    DWC Custom Configuration
    Duet Web Control
    13
    42
    3.7k
    • theKMundefined
      theKM @theKM
      @thekm
      After poking the source code, my guess above was already pretty darn close to how it already is. The root of the routing code...
      export const Menu = Vue.observable({
      	Control: {
      		icon: 'mdi-tune',
      		caption: 'menu.control.caption',
      		pages: []
      	Job: {
      		icon: 'mdi-printer',
      		caption: 'menu.job.caption',
      		pages: []
      	Files: {
      		icon: 'mdi-sd',
      		caption: 'menu.files.caption',
      		pages: []
      	Plugins: {
      		icon: 'mdi-puzzle',
      		caption: 'menu.plugins.caption',
      		pages: []
      	Settings: {
      		icon: 'mdi-wrench',
      		caption: 'menu.settings.caption',
      		pages: []
      ...with a component self-registering into the menu and the route with...
      		registerRoute(this, {
      			Control: {
      				Dashboard: {
      					icon: 'mdi-view-dashboard',
      					caption: 'menu.control.dashboard',
      					path: '/'
      ...just externalise this configuration. I can't think of any reason why this couldn't/shouldn't be done.
      If people can have control of the menu, they could promote a plugin to take the place of the dashboard, and then they are, for all intents and purposes, in control of just about everything in the interface.
      MintyTreborundefined 1 Reply Last reply Reply Quote 0
      • MintyTreborundefined
        MintyTrebor @theKM
        Chipping in as we seem to have a number of plugin devs on this thread, and to possibly help the OP query.
        @Dr_Ju_Ju The DWC top section can be hidden (as mentioned in an earlier post) if you happen to running on mobile. A button appears to show hide the section. I have looked at the code and it only requires the DWC dev @chrishamm to change 2 lines of code to enable that button for all screen sizes. I see no functional reason why this change cannot be requested to be included in the next release if @chrishamm agrees. Hopefully this would help alleviate some of your frustration.
        From a plugin dev perspective I personally would like the change to go one step further and make the show/hide button function addressable through the JS Dom (it may already be, I just haven't tried yet). This way plugin dev's can use/offer the option to show hide the top section in their UI if required. This seems like a low impact way of making this feature more useful, without compromising existing functionality.
        Going forward if this change were to be made, I would expand BtnCmd to include more DWC info/control panels (I only offer a small selection currently) enabling a user to effectively pick and choose the panels they want on screen, which would go some way to meeting the demand for more customisation options.
        I can see this being helpful for other plugins where more screen real estate would be desirable - heightmap - gcode viewer etc....
        Thoughts?
        Given the amount of interest this post has generated I would be interested to hear @chrishamm thoughts on these proposals / discussion.
        Update: For the plugin devs
        window.document.getElementById("global-container").hidden = true;
        does already work to show/hide top section - (I had to have a go😊 )
        NodeDSF - Native Node-Red integration with Duet boards.
        BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
        ReleaseMgr - Duet update info inside DWC.
        Repo
        chimaeraghundefined 1 Reply Last reply Reply Quote 3
        • chimaeraghundefined
          chimaeragh @MintyTrebor
          @mintytrebor It would be nice if the web control was more modular and you could pick which modules to enable. I had to use your plugin to create a custom simpler interface because the default is too much for my needs. But the unecessary parts still load and take away from the user experience 243201782_10225569456919073_6443297781810908160_n.jpg 243169285_10225569456399060_6148114605962503494_n.jpg
          Duet 2 Wifi, Ooznest Workbee CNC 1510
          gloomyandyundefined 1 Reply Last reply Reply Quote 0
          • gloomyandyundefined
            gloomyandy @chimaeragh
            @chimaeragh I've not used the button plugin, but perhaps it would help the developers of both that and the main part of DWC if you could explain a little more as to what parts of your current setup you find unnecessary and how they take away from the user experience?
