 F620 G1 X145.766 Y155.526 E0.0051 G1 X145.541 Y155.723 F620 G1 X145.402 Y155.584 F620 G1 X145.276 Y155.773 F620 G1 X145.193 Y155.941 F620 G1 X145.256 Y156.004 F620 G92 E0 G1 E-6.5000 F1500 ; layer 10, Z = 2.100 ; inner perimeter G1 X146.244 Y155.088 F4800 G1 Z2.100 F300 G1 E0.0000 F1500 G92 E0 G1 X146.035 Y154.850 E0.0040 F582 G1 X146.183 Y154.683 E0.0068 G1 X146.714 Y154.217 E0.0156 G1 X147.301 Y153.825 E0.0245 G1 X147.934 Y153.512 E0.0333 G1 X148.603 Y153.285 E0.0422 G1 X149.295 Y153.147 E0.0510 G1 X150.000 Y153.101 E0.0599 G1 X150.705 Y153.147 E0.0687 G1 X151.397 Y153.285 E0.0776 G1 X152.066 Y153.512 E0.0865 G1 X152.699 Y153.825 E0.0953 G1 X153.287 Y154.217 E0.1042 G1 X153.817 Y154.683 E0.1130 G1 X153.965 Y154.850 E0.1158 G1 X153.756 Y155.088 E0.1198 G1 X153.301 Y154.783 E0.1267 G1 X152.526 Y154.401 E0.1375 G1 X151.709 Y154.124 E0.1483 G1 X150.862 Y153.955 E0.1591 G1 X150.000 Y153.899 E0.1700 G1 X149.138 Y153.955 E0.1808 G1 X148.291 Y154.124 E0.1916 G1 X147.474 Y154.401 E0.2025 G1 X147.105 Y154.583 E0.2076 G1 X146.699 Y154.783 F582 G1 X146.244 Y155.088 F582 ; outer perimeter G1 X146.225 Y155.581 F4800 G92 E0 G1 X145.616 Y156.116 E0.0102 F388 G1 X145.081 Y156.725 E0.0203 G1 X144.630 Y157.400 E0.0305 G1 X144.272 Y158.127 E0.0407 G1 X144.214 Y158.298 E0.0429 G1 X144.250 Y157.743 E0.0499 G1 X144.398 Y156.999 E0.0594 G1 X144.642 Y156.281 E0.0689 G1 X144.977 Y155.600 E0.0785 G1 X145.399 Y154.969 E0.0880 G1 X145.899 Y154.399 E0.0975 G1 X146.469 Y153.899 E0.1070 G1 X147.100 Y153.477 E0.1165 G1 X147.781 Y153.142 E0.1260 G1 X148.499 Y152.898 E0.1355 G1 X149.243 Y152.750 E0.1450 G1 X150.000 Y152.700 E0.1546 G1 X150.757 Y152.750 E0.1641 G1 X151.501 Y152.898 E0.1736 G1 X152.219 Y153.142 E0.1831 G1 X152.900 Y153.477 E0.1926 G1 X153.531 Y153.899 E0.2021 G1 X154.101 Y154.399 E0.2116 G1 X154.601 Y154.969 E0.2212 G1 X155.023 Y155.600 E0.2307 G1 X155.358 Y156.281 E0.2402 G1 X155.602 Y156.999 E0.2497 G1 X155.750 Y157.743 E0.2592 G1 X155.786 Y158.298 E0.2662 G1 X155.728 Y158.127 E0.2684 G1 X155.370 Y157.400 E0.2786 G1 X154.919 Y156.725 E0.2888 G1 X154.384 Y156.116 E0.2989 G1 X153.775 Y155.581 E0.3091 G1 X153.100 Y155.130 E0.3193 G1 X152.373 Y154.772 E0.3295 G1 X151.605 Y154.511 E0.3396 G1 X150.809 Y154.353 E0.3498 G1 X150.000 Y154.300 E0.3600 G1 X149.191 Y154.353 E0.3701 G1 X148.395 Y154.511 E0.3803 G1 X147.627 Y154.772 E0.3905 G1 X147.069 Y155.047 E0.3983 G1 X146.900 Y155.130 F388 G1 X146.225 Y155.581 F388 ; gap fill G1 X145.906 Y155.225 F4800 G92 E0 G1 X145.903 Y155.229 E0.0001 F621 G1 X145.195 Y155.936 F621 G1 X148.539 Y153.724 F4800 G92 E0 G1 X148.620 Y153.643 E0.0014 F621 G1 X148.692 Y153.618 E0.0024 G1 X149.339 Y153.490 E0.0107 G1 X149.224 Y153.605 E0.0127 G1 X149.829 Y153.565 E0.0203 G1 X149.944 Y153.450 E0.0224 G1 X150.000 Y153.446 E0.0231 G1 X150.482 Y153.478 E0.0291 G1 X150.381 Y153.579 E0.0309 G1 X150.907 Y153.613 E0.0375 G1 X150.911 Y153.614 E0.0376 G1 X150.974 Y153.552 E0.0387 G1 X150.996 Y153.556 E0.0390 G1 X151.308 Y153.618 F621 G1 X151.431 Y153.660 F621 G1 X151.383 Y153.708 F621 G1 X151.798 Y153.791 F621 G1 X151.849 Y153.808 F621 G1 X151.854 Y153.803 F621 G1 X154.158 Y155.459 F4800 G92 E0 G1 X154.372 Y155.245 E0.0038 F621 G1 X154.424 Y155.324 E0.0050 G1 X154.598 Y155.584 F621 G1 X154.459 Y155.723 F621 G1 X154.628 Y155.872 F621 G1 X154.744 Y156.004 F621 G1 X154.807 Y155.941 F621 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X153.757 Y136.088 F4800 G1 E0.0000 F1500 G92 E0 G1 X153.301 Y135.783 E0.0069 F582 G1 X152.526 Y135.401 E0.0177 G1 X151.709 Y135.124 E0.0285 G1 X150.862 Y134.955 E0.0394 G1 X150.000 Y134.899 E0.0502 G1 X149.138 Y134.955 E0.0610 G1 X148.291 Y135.124 E0.0718 G1 X147.474 Y135.401 E0.0827 G1 X146.699 Y135.783 E0.0935 G1 X146.244 Y136.088 E0.1004 G1 X146.035 Y135.850 E0.1043 G1 X146.183 Y135.683 E0.1071 G1 X146.714 Y135.217 E0.1160 G1 X147.301 Y134.825 E0.1248 G1 X147.934 Y134.512 E0.1337 G1 X148.603 Y134.285 E0.1426 G1 X149.295 Y134.147 E0.1514 G1 X150.000 Y134.101 E0.1603 G1 X150.705 Y134.147 E0.1691 G1 X151.397 Y134.285 E0.1780 G1 X152.066 Y134.512 E0.1868 G1 X152.699 Y134.825 E0.1957 G1 X153.287 Y135.217 E0.2045 G1 X153.471 Y135.379 E0.2076 G1 X153.817 Y135.683 F582 G1 X153.965 Y135.850 F582 G1 X153.756 Y136.088 F582 ; outer perimeter G1 X153.775 Y136.581 F4800 G92 E0 G1 X153.100 Y136.130 E0.0102 F388 G1 X152.373 Y135.772 E0.0203 G1 X151.605 Y135.511 E0.0305 G1 X150.809 Y135.353 E0.0407 G1 X150.000 Y135.300 E0.0509 G1 X149.191 Y135.353 E0.0610 G1 X148.395 Y135.511 E0.0712 G1 X147.627 Y135.772 E0.0814 G1 X146.900 Y136.130 E0.0915 G1 X146.225 Y136.581 E0.1017 G1 X145.616 Y137.116 E0.1119 G1 X145.081 Y137.725 E0.1221 G1 X144.630 Y138.400 E0.1322 G1 X144.272 Y139.127 E0.1424 G1 X144.214 Y139.298 E0.1447 G1 X144.250 Y138.743 E0.1516 G1 X144.398 Y137.999 E0.1611 G1 X144.642 Y137.281 E0.1706 G1 X144.977 Y136.600 E0.1802 G1 X145.399 Y135.969 E0.1897 G1 X145.899 Y135.399 E0.1992 G1 X146.469 Y134.899 E0.2087 G1 X147.100 Y134.477 E0.2182 G1 X147.781 Y134.142 E0.2277 G1 X148.499 Y133.898 E0.2372 G1 X149.243 Y133.750 E0.2468 G1 X150.000 Y133.700 E0.2563 G1 X150.757 Y133.750 E0.2658 G1 X151.501 Y133.898 E0.2753 G1 X152.219 Y134.142 E0.2848 G1 X152.900 Y134.477 E0.2943 G1 X153.531 Y134.899 E0.3038 G1 X154.101 Y135.399 E0.3134 G1 X154.601 Y135.969 E0.3229 G1 X155.023 Y136.600 E0.3324 G1 X155.358 Y137.281 E0.3419 G1 X155.602 Y137.999 E0.3514 G1 X155.750 Y138.743 E0.3609 G1 X155.786 Y139.298 E0.3679 G1 X155.728 Y139.127 E0.3701 G1 X155.370 Y138.400 E0.3803 G1 X154.919 Y137.725 E0.3905 G1 X154.509 Y137.258 E0.3983 G1 X154.384 Y137.116 F388 G1 X153.775 Y136.581 F388 ; gap fill G1 X154.033 Y136.350 F4800 G92 E0 G1 X154.270 Y136.113 E0.0042 F621 G1 X154.328 Y136.179 E0.0053 G1 X154.505 Y136.444 E0.0093 G1 X154.347 Y136.602 E0.0121 G1 X154.335 Y136.614 F621 G1 X154.628 Y136.872 F621 G1 X154.635 Y136.880 F621 G1 X154.730 Y136.785 F621 G1 X154.917 Y137.164 F621 G1 X154.899 Y137.181 F621 G1 X151.679 Y134.744 F4800 G92 E0 G1 X151.660 Y134.763 E0.0003 F621 G1 X151.188 Y134.669 E0.0064 G1 X151.251 Y134.607 E0.0075 G1 X150.779 Y134.513 E0.0135 G1 X150.693 Y134.599 E0.0150 G1 X150.162 Y134.565 E0.0217 G1 X150.263 Y134.463 E0.0235 G1 X150.000 Y134.446 E0.0268 G1 X149.695 Y134.466 E0.0307 G1 X149.579 Y134.582 E0.0327 G1 X149.093 Y134.613 E0.0388 G1 X148.983 Y134.635 E0.0402 G1 X148.954 Y134.641 F621 G1 X149.048 Y134.547 F621 G1 X148.692 Y134.618 F621 G1 X148.267 Y134.762 F621 G1 X148.248 Y134.782 F621 G92 E0 G1 E-6.5000 F1500 ; layer 11, Z = 2.300 ; inner perimeter G1 X148.291 Y135.124 F4800 G1 Z2.300 F300 G1 E0.0000 F1500 G92 E0 G1 X147.474 Y135.401 E0.0108 F582 G1 X146.699 Y135.783 E0.0217 G1 X146.244 Y136.088 E0.0285 G1 X146.035 Y135.850 E0.0325 G1 X146.183 Y135.683 E0.0353 G1 X146.714 Y135.217 E0.0441 G1 X147.301 Y134.825 E0.0530 G1 X147.934 Y134.512 E0.0619 G1 X148.603 Y134.285 E0.0707 G1 X149.295 Y134.147 E0.0796 G1 X150.000 Y134.101 E0.0884 G1 X150.705 Y134.147 E0.0973 G1 X151.397 Y134.285 E0.1061 G1 X152.066 Y134.512 E0.1150 G1 X152.699 Y134.825 E0.1238 G1 X153.287 Y135.217 E0.1327 G1 X153.817 Y135.683 E0.1416 G1 X153.965 Y135.850 E0.1444 G1 X153.756 Y136.088 E0.1483 G1 X153.301 Y135.783 E0.1552 G1 X152.526 Y135.401 E0.1660 G1 X151.709 Y135.124 E0.1768 G1 X150.862 Y134.955 E0.1877 G1 X150.000 Y134.899 E0.1985 G1 X149.275 Y134.946 E0.2076 G1 X149.138 Y134.955 F582 G1 X148.291 Y135.124 F582 ; outer perimeter G1 X148.395 Y135.511 F4800 G92 E0 G1 X147.627 Y135.772 E0.0102 F388 G1 X146.900 Y136.130 E0.0203 G1 X146.225 Y136.581 E0.0305 G1 X145.616 Y137.116 E0.0407 G1 X145.081 Y137.725 E0.0509 G1 X144.630 Y138.400 E0.0610 G1 X144.272 Y139.127 E0.0712 G1 X144.214 Y139.298 E0.0735 G1 X144.250 Y138.743 E0.0804 G1 X144.398 Y137.999 E0.0899 G1 X144.642 Y137.281 E0.0995 G1 X144.977 Y136.600 E0.1090 G1 X145.399 Y135.969 E0.1185 G1 X145.899 Y135.399 E0.1280 G1 X146.469 Y134.899 E0.1375 G1 X147.100 Y134.477 E0.1470 G1 X147.781 Y134.142 E0.1565 G1 X148.499 Y133.898 E0.1660 G1 X149.243 Y133.750 E0.1756 G1 X150.000 Y133.700 E0.1851 G1 X150.757 Y133.750 E0.1946 G1 X151.501 Y133.898 E0.2041 G1 X152.219 Y134.142 E0.2136 G1 X152.900 Y134.477 E0.2231 G1 X153.531 Y134.899 E0.2326 G1 X154.101 Y135.399 E0.2422 G1 X154.601 Y135.969 E0.2517 G1 X155.023 Y136.600 E0.2612 G1 X155.358 Y137.281 E0.2707 G1 X155.602 Y137.999 E0.2802 G1 X155.750 Y138.743 E0.2897 G1 X155.786 Y139.298 E0.2967 G1 X155.728 Y139.127 E0.2989 G1 X155.370 Y138.400 E0.3091 G1 X154.919 Y137.725 E0.3193 G1 X154.384 Y137.116 E0.3295 G1 X153.775 Y136.581 E0.3396 G1 X153.100 Y136.130 E0.3498 G1 X152.373 Y135.772 E0.3600 G1 X151.605 Y135.511 E0.3701 G1 X150.809 Y135.353 E0.3803 G1 X150.000 Y135.300 E0.3905 G1 X149.379 Y135.340 E0.3983 G1 X149.191 Y135.353 F388 G1 X148.395 Y135.511 F388 ; gap fill G1 X148.340 Y134.763 F4800 G92 E0 G1 X148.321 Y134.744 E0.0003 F620 G1 X148.692 Y134.618 E0.0053 G1 X148.749 Y134.607 E0.0060 G1 X148.812 Y134.669 E0.0071 G1 X149.093 Y134.613 E0.0107 G1 X149.307 Y134.599 E0.0134 G1 X149.221 Y134.513 E0.0149 G1 X149.340 Y134.489 E0.0164 G1 X149.737 Y134.463 E0.0214 G1 X149.838 Y134.565 E0.0232 G1 X150.000 Y134.554 E0.0253 G1 X150.421 Y134.582 E0.0305 G1 X150.305 Y134.466 E0.0326 G1 X150.660 Y134.489 E0.0370 G1 X150.834 Y134.524 E0.0393 G1 X150.952 Y134.547 F620 G1 X151.046 Y134.641 F620 G1 X151.752 Y134.782 F620 G1 X151.733 Y134.762 F620 G1 X145.730 Y136.113 F4800 G92 E0 G1 X145.967 Y136.350 E0.0042 F620 G1 X145.665 Y136.614 E0.0092 G1 X145.518 Y136.467 E0.0118 G1 X145.495 Y136.444 F620 G1 X145.276 Y136.773 F620 G1 X145.270 Y136.785 F620 G1 X145.365 Y136.880 F620 G1 X145.101 Y137.181 F620 G1 X145.083 Y137.164 F620 