    Place to show off PCB Effector assemblies
    Smart effector for delta printers
    15
    49
    8.2k
      T3P3Tony administrators
      @DjDemonD:
      On a slightly different note, I didn't have much luck with the molex microfit connector, whatever orientation I was inserting the crimps into the housing there was no positive click and the expected retention of the cable. Is there some sort of knack to doing it? I don't seem to have any problems with duponts or the molex KK connectors?
      The two little barbs on the sides of the pin should lock in to the microfit housing. Its possible you are not inserting them far enough. Try pushing them in a little further (I sometimes use a small jeweler's screwdriver to push on the back of the pin)
      • DjDemonDundefined
        DjDemonD
        Hi Tony, the blowers work well and were Nebbian's (from reprap forum) idea. They will tolerate 12v and then they are extremely powerful but they shift a fair amount of air at 5v. I find I can PWM them from about 30% to 100%.
        I tried sensitivities from 0 to 255 not much difference, as David said I think its that this fan is a much more powerful unit than the e3d standard one, and its is very close, and directly beneath the strain gauge. I suspect it won't be a problem for most. I would have tried the spacer but then I like the compact hotend below the effector for its reduction in effect of tilt and stability.
        My connectors are holding together, just seemed so much less positive locking into place than other types of crimps/housings I've used. But I'll try that idea.
        I have noticed my large nut holding the heatsink came loose and with the nimble adaptor in place its hard to get to. Makes me wonder if:
        A nut can be sourced which has slots on the side which could be used to push it round with a flat bladed screwdriver for tightening purposes, I accept there is a risk to the PCB.
        Or maybe we can design a 12 pointed star type locking ring type thing into the underside of the nimble adaptor once the nut is in a reasonable rotational position we could tighten the hot end heatsink into it.
        www.precisionpiezo.co.uk
        • DADIYundefined
          DADIY
          A few spots of thread lock should stop the nut coming loose.
          • Hergonowayundefined
            Hergonoway
            @DADIY:
            Had the same issue, 1 drop of thread lock did the job.
            Delta goes BrrrRRRRrrrrrRRRRrrr
            • oleeundefined
              olee
              I wonder what the tightening torque is right for the nut? M12 thread can withstand rather large torque even aluminium one (21Nm) but I doubt FR4 and moreover a plastic washer can. Does overtightening have any detrimental effect on the strain gauge which are just accordeon shaped traces on the effector PCB around the heatsink sitting hole? As for me thread lock is not good solution for the task considering a need for hotend reassembly and fragility of the PCB with all that electronic components on it.
                We've designed the effector so that that the strain gauge traces are clear of the area that takes the clamping force. You should be able to use quite a high torque, but bear in mind that the heatsink is aluminium and the thread pitch is fine - therefore the thread depth is small too. If you are in doubt then we suggest you use a drop of non-permanent thread lock.
                • oleeundefined
                  olee
                  Thanks! First I'm going to try a medium torque something like 10Nm without thread lock. Getting it loose then thread lock will be last resort.
                  • clearlynotstefanundefined
                    clearlynotstefan
                    DJ - would you mind sharing the mount for the fan holders you got there? I just ordered a set. PWM-wise gimme a quick rundown of how you've got them wired when you get a chance? I don't wanna blow anything up haha
                    • DjDemonDundefined
                      DjDemonD
                      Hi dude, sure they're in the thingiverse listing for the fan shroud https://www.thingiverse.com/thing:2490021 screw the brackets onto the magnetic stud m3 bolts with m3 nuts, and then bond the fans on with CA/super glue.
                      If I was going to change anything I'd edit them to allow a little extra clearance between the bolt hole at the top and the vertical section so the nut is easier to do up, but being slightly tight keeps it tensioned so hey ho.
                      Wiring - you can run these fans on 12v (not 24v) but probably PWM them to 50% max. but that's up to you. I find they give plenty cooling at 5v.
                      If you prefer to do it properly, then you can take 5v from the duet board (see schematic - I think you can use the 5v pin on the fan voltage jumper or expansion connector) wire them in parallel at the smart effector, supply the 5v positive to them, ground them back through the duet Fan 0 (by default) GND pin which then allows PWM control.
                      I have a buck converter instead, as at the time I built the machine I was using 12v fans on a 24v system. If you go down this route then wire the positive input of the converter to the fan 0 positive (or I suppose any Vin source), wire the negative input to the converter to PSU negative, then send the positive output from the converter (set nominally to 5v output) to the fans via the smart effector, and ground them to the fan 0 GND pin, this allows PWM control.
                      • DjDemonDundefined
                        DjDemonD
                        Just to say I have a supply of those tiny fans, if anyone UK based wants to buy one they're in my shop:
                        https://www.precisionpiezo.co.uk/shop
                        Probably not worth sending them overseas as the shipping will be too much for just a fan on its own.
                        • Mikeundefined
                          Mike
                          Just a side note - I've been running those for a bit, you can also buy them 12V ones in the same form factor. The airflow is simply amazing.
                          https://www.digikey.com/product-detail/en/delta-electronics/BFB0312HA-A/603-1112-ND/1014443
                            Ahh good to know, now I need to find them in 24V and that would be perfect!
                            Can your confirm if the 12V ones work properly with PWM?
                            • number40fanundefined
                              number40fan
                              http://www.ebay.com/itm/Lot-2pcs-Ball-Bearing-4cm-40mm-x-10mm-Blower-Fan-12V-Brushless-Cooling-fan-2pin/263060496493?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D47046%26meid%3Dd590363eeeeb46a481b35ce269653e33%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D263060496493&_trksid=p2481888.c100675.m4236&_trkparms=pageci%253Ac37d1707-923b-11e7-a62d-74dbd1808495%257Cparentrq%253A522b019a15e0a9c4dec5ebddfff6cfbe%257Ciid%253A1
                              9.5cfm out of these. PWM works fine.
                              • DjDemonDundefined
                                DjDemonD
                                @T3P3Tony:
                                If you mean the 40x40 then I don't know the 30x30x10 fan I have - 5v one, will work at 12v but they do sound like they are working hard.
                                I just pull 5v off the duet 5v rail and ground it via the fan0 GND pin.
                                • Mikeundefined
                                  Mike
                                  @T3P3Tony:
                                  Yep, they do. I can run them from 25% to 100%
                                    Hergonoway
                                    For my part I used these blowers fan 24v 404010mm : https://www.aliexpress.com/item/2PCS-Gdstime-40mm-40x10mm-4CM-DC-24V-0-1A-Mini-Turbo-Blower-Cooling-Cooler-Fan-For/32799434002.html
                                    10.25CFM, 24V works with PWM (without tuning M106, with default frequency F250)
                                    • DADIYundefined
                                      DADIY
                                      @Hergonoway:
                                      thanks for the link, I've just ordered a couple as for some reason the standard fan+shroud didn't fit my smart effector correctly. I just hope not to get burnt by Ali express again. The bed heater I ordered from there got lost in the post but they favoured the seller so I lost my money.
                                        number40fan
                                        I ordered two sets as well. I don't currently run 24V, but the time shipping takes, I might get the itch before they show up.
                                        • Mikeundefined
                                          Mike
                                          Isn't it a lot more convenient to just run the fans from 12V? Sure, you need a step-down converter or a separate 12V PSU, but the choice of fans is so much greater. A DC-DC buck converter is below 10 money units on amazon.
                                            Hergonoway
                                            @DADIY:
                                            @Hergonoway:
                                            Np, hope you like them. I'll share my fan mount for the smart effector once I finish my duet wifi box
