Z homing issu whit endstop please help
@jay_s_uk ; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes forwards
M350 Z16 E16 I0 ; configure microstepping without interpolation
M350 X16 Y16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z2756.00 E675.00 ; set steps per mm
M566 X900.00 Y900.00 Z20.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z20.00 E6000.00 ; set maximum speeds (mm/min)
M201 X5000.00 Y5000.00 Z10.00 E500.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E550 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y500 Z600 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin ^zstop; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 C"^zprobe.in" H5 F100 T2000
M950 S0 C"exp.heater3"
G31 P500 X30 Y60 Z8 ; set Z probe trigger value, offset and trigger height
M557 X15:315 Y15:315 S20 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"pt100000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
T0 ; select first tool -
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 Z16 E16 I0 ; configure microstepping without interpolation M350 X16 Y16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z2756.00 E675.00 ; set steps per mm M566 X900.00 Y900.00 Z20.00 E600.00 ; set maximum instantaneous speed changes (mm/min) M203 X30000.00 Y30000.00 Z20.00 E6000.00 ; set maximum speeds (mm/min) M201 X5000.00 Y5000.00 Z10.00 E500.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E550 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z600 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin ^zstop ; Z-Probe M950 S0 C"exp.heater3" M558 P9 C"^zprobe.in" H5 F100 T2000 G31 P500 X30 Y60 Z8 ; set Z probe trigger value, offset and trigger height M557 X15:315 Y15:315 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous T0 ; select first tool
I've made a couple of tweaks. could you load that please?
@jay_s_uk 20.10.2021, 15:08:02
Error: Temperature reading fault on heater 1: sensor open circuit
20.10.2021, 15:08:00 M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
@bartekp what to do next
@bartekp does the probe display in that panel now?
@jay_s_uk z probe 0
@bartekp is that with the bltouch extended or retracted?
Do M401 and M402 do anything? -
@jay_s_ukdo nothing but no errors
@bartekp is retracted
@bartekp sounds like you need you check your wiring carefully (with the power off)
@jay_s_uk can you tell me how should be connected to duet 2 ?
wifi -
@bartekp i have greean instead red line maybe i should change betwen green and yelow
@bartekp I checked connection and evey line is ok
@bartekp the creality BLTouch wire colours are here for reference
https://forum.duet3d.com/topic/25598/bl-touch-on-duet3/6?_=1634733529379 -
@jay_s_uk it look like i have good connected
@bartekp can you show the duet end?
@jay_s_uk what you mean duet end
conection to duet ?