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X148.603 Y153.285 F4800 G1 E0.0000 F1500 G92 E0 G1 X149.295 Y153.147 E0.0089 F582 G1 X150.000 Y153.101 E0.0177 G1 X150.705 Y153.147 E0.0266 G1 X151.397 Y153.285 E0.0354 G1 X152.066 Y153.512 E0.0443 G1 X152.699 Y153.825 E0.0531 G1 X153.287 Y154.217 E0.0620 G1 X153.817 Y154.683 E0.0708 G1 X153.965 Y154.850 E0.0736 G1 X153.756 Y155.088 E0.0776 G1 X153.301 Y154.783 E0.0845 G1 X152.526 Y154.401 E0.0953 G1 X151.709 Y154.124 E0.1061 G1 X150.862 Y153.955 E0.1170 G1 X150.000 Y153.899 E0.1278 G1 X149.138 Y153.955 E0.1386 G1 X148.291 Y154.124 E0.1495 G1 X147.474 Y154.401 E0.1603 G1 X146.699 Y154.783 E0.1711 G1 X146.244 Y155.088 E0.1780 G1 X146.035 Y154.850 E0.1819 G1 X146.183 Y154.683 E0.1847 G1 X146.714 Y154.217 E0.1936 G1 X147.301 Y153.825 E0.2025 G1 X147.670 Y153.642 E0.2076 G1 X147.934 Y153.512 F582 G1 X148.603 Y153.285 F582 ; outer perimeter G1 X148.499 Y152.898 F4800 G92 E0 G1 X149.243 Y152.750 E0.0095 F388 G1 X150.000 Y152.700 E0.0190 G1 X150.757 Y152.750 E0.0285 G1 X151.501 Y152.898 E0.0381 G1 X152.219 Y153.142 E0.0476 G1 X152.900 Y153.477 E0.0571 G1 X153.531 Y153.899 E0.0666 G1 X154.101 Y154.399 E0.0761 G1 X154.601 Y154.969 E0.0856 G1 X155.023 Y155.600 E0.0951 G1 X155.358 Y156.281 E0.1046 G1 X155.602 Y156.999 E0.1142 G1 X155.750 Y157.743 E0.1237 G1 X155.786 Y158.298 E0.1306 G1 X155.728 Y158.127 E0.1329 G1 X155.370 Y157.400 E0.1431 G1 X154.919 Y156.725 E0.1532 G1 X154.384 Y156.116 E0.1634 G1 X153.775 Y155.581 E0.1736 G1 X153.100 Y155.130 E0.1838 G1 X152.373 Y154.772 E0.1939 G1 X151.605 Y154.511 E0.2041 G1 X150.809 Y154.353 E0.2143 G1 X150.000 Y154.300 E0.2244 G1 X149.191 Y154.353 E0.2346 G1 X148.395 Y154.511 E0.2448 G1 X147.627 Y154.772 E0.2550 G1 X146.900 Y155.130 E0.2651 G1 X146.225 Y155.581 E0.2753 G1 X145.616 Y156.116 E0.2855 G1 X145.081 Y156.725 E0.2956 G1 X144.630 Y157.400 E0.3058 G1 X144.272 Y158.127 E0.3160 G1 X144.214 Y158.298 E0.3182 G1 X144.250 Y157.743 E0.3252 G1 X144.398 Y156.999 E0.3347 G1 X144.642 Y156.281 E0.3442 G1 X144.977 Y155.600 E0.3537 G1 X145.399 Y154.969 E0.3633 G1 X145.899 Y154.399 E0.3728 G1 X146.469 Y153.899 E0.3823 G1 X147.100 Y153.477 E0.3918 G1 X147.564 Y153.249 E0.3983 G1 X147.781 Y153.142 F388 G1 X148.499 Y152.898 F388 ; gap fill G1 X148.151 Y153.808 F4800 G92 E0 G1 X148.147 Y153.803 E0.0001 F620 G1 X148.569 Y153.660 E0.0057 G1 X148.617 Y153.708 E0.0065 G1 X149.089 Y153.614 E0.0126 G1 X149.026 Y153.552 E0.0137 G1 X149.340 Y153.489 E0.0177 G1 X149.518 Y153.478 E0.0199 G1 X149.619 Y153.579 E0.0217 G1 X150.000 Y153.554 E0.0265 G1 X150.171 Y153.565 E0.0287 G1 X150.056 Y153.450 E0.0307 G1 X150.635 Y153.488 E0.0380 G1 X150.660 Y153.489 F620 G1 X150.776 Y153.605 F620 G1 X150.907 Y153.613 F620 G1 X151.461 Y153.724 F620 G1 X151.380 Y153.643 F620 G1 X154.094 Y155.225 F4800 G92 E0 G1 X154.097 Y155.229 E0.0001 F620 G1 X154.805 Y155.936 F620 G92 E0 G1 E-6.5000 F1500 G1 X145.628 Y155.245 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.843 Y155.459 E0.0038 F620 G1 X145.766 Y155.526 E0.0051 G1 X145.541 Y155.723 F620 G1 X145.402 Y155.584 F620 G1 X145.276 Y155.773 F620 G1 X145.193 Y155.941 F620 G1 X145.256 Y156.004 F620 G92 E0 G1 E-6.5000 F1500 ; layer 12, Z = 2.500 ; inner perimeter G1 X146.244 Y155.088 F4800 G1 Z2.500 F300 G1 E0.0000 F1500 G92 E0 G1 X146.035 Y154.850 E0.0040 F582 G1 X146.183 Y154.683 E0.0068 G1 X146.714 Y154.217 E0.0156 G1 X147.301 Y153.825 E0.0245 G1 X147.934 Y153.512 E0.0333 G1 X148.603 Y153.285 E0.0422 G1 X149.295 Y153.147 E0.0510 G1 X150.000 Y153.101 E0.0599 G1 X150.705 Y153.147 E0.0687 G1 X151.397 Y153.285 E0.0776 G1 X152.066 Y153.512 E0.0865 G1 X152.699 Y153.825 E0.0953 G1 X153.287 Y154.217 E0.1042 G1 X153.817 Y154.683 E0.1130 G1 X153.965 Y154.850 E0.1158 G1 X153.756 Y155.088 E0.1198 G1 X153.301 Y154.783 E0.1267 G1 X152.526 Y154.401 E0.1375 G1 X151.709 Y154.124 E0.1483 G1 X150.862 Y153.955 E0.1591 G1 X150.000 Y153.899 E0.1700 G1 X149.138 Y153.955 E0.1808 G1 X148.291 Y154.124 E0.1916 G1 X147.474 Y154.401 E0.2025 G1 X147.105 Y154.583 E0.2076 G1 X146.699 Y154.783 F582 G1 X146.244 Y155.088 F582 ; outer perimeter G1 X146.225 Y155.581 F4800 G92 E0 G1 X145.616 Y156.116 E0.0102 F388 G1 X145.081 Y156.725 E0.0203 G1 X144.630 Y157.400 E0.0305 G1 X144.272 Y158.127 E0.0407 G1 X144.214 Y158.298 E0.0429 G1 X144.250 Y157.743 E0.0499 G1 X144.398 Y156.999 E0.0594 G1 X144.642 Y156.281 E0.0689 G1 X144.977 Y155.600 E0.0785 G1 X145.399 Y154.969 E0.0880 G1 X145.899 Y154.399 E0.0975 G1 X146.469 Y153.899 E0.1070 G1 X147.100 Y153.477 E0.1165 G1 X147.781 Y153.142 E0.1260 G1 X148.499 Y152.898 E0.1355 G1 X149.243 Y152.750 E0.1450 G1 X150.000 Y152.700 E0.1546 G1 X150.757 Y152.750 E0.1641 G1 X151.501 Y152.898 E0.1736 G1 X152.219 Y153.142 E0.1831 G1 X152.900 Y153.477 E0.1926 G1 X153.531 Y153.899 E0.2021 G1 X154.101 Y154.399 E0.2116 G1 X154.601 Y154.969 E0.2212 G1 X155.023 Y155.600 E0.2307 G1 X155.358 Y156.281 E0.2402 G1 X155.602 Y156.999 E0.2497 G1 X155.750 Y157.743 E0.2592 G1 X155.786 Y158.298 E0.2662 G1 X155.728 Y158.127 E0.2684 G1 X155.370 Y157.400 E0.2786 G1 X154.919 Y156.725 E0.2888 G1 X154.384 Y156.116 E0.2989 G1 X153.775 Y155.581 E0.3091 G1 X153.100 Y155.130 E0.3193 G1 X152.373 Y154.772 E0.3295 G1 X151.605 Y154.511 E0.3396 G1 X150.809 Y154.353 E0.3498 G1 X150.000 Y154.300 E0.3600 G1 X149.191 Y154.353 E0.3701 G1 X148.395 Y154.511 E0.3803 G1 X147.627 Y154.772 E0.3905 G1 X147.069 Y155.047 E0.3983 G1 X146.900 Y155.130 F388 G1 X146.225 Y155.581 F388 ; gap fill G1 X145.906 Y155.225 F4800 G92 E0 G1 X145.903 Y155.229 E0.0001 F621 G1 X145.195 Y155.936 F621 G1 X148.539 Y153.724 F4800 G92 E0 G1 X148.620 Y153.643 E0.0014 F621 G1 X148.692 Y153.618 E0.0024 G1 X149.339 Y153.490 E0.0107 G1 X149.224 Y153.605 E0.0127 G1 X149.829 Y153.565 E0.0203 G1 X149.944 Y153.450 E0.0224 G1 X150.000 Y153.446 E0.0231 G1 X150.482 Y153.478 E0.0291 G1 X150.381 Y153.579 E0.0309 G1 X150.907 Y153.613 E0.0375 G1 X150.911 Y153.614 E0.0376 G1 X150.974 Y153.552 E0.0387 G1 X150.996 Y153.556 E0.0390 G1 X151.308 Y153.618 F621 G1 X151.431 Y153.660 F621 G1 X151.383 Y153.708 F621 G1 X151.798 Y153.791 F621 G1 X151.849 Y153.808 F621 G1 X151.854 Y153.803 F621 G1 X154.158 Y155.459 F4800 G92 E0 G1 X154.372 Y155.245 E0.0038 F621 G1 X154.424 Y155.324 E0.0050 G1 X154.598 Y155.584 F621 G1 X154.459 Y155.723 F621 G1 X154.628 Y155.872 F621 G1 X154.744 Y156.004 F621 G1 X154.807 Y155.941 F621 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X153.757 Y136.088 F4800 G1 E0.0000 F1500 G92 E0 G1 X153.301 Y135.783 E0.0069 F582 G1 X152.526 Y135.401 E0.0177 G1 X151.709 Y135.124 E0.0285 G1 X150.862 Y134.955 E0.0394 G1 X150.000 Y134.899 E0.0502 G1 X149.138 Y134.955 E0.0610 G1 X148.291 Y135.124 E0.0718 G1 X147.474 Y135.401 E0.0827 G1 X146.699 Y135.783 E0.0935 G1 X146.244 Y136.088 E0.1004 G1 X146.035 Y135.850 E0.1043 G1 X146.183 Y135.683 E0.1071 G1 X146.714 Y135.217 E0.1160 G1 X147.301 Y134.825 E0.1248 G1 X147.934 Y134.512 E0.1337 G1 X148.603 Y134.285 E0.1426 G1 X149.295 Y134.147 E0.1514 G1 X150.000 Y134.101 E0.1603 G1 X150.705 Y134.147 E0.1691 G1 X151.397 Y134.285 E0.1780 G1 X152.066 Y134.512 E0.1868 G1 X152.699 Y134.825 E0.1957 G1 X153.287 Y135.217 E0.2045 G1 X153.471 Y135.379 E0.2076 G1 X153.817 Y135.683 F582 G1 X153.965 Y135.850 F582 G1 X153.756 Y136.088 F582 ; outer perimeter G1 X153.775 Y136.581 F4800 G92 E0 G1 X153.100 Y136.130 E0.0102 F388 G1 X152.373 Y135.772 E0.0203 G1 X151.605 Y135.511 E0.0305 G1 X150.809 Y135.353 E0.0407 G1 X150.000 Y135.300 E0.0509 G1 X149.191 Y135.353 E0.0610 G1 X148.395 Y135.511 E0.0712 G1 X147.627 Y135.772 E0.0814 G1 X146.900 Y136.130 E0.0915 G1 X146.225 Y136.581 E0.1017 G1 X145.616 Y137.116 E0.1119 G1 X145.081 Y137.725 E0.1221 G1 X144.630 Y138.400 E0.1322 G1 X144.272 Y139.127 E0.1424 G1 X144.214 Y139.298 E0.1447 G1 X144.250 Y138.743 E0.1516 G1 X144.398 Y137.999 E0.1611 G1 X144.642 Y137.281 E0.1706 G1 X144.977 Y136.600 E0.1802 G1 X145.399 Y135.969 E0.1897 G1 X145.899 Y135.399 E0.1992 G1 X146.469 Y134.899 E0.2087 G1 X147.100 Y134.477 E0.2182 G1 X147.781 Y134.142 E0.2277 G1 X148.499 Y133.898 E0.2372 G1 X149.243 Y133.750 E0.2468 G1 X150.000 Y133.700 E0.2563 G1 X150.757 Y133.750 E0.2658 G1 X151.501 Y133.898 E0.2753 G1 X152.219 Y134.142 E0.2848 G1 X152.900 Y134.477 E0.2943 G1 X153.531 Y134.899 E0.3038 G1 X154.101 Y135.399 E0.3134 G1 X154.601 Y135.969 E0.3229 G1 X155.023 Y136.600 E0.3324 G1 X155.358 Y137.281 E0.3419 G1 X155.602 Y137.999 E0.3514 G1 X155.750 Y138.743 E0.3609 G1 X155.786 Y139.298 E0.3679 G1 X155.728 Y139.127 E0.3701 G1 X155.370 Y138.400 E0.3803 G1 X154.919 Y137.725 E0.3905 G1 X154.509 Y137.258 E0.3983 G1 X154.384 Y137.116 F388 G1 X153.775 Y136.581 F388 ; gap fill G1 X154.033 Y136.350 F4800 G92 E0 G1 X154.270 Y136.113 E0.0042 F621 G1 X154.328 Y136.179 E0.0053 G1 X154.505 Y136.444 E0.0093 G1 X154.347 Y136.602 E0.0121 G1 X154.335 Y136.614 F621 G1 X154.628 Y136.872 F621 G1 X154.635 Y136.880 F621 G1 X154.730 Y136.785 F621 G1 X154.917 Y137.164 F621 G1 X154.899 Y137.181 F621 G1 X151.679 Y134.744 F4800 G92 E0 G1 X151.660 Y134.763 E0.0003 F621 G1 X151.188 Y134.669 E0.0064 G1 X151.251 Y134.607 E0.0075 G1 X150.779 Y134.513 E0.0135 G1 X150.693 Y134.599 E0.0150 G1 X150.162 Y134.565 E0.0217 G1 X150.263 Y134.463 E0.0235 G1 X150.000 Y134.446 E0.0268 G1 X149.695 Y134.466 E0.0307 G1 X149.579 Y134.582 E0.0327 G1 X149.093 Y134.613 E0.0388 G1 X148.983 Y134.635 E0.0402 G1 X148.954 Y134.641 F621 G1 X149.048 Y134.547 F621 G1 X148.692 Y134.618 F621 G1 X148.267 Y134.762 F621 G1 X148.248 Y134.782 F621 G92 E0 G1 E-6.5000 F1500 ; layer 13, Z = 2.700 ; inner perimeter G1 X148.291 Y135.124 F4800 G1 Z2.700 F300 G1 E0.0000 F1500 G92 E0 G1 X147.474 Y135.401 E0.0108 F582 G1 X146.699 Y135.783 E0.0217 G1 X146.244 Y136.088 