    [3.4.0b7] Firmware update changes 1LC temp
    Beta Firmware
    13
    59
    3.6k
      jay_s_uk @Alex.cr
      @alex-cr I am also getting this on one toolboard.
      3.4b6 reports the normal room temperature. 3.4b7 reports -4.6 degrees.
      going back to 3.4b6 on the toolboard fixes the issue
      • Alex.crundefined
        Alex.cr @Gixxerfast
        @gixxerfast
        Yup can confirm.
        12/17/2021, 6:36:06 PM	M115 B20
        Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta7 (2021-12-16 12:25:01)
        @jay_s_uk
        Thanks for confirming.
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        Gixxerfastundefined 1 Reply Last reply Reply Quote 0
        • Gixxerfastundefined
          Gixxerfast @Alex.cr
          @alex-cr Do you have a thermistor or a pt1000 or something else?
          Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
          Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
          Ender 3 Pro with BTT SKR-2 + RRF
          Alex.crundefined 1 Reply Last reply Reply Quote 0
          • Alex.crundefined
            Alex.cr @Gixxerfast
            @gixxerfast
            PT1000 in my extruder on the 1LC.
            There are two thermistors for my heat bed on the 6HC. There is also a thermistor as one of my chamber sensors on the 3HC. These were unaffected.
              Gixxerfast @Alex.cr
              @alex-cr So strange, I have a pt1000 as well. Wonder what this problem can be caused by.
              • Alex.crundefined
                Alex.cr @Gixxerfast
                @gixxerfast
                Not sure but I remember this happening during another beta. It may have been in the 3.3 beta series.
                • Fumbleundefined
                  Fumble
                  I’m running one V1.0 toolboard and one V1.1, both with thermistors
                  M308 S2 P"020.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin 121.temp0
                  M308 S3 P"021.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 3 as thermistor on pin 121.temp0
                  On the upgrade to b7 from b6 the first toolboard immediately threw a fault saying the circuit was open circuit showing the temp as -273.1
                  M122 also claimed the board didn’t have an accelerometer
                  Reflashing that board to b6 it shows within a degree of the other board at room temp.
                  But still no accelerometer
                  IDEX CoreXY Duet3 SBC+6HC+1LC
                    Gixxerfast @Fumble
                    @fumble Just to clarify. When downgrading the toolboard to b6 you do so with the main board as well and vice versa?
                    dc42undefined Fumbleundefined 2 Replies Last reply Reply Quote 0
                      dc42 administrators @Gixxerfast
                      @Alex-cr @Fumble @Gixxerfast @jay_s_uk please can you try connecting the thermistor or PT1000 to temp1 on the tool board, change config.g appropriately, and see whether the problem persists. This will help me identify the cause.
                      Fumbleundefined Gixxerfastundefined Alex.crundefined PCRundefined 5 Replies Last reply Reply Quote 0
                      • Fumbleundefined
                        Fumble @dc42
                        @dc42 Yes same using temp1 reports 18.5 with b6 and open circuit with b7
                        • Fumbleundefined
                          Fumble @Gixxerfast
                          @gixxerfast Downgrading I only updated the one toolboard. While I realise it might not be able to collect data using different firmware versions, I would have expected M122 to detect it ok
                            Gixxerfast @dc42
                            @dc42 Oh, mine is working fine with the v1.1 toolboard with a generic pt1000 and b7. I'm just butting in because it's interesting as I have the same setup and it's working fine ...
                            • Fumbleundefined
                              Fumble @dc42
                              @dc42 I notice Alex-cr is running SBC+6HC+1LC as am I while Gixxerfast is Mini5
                              • Alex.crundefined
                                Alex.cr @dc42
                                @dc42 said in [3.4.0b7] Firmware update changes 1LC temp:
                                @dc42 I have confirmed that moving the PT1000 to temp1 did not resolve the issue. The problem persists.
                                • Alex.crundefined
                                  Alex.cr @Alex.cr
                                  Additional issues are occurring now. Once I performed a new heater tuning on this extruder to test the new algorithm I cannot get the heater to turn on.
                                  The M303 completed correctly and I updated my M307 command in my config. Now when I use DWC, G10,M568, or M109/M104 commands the heater will just sit there and not heat.
                                  Sending an M105 command confirms that the temps were requested.
                                  If I send the appropriate M303 command the system will heat/tune and act correctly. Reuploading B6 to the 1LC restores the ability to use the heater.
                                  • leobgundefined
                                    leobg
                                    I can confirm the erratic temperature reading after upgrading to B7 with 1LC v1.1. SBC + 6HC + 1LC. Flashing back to B6 returns thermistor readings to normal. Slice Engineering Hight Temp thermistor (450C).
