G29.g? Somehow?
Hi *,
I have the problem that I have some dependencies before I can execute G29 itself. So I wrote a macro and placed in in 0:/macros/30_blabla.g which I can execute easily. No problems so far. It happened a couple of times now that I have forgotten that (to many printer problems) and executed the G29 directly from the DWC menu at the top. That ended all the time in a nice hole in the PEI because at this time is the wrong endstop active.
It would be very nice if there would be the possibility to have something like a G29.g which will be executed if it is present or something like that.
Cheers, Chriss
@chriss create a file called mesh.g
That's ran when G29 is ran.
You can put your dependencies in there followed by G29 S0 -
@jay_s_uk Thanks, I will test that and I will play a bit with that.
Is there a list of all files RRF is using/possible?
I search that list almost every time I configure a new printer.
Cheers, Chriss
@chriss here you go
https://duet3d.dozuki.com/Wiki/Macros -
Thanks.... bookmarked it.