E0.0285 G1 X146.035 Y135.850 E0.0325 G1 X146.183 Y135.683 E0.0353 G1 X146.714 Y135.217 E0.0441 G1 X147.301 Y134.825 E0.0530 G1 X147.934 Y134.512 E0.0619 G1 X148.603 Y134.285 E0.0707 G1 X149.295 Y134.147 E0.0796 G1 X150.000 Y134.101 E0.0884 G1 X150.705 Y134.147 E0.0973 G1 X151.397 Y134.285 E0.1061 G1 X152.066 Y134.512 E0.1150 G1 X152.699 Y134.825 E0.1238 G1 X153.287 Y135.217 E0.1327 G1 X153.817 Y135.683 E0.1416 G1 X153.965 Y135.850 E0.1444 G1 X153.756 Y136.088 E0.1483 G1 X153.301 Y135.783 E0.1552 G1 X152.526 Y135.401 E0.1660 G1 X151.709 Y135.124 E0.1768 G1 X150.862 Y134.955 E0.1877 G1 X150.000 Y134.899 E0.1985 G1 X149.275 Y134.946 E0.2076 G1 X149.138 Y134.955 F582 G1 X148.291 Y135.124 F582 ; outer perimeter G1 X148.395 Y135.511 F4800 G92 E0 G1 X147.627 Y135.772 E0.0102 F388 G1 X146.900 Y136.130 E0.0203 G1 X146.225 Y136.581 E0.0305 G1 X145.616 Y137.116 E0.0407 G1 X145.081 Y137.725 E0.0509 G1 X144.630 Y138.400 E0.0610 G1 X144.272 Y139.127 E0.0712 G1 X144.214 Y139.298 E0.0735 G1 X144.250 Y138.743 E0.0804 G1 X144.398 Y137.999 E0.0899 G1 X144.642 Y137.281 E0.0995 G1 X144.977 Y136.600 E0.1090 G1 X145.399 Y135.969 E0.1185 G1 X145.899 Y135.399 E0.1280 G1 X146.469 Y134.899 E0.1375 G1 X147.100 Y134.477 E0.1470 G1 X147.781 Y134.142 E0.1565 G1 X148.499 Y133.898 E0.1660 G1 X149.243 Y133.750 E0.1756 G1 X150.000 Y133.700 E0.1851 G1 X150.757 Y133.750 E0.1946 G1 X151.501 Y133.898 E0.2041 G1 X152.219 Y134.142 E0.2136 G1 X152.900 Y134.477 E0.2231 G1 X153.531 Y134.899 E0.2326 G1 X154.101 Y135.399 E0.2422 G1 X154.601 Y135.969 E0.2517 G1 X155.023 Y136.600 E0.2612 G1 X155.358 Y137.281 E0.2707 G1 X155.602 Y137.999 E0.2802 G1 X155.750 Y138.743 E0.2897 G1 X155.786 Y139.298 E0.2967 G1 X155.728 Y139.127 E0.2989 G1 X155.370 Y138.400 E0.3091 G1 X154.919 Y137.725 E0.3193 G1 X154.384 Y137.116 E0.3295 G1 X153.775 Y136.581 E0.3396 G1 X153.100 Y136.130 E0.3498 G1 X152.373 Y135.772 E0.3600 G1 X151.605 Y135.511 E0.3701 G1 X150.809 Y135.353 E0.3803 G1 X150.000 Y135.300 E0.3905 G1 X149.379 Y135.340 E0.3983 G1 X149.191 Y135.353 F388 G1 X148.395 Y135.511 F388 ; gap fill G1 X148.340 Y134.763 F4800 G92 E0 G1 X148.321 Y134.744 E0.0003 F620 G1 X148.692 Y134.618 E0.0053 G1 X148.749 Y134.607 E0.0060 G1 X148.812 Y134.669 E0.0071 G1 X149.093 Y134.613 E0.0107 G1 X149.307 Y134.599 E0.0134 G1 X149.221 Y134.513 E0.0149 G1 X149.340 Y134.489 E0.0164 G1 X149.737 Y134.463 E0.0214 G1 X149.838 Y134.565 E0.0232 G1 X150.000 Y134.554 E0.0253 G1 X150.421 Y134.582 E0.0305 G1 X150.305 Y134.466 E0.0326 G1 X150.660 Y134.489 E0.0370 G1 X150.834 Y134.524 E0.0393 G1 X150.952 Y134.547 F620 G1 X151.046 Y134.641 F620 G1 X151.752 Y134.782 F620 G1 X151.733 Y134.762 F620 G1 X145.730 Y136.113 F4800 G92 E0 G1 X145.967 Y136.350 E0.0042 F620 G1 X145.665 Y136.614 E0.0092 G1 X145.518 Y136.467 E0.0118 G1 X145.495 Y136.444 F620 G1 X145.276 Y136.773 F620 G1 X145.270 Y136.785 F620 G1 X145.365 Y136.880 F620 G1 X145.101 Y137.181 F620 G1 X145.083 Y137.164 F620 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X148.603 Y153.285 F4800 G1 E0.0000 F1500 G92 E0 G1 X149.295 Y153.147 E0.0089 F582 G1 X150.000 Y153.101 E0.0177 G1 X150.705 Y153.147 E0.0266 G1 X151.397 Y153.285 E0.0354 G1 X152.066 Y153.512 E0.0443 G1 X152.699 Y153.825 E0.0531 G1 X153.287 Y154.217 E0.0620 G1 X153.817 Y154.683 E0.0708 G1 X153.965 Y154.850 E0.0736 G1 X153.756 Y155.088 E0.0776 G1 X153.301 Y154.783 E0.0845 G1 X152.526 Y154.401 E0.0953 G1 X151.709 Y154.124 E0.1061 G1 X150.862 Y153.955 E0.1170 G1 X150.000 Y153.899 E0.1278 G1 X149.138 Y153.955 E0.1386 G1 X148.291 Y154.124 E0.1495 G1 X147.474 Y154.401 E0.1603 G1 X146.699 Y154.783 E0.1711 G1 X146.244 Y155.088 E0.1780 G1 X146.035 Y154.850 E0.1819 G1 X146.183 Y154.683 E0.1847 G1 X146.714 Y154.217 E0.1936 G1 X147.301 Y153.825 E0.2025 G1 X147.670 Y153.642 E0.2076 G1 X147.934 Y153.512 F582 G1 X148.603 Y153.285 F582 ; outer perimeter G1 X148.499 Y152.898 F4800 G92 E0 G1 X149.243 Y152.750 E0.0095 F388 G1 X150.000 Y152.700 E0.0190 G1 X150.757 Y152.750 E0.0285 G1 X151.501 Y152.898 E0.0381 G1 X152.219 Y153.142 E0.0476 G1 X152.900 Y153.477 E0.0571 G1 X153.531 Y153.899 E0.0666 G1 X154.101 Y154.399 E0.0761 G1 X154.601 Y154.969 E0.0856 G1 X155.023 Y155.600 E0.0951 G1 X155.358 Y156.281 E0.1046 G1 X155.602 Y156.999 E0.1142 G1 X155.750 Y157.743 E0.1237 G1 X155.786 Y158.298 E0.1306 G1 X155.728 Y158.127 E0.1329 G1 X155.370 Y157.400 E0.1431 G1 X154.919 Y156.725 E0.1532 G1 X154.384 Y156.116 E0.1634 G1 X153.775 Y155.581 E0.1736 G1 X153.100 Y155.130 E0.1838 G1 X152.373 Y154.772 E0.1939 G1 X151.605 Y154.511 E0.2041 G1 X150.809 Y154.353 E0.2143 G1 X150.000 Y154.300 E0.2244 G1 X149.191 Y154.353 E0.2346 G1 X148.395 Y154.511 E0.2448 G1 X147.627 Y154.772 E0.2550 G1 X146.900 Y155.130 E0.2651 G1 X146.225 Y155.581 E0.2753 G1 X145.616 Y156.116 E0.2855 G1 X145.081 Y156.725 E0.2956 G1 X144.630 Y157.400 E0.3058 G1 X144.272 Y158.127 E0.3160 G1 X144.214 Y158.298 E0.3182 G1 X144.250 Y157.743 E0.3252 G1 X144.398 Y156.999 E0.3347 G1 X144.642 Y156.281 E0.3442 G1 X144.977 Y155.600 E0.3537 G1 X145.399 Y154.969 E0.3633 G1 X145.899 Y154.399 E0.3728 G1 X146.469 Y153.899 E0.3823 G1 X147.100 Y153.477 E0.3918 G1 X147.564 Y153.249 E0.3983 G1 X147.781 Y153.142 F388 G1 X148.499 Y152.898 F388 ; gap fill G1 X148.151 Y153.808 F4800 G92 E0 G1 X148.147 Y153.803 E0.0001 F620 G1 X148.569 Y153.660 E0.0057 G1 X148.617 Y153.708 E0.0065 G1 X149.089 Y153.614 E0.0126 G1 X149.026 Y153.552 E0.0137 G1 X149.340 Y153.489 E0.0177 G1 X149.518 Y153.478 E0.0199 G1 X149.619 Y153.579 E0.0217 G1 X150.000 Y153.554 E0.0265 G1 X150.171 Y153.565 E0.0287 G1 X150.056 Y153.450 E0.0307 G1 X150.635 Y153.488 E0.0380 G1 X150.660 Y153.489 F620 G1 X150.776 Y153.605 F620 G1 X150.907 Y153.613 F620 G1 X151.461 Y153.724 F620 G1 X151.380 Y153.643 F620 G1 X154.094 Y155.225 F4800 G92 E0 G1 X154.097 Y155.229 E0.0001 F620 G1 X154.805 Y155.936 F620 G92 E0 G1 E-6.5000 F1500 G1 X145.628 Y155.245 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.843 Y155.459 E0.0038 F620 G1 X145.766 Y155.526 E0.0051 G1 X145.541 Y155.723 F620 G1 X145.402 Y155.584 F620 G1 X145.276 Y155.773 F620 G1 X145.193 Y155.941 F620 G1 X145.256 Y156.004 F620 G92 E0 G1 E-6.5000 F1500 ; layer 14, Z = 2.900 ; inner perimeter G1 X146.244 Y155.088 F4800 G1 Z2.900 F300 G1 E0.0000 F1500 G92 E0 G1 X146.035 Y154.850 E0.0040 F582 G1 X146.183 Y154.683 E0.0068 G1 X146.714 Y154.217 E0.0156 G1 X147.301 Y153.825 E0.0245 G1 X147.934 Y153.512 E0.0333 G1 X148.603 Y153.285 E0.0422 G1 X149.295 Y153.147 E0.0510 G1 X150.000 Y153.101 E0.0599 G1 X150.705 Y153.147 E0.0687 G1 X151.397 Y153.285 E0.0776 G1 X152.066 Y153.512 E0.0865 G1 X152.699 Y153.825 E0.0953 G1 X153.287 Y154.217 E0.1042 G1 X153.817 Y154.683 E0.1130 G1 X153.965 Y154.850 E0.1158 G1 X153.756 Y155.088 E0.1198 G1 X153.301 Y154.783 E0.1267 G1 X152.526 Y154.401 E0.1375 G1 X151.709 Y154.124 E0.1483 G1 X150.862 Y153.955 E0.1591 G1 X150.000 Y153.899 E0.1700 G1 X149.138 Y153.955 E0.1808 G1 X148.291 Y154.124 E0.1916 G1 X147.474 Y154.401 E0.2025 G1 X147.105 Y154.583 E0.2076 G1 X146.699 Y154.783 F582 G1 X146.244 Y155.088 F582 ; outer perimeter G1 X146.225 Y155.581 F4800 G92 E0 G1 X145.616 Y156.116 E0.0102 F388 G1 X145.081 Y156.725 E0.0203 G1 X144.630 Y157.400 E0.0305 G1 X144.272 Y158.127 E0.0407 G1 X144.214 Y158.298 E0.0429 G1 X144.250 Y157.743 E0.0499 G1 X144.398 Y156.999 E0.0594 G1 X144.642 Y156.281 E0.0689 G1 X144.977 Y155.600 E0.0785 G1 X145.399 Y154.969 E0.0880 G1 X145.899 Y154.399 E0.0975 G1 X146.469 Y153.899 E0.1070 G1 X147.100 Y153.477 E0.1165 G1 X147.781 Y153.142 E0.1260 G1 X148.499 Y152.898 E0.1355 G1 X149.243 Y152.750 E0.1450 G1 X150.000 Y152.700 E0.1546 G1 X150.757 Y152.750 E0.1641 G1 X151.501 Y152.898 E0.1736 G1 X152.219 Y153.142 E0.1831 G1 X152.900 Y153.477 E0.1926 G1 X153.531 Y153.899 E0.2021 G1 X154.101 Y154.399 E0.2116 G1 X154.601 Y154.969 E0.2212 G1 X155.023 Y155.600 E0.2307 G1 X155.358 Y156.281 E0.2402 G1 X155.602 Y156.999 E0.2497 G1 X155.750 Y157.743 E0.2592 G1 X155.786 Y158.298 E0.2662 G1 X155.728 Y158.127 E0.2684 G1 X155.370 Y157.400 E0.2786 G1 X154.919 Y156.725 E0.2888 G1 X154.384 Y156.116 E0.2989 G1 X153.775 Y155.581 E0.3091 G1 X153.100 Y155.130 E0.3193 G1 X152.373 Y154.772 E0.3295 G1 X151.605 Y154.511 E0.3396 G1 X150.809 Y154.353 E0.3498 G1 X150.000 Y154.300 E0.3600 G1 X149.191 Y154.353 E0.3701 G1 X148.395 Y154.511 E0.3803 G1 X147.627 Y154.772 E0.3905 G1 X147.069 Y155.047 E0.3983 G1 X146.900 Y155.130 F388 G1 X146.225 Y155.581 F388 ; gap fill G1 X145.906 Y155.225 F4800 G92 E0 G1 X145.903 Y155.229 E0.0001 F621 G1 X145.195 Y155.936 F621 G1 X148.539 Y153.724 F4800 G92 E0 G1 X148.620 Y153.643 E0.0014 F621 G1 X148.692 Y153.618 E0.0024 G1 X149.339 Y153.490 E0.0107 G1 X149.224 Y153.605 E0.0127 G1 X149.829 Y153.565 E0.0203 G1 X149.944 Y153.450 E0.0224 G1 X150.000 Y153.446 E0.0231 G1 X150.482 Y153.478 E0.0291 G1 X150.381 Y153.579 E0.0309 G1 X150.907 Y153.613 E0.0375 G1 X150.911 Y153.614 E0.0376 G1 X150.974 Y153.552 E0.0387 G1 X150.996 Y153.556 E0.0390 G1 X151.308 Y153.618 F621 G1 X151.431 Y153.660 F621 G1 X151.383 Y153.708 F621 G1 X151.798 Y153.791 F621 G1 X151.849 Y153.808 F621 G1 X151.854 Y153.803 F621 G1 X154.158 Y155.459 F4800 G92 E0 G1 X154.372 Y155.245 E0.0038 F621 G1 X154.424 Y155.324 E0.0050 G1 X154.598 Y155.584 F621 G1 X154.459 Y155.723 F621 G1 X154.628 Y155.872 F621 G1 X154.744 Y156.004 F621 G1 X154.807 Y155.941 F621 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X153.757 Y136.088 F4800 G1 E0.0000 F1500 G92 E0 G1 X153.301 Y135.783 E0.0069 F582 G1 X152.526 Y135.401 E0.0177 G1 X151.709 Y135.124 E0.0285 G1 X150.862 Y134.955 E0.0394 G1 X150.000 Y134.899 E0.0502 G1 X149.138 Y134.955 E0.0610 G1 X148.291 Y135.124 E0.0718 G1 X147.474 Y135.401 E0.0827 