    3.4.0 b3 leaning prints
    Beta Firmware
    9
    43
    2.4k
      dc42 administrators @Adrian52
      Thanks to everyone who has helped us to try to track this down. @chrishamm has managed to reduce one of your leaning prints to a pair of 2 moves that leaves one of the carriages 2 microsteps away from the correct position. I expect to be able to track down the problem now.
      dc42undefined 1 Reply Last reply Reply Quote 5
        dc42 administrators @dc42
        @Adrian52 @CabalSoul @DaveA @Fred-Y @jay_s_uk @SIam I have put new firmware builds with a fix for the issue I was eventually able to reproduce at https://www.dropbox.com/sh/kgah0ylh2zu2f7w/AAD2vQOiTQrFly1p22sob6c7a?dl=0. As with all unofficial builds, use them with care.
        CabalSoulundefined jay_s_ukundefined DaveAundefined Fred-Yundefined 4 Replies Last reply Reply Quote 0
        • CabalSoulundefined
          CabalSoul @dc42
          @dc42 thank you exactly what I needed. I am going to test right away.
          I've tested it and it seems to work. Thanks again.
          Anycubic Predator, Orbiter Extruder , Duet Wifi, Mosquito Hotend, Remote Extruder Stepper cooling and Part cooling
            jay_s_uk @dc42
            @dc42 one print completed so far and no leaning!
            What was it in the end?
            Blacksheep99undefined dc42undefined 2 Replies Last reply Reply Quote 0
            • Blacksheep99undefined
              Blacksheep99 @jay_s_uk
              @jay_s_uk said in 3.4.0 b3 leaning prints:
              It was the Pisa effect apparently…….
                dc42 administrators @jay_s_uk
                The new code didn't fully allow for the case of a move ending when a tower that had been moving up was on the point of reversing and moving down, but the required final position was one microstep higher than the theoretical highest point reached, because the stepper motor position had been rounded up to the next microstep to get closer to the commanded position for the end or the move.
                jay_s_ukundefined 1 Reply Last reply Reply Quote 2
                  jay_s_uk @dc42
                  @dc42 thank you!
                  • DaveAundefined
                    DaveA @dc42
                    @dc42 Thanks for the fix. I tested with two of my leaning files and they now print correctly.
                    • Fred-Yundefined
                      Fred-Y @dc42
                      @dc42 I just finished to print my test file and it looks good 👍
                      I have another print to to today, hopefully it will be good as well.
                        dc42 administrators @Fred-Y
                        All, we have identified that the leaning issue on deltas was not completely fixed by that internal build because there was another less common situation in which a step was taken in the wrong direction. I am currently testing a fix for that.
                        • Fred-Yundefined Fred-Y referenced this topic
