    Z axis not homing
    1.6k
    • PRIOR123undefined
      PRIOR123 @jay_s_uk
      @jay_s_uk
      the homing error is fixed but the x and y positioning when homing the Z via home all isnt working
        jay_s_uk @PRIOR123
        @prior123 because you're in absolute mode. Surely X-38 Y-10 is off your bed or even outside your axis limits
        PRIOR123undefined 1 Reply Last reply Reply Quote 0
        • PRIOR123undefined
          PRIOR123 @jay_s_uk
          @jay_s_uk so should i comment out that line then? sorry im pretty unknown when it comes to programming
            jay_s_uk @PRIOR123
            @prior123 well where do you want the nozzle to move to when you do the G30?
            • PRIOR123undefined
              PRIOR123 @jay_s_uk
              @jay_s_uk probably X-60 and Y-10
              But i just changed that in the homeall.g and it doesnt seem to be doing anything
                jay_s_uk @PRIOR123
                @prior123 how? That's way outside your bed limits set in M208 in your config
                • PRIOR123undefined
                  PRIOR123 @jay_s_uk
                  @jay_s_uk this has helpe massively! thank you.
                  How can i work out the true measurements essentially ive defined it all no with
                  M208 X60 Y-10 Z0 S1 ; set axis minima
                  M208 X235 Y235 Z260 S0 ; set axis maxima
                  however im not trying to define the mesh coordinates and i am continuously getting this
                  Warning: Skipping grid point X=200.0, Y=180.0 because Z probe cannot reach it
                  Warning: Skipping grid point X=220.0, Y=180.0 because Z probe cannot reach it
                  Warning: Skipping grid point X=220.0, Y=200.0 because Z probe cannot reach it
                  Warning: Skipping grid point X=200.0, Y=200.0 because Z probe cannot reach it
                  • PRIOR123undefined
                    PRIOR123 @PRIOR123
                    @prior123 the Z probe can go further im just really confused why it thinks it cant
                      jay_s_uk @PRIOR123
                      @prior123 your z probe has an offset of x-49. That means it can probe any further than 49mm before your x maximum. So with a maximum of 235, you can only probe up to X186 (otherwise the nozzle will have to go outside the machine limits)
                      • PRIOR123undefined
                        PRIOR123 @jay_s_uk
                        @jay_s_uk said in Z axis not homing:
                        235
                        sooo close now
                        ive recalibrated the Z probe, and redefined both the bed size and mesh size.
                        I have just one last issue it still wont hit the last point on the bed and throws out an error before continuing the rest of the G32 code
                        G31 P500 X-43 Y10 Z3.79 ; set Z probe trigger value, offset and trigger height
                        M557 X60:260 Y30:245 S20 ; define mesh grid
                        i thought it may have been the S value but that doesnt seem to make sense as 20 goes into 260
                        any more ideas?
                          jay_s_uk @PRIOR123
                          @prior123 what error does it throw
                          • PRIOR123undefined
                            PRIOR123 @jay_s_uk
                            @jay_s_uk
                            G32
                            Warning: Skipping grid point X=240.0, Y=30.0 because Z probe cannot reach it
                            Warning: Skipping grid point X=260.0, Y=30.0 because Z probe cannot reach it
                            Warning: Skipping grid point X=260.0, Y=50.0 because Z probe cannot reach it
                            Warning: Skipping grid point X=240.0, Y=50.0 because Z probe cannot reach it
                            jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                              jay_s_uk @PRIOR123
                              @prior123 again, you cant probe those points because your nozzle will go outside your axis limits. Based on 260, the closest you can go is X217
                              • fcwiltundefined
                                fcwilt @PRIOR123
                                @prior123 said in Z axis not homing:
                                @jay_s_uk
                                G32
                                If the warnings are in response to G32 we need to see your bed.g file.
                                Do you understand how the probe X and Y offsets limit where the probe can reach?
                                And, just FYI, I find it easier to use the P parameter for M557 rather than the S parameter. I care more about the number of grid points rather than the actual spacing of the grid points.
                                • PRIOR123undefined
                                  PRIOR123 @fcwilt
                                  @fcwilt said in Z axis not homing:
                                  557
                                  ; bed.g
                                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 16 2021 15:54:40 GMT+0000 (Greenwich Mean Time)
                                  G29 ; probe the bed and enable compensation
                                  What would i put for the M557 if it wasnt using an S value? i only put an S value because it feels easier to understand if i know the distance
                                  • PRIOR123undefined
                                    PRIOR123 @jay_s_uk
                                    @jay_s_uk
                                    So i know what you are saying but am i changing the
                                    to
                                    M557 X217:260 Y30:245 S20 ?
                                    • fcwiltundefined
                                      fcwilt @PRIOR123
                                      ; bed.g
                                      Strictly speaking you are not using bed.g as it was intended.
                                      G32 is the command for bed leveling, be it manual or automatic. G32 invokes bed.g.
                                      G29 is the command for mesh bed compensation. G29 invokes mesh.g
                                      The DWC has menu items for G32 and G29. If you follow the convention above then the actions performed using the DWC will match what the DWC menu items say.
                                      What you have will certainly work, it is just "out of sync" with the conventions and the DWC menu items.
                                      To follow the convention you would simply create the file mesh.g and move into it the commands you currently have in bed.g.
                                      For example If, instead of Snn, I put P20 the firmware generates a 20 x 20 grid. If I put P20:10 it generates a 20 x 10 grid.
                                      To me the number of points is of greater interest than the exacting spacing of the points.
