Duet 3 6HC com port doesn't appear (Windows)
@coen_l is it too far away?
can you give a bit more info?
whats on the sd card?
how are you powering the board?
whats in your config file? -
@jay_s_uk I guess
It's all very new to me. Sorry
- SD card: all original files on SD card supplied with the Duet 3. Date of files 15-2-2021 + my delta config
- Connected to a 12v HP server power supply.
; Configuration file for Duet 3 (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Nov 27 2021 22:45:11 GMT+0100 (Midden-Europese standaardtijd); General preferences
M550 P"Opiliones" ; set printer name
M665 R267 L525 B175 H700 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M551 P"DraadLoos" ; set password
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z1500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
M574 Y2 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
M574 Z2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in; Z-Probe
M558 P5 R0.4 C"io3.in+io3.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
M557 R85 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M143 H1 S250 ; set temperature limit for heater 1 to 250C; Fans
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
@coen_l said in Duet 3 6HC com port doesn't appear (Windows):
My New Duet 3 6HC is not recognized by my laptop. I have tried different USB cables and laptops. With the same result, no COM-port response and no confirmation sound when a USB is plugged into the laptop.
Do any of the LEDs on the board light up when you connect it to USB?
It can be very picky about USB cables and ports.
@phaedrux same LEDs light up when the board is connected to 12v
Can you try working through this guide?
https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
Step: "If no port appears, or you get a Windows error message several seconds after you connect the Duet via USB, try connecting it to a different USB port, and try using a different USB cable, making sure that the USB cable is a data cable (some USB cables provide power only)."
No restult.Step: "If the port still doesn't appear on the PC
If neither port is shown, then the Duet may be faulty or it may not have valid firmware installed. With USB power applied, erase the firmware. Only erase the firmware if your board is completely unresponsive, or if instructed to do so by Duet3D."If I'm seeing correctly, I'll have to clear the Firmware then. Spooky! what happens to the warranty?
I don't understand the question. Reflashing the firmware and warranty are not related. If we can't get it up and running your warranty would then take over. Fear not.
To try clearing the firmware and getting it to show up as a firmware flashing port in windows follow this: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_To_update_via_USB_using_a_Windows_host
@phaedrux
It's good to hear that firmware and warranty are not related. Then I can go through the steps with a calmer feeling. I'm going to give it a try in a minute. Gather some courage firstThank you for your help.
There's little to worry about. It's basically impossible to brick a Duet with a firmware update. Even a failed one.
The trick will be getting it to show up in windows as a USB device.
Do you happen to have a powered USB hub?
@phaedrux said in Duet 3 6HC com port doesn't appear (Windows):
My laptop has ss usb ports.
Just completed the firmware flash successfully thanks to your help. The Duet is now also visible in device manager.
It is correct that the "Status" LED is blinking right?
Thank you very very much for your help!
@coen_l I'm glad you got it working. It's normal for Duet 3 boards to blink that red LED at 1Hz. The reason they do is so that when you connect expansion boards via CAN bus, you can see when they are communicating because the red LEDs all blink in sync.
@dc42 Thanks for the info.
Just signed up with DWC, very nice interface. Now I can continue with the next step, installing the electronics and connecting.
It's amazing how quickly help is provided. I really appreciate it.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
