    Mini 5+ wifi: unable to open DWC
    Duet Web Control
    591
    • Sebastian 0undefined
      Sebastian 0 @T3P3Tony
      @Phaedrux Here is my config.g file
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"V-Core 3"                        ; set printer name
      M669 K1                                 ; CoreXY
      G29 S1                                  ; Set Units to Millimeters
      M552 P0.0.0.0 S1                        ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0.0 S1 D3                         ; physical drive 0.0 goes forwards
      M569 P0.1 S1 D3                         ; physical drive 0.1 goes forwards
      M569 P0.2 S1 D3                         ; physical drive 0.2 goes forwards
      M569 P0.3 S1 D3                         ; physical drive 0.3 goes forwards
      M569 P0.4 S1 D3                         ; physical drive 0.4 goes forwards
      M569 P0.5 S1 D3                         ; physical drive 0.5 goes forwards
      M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00               ; set steps per mm
      M906 X1000 Y1000 Z800 I30               ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M566 X400.00 Y400.00 Z6.00 E120.00 P1          ; set maximum instantaneous speed changes (mm/min)
      M203 X10800.00 Y10800.00 Z1000.00 E3600.00     ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E3600.00        ; set accelerations (mm/s^2)
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X310 Y300 Z300 S0                         ; set axis maxima
      M574 X1 S1 P"io1.in"                           ; configure active high endstops
      M574 Y2 S1 P"io0.in"                           ; configure active high endstops
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M671 X-4.5:150:304.5 Y-4.52:305:-4.52 S5       ; define positions of Z leadscrews or bed levelling screws
      M557 X20:280 Y20:280 P5                        ; define 5x5 mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"    ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                     ; create bed heater output on out5 and map it to sensor 0
      M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S110                                           ; set temperature limit for heater 0 to 110C
      ;; Run Bed PID Tune!! Bellow is an example for a 300x300 bed
      ;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0
      M950 F0 C"out3" Q500                   ; create fan 0 on pin out3 and set its frequency
      M106 P0 C"Hotend Fan" S0 H1 T45 L255   ; set fan 0 name and value. Thermostatic control turned on for Hotend
      M950 F1 C"out4" Q500                   ; create fan 1 on pin out4 and set its frequency
      M106 P1 C"Layer Fan" S0 H-1 L255       ; set fan 1 name and value. Thermostatic control is turned off
      M563 P0 D0 H1 F1           ; define tool 0
      G10 P0 X0 Y0 Z0            ; set tool 0 axis offsets
      G10 P0 R0 S0               ; set initial tool 0 active and standby temperatures to 0C
      M950 H1 C"out1" T1         ; create nozzle heater output on out2 and map it to sensor 1
      M307 H1 B0 S1.00           ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S250               ; set the maximum temperature in C for heater
      ; EVA 2 / BMG / E3D V6
      M92 E830          ; set extruder steps per mm, 0.9 angle/step (LDO Pancake)
      M906 E800         ; set extruder motor current (mA) and idle factor in per cent
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend"
      ;; Run Heater PID Tune!!
      ;; M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0
      ;; Inductive Probe
      ; M558 P5 C"!io3.in" H5 F400 T5000       ; set Z probe type to unmodulated and the dive height + speeds
      ; G31 P500 X-30 Y-15 Z0.20               ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ;; BLTouch
      ; M950 S0 C"io2.out"                     ; Create a servo pin on io2
      ; M558 P9 C"io2.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
      ; G31 P25 X-28.00 Y-13.00 Z0.90          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      M404 N1.75 D0.4                                 ; Filament width and nozzle diameter
      T0
      ; Pressure Advance
      ; M572 D0 S0.10
        @t3p3tony As far as I can tell the wifi network was added successfully. But the generated IP address is not accessible via my browser.
        M552 S-1
        WiFi module stopped
        ok
        M552
        WiFi module is disabled
        ok
        M552 S0
        ok
        WiFi module started
        M587 S"FRITZ!Box 7490" P"myPassword"
        Remembered networks:
        TNCAPF318D9 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
        FRITZ!Box_V-Core3 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
        ok
        M552 S1
        ok
        WiFi module is connected to access point FRITZ!Box_V-Core3, IP address 192.168.179.2
          Phaedrux Moderator @Sebastian 0
          @sebastian-0 said in Mini 5+ wifi: unable to open DWC:
          The command doesn't match the comment here. Setting to MM is G21. G29 S1 is loading the mesh heightmap which you do now want to do in config.g. You want to do that after you've homed the printer and most importantly after the Z axis has been homed with the probe.
          M552 P0.0.0.0 S1
          I can't tell what it's complaining about here. I would suggest trying just M552 S1 and remove the P0.0.0.0 entirely. DHCP is the default anyway. Delete the line entirely and type it from scratch.
          See if that will connect to wifi at startup and allow the DWC to load.
          RepRapFirmware for Duet 3 Mini 5+ version 3.2.2
          I would also suggest that you update your firmware to 3.3
          As you don't currently have access to the DWC to upload the firmware you can use the USB method shown here if that doesn't fix the network connectivity.
          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
          Then you can manually update the DWC files by extracting the zip file to the /www folder on the SD card.
