    Minimum Viable Duet3 CNC Hardware
    CNC
    9
    12
    1.0k
    • natewalckundefined
      natewalck
      Hey all!
      I am working on a PrintNC build and happen to have a spare Duet3 that I intend to use for the PrintNC.
      It uses a VFD Spindle, which I intend to use a PWM to 0-10V board to adapt for Duet3 use (Something like this: https://www.amazon.com/DAOKI-Voltage-Converter-Interface-Switching/dp/B081W4NTML .Thanks to folks in PrintNC discord for this tip).
      As for powering the steppers, I assume the thing to do is 32V input for the 5160s, correct?
      Does anyone have suggestions on a solid 32V PSU that would be able to power some beefy Nema23s?
      So to summarize, the list of needed hardware as I understand it:
      • Duet 3
      • PWM to 0-10V Board for VFD control
      • Nema 23s for each axis
      • Spindle (In my case, a 2.2Kw VFD spindle)
      • 32V Power Supply
      • Endstops
      Is there anything else that would be useful on the hardware end in relation to running a CNC using a Duet 3?
      I think having a known good hardware setup for each CNC size/class may be nice, then people can jump right in and riff on it as desired.
        jay_s_uk
        Welcome. I have a printNC but use external drivers with the STM port of RRF.
        Don’t know if any PSUs off the top of my head.
        The Duet 3 already supports VFDs natively so you don’t need the converter board.
        PM me and I can share you my config etc.
        I’m on discord on the printNC channel under this username
        Tsolsiundefined 1 Reply Last reply Reply Quote 1
          T3P3Tony administrators
          the Duet 3 6HC has a 0-5V PWM output that can be used to drive a voltage converter like the one linked, It does not have a direct 0-10V VFD driver on board.
          Other than that I am not familiar with the printNC.
          • SDJundefined
            SDJ
            I built a CNC machine recently using these components and a duet2. I had issues with the PWM converter you linked to. I would recommend this one instead. Both, however, say limit 30V, not 32V.
            I use two of those PWM converters, one on E0heat to enable spindle on as my VFD requires a 10V signal input to do so, and one on E1heat for spindle speed. The Duet uses the difference between Vin and E0- or E1- for the PWM signal. That means E0- and E1- start at Vin (no PWM) and goes down to 0 (diff = Vin = max PWM).
            The PWM converter board you linked to cannot handle this. It only works if both Vin and E0- or E1- start at 0V/PWM, and E0- or E1- goes to Vin. You can enable this using !E0heat in RRF3, but I would not do this. There is a dangerous issue with this setup. Let's say you have a problem and you hit the emergency stop button to reset the board. There is a brief moment, maybe before the !E0heat in the config takes over, that E1 and E0heat briefly pulses to Vin. The board you linked to sees this as max PWM and Spindle On basically turning the emergency stop into a temporary spindle on at max speed button. This isn't a problem starting up the machine since the VFD takes longer to come online. But any reset where the VFD is ready to go and you E-Stop, boom.
            I would suggest NO prox sensors rather than NC for redundancy and I am also using an 8 channel relay to isolate between prox sensors and z-probe from the duet.
              dc42 administrators @SDJ
              @SDJ said in Minimum Viable Duet3 CNC Hardware:
              In RRF 3.2beta we've changed the way this works, to be more compatible with typical VFD spindle controllers.
              • Tsolsiundefined
                Tsolsi @jay_s_uk
                @jay_s_uk Hi there, you have any config file for CNC for duet 3? I am so stuck with it, I don't even know which IO to connect the end stops to in combination with which driver motor.
                Would you tell me maybe what you have? Or share config file with a short explanation or a pointer to where to look?
                Starting in CNC with a duet 3 and a bit of lost now.
                Thank you very much 🙂
                  jay_s_uk @Tsolsi
                  @Tsolsi I've pm'd you
                  MortarArtundefined 1 Reply Last reply Reply Quote 1
                  • MortarArtundefined
                    MortarArt @jay_s_uk
                    @jay_s_uk hi! Is there any chance that I could get a config as well? I'm looking at building a PrintNC with the Duet3 as well.
                    Also; as to the details outlined by SDJ; I'm assuming that's now resolved due to the updates dc42 mentioned?
                    Has anyone in this thread used a PrintNC to trim mild steel plate? Looking at very shallow cuts, to get shop bought plates to a set length on one axis.
                    • tenajaundefined
                      tenaja
                      You need NC end-stop switches so the machine stops if there's a broken wire, for safety.
                      That looks like a nice machine design... I've bookmarked it for my wish list.
                      Keep in mind that the duet fw doesn't have backlash compensation, and a nice machine like that will be held back by that limitation. A while back, somebody posted a python script (I think) to add it to the gcode. This is far from optimal, but a reasonable compromise.
                      I've used several duets on some small cnc's where backlash isn't a factor, but when (if) I build a cnc router, it'll definitely have a control with backlash in it. I found LinuxCNC to be excellent, and would certainly use it again.
                      Then again, if you are just making big wooden signs or other artistic objects, backlash is nothing... But some of those videos show the design cutting steel and aluminum, and it typically matters more with mechanical objects than artistic objects. Sure, you can fudge it like we do with our 3d printers (add 1 percent here & there, etc) but it's easier when it's accurate.
                      MortarArtundefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
                        MortarArt @tenaja
                        @tenaja so according to this video, backlash is pretty minimal, though I do take your point. Even that small amount can result in parts that are not fit for purpose. I'm going to be investigating how to minimise that for my build.
                        I'll also start out operating the router semi-automatically to begin with, to get used to CNC operations, as I come from a manual machining background.
                        What are NC end-stop switches? No contact?
                        • rjenkinsgbundefined
                          rjenkinsgb @tenaja
                          @tenaja said in Minimum Viable Duet3 CNC Hardware:
                          From a quick look at the mechanical design, it should be simple to use two nuts on each screw if backlash could be a problem.
                          Mount the second using screws with spring washers / belleville washers and just enough preload tension to stabilise the axis, without putting excess load on the nuts.
                          A lot of machine tools used that type of system, even with Acme screws. You can also get ballscrews (at least in larger sizes) that have true "Anti backlash" nuts, with two short ballnut units in overall nut housing, with one being threaded in and adjustable.
                          Note that many places selling the small rolled screws claim the nuts are anti-backlash despite being single units... I think they must be comparing to acme screws.
                          More info:
                          https://www.linearmotiontips.com/ball-screw-preload-what-you-need-to-know/
                          Robert J.
                          Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                          • tenajaundefined
                            tenaja
                            True, you can get anti backlash screws, and they'll make a better machines. But that doesn't fix the backlash in the bearings. It's also a lot more expensive.
                            NC switches are "Normally Closed" (conducting). You use that setup so when a wire breaks, you don't lose safety. Always consider safety when making setup choices. Maybe a router that operated at a snails pace with undersize motors doesn't have the same safety issues, but it starts good habits and avoid copy-paste into a machine that is more substantial.
