    Mapping PT1000 sensors on Toolboard to Heater Outputs on 6HC
    361
    • ArcadeKillaundefined
      ArcadeKilla
      I am very close to having my machine ready but I am running into one issue. The sensor appears to not exist to the system when mapping my two PT1000 sensors connected to my Toolboard and my two heaters on my 6HC. I get "M308 S1 H999
      Error: M308: Sensor 1 does not exist" and "Error: Temperature reading fault on heater 1: unknown sensor" when trying to interact with them. Here is my config; the S2 is set to be a redundant backup for failures:
      ; configuration file for Duet 3 Mini 5+ (firmware version 3.3) with Duet 3 Toolboard1LC, Rotating Magnet Filament Monitor
      M575 P1 S1 B57600                                                        ; enable support for PanelDue
      G21        ; work in millimeters
      G90        ; send absolute coordinates...
      M83        ; ...but relative extruder moves
      M550 P"duet3"                                                         	 ; set printer name
      M669 K1        ; select CoreXY mode
      ; Tool board (CAN ID #121)
      G4 S6        ; wait for tool board to start
      ; PanelDue Enable
      M575 P1 S1 B57600
      M552 S1        ; enable network
      M586 P0 S1                                                               ; enable HTTP
      M586 P1 S0                                                               ; disable FTP
      M586 P2 S0                                                               ; disable Telnet
      M569 P0.0 S0 D3                                                          ; physical drive 0.0 goes forwards use stealthChop2
      M569 P0.1 S0 D3                                                          ; physical drive 0.1 goes forwards use stealthChop2
      M569 P0.2 S0 D3                                                          ; physical drive 0.2 goes forwards use stealthChop2
      M569 P0.3 S1 D3                                                          ; physical drive 0.3 goes forwards use stealthChop2
      M569 P0.4 S1 D3                                                          ; physical drive 0.4 goes forwards use stealthChop2
      M569 P121.0 S1 D3                                                        ; physical drive 121.5 goes forwards use stealthChop2
      M584 X0.4 Y0.3 Z0.0:0.1:0.2 E121.0                                       ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                                  ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E830.00                                        ; set steps per mm
      M566 X400.00 Y400.00 Z6.00 E120.00 P1                                    ; set maximum instantaneous speed changes (mm/min)
      M203 X10800.00 Y10800.00 Z1000.00 E3600.00                               ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E3600.00                                  ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z800 E800 I30                                           ; set motor currents (mA) and motor idle factor in percent
      M84 S30        ; Set idle timeout
      M208 X0 Y0 Z0 S1                                                         ; set axis minima
      M208 X505 Y500 Z500 S0                                                   ; set axis maxima
      M574 X1 S1 P"121.io2.in"                                                 ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io2.in on toolboard
      M574 Y2 S1 P"io6.in"                                                     ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io6.in
      M574 Z1 S2                                                               ; configure Z-probe endstop for low end on Z
      M950 S0 C"121.io0.out"                                                   ; create servo pin 0 for BLTouch on tool board
      M558 P9 C"121.io0.in" H5 F120 T6000 A5                                   ; set Z probe type to bltouch and the dive height + speeds on tool board
      G31 P500 X-40 Y-30 Z0.9                                                ; set Z probe trigger value, offset and trigger height
      M671 X-4.5:250:500 Y-4.52:500:-4.52 S5                                   ; define positions of Z leadscrews, 5mm maximum correction
      M557 X20:280 Y20:280 P5                                                  ; define 5x5 mesh grid
      ; Bed Heater
      M308 S0 Q10 P"temp0" Y"thermistor" T100000 B3950 A"Bed"                  ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                                       ; create bed heater output on out1 and map it to sensor 0
      M307 H0 B0 S1.00                                                         ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0        ; map heated bed to heater 0
      M143 H0 S120                                                             ; set temperature limit for heater 0 to 120C
      																		 ; Mosquito Magnum+ Separate Heaters Single Tool (Two Sensors)
      ; Two Temperature Sensors
      M308 S1 P"121.temp0" Y"pt1000" A"RightTemp" 						 	 ;Pt1000 located in right side of hot block
      M308 S2 P"121.temp1" Y"pt1000" A"LeftTemp" 								 ;Pt1000 located in left side of hot block
      ; Define Mosquito Magnum+ heaters
      M950 H1 C"out2" T1 														 ;Single Heater
      M950 H2 C"out3" T1 														 ;Second Heater
      ; Define Monitor Temperature Sensor
      M143 H1 P1 S310 T2 A0
      M143 H2 P1 S310 T2 A0
      ;Mosquito Magnum+ Max Temperatures
      M143 H1 S310
      M143 H2 S310
      ;Tool Definition Mosquito Magnum+
      ;M563 P0 D0 H1:2 S"Mosquito Magnum+" F1 									 ;Define Mosquito Magnum+ Tool
      ;T0 																		 ;Set tool 0 as active tool
      ;G10 P0 S0:0 R0:0 														 ;Set tool operating and standby temperatures
      ;; Run Bed PID Tune!! Below is an example for a 300x300 bed
      ;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0
      ;; Run Heater PID Tune!!
