    Sensor not showing on DWC
    747
    • Tinchusundefined
      Tinchus @Tinchus
      @tinchus ANother thing I noticed: when resetting the DWC, for a brief period of time the sensors are showed, but then they are not. DWC is filtering somehow/somewhy showing these sensor on the interface?
        T3P3Tony administrators @Tinchus
        @tinchus I don't think those M143 commands are correct, there is no "T" parameter for M143
        https://duet3d.dozuki.com/Wiki/M143
        Edited: I did not read the documentation properly 🤦
        The T command is valid.
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @T3P3Tony
          @t3p3tony Yes there is, for reprap 3 and later you have the T
            @tinchus thanks I have edited my post as I missed that!
            So I think those T parameters are redundant as they are the same as the default, but they should do no harm being there.
            I will have to ask @chrishamm if a sensor will show up in the "extra" tab if it is assigned to a heater. Then It should show up in the "heaters" tab instead. That said there is a complication because these heaters are not assigned to a Bed, Chamber or Tool so may not be showing up at all.
            What is the purpose of these resistors? chamber heaters? if so then maybe you need to set them up using M141 as well.
            • Tinchusundefined
              Tinchus @T3P3Tony
              @t3p3tony Thr purpose of these "heaters: is to have a security control over the max temperature the chambers resisters can reach. O created these heaters, connected their outputs to reles, and in this way I wanted to be able to monitor and control those heaters. Both reles are also conected to the "main" heater assigned to the chambers, so basically I can turn on the chamber, the main rele activated giving power to the secondary reles, but if any of them reaches the max temperature, I can turnoff each one of them individually.
                @tinchus ahh I see.
                In that case I think you use M143 with a secondary temperature sensor for the main chamber heater definitions, not for new heaters.
                • Tinchusundefined
                  Tinchus @T3P3Tony
                  @t3p3tony Sorry, I dont understan the answer, what Im doing wrong?
                    @Tinchus
                    The confusion for me is you have 1 chamber heater configured on out7
                    From the comment your chamber heater is H0
                    M141 H0 ; map chamber to heater 0
                    So
                    I think you need to map the temperature sensor to that one:
                    M143 H0 P1 S100 T5 A2
                    later you have said that H5 and H6 are chamber heaters on out8 and out5.
                    How is everything wired?
                    • Tinchusundefined
                      Tinchus @T3P3Tony
                      @t3p3tony H0 is the heater defined for the chamber. So I have a rele conected to yhe output of this heater, and a sensor or it. This is how I send energy to the rele and so to the resistors (2 of them).
                      Through this main rele, I send energy to another 2 reles. And each of these reles give energy to each one of the 2 ressitors.
                      Then I defined heaters 5 and 6, with sensors 3 and 4. Heater 5 is wired to out 8 and heater 6 to out5.
                      My intention was: in this way I can turn on the chamber, default state of out8 and out5 is ON (notice the !) so those 2 reles are always sending energy, but the energy is really sent only when the main rele is ON. BUT monitoring sensor 3 nad 4, I shoudl be capable of turn off or on heater 5 or 6 if any of them reaches a dangerous temperature. Im measuring the resistors themperute there NOT the chamber temperature.
                      Makes sense?
                        @tinchus it does make sense, but I am not sure M143 will work to control a heater that is not associated with any heating task (i.e. its not a tool, a bed or a chamber) @dc42 would need to say if it is supported.
                        As a test why not create two more chamber heaters using M141 for those secondary "heaters" and then see if M143 works as expected for them.
                        • Tinchusundefined
                          Tinchus @T3P3Tony
                          @t3p3tony Im trying to to do this following your advice and create 2 heaters for the chamber. I did this but it is not working, looks like the chamber definition only accepts 1 heater? Am I doing something wrong?:
                          M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"chamber" ; configuro sensor 0 en pin temp0
                          M950 H0 C"out7" T0 ; create bed heater output on out0 and map it to sensor 0
                          M307 H0 R0.31 C284.700:284.700 D30 S1.00 V0 B0 ; enable PID mode for the chamber heater and set PWM limit
                          M308 S3 P"spi.cs0"Y"thermocouple-max31856" K"K" A"chamber_resistorR"
                          M308 S4 P"spi.cs1"Y"thermocouple-max31856" K"K" A"chamber_resistorL"
                          M950 H3 C"out8" T0 ;T3
                          M141 H0 H3
                          M143 H0 P0 S240
                          M143 H0 T3 S150 A2
                          M143 H3 T4 S150 A2
                            @tinchus
                            I meant leave this part of your original config as it was:
                            M307 H0 R0.2 C284.700:284.700 D30 S1.00 V0 B0 ; enable PID mode for the chamber heater and set PWM limit
                            M143 H0 P0 S240 ; set temperature limit for heater 0 to 240C
                            but add the two additional chamber heaters for the two resistors
                            ;main resistors security control
                            M308 S3 P"spi.cs0"Y"thermocouple-max31856" K"J" A"chamber_resistorR"
                            M950 H5 C"!out8" T3
                            M141 H5 ; map chamber heater safety control R to heater 5
                            M143 H5 T3 S100 A2
                            M308 S4 P"spi.cs1"Y"thermocouple-max31856" K"J" A"chamber_resistorL"
                            M950 H6 C"!out5" T4
                            M141 H6 ; map chamber heater safety control L to heater 6
                            M143 H6 T4 S100 A2
                            • Tinchusundefined
                              Tinchus @T3P3Tony
                              @t3p3tony ok, im still fighting this issue.
