Large Format Dowell to Duet conversion
@t3p3tony it's flashing four times, then two times, then one quick flash. Sirial tools crashed too.
I started SirialTools up again and it says:
@charles-fraser ok. lets take a step back. With nothing other than CAN and power connected to the 3HC what flashing do you get after a power cycle?
@t3p3tony I power cycled again and turned off USB power too. Now both 3HC + 6HC diag lights flashing in time again.
How long should I wait for the 3HC firmware to update? Will it say okay after that or does it take a min?
@charles-fraser
ok set all the dip switches to off (currently switch 1 is set to on). Then power cycle. You should see the LED flash rapidly as firmware is loaded. once the LED reverts back to flashing in sync (after 20 seconds or so) then set the switch back to 1 on, rest off, then power cycle.Updated as our posts crossed.
@charles-fraser oh it says v 3.3 on the 3HC too now! Okay phew! I will try reconnecting bits to see what's shorting the board. Thank you!
@t3p3tony Oh it's the 3D touch shorting it out! I will disconnect all of that. It's a bit of a complicated wiring with that.
@charles-fraser ok glad that you found what it was.
Next step is to get back to SBC mode and see if you can connect to the Duet in DWC from the browser on the pi.
@t3p3tony Aibo - easy peasy hehe
I replaced the thermocouple on the heat block with a thermistor because the thermocouple runs along the motor wires and is not sheilded down there.
Could you guess what could be shorting out the whole board on the 3D touch that would cause the heat cartridge heating to run off out of control please?
@T3P3Tony slight problem is I only have one SD card. Can I remove the SD from the 6HC and reflash it with the Duet Pi image and then just control from the Pi?)
@charles-fraser yes. If its the one that came with the 6HC it probably has dual partitions and may not need reflashing.
edited to add: make a copy of your /sys/ directory if you have edited stuff to not loose the edits.
@t3p3tony okay I have the Pi connected and updated the system files from an exact copy of the ones I had running on the board before but just uploaded to the Pi through USB
Here are my errors. Amazed how neither the thermistor nor the thermocouple (for the bed) are working.
@charles-fraser ok please post the contents of your config.g as you are using it now here (using the </> menu option to get it to format nicely)
@t3p3tony no wait the SBC is not connecting to the Duet. It says connected but when I run a command like M115 it just keeps loading and loading and gets stuck there
remove the M550, M552 commands from config.g
M558 should be set to type 9 (P9 in the M558 command)
Edit - Ahh sorry I see that.
Can you access the "system" page and edit config.g if so try making those changes. -
This post is deleted! -
Right so I unzipped the config file on the duet on my mac now and when I try to edit the config.g file I cant because it says it's locked; so I copied and pasted the contents of that file into a new text dog with the changes you specified (I think)
; Configuration file for Duet 3 (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.3 on Fri Oct 01 2021 16:59:54 GMT+0100 (British Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves ; Wait a moment for the CAN expansion boards to start G4 S2 ; Network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M569 P0.4 S1 ; physical drive 0.4 goes forwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M569 P1.0 S1 ; physical drive 1.0 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3:0.4:0.5:1.0 ; set drive mapping M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00:420.00:420.00:420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2) M906 X3000 Y3000 Z800 E800:800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X1200 Y2000 Z1600 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M558 P9 C"^1.io1.in" H100 F120 T6000 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"spi.cs1" Y"thermocouple-max31855" ; configure sensor 0 as thermocouple via CS pin spi.cs1 M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp0" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp0 M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 300C ; Fans M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"out9" Q500 ; create fan 1 on pin out9 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off ; Tools M563 P0 S"lily" D0 H1 F0:1 ; define tool 0 G10 P0 X100 Y100 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined -
@charles-fraser, how come it was zipped in the first place? did you download the whole sys directory? what happens if you (in DWC) go to the "system" page in the menu, then click on config.g (if its visible).
@t3p3tony oh I see that’s where I should edit the .sys file. I was unzipping the config.zip editing the file then zipping it again. This way I could keep a copy of all edits I make on my computer incase it all freezes up again. All changes to config.g should be made inside DWC ?
@t3p3tony okay so I made those changes to the config.g file inside DWC and nothing. I still can’t run commands on the console it just gets stuck and spins around and around and around loading. I have to close the chromium browser and open a new DWC to get rid of that. NB: it says it’s connected to the duet even if there is no power going to the Duet!
