    InputShaping plugin shows only zeros for frequencies
    Plugins for DWC and DSF
    844
      dc42 administrators @flopo76
      @flopo76 please make the .csv file available. I suspect the rate has been recorded as zero, which we have a few other reports of.
      flopo76undefined 1 Reply Last reply Reply Quote 0
      • flopo76undefined
        flopo76 @dc42
        @dc42 121_2021-08-21_08.22.00.csv
        flopo76undefined dc42undefined 2 Replies Last reply Reply Quote 0
        • flopo76undefined
          flopo76 @flopo76
          @flopo76 I have another Voron with same board and tool board and work very well
            @flopo76 thanks. That .csv file looks OK apart from some axes being swapped, so I would expect it to display correctly. Are you able to display it in the Accelerometer plugin?
            • flopo76undefined
              flopo76 @dc42
              @dc42 Yes,i posted a screen shot,the csv are displayed but no frequnzy,all 0.0 in all axes
              • flopo76undefined
                flopo76 @flopo76
                @flopo76 https://youtu.be/ZoDT4MqVUQc
                • mfs12undefined
                  mfs12
                  @flopo76 can you record a csv file with the accelerometer plugin and share it in the forum?
                  This bugs looks same as the issue @Heartleander81 reported.
                  https://forum.duet3d.com/topic/25433/inputshaping-plugin-shows-only-zeros-with-toolboard-1lc
                  Visit me on github at https://github.com/mfs12/
                  • mfs12undefined mfs12 referenced this topic
                  • mfs12undefined mfs12 moved this topic from Tuning and tweaking
                  • mfs12undefined mfs12 marked this topic as a question
                    @flopo76 please see this post https://forum.duet3d.com/topic/25433/inputshaping-plugin-shows-only-zeros-with-toolboard-1lc/37?_=1636541195995 and the following ones. I suspect your tool board has a similar issue.
                    • flopo76undefined
                      flopo76 @dc42
                      This is my board. No diode. What type of diode need to soldering? I have 4 tool board in my lab. one is 1.2 version others 1.1 but all with diode mounted.20211110_143604.jpg
                      • Gixxerfastundefined
                        Gixxerfast
                        What 1LC V1.2? When did that happen and any new features?
                        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                        Ender 3 Pro with BTT SKR-2 + RRF
                          @flopo76 the diode part number we use is MMSD4148G. Electrically, any small signal silicon (not Schottky) diode will do. We chose that one because the SOD123 package it comes in is the right size to fit across those pads (just). There is also a fine trace between the two PA19 pads which needs to be cut. The cathode of the diode is connected to the PA19 pad and the anode to the PA0 pad.
                          @Gixxerfast revision 1.2 is a minor revision to avoid the need to solder the diode on the back, also we moved some components around. The only significant feature it has compared to version 1.1 is that it has pads for fitting a reflective opto sensor as a tool docking switching as an alternative to the pads for a microswitch.
                          • flopo76undefined
                            flopo76 @dc42
                            @dc42 said in InputShaping plugin shows only zeros for frequencies:
                            MMSD4148G
                            Ok, is a 1n4148 diode,i have i, even in smd case. Thanks.
                            • mfs12undefined
                              mfs12
                              @flopo76, did this solve your problem?
                              • flopo76undefined
                                flopo76 @mfs12
                                @mfs12 Yes solved. Thanks
                                • dc42undefined dc42 has marked this topic as solved
