    Z axis not homing
    1.6k
      jay_s_uk @PRIOR123
      @prior123 have you got the x axis travelling further than total axis travel?
      If it fails to find the endstops on the first move but finds it on the second, that's usually when you get that message
      PRIOR123undefined 2 Replies Last reply Reply Quote 0
      • PRIOR123undefined
        PRIOR123 @jay_s_uk
        @jay_s_uk
        you were right i was on +Xaxis not - (facepalm)
        Thank you
        • PRIOR123undefined
          PRIOR123 @jay_s_uk
          @jay_s_uk
          Sorry to keep on but im now having an issue where the BOLD line isnt being read. The printer just keeps the x and Y axis by the end stops
          G91 ; relative positioning
          G1 H1 X230.5 Y235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X-5 Y-5 F6000 ; go back a few mm
          G1 H1 X230.5 Y235 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X-38 Y-10 F6000 ; go to first bed probe point and home Z
          ;G1 X-100 Y-50 F6000 ; go to first bed probe point and home Z
          :s
          PRIOR123undefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
          • PRIOR123undefined
            PRIOR123 @PRIOR123
            @prior123
            if i put my finger in to make the printer think its homed the Z axis (on home all) im still getting this error too
            G28
            Error: in file macro line 5: M280: parameter 'P' too high
              jay_s_uk @PRIOR123
              @prior123 can your printer even reach X-38 Y-10?
              Post your config.g
              PRIOR123undefined 1 Reply Last reply Reply Quote 0
                jay_s_uk @PRIOR123
                @prior123 you may also want to check your retractprobe.g as well
                • PRIOR123undefined
                  PRIOR123 @jay_s_uk
                  @jay_s_uk
                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 16 2021 15:54:40 GMT+0000 (Greenwich Mean Time)
                  M550 P"" ; set printer name
                  ;M551 P"" ; set password
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P0 S1 ; physical drive 0 goes backwards
                  M569 P1 S1 ; physical drive 1 goes backwards
                  M569 P3 S0 ; physical drive 3 goes forwards
                  M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                  M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X-5.5 Y-10 Z0 S1 ; set axis minima
                  M208 X220 Y220 Z250 S0 ; set axis maxima
                  M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                  M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X-49 Y9 Z1.597 ; set Z probe trigger value, offset and trigger height
                  M557 X-15:165 Y20:230 S20 ; define mesh grid
                  ;M557 X5:205 Y5:165 S20 ; Define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
                  M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                  M106 P0 C"Part Cooling" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                  M106 P1 C"Heatsink/Hotend" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
                  M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                  M106 P2 C"PartCooling" S1 H1 T45 ; set fan 2 name and value. Thermostatic control is turned on
                  M563 P0 S"PrintHead01" D0 H1 F0 ; define tool 0
                  T0 ; select first tool
                  • PRIOR123undefined
                    PRIOR123 @jay_s_uk
                    @jay_s_uk This has stopped the warning sign! thank you
                      jay_s_uk @PRIOR123
                      @prior123 all sorted now?
                      • PRIOR123undefined
                        PRIOR123 @jay_s_uk
                        @jay_s_uk
                        the homing error is fixed but the x and y positioning when homing the Z via home all isnt working
                          jay_s_uk @PRIOR123
                          @prior123 because you're in absolute mode. Surely X-38 Y-10 is off your bed or even outside your axis limits
                          • PRIOR123undefined
                            PRIOR123 @jay_s_uk
                            @jay_s_uk so should i comment out that line then? sorry im pretty unknown when it comes to programming
                              jay_s_uk @PRIOR123
                              @prior123 well where do you want the nozzle to move to when you do the G30?
                              • PRIOR123undefined
                                PRIOR123 @jay_s_uk
                                @jay_s_uk probably X-60 and Y-10
                                But i just changed that in the homeall.g and it doesnt seem to be doing anything
                                  jay_s_uk @PRIOR123
                                  @prior123 how? That's way outside your bed limits set in M208 in your config
                                  • PRIOR123undefined
                                    PRIOR123 @jay_s_uk
                                    @jay_s_uk this has helpe massively! thank you.
                                    How can i work out the true measurements essentially ive defined it all no with
                                    M208 X60 Y-10 Z0 S1 ; set axis minima
                                    M208 X235 Y235 Z260 S0 ; set axis maxima
                                    however im not trying to define the mesh coordinates and i am continuously getting this
                                    Warning: Skipping grid point X=200.0, Y=180.0 because Z probe cannot reach it
                                    Warning: Skipping grid point X=220.0, Y=180.0 because Z probe cannot reach it
                                    Warning: Skipping grid point X=220.0, Y=200.0 because Z probe cannot reach it
                                    Warning: Skipping grid point X=200.0, Y=200.0 because Z probe cannot reach it
                                    • PRIOR123undefined
                                      PRIOR123 @PRIOR123
                                      @prior123 the Z probe can go further im just really confused why it thinks it cant
                                        jay_s_uk @PRIOR123
                                        @prior123 your z probe has an offset of x-49. That means it can probe any further than 49mm before your x maximum. So with a maximum of 235, you can only probe up to X186 (otherwise the nozzle will have to go outside the machine limits)
                                        • PRIOR123undefined
                                          PRIOR123 @jay_s_uk
                                          @jay_s_uk said in Z axis not homing:
                                          235
                                          sooo close now
                                          ive recalibrated the Z probe, and redefined both the bed size and mesh size.
                                          I have just one last issue it still wont hit the last point on the bed and throws out an error before continuing the rest of the G32 code
                                          G31 P500 X-43 Y10 Z3.79 ; set Z probe trigger value, offset and trigger height
                                          M557 X60:260 Y30:245 S20 ; define mesh grid
                                          i thought it may have been the S value but that doesnt seem to make sense as 20 goes into 260
                                          any more ideas?
                                            jay_s_uk @PRIOR123
                                            @prior123 what error does it throw
