Large Format Dowell to Duet conversion
362
35.2k
    jay_s_uk @Charles Fraser
    @charles-fraser find out the IP address from your router and navigate to that, assuming you have M552 S1 in your config.g
    undefined 1 Reply Last reply 26 Sept 2021, 20:07 Reply Quote 0
      Charles Fraser @jay_s_uk
      @jay_s_uk
      my router can not see the Duet
      Neither can the apple
      Neither can the SBC
      I will try to edit the boot file as it says:
      Create a new file named “wpa_supplicant.conf” (exact naming is critical, do not have a ".txt" at the end of the file).
      In a text editor add the following:
      country=GB
      update_config=1
      ctrl_interface=/var/run/wpa_supplicant
      network={
      ssid="SSID_OF_NETWORK"
      psk="PASSWORD_OF_NETWORK"
        jay_s_uk
        @charles-fraser I thought you were setting this up standalone? Chucking the SBC into the mix when you can't get it to work standalone won't help.
        Post a screenshot of the SD card structure.
        Also post the contents of your config.g
        undefined 1 Reply Last reply 26 Sept 2021, 20:15 Reply Quote 0
          @jay_s_uk
          I'm just making a point by referencing all the devices that can not connect to the Duet
          Here is a screen shot of my boot drive file config:
          (NB connecting over wifi doesnt work either)
          Here is the config folder:
          config.g
          undefined 1 Reply Last reply 26 Sept 2021, 20:18 Reply Quote 0
            @charles-fraser is that boot partition the only partition on the SD card? And is that partition fat32?
            When the board is powered and the ethernet cable is plugged in, do the lights on the ethernet socket flash?
            undefined 2 Replies Last reply 26 Sept 2021, 20:20 Reply Quote 0
              @jay_s_uk yes that is the only partition on the SD. Yes fat32. No lights come on when Ether cable plugged into Duet 3. They do come on when plugged into Pi.
                @jay_s_uk Is there a table somewhere that explains what a dim orange status light means? This all went wrong when following the instructions for adding the expansion board firmware to the /sys folder.
                undefined 1 Reply Last reply 26 Sept 2021, 20:28 Reply Quote 0
                  @charles-fraser when powered up from 12/24v only can you take a photo of the lights on the duet 3 please
                  undefined 3 Replies Last reply 26 Sept 2021, 20:30 Reply Quote 0
                        @jay_s_uk do you know what these mean? Please could you provide a link to where one can find what they mean. I can find no such information
                        undefined 1 Reply Last reply 26 Sept 2021, 20:40 Reply Quote 0
                          @charles-fraser they're shown on here. All of those look normal I think
                          https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
                          undefined 1 Reply Last reply 26 Sept 2021, 20:44 Reply Quote 0
                            @jay_s_uk thank you, the diag light is not flashing as it was before which indicates things are working propperly. Now it remains dim orange. This indicates therefore that things are not working propperly. Hopefully someone from Duet @dc42 @Phaedrux @chrishamm can respond in the morning when work starts
                            undefined undefined 2 Replies Last reply 26 Sept 2021, 20:46 Reply Quote 0
                              @charles-fraser the diag light should flash every second or so.
                              You could try reinstalling the firmware using bossa https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_All_other_Duet_boards
                                dc42 administrators @Charles Fraser
                                @charles-fraser said in Large Format Dowell to Duet conversion:
                                That usually means you have erased the firmware on the board. It will need to be reinstallled using USB and Bossa.
                                undefined 3 Replies Last reply 26 Sept 2021, 21:03 Reply Quote 0
                                  Charles Fraser @dc42
                                  This post is deleted!
                                    @dc42 thanks what does ‘ Jumpering the erase jumper’ mean?
                                    undefined 1 Reply Last reply 26 Sept 2021, 21:14 Reply Quote 0
                                      @charles-fraser just a Physical jumper on the 2 pins that say erase
                                        @jay_s_uk so how to I jump the jumper? With crocodile clips>?? just connect the two pins then power it up and the firmware will erase?
                                        undefined 1 Reply Last reply 26 Sept 2021, 21:15 Reply Quote 0
                                          @dc42 hi DC 42 can you please read up this thread and explain why the board has crashes and erased firmware when I was following instructions to update firmware of the expansion board?
                                          Can you also please explain why the firmware of the expansion board was not automatically updated when I uploading the zipped config file from the firmware configurator that set the expansion board up and the firmware version?
                                          74 out of 362