G1 X146.699 Y135.783 E0.0935 G1 X146.244 Y136.088 E0.1004 G1 X146.035 Y135.850 E0.1043 G1 X146.183 Y135.683 E0.1071 G1 X146.714 Y135.217 E0.1160 G1 X147.301 Y134.825 E0.1248 G1 X147.934 Y134.512 E0.1337 G1 X148.603 Y134.285 E0.1426 G1 X149.295 Y134.147 E0.1514 G1 X150.000 Y134.101 E0.1603 G1 X150.705 Y134.147 E0.1691 G1 X151.397 Y134.285 E0.1780 G1 X152.066 Y134.512 E0.1868 G1 X152.699 Y134.825 E0.1957 G1 X153.287 Y135.217 E0.2045 G1 X153.471 Y135.379 E0.2076 G1 X153.817 Y135.683 F582 G1 X153.965 Y135.850 F582 G1 X153.756 Y136.088 F582 ; outer perimeter G1 X153.775 Y136.581 F4800 G92 E0 G1 X153.100 Y136.130 E0.0102 F388 G1 X152.373 Y135.772 E0.0203 G1 X151.605 Y135.511 E0.0305 G1 X150.809 Y135.353 E0.0407 G1 X150.000 Y135.300 E0.0509 G1 X149.191 Y135.353 E0.0610 G1 X148.395 Y135.511 E0.0712 G1 X147.627 Y135.772 E0.0814 G1 X146.900 Y136.130 E0.0915 G1 X146.225 Y136.581 E0.1017 G1 X145.616 Y137.116 E0.1119 G1 X145.081 Y137.725 E0.1221 G1 X144.630 Y138.400 E0.1322 G1 X144.272 Y139.127 E0.1424 G1 X144.214 Y139.298 E0.1447 G1 X144.250 Y138.743 E0.1516 G1 X144.398 Y137.999 E0.1611 G1 X144.642 Y137.281 E0.1706 G1 X144.977 Y136.600 E0.1802 G1 X145.399 Y135.969 E0.1897 G1 X145.899 Y135.399 E0.1992 G1 X146.469 Y134.899 E0.2087 G1 X147.100 Y134.477 E0.2182 G1 X147.781 Y134.142 E0.2277 G1 X148.499 Y133.898 E0.2372 G1 X149.243 Y133.750 E0.2468 G1 X150.000 Y133.700 E0.2563 G1 X150.757 Y133.750 E0.2658 G1 X151.501 Y133.898 E0.2753 G1 X152.219 Y134.142 E0.2848 G1 X152.900 Y134.477 E0.2943 G1 X153.531 Y134.899 E0.3038 G1 X154.101 Y135.399 E0.3134 G1 X154.601 Y135.969 E0.3229 G1 X155.023 Y136.600 E0.3324 G1 X155.358 Y137.281 E0.3419 G1 X155.602 Y137.999 E0.3514 G1 X155.750 Y138.743 E0.3609 G1 X155.786 Y139.298 E0.3679 G1 X155.728 Y139.127 E0.3701 G1 X155.370 Y138.400 E0.3803 G1 X154.919 Y137.725 E0.3905 G1 X154.509 Y137.258 E0.3983 G1 X154.384 Y137.116 F388 G1 X153.775 Y136.581 F388 ; gap fill G1 X154.033 Y136.350 F4800 G92 E0 G1 X154.270 Y136.113 E0.0042 F621 G1 X154.328 Y136.179 E0.0053 G1 X154.505 Y136.444 E0.0093 G1 X154.347 Y136.602 E0.0121 G1 X154.335 Y136.614 F621 G1 X154.628 Y136.872 F621 G1 X154.635 Y136.880 F621 G1 X154.730 Y136.785 F621 G1 X154.917 Y137.164 F621 G1 X154.899 Y137.181 F621 G1 X151.679 Y134.744 F4800 G92 E0 G1 X151.660 Y134.763 E0.0003 F621 G1 X151.188 Y134.669 E0.0064 G1 X151.251 Y134.607 E0.0075 G1 X150.779 Y134.513 E0.0135 G1 X150.693 Y134.599 E0.0150 G1 X150.162 Y134.565 E0.0217 G1 X150.263 Y134.463 E0.0235 G1 X150.000 Y134.446 E0.0268 G1 X149.695 Y134.466 E0.0307 G1 X149.579 Y134.582 E0.0327 G1 X149.093 Y134.613 E0.0388 G1 X148.983 Y134.635 E0.0402 G1 X148.954 Y134.641 F621 G1 X149.048 Y134.547 F621 G1 X148.692 Y134.618 F621 G1 X148.267 Y134.762 F621 G1 X148.248 Y134.782 F621 G92 E0 G1 E-6.5000 F1500 ; layer 15, Z = 3.100 ; inner perimeter G1 X148.291 Y135.124 F4800 G1 Z3.100 F300 G1 E0.0000 F1500 G92 E0 G1 X147.474 Y135.401 E0.0108 F582 G1 X146.699 Y135.783 E0.0217 G1 X146.244 Y136.088 E0.0285 G1 X146.035 Y135.850 E0.0325 G1 X146.183 Y135.683 E0.0353 G1 X146.714 Y135.217 E0.0441 G1 X147.301 Y134.825 E0.0530 G1 X147.934 Y134.512 E0.0619 G1 X148.603 Y134.285 E0.0707 G1 X149.295 Y134.147 E0.0796 G1 X150.000 Y134.101 E0.0884 G1 X150.705 Y134.147 E0.0973 G1 X151.397 Y134.285 E0.1061 G1 X152.066 Y134.512 E0.1150 G1 X152.699 Y134.825 E0.1238 G1 X153.287 Y135.217 E0.1327 G1 X153.817 Y135.683 E0.1416 G1 X153.965 Y135.850 E0.1444 G1 X153.756 Y136.088 E0.1483 G1 X153.301 Y135.783 E0.1552 G1 X152.526 Y135.401 E0.1660 G1 X151.709 Y135.124 E0.1768 G1 X150.862 Y134.955 E0.1877 G1 X150.000 Y134.899 E0.1985 G1 X149.275 Y134.946 E0.2076 G1 X149.138 Y134.955 F582 G1 X148.291 Y135.124 F582 ; outer perimeter G1 X148.395 Y135.511 F4800 G92 E0 G1 X147.627 Y135.772 E0.0102 F388 G1 X146.900 Y136.130 E0.0203 G1 X146.225 Y136.581 E0.0305 G1 X145.616 Y137.116 E0.0407 G1 X145.081 Y137.725 E0.0509 G1 X144.630 Y138.400 E0.0610 G1 X144.272 Y139.127 E0.0712 G1 X144.214 Y139.298 E0.0735 G1 X144.250 Y138.743 E0.0804 G1 X144.398 Y137.999 E0.0899 G1 X144.642 Y137.281 E0.0995 G1 X144.977 Y136.600 E0.1090 G1 X145.399 Y135.969 E0.1185 G1 X145.899 Y135.399 E0.1280 G1 X146.469 Y134.899 E0.1375 G1 X147.100 Y134.477 E0.1470 G1 X147.781 Y134.142 E0.1565 G1 X148.499 Y133.898 E0.1660 G1 X149.243 Y133.750 E0.1756 G1 X150.000 Y133.700 E0.1851 G1 X150.757 Y133.750 E0.1946 G1 X151.501 Y133.898 E0.2041 G1 X152.219 Y134.142 E0.2136 G1 X152.900 Y134.477 E0.2231 G1 X153.531 Y134.899 E0.2326 G1 X154.101 Y135.399 E0.2422 G1 X154.601 Y135.969 E0.2517 G1 X155.023 Y136.600 E0.2612 G1 X155.358 Y137.281 E0.2707 G1 X155.602 Y137.999 E0.2802 G1 X155.750 Y138.743 E0.2897 G1 X155.786 Y139.298 E0.2967 G1 X155.728 Y139.127 E0.2989 G1 X155.370 Y138.400 E0.3091 G1 X154.919 Y137.725 E0.3193 G1 X154.384 Y137.116 E0.3295 G1 X153.775 Y136.581 E0.3396 G1 X153.100 Y136.130 E0.3498 G1 X152.373 Y135.772 E0.3600 G1 X151.605 Y135.511 E0.3701 G1 X150.809 Y135.353 E0.3803 G1 X150.000 Y135.300 E0.3905 G1 X149.379 Y135.340 E0.3983 G1 X149.191 Y135.353 F388 G1 X148.395 Y135.511 F388 ; gap fill G1 X148.340 Y134.763 F4800 G92 E0 G1 X148.321 Y134.744 E0.0003 F620 G1 X148.692 Y134.618 E0.0053 G1 X148.749 Y134.607 E0.0060 G1 X148.812 Y134.669 E0.0071 G1 X149.093 Y134.613 E0.0107 G1 X149.307 Y134.599 E0.0134 G1 X149.221 Y134.513 E0.0149 G1 X149.340 Y134.489 E0.0164 G1 X149.737 Y134.463 E0.0214 G1 X149.838 Y134.565 E0.0232 G1 X150.000 Y134.554 E0.0253 G1 X150.421 Y134.582 E0.0305 G1 X150.305 Y134.466 E0.0326 G1 X150.660 Y134.489 E0.0370 G1 X150.834 Y134.524 E0.0393 G1 X150.952 Y134.547 F620 G1 X151.046 Y134.641 F620 G1 X151.752 Y134.782 F620 G1 X151.733 Y134.762 F620 G1 X145.730 Y136.113 F4800 G92 E0 G1 X145.967 Y136.350 E0.0042 F620 G1 X145.665 Y136.614 E0.0092 G1 X145.518 Y136.467 E0.0118 G1 X145.495 Y136.444 F620 G1 X145.276 Y136.773 F620 G1 X145.270 Y136.785 F620 G1 X145.365 Y136.880 F620 G1 X145.101 Y137.181 F620 G1 X145.083 Y137.164 F620 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X148.603 Y153.285 F4800 G1 E0.0000 F1500 G92 E0 G1 X149.295 Y153.147 E0.0089 F582 G1 X150.000 Y153.101 E0.0177 G1 X150.705 Y153.147 E0.0266 G1 X151.397 Y153.285 E0.0354 G1 X152.066 Y153.512 E0.0443 G1 X152.699 Y153.825 E0.0531 G1 X153.287 Y154.217 E0.0620 G1 X153.817 Y154.683 E0.0708 G1 X153.965 Y154.850 E0.0736 G1 X153.756 Y155.088 E0.0776 G1 X153.301 Y154.783 E0.0845 G1 X152.526 Y154.401 E0.0953 G1 X151.709 Y154.124 E0.1061 G1 X150.862 Y153.955 E0.1170 G1 X150.000 Y153.899 E0.1278 G1 X149.138 Y153.955 E0.1386 G1 X148.291 Y154.124 E0.1495 G1 X147.474 Y154.401 E0.1603 G1 X146.699 Y154.783 E0.1711 G1 X146.244 Y155.088 E0.1780 G1 X146.035 Y154.850 E0.1819 G1 X146.183 Y154.683 E0.1847 G1 X146.714 Y154.217 E0.1936 G1 X147.301 Y153.825 E0.2025 G1 X147.670 Y153.642 E0.2076 G1 X147.934 Y153.512 F582 G1 X148.603 Y153.285 F582 ; outer perimeter G1 X148.499 Y152.898 F4800 G92 E0 G1 X149.243 Y152.750 E0.0095 F388 G1 X150.000 Y152.700 E0.0190 G1 X150.757 Y152.750 E0.0285 G1 X151.501 Y152.898 E0.0381 G1 X152.219 Y153.142 E0.0476 G1 X152.900 Y153.477 E0.0571 G1 X153.531 Y153.899 E0.0666 G1 X154.101 Y154.399 E0.0761 G1 X154.601 Y154.969 E0.0856 G1 X155.023 Y155.600 E0.0951 G1 X155.358 Y156.281 E0.1046 G1 X155.602 Y156.999 E0.1142 G1 X155.750 Y157.743 E0.1237 G1 X155.786 Y158.298 E0.1306 G1 X155.728 Y158.127 E0.1329 G1 X155.370 Y157.400 E0.1431 G1 X154.919 Y156.725 E0.1532 G1 X154.384 Y156.116 E0.1634 G1 X153.775 Y155.581 E0.1736 G1 X153.100 Y155.130 E0.1838 G1 X152.373 Y154.772 E0.1939 G1 X151.605 Y154.511 E0.2041 G1 X150.809 Y154.353 E0.2143 G1 X150.000 Y154.300 E0.2244 G1 X149.191 Y154.353 E0.2346 G1 X148.395 Y154.511 E0.2448 G1 X147.627 Y154.772 E0.2550 G1 X146.900 Y155.130 E0.2651 G1 X146.225 Y155.581 E0.2753 G1 X145.616 Y156.116 E0.2855 G1 X145.081 Y156.725 E0.2956 G1 X144.630 Y157.400 E0.3058 G1 X144.272 Y158.127 E0.3160 G1 X144.214 Y158.298 E0.3182 G1 X144.250 Y157.743 E0.3252 G1 X144.398 Y156.999 E0.3347 G1 X144.642 Y156.281 E0.3442 G1 X144.977 Y155.600 E0.3537 G1 X145.399 Y154.969 E0.3633 G1 X145.899 Y154.399 E0.3728 G1 X146.469 Y153.899 E0.3823 G1 X147.100 Y153.477 E0.3918 G1 X147.564 Y153.249 E0.3983 G1 X147.781 Y153.142 F388 G1 X148.499 Y152.898 F388 ; gap fill G1 X148.151 Y153.808 F4800 G92 E0 G1 X148.147 Y153.803 E0.0001 F620 G1 X148.569 Y153.660 E0.0057 G1 X148.617 Y153.708 E0.0065 G1 X149.089 Y153.614 E0.0126 G1 X149.026 Y153.552 E0.0137 G1 X149.340 Y153.489 E0.0177 G1 X149.518 Y153.478 E0.0199 G1 X149.619 Y153.579 E0.0217 G1 X150.000 Y153.554 E0.0265 G1 X150.171 Y153.565 E0.0287 G1 X150.056 Y153.450 E0.0307 G1 X150.635 Y153.488 E0.0380 G1 X150.660 Y153.489 F620 G1 X150.776 Y153.605 F620 G1 X150.907 Y153.613 F620 G1 X151.461 Y153.724 F620 G1 X151.380 Y153.643 F620 G1 X154.094 Y155.225 F4800 G92 E0 G1 X154.097 Y155.229 E0.0001 F620 G1 X154.805 Y155.936 F620 G92 E0 G1 E-6.5000 F1500 G1 X145.628 Y155.245 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.843 Y155.459 E0.0038 F620 G1 X145.766 Y155.526 E0.0051 G1 X145.541 Y155.723 F620 G1 X145.402 Y155.584 F620 G1 X145.276 Y155.773 F620 G1 X145.193 Y155.941 F620 G1 X145.256 Y156.004 F620 G92 E0 G1 E-6.5000 F1500 ; layer 16, Z = 3.300 ; inner perimeter G1 X146.244 Y155.088 F4800 G1 Z3.300 F300 G1 E0.0000 F1500 G92 E0 G1 X146.035 Y154.850 E0.0040 F582 G1 X146.183 Y154.683 E0.0068 G1 X146.714 Y154.217 E0.0156 G1 X147.301 Y153.825 E0.0245 G1 X147.934 Y153.512 E0.0333 G1 X148.603 Y153.285 E0.0422 G1 X149.295 Y153.147 E0.0510 G1 X150.000 Y153.101 E0.0599 G1 X150.705 Y153.147 E0.0687 G1 X151.397 Y153.285 E0.0776 G1 X152.066 Y153.512 E0.0865 G1 X152.699 Y153.825 E0.0953 G1 X153.287 Y154.217 E0.1042 G1 X153.817 Y154.683 E0.1130 G1 X153.965 Y154.850 