    Large Format Dowell to Duet conversion
    362
    35.8k
    • Charles Fraserundefined
      Charles Fraser @jay_s_uk
      @jay_s_uk Hi there. Who is this sorry?
      I am trying to connect to just the mainboard and nothing. I am trying in standalone mode, but I can't find the instructions for how to connect to the board through the local host IT IS NOT PROVIDED IN THE INSTRUCTIONS like so many other things.
      Please, whoever you are, please help me get this thing working with a set of instructions that describe each step that needs to be taken. May thanks
        jay_s_uk @Charles Fraser
        @charles-fraser I don't work for duet3d or anything, just an end user.
        You can follow these instructions
        They will get you started in standalone mode.
        But as I say, you don't actually need a config (or even an SD card) on the board to check what firmware you have installed.
        It's pretty crucial that for SBC mode that the firmware and DSF are the same version.
        But if we start with the basics, check the firmware version of the board and we can go from there.
        Charles Fraserundefined 1 Reply Last reply Reply Quote 0
          @jay_s_uk thanks! What's the DSF?
            @charles-fraser DSF = DuetSoftwareFrame - i.e. the software running on the Pi
              Charles Fraser
              @jay_s_uk the link you provided does not work
                @charles-fraser updated it. Didn't see the ) in the address and screwed it up
                  @jay_s_uk thanks I am trying to find the board using serial tools on my macbookpro m1 - it doesnt see the board which is now powered by that mini usb connector through the usb dongle (Macbook Pros only have usb c ports so need a dongle)
                    @charles-fraser hmm, i don't use a mac so I can't really help you with that one.
                    Are you using the USB cable that came with the board?
                    Charles Fraserundefined 2 Replies Last reply Reply Quote 0
                      there was no usb cable that came with this board. This is the duet 3
                        @charles-fraser
                        ok, I thought they supplied them with USB cables.
                        I suggest trying a different micro USB cable. Not all of them send data.
                          @jay_s_uk there was no USB cable with this board this is the deut 3
                          How do I connect to the board using the ethernet to my router. I found something about localhost.duet or something but the layout of the wiki is so anti intuitive and litterally does not branch there from the getting started menu. I cant find it in google I can't find it looking through the site for f'ing hours!
                            @jay_s_uk How do I reset this board back to factory settings????
                              @jay_s_uk I've tried three cables, none work
                                @charles-fraser you'd need to make sure your sd card had the correct SD card structure following what's listed here https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
                                ultimately you'll need a sys folder containing a populated config.g (which you can get from the config tool) and the www folder which you might as well use the 3.3.0 version of DWC from here
                                @charles-fraser said in Large Format Dowell to Duet conversion:
                                there is no factory reset as none of your config is stored on the board. its all loaded from the SD card on boot
                                  @jay_s_uk I have a propper config file from the config tool
                                  I copied and pasted all the instructions as shown there and added the gcode file and the other one it said. The /www /sys and /firmware folders are copied and pasted onto the SD directly without the parent /config file
                                    @jay_s_uk
                                    the SBC can not connect to the duet
                                    the laptop does not connect to the duet
                                    do you know how to send it commands over an through the ethernet connected through my modem please?
                                      @charles-fraser find out the IP address from your router and navigate to that, assuming you have M552 S1 in your config.g
                                        @jay_s_uk
                                        my router can not see the Duet
                                        Neither can the apple
                                        Neither can the SBC
                                        I will try to edit the boot file as it says:
                                        Create a new file named “wpa_supplicant.conf” (exact naming is critical, do not have a ".txt" at the end of the file).
                                        In a text editor add the following:
                                        country=GB
                                        update_config=1
                                        ctrl_interface=/var/run/wpa_supplicant
                                        network={
                                        ssid="SSID_OF_NETWORK"
                                        psk="PASSWORD_OF_NETWORK"
                                          jay_s_uk
                                          @charles-fraser I thought you were setting this up standalone? Chucking the SBC into the mix when you can't get it to work standalone won't help.
                                          Post a screenshot of the SD card structure.
                                          Also post the contents of your config.g
                                            @jay_s_uk
                                            I'm just making a point by referencing all the devices that can not connect to the Duet
                                            Here is a screen shot of my boot drive file config:
                                            (NB connecting over wifi doesnt work either)
                                            Here is the config folder:
                                            config.g
