    Delta Z triggered height
    545
      T3P3Tony administrators @Gaou
      @gaou said in Delta Z triggered height:
      procedure to measure triggered heights by smart effector.
      part of the benefit of using a smart effector is that the nozzle is the probe so you should not need to set individual trigger height offsets for each probe point.
      Gaouundefined 1 Reply Last reply Reply Quote 0
      • Gaouundefined
        Gaou @Phaedrux
        @phaedrux said in Delta Z triggered height:
        On the documentation is says that i need to specify the triggered height for the center of the bed and then every point on my bed config.
        Can you point me to the page you're seeing this please?
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        Delta Printer || Duet 0.85 || firmware 1.23
        Laser K40 || Duet 0.85 || Firmware 1.26.1 || Web 1.22
        • Gaouundefined
          Gaou @T3P3Tony
          @t3p3tony said in Delta Z triggered height:
          i am trying to fine tune my deltas and as far as i know i have to go trough the process that documentation says. i am printing alright but i want to go after for that perfect thing.
            Have you actually measured a variance in trigger height based on XY location?
            • Gaouundefined
              Gaou @Phaedrux
              i am not sure i got what you asked. in every bed point of my 10's i got a different triggered height.. even in one spot ( let's say the center i got a different triggered height every time . on the X0Y0 there is a variation of one thousand of a milimeter no matter what i do ...!
                Do this test at multiple points on the bed. Test each point multiple times.
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                Do you have variance over multiple probings at the same spot?
                Do you have variance between different XY points on the bed?
                • Gaouundefined
                  Gaou @Phaedrux
                  This is the procedure i follow. done this hundered times on each of my printers.
                  Yeap....
                  Yes
                  achrnundefined 1 Reply Last reply Reply Quote 0
                    Can you share your config, homedelta, bed.g, M122, etc?
                    • achrnundefined
                      achrn @Gaou
                      Yeap....
                      Is it meaningful variance? You've previously referred to it being "a variation of one thousand of a milimeter no matter what i do"
                      If it's a conventional delta, 20 tooth drives, 2mm pitch belt, 400 step motor, 16x microstepping, one microstep is six thousandths of a millimetre, so getting one thousandth repeatability is remarkably good, and I doubt can be improved.
                      • Gaouundefined
                        Gaou @Phaedrux
                        config.g bed.g
                          What do you have in config-override.g?