E0.1158 G1 X153.756 Y155.088 E0.1198 G1 X153.301 Y154.783 E0.1267 G1 X152.526 Y154.401 E0.1375 G1 X151.709 Y154.124 E0.1483 G1 X150.862 Y153.955 E0.1591 G1 X150.000 Y153.899 E0.1700 G1 X149.138 Y153.955 E0.1808 G1 X148.291 Y154.124 E0.1916 G1 X147.474 Y154.401 E0.2025 G1 X147.105 Y154.583 E0.2076 G1 X146.699 Y154.783 F582 G1 X146.244 Y155.088 F582 ; outer perimeter G1 X146.225 Y155.581 F4800 G92 E0 G1 X145.616 Y156.116 E0.0102 F388 G1 X145.081 Y156.725 E0.0203 G1 X144.630 Y157.400 E0.0305 G1 X144.272 Y158.127 E0.0407 G1 X144.214 Y158.298 E0.0429 G1 X144.250 Y157.743 E0.0499 G1 X144.398 Y156.999 E0.0594 G1 X144.642 Y156.281 E0.0689 G1 X144.977 Y155.600 E0.0785 G1 X145.399 Y154.969 E0.0880 G1 X145.899 Y154.399 E0.0975 G1 X146.469 Y153.899 E0.1070 G1 X147.100 Y153.477 E0.1165 G1 X147.781 Y153.142 E0.1260 G1 X148.499 Y152.898 E0.1355 G1 X149.243 Y152.750 E0.1450 G1 X150.000 Y152.700 E0.1546 G1 X150.757 Y152.750 E0.1641 G1 X151.501 Y152.898 E0.1736 G1 X152.219 Y153.142 E0.1831 G1 X152.900 Y153.477 E0.1926 G1 X153.531 Y153.899 E0.2021 G1 X154.101 Y154.399 E0.2116 G1 X154.601 Y154.969 E0.2212 G1 X155.023 Y155.600 E0.2307 G1 X155.358 Y156.281 E0.2402 G1 X155.602 Y156.999 E0.2497 G1 X155.750 Y157.743 E0.2592 G1 X155.786 Y158.298 E0.2662 G1 X155.728 Y158.127 E0.2684 G1 X155.370 Y157.400 E0.2786 G1 X154.919 Y156.725 E0.2888 G1 X154.384 Y156.116 E0.2989 G1 X153.775 Y155.581 E0.3091 G1 X153.100 Y155.130 E0.3193 G1 X152.373 Y154.772 E0.3295 G1 X151.605 Y154.511 E0.3396 G1 X150.809 Y154.353 E0.3498 G1 X150.000 Y154.300 E0.3600 G1 X149.191 Y154.353 E0.3701 G1 X148.395 Y154.511 E0.3803 G1 X147.627 Y154.772 E0.3905 G1 X147.069 Y155.047 E0.3983 G1 X146.900 Y155.130 F388 G1 X146.225 Y155.581 F388 ; gap fill G1 X145.906 Y155.225 F4800 G92 E0 G1 X145.903 Y155.229 E0.0001 F621 G1 X145.195 Y155.936 F621 G1 X148.539 Y153.724 F4800 G92 E0 G1 X148.620 Y153.643 E0.0014 F621 G1 X148.692 Y153.618 E0.0024 G1 X149.339 Y153.490 E0.0107 G1 X149.224 Y153.605 E0.0127 G1 X149.829 Y153.565 E0.0203 G1 X149.944 Y153.450 E0.0224 G1 X150.000 Y153.446 E0.0231 G1 X150.482 Y153.478 E0.0291 G1 X150.381 Y153.579 E0.0309 G1 X150.907 Y153.613 E0.0375 G1 X150.911 Y153.614 E0.0376 G1 X150.974 Y153.552 E0.0387 G1 X150.996 Y153.556 E0.0390 G1 X151.308 Y153.618 F621 G1 X151.431 Y153.660 F621 G1 X151.383 Y153.708 F621 G1 X151.798 Y153.791 F621 G1 X151.849 Y153.808 F621 G1 X151.854 Y153.803 F621 G1 X154.158 Y155.459 F4800 G92 E0 G1 X154.372 Y155.245 E0.0038 F621 G1 X154.424 Y155.324 E0.0050 G1 X154.598 Y155.584 F621 G1 X154.459 Y155.723 F621 G1 X154.628 Y155.872 F621 G1 X154.744 Y156.004 F621 G1 X154.807 Y155.941 F621 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X153.757 Y136.088 F4800 G1 E0.0000 F1500 G92 E0 G1 X153.301 Y135.783 E0.0069 F582 G1 X152.526 Y135.401 E0.0177 G1 X151.709 Y135.124 E0.0285 G1 X150.862 Y134.955 E0.0394 G1 X150.000 Y134.899 E0.0502 G1 X149.138 Y134.955 E0.0610 G1 X148.291 Y135.124 E0.0718 G1 X147.474 Y135.401 E0.0827 G1 X146.699 Y135.783 E0.0935 G1 X146.244 Y136.088 E0.1004 G1 X146.035 Y135.850 E0.1043 G1 X146.183 Y135.683 E0.1071 G1 X146.714 Y135.217 E0.1160 G1 X147.301 Y134.825 E0.1248 G1 X147.934 Y134.512 E0.1337 G1 X148.603 Y134.285 E0.1426 G1 X149.295 Y134.147 E0.1514 G1 X150.000 Y134.101 E0.1603 G1 X150.705 Y134.147 E0.1691 G1 X151.397 Y134.285 E0.1780 G1 X152.066 Y134.512 E0.1868 G1 X152.699 Y134.825 E0.1957 G1 X153.287 Y135.217 E0.2045 G1 X153.471 Y135.379 E0.2076 G1 X153.817 Y135.683 F582 G1 X153.965 Y135.850 F582 G1 X153.756 Y136.088 F582 ; outer perimeter G1 X153.775 Y136.581 F4800 G92 E0 G1 X153.100 Y136.130 E0.0102 F388 G1 X152.373 Y135.772 E0.0203 G1 X151.605 Y135.511 E0.0305 G1 X150.809 Y135.353 E0.0407 G1 X150.000 Y135.300 E0.0509 G1 X149.191 Y135.353 E0.0610 G1 X148.395 Y135.511 E0.0712 G1 X147.627 Y135.772 E0.0814 G1 X146.900 Y136.130 E0.0915 G1 X146.225 Y136.581 E0.1017 G1 X145.616 Y137.116 E0.1119 G1 X145.081 Y137.725 E0.1221 G1 X144.630 Y138.400 E0.1322 G1 X144.272 Y139.127 E0.1424 G1 X144.214 Y139.298 E0.1447 G1 X144.250 Y138.743 E0.1516 G1 X144.398 Y137.999 E0.1611 G1 X144.642 Y137.281 E0.1706 G1 X144.977 Y136.600 E0.1802 G1 X145.399 Y135.969 E0.1897 G1 X145.899 Y135.399 E0.1992 G1 X146.469 Y134.899 E0.2087 G1 X147.100 Y134.477 E0.2182 G1 X147.781 Y134.142 E0.2277 G1 X148.499 Y133.898 E0.2372 G1 X149.243 Y133.750 E0.2468 G1 X150.000 Y133.700 E0.2563 G1 X150.757 Y133.750 E0.2658 G1 X151.501 Y133.898 E0.2753 G1 X152.219 Y134.142 E0.2848 G1 X152.900 Y134.477 E0.2943 G1 X153.531 Y134.899 E0.3038 G1 X154.101 Y135.399 E0.3134 G1 X154.601 Y135.969 E0.3229 G1 X155.023 Y136.600 E0.3324 G1 X155.358 Y137.281 E0.3419 G1 X155.602 Y137.999 E0.3514 G1 X155.750 Y138.743 E0.3609 G1 X155.786 Y139.298 E0.3679 G1 X155.728 Y139.127 E0.3701 G1 X155.370 Y138.400 E0.3803 G1 X154.919 Y137.725 E0.3905 G1 X154.509 Y137.258 E0.3983 G1 X154.384 Y137.116 F388 G1 X153.775 Y136.581 F388 ; gap fill G1 X154.033 Y136.350 F4800 G92 E0 G1 X154.270 Y136.113 E0.0042 F621 G1 X154.328 Y136.179 E0.0053 G1 X154.505 Y136.444 E0.0093 G1 X154.347 Y136.602 E0.0121 G1 X154.335 Y136.614 F621 G1 X154.628 Y136.872 F621 G1 X154.635 Y136.880 F621 G1 X154.730 Y136.785 F621 G1 X154.917 Y137.164 F621 G1 X154.899 Y137.181 F621 G1 X151.679 Y134.744 F4800 G92 E0 G1 X151.660 Y134.763 E0.0003 F621 G1 X151.188 Y134.669 E0.0064 G1 X151.251 Y134.607 E0.0075 G1 X150.779 Y134.513 E0.0135 G1 X150.693 Y134.599 E0.0150 G1 X150.162 Y134.565 E0.0217 G1 X150.263 Y134.463 E0.0235 G1 X150.000 Y134.446 E0.0268 G1 X149.695 Y134.466 E0.0307 G1 X149.579 Y134.582 E0.0327 G1 X149.093 Y134.613 E0.0388 G1 X148.983 Y134.635 E0.0402 G1 X148.954 Y134.641 F621 G1 X149.048 Y134.547 F621 G1 X148.692 Y134.618 F621 G1 X148.267 Y134.762 F621 G1 X148.248 Y134.782 F621 G92 E0 G1 E-6.5000 F1500 ; layer 17, Z = 3.500 ; inner perimeter G1 X148.291 Y135.124 F4800 G1 Z3.500 F300 G1 E0.0000 F1500 G92 E0 G1 X147.474 Y135.401 E0.0108 F582 G1 X146.699 Y135.783 E0.0217 G1 X146.244 Y136.088 E0.0285 G1 X146.035 Y135.850 E0.0325 G1 X146.183 Y135.683 E0.0353 G1 X146.714 Y135.217 E0.0441 G1 X147.301 Y134.825 E0.0530 G1 X147.934 Y134.512 E0.0619 G1 X148.603 Y134.285 E0.0707 G1 X149.295 Y134.147 E0.0796 G1 X150.000 Y134.101 E0.0884 G1 X150.705 Y134.147 E0.0973 G1 X151.397 Y134.285 E0.1061 G1 X152.066 Y134.512 E0.1150 G1 X152.699 Y134.825 E0.1238 G1 X153.287 Y135.217 E0.1327 G1 X153.817 Y135.683 E0.1416 G1 X153.965 Y135.850 E0.1444 G1 X153.756 Y136.088 E0.1483 G1 X153.301 Y135.783 E0.1552 G1 X152.526 Y135.401 E0.1660 G1 X151.709 Y135.124 E0.1768 G1 X150.862 Y134.955 E0.1877 G1 X150.000 Y134.899 E0.1985 G1 X149.275 Y134.946 E0.2076 G1 X149.138 Y134.955 F582 G1 X148.291 Y135.124 F582 ; outer perimeter G1 X148.395 Y135.511 F4800 G92 E0 G1 X147.627 Y135.772 E0.0102 F388 G1 X146.900 Y136.130 E0.0203 G1 X146.225 Y136.581 E0.0305 G1 X145.616 Y137.116 E0.0407 G1 X145.081 Y137.725 E0.0509 G1 X144.630 Y138.400 E0.0610 G1 X144.272 Y139.127 E0.0712 G1 X144.214 Y139.298 E0.0735 G1 X144.250 Y138.743 E0.0804 G1 X144.398 Y137.999 E0.0899 G1 X144.642 Y137.281 E0.0995 G1 X144.977 Y136.600 E0.1090 G1 X145.399 Y135.969 E0.1185 G1 X145.899 Y135.399 E0.1280 G1 X146.469 Y134.899 E0.1375 G1 X147.100 Y134.477 E0.1470 G1 X147.781 Y134.142 E0.1565 G1 X148.499 Y133.898 E0.1660 G1 X149.243 Y133.750 E0.1756 G1 X150.000 Y133.700 E0.1851 G1 X150.757 Y133.750 E0.1946 G1 X151.501 Y133.898 E0.2041 G1 X152.219 Y134.142 E0.2136 G1 X152.900 Y134.477 E0.2231 G1 X153.531 Y134.899 E0.2326 G1 X154.101 Y135.399 E0.2422 G1 X154.601 Y135.969 E0.2517 G1 X155.023 Y136.600 E0.2612 G1 X155.358 Y137.281 E0.2707 G1 X155.602 Y137.999 E0.2802 G1 X155.750 Y138.743 E0.2897 G1 X155.786 Y139.298 E0.2967 G1 X155.728 Y139.127 E0.2989 G1 X155.370 Y138.400 E0.3091 G1 X154.919 Y137.725 E0.3193 G1 X154.384 Y137.116 E0.3295 G1 X153.775 Y136.581 E0.3396 G1 X153.100 Y136.130 E0.3498 G1 X152.373 Y135.772 E0.3600 G1 X151.605 Y135.511 E0.3701 G1 X150.809 Y135.353 E0.3803 G1 X150.000 Y135.300 E0.3905 G1 X149.379 Y135.340 E0.3983 G1 X149.191 Y135.353 F388 G1 X148.395 Y135.511 F388 ; gap fill G1 X148.340 Y134.763 F4800 G92 E0 G1 X148.321 Y134.744 E0.0003 F620 G1 X148.692 Y134.618 E0.0053 G1 X148.749 Y134.607 E0.0060 G1 X148.812 Y134.669 E0.0071 G1 X149.093 Y134.613 E0.0107 G1 X149.307 Y134.599 E0.0134 G1 X149.221 Y134.513 E0.0149 G1 X149.340 Y134.489 E0.0164 G1 X149.737 Y134.463 E0.0214 G1 X149.838 Y134.565 E0.0232 G1 X150.000 Y134.554 E0.0253 G1 X150.421 Y134.582 E0.0305 G1 X150.305 Y134.466 E0.0326 G1 X150.660 Y134.489 E0.0370 G1 X150.834 Y134.524 E0.0393 G1 X150.952 Y134.547 F620 G1 X151.046 Y134.641 F620 G1 X151.752 Y134.782 F620 G1 X151.733 Y134.762 F620 G1 X145.730 Y136.113 F4800 G92 E0 G1 X145.967 Y136.350 E0.0042 F620 G1 X145.665 Y136.614 E0.0092 G1 X145.518 Y136.467 E0.0118 G1 X145.495 Y136.444 F620 G1 X145.276 Y136.773 F620 G1 X145.270 Y136.785 F620 G1 X145.365 Y136.880 F620 G1 X145.101 Y137.181 F620 G1 X145.083 Y137.164 F620 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X148.603 Y153.285 F4800 G1 E0.0000 F1500 G92 E0 G1 X149.295 Y153.147 E0.0089 F582 G1 X150.000 Y153.101 E0.0177 G1 X150.705 Y153.147 E0.0266 G1 X151.397 Y153.285 E0.0354 G1 X152.066 Y153.512 E0.0443 G1 X152.699 Y153.825 E0.0531 G1 X153.287 Y154.217 E0.0620 G1 X153.817 Y154.683 E0.0708 G1 X153.965 Y154.850 E0.0736 G1 X153.756 Y155.088 E0.0776 G1 X153.301 Y154.783 E0.0845 G1 X152.526 Y154.401 E0.0953 G1 X151.709 Y154.124 E0.1061 G1 X150.862 Y153.955 E0.1170 G1 X150.000 Y153.899 E0.1278 G1 X149.138 Y153.955 E0.1386 G1 X148.291 Y154.124 E0.1495 G1 X147.474 Y154.401 E0.1603 G1 X146.699 Y154.783 E0.1711 G1 X146.244 Y155.088 E0.1780 G1 X146.035 Y154.850 E0.1819 G1 X146.183 Y154.683 E0.1847 G1 X146.714 