      ;; M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0
      M950 F0 C"out5" Q500; create fan 0 on pin out1 on tool board and set its frequency
      M106 P0 C"Watercooling Fan" S1 H1 T45                                    ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"121.out2" Q500                                                 ; create fan 1 on pin out2 on tool board and set its frequency
      M106 P1 C"Layer Fan" S1 H-1                                              ; set fan 1 value. Thermostatic control is turned off
      M563 P0 S"Mosquito Magnum+" D0 H1:2 F1                                   ; define tool 0 with extruder drive 0 heater 1 and fan 1
      G10 P0 X0 Y0 Z0                                                          ; set tool 0 axis offsets
      G10 P0 R0 S0                                                             ; set initial tool 0 active and standby temperatures to 0C
      M302 S180 R180                                                           ; allow extrusion starting from 180C and retractions already from 180C
      ; Accelerometer
      M955 P121.0 I12                                                          ; Accelerometer on tool board, oriented counter-clockwise 90
      ; Filament Monitor
      M591 D0 P3 C"121.io1.in" S1 R70:130 L24.8 E3.0                           ; Duet3D rotating magnet sensor for extruder drive 0 is connected to io1.in on tool board,
        ; enabled, 70% to 130% tolerance, sensitivity 24.8mm.rev, 3mm detection length
      ; Custom settings
      M404 N1.75 D0.4                                                          ; set filament width and nozzle diameter
      Alex.crundefined 1 Reply Last reply Reply Quote 0
      • Alex.crundefined
        Alex.cr @ArcadeKilla
        @arcadekilla
        As far as I am aware, this is a current limitation imposed by RRF. Heaters and their sensors must be present on the same board to function correctly. (I am trying to find the documentation that explains this in detail.)
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        ArcadeKillaundefined 2 Replies Last reply Reply Quote 0
          ArcadeKilla @Alex.cr
          @alex-cr Damn! That may be a serious issue. I cut my PT1000 wires for Toolboard length. I wanted to run the heaters separately, mainly for safety, as it is 100 watts of heater.
            @alex-cr Maybe running one PT1000 off the Toolboard and then running one back to the mainboard...hmmm idk. I wonder if there is a trick to override that.
            • Alex.crundefined
              @arcadekilla
              The only real way around it would be to drive the heaters with an external mosfet off of the toolboard. This way the toolboard does all of the work but power could come from some place besides the toolboard itself.
              Edit: Somthing like this. link text
              ArcadeKillaundefined 1 Reply Last reply Reply Quote 0
                @alex-cr Well damn...seems just running the PT1000s back to the board is the only option, really. The mosfets would defeat the purpose.
                • Alex.crundefined
                  @arcadekilla
                  Not entirely. You can still drive all of your fans and temp sensors from the toolboard itself. The power wires that run to the toolboard could be branched to power the mosfet. This way you don't need to rerun any major wiring back to the mainboard. That being said it might be easier to extend the wires for the PT1000s and call it a day.
                    https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
                    Do you mean these limitations?