            theKMundefined chimaeraghundefined 2 Replies Last reply Reply Quote 0
            • theKMundefined
              theKM @gloomyandy
              @gloomyandy ...I've never once been on the filaments screen, even when using my 3d printer. My CNC doesn't even know what a filament is but that screen is still there. Similarly I've never used the macro screen as I set up macros and such to launch off buttons from my own button plugin, which also takes over from the Dashboard... three whole screens I'd like to have removed from the menu.
                chimaeragh @gloomyandy
                @gloomyandy Other than Files --> Jobs, the above screenshots are the only interface elements I would usually need to control my Duet from my phone. The other parts of Web Control still load and add to memory usage causing some lag. Also this plugin interface is not the default when I open DWC, I still have to find the plugin in the side panel and open it from there. Then I have to click the icon to hide the rest of the interface.
                When a job starts the interface automatically switches to Job Status which is not really optimised for my use case. I prefer the first screenshot as I only need to pause or see the time remaining when I start a job on my CNC. Speed factor and baby stepping can be handled by the BtnCmd plugin but I don't need Layer Height, Filament, Extruder etc when running a job. It makes finding the information you need more difficult. I would propose hiding unpopulated labels from showing in DWC. That should give a cleaner interface.
                • oozeBotundefined
                  oozeBot @Dr_Ju_Ju
                  @dr_ju_ju said in DWC Custom Configuration:
                  Is there any way to easily customise the DWC pages, without reverting to additional HTTP pages etc ??
                  I especially want to get rid of the ridiculous/superfluous three boxes at the top of every screen, two which are effectively displaying the same information !!
                  Our thought was to modify it like the side menu with a button that toggles its visibility, but we haven't got around to messing with it yet.
                  theKMundefined 1 Reply Last reply Reply Quote 0
                  • theKMundefined
                    theKM
                    I have my menu driving by configuration now; can place and configure where the default pages sit (and omit if not desired; macros and filaments pages removed below), place plugins into specific order (my "move it move it" is a plugin)... I just need to get it loading out of the vuex settings loader and backwards compatability for plugin registration so they can keep working as-is...
                    • theKMundefined
                      theKM @oozeBot
                      @oozebot ...there's already a button in the top right that does it, but for some reason is set to hide on large screens.
                      oozeBotundefined 1 Reply Last reply Reply Quote 0
                      • oozeBotundefined
                        oozeBot @theKM
                        @thekm I was referring to adding a second button (like the one that exists for the menu) to hide/show the Status, Tools, and Temp Chart..
                        • theKMundefined
                          theKM @oozeBot
                          @oozebot ...it just sounds like this green button is exactly what you're describing... because it toggles the Status component, etc (the same way that the menu button works)...
                          I was thinking the same thing, until I was messing with the UI yesterday, resized to smaller browser to test responsiveness of something and there it was.
                          • oozeBotundefined
                            oozeBot @theKM
                            @thekm hmm - never noticed that! Unfortunately, that's only visible when the window is quite small.. and it looks like it reverts when the window is resized. I'll mess with it in code when I have a chance.
                            Thanks for pointing it out!
                            • theKMundefined
                              theKM @oozeBot
                              @oozebot ...three line change to have it stay put all the time; in App.vue, remove "hidden-md-and-up" from the button, and "|| $vuetify.breakpoint.mdAndUp" from the panel container and divider.
                              • theKMundefined
                                theKM
                                Messing with menu config after work...
                                • config comes from and stored in 'dwc-settings.json' along with everything else
                                • default works as-is, nobody will know anything is different until they tweak the config of it themselves
                                • complete control over the menu; change the order of it, flatten it (remove the groupings), add buttons that run gcode including adding them to submenus, create submenus, change the icons and colours (yup, can have a menu of macros that run directly from the menu, because why not!? )
                                • internally the system pages are tweaked how they register in to the menu, but no-change for existing plugins to be able to plonk them somewhere specific by configuration.
                                Good fun. 🙂
                                • chimaeraghundefined chimaeragh referenced this topic