Y154.217 E0.1936 G1 X147.301 Y153.825 E0.2025 G1 X147.670 Y153.642 E0.2076 G1 X147.934 Y153.512 F582 G1 X148.603 Y153.285 F582 ; outer perimeter G1 X148.499 Y152.898 F4800 G92 E0 G1 X149.243 Y152.750 E0.0095 F388 G1 X150.000 Y152.700 E0.0190 G1 X150.757 Y152.750 E0.0285 G1 X151.501 Y152.898 E0.0381 G1 X152.219 Y153.142 E0.0476 G1 X152.900 Y153.477 E0.0571 G1 X153.531 Y153.899 E0.0666 G1 X154.101 Y154.399 E0.0761 G1 X154.601 Y154.969 E0.0856 G1 X155.023 Y155.600 E0.0951 G1 X155.358 Y156.281 E0.1046 G1 X155.602 Y156.999 E0.1142 G1 X155.750 Y157.743 E0.1237 G1 X155.786 Y158.298 E0.1306 G1 X155.728 Y158.127 E0.1329 G1 X155.370 Y157.400 E0.1431 G1 X154.919 Y156.725 E0.1532 G1 X154.384 Y156.116 E0.1634 G1 X153.775 Y155.581 E0.1736 G1 X153.100 Y155.130 E0.1838 G1 X152.373 Y154.772 E0.1939 G1 X151.605 Y154.511 E0.2041 G1 X150.809 Y154.353 E0.2143 G1 X150.000 Y154.300 E0.2244 G1 X149.191 Y154.353 E0.2346 G1 X148.395 Y154.511 E0.2448 G1 X147.627 Y154.772 E0.2550 G1 X146.900 Y155.130 E0.2651 G1 X146.225 Y155.581 E0.2753 G1 X145.616 Y156.116 E0.2855 G1 X145.081 Y156.725 E0.2956 G1 X144.630 Y157.400 E0.3058 G1 X144.272 Y158.127 E0.3160 G1 X144.214 Y158.298 E0.3182 G1 X144.250 Y157.743 E0.3252 G1 X144.398 Y156.999 E0.3347 G1 X144.642 Y156.281 E0.3442 G1 X144.977 Y155.600 E0.3537 G1 X145.399 Y154.969 E0.3633 G1 X145.899 Y154.399 E0.3728 G1 X146.469 Y153.899 E0.3823 G1 X147.100 Y153.477 E0.3918 G1 X147.564 Y153.249 E0.3983 G1 X147.781 Y153.142 F388 G1 X148.499 Y152.898 F388 ; gap fill G1 X148.151 Y153.808 F4800 G92 E0 G1 X148.147 Y153.803 E0.0001 F620 G1 X148.569 Y153.660 E0.0057 G1 X148.617 Y153.708 E0.0065 G1 X149.089 Y153.614 E0.0126 G1 X149.026 Y153.552 E0.0137 G1 X149.340 Y153.489 E0.0177 G1 X149.518 Y153.478 E0.0199 G1 X149.619 Y153.579 E0.0217 G1 X150.000 Y153.554 E0.0265 G1 X150.171 Y153.565 E0.0287 G1 X150.056 Y153.450 E0.0307 G1 X150.635 Y153.488 E0.0380 G1 X150.660 Y153.489 F620 G1 X150.776 Y153.605 F620 G1 X150.907 Y153.613 F620 G1 X151.461 Y153.724 F620 G1 X151.380 Y153.643 F620 G1 X154.094 Y155.225 F4800 G92 E0 G1 X154.097 Y155.229 E0.0001 F620 G1 X154.805 Y155.936 F620 G92 E0 G1 E-6.5000 F1500 G1 X145.628 Y155.245 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.843 Y155.459 E0.0038 F620 G1 X145.766 Y155.526 E0.0051 G1 X145.541 Y155.723 F620 G1 X145.402 Y155.584 F620 G1 X145.276 Y155.773 F620 G1 X145.193 Y155.941 F620 G1 X145.256 Y156.004 F620 G92 E0 G1 E-6.5000 F1500 ; layer 18, Z = 3.700 ; inner perimeter G1 X146.244 Y155.088 F4800 G1 Z3.700 F300 G1 E0.0000 F1500 G92 E0 G1 X146.035 Y154.850 E0.0040 F582 G1 X146.183 Y154.683 E0.0068 G1 X146.714 Y154.217 E0.0156 G1 X147.301 Y153.825 E0.0245 G1 X147.934 Y153.512 E0.0333 G1 X148.603 Y153.285 E0.0422 G1 X149.295 Y153.147 E0.0510 G1 X150.000 Y153.101 E0.0599 G1 X150.705 Y153.147 E0.0687 G1 X151.397 Y153.285 E0.0776 G1 X152.066 Y153.512 E0.0865 G1 X152.699 Y153.825 E0.0953 G1 X153.287 Y154.217 E0.1042 G1 X153.817 Y154.683 E0.1130 G1 X153.965 Y154.850 E0.1158 G1 X153.756 Y155.088 E0.1198 G1 X153.301 Y154.783 E0.1267 G1 X152.526 Y154.401 E0.1375 G1 X151.709 Y154.124 E0.1483 G1 X150.862 Y153.955 E0.1591 G1 X150.000 Y153.899 E0.1700 G1 X149.138 Y153.955 E0.1808 G1 X148.291 Y154.124 E0.1916 G1 X147.474 Y154.401 E0.2025 G1 X147.105 Y154.583 E0.2076 G1 X146.699 Y154.783 F582 G1 X146.244 Y155.088 F582 ; outer perimeter G1 X146.225 Y155.581 F4800 G92 E0 G1 X145.616 Y156.116 E0.0102 F388 G1 X145.081 Y156.725 E0.0203 G1 X144.630 Y157.400 E0.0305 G1 X144.272 Y158.127 E0.0407 G1 X144.214 Y158.298 E0.0429 G1 X144.250 Y157.743 E0.0499 G1 X144.398 Y156.999 E0.0594 G1 X144.642 Y156.281 E0.0689 G1 X144.977 Y155.600 E0.0785 G1 X145.399 Y154.969 E0.0880 G1 X145.899 Y154.399 E0.0975 G1 X146.469 Y153.899 E0.1070 G1 X147.100 Y153.477 E0.1165 G1 X147.781 Y153.142 E0.1260 G1 X148.499 Y152.898 E0.1355 G1 X149.243 Y152.750 E0.1450 G1 X150.000 Y152.700 E0.1546 G1 X150.757 Y152.750 E0.1641 G1 X151.501 Y152.898 E0.1736 G1 X152.219 Y153.142 E0.1831 G1 X152.900 Y153.477 E0.1926 G1 X153.531 Y153.899 E0.2021 G1 X154.101 Y154.399 E0.2116 G1 X154.601 Y154.969 E0.2212 G1 X155.023 Y155.600 E0.2307 G1 X155.358 Y156.281 E0.2402 G1 X155.602 Y156.999 E0.2497 G1 X155.750 Y157.743 E0.2592 G1 X155.786 Y158.298 E0.2662 G1 X155.728 Y158.127 E0.2684 G1 X155.370 Y157.400 E0.2786 G1 X154.919 Y156.725 E0.2888 G1 X154.384 Y156.116 E0.2989 G1 X153.775 Y155.581 E0.3091 G1 X153.100 Y155.130 E0.3193 G1 X152.373 Y154.772 E0.3295 G1 X151.605 Y154.511 E0.3396 G1 X150.809 Y154.353 E0.3498 G1 X150.000 Y154.300 E0.3600 G1 X149.191 Y154.353 E0.3701 G1 X148.395 Y154.511 E0.3803 G1 X147.627 Y154.772 E0.3905 G1 X147.069 Y155.047 E0.3983 G1 X146.900 Y155.130 F388 G1 X146.225 Y155.581 F388 ; gap fill G1 X145.906 Y155.225 F4800 G92 E0 G1 X145.903 Y155.229 E0.0001 F621 G1 X145.195 Y155.936 F621 G1 X148.539 Y153.724 F4800 G92 E0 G1 X148.620 Y153.643 E0.0014 F621 G1 X148.692 Y153.618 E0.0024 G1 X149.339 Y153.490 E0.0107 G1 X149.224 Y153.605 E0.0127 G1 X149.829 Y153.565 E0.0203 G1 X149.944 Y153.450 E0.0224 G1 X150.000 Y153.446 E0.0231 G1 X150.482 Y153.478 E0.0291 G1 X150.381 Y153.579 E0.0309 G1 X150.907 Y153.613 E0.0375 G1 X150.911 Y153.614 E0.0376 G1 X150.974 Y153.552 E0.0387 G1 X150.996 Y153.556 E0.0390 G1 X151.308 Y153.618 F621 G1 X151.431 Y153.660 F621 G1 X151.383 Y153.708 F621 G1 X151.798 Y153.791 F621 G1 X151.849 Y153.808 F621 G1 X151.854 Y153.803 F621 G1 X154.158 Y155.459 F4800 G92 E0 G1 X154.372 Y155.245 E0.0038 F621 G1 X154.424 Y155.324 E0.0050 G1 X154.598 Y155.584 F621 G1 X154.459 Y155.723 F621 G1 X154.628 Y155.872 F621 G1 X154.744 Y156.004 F621 G1 X154.807 Y155.941 F621 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X153.757 Y136.088 F4800 G1 E0.0000 F1500 G92 E0 G1 X153.301 Y135.783 E0.0069 F582 G1 X152.526 Y135.401 E0.0177 G1 X151.709 Y135.124 E0.0285 G1 X150.862 Y134.955 E0.0394 G1 X150.000 Y134.899 E0.0502 G1 X149.138 Y134.955 E0.0610 G1 X148.291 Y135.124 E0.0718 G1 X147.474 Y135.401 E0.0827 G1 X146.699 Y135.783 E0.0935 G1 X146.244 Y136.088 E0.1004 G1 X146.035 Y135.850 E0.1043 G1 X146.183 Y135.683 E0.1071 G1 X146.714 Y135.217 E0.1160 G1 X147.301 Y134.825 E0.1248 G1 X147.934 Y134.512 E0.1337 G1 X148.603 Y134.285 E0.1426 G1 X149.295 Y134.147 E0.1514 G1 X150.000 Y134.101 E0.1603 G1 X150.705 Y134.147 E0.1691 G1 X151.397 Y134.285 E0.1780 G1 X152.066 Y134.512 E0.1868 G1 X152.699 Y134.825 E0.1957 G1 X153.287 Y135.217 E0.2045 G1 X153.471 Y135.379 E0.2076 G1 X153.817 Y135.683 F582 G1 X153.965 Y135.850 F582 G1 X153.756 Y136.088 F582 ; outer perimeter G1 X153.775 Y136.581 F4800 G92 E0 G1 X153.100 Y136.130 E0.0102 F388 G1 X152.373 Y135.772 E0.0203 G1 X151.605 Y135.511 E0.0305 G1 X150.809 Y135.353 E0.0407 G1 X150.000 Y135.300 E0.0509 G1 X149.191 Y135.353 E0.0610 G1 X148.395 Y135.511 E0.0712 G1 X147.627 Y135.772 E0.0814 G1 X146.900 Y136.130 E0.0915 G1 X146.225 Y136.581 E0.1017 G1 X145.616 Y137.116 E0.1119 G1 X145.081 Y137.725 E0.1221 G1 X144.630 Y138.400 E0.1322 G1 X144.272 Y139.127 E0.1424 G1 X144.214 Y139.298 E0.1447 G1 X144.250 Y138.743 E0.1516 G1 X144.398 Y137.999 E0.1611 G1 X144.642 Y137.281 E0.1706 G1 X144.977 Y136.600 E0.1802 G1 X145.399 Y135.969 E0.1897 G1 X145.899 Y135.399 E0.1992 G1 X146.469 Y134.899 E0.2087 G1 X147.100 Y134.477 E0.2182 G1 X147.781 Y134.142 E0.2277 G1 X148.499 Y133.898 E0.2372 G1 X149.243 Y133.750 E0.2468 G1 X150.000 Y133.700 E0.2563 G1 X150.757 Y133.750 E0.2658 G1 X151.501 Y133.898 E0.2753 G1 X152.219 Y134.142 E0.2848 G1 X152.900 Y134.477 E0.2943 G1 X153.531 Y134.899 E0.3038 G1 X154.101 Y135.399 E0.3134 G1 X154.601 Y135.969 E0.3229 G1 X155.023 Y136.600 E0.3324 G1 X155.358 Y137.281 E0.3419 G1 X155.602 Y137.999 E0.3514 G1 X155.750 Y138.743 E0.3609 G1 X155.786 Y139.298 E0.3679 G1 X155.728 Y139.127 E0.3701 G1 X155.370 Y138.400 E0.3803 G1 X154.919 Y137.725 E0.3905 G1 X154.509 Y137.258 E0.3983 G1 X154.384 Y137.116 F388 G1 X153.775 Y136.581 F388 ; gap fill G1 X154.033 Y136.350 F4800 G92 E0 G1 X154.270 Y136.113 E0.0042 F621 G1 X154.328 Y136.179 E0.0053 G1 X154.505 Y136.444 E0.0093 G1 X154.347 Y136.602 E0.0121 G1 X154.335 Y136.614 F621 G1 X154.628 Y136.872 F621 G1 X154.635 Y136.880 F621 G1 X154.730 Y136.785 F621 G1 X154.917 Y137.164 F621 G1 X154.899 Y137.181 F621 G1 X151.679 Y134.744 F4800 G92 E0 G1 X151.660 Y134.763 E0.0003 F621 G1 X151.188 Y134.669 E0.0064 G1 X151.251 Y134.607 E0.0075 G1 X150.779 Y134.513 E0.0135 G1 X150.693 Y134.599 E0.0150 G1 X150.162 Y134.565 E0.0217 G1 X150.263 Y134.463 E0.0235 G1 X150.000 Y134.446 E0.0268 G1 X149.695 Y134.466 E0.0307 G1 X149.579 Y134.582 E0.0327 G1 X149.093 Y134.613 E0.0388 G1 X148.983 Y134.635 E0.0402 G1 X148.954 Y134.641 F621 G1 X149.048 Y134.547 F621 G1 X148.692 Y134.618 F621 G1 X148.267 Y134.762 F621 G1 X148.248 Y134.782 F621 G92 E0 G1 E-6.5000 F1500 ; layer 19, Z = 3.900 ; inner perimeter G1 X148.291 Y135.124 F4800 G1 Z3.900 F300 G1 E0.0000 F1500 G92 E0 G1 X147.474 Y135.401 E0.0108 F582 G1 X146.699 Y135.783 E0.0217 G1 X146.244 Y136.088 E0.0285 G1 X146.035 Y135.850 E0.0325 G1 X146.183 Y135.683 E0.0353 G1 X146.714 Y135.217 E0.0441 G1 X147.301 Y134.825 E0.0530 G1 X147.934 Y134.512 E0.0619 G1 X148.603 Y134.285 E0.0707 G1 X149.295 Y134.147 E0.0796 G1 X150.000 Y134.101 E0.0884 G1 X150.705 Y134.147 E0.0973 G1 X151.397 Y134.285 E0.1061 G1 X152.066 Y134.512 E0.1150 G1 X152.699 Y134.825 E0.1238 G1 X153.287 Y135.217 E0.1327 G1 X153.817 Y135.683 E0.1416 G1 X153.965 Y135.850 E0.1444 G1 X153.756 Y136.088 E0.1483 G1 X153.301 Y135.783 E0.1552 G1 X152.526 Y135.401 E0.1660 G1 X151.709 Y135.124 E0.1768 G1 X150.862 Y134.955 E0.1877 G1 X150.000 Y134.899 E0.1985 G1 X149.275 Y134.946 E0.2076 G1 X149.138 Y134.955 F582 G1 X148.291 Y135.124 F582 ; outer perimeter G1 X148.395 