Duet resetting when using air pump
Hmm. Interesting idea. I don't think so, but that I guess something like that would cause it to draw too much current, right? If I connect it to my bench power supply, which has a current meter, it runs along just fine around 540-550 mA without any apparent problems. I guess there could be some kind of momentary surge of current that I couldn't see on that display.
The Duet is doing nothing else (as far as I know). I just go to the web interface and set the fan speed and it dies after a few seconds.
I have now tried connecting a power MOSFET between Duet and the air pump, but that didn't make a difference either. Perhaps there's a momentary short in the pump, which I might not notice when using the bench power supply, which probably has protection against that. No idea what I would do about that, though. Buy a new pump?
The power MOSFET should protect the Duet from that sort of stuff. Are you running the pump.off a seperate supply.niw you are using an external supply? Another thing worth a try is switching fan pins to see if there is an issue with that particular fan channel.
That pump looks like the same one I'm using best I can tell from the pic. I have a small 12V 5A power supply for the pump and a 24V supply for everything else. Before I installed mine I tested on 24V and the instaneous power on spike was in the range of 3.2A and the pump ran really hot so I used a separate 12V supply. They (China) advertised 24/12V but running the numbers down on the motor itself led me to the conclusion that mines a 12V 550. I finally ran down what I think is the actual manufacturer.
It might be worth putting a power resistor in series with the motor to limit current surges. If its running current is about 0.5A then a value of 1 to 2 ohms should be about right.
If the motor has a built-in capacitor for interference suppression, that would give rise to current surges when PWM is used - giving another reason to add the resistor.
David what sort of power rating would you suggest?
I have a 24V version of the same/similar pump and have not had any issues yet. I generally run it at 0.3-0.7 PWM.
The steady-state power dissipation @ 0.5A would be 0.25W for a 1 ohm resistor, or 0.5W for a 2 ohm resistor. So 1W or 2W should be adequate unless the motor stalls.
Thanks David hope to see you at TCT on the Wednesday
Doug
If the motor has a built-in capacitor for interference suppression, that would give rise to current surges when PWM is used - giving another reason to add the resistor.Interesting. Thanks, I will try that tonight. I don't have any power resistors, but putting eight 0.25 W, 15 Ξ© resistors in parallel should work for now.
Just my thoughts : What's happening at that same moment in your printer.
I mean the sum of all currents has to be less or equal to the current the PSU can supply β¦
Could be a power dip too. -
also just for info I now have my pump connected and running on Fan0 connector set as a print fan and it works just fine and can adjust the speed from the Panel due as expected get masses of air thru the berd air tube now don't think I will ever have to run it at above 25% more likely 15-20 will be the sweet spot
Could be a power dip too.As far as I know, nothing else is happening. I first discovered this problem when trying to print, but turning the fan (pump) on manually in DWC is enough to reproduce the issue. The PSU capacity is ample. 600W should be enough for Duet and a pump
Unless your heater draws something like 595W, this should be sufficient indeed
Is the metal frame of the pump motor in contact with anything? Do the wires between the Duet and the motor run parallel with any other wires? I'm wondering if it could be an interference issue.
It might be worth putting a power resistor in series with the motor to limit current surges. If its running current is about 0.5A then a value of 1 to 2 ohms should be about right. If the motor has a built-in capacitor for interference suppression, that would give rise to current surges when PWM is used - giving another reason to add the resistor.
So I just tried this, and⦠no difference.
No, I have isolated the pump in a plastic shell. Same thing when it's laying bare on a [wooden] table. I have tried keeping the wires from being near anything else, and it doesn't make a difference.
Can you provide photos of the wiring between the air pump and the Duet?
Does the problem definitely go away if you disconnect the air pump and then go through the same sequence?
Sure! Here's the pump side:
Excuse the ugly blob of resistors! The diode is a 1N4007. The black/red wires are about 80 cm long and end up here, in FAN0, on the other side:
Yep. If I disconnect the pump from FAN0 and turn on the fan in DWC, Duet never resets.
And same thing if I connect a normal fan. It spins happily and Duet runs fine.
Are you certain that the wire coming out of the right hand side of the diode isn't shorting against the motor casing? In the photo it looks as if it could be, but perhaps that's just because of the angle that it's taken from.
