    Rotating Magnetic Sensor - Keeps Pausing Printer
    Filament Monitor
    9
    151
    8.8k
      T3P3Tony administrators @wouldstain
      @wouldstain
      At the end of the test file is the following:
      var extruder=tools[state.currentTool].extruders[0]
      M400
      M591 D{var.extruder}
      Comment out the line starting with var and change the D variable to the appropriate one for your machine (normally 0)
      ;var extruder=tools[state.currentTool].extruders[0]
      M400
      M591 D0
      wouldstainundefined 1 Reply Last reply Reply Quote 0
      • wouldstainundefined
        wouldstain @T3P3Tony
        @t3p3tony
        Console output:
        1635171097795-mfm-test-1:
        Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 131 agc 75, measured sensitivity 25.89mm/rev, min 99% max 103% over 48.1mm
        1635171097802-mfm-test-2:
        Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 132 agc 77, measured sensitivity 26.00mm/rev, min 95% max 102% over 99.6mm
        1635171097805-mfm-test-3:
        Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 132 agc 75, measured sensitivity 25.87mm/rev, min 98% max 102% over 49.0mm
        1635173702760-mfm-test-4:
        Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 132 agc 75, measured sensitivity 26.09mm/rev, min 97% max 102% over 39.1mm
        1635178672431-mfm-test-5
        Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 131 agc 75, measured sensitivity 25.88mm/rev, min 98% max 102% over 99.3mm
        1635178672433-mfm-test-6
        Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 131 agc 75, measured sensitivity 25.99mm/rev, min 97% max 104% over 99.4mm
        1635178672436-mfm-test-7
        Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 131 agc 75, measured sensitivity 25.79mm/rev, min 98% max 101% over 45.4mm
          A Former User @dc42
          @dc42 said in Rotating Magnetic Sensor - Keeps Pausing Printer:
          @thedragonlord @wouldstain @alankilian @charlesmc @CNCModeller I have fixed a couple of potential issues in RRF that might have caused spurious under or over extrusion reports. My initial testing suggests that these have fixed at least part of the problem - the window at the end of the drywall-anchor print went from about 53-130% before to 93-112% after. However I have not done enough runs (2 before the changes, 1 after) to prove statistically that the changes have made an improvement.
          If you wish to try out RRF with these changes, you can find the binaries at https://www.dropbox.com/sh/xeu30go894p9xbs/AAB5U66SH4wbjKIcX0snUbKxa?dl=0. Caution! These are pre-beta binaries so they have had limited testing. If you are not already running firmware 3.4beta5 then you must read the upgrade notes before installing them.
          No way...Installed the pre beta but got this after few minutes of printing:
          Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 24.78mm/rev, allow 60% to 130%, check every 3.0mm, version 3, mag 131 agc 66, measured sensitivity 24.49mm/rev, min 41% max 118% over 771.9mm
          I've kept an eye to the range for about two minutes and the minimum and maximun have been about stable at around 94% and 104%. After two minutes I went away from the printer so I can't say if before the stop the range has started to enlarge or if the stop itself has been a single event
          What I can say for sure is that once more the stop occured in the surrounding of a sharp corner where the nozzle slows down...(I can say because I've found a small blob of filament where the nozzle has stopped)
            @thedragonlord is this with the file Very Fast Test Print__PETG Amazon Basic_0.2000mm.gcode that you posted earlier?
              A Former User @dc42
              no, with this one
              GTS3D PLA Calibration Cube T0__PLA GTS3D_0.2000mm.gcode
                wouldstain
                @T3P3Tony @dc42
                Just received this from the attached print:
                Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 129 agc 75, measured sensitivity 27.29mm/rev, min -1% max 109% over 406.5mm
                I'm guessing the negative percentage indicates a retraction?
                Cone_threaded.stl
                  @wouldstain thanks. I have found a section of a short print file that gives repeatable bad results.
                  It would be helpful to try the cone print but better if you attached the sliced gcode than the stl file and my slicing settings will be different.
                  wouldstainundefined 2 Replies Last reply Reply Quote 0
                    @t3p3tony
                    Oops! I had passed it directly from Prusa to the printer w/o saving as a file...
                    here you go!
                    Cone_threaded.gcode
                      @t3p3tony
                      It occurs to me that this could be part of a broader issue I had encountered prior to installing the MFM.