Y135.511 F4800 G92 E0 G1 X147.627 Y135.772 E0.0102 F388 G1 X146.900 Y136.130 E0.0203 G1 X146.225 Y136.581 E0.0305 G1 X145.616 Y137.116 E0.0407 G1 X145.081 Y137.725 E0.0509 G1 X144.630 Y138.400 E0.0610 G1 X144.272 Y139.127 E0.0712 G1 X144.214 Y139.298 E0.0735 G1 X144.250 Y138.743 E0.0804 G1 X144.398 Y137.999 E0.0899 G1 X144.642 Y137.281 E0.0995 G1 X144.977 Y136.600 E0.1090 G1 X145.399 Y135.969 E0.1185 G1 X145.899 Y135.399 E0.1280 G1 X146.469 Y134.899 E0.1375 G1 X147.100 Y134.477 E0.1470 G1 X147.781 Y134.142 E0.1565 G1 X148.499 Y133.898 E0.1660 G1 X149.243 Y133.750 E0.1756 G1 X150.000 Y133.700 E0.1851 G1 X150.757 Y133.750 E0.1946 G1 X151.501 Y133.898 E0.2041 G1 X152.219 Y134.142 E0.2136 G1 X152.900 Y134.477 E0.2231 G1 X153.531 Y134.899 E0.2326 G1 X154.101 Y135.399 E0.2422 G1 X154.601 Y135.969 E0.2517 G1 X155.023 Y136.600 E0.2612 G1 X155.358 Y137.281 E0.2707 G1 X155.602 Y137.999 E0.2802 G1 X155.750 Y138.743 E0.2897 G1 X155.786 Y139.298 E0.2967 G1 X155.728 Y139.127 E0.2989 G1 X155.370 Y138.400 E0.3091 G1 X154.919 Y137.725 E0.3193 G1 X154.384 Y137.116 E0.3295 G1 X153.775 Y136.581 E0.3396 G1 X153.100 Y136.130 E0.3498 G1 X152.373 Y135.772 E0.3600 G1 X151.605 Y135.511 E0.3701 G1 X150.809 Y135.353 E0.3803 G1 X150.000 Y135.300 E0.3905 G1 X149.379 Y135.340 E0.3983 G1 X149.191 Y135.353 F388 G1 X148.395 Y135.511 F388 ; gap fill G1 X148.340 Y134.763 F4800 G92 E0 G1 X148.321 Y134.744 E0.0003 F620 G1 X148.692 Y134.618 E0.0053 G1 X148.749 Y134.607 E0.0060 G1 X148.812 Y134.669 E0.0071 G1 X149.093 Y134.613 E0.0107 G1 X149.307 Y134.599 E0.0134 G1 X149.221 Y134.513 E0.0149 G1 X149.340 Y134.489 E0.0164 G1 X149.737 Y134.463 E0.0214 G1 X149.838 Y134.565 E0.0232 G1 X150.000 Y134.554 E0.0253 G1 X150.421 Y134.582 E0.0305 G1 X150.305 Y134.466 E0.0326 G1 X150.660 Y134.489 E0.0370 G1 X150.834 Y134.524 E0.0393 G1 X150.952 Y134.547 F620 G1 X151.046 Y134.641 F620 G1 X151.752 Y134.782 F620 G1 X151.733 Y134.762 F620 G1 X145.730 Y136.113 F4800 G92 E0 G1 X145.967 Y136.350 E0.0042 F620 G1 X145.665 Y136.614 E0.0092 G1 X145.518 Y136.467 E0.0118 G1 X145.495 Y136.444 F620 G1 X145.276 Y136.773 F620 G1 X145.270 Y136.785 F620 G1 X145.365 Y136.880 F620 G1 X145.101 Y137.181 F620 G1 X145.083 Y137.164 F620 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X148.603 Y153.285 F4800 G1 E0.0000 F1500 G92 E0 G1 X149.295 Y153.147 E0.0089 F582 G1 X150.000 Y153.101 E0.0177 G1 X150.705 Y153.147 E0.0266 G1 X151.397 Y153.285 E0.0354 G1 X152.066 Y153.512 E0.0443 G1 X152.699 Y153.825 E0.0531 G1 X153.287 Y154.217 E0.0620 G1 X153.817 Y154.683 E0.0708 G1 X153.965 Y154.850 E0.0736 G1 X153.756 Y155.088 E0.0776 G1 X153.301 Y154.783 E0.0845 G1 X152.526 Y154.401 E0.0953 G1 X151.709 Y154.124 E0.1061 G1 X150.862 Y153.955 E0.1170 G1 X150.000 Y153.899 E0.1278 G1 X149.138 Y153.955 E0.1386 G1 X148.291 Y154.124 E0.1495 G1 X147.474 Y154.401 E0.1603 G1 X146.699 Y154.783 E0.1711 G1 X146.244 Y155.088 E0.1780 G1 X146.035 Y154.850 E0.1819 G1 X146.183 Y154.683 E0.1847 G1 X146.714 Y154.217 E0.1936 G1 X147.301 Y153.825 E0.2025 G1 X147.670 Y153.642 E0.2076 G1 X147.934 Y153.512 F582 G1 X148.603 Y153.285 F582 ; outer perimeter G1 X148.499 Y152.898 F4800 G92 E0 G1 X149.243 Y152.750 E0.0095 F388 G1 X150.000 Y152.700 E0.0190 G1 X150.757 Y152.750 E0.0285 G1 X151.501 Y152.898 E0.0381 G1 X152.219 Y153.142 E0.0476 G1 X152.900 Y153.477 E0.0571 G1 X153.531 Y153.899 E0.0666 G1 X154.101 Y154.399 E0.0761 G1 X154.601 Y154.969 E0.0856 G1 X155.023 Y155.600 E0.0951 G1 X155.358 Y156.281 E0.1046 G1 X155.602 Y156.999 E0.1142 G1 X155.750 Y157.743 E0.1237 G1 X155.786 Y158.298 E0.1306 G1 X155.728 Y158.127 E0.1329 G1 X155.370 Y157.400 E0.1431 G1 X154.919 Y156.725 E0.1532 G1 X154.384 Y156.116 E0.1634 G1 X153.775 Y155.581 E0.1736 G1 X153.100 Y155.130 E0.1838 G1 X152.373 Y154.772 E0.1939 G1 X151.605 Y154.511 E0.2041 G1 X150.809 Y154.353 E0.2143 G1 X150.000 Y154.300 E0.2244 G1 X149.191 Y154.353 E0.2346 G1 X148.395 Y154.511 E0.2448 G1 X147.627 Y154.772 E0.2550 G1 X146.900 Y155.130 E0.2651 G1 X146.225 Y155.581 E0.2753 G1 X145.616 Y156.116 E0.2855 G1 X145.081 Y156.725 E0.2956 G1 X144.630 Y157.400 E0.3058 G1 X144.272 Y158.127 E0.3160 G1 X144.214 Y158.298 E0.3182 G1 X144.250 Y157.743 E0.3252 G1 X144.398 Y156.999 E0.3347 G1 X144.642 Y156.281 E0.3442 G1 X144.977 Y155.600 E0.3537 G1 X145.399 Y154.969 E0.3633 G1 X145.899 Y154.399 E0.3728 G1 X146.469 Y153.899 E0.3823 G1 X147.100 Y153.477 E0.3918 G1 X147.564 Y153.249 E0.3983 G1 X147.781 Y153.142 F388 G1 X148.499 Y152.898 F388 ; gap fill G1 X148.151 Y153.808 F4800 G92 E0 G1 X148.147 Y153.803 E0.0001 F620 G1 X148.569 Y153.660 E0.0057 G1 X148.617 Y153.708 E0.0065 G1 X149.089 Y153.614 E0.0126 G1 X149.026 Y153.552 E0.0137 G1 X149.340 Y153.489 E0.0177 G1 X149.518 Y153.478 E0.0199 G1 X149.619 Y153.579 E0.0217 G1 X150.000 Y153.554 E0.0265 G1 X150.171 Y153.565 E0.0287 G1 X150.056 Y153.450 E0.0307 G1 X150.635 Y153.488 E0.0380 G1 X150.660 Y153.489 F620 G1 X150.776 Y153.605 F620 G1 X150.907 Y153.613 F620 G1 X151.461 Y153.724 F620 G1 X151.380 Y153.643 F620 G1 X154.094 Y155.225 F4800 G92 E0 G1 X154.097 Y155.229 E0.0001 F620 G1 X154.805 Y155.936 F620 G92 E0 G1 E-6.5000 F1500 G1 X145.628 Y155.245 F4800 G1 E0.0000 F1500 G92 E0 G1 X145.843 Y155.459 E0.0038 F620 G1 X145.766 Y155.526 E0.0051 G1 X145.541 Y155.723 F620 G1 X145.402 Y155.584 F620 G1 X145.276 Y155.773 F620 G1 X145.193 Y155.941 F620 G1 X145.256 Y156.004 F620 G92 E0 G1 E-6.5000 F1500 ; layer 20, Z = 4.100 ; inner perimeter G1 X146.244 Y155.088 F4800 G1 Z4.100 F300 G1 E0.0000 F1500 G92 E0 G1 X146.035 Y154.850 E0.0040 F582 G1 X146.183 Y154.683 E0.0068 G1 X146.714 Y154.217 E0.0156 G1 X147.301 Y153.825 E0.0245 G1 X147.934 Y153.512 E0.0333 G1 X148.603 Y153.285 E0.0422 G1 X149.295 Y153.147 E0.0510 G1 X150.000 Y153.101 E0.0599 G1 X150.705 Y153.147 E0.0687 G1 X151.397 Y153.285 E0.0776 G1 X152.066 Y153.512 E0.0865 G1 X152.699 Y153.825 E0.0953 G1 X153.287 Y154.217 E0.1042 G1 X153.817 Y154.683 E0.1130 G1 X153.965 Y154.850 E0.1158 G1 X153.756 Y155.088 E0.1198 G1 X153.301 Y154.783 E0.1267 G1 X152.526 Y154.401 E0.1375 G1 X151.709 Y154.124 E0.1483 G1 X150.862 Y153.955 E0.1591 G1 X150.000 Y153.899 E0.1700 G1 X149.138 Y153.955 E0.1808 G1 X148.291 Y154.124 E0.1916 G1 X147.474 Y154.401 E0.2025 G1 X147.105 Y154.583 E0.2076 G1 X146.699 Y154.783 F582 G1 X146.244 Y155.088 F582 ; outer perimeter G1 X146.225 Y155.581 F4800 G92 E0 G1 X145.616 Y156.116 E0.0102 F388 G1 X145.081 Y156.725 E0.0203 G1 X144.630 Y157.400 E0.0305 G1 X144.272 Y158.127 E0.0407 G1 X144.214 Y158.298 E0.0429 G1 X144.250 Y157.743 E0.0499 G1 X144.398 Y156.999 E0.0594 G1 X144.642 Y156.281 E0.0689 G1 X144.977 Y155.600 E0.0785 G1 X145.399 Y154.969 E0.0880 G1 X145.899 Y154.399 E0.0975 G1 X146.469 Y153.899 E0.1070 G1 X147.100 Y153.477 E0.1165 G1 X147.781 Y153.142 E0.1260 G1 X148.499 Y152.898 E0.1355 G1 X149.243 Y152.750 E0.1450 G1 X150.000 Y152.700 E0.1546 G1 X150.757 Y152.750 E0.1641 G1 X151.501 Y152.898 E0.1736 G1 X152.219 Y153.142 E0.1831 G1 X152.900 Y153.477 E0.1926 G1 X153.531 Y153.899 E0.2021 G1 X154.101 Y154.399 E0.2116 G1 X154.601 Y154.969 E0.2212 G1 X155.023 Y155.600 E0.2307 G1 X155.358 Y156.281 E0.2402 G1 X155.602 Y156.999 E0.2497 G1 X155.750 Y157.743 E0.2592 G1 X155.786 Y158.298 E0.2662 G1 X155.728 Y158.127 E0.2684 G1 X155.370 Y157.400 E0.2786 G1 X154.919 Y156.725 E0.2888 G1 X154.384 Y156.116 E0.2989 G1 X153.775 Y155.581 E0.3091 G1 X153.100 Y155.130 E0.3193 G1 X152.373 Y154.772 E0.3295 G1 X151.605 Y154.511 E0.3396 G1 X150.809 Y154.353 E0.3498 G1 X150.000 Y154.300 E0.3600 G1 X149.191 Y154.353 E0.3701 G1 X148.395 Y154.511 E0.3803 G1 X147.627 Y154.772 E0.3905 G1 X147.069 Y155.047 E0.3983 G1 X146.900 Y155.130 F388 G1 X146.225 Y155.581 F388 ; gap fill G1 X145.906 Y155.225 F4800 G92 E0 G1 X145.903 Y155.229 E0.0001 F621 G1 X145.195 Y155.936 F621 G1 X148.539 Y153.724 F4800 G92 E0 G1 X148.620 Y153.643 E0.0014 F621 G1 X148.692 Y153.618 E0.0024 G1 X149.339 Y153.490 E0.0107 G1 X149.224 Y153.605 E0.0127 G1 X149.829 Y153.565 E0.0203 G1 X149.944 Y153.450 E0.0224 G1 X150.000 Y153.446 E0.0231 G1 X150.482 Y153.478 E0.0291 G1 X150.381 Y153.579 E0.0309 G1 X150.907 Y153.613 E0.0375 G1 X150.911 Y153.614 E0.0376 G1 X150.974 Y153.552 E0.0387 G1 X150.996 Y153.556 E0.0390 G1 X151.308 Y153.618 F621 G1 X151.431 Y153.660 F621 G1 X151.383 Y153.708 F621 G1 X151.798 Y153.791 F621 G1 X151.849 Y153.808 F621 G1 X151.854 Y153.803 F621 G1 X154.158 Y155.459 F4800 G92 E0 G1 X154.372 Y155.245 E0.0038 F621 G1 X154.424 Y155.324 E0.0050 G1 X154.598 Y155.584 F621 G1 X154.459 Y155.723 F621 G1 X154.628 Y155.872 F621 G1 X154.744 Y156.004 F621 G1 X154.807 Y155.941 F621 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X153.757 Y136.088 F4800 G1 E0.0000 F1500 G92 E0 G1 X153.301 Y135.783 E0.0069 F582 G1 X152.526 Y135.401 E0.0177 G1 X151.709 Y135.124 E0.0285 G1 X150.862 Y134.955 E0.0394 G1 X150.000 Y134.899 E0.0502 G1 X149.138 Y134.955 E0.0610 G1 X148.291 Y135.124 E0.0718 G1 X147.474 Y135.401 E0.0827 G1 X146.699 Y135.783 E0.0935 G1 X146.244 Y136.088 E0.1004 G1 X146.035 Y135.850 E0.1043 G1 X146.183 Y135.683 E0.1071 G1 X146.714 Y135.217 E0.1160 G1 X147.301 Y134.825 E0.1248 G1 X147.934 Y134.512 E0.1337 G1 X148.603 Y134.285 E0.1426 G1 X149.295 Y134.147 E0.1514 G1 X150.000 Y134.101 E0.1603 G1 X150.705 Y134.147 E0.1691 G1 X151.397 Y134.285 E0.1780 G1 X152.066 Y134.512 E0.1868 G1 X152.699 Y134.825 E0.1957 G1 X153.287 Y135.217 E0.2045 G1 X153.471 Y135.379 E0.2076 G1 X153.817 Y135.683 F582 G1 X153.965 Y135.850 F582 G1 X153.756 Y136.088 F582 ; outer perimeter G1 X153.775 Y136.581 F4800 G92 E0 G1 X153.100 Y136.130 E0.0102 F388 G1 X152.373 Y135.772 E0.0203 G1 X151.605 Y135.511 E0.0305 G1 X150.809 Y135.353 E0.0407 G1 X150.000 Y135.300 E0.0509 