                              I went to a more simple configuration because with the one I wanted above, I never got to the point of making all the outputs work.
                              I have now 2 reles, connected in 2 independent outputs and this is the config:
                              M307 H0 R0.31 C284.700:284.700 D30 S1.00 V0 B0 ; PID heater chamber 2
                              M141 P0 H0
                              M141 P1 H3
                              M143 H0 P0 S240
                              M143 H0 T3 S350 A2
                              M143 H3 T4 S350 A2
                              M143 H3 P1 S240
                              My problem is weird: I excute in my gcode:
                              M141 H3 S150 <<<< then heater 3 turns ok, OK so far
                              M141 H0 S150 <<<< heater 0 turns on, BUT H3 turns off
                              Why is doing this?
                                @tinchus M141 has two parts to it:
                                https://duet3d.dozuki.com/Wiki/M141
                                1. Setup a chamber heater
                                2. Control a chamber heater
                                To setup a chamber heater:
                                M141 P0 H0 ; configure chamber heater 0 to use heater 0
                                M141 P1 H3 ; configure chamber heater 1 to use heater 3
                                To use a chamber heater:
                                M141 P0 S150 ; set chamber heater 0 to 150C
                                M141 P1 S150 ; set chamber heater 1 to 150C
                                I think the issue here is you are using configuration commands "H" in control. This may not be the only issue but its certainly not going to help!
                                Also I think your M143 commands are not quite as excepted, If I understand correctly the idea is you have two heater protection instances, one using the chamber temperature and another using the heater temperature.
                                A heater can have multiple (up to 3 normally) protection instances:
                                M143 H0 P0 S240 ;Heater 0 monitor 0 uses sensor 0 to generate a heater fault if the reading exceeds 240.0°C
                                M143 H0 P1 T3 S350 A2 ;Heater 0 monitor 1 uses sensor 3 to temporarily switch off if the reading exceeds 350.0°C
                                M143 H3 P0 S240 ;Heater 3 monitor 0 uses sensor 0 to generate a heater fault if the reading exceeds 240.0°C
                                M143 H3 P1 T3 S350 A2 ;Heater 3 monitor 1 uses sensor 4 to temporarily switch off if the reading exceeds 350.0°C
                                So in your command for H0 you only have 1 protection instance as P0 is the default and you do not specify a protection instance here: M143 H0 T3 S350 A2
                                Tinchusundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                • Tinchusundefined
                                  Tinchus @T3P3Tony
                                  This post is deleted!
                                    T3P3Tony administrators @T3P3Tony
                                    @Tinchus I just saw your other thread where you say:
                                    But I tried to start printing today and I found this issue: so far I was using the DWC, on the screen I choosed the desired temperature. Due to restrictions or maybe my lack of knowledge on reprapfirmware, my config created on the screen 2 chambers, so on the screen I have to set up the chamber temperature on both of them. No a problem for me. And this is working ok. I set up the temperature on them and both resistors turn on.
                                    Now I moved into printing. I set up my start gcode using M141 P0 S80 and M141 P1 S80 in order to turn on both chamber heaters.
                                    To my surprise this gcode is not working : M141 P0 S80 turns on 1 heater, but them M141 P1 S80 turns on the other heater but turns off the first one. And so on: every time I execute a gocode to turn on 1 heater the other one is turned off.
                                    Lets keep the discussion here so its easier to follow later
                                    Ok so this has progressed to the point where the two chamber heaters work when controlled with DWC, but not in a print file?
                                    I have replicated part of your system as best I can (I dont have a chamber with two heaters so have to work around this) and If I send:
                                    M141 P0 S150
                                    M141 P1 S150
                                    from the console, both heaters stay on (at least until the heater faults i get beacuse this is not a proper chamber heater just a replication).
                                    Can you try sending the commands form the console and see the results.
                                    If the first heater turns off then are any errors reported in the console? Also what is the state of the heater in DWC?