                      In short, I was experiencing what appeared to be over-advancement on the extruder. This would often result in filament being ground in the extruder to the point where it would no longer feed leading to an eventual clog in the hotend and even in the throat.
                      I worked with @3lemental to tune the M92 E-value (went from 837 to 814) which yielded some improvement but did not completely resolve the issue.
                      Installing the MFM lead to a drastic improvement (no more clogs or ground filament!) but these pauses may be related. Since this was no longer ruining print jobs, I sort of placed the issue on the back burner.
                      I don't know if it's appropriate to this thread but I have more detail on what steps I had / have taken so far on this.
                      Just let me know if you would like me to post it here or elsewhere.
                        @wouldstain Probably better to start a new thread on that, thanks.
                          dc42 administrators @T3P3Tony
                          I have put new 3.4beta5+1 binaries at https://www.dropbox.com/sh/xeu30go894p9xbs/AAB5U66SH4wbjKIcX0snUbKxa?dl=0. These fix a bug that was giving me consistently poor results from the filament monitor on the drywall-anchor print. This particular bug was either introduced or made worse in version 3.4beta2. The particular instance that triggered it was a very short extruder move, less than one microstep long. This means that it would have occurred more often on machines with low extruder steps/mm.
                          Use these binaries with caution, because I have done only small test prints with the Duet 2 binary, basic movement tests with the Duet 3 binary, and I have not yet tested the Duet 3 Mini or Maestro binaries.
                          These binaries also include the race condition fix that may have caused occasional incorrect results from the filament monitor in firmware 3.3 and earlier versions.
                          A Former User? wouldstainundefined alankilianundefined 5 Replies Last reply Reply Quote 0
                            A Former User @dc42
                            I'll give it a try with the same gcode I've posted earlier and I'll let you know... just for info my printer uses two bondtech BMG extruders so I haven't configured a low step/mm for them
                              A Former User @dc42
                              Good news so far!
                              I've reprinted the same gcode and it went all ok!
                              M591 D0
                              Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 24.78mm/rev, allow 60% to 130%, check every 3.0mm, version 3, mag 131 agc 65, measured sensitivity 24.54mm/rev, min 95% max 112% over 1356.0mm
                              so far so good!
                              More tests will follow!
                              Thank you guys for your effort!
                              EDIT:
                              It doesn't work anymore the Telegram bot I use to have all the printer notifications...have you changed something?
                                T3P3Tony administrators @A Former User
                                @thedragonlord said in Rotating Magnetic Sensor - Keeps Pausing Printer:
                                best to start a new thread on that
                                  A Former User @T3P3Tony
                                  @t3p3tony said in Rotating Magnetic Sensor - Keeps Pausing Printer:
                                  Ok, I wrote here because the issue started this morning after the installation of the last pre beta
                                    A Former User @dc42
                                    I can confirm that the sensor issues has been solved by your FW patch...I've made several small prints and one large prints in dual material using both the sensors and I had no problem at all
                                    Thanks again
                                      @thedragonlord thanks for your help in working through this and providing some test prints. Can you confirm your filament monitor settings, PA settings and what filament monitor results you are now getting.
                                      @wouldstain have you had any success with the new builds yet?
                                        Monitor settings:
                                        M591 D0 P3 C"e0stop" R60:300 L24.78 E3.0 S1
                                        M591 D1 P3 C"e1stop" R60:300 L24.67 E3.0 S1
                                        PA Settings for PLA:
                                        M572 D0 S0.45 ; Pressure Advance
                                        M572 D1 S0.45 ; Pressure Advance
                                        PA Settings for PETG:
                                        M572 D0 S0.75 ; Pressure Advance
                                        M572 D1 S0.75 ; Pressure Advance
                                        I alway get results around 95-98% as minimum
                                          wouldstain @dc42
                                          @dc42 Duet2Combined.bin for Duet2 Wifi?
                                          Also, what is the .map file? Is that something I need?
                                          Thank you!
                                            @wouldstain you can ignore the map file. This is a build of RRF 3.4b5+1, are you running 3.4b5 already? If so then you can just update to this version using the Update system files in DWC->System. If you are not then please update to 3.4b5 first (DWC as well as RRF)