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWebControl-SD.zip
          Sebastian 0undefined 1 Reply Last reply Reply Quote 0
            Sebastian 0 @Phaedrux
            @phaedrux When trying to connect to my FritzBox (with the guest account (FRITZ!Box_V-Core3) deactivated) with the SSID and password of my main account (FritzBox! 7490) the following happens: (I made sure the password is typed in correct)
            M552 S-1
            WiFi module stopped
            ok
            M552
            ok
            M552 S0
            ok
            WiFi module started
            M587 S"FRITZ!Box 7490" P“myPassword“
            ok
            M552 S1
            ok
            WiFi reported error: no known networks found
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            with the guest account activated this happens (again using the SSID and password of my main account)
            M552 S-1
            WiFi module stopped
            ok
            M552
            ok
            M552 S0
            ok
            WiFi module started
            ok
            M552 S1
            ok
            So maybe the reason for this issue is my router or some router settings.
            In any case I’ll try to update the Mini5+ firmware.
            T3P3Tonyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              T3P3Tony administrators @Sebastian 0
              ok so that looks good - you are getting an IP address and its connecting. I would use that network for now. The PC you are connecting from needs to be on the same network - it probably won't work with your PC on the main network and the Duet on a guest network.
              if you can ping 192.168.179.2 from your PC (which should also be on 192.168.179.X) then what happens when you try and connect to that IP in a browser?
                P“myPassword“
                The quotes around that password look strange. I would suggest creating a macro with the M587 command in it to join the network with your password in that. Then use M98 P to call that macro from the usb terminal. That avoids using the USB terminal to send the password itself which can sometimes send different characters than intended.
                Sebastian 0undefined 1 Reply Last reply Reply Quote 2
                  @t3p3tony This is what happens when I type in the IP address.
                  Bildschirmfoto 2021-12-01 um 16.15.40.png Bildschirmfoto 2021-12-01 um 16.13.17.png
                    @phaedrux Unfortunately, I have no idea of how to write macros. In the original code, however, the quotation marks look exactly like those in the SSID. The formatting was probably changed when the password was substituted.
                      A macro is just a text file that contains the gcode commands you want to send.
                      Here's an example of one to add the SSID.
                      ; Add default wifi network
                      M552 S0			; Disable network module
                      G4 S5			; wait 5 seconds
                      M587 S"NETWORKNAME" P"PASSWORD"			; Add duet wifi SSID to remembered networks list
                      M552 S1			; reenable wifi module
                      If you save that as a text file called addwifi.g and place it in the sys folder on the SD card you can then execute it from the usb terminal with M98 P"addwifi.g"
                      This ensures that your password isn't getting modified by the USB terminal sender which can sometimes happen.
                      It may also help to use M588 S"*" to clear out all saved networks first before readding it.
                      • rjenkinsgbundefined
                        rjenkinsgb
                        This may be relevant to the networking problem:
                        I've just today received another new Duet 3 6HC board. I don't have the machine assembled yet, but I was curious what the board alone would do, and what firmware was pre-loaded - V3.3, as it happens.
                        I connected it via USB & connected to the port that appeared (COM10) using Realterm.
                        Then I plugged in the Ethernet cable; it gave a message stating its IP address was 192.168.1.14
                        My network runs on 192.168.0.x and the DHCP server only issues addresses in the range 0.100 - 0.199, as I use static IP addresses for all fixed devices.
                        Seeing the 1.14 address in the thread above makes me think there is a bug in the firmware.
                        (My previous Duet 6HC build has only ever run is SBC mode, I never had cause to directly connect Ethernet to it).
                        Robert J.
                        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                        Dougal1957undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                        • Dougal1957undefined
                          Dougal1957 @rjenkinsgb
                          @rjenkinsgb IIRC that address is coded into the default Config for the purposes of QC testing but that will need someone from Duet to confirm that or you could just check it yourself
                            T3P3Tony administrators @rjenkinsgb
                            @rjenkinsgb yes that's the testing IP in the default config.g, it not hardcoded in anywhere. The default config should also give a warning to replace it with one from the config tool.
                              @phaedrux The firmware is now updated (Version 3.3). Like you advised I created a macro, but the DWC is still not opening.
                              M669 K1                                 ; CoreXY
                              G21 S1                                  ; Set Units to Millimeters
                              M588 S"*"                               ; clear out all saved networks first before readding it
                              M98 P"addwifi.g"
                              M552 S1                                 ; enable network and acquire dynamic address via DHCP
                              RepRapFirmware for Duet 3 Mini 5+ version 3.3
                              Executing config.g… Error: Failed to reset the WiFi module to factory settings: WiFi module is disabled
                              Error: Failed to add SSID to remembered list: WiFi module is disabled
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              Warning: Sensor number 1 has not been defined
                              Done!
                              RepRapFirmware for Duet 3 Mini 5+ is up and running.
                              WiFi module started
                              Error: Temperature reading fault on heater 1: sensor open circuit
                                ; Network M588 S"*" ; clear out all saved networks first before readding it M98 P"addwifi.g"
                                These lines should be removed from config.g. You'll have to use the USB terminal to send each of those commands separately. They only need to be sent once.
