    Problems with direct drive extruder skipping
    611
    • dbrb2undefined
      dbrb2
      I have an X5SA printer with a Duet board with the following paramaters:
      Firmware Version: 2.05.1 (2020-02-09b1)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
      I am having an odd problem with my extruder.
      Even when extruding filament into thin air - no hot-end at all - I am getting quite severe skipping, causing problems printing - see this video:
      https://photos.app.goo.gl/zxSyeezumrJqYFRr7
      The smallest assist from me from below and it will move slowly, but any idea what the problem may be? The extruder is direct drive - could that be a problem? But the torque required here should be minimal....I have adjusted the tension between the gear and the runner wheel without obvious effect
      My steps per mm is:
      M92 X80.00 Y80.00 Z1500.00 E100 ; set steps per mm
      This seemed to be working - but since calibrating, the knocking has now become much worse
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SJ-6JKD4-3S86Q-TAX7F
      Used output buffers: 3 of 24 (9 max)
      Static ram: 25712
      Dynamic ram: 93252 of which 304 recycled
      Exception stack ram used: 648
      Never used ram: 11156
      Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3728) IDLE(ready,160)
      Owned mutexes:
      Last reset 01:46:12 ago, cause: software
      Last software reset at 2021-10-28 18:55, reason: User, spinning module GCodes, available RAM 11156 bytes (slot 1)
      Error status: 0
      Free file entries: 9
      SD card longest block write time: 109.6ms, max retries 0
      MCU temperature: min 30.2, current 34.1, max 34.4
      Supply voltage: min 23.2, current 24.0, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/204
      Driver 1: standstill, SG min/max 0/234
      Driver 2: standstill, SG min/max 0/127
      Date/time: 2021-10-28 20:41:35
      Slowest loop: 26.43ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 95, MaxWait: 336963ms
      Bed compensation in use: mesh, comp offset 0.321
      === DDARing ===
      Scheduled moves: 11679, completed moves: 11679, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.4
      • o_lampeundefined
        o_lampe @dbrb2
        @dbrb2 from the video I can tell that you are using the extruder the wrong way round, although this should work as well somehow
        The spring of the lever arm is quite tight, I'd reduce spring load a lot.
        dbrb2undefined 1 Reply Last reply Reply Quote 0
        • dbrb2undefined
          dbrb2 @o_lampe
          Thanks - I'll take a look tonight. I tried the tension much looser without much effect, but will try again.
          When you say the wrong way around, how do you mean?
          The motor turns, pushes the filament up from below and into the Bowden tube, in the direction of the hot end (when it's connected)
          Thanks!
          • o_lampeundefined
            o_lampe @dbrb2
            @dbrb2 Ok, I didn't see much movement anyway. What I also noticed is hard to describe: the (virtual) axis between drive wheel center and idler wheel center should be perpendicular to the filament path. That's not the case with your extruder.
            BTW: How much current does the stepper get? And how much is max. current?
            • rjenkinsgbundefined
              rjenkinsgb
              With power off and the pressure roller held away from the drive gear, can you turn the motor freely by hand, complete turns?
              If so, I'd suggest carefully re-checking or replacing the wiring to the extruder motor; a bad connection causing low power on one winding seems the likeliest cause?
              If you cannot find any problems, do you have a spare stepper output you can try it on?
              Robert J.
              Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
              • dbrb2undefined
                dbrb2 @rjenkinsgb
                @rjenkinsgb thanks. Yes, it moves freely with just a very slight but consistent "judder" as it turns.
                I have checked the wiring, which seems ok, and will double check the mechanics later today.
                I do have a spare motor as well if it comes to that
                • Gixxerfastundefined
                  Gixxerfast
                  It's not uncommon for these extruders that the idler wheel eats into the aluminum quite rapidly since for many of then there's no spacer underneath (I could remember this wrongly since it was a while since I used this type). I would checkout the idler wheel and arm before looking any further.
                  Just a thought.
                  Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                  Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                  Ender 3 Pro with BTT SKR-2 + RRF
                  • dbrb2undefined
                    dbrb2 @Gixxerfast
                    @gixxerfast said in Problems with direct drive extruder skipping:
                    Ok. I have:
                    replaced the extruder with an idemntical type
                    Recalibrated extrtuder
                    Re-run bed calibration
                    Still getting a lot of extruder skipping. I wonder if the nozzle could be more blocked than it seems (it is certainly working, but maybe the pressure needed is higher than it should be...?)
                    I have an old titan extruder somewhere....perhaps I could try that. Should give me more torque...
                    Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                      Gixxerfast @dbrb2
                      @dbrb2 But in the video it looked like it skipped just pushing the filament through the extruder.
                      Can you post your config.g ?
                      I think you can just run an empty M906 to show the motor currents.
                      If all is good there, you might have a bad crimp/connection.
                      • dbrb2undefined
                        dbrb2 @Gixxerfast
                        @gixxerfast Yes - the video was with no hot-end
                        Interestingly, I have found that post my changes today (replacing extruder mechanism and motor, checking calibration) , it can extrude into the air fine. I also shortened the bowden tube path slightly.
                        On a test extrusion, once it starts skipping, it will keep doing so, but a little hand assistance and it will then work fine. So it seems like once it starts to jam, it stays that way until released.
                        M906 gives me:
                        Motor current (mA) - X:800, Y:800, Z:800, E:800, idle factor 30%
                        It feels like there may be room to increase this...? The motot has a niminal maximum of 1.8A:
                        SL42STH40-1684A 1.8A
                        My entire config is:
                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 19:55:13 GMT+0100 (British Summer Time)
                        G21 ; use mm
                        M550 P"TronXY X5SA" ; set printer name
                        M669 K1 ; select CoreXY mode
                        M552 S1 ; enablee network
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M569 P3 S1 ; Extruder physical drive 3 goes forwards
                        M566 X900.00 Y900.00 Z12.00 E100.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X6000.00 Y6000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
                        M84 S30 ; Set idle timeout
                        M208 X00 Y00 Z0 S1 ; set axis minima
                        M208 X310 Y310 Z380 S0 ; set axis maxima
                        M574 X1 Y1 S0 ; set active low endstops
                        ; Filament Run Out Sensor
                        M591 D0 P1 C4 S1 ; Filament runout Sensor for Extruder E0 on E1 Endstop input P1 = signal HIGH.
                        M558 P5 I1 H5 F120 T6000 ; set Z probe type to inductive and the dive height + speeds
                        G31 P500 X20 Y20 Z0.53 ; set Z probe trigger value, offset and trigger height
                        M557 X90:280 Y90:280 S20 ; define mesh grid
                        M106 P2 S0 I0 F500 H-1 ; set fan 2 as part cooling fan
                        M106 P0 T45 S0.7 H1 ; set fan 0 as our hotend fan
                        M563 P0 D0 H1 F2 ; define tool 0 uses part cooling fan 0
                        • o_lampeundefined
                          o_lampe @dbrb2
                          @dbrb2 said in Problems with direct drive extruder skipping:
                          M906 gives me:
                          It feels like there may be room to increase this...? The motor has a minimal maximum of 1.8A:
                          That's why! You can easily raise the current to 1.4-1.6A = E1400 or E1600
                          • dbrb2undefined
                            dbrb2 @o_lampe
                            @o_lampe so far that is looking good....
                            I moved from a geared extruder that was relay hard to thread to this one - but didn't increase the current, despite the obvious need to have more torque!
                            Fingers crossed....
