    Rotating Magnetic Sensor - Keeps Pausing Printer
    Filament Monitor
    9
    151
    9.7k
    • charlesmcundefined
      charlesmc
      I had a successful 13 hour print yesterday. I kicked off a new 9 hour print and the printer kept pausing due to "too little movement on extruder".
      This seems to be in line with alankilian's comment above that he had to disable his because he couldn't stop false positives.
      Note that there was a pause generated by the filament sensor just before the 6:31AM M591 D0 call.
      Any suggestions on how to correct this?
      I'd like the magnetic filament sensor to just say...I've stopped rotating completely...must be out of filament so put the system into pause.
      Is the sensor not taking into account retraction and rewards movement of the filament?
      • wouldstainundefined
        wouldstain
        Having same problem.
        Data point: I'm experiencing this much more frequently with PLA than with PETG.
        With PLA it generally occurs multiple times in a single print, with PETG, maybe once or twice.
        Sensor settings:
        M591 P3 C"e0_stop" S1 D0 L26.5 R50:130
        Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 50% to 130%, check every 3.0mm, version 3, mag 132 agc 76, measured sensitivity 26.16mm/rev, min 93% max 106% over 4061.3mm
          T3P3Tony administrators @wouldstain
          @wouldstain please send a M591 D0 after the pause.
          @charlesmc the sensor does take into account retraction. It looks like the pause was generated because your minimum dropped to 17% (which is below the minimum you have set). The question is why its below the minimum. It could be because there are lots of short movements and retractions in the print, it could be because your extruder is slipping slightly (maybe on very fast moves (i.e. the sensor is doing its job) or something i have not thought of. It would be helpful to have as short a bit of gcode as possible that recreates this drop to 17% or as close to 17% as possible.
          wouldstainundefined A Former User? kroybalundefined 3 Replies Last reply Reply Quote 0
            wouldstain @T3P3Tony
            @t3p3tony
            First PLA print in a few days. It's a fairly short one but it only paused 2x.
            Pauses below are from the same print.
            First Pause
            Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 50% to 130%, check every 3.0mm, version 3, mag 130 agc 75, measured sensitivity 25.63mm/rev, min 32% max 105% over 2072.3mm
            Second Pause:
            Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 50% to 130%, check every 3.0mm, version 3, mag 129 agc 75, measured sensitivity 26.07mm/rev, min 28% max 107% over 178.4mm
              @wouldstain so a window of 20% to 130% looks like it work be a good start for your settings.
              wouldstainundefined 2 Replies Last reply Reply Quote 0
                @t3p3tony Adjusted it this morning as suggested.
                Print paused at 6%:
                M591 D0
                Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 20% to 130%, check every 3.0mm, version 3, mag 130 agc 75, measured sensitivity 25.55mm/rev, min 5% max 104% over 769.7mm
                wouldstainundefined 1 Reply Last reply Reply Quote 0
                  wouldstain @wouldstain
                  @T3P3Tony
                  Again at 60%:
                  M591 D0
                  Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 20% to 130%, check every 3.0mm, version 3, mag 130 agc 75, measured sensitivity 25.59mm/rev, min -9% max 109% over 2162.1mm
                    @t3p3tony
                    ... and one more time tonight on a different print job:
                    Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 20% to 130%, check every 3.0mm, version 3, mag 130 agc 75, measured sensitivity 26.27mm/rev, min 96% max 135% over 6625.2mm
                      A Former User @T3P3Tony
                      @t3p3tony said in Rotating Magnetic Sensor - Keeps Pausing Printer:
                      I have the same issue, EVERY print I lunch, ALWAYS in the first layer after made the initial perimeters and after 3 lines of the bottom infill the sensor pauses the print because the minum drop to 14%..this happens ALWAYS at the first layer after have printed the perimeters...later on the print the sensor seems to work
                      This is an example GCODE:Very Fast Test Print__PETG Amazon Basic_0.2000mm.gcode
                      Let me know
                        @wouldstain said in Rotating Magnetic Sensor - Keeps Pausing Printer:
                        can you send me the print file that causes this. also please post a pic of how you have the MFM attached to the extruder
                          T3P3Tony administrators @A Former User
                          @thedragonlord thanks for the example print file
                            you're welcome! I hope it could be helpful
                              @thedragonlord could you also post a pic of how you have this mounted please.
                                uh now I'm at office so I can't do this, I'll do later now I try to explain: I've mounted the sensor BEFORE the BMG extruders, there's almost no space between the sensor housing "exit" and the BMG "entry" (of course they are attached with a PTF small tube)...any case this evening I'll post a photo if the description isn't enough
                                EDIT
                                this is a picture I've just taken with my infrared IPcam...as you can see above the BMG there's the sensor housing, is this enoguh?
                                  @thedragonlord yes thanks
                                    MegaBot_Sitting_Body_Upper.gcode
                                      A Former User @wouldstain
                                      Same configuration than mine
                                        @thedragonlord @wouldstain thanks the mounting arrangements look good. I hope be be able to investigate this with the gcode you uploaded here later in the week.
                                        A Former User? wouldstainundefined 2 Replies Last reply Reply Quote 0
                                          ok, thanks
                                            @t3p3tony this one is interresting:
                                            Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 20% to 130%, check every 3.0mm, version 3, mag 132 agc 76, measured sensitivity 19.53mm/rev, min 100% max 100% over 12.0mm
                                            happening repeatedly on a smaller print.Drywall_Anchor.gcode
