    after print part orientation change
    914
      Phaedrux Moderator @patel
      @patel said in after print part orientation change:
      @phaedrux Thank you for reply
      I made corrections but still results is the same
      Can you post your homing files as well please?
      Can you confirm for me a few details?
      Where are your endstops located? Photo?
      When looking at the printer from the front, the 0,0 position should be located at the front left corner.
      -X should move to the left, +X should move to the right, -Y should move to the front, +Y should move the back.
      patelundefined 2 Replies Last reply Reply Quote 0
      • patelundefined
        patel @Phaedrux
        @phaedrux
        I send all data tomorrow. We have power outage today
        Sorry for delay
        • FrankVundefined
          FrankV
          As earlier mentioned, I think you have to rule out some things:
          Is your x motor your x motor. (sending gcode)
          Is your y motor your y motor. (sending gcode)
          Does they rotate in the correct way. (sending gcode)
          Does x home before y?
          Read your gcode in another slicer (or gcode viewer) and see the result.
          From there you can troubleshoot. Looks to me you changed x and y.
          • patelundefined
            patel @Phaedrux
            ; Configuration file for Duet WiFi (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Dec 12 2021 20:23:27 GMT-0600 (Central Standard Time)
            G21
            M669 K0
            M550 P"My Printer" ; Set machine name
            M552 S1 ; Enable network
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M584 X0 Y2 Z1 E3 ; set drive mapping
            M92 X87.50 Y87.50 Z1052.20 E476.50 ; set steps per mm
            M84 S30 ; Set idle timeout
            M208 X260 Y280 Z215.8 S0 ; set axis maxima
            M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
            M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
            M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
            M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
            ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
            ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
            M308 S1 P"e0temp" Y"pt1000" ; sensor 1
            M950 H1 C"e0heat" T1 ; create heater and map sensor 1
            M950 F0 C"fan1" Q500 ; create fan 0 on pin fan1 and set its frequency
            HOME FILE
            ; homex.g
            ; called to home the X axis
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Dec 15 2021 15:04:17 GMT-0600 (Central Standard Time)
            G91 ; relative positioning
            G1 H1 X-265 F1800 ; move quickly to X axis endstop and stop there (first pass)
            G1 H2 X5 F6000 ; go back a few mm
            G1 H1 X-265 F360 ; move slowly to X axis endstop once more (second pass)
            G1 H2 Z-5 F6000 ; lower Z again
            G90 ; absolute positioning
            ; homey.g
            ; called to home the Y axis
            G1 H1 Y-285 F1800 ; move quickly to Y axis endstop and stop there (first pass)
            G1 H2 Y5 F6000 ; go back a few mm
            G1 H1 Y-285 F360 ; move slowly to Y axis endstop once more (second pass)
            ; homez.g
            ; called to home the Z axis
            G1 H1 Z-220.8 F1800 ; move Z down until the endstop is triggered
            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
            ;G91 ; relative positioning
            ;G90 ; absolute positioning
            ; homeall.g
            ; called to home all axes
            G1 H1 X-265 Y-285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-265 Y-285 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G1 H1 Z-220.8 F360 ; move Z down stopping at the endstop
            patelundefined 1 Reply Last reply Reply Quote 0
            • patelundefined
              patel @patel
              @patel
              M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
              M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                @patel
                Which is it?
                Is the red dot the endstop location for both X and Y?
                @phaedrux said in after print part orientation change:
                Does it move like this?
                • patelundefined
                  patel @Phaedrux
                  @phaedrux
                  Yes red dot end stop switch
                  • patelundefined
                    patel @Phaedrux
                    @phaedrux
                    thank you very much you fix my printer .
                    1 week i am looking problem . lot of search google, lot of change file but what you say When looking at the printer from the front, the 0,0 position should be located at the front left corner.
                      @phaedrux
                      If that's the case, then then endstop definition should be X at low end (M574 X1) Y at high end (M574 Y2) and the homing moves should change to have X move negative to the left and Y move positive to the back.
                      If those movement directions are no correct, then the motor rotation may need to change in M569. https://duet3d.dozuki.com/Wiki/M569
                      • patelundefined
                        patel @Phaedrux
                        @phaedrux
                        Know ok
                        Thank you again for helping me
                        • Phaedruxundefined Phaedrux has marked this topic as solved