                                    • PCRundefined
                                      PCR @dc42
                                      @dc42 same here. Dyze 450€ thermistor temp0 on toolboard. Reports open circuit after upgrade
                                        dc42 administrators @PCR
                                        Thanks. Please can those of you with the problem try the following:
                                        1. Install the modified beta7 tool board firmware from https://www.dropbox.com/sh/5ubjszy9fmlvzwu/AAAeOMGP-Yi-Gn9LZwQoPfita?dl=0.
                                        2. Check that the temperature reading is still incorrect.
                                        3. Send M122 B# where # is the CAN address of the tool board.
                                        4. Send M308 S# where # is the sensor number of the thermistor or PT1000 on the tool board.
                                        5. Post the M122 and M308 responses here.
                                        Marshalundefined Fumbleundefined jay_s_ukundefined 3 Replies Last reply Reply Quote 0
                                        • Marshalundefined
                                          Marshal @dc42
                                          @dc42 Hi,
                                          for me beta7+1 fixed the issue.
                                          (theres a small typo in your post - 3. Send M121 B#)
                                          config.g - not changed
                                          M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8
                                          [3.4.0b7]:
                                          M122 B20
                                          Diagnostics for board 20:
                                          Duet TOOL1LC rev 1.0 or earlier firmware version 3.4.0beta7 (2021-12-16 12:25:01)
                                          Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                                          Never used RAM 3648, free system stack 2788 words
                                          Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(delaying,3.0%,57) MAIN(running,91.8%,351) IDLE(ready,0.0%,40) AIN(delaying,4.9%,142), total 100.0%
                                          Last reset 00:02:33 ago, cause: software
                                          Last software reset time unknown, reason: AssertionFailed, available RAM 4592, slot 1
                                          Software reset code 0x0120 ICSR 0x00000000 SP 0x20003cac Task   Freestk 130 bad marker
                                          Stack: 00000544 00023174 00019cb5 20003044 00016e33 20003044 00016505 20000ed0 00000000 00000001 0000828d 200071c8 200071c8 200071e0 00000000 20000f50 000116b3 00022530 000225e8 00021c40 00019c55 200071c8 200071c8 20000f50 00008405 200071d8 000009c6
                                          Driver 0: pos 0, 419.2 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 24, reads 10980, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                                          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                          Peak sync jitter 5/8, peak Rx sync delay 213, resyncs 0/0, no step interrupt scheduled
                                          VIN voltage: min 24.2, current 24.2, max 24.3
                                          MCU temperature: min 33.2C, current 35.9C, max 35.9C
                                          Last sensors broadcast 0x00000002 found 1 97 ticks ago, 0 ordering errs, loop time 0
                                          CAN messages queued 3054, send timeouts 0, received 1386, lost 0, free buffers 37, min 37, error reg 0
                                          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                          Accelerometer: none
                                          I2C bus errors 4509, naks 4509, other errors 4509
                                          M308 S1
                                          Sensor 1 type Thermistor using pin 20.temp0, reading 13.5, last error: success, T:100000.0 B:4725.0 C:7.06e-8 R:2200.0 L:0 H:0
                                          Readings:
                                          [3.4.0b7+1]:
                                          M122 B20
                                          Duet TOOL1LC rev 1.0 or earlier firmware version 3.4.0beta7+1 (2021-12-18 13:47:42)
                                          All averaging filters OK
                                          Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(notifyWait,3.0%,57) MAIN(running,91.8%,341) IDLE(ready,0.0%,40) AIN(delaying,4.9%,142), total 100.0%
                                          Last reset 00:04:12 ago, cause: software
                                          Driver 0: pos 0, 419.2 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 51, reads 60503, writes 11, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                                          Peak sync jitter 4/9, peak Rx sync delay 214, resyncs 0/1, no step interrupt scheduled
                                          MCU temperature: min 37.2C, current 37.6C, max 37.6C
                                          Last sensors broadcast 0x00000002 found 1 137 ticks ago, 0 ordering errs, loop time 0
                                          CAN messages queued 4866, send timeouts 0, received 2276, lost 0, free buffers 37, min 37, error reg 50000
                                          Accelerometer: none
                                          M308 S1
                                          Sensor 1 type Thermistor using pin 20.temp0, reading 25.5, last error: success, T:100000.0 B:4725.0 C:7.06e-8 R:2200.0 L:0 H:0
                                          Readings:
                                          In Progress CoreXY:
                                          • Duet3 6HC
                                          • 1 Toolboard LC1
                                          • Fumbleundefined
                                            Fumble @dc42
                                            After installing that firmware and rebooting everything it gave the correct temperature
                                            Checked I loaded the firmware ok as I'm not the best on linux
