    Place to show off PCB Effector assemblies
    Smart effector for delta printers
    15
    49
    8.2k
    • clearlynotstefanundefined
      clearlynotstefan
      DJ - would you mind sharing the mount for the fan holders you got there? I just ordered a set. PWM-wise gimme a quick rundown of how you've got them wired when you get a chance? I don't wanna blow anything up haha
      • DjDemonDundefined
        DjDemonD
        Hi dude, sure they're in the thingiverse listing for the fan shroud https://www.thingiverse.com/thing:2490021 screw the brackets onto the magnetic stud m3 bolts with m3 nuts, and then bond the fans on with CA/super glue.
        If I was going to change anything I'd edit them to allow a little extra clearance between the bolt hole at the top and the vertical section so the nut is easier to do up, but being slightly tight keeps it tensioned so hey ho.
        Wiring - you can run these fans on 12v (not 24v) but probably PWM them to 50% max. but that's up to you. I find they give plenty cooling at 5v.
        If you prefer to do it properly, then you can take 5v from the duet board (see schematic - I think you can use the 5v pin on the fan voltage jumper or expansion connector) wire them in parallel at the smart effector, supply the 5v positive to them, ground them back through the duet Fan 0 (by default) GND pin which then allows PWM control.
        I have a buck converter instead, as at the time I built the machine I was using 12v fans on a 24v system. If you go down this route then wire the positive input of the converter to the fan 0 positive (or I suppose any Vin source), wire the negative input to the converter to PSU negative, then send the positive output from the converter (set nominally to 5v output) to the fans via the smart effector, and ground them to the fan 0 GND pin, this allows PWM control.
        www.precisionpiezo.co.uk
        • DjDemonDundefined
          DjDemonD
          Just to say I have a supply of those tiny fans, if anyone UK based wants to buy one they're in my shop:
          https://www.precisionpiezo.co.uk/shop
          Probably not worth sending them overseas as the shipping will be too much for just a fan on its own.
          • Mikeundefined
            Mike
            Just a side note - I've been running those for a bit, you can also buy them 12V ones in the same form factor. The airflow is simply amazing.
            https://www.digikey.com/product-detail/en/delta-electronics/BFB0312HA-A/603-1112-ND/1014443
              T3P3Tony administrators
              Ahh good to know, now I need to find them in 24V and that would be perfect!
              Can your confirm if the 12V ones work properly with PWM?
              • number40fanundefined
                number40fan
                http://www.ebay.com/itm/Lot-2pcs-Ball-Bearing-4cm-40mm-x-10mm-Blower-Fan-12V-Brushless-Cooling-fan-2pin/263060496493?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D47046%26meid%3Dd590363eeeeb46a481b35ce269653e33%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D263060496493&_trksid=p2481888.c100675.m4236&_trkparms=pageci%253Ac37d1707-923b-11e7-a62d-74dbd1808495%257Cparentrq%253A522b019a15e0a9c4dec5ebddfff6cfbe%257Ciid%253A1
                9.5cfm out of these. PWM works fine.
                • DjDemonDundefined
                  DjDemonD
                  @T3P3Tony:
                  If you mean the 40x40 then I don't know the 30x30x10 fan I have - 5v one, will work at 12v but they do sound like they are working hard.
                  I just pull 5v off the duet 5v rail and ground it via the fan0 GND pin.
                  • Mikeundefined
                    Mike
                    @T3P3Tony:
                    Yep, they do. I can run them from 25% to 100%
                    • Hergonowayundefined
                      Hergonoway
                      For my part I used these blowers fan 24v 404010mm : https://www.aliexpress.com/item/2PCS-Gdstime-40mm-40x10mm-4CM-DC-24V-0-1A-Mini-Turbo-Blower-Cooling-Cooler-Fan-For/32799434002.html
                      10.25CFM, 24V works with PWM (without tuning M106, with default frequency F250)
                      Delta goes BrrrRRRRrrrrrRRRRrrr
                      • DADIYundefined
                        DADIY
                        @Hergonoway:
                        thanks for the link, I've just ordered a couple as for some reason the standard fan+shroud didn't fit my smart effector correctly. I just hope not to get burnt by Ali express again. The bed heater I ordered from there got lost in the post but they favoured the seller so I lost my money.
                          number40fan
                          I ordered two sets as well. I don't currently run 24V, but the time shipping takes, I might get the itch before they show up.
                          • Mikeundefined
                            Mike
                            Isn't it a lot more convenient to just run the fans from 12V? Sure, you need a step-down converter or a separate 12V PSU, but the choice of fans is so much greater. A DC-DC buck converter is below 10 money units on amazon.
                              Hergonoway
                              @DADIY:
                              @Hergonoway:
                              Np, hope you like them. I'll share my fan mount for the smart effector once I finish my duet wifi box
                              • Adrian52undefined
                                Adrian52
                                This is my smart effector with fan duct based on David's design (its on thingiverse 2521716).
                                I have used my existing Traxxas rods with mounts that I put on thingiverse too (2492092). They seem to work very well - my best 8 parameter residual error is 0.005. As you can probably see, using Capricorn bowden tube, which seems excellent. Retraction of 2.4mm seems fine on the 60cm tube on my Kossel XL. Probe works wonderfully well. Not sure if my picture is going to appear though - haven't done this before.
                                  number40fan
                                  • Adrian52undefined
                                    Adrian52
                                    Thank you (how did you do that?)
                                    • Jareryundefined
                                      Jarery
                                      Nice, what material did you use for the fan ducts ?
                                        number40fan
                                        I uploaded the picture to imgbb.com.
                                        • Adrian52undefined
                                          Adrian52
                                          I used e3d edge 'very black' PETG for the fan duct. I try not to leave it too long with the hot end hot and the print fan off - OK so far.
