    BED height map problem
    591
    • fcwiltundefined
      fcwilt @matej1006
      @matej1006 said in BED height map problem:
      @fcwilt
      i order form one German site which have special aluminuim which won't bend as basic aluminium
      i paid much more for it
      Can you provide a link to the site?
      matej1006undefined 1 Reply Last reply Reply Quote 0
      • matej1006undefined
        matej1006 @jay_s_uk
        @jay_s_uk Hello Jay
        maybe you will remember my problem hehe.
        i will add some picture of my gantry and whole core-xy
          matej1006 @fcwilt
          @fcwilt i will try to find it long time pass from when i ordered.
          i think is like 18 month's
          CanDo415undefined 1 Reply Last reply Reply Quote 1
          • CanDo415undefined
            CanDo415 @matej1006
            @matej1006
            Do you use a magnetic bed?
            I have the same problems with a 355x355 bed.
              matej1006 @CanDo415
              @cando415
              yeah from ziflex, realy and also like almost 1mm deviation
              CanDo415undefined 1 Reply Last reply Reply Quote 0
              • CanDo415undefined
                CanDo415 @matej1006
                @matej1006
                tyr the mapping cold and compare with a hot mapping. I think the differences are a problem of the magnethight
                  matej1006 @CanDo415
                  @cando415 i did and there was not a lot of difference
                  • CanDo415undefined
                    CanDo415 @matej1006
                    @matej1006 so the temperature is not the problem
                      T3P3Tony administrators @CanDo415
                      @cando415 if you have a straight edge you will be able to confirm quickly that its not the bed that is that warped. I think @jay_s_uk was right with the gantry.
                        matej1006 @T3P3Tony
                        @t3p3tony yeah i will just unscrew a little all screw in linear rail and then try.
                        Maybe i have ma linear rails in back more closer than in the front of printer.
                        i hope is that 😉
                        Matej
