Can't get bed to stay @ 110 and having both bed and hotend faults
In the US I use a 110 volt heated bed and pull the power from the same feed to my 24 volt power supply. If you have access to 220 volt then you would use that.
Ok. So 110 (In the US also) can come directly from the wall to power the bed.
Basically instead of the PSU to the SSR just splice the wall feed that goes to the PSU?
If that is the case then I will need an AC/DC SSR instead of DC/DC correct?
Yes.
Are you using a dc-dc ssr now? Some these have really big inefficiency (does the ssr get hot?), try running the bed directly off the duet instead of using an ssr, it can handle these sort of currents.
You need one for mains bed as there is no mains voltage switching capability on the duet. AC dc ssrs are quite efficient so don't get that hot.
Yes, DC - DC right now. Not hot at all (currently printing @ 50c though).
I will try going directly to the bed from duet and see what results that has.
So to talk it through. The SSR basically takes a DC current input, once it goes active it trips the power straight from the PSU which is 24v. The Duet can handle 24v so the inefficiency of the SSR could be slowing the heating process?
This is a DBOT and I used the BOM from that, I would make the assumption that because they used RAMPS that the SSR was required?
If your DC-DC SSR is a SSR-40DD or similar, it will be dropping about 1.5V-2.0V and will get very hot when the bed heater is running at full power, unless you have a huge heatsink on it, and will reduce the power getting to the bed heater significantly. If the SSR is the Auber Instruments one that we recommend in the wiki, it will run cool and it won't cause a significant reduction in bed heater power.
The duet (wifi/ethernet) should be able to handle 18amps (12-24v) for the bed heater, if your bed heater has 4.5ohms resistance then at 24v it will draw 5.3amps so you're well within that limit.
I'd only use accessory DC switching devices (SSR, or better for DC an external Mosfet board) if you are close to or over the 18A for the bed, or if you want to use a second PSU (to essentially isolate the two PSU's).
With AC mains/line you have to use an SSR (or mechanical relay but this isn't the ideal option).
It still isn't going to perform spectacularly as its still only putting 128watts into 600cm2 which is 0.21w/cm2 so around about half the power that is recommended for reasonably quick heating and good maintenance of temperature, but if you're losing power through the SSR this is going to be lower still.
That all makes sense. Good information to work with.
@dc42 I got the original SSR that you recommended.
To run the 110v from the wall, would this be suitable? https://www.amazon.com/Solid-24-380V-SSR-25D-Output-Shipping/dp/B0749M5FFW/ref=sr_1_4?ie=UTF8&qid=1504218857&sr=8-4&keywords=SSR++ac+110v+dc
Yes SSR-25DA is suitable for controlling an AC mains voltage bed heater.
That works on the duet?
