    Thermistor 500°C with Duet3
    589
    • Anopsia1000undefined
      Anopsia1000
      Is there a way to use a thermistor 500°C with the Duet3
      Sensors config is
      M308 S1 P"121.temp0" Y"thermistor" T4606017 B5848 C5.548428e-8
      M950 H1 C"121.out0" T1
      My reading is -273°C, impossible to heat up. Always faulty.
      Stephen6309undefined dc42undefined TLASundefined zaptaundefined 4 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Anopsia1000
        @anopsia1000 Check you connections, -273 usually means a short.
          dc42 administrators @Anopsia1000
          @anopsia1000 does it really have a resistance of 4.6Mohms at 25C? If so then it's going to be hard to read at room temperature.
          How old is the tool board? If it wasn't running firmware 3.3 when you received it, then you may need to run calibration (using 3.3 or 3.4beta firmware). See https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings.
          Anopsia1000undefined 1 Reply Last reply Reply Quote 0
            Anopsia1000 @dc42
            @dc42 Thanks for the answers.
            Wiring is brand new, no shorts. I confirm the T25 R is 4606017 ohm.
            board: duet 3mb6hc
            firmware: 3.3 config w/ reprap online configurator.
            Will try the calibration.
            At room temp on a duet2 firmware 2 I have no issue beside the usual low accuracy at room temp.
              @Anopsia1000
              That command says that sensor 1 is connected to a tool board, not the 6HC main board. Is that correct?
              • TLASundefined
                TLAS @Anopsia1000
                @anopsia1000
                Please keep in mind that most thermistors are rated to ~250C. If you went above that, it’s a gamble if it’ll read correctly or survive without a short.
                • zaptaundefined
                  zapta @Anopsia1000
                  @anopsia1000 , can you share the specifications/datasheet of your thermistor?
                  Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                  • Gixxerfastundefined
                    Gixxerfast @zapta
                    @zapta It's most likely the Trianglelabs D500 thermistor.
                    Datasheet in here:
                    https://forum.duet3d.com/topic/24306/duet-2-wifi-problem-with-the-t-d500-thermistor
                    Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                    Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                    Ender 3 Pro with BTT SKR-2 + RRF
