    Height Map - Substantial z-offset after setting z-offset
    4.0k
    • TimsWorkshopundefined
      TimsWorkshop @fcwilt
      @fcwilt so I did a G32 and had to adjust the knobs again, and then ran a G29 with one probe and F100... it took a while, but mesh looks much better. We'll see how it looks tomorrow after a 20hr print.
      Ender 5 Plus - E3D Hemera Hotend - Duet 2 Wifi
      TimsWorkshopundefined 1 Reply Last reply Reply Quote 1
      • zaptaundefined
        zapta @fcwilt
        @fcwilt said in Height Map - Substantial z-offset after setting z-offset:
        I was a programmer for 30+ years but now given the limited number of files I put them in one place and I always know where they are - the System folder.
        71 year old brains crave simplicity
        @fcwilt, software engineering is a relatively new profession. Did you transition from another discipline?
        Software engineering is unique because people from other disciplines can easily transition to it and do well just by applying common sense. This is not the case with other branches of engineering and STEM (imagine a software engineer designing a bridge ;)).
        • fcwiltundefined
          fcwilt @zapta
          @zapta said in Height Map - Substantial z-offset after setting z-offset:
          Actually I studied digital circuit design and did that for a couple of years but when microprocessors began to take off my company needed someone to learn how to code for them.
          From that I learned that I liked programming and had the skills. So I branched out into application programming.
            TimsWorkshop @TimsWorkshop
            @infidelprops said in Height Map - Substantial z-offset after setting z-offset:
            So finished the print and ran another G29... this time it was still a good mesh and worked well. Not sure but thinking I may want to tune my stepper motors to help reduce them falling, one side or the other.
            • fcwiltundefined
              fcwilt @TimsWorkshop
              Sounds promising.
              One of the benefits of auto bed leveling is getting the Z steppers back in sync.
              On my 3 Z printer when removing the magnetic print surface a stepper sometimes moves due to the reduced current levels.
              TimsWorkshopundefined zaptaundefined 2 Replies Last reply Reply Quote 1
                @fcwilt Thanks mate - I've just got BL Touches delivered and am going to put those in versus the EZABL probe.. that will be todays task.
                • zaptaundefined
                  zapta @fcwilt
                  Stumbled today upon this unboxing video. The printer has two Z motors as well as a belt that keeps them sync'ed. It's an interesting idea.
                  https://youtu.be/CkTgm4AQjhY?t=397
                  • fcwiltundefined
                    fcwilt @zapta
                    I've got one of the earlier, smaller Sapphire Core XY unit
                    It was a pretty nice unit of the box.
                    But I cannot help myself and had to mod it (Duet, PanelDue, better hotend, Zesty Nimble, better bed).
                    Happy with the unit.
                    Here is a quick-and-dirty video of my 3 Z Stepper Belt Drive printer showing the ability to deal with a badly out of level bed:
                    3 Z Stepper Printer
                    TimsWorkshopundefined 1 Reply Last reply Reply Quote 0
                      @fcwilt Just wanted to post a quick update... I ditched the EZABL and put new BLT's in and haven't had a problem since. Prints are coming out beautiful and I haven't had to adjust the baby steps since the first MBL/ABL.
                      Thanks again for all the insight and help!
                      fcwiltundefined 1 Reply Last reply Reply Quote 2
                      • fcwiltundefined
                        I love a happy ending.
                        I had doubts about the EZABL when I found out it was capacitive. Before you removed it did you ever try a very slow probing speed?
