Toolboard 1.1 - Driver not present
@rjenkinsgb
Set stepper current to 100%
Set jerk, accelerations etc. -
Tried with 3.4.0 beta 7
After M122 b121 the driver info is like that:
"Driver 0: pos 6560, 656.0 steps/mm,ok, steps req 6560 done 6560"But the stepper is not working at all.
Check the motor wiring?
The motors on my extruders have the centre two pins swapped compared to the axis motors.
Are you trying to extrude without the temperature being above 160c?
@rjenkinsgb Wirings are ok, tested with 2 different steppers that are working on other boards (duet boards)
@phaedrux Driver not "drive" stepper. I tried with 200°c and using M302
This post is deleted! -
Problem solved....
Is the driver.
I have another toolboard (never used, unboxed and installed) from the same reseller (filafarm.de).
Same wirings, same config, and works like a charm.
So the first Toolboard have a not working driver.
Can a moderator allow (give ok) reseller to replace this board? -
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@phaedrux said in Toolboard 1.1 - Driver not present:
Done. Thanks