G1 X149.191 Y135.353 E0.0610 G1 X148.395 Y135.511 E0.0712 G1 X147.627 Y135.772 E0.0814 G1 X146.900 Y136.130 E0.0915 G1 X146.225 Y136.581 E0.1017 G1 X145.616 Y137.116 E0.1119 G1 X145.081 Y137.725 E0.1221 G1 X144.630 Y138.400 E0.1322 G1 X144.272 Y139.127 E0.1424 G1 X144.214 Y139.298 E0.1447 G1 X144.250 Y138.743 E0.1516 G1 X144.398 Y137.999 E0.1611 G1 X144.642 Y137.281 E0.1706 G1 X144.977 Y136.600 E0.1802 G1 X145.399 Y135.969 E0.1897 G1 X145.899 Y135.399 E0.1992 G1 X146.469 Y134.899 E0.2087 G1 X147.100 Y134.477 E0.2182 G1 X147.781 Y134.142 E0.2277 G1 X148.499 Y133.898 E0.2372 G1 X149.243 Y133.750 E0.2468 G1 X150.000 Y133.700 E0.2563 G1 X150.757 Y133.750 E0.2658 G1 X151.501 Y133.898 E0.2753 G1 X152.219 Y134.142 E0.2848 G1 X152.900 Y134.477 E0.2943 G1 X153.531 Y134.899 E0.3038 G1 X154.101 Y135.399 E0.3134 G1 X154.601 Y135.969 E0.3229 G1 X155.023 Y136.600 E0.3324 G1 X155.358 Y137.281 E0.3419 G1 X155.602 Y137.999 E0.3514 G1 X155.750 Y138.743 E0.3609 G1 X155.786 Y139.298 E0.3679 G1 X155.728 Y139.127 E0.3701 G1 X155.370 Y138.400 E0.3803 G1 X154.919 Y137.725 E0.3905 G1 X154.509 Y137.258 E0.3983 G1 X154.384 Y137.116 F388 G1 X153.775 Y136.581 F388 ; gap fill G1 X154.033 Y136.350 F4800 G92 E0 G1 X154.270 Y136.113 E0.0042 F621 G1 X154.328 Y136.179 E0.0053 G1 X154.505 Y136.444 E0.0093 G1 X154.347 Y136.602 E0.0121 G1 X154.335 Y136.614 F621 G1 X154.628 Y136.872 F621 G1 X154.635 Y136.880 F621 G1 X154.730 Y136.785 F621 G1 X154.917 Y137.164 F621 G1 X154.899 Y137.181 F621 G1 X151.679 Y134.744 F4800 G92 E0 G1 X151.660 Y134.763 E0.0003 F621 G1 X151.188 Y134.669 E0.0064 G1 X151.251 Y134.607 E0.0075 G1 X150.779 Y134.513 E0.0135 G1 X150.693 Y134.599 E0.0150 G1 X150.162 Y134.565 E0.0217 G1 X150.263 Y134.463 E0.0235 G1 X150.000 Y134.446 E0.0268 G1 X149.695 Y134.466 E0.0307 G1 X149.579 Y134.582 E0.0327 G1 X149.093 Y134.613 E0.0388 G1 X148.983 Y134.635 E0.0402 G1 X148.954 Y134.641 F621 G1 X149.048 Y134.547 F621 G1 X148.692 Y134.618 F621 G1 X148.267 Y134.762 F621 G1 X148.248 Y134.782 F621 G92 E0 G1 E-6.5000 F1500 ; layer 21, Z = 4.300 ; inner perimeter G1 X148.291 Y135.124 F4800 G1 Z4.300 F300 G1 E0.0000 F1500 G92 E0 G1 X147.474 Y135.401 E0.0108 F540 G1 X146.699 Y135.783 E0.0217 G1 X146.244 Y136.088 E0.0285 G1 X146.035 Y135.850 E0.0325 G1 X146.183 Y135.683 E0.0353 G1 X146.714 Y135.217 E0.0441 G1 X147.301 Y134.825 E0.0530 G1 X147.934 Y134.512 E0.0619 G1 X148.603 Y134.285 E0.0707 G1 X149.295 Y134.147 E0.0796 G1 X150.000 Y134.101 E0.0884 G1 X150.705 Y134.147 E0.0973 G1 X151.397 Y134.285 E0.1061 G1 X152.118 Y134.530 E0.1157 G1 X152.118 Y135.263 E0.1249 G1 X151.709 Y135.124 E0.1303 G1 X150.862 Y134.955 E0.1411 G1 X150.000 Y134.899 E0.1520 G1 X149.275 Y134.946 E0.1611 G1 X149.138 Y134.955 F540 G1 X148.291 Y135.124 F540 ; outer perimeter G1 X148.395 Y135.511 F4800 G92 E0 G1 X147.627 Y135.772 E0.0102 F360 G1 X146.900 Y136.130 E0.0203 G1 X146.225 Y136.581 E0.0305 G1 X145.616 Y137.116 E0.0407 G1 X145.081 Y137.725 E0.0509 G1 X144.630 Y138.400 E0.0610 G1 X144.588 Y138.486 E0.0622 G1 X144.509 Y137.673 E0.0725 G1 X144.642 Y137.281 E0.0777 G1 X144.977 Y136.600 E0.0872 G1 X145.399 Y135.969 E0.0967 G1 X145.899 Y135.399 E0.1062 G1 X146.469 Y134.899 E0.1157 G1 X147.100 Y134.477 E0.1252 G1 X147.781 Y134.142 E0.1347 G1 X148.499 Y133.898 E0.1443 G1 X149.243 Y133.750 E0.1538 G1 X150.000 Y133.700 E0.1633 G1 X150.757 Y133.750 E0.1728 G1 X151.501 Y133.898 E0.1823 G1 X152.219 Y134.142 E0.1918 G1 X152.518 Y134.289 E0.1960 G1 X152.518 Y135.843 E0.2155 G1 X152.373 Y135.772 E0.2175 G1 X151.605 Y135.511 E0.2277 G1 X150.809 Y135.353 E0.2379 G1 X150.000 Y135.300 E0.2480 G1 X149.379 Y135.340 E0.2558 G1 X149.191 Y135.353 F360 G1 X148.395 Y135.511 F360 ; gap fill G1 X148.340 Y134.763 F4800 G92 E0 G1 X148.321 Y134.744 E0.0003 F576 G1 X148.692 Y134.618 E0.0053 G1 X148.749 Y134.607 E0.0060 G1 X148.812 Y134.669 E0.0071 G1 X149.093 Y134.613 E0.0107 G1 X149.307 Y134.599 E0.0134 G1 X149.221 Y134.513 E0.0149 G1 X149.340 Y134.489 E0.0164 G1 X149.737 Y134.463 E0.0214 G1 X149.838 Y134.565 E0.0232 G1 X150.000 Y134.554 E0.0253 G1 X150.421 Y134.582 E0.0305 G1 X150.305 Y134.466 E0.0326 G1 X150.660 Y134.489 E0.0370 G1 X150.834 Y134.524 E0.0393 G1 X150.952 Y134.547 F576 G1 X151.046 Y134.641 F576 G1 X151.752 Y134.782 F576 G1 X151.733 Y134.762 F576 G1 X145.730 Y136.113 F4800 G92 E0 G1 X145.967 Y136.350 E0.0042 F576 G1 X145.665 Y136.614 E0.0092 G1 X145.518 Y136.467 E0.0118 G1 X145.495 Y136.444 F576 G1 X145.276 Y136.773 F576 G1 X145.270 Y136.785 F576 G1 X145.365 Y136.880 F576 G1 X145.101 Y137.181 F576 G1 X145.083 Y137.164 F576 G92 E0 G1 E-6.5000 F1500 ; inner perimeter G1 X148.603 Y153.285 F4800 G1 E0.0000 F1500 G92 E0 G1 X149.295 Y153.147 E0.0089 F540 G1 X150.000 Y153.101 E0.0177 G1 X150.705 Y153.147 E0.0266 G1 X151.397 Y153.285 E0.0354 G1 X152.118 Y153.530 E0.0450 G1 X152.118 Y154.263 E0.0542 G1 X151.709 Y154.124 E0.0596 G1 X150.862 Y153.955 E0.0704 G1 X150.000 Y153.899 E0.0812 G1 X149.138 Y153.955 E0.0921 G1 X148.291 Y154.124 E0.1029 G1 X147.474 Y154.401 E0.1137 G1 X146.699 Y154.783 E0.1246 G1 X146.244 Y155.088 E0.1314 G1 X146.035 Y154.850 E0.1354 G1 X146.183 Y154.683 E0.1382 G1 X146.714 Y154.217 E0.1470 G1 X147.301 Y153.825 E0.1559 G1 X147.670 Y153.642 E0.1611 G1 X147.934 Y153.512 F540 G1 X148.603 Y153.285 F540 ; outer perimeter G1 X148.499 Y152.898 F4800 G92 E0 G1 X149.243 Y152.750 E0.0095 F360 G1 X150.000 Y152.700 E0.0190 G1 X150.757 Y152.750 E0.0285 G1 X151.501 Y152.898 E0.0381 G1 X152.219 Y153.142 E0.0476 G1 X152.518 Y153.289 E0.0517 G1 X152.518 Y154.843 E0.0712 G1 X152.373 Y154.772 E0.0733 G1 X151.605 Y154.511 E0.0834 G1 X150.809 Y154.353 E0.0936 G1 X150.000 Y154.300 E0.1038 G1 X149.191 Y154.353 E0.1140 G1 X148.395 Y154.511 E0.1241 G1 X147.627 Y154.772 E0.1343 G1 X146.900 Y155.130 E0.1445 G1 X146.225 Y155.581 E0.1546 G1 X145.616 Y156.116 E0.1648 G1 X145.081 Y156.725 E0.1750 G1 X144.630 Y157.400 E0.1852 G1 X144.588 Y157.486 E0.1864 G1 X144.509 Y156.673 E0.1966 G1 X144.642 Y156.281 E0.2018 G1 X144.977 Y155.600 E0.2113 G1 X145.399 Y154.969 E0.2208 G1 X145.899 Y154.399 E0.2303 G1 X146.469 Y153.899 E0.2398 G1 X147.100 Y153.477 E0.2494 G1 X147.564 Y153.249 E0.2558 G1 X147.781 Y153.142 F360 G1 X148.499 Y152.898 F360 ; gap fill G1 X148.151 Y153.808 F4800 G92 E0 G1 X148.147 Y153.803 E0.0001 F576 G1 X148.569 Y153.660 E0.0057 G1 X148.617 Y153.708 E0.0065 G1 X149.089 Y153.614 E0.0126 G1 X149.026 Y153.552 E0.0137 G1 X149.340 Y153.489 E0.0177 G1 X149.518 Y153.478 E0.0199 G1 X149.619 Y153.579 E0.0217 G1 X150.000 Y153.554 E0.0265 G1 X150.171 Y153.565 E0.0287 G1 X150.056 Y153.450 E0.0307 G1 X150.635 Y153.488 E0.0380 G1 X150.660 Y153.489 F576 G1 X150.776 Y153.605 F576 G1 X150.907 Y153.613 F576 G1 X151.461 Y153.724 F576 G1 X151.380 Y153.643 F576 G1 X145.628 Y155.245 F4800 G92 E0 G1 X145.843 Y155.459 E0.0038 F576 G1 X145.766 Y155.526 E0.0051 G1 X145.541 Y155.723 F576 G1 X145.402 Y155.584 F576 G1 X145.276 Y155.773 F576 G1 X145.193 Y155.941 F576 G1 X145.256 Y156.004 F576 G92 E0 G1 E-6.5000 F1500 ; layer end M104 S0 ; turn off extruder M140 S0 ; turn off bed G91 ; use relative coordinates G1 Z0.6 F5000 ; lift nozzle by 0.6mm G90 ; use absolute coordinates G1 X150 Y0 ; move Y axis to end position M84 ; disable extruder ;M18 ; Disable all stepper motors M107 ; turn off fan ; Build Summary ; Build time: 0 hours 6 minutes ; Filament length: 59.2 mm (0.06 m) ; Plastic volume: 377.62 mm^3 (0.38 cc) ; Plastic weight: 0.47 g (0.00 lb) ; Material cost: 0.02
Thanks, it's extrusion-related then. I'll prepare a change for you to test. Is your board a Duet WiFi?
Yes Duet WiFI
Please can you try 1.19+6 at https://www.dropbox.com/s/yybmbe4jyonn2g3/DuetWiFiFirmware.bin?dl=0 and see if it is better.
Hello everyone,
David I have exactly the same problem on my DELTA, I have a big vibration that I did not have in 1.19 + 4.
I have my printer back in this version, and I have no problem.
Maybe the size of the print has something to have, because yesterday I tried Version 1.19 + 5 on a 10mn print and no problem.
The I had to launch a print of 9H. -
Come home, not possible to test before tomorrow afternoon at the fablab …
Hello everyone,
The I had to launch a print of 9H.Please can you try the 1.16 version too. Versions for Duet Ethernet and Duet WiFi are at https://www.dropbox.com/sh/wzb6bm1www3ewn5/AACUbv-2xHJkzV2gdThu7a5Wa?dl=0. EDIT: and now a Duet 08/085 build too.
Hello everyone
David I made an impression of 2h in 1.19 + 6, and apparently more problem of vibration in me.
On the other hand I still had a disconnection of the card on the web, I try on 2 computers, and impossible to reconnect.
I do not know if this comes from my network or update.
thank you for your work -
Thank for your message. Please clarify:
1. Is vibration still a problem for you, or not?
2. If vibration is still a problem, does it occur at any particular place in the print? For example, when printing the skirt of a print that was sliced using Simplify3D.
Regarding the network disconnection:
1. Did you install version 1.19+1 of the wifi module firmware (DuetWiFiServer.bin)? The Settings/General page of Duet Web Control will tell you which version of the WiFi Server you are running.
2. If yes, then any reconnection attempts made will be reported to PanelDue if you have one (check the Console page) and to USB.
1> I no longer have any vibration.
 Network
1> Yes I'm fine with WiFi Server Version: 1.19 + 1
2> I would look next time that this product and I would tell you. -
apparently 1.19+6 ok for me no vibrate on my Scara, Thanks
I feel that the speed is faster ? -
Thanks, both of you. I'll relabel 1.19+6 as 1.19.2 and release it later this afternoon.
